S23T24C – ESD Protection Diode
Feature
280 Watts Peak Pulse Power per Line (tp=8/20μs)
Solid-state silicon-avalanche technology
Bidirectional configurations
Low leakage current
Low clamping voltage
IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 6A (8/20μs)
Applications
Mechanical Data
Data lines
Automatic Teller Machines
Net works
Power line
CAN/LIN bus protection
SOT-23 package
Molding compound flammability rating: UL94V-0
Marking: Marking Code
Packaging: Tape and Reel
RoHS Compliant
Schematic and PIN Configuration
Maximum Rating
Parameter
Symbol
IEC61000-4-2 ESD Voltage – Air Mode
VESD(1)
IEC61000-4-2 ESD Voltage – Contact Mode
Peak Pulse Power
Limit
±30
±30
Unit
kV
PPP(2)
280
W
TL
260
°C
Junction Temperature
TJ
-55~125
°C
Storage Temperature Range
Tstg
-55~125
°C
Maximum Lead Solder Temperature (10 seconds duration)
Note:
1.
2.
3.
Device stressed with ten non-repetitive ESD pulses.
Non-repetitive current pulse 8/20s exponential decay waveform according to IEC61000-4-5.
All ratings are measured at environmental temperature of TA = 25°C unless otherwise noted.
新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan.
TEL: +886-3-5643931 FAX: +886-3-5644624
http://www.pttc.com.tw
Page: 1 of 4
2018/03/21
Rev: B
Electrical Characteristics (T=25℃)
Parameter
Reverse Stand-off Voltage
Reverse Breakdown Voltage
Symbol
Test Conditions
Min
Typ
VRWM(1)
VBR
IT = 1mA
26.7
Reverse Leakage Current
IR
VRWM = 24V
Peak Pulse Current
IPP
Clamping Voltage
VC
IPP = 6A
Junction Capacitance
CJ
VR = 0V, f = 1MHz
Max
Unit
24
V
30
34
V
0.1
0.5
μA
12
6
A
48
V
15
pF
Note:
1.
2.
3.
Other voltages available upon request.
Electrical Parameters
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
Working Peak Reverse Voltage
IR
Maximum Reverse Leakage Current @ VRWM
VBR
Breakdown Voltage @ IT
IT
Test Current
Page: 2 of 4
2018/03/21
Rev: B
Typical Characteristics
Page: 3 of 4
2018/03/21
Rev: B
SOT-23 Package Outline Dimensions
Symbol
A
Dimensions (mm)
Dimensions (inch)
Min
Max
Min
Max
0.900
1.150
0.035
0.045
A1
0.100
0.004
A2
0.900
1.050
0.035
0.041
D
2.800
3.000
0.110
0.118
b
0.300
0.500
0.012
0.020
E
2.250
2.550
0.089
0.100
E1
1.200
1.400
0.047
0.055
e
0.950 BSC
0.037 BSC
L
0.300
0.500
0.012
0.020
0°
8°
0°
8°
Marking
Packaging Information
Order Code
Packaging
Reel Size
PCS/Reel
S23T24C
SOT-23
7 inch
3,000
Page: 4 of 4
2018/03/21
Rev: B
很抱歉,暂时无法提供与“S23T24C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.55610
- 50+0.43946
- 150+0.38114
- 500+0.33740
- 3000+0.30240
- 6000+0.28491
