FS-935
FS-935
    DIGIINTERNATIONAL
    JTAG-BOOSTER FOR IDT64145 3.3V
FS-935 数据手册
JTAG-Booster for IDT RC64145 FORTH-SYSTEME GmbH P.O. Box 11 03 Kueferstrasse 8 l D-79200 Breisach, Germany l D-79206 Breisach, Germany (+49 (7667) 908-0 l Fax +49 (7667) 908-200 l e-mail: sales@fsforth.de JTAG-Booster for IDT 64145 Copyright  1995..2000: FS FORTH-SYSTEME GmbH Postfach 1103, D-79200 Breisach, Germany Release of Document: Author: Filename: Program Version: February 08, 2000 Dieter Fögele JTAG145a.doc 3.00 All rights reserved. No part of this document may be copied or reproduced in any form or by any means without the prior written consent of FS FORTHSYSTEME GmbH. 2 JTAG145a.doc JTAG-Booster for IDT 64145 Table of Contents 1. General.......................................................................................................... 4 1.1. System Requirements ......................................................................... 4 1.2. Connecting your PC to the target system ............................................ 5 1.3. First Example....................................................................................... 7 1.4. Trouble Shooting ................................................................................. 9 1.5. Error Messages ................................................................................. 10 1.6. Initialization file JTAG145.INI............................................................. 14 1.7. Supported flash devices .................................................................... 20 2. JTAG145 Parameter Description ................................................................. 25 2.1. Program a Flash Device .................................................................... 28 2.2. Read a Flash Device to file................................................................ 31 2.3. Verify a Flash Device with file............................................................ 33 2.4. Dump target memory ......................................................................... 35 2.5. Program an I²C-Device ...................................................................... 36 2.6. Read an I²C-Device to file.................................................................. 38 2.7. Verify an I²C-Device with file.............................................................. 40 2.8. Dump an I²C-Device .......................................................................... 42 2.9. Toggle CPU pins................................................................................ 43 2.10.Polling CPU pins ............................................................................... 44 2.11.Polling CPU pins while the CPU is running ....................................... 45 2.12.List supported Flash Devices ............................................................ 46 3. Implementation Information ......................................................................... 47 JTAG145a.doc 3 JTAG-Booster for IDT 64145 1. General The program JTAG145 uses the JTAG port of the IDT RC64145 embedded controller in conjunction with the small JTAG-BOOSTER: • • • • • to program data into flash memory to verify and read the contents of a flash memory to make a memory dump to access an I²C Device to test CPU signals All functions are done without any piece of software running in the target. No firmware or BIOS must be written. Bootstrap software may be downloaded to initially unprogrammed memories. For latest documentation please refer to the file README.TXT on the distribution disk. 1.1. System Requirements To successfully run this tool the following requirements must be met: • MSDOS, WIN3.x, WIN9x or WinNT (WinNT is supported with an additional support-kit) • Intel 80386 or higher • 205 kByte of free DOS memory • no extended memory • Parallel Port 4 JTAG145a.doc JTAG-Booster for IDT 64145 1.2. Connecting your PC to the target system The JTAG-Booster can be plugged into standard parallel ports (LPT1-3) with a DB25-Connector. 1 LPT1-3 1 Élan SC400 Module Élan486 The target end of the cable has the following reference: 1 TCK 2* GND 3 TMS 4 TRST# 5 NC 6 TDI 7 TDO 8 +3.3V *PIN 2 can be detected by the white thick cable. To connect your design to the JTAG-BOOSTER you need a single row berg connector with a spacing of 2.54mm on your PCB. The names refer to the target: Pin 7 is the target’s TDO pin and is connected to the JTAG-Booster’s TDI pin. Since the JTAG-Booster operates with 5V, in addition a level shifter is necessary to connect the JTAG-Booster to a target operating with 3.3 volts. This level shifter must be ordered separately. The IDT RC64145 does not have a TRST# pin. The reset of the JTAG interface is connected (internally to the IDT RC64145) to the system reset (Pin SYS_RST#). We recommend not to connect the system reset with the TRST# pin of the JTAG connector. For more information see chapter 3. “Implementation Information” JTAG145a.doc 5 JTAG-Booster for IDT 64145 Before you start the program, the JTAG-BOOSTER must be plugged to a parallel interface of your PC and to the 8 pin JTAG connector on the target. The utility is started with the general command line format: JTAG145 /function [filename] [/option_1] ... [/option_n]. Note that the function must be the first argument followed (if needed) by the filename. If you want to cancel execution of JTAG145, press CTRL-Break-Key. On any error the program aborts with an MSDOS error level of one. 6 JTAG145a.doc JTAG-Booster for IDT 64145 1.3. First Example In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JTAG145 /P MYAPP.BIN /VERIFY at the DOS prompt results in the following output: JTAG145 --- JTAG utility for IDT RC64145 (32bit) Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 3.00 of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JTAG145.INI Target: Generic Target Using LPT at I/O-address 0378h JTAG Adapter detected (5) 1 Device detected in JTAG chain Device 0: IDCODE=00004067 IDT RC64145, Revision 0 Sum of instruction register bits : 4 CPU position :0 Instruction register offset :0 (6) (7) (8) (9) (10) AMD 29LV640 (word mode) detected Erasing Flash-EPROM Block #:0 Programming File MYAPP.BIN 65536 Bytes programmed Programming ok Erase Time : Program Time : JTAG145a.doc 2.5 sec 60.7 sec 7 JTAG-Booster for IDT 64145 (1) The initialization file JTAG145.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the IDT RC64145 are switched to bypass mode. (6) The length of all instruction registers in the JTAG chain are added. (7) The position of the IDT RC64145 in the JTAG chain is checked. (8) The position of the JTAG instruction register of the IDT RC64145 is checked (9) One Flash-EPROMs AMD 29LV640 selected with chip select BOOTCS# is found. (10) In this example one block must be erased. 8 JTAG145a.doc JTAG-Booster for IDT 64145 1.4. Trouble Shooting Avoid long distances between your Host-PC and the target. If you are using standard parallel extension cable, the JTAG-BOOSTER may not work. Don't use Dongles between the parallel port and the JTAG-BOOSTER. Switch off all special modes of your printer port (EPP, ECP, ...) in the BIOS setup. Only standard parallel port (SPP) mode is allowed. On very fast PCs there could be verify errors. To avoid this, watch for the ´IO recovery time´-switch in the BIOS Setup which must be turned on. Otherwise try to slow down your PC by setting the turbo switch off. When using older flash devices (nearly maximum erase cycles reached), we propose to use the /VERIFY option. This is also true for the relatively slow 3 Volt only flash devices. Some newer fast flash devices need a setup time between address/data and the write strobe signal. If programming of this devices fails, try with the option /WRSETUP again. If there are problems with autodetection of the flash devices use the /DEVICE= option. To speed up autodetection specify the option /16BIT or /8BIT. Don't use hardware protected flash memories. The used chip selects must be defined as output and inactive in the initialization file (see chapter 1.6 “Initialization file JTAG145.INI”). Also the address bits must be defined as output. JTAG145a.doc 9 JTAG-Booster for IDT 64145 1.5. Error Messages • 80386 or greater required The JTAG-BOOSTER does not work on a 8088/8086 or a 80286 platform. • Adapter not connected or target power fail The JTAG-Booster wasn't found. Please check connection to parallel port and connection to target. Check target power. Check your BIOS-Setup. • Can't open x:\yyy\zzz\JTAG145.OVL The overlay file JTAG145.OVL must be in the same directory as JTAG145.EXE. • Configuration file XYZ not found. The file specified with the option /INI= wasn't found. • Device offset out of range The value specified with the option /OFFSET= is greater than the size of the detected flash device. • Disk full Writing a output file was aborted as a result of missing disk space. • Error creating file: The output file could not be opened. Please check free disk space or write protection. • Error: Pin-Name is an output only pin The specified pin cannot be sampled. Check the command line. Check the initialization file. • Error: Pin-Name is an input only pin The specified pin cannot be activated. Check the command line. Check the initialization file. • Error: Pin-Name may not be read back The specified pin can be switched to tristate, but cannot be read back. Check the command line. 10 JTAG145a.doc JTAG-Booster for IDT 64145 • illegal function: The first parameter of the command line must be a valid function. See chapter 2 “JTAG145 Parameter Description” for a list of supported functions. • illegal number: The specified number couldn’t be interpret as a valid number. Check the relevant number base. • illegal option: See chapter 2 “JTAG145 Parameter Description” for a list of supported options. • illegal Pin Type: The name specified with the option /PIN= must be one of the list of chapter 1.6 ”Initialization file JTAG145.INI” • illegal Flash Type: The name specified with the option /DEVICE= must be one of the list of chapter 1.7 ”Supported flash devices”. • Input file not found: The specified file cannot be found • Input file is empty: Files with zero length are not accepted • " " is undefined Please check the syntax in your configuration file. (See chapter 1.6 “Initialization file JTAG145.INI”). • LPTx not installed The LPT port specified with /LPTx cannot be found. Please check the LPT port or specify a installed LPT port. Check your BIOS setup. • missing filename Most functions need a filename as second parameter. JTAG145a.doc 11 JTAG-Booster for IDT 64145 • missing option /I2CCLK= Some functions need the option /I2CCLK= to be defined. • missing option /I2CDAT= Some functions need the option /I2CDAT= or the options /I2CDATO= and /I2CDATI= to be defined. • missing option /LENGTH= Some functions need the option /LENGTH= to be defined. • missing option /PIN= Some functions need the option /PIN= to be defined. • More than 9 devices in the JTAG chain or TDI pin stuck at low level The JTAG chain is limited to 9 parts. Check target power. Check the target’s TDO pin. • No devices found in JTAG chain or TDI pin stuck at high level A stream of 32 high bits was detected on the pin TDI. TDI may stuck at high level. Check the connection to your target. Check the target power. Check the target’s TDO pin. • Option /CPUPOS= out of range The number specified with the option /CPUPOS= must be less or equal to the number of parts minus 1. • Option /IROFFS= out of range Please specify a smaller value • Part at specified position is not a IDT RC64145 The option /CPUPOS= points to a part not a IDT RC64145 (32bit). The part may be switched to the 64bit JTAG mode. • Pins specified with /I2CCLK= and /I2CDAT= must have different control cells The pin specified with the option /I2CDAT= must be able to be switched to high impedance while the pin specified with option /I2CCLK= is an active output. See chapter 1.6 “Initialization file JTAG145.INI”. 12 JTAG145a.doc JTAG-Booster for IDT 64145 • Pins specified with /I2CCLK= and /I2CDATI= must have different control cells The pin specified with the option /I2CDATI= must be able to be switched to high impedance while the pin specified with option /I2CCLK= is an active output. See chapter 1.6 “Initialization file JTAG145.INI”. • Pins specified with /I2CDATO= and /I2CDATI= must have different control cells The pin specified with the option /I2CDATI= must be able to be switched to high impedance while the pin specified with option /I2CDATO= is an active output. See chapter 1.6 “Initialization file JTAG145.INI”. • Specify only one of that options: Some options are exclusive (i.e. /8BIT and /16BIT). Don't mix them. • There are unknown parts in the JTAG chain. Please use the option /IROFFS= to specify the instr. reg. offset of the CPU. If there are unknown parts in the JTAG chain, the program isn’t able to determine the logical position of the CPU’s instruction register. • There is no IDT RC64145 in the JTAG chain No IDT RC64145 was found in the JTAG chain. Check the target power. Try with option /DRIVER=4 again. • Value of option /FILE-OFFSET out of range The value of the option /FILE-OFFSET= points behind end of file. • wrong driver # The value specified with the option /DRIVER= is out of range. • wrong Identifier (xxxx) No valid identifier found. Check the specified chip select signal and the bus width. Try with the option /DEVICE= . JTAG145a.doc 13 JTAG-Booster for IDT 64145 1.6. Initialization file JTAG145.INI This file is used to set the CPU signals for input/output. In case of output signal an additional parameter is used to set the default level to high or low. This file can be used to adapt your own IDT RC64145 design to the JTAG-BOOSTER. The Target-Entry is used to identify your design which is displayed with most commands. When the JTAG145 software is started it scans the current directory for an existing initialization file named JTAG145.INI. If no entry is found the default values are used. You may also specify the initialization file with the option /INI= . If the specified file isn't found, the program aborts with an error message. The CPU pins can also be used with the functions /BLINK (chapter 2.9), /PIN? (chapter 2.10) and /SAMPLE (chapter 2.11) to test the signals on your design. Example of JTAG145.INI: // Description file for IDT RC64145 Target: Generic Target // All chip select signals are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults. // Pin names are defined in upper case. // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as input. CPU_AD31 Inp // Address/Data to/from CPU CPU_AD30 Inp // CPU_AD29 Inp // CPU_AD28 Inp // CPU_AD27 Inp // CPU_AD26 Inp // CPU_AD25 Inp // CPU_AD24 Inp // CPU_AD23 Inp // CPU_AD22 Inp // CPU_AD21 Inp // CPU_AD20 Inp // CPU_AD19 Inp // CPU_AD18 Inp // 14 JTAG145a.doc JTAG-Booster for IDT 64145 CPU_AD17 CPU_AD16 CPU_AD15 CPU_AD14 CPU_AD13 CPU_AD12 CPU_AD11 CPU_AD10 CPU_AD9 CPU_AD8 CPU_AD7 CPU_AD6 CPU_AD5 CPU_AD4 CPU_AD3 CPU_AD2 CPU_AD1 CPU_AD0 CPU_CMD8 CPU_CMD7 CPU_CMD6 CPU_CMD5 CPU_CMD4 CPU_CMD3 CPU_CMD2 CPU_CMD1 CPU_CMD0 PCI_AD31 PCI_AD30 PCI_AD29 PCI_AD28 PCI_AD27 PCI_AD26 PCI_AD25 PCI_AD24 PCI_AD23 PCI_AD22 PCI_AD21 PCI_AD20 PCI_AD19 PCI_AD18 PCI_AD17 PCI_AD16 JTAG145a.doc Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // // // Address/Data to/from CPU // // // // // // // // // // // // // // // // Command/Data Identifier to/from CPU // // // // // // // // // PCI Address/Data // // // // // // // // // // // // // // // 15 JTAG-Booster for IDT 64145 PCI_AD15 PCI_AD14 PCI_AD13 PCI_AD12 PCI_AD11 PCI_AD10 PCI_AD9 PCI_AD8 PCI_AD7 PCI_AD6 PCI_AD5 PCI_AD4 PCI_AD3 PCI_AD2 PCI_AD1 PCI_AD0 PCI_CBE3# PCI_CBE2# PCI_CBE1# PCI_CBE0# PCI_FRAME# PCI_IRDY# PCI_TRDY# PCI_DEVSEL# PCI_STOP# PCI_PERR# PCI_PAR PIO12 PIO11 PIO10 PIO9 DMA_REQ3# DMA_REQ2# DMA_REQ1# DMA_REQ0# SYS_WAIT DMA_ACK3# DMA_ACK2# DMA_ACK1# DMA_ACK0# SYS_DATA31 SYS_DATA30 SYS_DATA29 16 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Out,Hi Out,Hi Out,Hi Out,Hi Inp Inp Inp // // // // // // // // // // // // // // // // // PCI Command/Byte Enable // PCI Command/Byte Enable // PCI Command/Byte Enable // PCI Command/Byte Enable // PCI Cycle Frame // PCI Initiator Ready // PCI Target Ready // PCI Device Select // PCI Stop // PCI Parity Error // PCI Parity Bit // // // // // DMA Request Input = PIO7 // DMA Request Input = PIO6 // DMA Request Input = PIO5 // DMA Request Input = PIO4 // Wait = PIO8 // DMA Acknowledge Output = PIO3 // DMA Acknowledge Output = PIO2 // DMA Acknowledge Output = PIO1 // DMA Acknowledge Output = PIO0 // System Interface Data // // JTAG145a.doc JTAG-Booster for IDT 64145 SYS_DATA28 SYS_DATA27 SYS_DATA26 SYS_DATA25 SYS_DATA24 SYS_DATA23 SYS_DATA22 SYS_DATA21 SYS_DATA20 SYS_DATA19 SYS_DATA18 SYS_DATA17 SYS_DATA16 SYS_DATA15 SYS_DATA14 SYS_DATA13 SYS_DATA12 SYS_DATA11 SYS_DATA10 SYS_DATA9 SYS_DATA8 SYS_DATA7 SYS_DATA6 SYS_DATA5 SYS_DATA4 SYS_DATA3 SYS_DATA2 SYS_DATA1 SYS_DATA0 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // The following pin is tristateable, but can not be read back PCI_REQ# Out,Hi // PCI Bus Request // The following pins are output only pins. // Setting to input (tristate) one of that pins results in an error. VALIDIN# Out,Hi // RC64145 drives valid Data CPU_RDY# Out,Hi // Ready, connects to the CPU CPU_INT# Out,Hi // Interrupt Output to CPU PCI_SERR# Out,Hi // PCI System Error, open drain output PCI_INT# Out,Hi // PCI Interrupt Request, open drain output UART0_SOUT Out,Hi // UART0 Serial Data Out UART0_RTS# Out,Hi // UART0 Request to Send UART0_DTR# Out,Hi // UART0 Data Terminal Ready JTAG145a.doc 17 JTAG-Booster for IDT 64145 UART1_SOUT SYS_ALE SPI_CS# SPI_MOSI SPI_CLK XCVRDIR_WR# XCVROE# SYS_BOOTCS# SYS_DEVCS0# SYS_DEVCS1# SYS_DEVCS2# SYS_DEVCS3# SYS_DEVOE# SD_WE# SD_CAS# SD_RAS# SD_BA1 SD_BA0 SD_CS3# SD_CS2# SD_CS1# SD_CS0# SYS_DQM_WE3# SYS_DQM_WE6# SYS_DQM_WE1# SYS_DQM_WE4# SYS_ADR11 SYS_ADR10 SYS_ADR9 SYS_ADR8 SYS_ADR7 SYS_ADR6 SYS_ADR5 SYS_ADR4 SYS_ADR3 SYS_ADR2 SYS_ADR1 SYS_ADR0 18 Out,Hi Out,Lo Out,Hi Out,Lo Out,Lo Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Lo Out,Lo Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo // UART1 Serial Data Out // Address Latch Enable, High->Latch transparent // SPI Chip Select, No connect??? // SPI Master Out Slave In, No connect???? // SPI Clock, No connect???? // External Transceiver Direction // External Transceiver Output Enable // Boot Chip Select // Device Chip Select // Device Chip Select // Device Chip Select // Device Chip Select // Device Output Enable // SDRAM Write Enable // SDRAM CAS# // SDRAM RAS# // SDRAM Bank Address // SDRAM Bank Address // SDRAM Chip Select // SDRAM Chip Select // SDRAM Chip Select // SDRAM Chip Select // Data Mask // Data Mask // Data Mask // Data Mask // // // // // // // // // // // // JTAG145a.doc JTAG-Booster for IDT 64145 // The following pins are input only. // Setting to output of one of these pins results in an error. // Declaration of the direction of these pins is optional. VALIDOUT# Inp // CPU drives valid Data SYS_CLK Inp // Input Clock to RC64145 PCI_IDSEL Inp // PCI Initialization Device Select PCI_LOCK# Inp // PCI Locked Cycle PCI_GNT# Inp // PCI Bus Grant PCI_CLK Inp // PCI Clock UART1_SIN Inp // UART1 Serial Data In UART0_CTS# Inp // UART0 Clear to Send UART0_DCD# Inp // UART0 Data Carrier Detect UART0_SIN Inp // UART0 Serial Data In SPI_MISO Inp // SPI Master In Slave Out, VCC CORE???? This example is equal to the default initialization which is used when no initialization file could be found in the current directory and no initialization file is specified with the option /INI=. Changes to the structure of the file could result in errors. Remarks can be added by using //. JTAG145a.doc 19 JTAG-Booster for IDT 64145 1.7. Supported flash devices The following names could be used with the /DEVICE= option: * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * AM29F010 AM29F010*2 AM29LV010 AM29LV010*2 AM29F100BW AM29F100BB AM29F100TW AM29F100TB AM29F200BW AM29F200BB AM29F200TW AM29F200TB AM29LV200BW AM29LV200BB AM29LV200TW AM29LV200TB AM29F040 AM29F040*2 AM29F400BW AM29F400BB AM29F400TW AM29F400TB AM29LV400BW AM29LV400BB AM29LV400TW AM29LV400TB AM29LV004B AM29LV004T AM29F080 AM29F080*2 AM29LV081 AM29LV081*2 AM29F800BW AM29F800BB AM29F800TW AM29F800TB AM29LV800BW AM29LV800BB 20 : AMD 29F010 : Dual AMD 29F010 : AMD 29LV010 : Dual AMD 29LV010 : AMD 29F100B : AMD 29F100B : AMD 29F100T : AMD 29F100T : AMD 29F200B : AMD 29F200B : AMD 29F200T : AMD 29F200T : AMD 29F200B : AMD 29F200B : AMD 29F200T : AMD 29F200T : AMD 29F040 : Dual AMD 29F040 : AMD 29F400B : AMD 29F400B : AMD 29F400T : AMD 29F400T : AMD 29LV400B : AMD 29LV400B : AMD 29LV400T : AMD 29LV400T : AMD 29LV004B : AMD 29LV004T : AMD 29F080 : Dual AMD 29F080 : AMD 29LV081 : Dual 29LV081 : AMD 29F800B : AMD 29F800B : AMD 29F800T : AMD 29F800T : AMD 29LV800B : AMD 29LV800B (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) (word mode) (byte mode) (word mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (word mode) (byte mode) (word mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V) (3.3V) (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) JTAG145a.doc JTAG-Booster for IDT 64145 AM29LV800TW * AM29LV800TB * AM29LV008T * AM29LV008B AM29F016 AM29F016*2 * AM29F017 AM29F017*2 AM29LV017*2 * AM29F160BW * AM29F160BB * AM29F160TW * AM29F160TB * AM29F160BB*2 * AM29F160TB*2 AM29LV160BW * AM29LV160BB * AM29LV160TW * AM29LV160TB AM29LV160BB*2 * AM29LV160TB*2 AM29F032 AM29F032*2 * AM29LV033 * AM29LV033*2 * AM29LV640 : AMD 29LV800T : AMD 29LV800T : AMD 29LV008T : AMD 29LV008B : AMD 29F016 : Dual AMD 29F016 : AMD 29F017 : Dual AMD 29F017 : Dual AMD 29LV017 : AMD 29F160B : AMD 29F160B : AMD 29F160T : AMD 29F160T : Dual AMD 29F160B : Dual AMD 29F160T : AMD 29LV160B : AMD 29LV160B : AMD 29LV160T : AMD 29LV160T : Dual AMD 29LV160B : Dual AMD 29LV160T : AMD 29F032 : Dual AMD 29F032 : AMD 29LV033 : Dual AMD 29F033 : AMD 29LV160 * * * * * * * * * * * : Intel 28F001T : Dual Intel 28F001T : Intel 28F001B : Intel 28F200B : Intel 28F200B : Intel 28F200T : Intel 28F200T : Intel 28F002B : Intel 28F002T : Intel 28F400B : Intel 28F400B : Intel 28F400T : Intel 28F400T : Intel 28F004B : Intel 28F004T : Intel 28F400B3B I28F001T I28F001T*2 I28F001B I28F200BW I28F200BB I28F200TW I28F200TB I28F002B I28F002T I28F400BW I28F400BB I28F400TW I28F400TB * I28F004B * I28F004T * I28F400B3B JTAG145a.doc (3.3V, word mode) (3.3V, byte mode) (3.3V) (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) (byte mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, byte mode) (3.3V, byte mode) (3.3V) (3.3V) (3.3V, word mode) (word mode) (byte mode) (word mode) (byte mode) (word mode) (byte mode) (word mode) (byte mode) Boot Block Smart3 Bottom 21 JTAG-Booster for IDT 64145 * * * * : Intel 28F400B3T : Intel 28F004 : Intel 28F800B : Intel 28F800B : Intel 28F800T : Intel 28F800T : Intel 28F800B3B : Intel 28F800B3T : Intel 28F008B : Intel 28F008T : Intel 28F008 : Dual Intel 28F008 : Intel 28F008 : Dual Intel 28F008 : Intel 28F016 : Intel 28F016 : Intel 28F016 : Intel 28F160 : Intel 28F160 : Intel 28F160 : Intel 28F160 : Intel 28F320 : Intel 28F320 : Intel 28F320 : Intel 28F320 : Intel 28F320 : Intel 28F320 : Intel 28F640 : Intel 28F640 : Intel 28F640 : Intel 28F640 : Intel 28F128 : Intel 28F128 Boot Block Smart3 Top FlashFile Smart3/5 (word mode) (byte mode) (word mode) (byte mode) Boot Block Smart3 Bottom Boot Block Smart3 Top * * * * * * * * * * * I28F400B3T I28F004S5 I28F800BW I28F800BB I28F800TW I28F800TB I28F800B3B I28F800B3T I28F008B I28F008T I28F008SA I28F008SA*2 I28F008S5 I28F008S5*2 I28F016W I28F016B I28F016S5 I28F160B3B I28F160B3T I28F160S5W I28F160S5B I28F320S5W I28F320S5B I28F320J5W I28F320J5B I28F320J3W I28F320J3B I28F640J5W I28F640J5B I28F640J3W I28F640J3B I28F128J3W I28F128J3B * * * * * * * * * MBM29F200BW MBM29F200BB MBM29F200TW MBM29F200TB MBM29LV200BW MBM29LV200BB MBM29LV200TW MBM29LV200TB MBM29F002B : Fujitsu 29F200B : Fujitsu 29F200B : Fujitsu 29F200T : Fujitsu 29F200T : Fujitsu 29LV200B : Fujitsu 29LV200B : Fujitsu 29LV200T : Fujitsu 29LV200T : Fujitsu 29F002B (word mode) (byte mode) (word mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) * * * * * * * * * * * 22 FlashFile 12V FlashFile 12V FlashFile Smart3/5 FlashFile Smart3/5 FlashFile (word mode) FlashFile (byte mode) FlashFile Smart3/5 Boot Block Smart3 Bottom Boot Block Smart3 Top FlashFile Smart5 (word mode) FlashFile Smart5 (byte mode) FlashFile Smart3/5 (word mode) FlashFile Smart3/5 (byte mode) StrataFlash (word mode) StrataFlash (byte mode) StrataFlash (3.3V, word mode) StrataFlash (3.3V, byte mode) StrataFlash (word mode) StrataFlash (byte mode) StrataFlash (3.3V, word mode) StrataFlash (3.3V, byte mode) StrataFlash (3.3V, word mode) StrataFlash (3.3V, byte mode) JTAG145a.doc JTAG-Booster for IDT 64145 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * MBM29F002SB MBM29LV002B MBM29F002T MBM29F002ST MBM29LV002T MBM29F040 MBM29F400BW MBM29F400BB MBM29F400TW MBM29F400TB MBM29LV400BW MBM29LV400BB MBM29LV400TW MBM29LV400TB MBM29LV004B MBM29LV004T MBM29F080 MBM29LV080 MBM29F800BW MBM29F800BB MBM29F800TW MBM29F800TB MBM29LV800BW MBM29LV800BB MBM29LV800TW MBM29LV800TB MBM29LV008B MBM29LV008T MBM29F016 MBM29F016*2 MBM29F017 MBM29F017*2 MBM29F160BW MBM29F160BB MBM29F160TW MBM29F160TB MBM29F160BB*2 MBM29F160TB*2 MBM29LV160BW MBM29LV160BB MBM29LV160TW MBM29LV160TB MBM29LV160BB*2 JTAG145a.doc : Fujitsu 29F002SB : Fujitsu 29LV002B : Fujitsu 29F002T : Fujitsu 29F002ST : Fujitsu 29LV002T : Fujitsu 29F040 : Fujitsu 29F400B : Fujitsu 29F400B : Fujitsu 29F400T : Fujitsu 29F400T : Fujitsu 29LV400B : Fujitsu 29LV400B : Fujitsu 29LV400T : Fujitsu 29LV400T : Fujitsu 29LV004B : Fujitsu 29LV004T : Fujitsu 29F080 : Fujitsu 29LV080 : Fujitsu 29F800B : Fujitsu 29F800B : Fujitsu 29F800T : Fujitsu 29F800T : Fujitsu 29LV800B : Fujitsu 29LV800B : Fujitsu 29LV800T : Fujitsu 29LV800T : Fujitsu 29LV008B : Fujitsu 29LV008T : Fujitsu 29F016 : Dual Fujitsu 29F016 : Fujitsu 29F017 : Dual Fujitsu 29F017 : Fujitsu 29LV160B : Fujitsu 29LV160B : Fujitsu 29LV160T : Fujitsu 29LV160T : Dual Fujitsu 29LV160B : Dual Fujitsu 29LV160T : Fujitsu 29LV160B : Fujitsu 29LV160B : Fujitsu 29LV160T : Fujitsu 29LV160T : Dual Fujitsu 29LV160B (TSOP40) (3.3V) (TSOP40) (3.3V) (word mode) (byte mode) (word mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V) (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) (byte mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, byte mode) 23 JTAG-Booster for IDT 64145 * MBM29LV160TB*2 MBM29F032 MBM29F032*2 : Dual Fujitsu 29LV160T : Fujitsu 29F032 : Dual Fujitsu 29F032*2 (3.3V, byte mode) * * * * : ST 29F100B : ST 29F100B : ST 29F100T : ST 29F100T : ST 29F200B : ST 29F200B : ST 29F200T : ST 29F200T : ST 29F040 : Dual ST 29F040 : ST 29W040 : Dual ST 29W040 : ST 29F400B : ST 29F400B : ST 29F400T : ST 29F400T : ST 29W400B : ST 29W400B : ST 29W400T : ST 29W400T : ST 29W004B : ST 29W004T : ST 29F800B : ST 29F800B : ST 29F800T : ST 29F800T (word mode) (byte mode) (word mode) (byte mode) (word mode) (byte mode) (word mode) (byte mode) * * * * * * * * * * * * * * * * * * * * * M29F100BW M29F100BB M29F100TW M29F100TB M29F200BW M29F200BB M29F200TW M29F200TB M29F040 M29F040*2 M29W040 M29W040*2 M29F400BW M29F400BB M29F400TW M29F400TB M29W400BW M29W400BB M29W400TW M29W400TB M29W004B M29W004T M29F800BW M29F800BB M29F800TW M29F800TB (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) The flash devices signed with ´*´ are not yet tested. 24 JTAG145a.doc JTAG-Booster for IDT 64145 2. JTAG145 Parameter Description When you start JTAG145.EXE without any parameters the following help screen with all possible functions and options is displayed: JTAG145 --- JTAG utility for the IDT RC64145 (32bit) Copyright © FS FORTH-SYSTEME GmbH, Breisach Version 3.00 of mm/dd/yyyy Programming of Flash-EPROMs and Debugging on targets with the IDT RC64145. The JTAG-Booster is needed to connect the parallel port of the PC to the JTAG port of the IDT RC64145. Usage: JTAG145 /function [filename] [/option_1] ... [/option_n] Supported functions: /P : Program a Flash Device /R : Read a Flash Device to file /V : Verify a Flash Device with file /DUMP : Make a target dump /PI2C : Program an I2C Device with file /RI2C : Read an I2C Device to file /VI2C : Verify an I2C Device with file /DUMPI2C : Make a dump of an I2C Device /BLINK : Toggle a CPU pin /PIN? : Test a CPU pin /SAMPLE : Test a CPU pin while CPU is running /LIST : Print a list of supported Flash devices Supported Options: /BOOTCS /DEVCS0 /DEVCS1 /DEVCS2 /NOCS /WRSETUP /VERIFY /TOP /P /NODUMP /NOERASE /LATTICE /LPT1 /LPT2 /LPT3 /LPT-BASE /8BIT /NOMAN /32H /32L /L= /FILE-OFFSET= /FO= /O= /DELAY= /DEVICE-BASE= /DRIVER= /DATA-MASK= /DM= /IROFFS= /DEVICE= /PIN= /I2CCLK= /I2CDAT= /I2CDATO= /WATCH= /OUT= /INI= JTAG145a.doc /DEVCS3 /PAUSE /ERASEALL /16BIT /LENGTH= /OFFSET= /DB= /CPUPOS= /I2CDATI= 25 JTAG-Booster for IDT 64145 The following options are valid for most functions: /DRIVER=x with x = 1,2,3,4 A driver for the interface to the JTAG-BOOSTER on the parallel port may be specified. /DRIVER=1 selects the fastest available driver, /DRIVER=4 selects the slowest one. Use a slower driver if there are problems with JTAGBOOSTER. Default: /DRIVER=3 /INI=file An initialization file may be specified. By default the current directory is searched for the file JTAG145.INI. If this file is not found and no initialization file is specified in the command line, default initialization values are used (see also chapter 1.6 “Initialization file JTAG145.INI”). Default: /INI=JTAG145.INI /LATTICE For demonstration purposes this software works with the Lattice ispLSI-Adapter, too. With the option /LATTICE you can simulate the speed achievable with the simple ispLSI-Adapter. /LPT1 /LPT2 /LPT3 A printer port may be specified where the JTAG-Booster resides. Default: /LPT1 /LPT-BASE The physical I/O-Address of printer port may be specified instead of the logical printer name. /OUT=file_or_device All screen outputs are redirected to the specified file or device. Note that you can't redirect to the same parallel port where the JTAG-Booster resides. Default: /OUT=CON /PAUSE With the option /PAUSE you can force the program to stop after each screen. Please do not use this option if you redirect the output to a file. Abbreviation: /P 26 JTAG145a.doc JTAG-Booster for IDT 64145 /WATCH= With the option /WATCH= a pin can be specified, which is toggled twice per second, while the program is active. This pin may be the trigger of a watchdog. This pin must be specified as output in the initialization file. JTAG145a.doc 27 JTAG-Booster for IDT 64145 2.1. Program a Flash Device Usage: JTAG145 /P filename [optionlist] The specified file is programmed to the flash memory. Finally a complete verify is done, if the option /VERIFY is omitted. If the verify fails, the contents of the flash memory is written to a file with the extension DMP. The type of the flash device is normally detected by the software. When autodetect fails you should use the /DEVICE= option to set the right flash device. The known devices are shown in chapter 1.7 “Supported flash devices”. Options: /DEVICE=devicename The device is detected automatically by switching to autoselect mode. In case of trouble you should select the device by using this parameter to avoid autodetection. /NOMAN If you use a flash device which is identical to one of the supported parts, but is from a different manufacturer, with this option you can suppress the comparison of the manufacturer identification code. We recommend to use this option together with the /DEVICE= option to avoid failures in autodetection. /DEVICE-BASE=hhhhhh1 By default a device start address of 3000000h (=48MByte) is used for accesses to the flash device. Default: /DEVICE-BASE=3000000 Abbreviation: /DB= /OFFSET=hhhhhh The programming starts at an offset of hhhhhh relative to the start address of the flash device. If the offset is negative, the offset specifies an address relative to the end of the flash device. See also option /TOP Default: /OFFSET=0 Abbreviation: /O= 1 hhhhhh=number base is hex 28 JTAG145a.doc JTAG-Booster for IDT 64145 /TOP If the option /TOP is used the option /OFFSET= specifies the address where the programming ends (plus one) instead of the starting address. This option is very important for Intel CPU architectures, because target execution always starts at the top of the address space. /FILE-OFFSET=hhhhhh If FILE-OFFSET is specified, the first hhhhhh bytes of the file are skipped and not programmed to target. Default: /FILE-OFFSET=0 Abbreviation: /FO= /LENGTH=hhhhhh The number of programmed bytes may be limited to LENGTH. If no LENGTH is specified the whole file is programmed. Default: /LENGTH=4000000 (64 MByte) Abbreviation: /L= /VERIFY If this option is specified, the result is verified on a cell by cell (cell=8bit or 16bit) basis instead of a complete verify after programming. If you want both a cell by cell verify and a complete verify after programming, please use a additional command line with the verify function. See chapter 2.3 “Verify a Flash Device with file”. /NODUMP In case of a verify error the contents of the flash memory is written to a file with the extension .DMP. With /NODUMP you can suppress this feature. /ERASEALL Erase the whole flash device. If this option isn't set, only those blocks are erased where new data should be written to. /NOERASE This option prevents the flash device from being erased. JTAG145a.doc 29 JTAG-Booster for IDT 64145 /BOOTCS /DEVCS0 /DEVCS1 /DEVCS2 /DEVCS3 This options may be used to specify one or more chip select signals to the flash memory. The used chip selects must be defined as output and inactive in the initialization file. (See chapter 1.6 “Initialization file JTAG145.INI”.) Default: /BOOTCS /NOCS Use this option to switch all chip select signals off. This may be necessary if the device's chip select is generated via a normal decoder instead of using the IDT RC64145 chip select unit. /32L /32H The JTAG-Booster is not able to handle the interface to a dual 16bit ROM (32bit-ROM). With this two options you can select one 16bit half of a 32bitROM. The option /32L selects the low word and /32H selects the high word. Do not specify the option /8BIT together with /32L or /32H. /WRSETUP By default write cycles to the Flash EPROM start with address, data and write strobe set at the same time. With the option /WRSETUP you can force the program to generate a setup time for address and data with respect to the write strobe. Examples: JTAG145 /P BIOS.ROM /VERIFY /O=-400000 This example programs the file BIOS.ROM to the flash memory with an offset of 4 MByte to the top of the boot flash. This is the point, where the MIPS Core fetches the first instructions. JTAG145 /P CE.EVN /VERIFY /32L /DEVCS0 This example programs the file CE.EVN to the lower word of a 32bit-ROM connected to DEVCS0#. 30 JTAG145a.doc JTAG-Booster for IDT 64145 2.2. Read a Flash Device to file Usage: JTAG145 /R filename [optionlist] The contents of a flash device is read and written to a file. The type of flash device is normally detected by the software. When autodetect fails you should use the /DEVICE= option to set the right flash device. The known devices are shown in chapter 1.7 “Supported flash devices”. Options: /DEVICE=devicename See function /P (Chapter 2.1) /NOMAN See function /P (Chapter 2.1) /DEVICE-BASE=hhhhhh2 See function /P (Chapter 2.1) /OFFSET=hhhhhh Reading of the flash memory starts at an offset of hhhhhh relative to the start address of the flash device. If the offset is negative, the offset specifies a address relative to the end of the flash device. See also option /TOP. Default: /OFFSET=0 Abbreviation: /O= /TOP If the option /TOP is used the option /OFFSET= specifies the address where reading ends (plus one) instead of the starting address. /LENGTH=hhhhhh The number of read bytes may be limited to LENGTH. If no LENGTH is specified the whole flash device is read (if no offset is specified). 2 hhhhhh=number base is hex JTAG145a.doc 31 JTAG-Booster for IDT 64145 /BOOTCS /DEVCS0 /DEVCS1 /DEVCS2 /DEVCS3 See function /P (Chapter 2.1) /8BIT /16BIT See function /P (Chapter 2.1) /32L /32H See function /P (Chapter 2.1) /WRSETUP See function /P (Chapter 2.1) Please note: In the function /R write cycles are needed to detect the type of the flash memory. Example: JTAG145 /R BIOS.ABS /L=10000 /TOP This example may be used to read the upper most 64 Kbyte of the flash memory to the file BIOS.ABS. 32 JTAG145a.doc JTAG-Booster for IDT 64145 2.3. Verify a Flash Device with file Usage: JTAG145 /V filename [optionlist] The contents of a flash device is compared with the specified file. If there are differences the memory is dumped to a file with the extension DMP. The type of flash device is normally detected by the software. When autodetect fails you should use the /DEVICE= option to set the right flash device. The known devices are shown in chapter 1.7 “Supported flash devices”. Options: /DEVICE=devicename See function /P (Chapter 2.1) /NOMAN See function /P (Chapter 2.1) /DEVICE-BASE=hhhhhh See function /P (Chapter 2.1) /OFFSET=hhhhhh See function /P (Chapter 2.1) /TOP See function /P (Chapter 2.1) /FILE-OFFSET=hhhhhh See function /P (Chapter 2.1) /LENGTH=hhhhhh See function /P (Chapter 2.1) /NODUMP See function /P (Chapter 2.1) /BOOTCS /DEVCS0 /DEVCS1 /DEVCS2 /DEVCS3 See function /P (Chapter 2.1) JTAG145a.doc 33 JTAG-Booster for IDT 64145 /8BIT /16BIT See function /P (Chapter 2.1) /32L /32H See function /P (Chapter 2.1) /WRSETUP See function /P (Chapter 2.1) Please note: In the function /V write cycles are needed to detect the type of the flash memory. Example: JTAG145 /V ROMDOS.ROM /L=20000 /TOP This example may be used to verify the upper most 128 Kbytes of the flash memory with the file ROMDOS.ROM (with i.e. 512 Kbytes). 34 JTAG145a.doc JTAG-Booster for IDT 64145 2.4. Dump target memory Usage: JTAG145 /DUMP [optionlist] A Hex-Dump of the target memory is printed on the screen, if not redirected to file or device. Options: /OFFSET=hhhhhh3 The memory dump starts at an offset of hhhhhh. Default: /OFFSET=0 Abbreviation: /O= /TOP If the option /TOP is used the option /OFFSET= specifies the address where the dump ends (plus one) instead of the starting address /LENGTH=hhhhhh Default: /LENGTH=100 Abbreviation: /L= /BOOTCS /DEVCS0 /DEVCS1 /DEVCS2 /DEVCS3 See function /P (Chapter 2.1) Default: /BOOTCS /8BIT /16BIT Default: /16BIT /32L /32H See function /P (Chapter 2.1) Example: JTAG145 /DUMP /BOOTCS This example makes a memory dump of the first 256 bytes of the Boot-EPROM. 3 hhhhhh=number base is hex JTAG145a.doc 35 JTAG-Booster for IDT 64145 2.5. Program an I²C-Device Usage: JTAG145 /PI2C filename [optionlist] The specified file is programmed to an I²C-Device (i.e. a serial EEPROM) connected to pins of the CPU. Finally a complete verify is done. If the verify fails, the contents of the I²C-Device is written to a file with the extension DMP. Two methods to connect the I²C-Device to the CPU are supported. The first method is to use two CPU pins, one pin for clock output (I2CCLK) and one pin for serial data input and output (I2CDAT). The second method is to use one pin for clock output (I2CCLK), one for serial data input (I2CDATI) and one for serial data output (I2CDATO). Options: /DEVICE-BASE=hhhhhh4 By default a device start address of 3000000h (=48MByte) is used for accesses to the flash device. Default: /DEVICE-BASE=3000000 Abbreviation: /DB= /OFFSET=hhhhhh The programming starts at an offset of hhhhhh relative to the start address of the I²C-Device. Default: /OFFSET=0 Abbreviation: /O= /FILE-OFFSET=hhhhhh If FILE-OFFSET is specified, the first hhhhhh bytes of the file are skipped and not programmed to target. Default: /FILE-OFFSET=0 Abbreviation: /FO= 4 hhhhhh=number base is hex 36 JTAG145a.doc JTAG-Booster for IDT 64145 /LENGTH=hhhhhh The number of programmed bytes may be limited to LENGTH. If no LENGTH is specified the whole file is programmed. Abbreviation: /L= /NODUMP In case of a verify error the contents of the I²C-Device is written to a file with the extension .DMP. With option /NODUMP you can suppress this feature. /I2CCLK=pin_name Specifies the CPU pin used for serial clock output. /I2CDAT=pin_name Specifies the CPU pin used for serial data input and output. Pin_name must specify a bidirectional pin otherwise an error message occurs. Instead of one bidirectional pin one pin for serial data input and one for serial data output may be used. See option /I2CDATO= and /I2CDATI= . /I2CDATO=pin_name Specifies the CPU pin used for serial data output. Pin_name must specify a output pin otherwise an error message occurs. /I2CDATI=pin_name Specifies the CPU pin used for serial data input. Pin_name must specify a input pin otherwise an error message occurs. Example: JTAG145 /PI2C EEPROM.CFG /I2CCLK=PIO10 /I2CDAT=PIO11 This example loads the file EEPROM.CFG to a serial EEPROM connected to the pins PIO10 and PIO11 of the IDT RC64145 JTAG145a.doc 37 JTAG-Booster for IDT 64145 2.6. Read an I²C-Device to file Usage: JTAG145 /RI2C filename /L=hhhhhh [optionlist] The contents of an I²C-Device (i.e. a serial EEPROM) is read and written to a file. The option /LENGTH= must be specified. Options: /DEVICE-BASE=hhhhhh5 See function /PI2C (Chapter 2.5) /OFFSET=hhhhhh Reading of the I²C-Device starts at an offset of hhhhhh relative to the start address of the I²C-Device. Default: /OFFSET=0 Abbreviation: /O= /LENGTH=hhhhhh The number of read bytes must be specified otherwise an error message occurs. Abbreviation: /L= /I2CCLK=pin_name See function /PI2C (Chapter 2.5) /I2CDAT=pin_name See function /PI2C (Chapter 2.5) /I2CDATO=pin_name See function /PI2C (Chapter 2.5) /I2CDATI=pin_name See function /PI2C (Chapter 2.5) 5 hhhhhh=number base is hex 38 JTAG145a.doc JTAG-Booster for IDT 64145 Example: JTAG145 /RI2C EEPROM.CFG /I2CCLK=PIO10 /I2CDAT=PIO11 /L=100 This example reads 256 bytes from a serial EEPROM to the file EEPROM.CFG. The serial EEPROM is connected to the pins PIO10 and PIO11 of the IDT RC64145. JTAG145a.doc 39 JTAG-Booster for IDT 64145 2.7. Verify an I²C-Device with file Usage: JTAG145 /VI2C filename [optionlist] The contents of an I²C-Device (i.e. a serial EEPROM) is compared with the specified file. If there are differences the contents of the I2C-Device is written to a file with the extension DMP. Options: /DEVICE-BASE= hhhhhh6 See function /PI2C (Chapter 2.5) /OFFSET=hhhhhh See function /PI2C (Chapter 2.5) /FILE-OFFSET=hhhhhh See function /PI2C (Chapter 2.5) /LENGTH=hhhhhh See function /PI2C (Chapter 2.5) /NODUMP See function /PI2C (Chapter 2.5) /I2CCLK=pin_name See function /PI2C (Chapter 2.5) /I2CDAT=pin_name See function /PI2C (Chapter 2.5) /I2CDATO=pin_name See function /PI2C (Chapter 2.5) /I2CDATI=pin_name See function /PI2C (Chapter 2.5) 6 hhhhhh=number base is hex 40 JTAG145a.doc JTAG-Booster for IDT 64145 Example: JTAG145 /VI2C EEPROM.CFG /I2CCLK=PIO10 /I2CDAT=PIO11 This example verifies 256 bytes from a serial EEPROM with the file EEPROM.CFG. The serial EEPROM is connected to the pins PIO10 and PIO11 of the IDT RC64145. JTAG145a.doc 41 JTAG-Booster for IDT 64145 2.8. Dump an I²C-Device Usage: JTAG145 /DUMPI2C [optionlist] A Hex-Dump of an I²C-Device is printed on the screen, if not redirected to file or device. Options: /OFFSET=hhhhhh7 The memory dump starts at an offset of hhhhhh. Default: /OFFSET=0 Abbreviation: /O= /LENGTH=hhhhhh Default: /LENGTH=100 Abbreviation: /L= /I2CCLK=pin_name See function /PI2C (Chapter 2.5) /I2CDAT=pin_name See function /PI2C (Chapter 2.5) /I2CDATO=pin_name See function /PI2C (Chapter 2.5) /I2CDATI=pin_name See function /PI2C (Chapter 2.5) Example: JTAG145 /DUMPI2C /I2CCLK=PIO10 /I2CDAT=PIO11 This example makes a memory dump of the first 100h bytes of a serial EEPROM connected to the CPU. 7 hhhhhh=number base is hex 42 JTAG145a.doc JTAG-Booster for IDT 64145 2.9. Toggle CPU pins Usage: JTAG145 /BLINK /PIN=pinname [optionlist] This command allows to test the hardware by blinking with LEDs or toggling CPU signals. Faster signals can be generated by setting the delay option to zero. This can be a very helpful feature to watch signals on an oscilloscope. Please Note: Not every pin of the IDT RC64145 may be specified as an output pin. Options: /PIN=pin_name CPU pin to toggle. If the option /PIN= is not specified an error message occurs. Most pins of the list in chapter 1.6 “Initialization file JTAG145.INI” can be used. If you type /PIN= without any pin declaration a list of the controller pins is displayed. /DELAY=dddddd8 Time to wait to next change of signal. This option can be adjusted to get optimum signals for measures with the oscilloscope. Default: /DELAY=10000 Example: JTAG145 /BLINK /PIN=DEVCS0# /DELAY=0 This example toggles the DEVCS0# pin very fast which can be followed by the use of an oscilloscope. 8 dddddd=number base is decimal JTAG145a.doc 43 JTAG-Booster for IDT 64145 2.10. Polling CPU pins Usage: JTAG145 /PIN? /PIN=pinname [optionlist] This command allows to test the hardware by polling controller signals. Please Note: Not every pin of the IDT RC64145 may be specified as an input pin. Options: /PIN=pin_name CPU pin to poll. If the option /PIN= is not specified an error message occurs. Most pins of the list in chapter 1.6 “Initialization file JTAG145.INI” can be used. If you type /PIN= without any pin declaration a list of the controller pins is displayed. Example: JTAG145 /PIN? /PIN=RESET# This example samples the reset pin of the IDT RC64145. 44 JTAG145a.doc JTAG-Booster for IDT 64145 2.11. Polling CPU pins while the CPU is running Usage: JTAG145 /SAMPLE /PIN=pinname [optionlist] This command is similar to the function /PIN?. But with this function any pin can be observed, independent of the pin direction. Additional the CPU remains in normal operation. Options: /PIN=pin_name CPU pin to poll. If the option /PIN= is not specified an error message occurs. All pins of the list in chapter 1.6 “Initialization file JTAG145.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. Example: JTAG145 /SAMPLE /PIN=PIO11 This example samples the state of the port pin PIO11 while the IDT RC64145 is running. JTAG145a.doc 45 JTAG-Booster for IDT 64145 2.12. List supported Flash Devices Usage: JTAG145 /LIST [optionlist] This command lists all supported flash devices to screen if not redirected to file or device. Flash devices signed with ´*´ are not yet tested. 46 JTAG145a.doc JTAG-Booster for IDT 64145 3. Implementation Information This chapter summarizes some information about the implementation of the JTAG-Booster and describes some restrictions. • In the IDT RC64145 a system reset does also reset the JTAG interface. Observing the pin SYS_RST# (i.e. with function /PIN? or /SAMPLE) is not possible. • The IDT RC64145 does not have a TRST# pin. The reset of the JTAG interface is connected (internally to the IDT RC64145) to the system reset (Pin SYS_RST#). We recommend not to connect the system reset with the TRST# pin of the JTAG connector. Otherwise the target is reset on any starting of the JTAG-Booster and the function /SAMPLE (see chapter 2.11) does not work. • The JTAG-Booster uses the 32 Bit mode of the JTAG chain. To configure the JTAG interface a pullup resistor is needed at the TDI pin. At end of the system reset (signal SYS_RST#) the TDI pin is sampled to configure the length of the chain. The IDT 64145 should be the first part in the JTAG chain (nearest to TDI) to get best control of the TDI pin. • If the IDT RC64145 is configured to the wrong mode, the JTAG booster aborts with an error message. In this case the target power should be cycled while the JTAG-Booster is not attached to the target. • The pin SYS_DEVOE# must be connected to the output enable pin of the Flash-EPROM. • The pin SYS_DQMWE1# must be connected to the write enable pin of the Flash-EPROM. The pin SYS_DQMWE0# is not available in the 32Bit JTAG chain and can not be used. • Even if there are byte wide devices used, connect SYS_DQMWE1# to all write enable inputs of the Flash-EPROMs. JTAG145a.doc 47 JTAG-Booster for IDT 64145 • In case of programming 8 Bit EPROMs there must be a switch/multiplexer on your board: For normal operation the signal SYS_DQMWE0# must be connected to the write enable input of the Flash-EPROM. For programming with the JTAG-Booster the signal SYS_DQMWE1# must be connected to the Flash-EPROM • As a result of the latched addresses only Flash devices with short unlock vectors are supported. This means that the old AMD 29F010 which needs the unlock addresses 0x5555 and 0x2AAA are not supported, the newer versions AM29F010B have short vectors (0x555 and 0x2AAA) and can be programmed. • Refer to the following table for connecting Flash-EPROMs to the IDT RC64145: 64145 signal SYS_DEVOE# SYS_BOOTCS# 1) SYS_DQMWE1# SYS_DATA0..7 SYS_DATA8..15 SYS_DATA16..31 SYS_ADR0..11 SYS_ADR12..23 2) 8 Bit Flash OE# CS# WE# D0..7 A0..11 3) A12..A23 16 Bit Flash OE# CS# WE# D0..7 D8..15 A0..11 3) A12..23 32 Bit Flash OE# CS# WE# D0..7 D8..15 D16..31 A0..11 3) A12..23 1) Or one of the other chip select signals: SYS_DEVCS0#, SYS_DEVCS1#, SYS_DEVCS2#, SYS_DEVCS3# 2) These signals are the latched SYS_ADR0..11. 3) SYS_ADR0..23 represent always a cell address. SYS_ADR0 should always be connected to the LSB of the device address, regardless of bank width. 48 JTAG145a.doc
FS-935 价格&库存
很抱歉,暂时无法提供与“FS-935”相匹配的价格&库存,您可以联系我们找货
