78104 SL005
78104 SL005
    ALPHAWIRE(阿尔法电线)
    78104 SL005
78104 SL005 数据手册
EcoCable® Mini Small Just Got Mini EcoCable® Mini Cable The Smallest Solution to Your Biggest Cable Problems S mall just got mini. Introducing EcoCable Mini. Our newest, completely recyclable high-performance cable is also our smallest and lightest to date. The latest addition to our EcoGen™ family of recyclable wire and cable, EcoCable Mini is small, but the performance advantages are big! It has all the benefits of our regular EcoCable line, like low specific gravity, low outgassing, and zero halogens. But it’s also up to 32% smaller and 44% lighter than standard 300 V PVC cable. 2 Small Just got Mini Smaller Size, Lower Weight EcoCable Mini recyclable cable was developed in response to our customers’ need for smaller, lighter 300 V cable. Design smaller, lighter devices with EcoCable Mini. Up to 32% smaller and 44% lighter than standard PVC cable, EcoCable Mini uses finely stranded conductors for remarkable flexibility, giving you more options for fast, easy routing. And the thin-wall insulation and jackets give you the most efficient use of constrained spaces. By combining better performance and minimum environmental impact, EcoCable Mini uses its mPPE insulation and jacketing to provide application advantages in a smaller, lighter cable. Its size makes routing and installation even easier, saving more time during production and maintenance. Even more convenient, it is available in over 250 standard configurations including four shielding options. Low Outgassing In applications like medical devices and semiconductor manufacturing equipment, low outgassing is critical in preventing corrosion, contamination, and premature component failure. EcoCable Mini cable gives you the advantage of up to 92% lower outgassing than PVC control cable. Low outgassing makes it well suited for cleanrooms, where an extremely low particle count is required to lessen the possibility of failure due to contamination. More Application Options EcoCable Mini is a 300 V cable that’s ideal for power and signal transmission applications in medical devices, semiconductor manufacturing equipment, and anywhere you are trying to take size and weight out of your design. Size Comparison: 28 AWG, 2 conductor unshielded cable 0.138 (3.51 mm) 0.094 (2.39 mm) 3 It’s also available in custom and composite configurations, so finding the right EcoCable Mini cable for your application is easier than ever. Take Advantage of all the Advantages • Up to 32% smaller and 44% lighter than PVC • 92% lower outgassing than PVC • 28 to 20 AWG • 100% recyclable mPPE insulation and jacketing • Contains no halogens, phthalates, or heavy metals • Meets RoHS and WEEE requirements Superior Availability • Available from stock in most sizes and constructions • Put-ups as small as 100’ • Same day shipment, next day delivery Alpha Wire’s next generation of eco-friendly, high-performance wire and cable, designed to provide better performance in a smaller package. • EcoCable® • EcoFlex® Cable • EcoCable® Mini • EcoWire® • EcoWire® Plus Learn more about the new EcoGen family of products at www.alphawire.com/EcoGen Specifications Configurations • Multiconductor or multipair • Unshielded, foil shielded, individually shielded pairs + overall foil shield, and Supra-Shield Foil + Braid • Custom and composite configurations available Materials • Conductors: Tinned copper • Insulation: mPPE • Shielding: Foil • Jacket: mPPE 4 Temperature Range • -40°C to +80°C Voltage Rating • 300 V Properties • Zero halogen • Specific gravity: 1.03 • 100% recyclable • Low outgassing Approvals • UL AWM 21460 • CE • CSA I A/B FT1 • RoHS • REACH • WEEE • Suitable for use in NFPA 79 applications • Meets UL VW-1 Flame Rating Availability • 100 ft (30.5 m) and 1000 ft (305 m) lengths • Bulk EcoCable Mini Cable Unshielded Multiconductor 28 AWG (0.0925 mm2) 26 AWG (0.154 mm2) Stranding: 19/40 (19 x 0.079 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/38 (19 x 0.102 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Conductors 78002 78003 78004 78006 78008 2 3 4 6 8 Nominal Diameter Inch mm 0.094 2.39 0.099 2.51 0.107 2.72 0.124 3.15 0.134 3.40 Part Number Conductors 78012 78013 78014 78016 78018 78020 78021 2 3 4 6 8 10 15 Nominal Diameter Inch mm 0.102 2.59 0.107 2.72 0.116 2.95 0.136 3.45 0.147 3.73 0.170 4.32 0.190 4.83 24 AWG (0.241 mm2) 22 AWG (0.382 mm2) Stranding: 19/36 (19 x 0.127 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Conductors 78022 78023 78024 78026 78028 78030 78031 78403 78433 2 3 4 6 8 10 15 20 25 Nominal Diameter Inch mm 0.112 2.84 0.118 3.00 0.128 3.25 0.152 3.86 0.164 4.17 0.190 4.83 0.213 5.41 0.238 6.05 0.268 6.81 Part Number Conductors 78032 78033 78034 78036 78038 78040 78041 78404 78434 2 3 4 6 8 10 15 20 25 Nominal Diameter Inch mm 0.126 3.20 0.133 3.38 0.145 3.68 0.173 4.39 0.187 4.75 0.218 5.54 0.245 6.22 0.275 6.98 0.310 7.87 20 AWG (0.616 mm2) Stranding: 19/32 (19 x 0.203 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Conductors 78042 78043 78044 78046 78048 78050 78055 78405 78435 2 3 4 6 8 10 15 20 25 Nominal Diameter Inch mm 0.142 3.61 0.150 3.81 0.165 4.19 0.197 5.00 0.214 5.44 0.250 6.35 0.282 7.16 0.317 8.05 0.358 9.09 5 EcoCable Mini Cable Unshielded Pairs 28 AWG (0.0925 mm2) 26 AWG (0.154 mm2) Stranding: 19/40 (19 x 0.079 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/38 (19 x 0.102 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Pairs 78052 78053 78054 78005 78056 78058 78009 2 3 4 5 6 8 9 Nominal Diameter Inch mm 0.132 3.35 0.140 3.56 0.153 3.89 0.167 4.24 0.182 4.62 0.198 5.03 0.213 5.41 Pairs 78062 78063 78064 78015 78066 78068 78019 2 3 4 5 6 8 9 Nominal Diameter Inch mm 0.146 3.71 0.154 3.91 0.169 4.29 0.185 4.70 0.202 5.13 0.219 5.56 0.237 6.02 24 AWG (0.241 mm2) 22 AWG (0.382 mm2) Stranding: 19/36 (19 x 0.127 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Pairs 78072 78073 78074 78025 78076 78078 78029 78408 78438 2 3 4 5 6 8 9 20 25 Nominal Diameter Inch mm 0.162 4.11 0.172 4.37 0.189 4.80 0.207 5.26 0.227 5.77 0.247 6.27 0.267 6.78 0.369 9.37 0.418 10.62 20 AWG (0.616 mm2) Stranding: 19/32 (19 x 0.203 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) 6 Part Number Part Number Pairs 78092 78093 78094 78045 78096 78098 78049 78410 78440 2 3 4 5 6 8 9 20 25 Nominal Diameter Inch mm 0.211 5.36 0.225 5.72 0.248 6.30 0.274 6.96 0.301 7.65 0.328 8.33 0.356 9.04 0.498 12.65 0.565 14.35 Part Number Pairs 78082 78083 78084 78035 78086 78088 78039 78409 78439 2 3 4 5 6 8 9 20 25 Nominal Diameter Inch mm 0.185 4.70 0.197 5.00 0.217 5.51 0.239 6.07 0.261 6.63 0.285 7.24 0.309 7.85 0.429 10.90 0.487 12.37 More Choice! EcoCable Mini cable is available with up to 25 conductors and a variety of shielding options. Custom and composite configurations are also available. Consult Alpha Wire for the latest product specifications. Sample the Performance Samples of EcoCable Mini cable are available today! Request yours at www.alphawire.com/ecogen or call 1-800-52 ALPHA EcoCable Mini Cable Foil Shielded Multiconductor 28 AWG (0.0925 mm2) 26 AWG (0.154 mm2) Stranding: 19/40 (19 x 0.079 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/38 (19 x 0.102 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Conductors 78102 78103 78104 78106 78108 2 3 4 6 8 Nominal Diameter Inch mm 0.098 2.49 0.103 2.62 0.111 2.82 0.128 3.25 0.138 3.51 Part Number Conductors 78112 78113 78114 78116 78118 78120 78121 2 3 4 6 8 10 15 Nominal Diameter Inch mm 0.106 2.69 0.111 2.82 0.12 3.05 0.14 3.56 0.151 3.84 0.174 4.42 0.194 4.93 24 AWG (0.241 mm2) 22 AWG (0.382 mm2) Stranding: 19/36 (19 x 0.127 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Conductors 78122 78123 78124 78126 78128 78130 78131 78413 78443 2 3 4 6 8 10 15 20 25 Nominal Diameter Inch mm 0.116 2.95 0.122 3.10 0.132 3.35 0.156 3.96 0.168 4.27 0.194 4.93 0.217 5.51 0.242 6.15 0.272 6.91 Part Number Conductors 78132 78133 78134 78136 78138 78140 78141 78414 78444 2 3 4 6 8 10 15 20 25 Nominal Diameter Inch mm 0.13 3.30 0.137 3.48 0.149 3.78 0.177 4.50 0.191 4.85 0.222 5.64 0.249 6.32 0.279 7.09 0.314 7.98 20 AWG (0.616 mm2) Stranding: 19/32 (19 x 0.203 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Conductors 78142 78143 78144 78146 78148 78150 78155 78415 78445 2 3 4 6 8 10 15 20 25 Nominal Diameter Inch mm 0.146 3.71 0.154 3.91 0.169 4.29 0.201 5.11 0.218 5.54 0.254 6.45 0.286 7.26 0.321 8.15 0.362 9.19 7 EcoCable Mini Cable Foil Shielded Pairs 28 AWG (0.0925 mm2) 26 AWG (0.154 mm2) Stranding: 19/40 (19 x 0.079 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/38 (19 x 0.102 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Pairs 78152 78153 78154 78105 78156 78158 78109 2 3 4 5 6 8 9 Nominal Diameter Inch mm 0.136 3.45 0.144 3.66 0.157 3.99 0.171 4.34 0.186 4.72 0.202 5.13 0.217 5.51 Pairs 78162 78163 78164 78115 78166 78168 78119 2 3 4 5 6 8 9 Nominal Diameter Inch mm 0.150 3.81 0.158 4.01 0.173 4.39 0.189 4.80 0.206 5.23 0.223 5.66 0.241 6.12 24 AWG (0.241 mm2) 22 AWG (0.382 mm2) Stranding: 19/36 (19 x 0.127 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Pairs 78172 78173 78174 78125 78176 78178 78129 78418 78448 2 3 4 5 6 8 9 20 25 Nominal Diameter Inch mm 0.166 4.22 0.176 4.47 0.193 4.90 0.211 5.36 0.231 5.87 0.251 6.38 0.271 6.88 0.373 9.47 0.422 10.72 20 AWG (0.616 mm2) Stranding: 19/32 (19 x 0.203 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) 8 Part Number Part Number Pairs 78192 78193 78194 78145 78196 78198 78149 78420 78450 2 3 4 5 6 8 9 20 25 Nominal Diameter Inch mm 0.215 5.46 0.229 5.82 0.252 6.40 0.278 7.06 0.305 7.75 0.332 8.43 0.360 9.14 0.502 12.75 0.569 14.45 Part Number Pairs 78182 78183 78184 78135 78186 78188 78139 78419 78449 2 3 4 5 6 8 9 20 25 Nominal Diameter Inch mm 0.189 4.80 0.201 5.11 0.221 5.61 0.243 6.17 0.265 6.73 0.289 7.34 0.313 7.95 0.433 11.00 0.491 12.47 More Choice! EcoCable Mini cable is available with up to 25 conductors and a variety of shielding options. Custom and composite configurations are also available. Consult Alpha Wire for the latest product specifications. Sample the Performance Samples of EcoCable Mini cable are available today! Request yours at www.alphawire.com/ecogen or call 1-800-52 ALPHA EcoCable Mini Cable Individually Foil Shielded Pairs + Overall Foil Shield 28 AWG (0.0925 mm2) 26 AWG (0.154 mm2) Stranding: 19/40 (19 x 0.079 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/38 (19 x 0.102 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Pairs 78202 78213 78204 78205 78206 78208 78209 2 3 4 5 6 8 9 Nominal Diameter Inch mm 0.153 3.89 0.162 4.11 0.177 4.50 0.194 4.93 0.211 5.36 0.229 5.82 0.247 6.27 Part Number Pairs 78212 78223 78214 78215 78216 78218 78219 2 3 4 5 6 8 9 Nominal Diameter Inch mm 0.167 4.24 0.177 4.50 0.194 4.93 0.213 5.41 0.232 5.89 0.252 6.40 0.273 6.93 24 AWG (0.241 mm2) 22 AWG (0.382 mm2) Stranding: 19/36 (19 x 0.127 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Pairs 78222 78233 78224 78225 78226 78228 78229 2 3 4 5 6 8 9 Nominal Diameter Inch mm 0.185 4.70 0.196 4.98 0.215 5.46 0.237 6.02 0.259 6.58 0.282 7.16 0.305 7.75 Part Number Pairs 78232 78243 78234 78235 78236 78238 78239 2 3 4 5 6 8 9 Nominal Diameter Inch mm 0.209 5.31 0.222 5.64 0.245 6.22 0.270 6.86 0.296 7.52 0.322 8.18 0.349 8.86 20 AWG (0.616 mm2) Stranding: 19/32 (19 x 0.203 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Pairs 78242 78253 78244 78245 78246 78248 78249 2 3 4 5 6 8 9 Nominal Diameter Inch mm 0.237 6.02 0.253 6.43 0.279 7.09 0.308 7.82 0.338 8.59 0.369 9.37 0.400 10.16 9 EcoCable Mini Cable Supra-Shield Foil + Braid Multiconductor 28 AWG (0.0925 mm2) 26 AWG (0.154 mm2) Stranding: 19/40 (19 x 0.079 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/38 (19 x 0.102 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Conductors 78302 78303 78304 78306 78308 2 3 4 6 8 Nominal Diameter Inch mm 0.125 3.18 0.130 3.30 0.138 3.51 0.155 3.94 0.165 4.19 Conductors 78312 78313 78314 78316 78318 78320 78321 2 3 4 6 8 10 15 Nominal Diameter Inch mm 0.133 3.38 0.138 3.51 0.147 3.73 0.167 4.24 0.178 4.52 0.201 5.11 0.221 5.61 24 AWG (0.241 mm2) 22 AWG (0.382 mm2) Stranding: 19/36 (19 x 0.127 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Conductors 78322 78323 78324 78326 78328 78330 78331 78423 78453 2 3 4 6 8 10 15 20 25 Nominal Diameter Inch mm 0.143 3.63 0.149 3.78 0.159 4.04 0.183 4.65 0.195 4.95 0.221 5.61 0.244 6.20 0.269 6.83 0.299 7.59 20 AWG (0.616 mm2) Stranding: 19/32 (19 x 0.203 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) 10 Part Number Part Number Conductors 78342 78343 78344 78346 78348 78350 78355 78425 78455 2 3 4 6 8 10 15 20 25 Nominal Diameter Inch mm 0.173 4.39 0.181 4.60 0.196 4.98 0.228 5.79 0.245 6.22 0.281 7.14 0.313 7.95 0.348 8.84 0.389 9.88 Part Number Conductors 78332 78333 78334 78336 78338 78340 78341 78424 78454 2 3 4 6 8 10 15 20 25 Nominal Diameter Inch mm 0.157 3.99 0.164 4.17 0.176 4.47 0.204 5.18 0.218 5.54 0.249 6.32 0.276 7.01 0.306 7.77 0.341 8.66 More Choice! EcoCable Mini cable is available with up to 25 conductors and a variety of shielding options. Custom and composite configurations are also available. Consult Alpha Wire for the latest product specifications. Sample the Performance Samples of EcoCable Mini cable are available today! Request yours at www.alphawire.com/ecogen or call 1-800-52 ALPHA EcoCable Mini Cable Supra-Shield Foil + Braid Pairs 28 AWG (0.0925 mm2) 26 AWG (0.154 mm2) Stranding: 19/40 (19 x 0.079 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/38 (19 x 0.102 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Pairs 78352 78353 78354 78305 78356 78358 78309 2 3 4 5 6 8 9 Nominal Diameter Inch mm 0.163 4.14 0.171 4.34 0.184 4.67 0.198 5.03 0.213 5.41 0.229 5.82 0.244 6.20 Part Number Pairs 78362 78363 78364 78315 78366 78368 78319 2 3 4 5 6 8 9 Nominal Diameter Inch mm 0.177 4.50 0.185 4.70 0.200 5.08 0.216 5.49 0.233 5.92 0.250 6.35 0.268 6.81 24 AWG (0.241 mm2) 22 AWG (0.382 mm2) Stranding: 19/36 (19 x 0.127 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Pairs 78372 78373 78374 78325 78376 78378 78329 78428 78458 2 3 4 5 6 8 9 20 25 Nominal Diameter Inch mm 0.193 4.90 0.203 5.16 0.220 5.59 0.238 6.05 0.258 6.55 0.278 7.06 0.298 7.57 0.400 10.16 0.449 11.40 Part Number Pairs 78382 78383 78384 78335 78386 78388 78339 2 3 4 5 6 8 9 Nominal Diameter Inch mm 0.216 5.49 0.228 5.79 0.248 6.30 0.270 6.86 0.292 7.42 0.316 8.03 0.340 8.64 20 AWG (0.616 mm2) Stranding: 19/32 (19 x 0.203 mm) Insulation thickness: 0.007 (0.18 mm) Jacket thickness: 0.015 (0.38 mm) Part Number Pairs 78392 78393 78394 78345 78396 78398 78349 2 3 4 5 6 8 9 Nominal Diameter Inch mm 0.242 6.15 0.256 6.50 0.279 7.09 0.305 7.75 0.332 8.43 0.359 9.12 0.387 9.83 11 Cables you trust. Service you deserve. Superior availability Every application is critical and cable failure is not an option when the safety of your equipment and personnel is paramount. Specify Alpha products since the integrity of your system is only as robust as the products you use. Alpha offers wire and cable from stock in most sizes and constructions, in both small and large put-ups, so you can order it when you need it. Our products are available for same-day shipment, eliminating long lead times. GLOBAL HEADQUARTERS 711 Lidgerwood Avenue Elizabeth, NJ 07207-0711 USA Toll Free: 1-800-52 ALPHA Tel: 1-908-925-8000 Fax: 1-908-925-5411 E-mail: info@alphawire.com EUROPE Alpha Wire International Saxon House 1 Downside | Sunbury-on-Thames Middlesex | United Kingdom TW16 6RT Tel: 01 932 772 422 Fax: 01 932 772 433 E-mail: europe@alphawire.com Service and support, second-to-none Selecting the correct cable for your critical application is essential to overall system reliability, performance, and safety. So we make it easy for you to select the right Alpha product for your specific application. Our online resources include a wire and cable selection guide, technical information, full product catalog, and a distributor locator to make it easy to select and get the wire or cable you need. Can’t find what you’re looking for? Design the cable to your specification. It’s easy, just visit www.alphawire.com! ASIA PACIFIC Alpha Wire Room 1308 | Baohua Mansion No 1211 Changde Road Shanghai | China | 200060 Tel: +86-21-6259 3510 / 6259 3957 Fax: +86-21-61498001 E-mail: apac@alphawire.com Alpha Wire’s next generation of eco-friendly, high-performance wire and cable, designed to provide better performance in a smaller package. ©2018 Alpha Wire. All rights reserved. Specifications subject to change. Consult Alpha Wire for latest specifications. EcoCable, EcoFlex, EcoGen, EcoWire, EcoWire Plus and Supra-Shield are trademarks of Alpha Wire. Lit. No. EcoC-Mini-1807 Supersedes: EcoC-Mini-1409
78104 SL005 价格&库存
很抱歉,暂时无法提供与“78104 SL005”相匹配的价格&库存,您可以联系我们找货
78104 SL005
    • 1+1375.670131+178.87500
    库存:1
