DWCM5412P
DWCM5412P
    DOWO(东沃电子)
    DFN10L_2.6X1.4MM
    EMI/RFI滤波器 DFN10L_2.6X1.4MM
DWCM5412P 数据手册
DWCM5412P ESD&CM Filter Features Two Differential Channels Common-Mode EMI Filter with Integrated ESD Protection ⚫ Large Differential Mode Bandwidth with Cutoff Frequency:4 GHz ⚫ High Common Mode Stop Band Attenuation ⚫ Provides ESD Protection to IEC61000−4−2 Level 4, ±15 kV Contact 1 1 ⚫ Discharge ⚫ Low Channel Input Capacitance Provides Superior Impedance Matching Performance ⚫ Low Channel Resistance: 6.0Ω ⚫ Maximum Package Height: 0.5 mm DFN2.6X1.35-10L IEC COMPATIBILITY (EN61000-4) ⚫ IEC 61000-4-2 (ESD) ±20kV (air), ±15kV (contact)+ ⚫ IEC 61000-4-4 (EFT) 40A (5/50ns) ⚫ IEC 61000-4-5 (Lightning) 4A (8/20μs) Mechanical Characteristics Applications ⚫ 1.35 x 2.6 mm DFN-10L package ⚫ USB 3.0 ⚫ Pb−Free Package Marking : Marking Code ⚫ HDMI 1.3/1.4/2.0 /DVI Display ⚫ Packaging : Tape and Reel per EIA 481 ⚫ MIPI D−PHY/M-PHY ⚫ RoHS Compliant ⚫ eSATA, MHL Schematic & PIN Configuration 1 / 7 DWCM5412P ESD&CM Filter Pin Description PIN number Description PIN number Description 1 In_1+ (to Connector) 6 Out_2- (to IC) 2 In_1- (to Connector) 7 Out_2+ (to IC) 3 GND 8 GND 4 In_2+ (to Connector) 9 Out_1- (to IC) 5 In_2- (to Connector) 10 Out_1+ (to IC) Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp = 8/20μs ) PPP 60 Watts Peak Pulse Current( tp = 8/20μs ) IPP 4 A DC Current per Line ILINE 100 mA TJ -55 to + 85 ℃ TSTG -55 to +150 ℃ Operating Temperature Storage Temperature Electrical Parameters (T=25℃ ) Symbol Parameter IPP Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR I IF Reverse Stand-Off Voltage Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IF Forward Current VF Forward Voltage @ IF VC VBR VRWM V IR VF IT IPP 2 / 7 DWCM5412P ESD&CM Filter Electrical Characteristics DWCM5412P Parameter Reverse Stand-Off Voltage Reverse Breakdown Voltage Symbol Conditions Min Typ VRWM VBR IT=1mA 5.6 Max Units 5 V 9 V 500 nA 1.5 V Reverse Leakage Current IR VRWM= 5V, T=25℃ Forward Voltage VF IF=10mA Channel Input Capacitance to Ground(Pins 1, 2, 4, 5 to Pins 3, 8) CIN VR = 0V, f = 1MHz 0.8 1.0 pF Clamping Voltage VC IPP=1A, tp=8/20μs 10 15 V ESD Clamping Voltage1 VC IPP = 4A tp = 0.2/100ns 9.5 V ESD Clamping Voltage1 VC IPP = 16A tp = 0.2/100ns 15.5 V Dynamic Resistance1,2 RDYN TLP=0.2/100ns I/O to Gnd 0.5 Ω Channel Resistance(Pins 1−10, 2−9, 4 −7 and 5−6) RCH 6.0 Ω Differential Mode Cut−off Frequency f3dB 50Ω Source and Load Termination 4.0 GHz @ 1GHz 23 dB Common Mode Stop Band Attenuation Fatten 0.5 Note: 1、TLP Setting:tp=100ns, tr=0.2ns, ITLP and VTLP sample window:t1=70ns to t2=90ns. 2、Dynamic resistance calculated from IPP=4A to IPP=16A using “Best Fit” 3 / 7 DWCM5412P ESD&CM Filter Typical Characteristics Figure 1: Differential attenuation versus frequency (Z0 diff = 100 Ω) Figure 2: Common mode attenuation versus frequency (Z0 com = 50 Ω) Figure 3: USB 3.0 Eye Diagram Test for 5Gbps Data Rate Figure 4: HDMI 2.0 Eye Diagram Test for 6Gbps Data Rate 4 / 7 DWCM5412P ESD&CM Filter Figure 6: Power Derating Curve 10 110 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) Figure 5: Peak Pulse Power vs. Pulse Time 1 60w 8/20µs Waveform 0.1 0.01 100 90 80 70 60 50 40 30 20 10 0 td – Pulse Duration - µs Ambient Temperature - TA (℃) Figure 7: Pulse Waveform Figure 8: Clamping Voltage vs. Peak Pulse Current 110 90 I pp 80 70 e-t 60 Percent Clamping Voltage -VC(V) Waveform Paramters tr=8µs td=20µs 100 50 40 td=Ipp/2 30 20 10 28 26 24 22 20 18 16 14 12 10 8 6 4 2 0 0 0 1 2 3 4 Peak Pulse Current -Ipp(A) Time (µs) Figure 10: TLP I-V Curve Figure 9: Capacitance vs. Reverse Voltage 2.5 2 TLP Current (A) Capacitance–Cj (pF) f=1 MHz 1.5 I/O Pin to Gnd 1 0.5 0 0 1 2 3 Reverse Voltage–VR (V) 4 5 TLP Voltage (V) 5 / 7 DWCM5412P ESD&CM Filter Soldering Parameters Reflow Condition Pre Heat Temperature Min (Ts(min)) Temperature Max (Ts(max)) Time (min to max) (ts ) Average ramp up rate (Liquidus Temp) (T L) to peak TS(max) to TL——Ramp-up Rate Temperature (TL) (Liquidus) Reflow Temperature (tL) Peak Temperature (TP) Pb – Free assembly 150°C 200°C 60 – 190 secs 5°C/second max 5°C/second max 217°C 60 – 150 seconds 260+0/-5 °C Time within actual peak Temperature (tp ) 20 – 40 seconds Ramp-down Rate Time 25°C to peak Temperature (T P) Do not exceed 5°C/second max 8 minutes Max. 280°C Reflow Condition 6 / 7 DWCM5412P ESD&CM Filter Outline Drawing –DFN-10L 1 D 1 A PIN1 INDICATOR (LASER MARK) E DFN2.6X1.35-10L A A1 SEATING PLANE C MILLIMETERS SYMBOL e 1 5 L 10 b MIN NOM MAX A 0.45 0.50 0.55 A1 0.00 0.02 0.05 b 0.15 0.20 0.25 D 2.55 2.60 2.65 E 1.30 1.35 1.40 e 0.50 BSC NOTES: L 1. CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES). 0.40 0.50 0.60 NOTES: 0.5 1. CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN 0.7 DEGREES). 2. THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY. 1.75 CONSULT YOUR MANUFACTURING TO ENSURE YOUR COMPANYS MANNUFACTURING GUIDELINES ARE MET. 0.2 Footprint (dimensions in mm) Marking Codes Part Number DWCM5412P CM1=Specific Device Code Marking Code XXX= Lot Code Package Information Qty:3k/Reel 7 / 7
DWCM5412P 价格&库存
很抱歉,暂时无法提供与“DWCM5412P”相匹配的价格&库存,您可以联系我们找货
