DSS110
DSS110
    BORN(伯恩半导体)
    SOD-123
    肖特基二极管 Single VR=100V IF=1A IR=0.5mA Cj=80pF SOD-123
DSS110 数据手册
DSS110 SURFACE MOUNT SCHOTTKY u BARRIER RECTIFIER SCHOTTKY SOD-123FL ROHS Features  High Current Capability  Low Forward Voltage Drop  High reliability  High temperature soldering guaranteed Mechanical Data     SOD-123 Small Outline Plastic Package Polarity: Color band denotes cathode end Epoxy UL: 94V-0 Mounting Position: Any Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) 单位 Symbol DSS110 Maximum repetitive peak reverse voltage VRRM 100 V Maximum RMS voltage VRMS 7 0 V Maximum DC blocking voltage VDC 100 V Maximum average forward rectified current IF(AV) 1.0 A Non-repetitive Peak forward surge current 8.3 ms single half sine-wave IFSM 25 A VF 0.85 V IR 0.5 5.0 mA mA Cj 80 pF Tj,TSTG -55-+125 ℃ Parameters Max. forward voltage @IF=2.0A Max. reverse current @VDC TA=25℃ TA=100℃ Type junction capacitance VR=4.0V, f=1MHz Operation junction and Storage temperature range Unit Note: 1) Thermal resistance from junction to ambient, PCB mounted. Rev 8: Nov 2014 www.born-tw.com Page 1 of 2 DSS110 AVERAGE FORWARD RECTIFIED CURRENT, AMPERES PEAK FORWARD SURGE CURRENT, AMPERES SURFACE MOUNT SCHOTTKY u BARRIER RECTIFIER SCHOTTKY FIG. 1- FORWARD CURRENT DERATING CURVE 1 0.8 Single Phase Half Wave 60Hz Resistive or inductive Load 0.6 0.4 0.2 0 0 25 50 75 100 125 150 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 30 20 15 10 5.0 175 0 FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 20 10 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 0.1 0.01 0.2 DSS12-DSS14 DSS15-DSS16 DSS17-DSS110 0.4 0.6 0.8 1.0 10 100 NUMBER OF CYCLES AT 60 Hz 1.1 INSTANTANEOUS REVERSE CURRENT, MILLIAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES AMBIENT TEMPERATURE, C FIG. 4-TYPICAL REVERSE CHARACTERISTICS 100 10 TJ=100 C 1 TJ=75 C 0.1 TJ=25 C 0.01 0.001 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 25 1 1 ROHS 2000 SOD-123FL PACKAGE OUTLINE Plastic surface mounted package 1000 100 TJ=25 C 10 0.1 1.0 10 100 REVERSE VOLTAGE,VOLTS Rev 8: Nov 2014 www.born-tw.com Page 2 of 2
DSS110 价格&库存
很抱歉,暂时无法提供与“DSS110”相匹配的价格&库存,您可以联系我们找货
DSS110
  • 20+0.23004
  • 200+0.18339
  • 600+0.15747
  • 3000+0.11330
  • 9000+0.09980
  • 21000+0.09245
库存:53117
DSS110
  • 1+0.13290
  • 3000+0.10590
库存:62049
DSS110
  • 20+0.21087
  • 300+0.16810
  • 1200+0.14434
  • 3000+0.10385
库存:5674
DSS110
  • 20+0.22980
  • 200+0.18280
  • 600+0.15600
  • 3000+0.11230
  • 9000+0.09890
  • 21000+0.09150
库存:15500
