SPC SPLICE
Wire-to-wire splices
Model No.
Applicable wire(reference)
SPC-01
SPC-20
4.2
Q'ty /
reel
0.25
12,000
0.5
10,000
5.5
Tin-plated
0.5∼1.7
SPC-40T
Branching
Dimension L Thickness
(mm)
(mm)
Tin-plated
0.4∼1.4
SPC-20T
SPC-40
L
0.2∼0.5
SPC-01T
Straight
Finish
Total cross sectional area(mm2)
5.7
Tin-plated
Material
Brass
End
This wire-to-wire splice is used extensively
for straight, branching, and end
connections.
RoHS compliance
Note: The “Applicable wire” shown above is for reference only. Contact JST for the
evaluation test on the wire to be used, especially when using special wires
such as solid wires, tin-plated wires, or those of non-annealed copper material.
Contact
Crimping
machine
SPC-01(T)
SPC-20(T)
Applicator
Crimp applicator
Dies
Crimp applicator with dies
MKS-L
MK/SPC-01
APLMK SPC01
MKS-L
MK/SPC-20
APLMK SPC20
AP-K2N
MKS-L
MK/SPC-40
APLMK SPC40
SPC-40(T)
PIERCING SPLICE
Model No.
PSL-40
L
PSL-40T
PSL-60
This splice, like the SPC terminal, has special
channels inside its crimp areas so that
insulation-coated windings (magnet wire like
enamel-coated wire, etc.) can be electrically
connected without removing the insulation
coating. It is suited for connections between
the windings of motors, relays and other
rotating devices, and the connections between
the windings and the leads of such devices.
Contact
Crimping
machine
PSL-40
(T)
PSL-60
(T)
PSL-80
(T)
1
Applicator
Crimp applicator
Dies
MKS-L
MK/PSL-40
APLMK PSL40
MKS-L
MK/PSL-60
APLMK PSL60
AP-K2N
MKS-L
MK/PSL-80
APLMK PSL80
PSL-60T
PSL-80
PSL-80T
0.6∼1.0
0.7∼1.8
1.5∼3.5
Finish
(mm)
(mm)
Q'ty /
reel
5.5
Tin-plated
5.7
0.5
10,000
Tin-plated
5.5
Tin-plated
Material
Brass
RoHS compliance
Note: 1. The applicable wire size (total sectional area) above serves
as a basic guideline. Before use, the performance of this
connector must be tested with the wire that is to be used.
Note: 2. Do not use this connector to connect more than two magnet wires
(enamel-coated wires, etc.).
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
很抱歉,暂时无法提供与“SPC-20T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+0.357441+0.04633
- 10+0.3574410+0.04633
- 50+0.2789850+0.03616
- 100+0.22667100+0.02938
- 500+0.20051500+0.02599
- 1000+0.183081000+0.02373
- 2000+0.183082000+0.02373
- 国内价格
- 20+0.20834
- 200+0.17075
- 600+0.14980
- 2000+0.13727
- 10000+0.12647
- 20000+0.12053
