SUPERPRO280
SUPERPRO280
    XELTEK(南京西尔特)
    PROGRAMMER UNIVERSAL 48-PIN
SUPERPRO280 数据手册
Superpro 280 $499 48 Pin Low Cost Advanced Universal Programmer FEATURES: * Supports 5000+ devices including E/EPROM, FLASH, Microcontroller, PLD * High Speed CPU generates more accurate and reliable algorithm timing * Very high programming speed. * Auto-Sense-and-Run, Batch Command and Auto Serial Number generation improve production efficiency * Programmable I/O level support low voltage devices down to 1.8V * Device Insertion and Pin contact Check protect chips from damaging * Available package adapters: PLCC, QFP, TSOP, SOIC, SOP, SSOP etc. * Supports Windows 2000/NT, Windows98/95 * Windows XP compatible * Connect to PC (desktop and notebook) via printer port. * Test standard logic devices and SRAM * One year guaranty. EXAMPLES of PRODUCTION THROUGHPUT Time in second. Throughput: PCS/8 hours Type Program Verify Throughput 28C64B 1 0.8 7578 24C256 3 8 2215 W78E58 13 3 1600 0.8 7578 PIC12C508 1 STANDARD PACKAGE: Superpro main unit, AC Adapter, Parallel Cable, User Manual and Program Diskette. SPECIFICATION: * AC Adapter : Input AC 220V or 110V * Output : DC 12V/1.5Amp * Dimension : 200(L) x 140(W) x 24(H)mm * Package : 263(L) x 232(W) x 100(H) * GW : 1.8Kg
SUPERPRO280 价格&库存
很抱歉,暂时无法提供与“SUPERPRO280”相匹配的价格&库存,您可以联系我们找货
