IMX233-SJTAG
IMX233-SJTAG
    OLIMEX
    OLINUXINO IMX233 SERIAL JTAG
IMX233-SJTAG 数据手册
iMX233-SJTAG S-JTAG adapter compatible with iMX233 iMX233-SJTAG is an adapter which uses just two signals and transoforms them into normal JTAG interface. Using parallel JTAG is tricky as the parallel JTAG signals are shared with SD-CARD SPI signals and if you use parallel JTAG signals you will lose the SD-CARD. This adapter solves the problem. The adapter works both with commercial IDEs and OpenOCD. HARDWARE We can’t release this design as open source as we received private programming logic from Freescale under NDA, so the best we can do is just to produce this adapter at low cost and make it affordable for all OLinuXino developers. FEATURES Option for target powering via PWR_E jumper Easy ways of powering the adapter ‐ from an USB or a JTAG SOFTWARE More info on the SJTAG interface
IMX233-SJTAG 价格&库存
很抱歉,暂时无法提供与“IMX233-SJTAG”相匹配的价格&库存,您可以联系我们找货
