DIO2032MP8
DIO2032MP8
    DIOO(帝奥)
    MSOP-8
    是低噪声、低电压和低功耗的放大器,具有 6MHz 的高增益带宽积,3.6V/μs 的压摆率,在 5V 时每个放大器的静态电流通常为 500μA。设计用于在低电压和低噪声系统中提供最佳性能,所有芯片都能...
DIO2032MP8 数据手册
Rev 1.2 DIO2031/2032/2033/2034/2036 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Features Descriptions Supply Voltage Range: 2.5V to 5.5V The DIO2031 (single), DIO2032 (dual), DIO2033 Low Supply Current: 500µA Typically (single with shutdown), DIO2034 (quad) and Rail-to-Rail Input and Output DIO2036 (Triple) are amplifiers with very low noise, 6MHz High Gain-Bandwidth Product low voltage, and low power operational. The High Slew Rate: 3.6V/µs DIO2031/2/3/4/6 Settling Time to 0.1% with 2V Step: 2.1µs product of 6MHz, a slew rate of 3.6V/µs, and a Overload Recovery Time: 0.9µs quiescent Packages: typically. has current a of high gain-bandwidth 500µA/amplifier at 5V DIO2031 Available in: SOT23-5/SOIC-8 DIO2032 Available in: The DIO2031/2/3/4/6 is designed to provide SOIC-8/MSOP-8/TSSOP-8 optimal performance in low voltage and low noise DIO2033 Available in: SOT23-6/SOIC-8 systems. All these chips provide rail-to-rail output DIO2034 Available in: TSSOP-14/SOIC-14 swing into heavy loads. The input common-mode DIO2036 Available in: QFN4*4-20 voltage range includes ground, and the maximum input offset voltage is 3.5mV for DIO2031/2/3/4/6. Applications Audio Output The DIO2033 has a power-down disable feature Sensor Interface that Active Filters individually. reduces the supply current to 90nA A/D Converters Cellular and Cordless Phones They are specified over the extended industrial Laptops and PDAs temperature range (-40 ℃ Photodiode Amplification operating range is from 2.5V to 5.5V. to +125 ℃ ). The Battery-Powered Instrumentation Ordering Information Order Part Number Top Marking DIO2031ST5 YWXH DIO2031SO8 DIO2031 DIO2032SO8 DIO2032MP8 DIO2032 DIO2032TP8 TA RoHS/Green Package -40 to +125°C SOT23-5 Tape & Reel, 3000 RoHS/Green -40 to +125°C SOIC-8 Tape & Reel, 2500 RoHS/Green -40 to +125°C SOIC-8 Tape & Reel, 2500 RoHS/Green -40 to +125°C MSOP-8 Tape & Reel, 3000 RoHS/Green -40 to +125°C TSSOP-8 Tape & Reel, 3000 DIO2033SO8 DIO2033 RoHS/Green -40 to +125°C SOIC-8 Tape & Reel, 2500 DIO2033ST6 YWXM RoHS/Green -40 to +125°C SOT23-6 Tape & Reel, 3000 RoHS/Green -40 to +125°C SOP-14 Tape & Reel, 2500 RoHS/Green -40 to +125°C TSSOP-14 Tape & Reel, 2500 RoHS/Green -40 to +125°C QFN4*4-20 Tape & Reel, 5000 DIO2034SO14 DIO2034 DIO2034TP14 DIO2036QN20 www.dioo.com DIO2036 © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 DIO2031/2032/2033/2034/2036 DIO2036 OUTF 16 10 OUTD VIN_F 17 9 OUTC VIP_F 18 8 VIN_C VSS 19 7 VIP_C VIP_A 20 6 VIP_B QFN4*4-20 Figure 1 Pin assignment (Top View) www.dioo.com © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Pin Assignments DIO2031/2032/2033/2034/2036 Pin name Description +Vs Positive supply -Vs Negative supply +IN (+INA/+INB/+INC/+IND) Positive Input (channel A/B/C/D) -IN (-INA/-INB/-INC/-IND) Negative Input (channel A/B/C/D) OUT (OUTA/OUTB/OUTC/OUTD) Output (channel A/B/C/D) DISABLE High worked, Low not work. NC Not Connect Absolute Maximum Ratings Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maxim rating conditions for extended periods may affect device reliability. Parameter Rating Unit 7.5 V (V-)-0.5 to (V+)+0.5 V -65 to 150 °C Junction Temperature 150 °C Lead Temperature Range 260 °C Supply Voltage Input Voltage Storage Temperature Range HBM, JEDEC: JESD22-A114 8 CDM, JEDEC: JESD22-C101 2 ESD kV Recommended Operating Conditions The Recommended Operating Conditions table defines the conditions for actual device operation to ensure optimal performance to the datasheet specifications. DIOO does not recommend exceeding them or designing to Absolute Maximum Ratings. Parameter Supply Voltage Input Voltage Operating Temperature Range www.dioo.com Rating Unit 2.5 to 5.5 V 0 to 5 V -40 to 125 °C © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Pin Description DIO2031/2032/2033/2034/2036 Typical value: V+=5V, RL=100kΩ to V+/2, TA = 25°C, unless otherwise specified. Symbol Parameter Conditions Min. Typ. Max. Unit -3.5 0.7 3.5 mV INPUT CHARACTERISTICS VOS Input Offset Voltage TA=25°C IB Input Bias Current -40°C≤TA≤125°C, V+=2.5V to 5.5V 1 10 pA IOS Input Offset Current -40°C≤TA≤125°C, V+=2.5V to 5.5V 1 10 pA VCM Common Mode Voltage Range V+=5.5V 5.6 V Common Mode Rejection Ratio -40°C≤TA≤125°C, Vs = 5.5V, VCM=-0.1V to 4V -40°C≤TA≤125°C, Vs=5.5V, VCM=-0.1V to 5.6V CMRR AOL ∆VOS/∆T -0.1 75 90 dB 66 90 dB RL=600Ω, Vo=0.15V to 4.85V 92 100 dB RL=10KΩ, Vo=0.05V to 4.95V 100 110 dB 2.7 µV/°C Open Loop Voltage Gain Input Offset Voltage Drift -40°C≤TA≤125°C OUTPUT CHARACTERISTICS Output Voltage Swing from Rail RL=600Ω -40°C≤TA≤125°C 0.1 RL=10kΩ -40°C≤TA≤125°C 0.015 IOUT Output Current V+= 5V Ro Closed Loop Output Impedance F=100kHz, G=+1 45 V 48 mA 2.6 Ω Turn-On Time 6.2 nS Turn-Off Time 1.4 nS POWER-DOWN DISABLE DISABLE Voltage Off 1.9 DISABLE Voltage On 2 V V POWER SUPPLY PSRR IS Operating Voltage Range 2.5 Power Supply Rejection Ration 70 Supply Current per Channel/Amp 5.5 94 V+= 5V , -40°C≤TA≤125°C 350 V+= 2.5V , -40°C≤TA≤125°C 320 V dB µA DYNAMIC PERFORMANCE GBP SR tS Gain Bandwidth Product RL=10kΩ Slew Rate RL=600Ω, G=1, 2V Output Step Setting Time RL=600Ω, G=1, 2V Output Step 6 MHz 3.6 V/µs 1 µs NOISE PERFORMANCE THD en Total Harmonic Distortion Voltage Noise Density f=10kHz, 1V Output Step, RL=600Ω and 100pF 0.015 f=1kHz, V+= 5V 20 f=10kHz, V+= 5V 12 % nV/√Hz Specifications subject to change without notice. www.dioo.com © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Electrical Characteristics DIO2031/2032/2033/2034/2036 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Typical Application Figure 2 Indirectly Driving Heavy Capacitive Load Figure 3 Indirectly Driving Heavy Capacitive Load with DC Accuracy +Vs Vn +Vs 10uF 10uF 0.1uF 0.1uF - Vout Vn DIO2031 Vp Vout DIO2031 Vp + - + 10uF 0.1uF -Vs(GND) Figure 4 Amplifier with Bypass Capacitors www.dioo.com © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 DIO2031/2032/2033/2034/2036 Typical value: V+=5V, RL=100kΩ to V+/2, TA = 25°C, unless otherwise specified. Supply Voltage vs. Supply Current Input Voltage vs. Supply Current Temperature vs. Input Offset Voltage www.dioo.com Temperature vs. Supply Current Common Mode Voltage vs. Input Offset Current CMRR vs. Frequency © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Typical Performance Characteristics DIO2031/2032/2033/2034/2036 GBW vs. Frequency Over Load Recover(Positive) www.dioo.com Maximum Output Voltage vs. Operating Voltage Slew Rate Over Load Recover(Negative) © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Maximum Output Voltage Swing vs. Frequency DIO2031/2032/2033/2034/2036 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.25 A1 0 0.15 A2 1.00 1.10 1.20 A3 0.60 0.65 0.70 b 0.36 0.50 b1 0.36 0.38 0.45 c 0.14 0.20 c1 0.14 0.15 0.16 D 2.826 2.926 3.026 E 2.60 2.80 3.00 E1 1.526 1.626 1.726 e 0.90 0.95 1.00 e1 1.80 1.90 2.00 L 0.35 0.45 0.60 L1 0.59REF L2 0.25BSC R 0.10 R1 0.10 0.25 Θ 0° 8° Θ1 3° 5° 7° Θ2 6° 14° www.dioo.com © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: SOT-23-5 DIO2031/2032/2033/2034/2036 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.25 A1 0 0.15 A2 1.00 1.10 1.20 A3 0.60 0.65 0.70 b 0.36 0.50 b1 0.36 0.38 0.45 c 0.14 0.20 c1 0.14 0.15 0.16 D 2.826 2.926 3.026 E 2.60 2.80 3.00 E1 1.526 1.626 1.726 e 0.90 0.95 1.00 e1 1.80 1.90 2.00 L 0.35 0.45 0.60 L1 0.59REF L2 0.25BSC R 0.10 R1 0.10 0.25 Θ 0° 8° Θ1 3° 5° 7° Θ2 6° 14° www.dioo.com © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: SOT-23-6 DIO2031/2032/2033/2034/2036 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.35 1.55 1.75 A1 0.10 0.15 0.25 A2 1.25 1.40 1.65 A3 0.50 0.60 0.70 b 0.38 0.51 b1 0.37 0.42 0.47 c 0.17 0.25 c1 0.17 0.20 0.23 D 4.80 4.90 5.00 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e 1.27BSC L 0.45 0.60 0.80 L1 1.04REF L2 0.25BSC R 0.07 R1 0.07 h 0.30 0.40 0.50 0° 8° Θ 15° 17° 19° Θ1 11° 13° 15° Θ2 15° 17° 19° Θ3 11° 13° 15° Θ4 www.dioo.com © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: SOIC-8 DIO2031/2032/2033/2034/2036 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.10 A1 0 0.15 A2 0.75 0.85 0.95 A3 0.25 0.35 0.39 b 0.28 0.37 b1 0.27 0.30 0.33 c 0.15 0.20 c1 0.14 0.15 0.16 D 2.90 3.00 3.10 E 4.70 4.90 5.10 E1 2.90 3.00 3.10 e 0.55 0.65 0.75 L 0.40 0.60 0.80 L1 0.95REF L2 0.25BSC R 0.07 R1 0.07 0° 8° Θ 9° 12° 15° Θ1 www.dioo.com © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: MSOP-8 DIO2031/2032/2033/2034/2036 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 1.20 A1 0.05 0.15 A2 0.90 1.00 1.05 A3 0.34 0.44 0.54 b 0.20 0.28 b1 0.20 0.22 0.24 c 0.10 0.19 c1 0.10 0.13 0.15 D 2.83 2.93 3.03 E 6.20 6.40 6.60 E1 4.30 4.40 4.50 e 0.65BSC L 0.45 0.60 0.75 L1 1.00REF L2 0.25BSC R 0.09 R1 0.09 S 0.20 θ1 0° 8° θ2 10° 12° 14° θ3 10° 12° 14° www.dioo.com © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: TSSOP-8 DIO2031/2032/2033/2034/2036 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A - - 1.20 A1 0.05 - 0.15 A2 0.90 1.00 1.05 A3 0.34 0.44 0.54 b 0.20 - 0.28 b1 0.20 0.22 0.24 c 0.10 - 0.19 c1 0.10 0.13 0.15 D 4.86 4.96 5.06 E 6.20 6.40 6.60 E1 4.30 4.40 4.50 e L www.dioo.com 0.65BSC 0.45 0.60 L1 1.00REF L2 0.25BSC 0.75 R 0.09 - - R1 0.09 - - S 0.20 - - Θ1 0° - 8° Θ2 10° 12° 14° Θ3 10° 12° 14° © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: TSSOP-14 DIO2031/2032/2033/2034/2036 COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN MAX A 1.35 1.60 1.75 A1 0.10 0.15 0.25 A2 1.25 1.45 1.65 A3 0.55 0.65 0.75 b 0.36 - 0.49 b1 0.35 0.40 0.45 c 0.17 - 0.25 c1 0.17 0.20 0.23 D 8.53 8.63 8.73 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e L www.dioo.com NOM 1.27BSC 0.45 0.60 L1 1.04REF L2 0.25BSC - 0.80 R 0.07 - R1 0.07 - - h 0.30 0.40 0.50 Θ 0° - 8° Θ1 6° 8° 10° Θ2 6° 8° 10° Θ3 5° 7° 9° Θ4 5° 7° 9° © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: SOIC-14 DIO2031/2032/2033/2034/2036 QFN-20 D2 h 1 2 EXPOSE THERMAL PAD ZONE e www.dioo.com A1 c A Nd COMMON DIMENSIONS (UNITS OF MEASURE=MILLIMETER) Symbol MIN NOM MAX A 0.70 0.75 0.80 A1 0.02 0.05 b 0.18 0.25 0.30 c 0.18 0.20 0.25 D 3.90 4.00 4.10 D2 2.55 2.65 2.75 e 0.50BSC Ne 2.00BSC Nd 2.00BSC E 3.90 4.00 4.10 E2 2.55 2.65 2.75 L 0.35 0.40 0.45 h 0.30 0.35 0.40 L/F 载体尺 114X114 寸(mil) © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers Physical Dimensions: DIO2031/2032/2033/2034/2036 Dioo is a professional design and sales corporation for high-quality and performance analog semiconductors. The company focuses on industry markets, such as, cell phone, handheld products, laptop, and medical equipment and so on. Dioo’s product families include analog signal processing and amplifying, LED drivers and charger IC. Go to http://www.dioo.com for a complete list of Dioo product families. For additional product information, or full datasheet, please contact with our Sales Department or Representatives. www.dioo.com © 2017 DIOO MICROCIRCUITS CO., LTD DIO2031/2032/2033/2034/2036• Rev. 1.2 500µA, 6MHz, Rail-to-Rail I/O CMOS Operational Amplifiers CONTACT US
DIO2032MP8 价格&库存
很抱歉,暂时无法提供与“DIO2032MP8”相匹配的价格&库存,您可以联系我们找货
