STD15P6F6AG
STD15P6F6AG
    LEIDITECH(雷卯电子)
    TO-252(DPAK)
    STD15P6F6AG
STD15P6F6AG 数据手册
STD15P6F6AG -100V P-Channel Enhancement Mode MOSFET Description Dimensions TO-252 The STD15P6F6AG uses advanced trench technology to provide excellent RDS(ON), low gate charge and operation with gate voltages as low as 4.5V. This device is suitable for use as a Battery protection or in other Switching application. General Features VDS = -100V ID =-15A Pin Configuration RDS(ON) < 185mΩ @ VGS=10V (Type:145mΩ) Application Brushless motor Load switch Uninterruptible power supply Package Marking and Ordering Information Product ID Pack Marking Qty(PCS) STD15P6F6AG TO-252 AP15P10D XXX YYYY 2500 Absolute Maximum Ratings (TC=25℃unless otherwise noted) Symbol Parameter Rating Units VDS Drain-Source Voltage -100 V VGS Gate-Source Voltage ±20 V ID@TC=25℃ Continuous Drain Current, VGS @ -10V1 -15 A ID@TC=100℃ Continuous Drain Current, VGS @ -10V1 -12 A IDM Pulsed Drain Current2 -45 A EAS Single Pulse Avalanche Energy3 56 mJ IAS Avalanche Current -15 A PD@TC=25℃ Total Power Dissipation4 50 W TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ RθJA Thermal Resistance Junction-Ambient 1 62.5 ℃/W RθJC Thermal Resistance Junction-Case1 2.5 ℃/W Rev : 01.08.2021 1/5 www.leiditech.com STD15P6F6AG P-Channel Electrical Characteristics (TJ =25 ℃, unless otherwise noted) Symbol Parameter Test Condition Min. Typ Max. Uni ts BVDSS Drain-Source Breakdown Voltage VGS = 0V, ID = -250μA -100 - - V IDSS Zero Gate Voltage Drain Current VDS = -80V, VGS = 0V - - 1 μA IGSS Gate to Body Leakage Current VDS = 0V, VGS = ±20V - - ±100 nA VGS(th) Gate Threshold Voltage VDS = VGS, ID = -250μA -1.0 - -2.5 V RDS(on) Static Drain-Source On-Resistance note1 VGS = -10V, ID = -2A - 145 185 VGS = -4.5V, ID = -1A - 170 200 Ciss Input Capacitance - 1545 - pF Coss Output Capacitance - 37 - pF Crss Reverse Transfer Capacitance - 25 - pF Qg Total Gate Charge - 27 - nC - 5.3 - nC - 3.2 - nC - 10 - ns - 27 - ns - 288 - ns - 88 - ns - - -18 A VGS = 0V, IS =-2A - - -1.3 V VGS = 0V, Isd= -6A, di/dt =100A/μs - 40 - nS - 28 - nC Qgs Gate-Source Charge Qgd Gate-Drain(“Miller”) Charge td(on) Turn-On Delay Time tr Turn-On Rise Time td(off) Turn-Off Delay Time tf Turn-Off Fall Time IS VSD VDS = -50V, VGS = 0V, f = 1.0MHz VDD = -50V, ID = -2A, VGS = -10V VDS = -50V, ID = -2A RG=4.5Ω, RL=25Ω VGEN = - 10 V Maximum Continuous Drain to Source Diode Forward Current Drain to Source Diode Forward Voltage trr Reverse Recovery Time Qrr Reverse Recovery Charge note1 mΩ Note : 1、The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper. 2、The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2% 3、The EAS data shows Max. rating . The test condition is V DD =-72V,VGS =-10V,L=0.1mH,IAS =-15A 4、The power dissipation is limited by 150℃ junction temperature 5、The data is theoretically the same as I D and I DM , in real applications , should be limited by total power dissipation. Rev : 01.08.2021 2/5 www.leiditech.com STD15P6F6AG Typical Characteristics Rev : 01.08.2021 3/5 www.leiditech.com STD15P6F6AG Rev : 01.08.2021 4/5 www.leiditech.com STD15P6F6AG Package Mechanical Data:TO-252-3L E A B2 Dimensions Ref. C2 L D H V2 D1 V1 A2 V1 2.50 0.083 0.098 A2 0 0.10 0 0.004 B 0.66 0.86 0.026 0.034 B2 5.18 5.48 0.202 0.216 C 0.40 0.60 0.016 0.024 C2 0.44 0.58 0.017 0.023 D 5.90 6.30 0.232 0.248 6.80 0.252 5.30REF 0.209REF 0.268 E 6.40 E1 4.63 G 4.47 4.67 H 9.50 10.70 0.374 0.421 L 1.09 1.21 0.043 0.048 L2 1.35 1.65 0.053 0.182 0.176 7° 0.184 0.065 7° 0° V2 DETAIL A Max. 2.10 V1 L2 Typ. Min. D1 DETAIL A Inches Max. V1 C E1 Typ. Min. A B G Millimeters 6° 0° 6° TO-252 Reel Spectification-TO-252 B D 0 P0 P2 E Ref. t1 A A D1 B0 F W Dimensions T K0 P1 A0 B 5° Φ3 29 A A B B 20 Φ13 Millimeters Inches Min. Typ. Max. Min. Typ. Max. W 15.90 16.00 16.10 0.626 0.630 0.634 E 1.65 1.75 1.85 0.065 0.069 0.073 F 7.40 7.50 7.60 0.291 0.295 0.299 D0 1.40 1.50 1.60 0.055 0.059 0.063 0.063 D1 1.40 1.50 1.60 0.055 0.059 P0 3.90 4.00 4.10 0.154 0.157 0.161 P1 7.90 8.00 8.10 0.311 0.315 0.319 P2 1.90 2.00 2.10 0.075 0.079 0.083 A0 6.85 6.90 7.00 0.270 0.271 0.276 B0 10.45 10.50 10.60 0.411 0.413 0.417 K0 2.68 2.78 2.88 0.105 0.109 0.113 T 0.24 t1 0.10 10P0 39.80 0.27 0.009 0.011 0.004 40.00 40.20 1.567 1.575 1.583 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.08.2021 5/5 www.leiditech.com
STD15P6F6AG
物料型号:STD15P6F6AG
器件简介:Leiditech公司的P-Channel Enhancement Mode MOSFET,特点是优秀的导通电阻RDS(ON)、低栅极电荷和可在低至4.5V的栅极电压下工作。适用于电池保护或其他开关应用,采用先进的沟道技术。
引脚分配:G(栅极)、S(源极)、D(漏极)。
参数特性: - 漏源电压 V_D_S = -100V - 漏极电流 I_D = -15A - RDS(ON) < 185mΩ @ VGS=10V (典型值:145mΩ)
功能详解:该器件适用于无刷电机负载开关、不间断电源等应用。
应用信息:无刷电机、负载开关、不间断电源。
封装信息:TO-252,包括详细的封装尺寸和卷轴规格。
电气特性表中提供了详细的测试条件和参数,如漏源击穿电压、栅极阈值电压、导通电阻、输入电容、输出电容、反向传输电容、栅极电荷等。还包括了典型特性图,如输出特性、导通电阻与栅极电压的关系、结温与导通电阻的关系、反向二极管的正向特性、栅极阈值电压与结温的关系等。
机械数据部分提供了TO-252-3L封装的详细尺寸信息。
STD15P6F6AG 价格&库存
很抱歉,暂时无法提供与“STD15P6F6AG”相匹配的价格&库存,您可以联系我们找货
