PESDNC2FD7VB
PESDNC2FD7VB
    PRISEMI(上海芯导电子)
    DFN1006-2
    双向ESD 7V截止 峰值浪涌电流:8A@8/20US
PESDNC2FD7VB 数据手册
PESDNC2FD7VB Bi-directional 7V Normal Capacitance ESD Protector Description The PESDNC2FD7VB protects sensitive semiconductor components from damage or upset due to electrostatic discharge (ESD) and other voltage induced transient events. They feature large cross-sectional area junctions for conducting high transient currents, offer desirable electrical characteristics for board level protection, such as fast response time, low operating voltage. It gives designer the flexibility to protect one bi-directional DFN1006-2L(Bottom View) line in applications where arrays are not practical. Feature  110W peak pulse power per line (tP = 8/20μs)  DFN1006-2L package  Replacement for MLV(0402)  Bidirectional configurations  Response time is typically < 1ns  Low clamping voltage  RoHS compliant  Transient protection for data lines to PD Marking (Top View) IEC61000-4-2(ESD) ±30kV(air), ±30kV(contact); IEC61000-4-4 (EFT) 40A (5/50ns) Applications  Cellular phones  Portable devices  Digital cameras  Power supplies Pin 1 Pin 2 Circuit Diagram Mechanical Characteristics  Mounting position: Any  Qualified max reflow temperature:260℃  Device meets MSL 1 requirements  DFN1006-2L without plating Rev.06.3 1 www.prisemi.com ESD Protector PESDNC2FD7VB Electronics Parameter Symbol VRWM IR VBR Parameter Peak Reverse Working Voltage Reverse Leakage Current @ VRWM IPP I Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP PPP Peak Pulse Power CJ Junction Capacitance IF Forward Current VF Forward Voltage @ IF IT IR VC VBR VRWM V IR IT VRWM VBR VC IPP Electrical characteristics per line@25℃ (unless otherwise specified) Parameter Symbol Peak Reverse Working Voltage VRWM Breakdown Voltage Conditions VBR IT = 1mA Reverse Leakage IR VRWM= 7V Clamping Voltage(1) VC TLP=16A, tp=100ns Dynamic Resistance(1) Clamping Voltage(2) Junction Capacitance Min. 7.5 RDYN VC CJ Typ. Max. Unit 7 V 10.5 V 1.0 μA 17 V 0.35 Ω IPP=3A,tp=8/20μs 11.5 14 V IPP=8A,tp=8/20μs 14.5 18 V VR=0V f = 1MHz 21 pF Notes:1. TLP parameter: Z0=50Ω,tp=100ns,tr=2ns,averaging window from 60ns to 80ns. RDYN is calculated from 4A to 16A. 2. Non-repetitve current pulse, according to IEC61000-4-5. Absolute maximum rating@25℃ Rating Symbol Value Unit Peak Pulse Power (tp=8/20μs) Ppp 110 W Peak Pulse Current(tp=8/20μs) Ipp 8 A Operating Temperature TJ -55 to 150 ℃ Storage Temperature TSTG -55 to 150 ℃ ESD Protection-Contact Discharge VESD ±30 kV ESD Protection-Air Discharge VESD ±30 kV Rev.06.3 2 www.prisemi.com ESD Protector PESDNC2FD7VB tf=8μs 100 100 80 60 % Of Rated Power IPP – Peak Pulse Current - % of IPP Typical Characteristics tP =20μs(IPP /2) 40 20 0 80 60 40 20 0 5 10 15 20 25 0 30 0 25 50 t - Time -μs 75 100 125 150 TL – Lead Temperature - ℃ Fig 1. Pulse Waveform Fig 2. Power Derating Curve 24 16 22 18 VC-Clamping Voltage (V) C-Junction capacitance (pF) 20 16 14 12 10 8 6 12 8 Pulse waveform: tp=8/20μs 4 4 2 0 0 -7 -6 -5 -4 -3 -2 -1 0 1 2 3 4 5 6 0 7 1 2 3 4 7 6 5 8 9 IPP-Peak pulse current (A) VR-Reverse voltage (V) . Fig 3. Capacitance vs. Reveres voltage Fig 4. Clamping voltage vs. Peak pulse current 1000 30 25 20 100 10 Current (A) Peak Pulse Power (W) 15 5 0 -5 -10 10 -15 -20 -25 1 1 10 100 1000 Pulse Duration(μs) -20 -15 -10 -5 0 5 10 15 20 Voltage (V) Fig 5. Non-Repetitive Peak Pulse Power vs. Pulse time Rev.06.3 -30 -25 3 Fig 6. TLP Measurement www.prisemi.com 25 ESD Protector Rev.06.3 PESDNC2FD7VB Fig 7. ESD clamping voltage Fig 8. ESD clamping voltage (IEC61000-4-2 +8kV contact) (IEC61000-4-2-8kV contact) 4 www.prisemi.com ESD Protector PESDNC2FD7VB Temperature of Soldering Solder Reflow Recommendation Remark: Pb free for 260℃;Pb for 245℃. PCB Design For TVS diodes a low-ohmic and low-inductive path to chassis earth is absolutely mandatory in order to achieve good ESD protection. Novices in the area of ESD protection should take following suggestions to heart:  Do not use stubs, but place the cathode of the TVS diode directly on the signal trace.  Do not make false economies and save copper for the ground connection.  Place via holes to ground as close as possible to the anode of the TVS diode.  Use as many via holes as possible for the ground connection.  Keep the length of via holes in mind! The longer the more inductance they will have. Rev.06.3 5 www.prisemi.com ESD Protector PESDNC2FD7VB Product dimension (DFN1006-2L) C D E F Top View H Bottom View Millimeters Inches Dim A MIN B Side View 1.20 MAX MIN MAX A 0.340 0.498 0.013 0.020 B 0.000 0.050 0.000 0.002 C 0.950 1.080 0.037 0.043 D 0.550 0.680 0.022 0.027 E 0.400 0.600 0.016 0.024 F 0.200 0.300 0.008 0.012 H 0.400 Typ. 0.015 Typ. 0.50 0.60 0.70 Notes: Unit:mm This recommended land pattern is for reference purposes only. Please consult Suggested PCB Layout your manufacturing group to ensure your PCB design guidelines are met. Ordering information Device Package Reel MPQ PESDNC2FD7VB DFN1006-2L (Pb-Free) 7" 10000 / Tape & Reel Rev.06.3 6 www.prisemi.com ESD Protector PESDNC2FD7VB Load with information USER DIRECTION OF FEED Φ1.50 ± 0.10 2.00 ± 0.05 2.00 ± 0.05 1.75 ± 0.10 4.00 ± 0.10 3.50 ± 0.05 8.00 ± 0.10 Φ0.50 ± 0.05 Unit:mm Rev.06.3 7 www.prisemi.com ESD Protector PESDNC2FD7VB IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.3 8 www.prisemi.com
PESDNC2FD7VB 价格&库存
很抱歉,暂时无法提供与“PESDNC2FD7VB”相匹配的价格&库存,您可以联系我们找货
