MIKROE-2331
MIKROE-2331
    MIKRO
    MIKROPROGFORKINETIS
MIKROE-2331 数据手册
Page 1 of 2 MikroProg for Kinetis From MikroElektonika Documentation mikroProg™ for Kinetis is a fast programmer and hardware debugger. Smart engineering allows mikroProg™ to support all Kinetis ARM® Cortex™-M4 devices in a single programmer! Outstanding performance, easy operation, elegant design and low price are it’s top features. It is supported in mikroElektronika, as well as in other ARM® compilers. mikroProg for Kinetis Contents ◾ ◾ ◾ ◾ ◾ 1 2 3 4 5 Key features Connecting to a PC mikroProg Suite™ for ARM® software Connecting with a target device Resources Key features ◾ Hardware Debugging ◾ No need for firmware updates ◾ New microcontrollers supported via latest version of mikroProg Suite™ for ARM® software What you see ◾ ◾ ◾ ◾ ◾ ◾ ◾ Flat cable Micro USB connector DATA transceiver indication LED ACTIVE indication LED LINK indication LED POWER indication LED Driver installation mikroProg for Kinetis programmer and debugger Supported A total of 35 Kinetis K MCUs devices Website www.mikroe.com/mikroprog/kinetis/ (http://www.mikroe.com/mikroprog/kinetis/) On-board mikroProg™ requires drivers in order to work. Drivers can be found on our site (http://www.mikroe.com/mikroprog/kinetis/). When you download the drivers, please extract files from the ZIP archive. The folder with extracted files contains folders with drivers for different operating systems. When you locate the drivers, please extract the setup file from the ZIP archive. You should be able to locate the driver setup file. Double click the setup file to begin installation of the programmer drivers. Connecting to a PC After driver installation is complete, you can connect the programmer with your PC using USB cable provided with the package. Green POWER LED should turn ON, indicating the presence of power supply. Amber-colored LINK LED will turn ON when link between mikroProg™ for Kinetis and PC is established. Link can be established only when correct drivers are installed on your PC. mikroProg Suite™ for ARM® software mikroProg™ for Kinetis programmer requires special programming software called mikroProg Suite™ for ARM®. This software is used for programming all of Kinetis ARM® Cortex™-M4 microcontroller families. It features intuitive interface and SingleClick™ programming technology. Software installation is available on following link (http://www.mikroe.com/downloads/get/2589/mikroprog-suite-arm-programming-software-setup-v140.zip). After downloading, extract the package and double click the executable setup file to start the installation. Connecting with a target device For connection with a target device mikroProg™ uses IDC10 JTAG connector. In order to make a proper connection with the target board, it is necessary to pay attention to IDC10 connector pinout. Every pin has a different purpose and for easy orientation IDC10 connector is marked with a little knob and incision between pins number 9 and 7. Resources Page 2 of 2 - mikroProg Suite for ARM (http://www.mikroe.com/downloads/get/2589/mikroprog-suite-arm-programming-software-setup-v140.zip) - MikroC for ARM (http://www.mikroe.com/mikroc/arm/) - mikroBasic for ARM (http://www.mikroe.com/mikrobasic/arm/) - mikroPascal for ARM (http://www.mikroe.com/mikropascal/arm/) Retrieved from "http://docs.mikroe.com/index.php?title=MikroProg_for_Kinetis&oldid=443" ◾ This page was last modified on 20 June 2016, at 19:00. ◾ Content is available under Creative Commons Attribution unless otherwise noted. http://docs.mikroe.com/index.php?title=MikroProg_for_Kinetis&printable=yes 7/11/2016
MIKROE-2331 价格&库存
很抱歉,暂时无法提供与“MIKROE-2331”相匹配的价格&库存,您可以联系我们找货
MIKROE-2331
  • 1+1247.57768
  • 5+1197.65375
库存:1
MIKROE-2331
  • 1+1418.573611+183.10983
