FS-9003
FS-9003
    DIGIINTERNATIONAL
    JTAG-BOOSTER FOR XSCALE 3.3V
FS-9003 数据手册
JTAG-Booster for Intel XScale P.O: Box 1103 Kueferstrasse 8 Tel. +49 (7667) 908-0 sales@fsforth.de • • • • D-79200 Breisach, Germany D-79206 Breisach, Germany Fax +49 (7667) 908-200 http://www.fsforth.de JTAG-Booster for Intel XScale Copyright  1995..2003: FS FORTH-SYSTEME GmbH Postfach 1103, D-79200 Breisach, Germany Release of Document: Author: Filename: Program Version: September 12, 2003 Dieter Fögele JTAG_XScaleb.doc 4.xx All rights reserved. No part of this document may be copied or reproduced in any form or by any means without the prior written consent of FS FORTH-SYSTEME GmbH. 2 JTAG_XScaleb.doc JTAG-Booster for Intel XScale Table of Contents 1. General ..........................................................................................................5 1.1. Ordering Information ............................................................................6 1.2. System Requirements ..........................................................................6 1.3. Contents of Distribution Disk ................................................................7 1.4. Connecting your PC to the target system .............................................8 1.5. First Example with Intel PXA210/250.................................................. 10 1.6. First Example with Intel PXA255/26x.................................................. 13 1.7. First Example with Intel IOP321.......................................................... 15 1.8. First Example with Intel IXP425 .......................................................... 17 1.9. Trouble Shooting ................................................................................ 19 1.10.Error Messages.................................................................................. 20 1.11.Initialization file JTAGxxx.INI.............................................................. 25 1.12.Supported flash devices..................................................................... 56 2. JTAGxxx Parameter Description................................................................... 57 2.1. Program a Flash Device ..................................................................... 60 2.2. Read a Flash Device to file................................................................. 64 2.3. Verify a Flash Device with file ............................................................. 66 2.4. Dump target memory.......................................................................... 68 2.5. Program an I²C-Device....................................................................... 70 2.6. Read an I²C-Device to file................................................................... 72 2.7. Verify an I²C-Device with file............................................................... 74 2.8. Dump an I²C-Device ........................................................................... 76 2.9. Toggle CPU pins ................................................................................ 78 2.10.Polling CPU pins ................................................................................ 79 2.11.Polling CPU pins while the CPU is running ........................................ 80 2.12.Show status of all CPU pins while the CPU is running ....................... 81 3. Implementation Information .......................................................................... 84 4. Converter Program HEX2BIN.EXE............................................................... 86 5. Support for Windows NT, Windows 2000 and Windows XP ......................... 88 5.1. Installation on a clean system............................................................. 88 5.2. Installation with already installed version 5.x/6.x of Kithara................. 88 5.3. Installation with already installed version 4.x of Kithara ...................... 88 JTAG_XScaleb.doc 3 JTAG-Booster for Intel XScale 5.4. De-Installation version 5.x/6.x: ........................................................... 89 4 JTAG_XScaleb.doc JTAG-Booster for Intel XScale 1. General The programs JTAG250.EXE, JTAG255.EXE, JTAG321.EXE and JTAG425 use the JTAG port of the Intel XScale processors in conjunction with the small JTAGBooster: • • • • • to program data into flash memory to verify and read the contents of a flash memory to make a memory dump to access an I²C Device to test CPU signals All functions are done without any piece of software running in the target. No firmware or BIOS must be written. Bootstrap software may be downloaded to initially unprogrammed memories. The JTAG-BOOSTER' s software is highly optimized to the JTAG chain of a specific target CPU. To give support for all processors of the Intel XScale family, there are three different programs on the distribution disk: • JTAG250.EXE : Tool for Intel PXA210/250 • JTAG255.EXE : Tool for Intel PXA255/26x • JTAG321.EXE : Tool for Intel IOP321 • JTAG425.EXE : Tool for Intel IXP425 Please contact us, if you need support for other members of the Intel XScale family. For latest documentation please refer to the file README.TXT on the distribution disk. JTAG_XScaleb.doc 5 JTAG-Booster for Intel XScale 1.1. Ordering Information The following related products are available • 9003 JTAG-Booster Intel XScale, 3.3V, PXA210/250, PXA255/26X, IOP321, PXA425 DOS/Win9x/WinNT/Win2000/WinXP, delivered with adapter type 285 1.2. System Requirements To successfully run this tool the following requirements must be met: • MSDOS, WIN3.x, WIN9x, WinNT, Win2000 or WindowsXP (WinNT/Win2000/WindowsXP is supported with an additional tool, see chapter 5 “Support for Windows NT, Windows 2000 and Windows XP”) • Intel 80386 or higher • 205 kByte of free DOS memory • Parallel Port 6 JTAG_XScaleb.doc JTAG-Booster for Intel XScale 1.3. Contents of Distribution Disk • JTAG250.EXE JTAG250.OVL Tool for Intel PXA210/250 • JTAG250.INI Template configuration file for Intel PXA210/250. See chapter 1.11 "Initialization file JTAGxxx.INI" • JTAG255.EXE JTAG255.OVL Tool for Intel PXA255/26x • JTAG255.INI Template configuration file for Intel PXA255/26x. See chapter 1.11 "Initialization file JTAGxxx.INI" • JTAG321.EXE JTAG321.OVL Tool for Intel IOP321 • JTAG321.INI Template configuration file for Intel IOP321. See chapter 1.11 "Initialization file JTAGxxx.INI" • JTAG425.EXE JTAG425.OVL Tool for Intel IXP425 • JTAG425.INI Template configuration file for Intel IXP425. See chapter 1.11 "Initialization file JTAGxxx.INI" • HEX2BIN.EXE Converter program to convert Intel HEX and Motorola S-Record files to binary. See chapter 4 "Converter Program HEX2BIN.EXE" • WinNT.zip Support for Windows NT and Windows 2000. See chapter 5 "Support for Windows NT, Windows 2000" • JTAG_V4xx_FLAS HES.pdf List of all supported Flash devices • README.txt Release notes, new features, known problems JTAG_XScaleb.doc 7 JTAG-Booster for Intel XScale 1.4. Connecting your PC to the target system The JTAG-Booster can be plugged into standard parallel ports (LPT1-3) with a DB25-Connector. 1 LPT1-3 1 Élan SC400 Module Élan486 The target end of the cable has the following reference: 1 TCK 2* GND 3 TMS 4 TRST# 5 NC 6 TDI 7 TDO 8 +3.3V *PIN 2 can be detected by the thick cable. To connect your design to the JTAG-BOOSTER you need a single row berg connector with a spacing of 2.54mm on your PCB. The names refer to the target: Pin 7 is the target’s TDO pin and is an input on the JTAG-Booster’s side. The 3.3V version of the JTAG-Booster (FS part number 285) is delivered together with this package. Don’t use the 5V version of the JTAG-Booster (FS part number 227) with a 3.3V target. Don’t apply 5V to the 3.3V version of the JTAG-Booster! Your target must be able to power the JTAG-Booster, it draws about 100mA. Before you start the program, the JTAG-BOOSTER must be plugged to a parallel interface of your PC and to the 8 pin JTAG connector on the target. 8 JTAG_XScaleb.doc JTAG-Booster for Intel XScale The utility is started with the general command line format: JTAGxxx JTAGxxx /function [filename] [/option_1] ... [/option_n]. Note that the function must be the first argument followed (if needed) by the filename. If you want to cancel execution of JTAGxxx, press CTRL-Break-Key. On any error the program aborts with an MSDOS error level of one. JTAG_XScaleb.doc 9 JTAG-Booster for Intel XScale 1.5. First Example with Intel PXA210/250 In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JTAG250 /P MYAPP.BIN at the DOS prompt results in the following output: JTAG250 --- JTAG utility for Intel PXA210/250 Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JTAG250.INI Target: Generic Target Using LPT at I/O-address 0378h JTAG Adapter detected (5) (6) (7) (8) (9) (10) 1 Device detected in JTAG chain Device 0: IDCODE=39264013 Intel XScale PXA210/250 Sum of instruction register bits : 5 CPU position :0 Instruction register offset :0 Length of boundary scan reg : 385 (11) (12) (13) Looking for a known flash device. Please wait.. Dual Intel 28F128 StrataFlash, 3.3V detected Bus size is 32 Bit Erasing Flash-EPROM Block #:0 Programming File MYAPP.BIN 65536 Bytes programmed successfully Erase Time Programming Time 10 : : 0.8 sec 28.1 sec JTAG_XScaleb.doc JTAG-Booster for Intel XScale (1) The initialization file JTAG250.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. With WinNT/Win2000/WinXP you must specify the option /LPT2 to access to the standard address 378h. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the Intel PXA210/250 are switched to bypass mode. (6) The revision (1st digit of the ID) is relevant for the PXA2xx family: Revision 0 -> PXA250 A0 Revision 1 -> PXA250 A1 Revision 2 -> PAA250 B0 Revision 3 -> PXA250 B1 Revision 4 -> PXA250 B2 Revision 5 -> PXA26x B0, use JTAG255.EXE Revision 6 -> PXA255 A0, use JTAG255.EXE (7) The length of all instruction registers in the JTAG chain are added. (8) The position of the Intel XScale in the JTAG chain is assumed to be zero, if not specified in the command line (see option /CPUPOS=). (9) The position of the JTAG instruction register of the Intel XScale is assumed to be zero, if not specified in the command line (see option /IROFFS=). (10) The real length of the boundary scan register is displayed here and compared with the boundary scan register length of a Intel PXA210/250. (11) Two Flashes Intel 28F128 selected with CS0# where found. (12) The resulting data bus size is printed here. JTAG_XScaleb.doc 11 JTAG-Booster for Intel XScale (13) In this example one block must be erased. 12 JTAG_XScaleb.doc JTAG-Booster for Intel XScale 1.6. First Example with Intel PXA255/26x In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JTAG255 /P MYAPP.BIN at the DOS prompt results in the following output: JTAG255 --- JTAG utility for Intel PXA255/26x Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JTAG255.INI Target: Generic Target Using LPT at I/O-address 0378h JTAG Adapter detected (5) (6) (7) (8) (9) (10) 1 Device detected in JTAG chain Device 0: IDCODE=69264013 Intel XScale PXA255/26x Sum of instruction register bits : 5 CPU position :0 Instruction register offset :0 Length of boundary scan reg : 410 (11) (12) (13) Looking for a known flash device. Please wait.. Dual Intel 28F128 StrataFlash, 3.3V detected Bus size is 32 Bit Erasing Flash-EPROM Block #:0 Programming File MYAPP.BIN 65536 Bytes programmed successfully Erase Time Programming Time JTAG_XScaleb.doc : : 0.8 sec 29.9 sec 13 JTAG-Booster for Intel XScale (1) The initialization file JTAG255.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the Intel PXA255/26x are switched to bypass mode. (6) The revision (1st digit of the ID) is relevant for the Intel PXA2xx family: Revision 0 -> PXA250 A0, use JTAG250.EXE Revision 1 -> PXA250 A1, use JTAG250.EXE Revision 2 -> PAA250 B0, use JTAG250.EXE Revision 3 -> PXA250 B1, use JTAG250.EXE Revision 4 -> PXA250 B2, use JTAG250.EXE Revision 5 -> PXA26x B0 Revision 6 -> PXA255 A0 (7) The length of all instruction registers in the JTAG chain are added. (8) The position of the Intel XScale in the JTAG chain is assumed to be zero, if not specified in the command line (see option /CPUPOS=). (9) The position of the JTAG instruction register of the Intel XScale is assumed to be zero, if not specified in the command line (see option /IROFFS=). (10) The real length of the boundary scan register is displayed here and compared with the boundary scan register length of a Intel PXA255/26x. (11) Two Flashes Intel 28F128 selected with CS0# where found. (12) The resulting data bus size is printed here. (13) In this example one block must be erased. 14 JTAG_XScaleb.doc JTAG-Booster for Intel XScale 1.7. First Example with Intel IOP321 In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JTAG321 /P MYAPP.BIN at the DOS prompt results in the following output: JTAG321 --- JTAG utility for Intel IOP321 Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JTAG321.INI Target: Generic Target Using LPT at I/O-address 0378h JTAG Adapter detected (5) 1 Device detected in JTAG chain Device 0: IDCODE=09267013 Intel XScale IOP321, Revision 0 Sum of instruction register bits : 5 CPU position :0 Instruction register offset :0 Length of boundary scan reg : 356 (6) (7) (8) (9) (10) (11) (12) Looking for a known flash device. Please wait.. Dual Intel 28F128 StrataFlash, 3.3V detected Bus size is 32 Bit Erasing Flash-EPROM Block #:0 Programming File MYAPP.BIN 65536 Bytes programmed successfully Erase Time Programming Time JTAG_XScaleb.doc : : 0.8 sec 26.0 sec 15 JTAG-Booster for Intel XScale (1) The initialization file JTAG321.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the Intel IOP321 are switched to bypass mode. (6) The length of all instruction registers in the JTAG chain are added. (7) The position of the Intel XScale in the JTAG chain is assumed to be zero, if not specified in the command line (see option /CPUPOS=). (8) The position of the JTAG instruction register of the Intel XScale is assumed to be zero, if not specified in the command line (see option /IROFFS=). (9) The real length of the boundary scan register is displayed here and compared with the boundary scan register length of a Intel IOP321. (10) Two Flashes Intel 28F128 selected with PCE0# where found. (11) The resulting data bus size is printed here. (12) In this example one block must be erased. 16 JTAG_XScaleb.doc JTAG-Booster for Intel XScale 1.8. First Example with Intel IXP425 In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JTAG425 /P MYAPP.BIN at the DOS prompt results in the following output: JTAG425 --- JTAG utility for Intel IXP425 Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JTAG425.INI Target: Generic Target with IXP425 Using LPT at I/O-address 0378h JTAG Adapter detected (5) (6) (7) (8) (9) (10) 1 Device detected in JTAG chain Device 0: IDCODE=09274013 Intel XScale IXP425, Revision 0 Sum of instruction register bits : 7 CPU position :0 Instruction register offset :0 Length of boundary scan reg : 498 (11) (12) (13) Looking for a known flash device. Please wait.. Intel 28F128 StrataFlash, 3.3V detected Bus size is 16 Bit Erasing Flash-EPROM Block #:0 Programming File MYAPP.BIN 65536 Bytes programmed successfully Erase Time Programming Time JTAG_XScaleb.doc : : 0.8 sec 72.6 sec 17 JTAG-Booster for Intel XScale (1) The initialization file JTAG425.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the Intel IXP425 are switched to bypass mode. (6) There are different ID codes for the Intel IXP425: x9274013 -> Intel IXP425, 533 MHz x9275013 -> Intel IXP425, 400 MHz x9276013 -> Intel IXP425, ??? MHz (reserved) x9277013 -> Intel IXP425, 266 MHz Note: "x" identifies the silicon stepping (7) The length of all instruction registers in the JTAG chain are added. (8) The position of the Intel XScale in the JTAG chain is assumed to be zero, if not specified in the command line (see option /CPUPOS=). (9) The position of the JTAG instruction register of the Intel XScale is assumed to be zero, if not specified in the command line (see option /IROFFS=). (10) The real length of the boundary scan register is displayed here and compared with the boundary scan register length of a Intel IXP425. (11) One Flash Intel 28F128 selected with EX_CS0# was found. (12) The resulting data bus size is printed here. (13) In this example one block must be erased. 18 JTAG_XScaleb.doc JTAG-Booster for Intel XScale 1.9. Trouble Shooting Avoid long distances between your Host-PC and the target. If you are using standard parallel extension cable, the JTAG-BOOSTER may not work. Don't use Dongles between the parallel port and the JTAG-BOOSTER. Switch off all special modes of your printer port (EPP, ECP, ...) in the BIOS setup. Only standard parallel port (SPP) mode is allowed. If there are problems with autodetection of the flash devices use the /DEVICE= option. To speed up autodetection specify one of the options /8BIT /16BIT or /32BIT. Don't use hardware protected flash memories. The used chip selects must be defined as output and inactive in the initialization file (see chapter 1.11 “Initialization file JTAGxxx.INI”). Also the address bits must be defined as output. Use the option /NOWRSETUP to speed up flash programming. JTAG_XScaleb.doc 19 JTAG-Booster for Intel XScale 1.10. Error Messages • 80386 or greater required The JTAG-BOOSTER does not work on a 8088/8086 or a 80286 platform. • Cable not connected or target power fail The JTAG-Booster (or one of the simple Parallel Port JTAG adapters selected with the options /LATTICE /WIGGLER /PLS /TRITON) wasn't found. Please check connection to parallel port and connection to target. Check target power. Check the command line options. Check your BIOSSetup. If you are using this program with WinNT, Win2000 or WinXP you must specify /LPT2 or /LPT-BASE=378 to get access to the standard printer port. • Can't open x:\yyy\zzz\JTAGxxx.OVL The overlay file JTAGxxx.OVL must be in the same directory as JTAGxxx.EXE. • Configuration file XYZ not found. The file specified with the option /INI= wasn't found. • Device offset out of range The value specified with the option /OFFSET= is greater than the size of the detected flash device. • Disk full Writing a output file was aborted as a result of missing disk space. • Do not specify option /NOCS with any other chip select There is a conflict in the command line. • Do not specify option /BYTE-MODE. Flash device does not have a byte mode pin. The flash device specified with the option /DEVICE= does not support switching between 16 (or 32) bit mode and 8 bit mode. In practice it does not have a pin with the name BYTE# 20 JTAG_XScaleb.doc JTAG-Booster for Intel XScale • Error creating file: The output file could not be opened. Please check free disk space or write protection. • Error: Pin-Name is an output only pin The specified pin cannot be sampled. Check the command line. Check the initialization file. • Error: Pin-Name is an input only pin The specified pin cannot be activated. Check the command line. Check the initialization file. • Error: Pin-Name may not be read back The specified pin can be switched to tristate, but cannot be read back. Check the command line. • illegal function: The first parameter of the command line must be a valid function. See chapter 2 “JTAGxxx Parameter Description” for a list of supported functions. • illegal number: The specified number couldn’t be interpret as a valid number. Check the relevant number base. • illegal option: See chapter 2 “JTAGxxx Parameter Description” for a list of supported options. • illegal Pin Type: The name specified with the option /PIN= must be one of the list of chapter 1.11 ”Initialization file JTAGxxx.INI” • illegal Flash Type: The name specified with the option /DEVICE= must be one of the list of chapter 1.12 ”Supported flash devices”. • Input file not found: The specified file cannot be found JTAG_XScaleb.doc 21 JTAG-Booster for Intel XScale • Input file is empty: Files with zero length are not accepted • " " is undefined Please check the syntax in your configuration file. (See chapter 1.11 “Initialization file JTAGxxx.INI”). • LPTx not installed The LPT port specified with /LPTx cannot be found. Please check the LPT port or specify a installed LPT port. Check your BIOS setup. If you are using this program with WinNT, Win2000 or WinXP you 1st must install the WinNT support package as described in chapter 5 "Support for Windows NT, Windows 2000 and Windows XP • missing filename Most functions need a filename as second parameter. • missing option /I2CCLK= Some functions need the option /I2CCLK= to be defined. • missing option /I2CDAT= Some functions need the option /I2CDAT= or the options /I2CDATO= and /I2CDATI= to be defined. • missing option /LENGTH= Some functions need the option /LENGTH= to be defined. • missing option /PIN= Some functions need the option /PIN= to be defined. • More than 9 devices in the JTAG chain or TDO pin stuck at low level The JTAG chain is limited to 9 parts. Check target power. Check the target’s TDO pin. • No devices found in JTAG chain or TDO pin stuck at high level A stream of 32 high bits was detected on the pin TDO. TDO may stuck at high level. Check the connection to your target. Check the target power. Check the target’s TDO pin. 22 JTAG_XScaleb.doc JTAG-Booster for Intel XScale • Option /CPUPOS= out of range The number specified with the option /CPUPOS= must be less or equal to the number of parts minus 1. • Option /IROFFS= out of range Please specify a smaller value • Part at specified position is not a Intel XScale The option /CPUPOS= points to a part not a Intel XScale • Pins specified with /I2CCLK= and /I2CDAT= must have different control cells The pin specified with the option /I2CDAT= must be able to be switched to high impedance while the pin specified with option /I2CCLK= is an active output. See chapter 1.11 “Initialization file JTAGxxx.INI”. • Pins specified with /I2CCLK= and /I2CDATI= must have different control cells The pin specified with the option /I2CDATI= must be able to be switched to high impedance while the pin specified with option /I2CCLK= is an active output. See chapter 1.11 “Initialization file JTAGxxx.INI”. • Pins specified with /I2CDATO= and /I2CDATI= must have different control cells The pin specified with the option /I2CDATI= must be able to be switched to high impedance while the pin specified with option /I2CDATO= is an active output. See chapter 1.11 “Initialization file JTAGxxx.INI”. • Specify only one of these options: Some options are exclusive (i.e. /8BIT and /16BIT). Don't mix them. • Sum of instruction register bits to low. Should be at least 5 bits for a Intel XScale (7 bits for the IXP425) The sum of all instruction register bits in the JTAG chain does not fit to the Intel XScale. Check the target connection. Check the target CPU type. Check the settings for /IROFFS= and /CPUPOS= , if there are several parts in the JTAG chain. JTAG_XScaleb.doc 23 JTAG-Booster for Intel XScale • Target no longer connected There is a cyclic check of the JTAG chain. Check target power. Check target connection. • There are unknown parts in the JTAG chain. Please use the option /IROFFS= to specify the instr. reg. offset of the CPU. If there are unknown parts in the JTAG chain, the program isn’t able to determine the logical position of the CPU’s instruction register. • There is no Intel XScale in the JTAG chain No Intel XScale was found in the JTAG chain. Check the target power. Try with option /DRIVER=4 again. • Value of option /FILE-OFFSET out of range The value of the option /FILE-OFFSET= points behind end of file. • wrong driver # The value specified with the option /DRIVER= is out of range. • Wrong Flash Identifier (xxxx) No valid identifier found. Check the specified chip select signal and the bus width. Try with the option /DEVICE= . • Wrong length of boundary scan register. Should be 385 for a Intel PXA210/250. (Should be 410 for a Intel PXA255/26x/Should be 356 for a Intel IOP321/ Should be 498 for a Intel IXP425.) The length of the boundary scan register of the selected part (if there are more than one in the chain) does not fit to the Intel XScale. Check the target connection. Check the target CPU type. Check the settings for /IROFFS= and /CPUPOS= , if there are several parts in the JTAG chain. 24 JTAG_XScaleb.doc JTAG-Booster for Intel XScale 1.11. Initialization file JTAGxxx.INI This file is used to define the default direction and level of all CPU signals. This file must be carefully adapted to your design with the Intel XScale. The TargetEntry is used to identify your design which is displayed with most commands. When the program JTAGxxx.EXE is started it scans the current directory for an existing initialization file named JTAGxxx.INI. If no entry is found the default values are used. You may also specify the initialization file with the option /INI= . If the specified file isn't found, the program aborts with an error message. The CPU pins can also be used with the functions /BLINK (chapter 2.9), /PIN? (chapter 2.10) and /SAMPLE (chapter 2.11) to test the signals on your design. The sample file below represents the values which are used for default initialization when no initialization file could be found in the current directory and no initialization file is specified with the option /INI=. Changes to the structure of the file could result in errors. Remarks can be added by using //. JTAG_XScaleb.doc 25 JTAG-Booster for Intel XScale Sample File JTAG250.INI: // Description file for Intel PXA210/250 Target: Generic Target // Adapt this file carefully to your design!! // All chip select signals are set to output and inactive. // The chip selects for the external PC-Card are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults. // Pin names are defined in upper case. // Low active signal are signed with a trailing #. // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. GPIO0 Inp // GPIO1 Inp // GP_RST#, GPreset input GPIO2 Inp // GPIO3 Inp // GPIO4 Inp // GPIO5 Inp // GPIO6 Inp // MMCCLK, MMC clock output GPIO7 Inp // 48MHZ, 48MHz clock output GPIO8 Inp // MMCCS0, MMC chip select 0 GPIO9 Inp // MMCCS1, MMC chip select 1 GPIO10 Inp // RTCCLK, RTC 1Hz output GPIO11 Inp // 3.6MHZ, 3.6MHz clock output GPIO12 Inp // 32KHZ, 32kHz clock output GPIO13 Inp // MBGNT, memory controller grant GPIO14 Inp // MBREQ, memory controller alternate bus master request GPIO15 Out,Hi // CS1#, chip select 1 GPIO16 Inp // PWM0, PMW0 output GPIO17 Inp // PWM1, PWM1 output GPIO18 Inp // RDY, ext. bus ready input GPIO19 Inp // DREQ1, ext. DMA request 1 GPIO20 Inp // DREQ0, ext. DMA request 0 GPIO21 Inp // GPIO22 Inp // GPIO23 Inp // SSPSCLK, SSP clock output GPIO24 Inp // SSPSFRM, SSP frame GPIO25 Inp // SSPTXD, SSP transmit data GPIO26 Inp // SSPRXD, SSP receive data GPIO27 Inp // SSPEXTCLK, SSP ext. clock input GPIO28 Inp // BITCLK, AC97 bit clock input 26 JTAG_XScaleb.doc JTAG-Booster for Intel XScale GPIO29 GPIO30 GPIO31 GPIO32 GPIO33 GPIO34 GPIO35 GPIO36 GPIO37 GPIO38 GPIO39 GPIO40 GPIO41 GPIO42 GPIO43 GPIO44 GPIO45 GPIO46 GPIO47 GPIO48 GPIO49 GPIO50 GPIO51 GPIO52 GPIO53 GPIO54 GPIO55 GPIO56 GPIO57 GPIO58 // BITCLK, AC97 bit clock output // BITCLK, I2S bit clock input // BITCLK, I2S bit clock output Inp // SDATA_IN0, AC97 sdata input 0 // SDATA_IN, I2S sdata input Inp // SDATA_OUT, AC97 sdata output // SDATA_OUT, I2S sdata output Inp // SYNC, AC97 sync output // SYNC, I2S sync output Inp // SDATA_IN1, AC97 sdata input 1 // SYSCLK, I2S system clock output Out,Hi // CS5#, chip select 5 Inp // FFRXD, FFUART receive data // MMCCS0, MMC chip select 0 Inp // FFCTS#, FFUART clear to send Inp // FFDCD#, FFUART data carrier detect Inp // FFDSR#, FFUART data terminal ready Inp // FFRI#, FFUART ring indicator Inp // FFTXD, FFUART transmit data // MMCCS1, MMC chip select 1 Inp // FFDTR#, FFUART data terminal ready Inp // FFRTS#, FFUART request to send Inp // BTRXD, BTUART receive data Inp // BTTXD, BTUART transmit data Inp // BTCTS#, BTUART clear to send Inp // BTRTS#, BTUART request to send Inp // RXD, STD_UART receive data // IRRXD, IR receive data Inp // TXD, STD_UART transmit data // IRTXD, IR transmit data Inp // POE#, Card Space output enable Inp // PWE#, Card Space write enable Inp // PIOR#, Card Space I/O read Inp // PIOW#, Card Space I/O write Out,Hi // PCE1#. Card Space card enable 1, !!! Out,Hi // PCE2#, Card Space card enable 2, !!! // MMCCLK, MMC clock output Inp // PSKTSEL#, Card Space socket select // MMCCLK, MMC clock output Inp // PREG#, Card Space register select Inp // PWAIT#, Card Space wait input Inp // IOIS16#, Card Space I/O bus width select Inp // L_DD0, LCD data pin 0 JTAG_XScaleb.doc 27 JTAG-Booster for Intel XScale GPIO59 GPIO60 GPIO61 GPIO62 GPIO63 GPIO64 GPIO65 GPIO66 Inp Inp Inp Inp Inp Inp Inp Inp GPIO67 Inp GPIO68 Inp GPIO69 Inp GPIO70 Inp GPIO71 Inp GPIO72 Inp GPIO73 Inp GPIO74 GPIO75 GPIO76 GPIO77 GPIO78 GPIO79 GPIO80 MMDAT MMCMD CS0# Inp Inp Inp Inp Out,Hi Out,Hi Out,Hi Inp Inp Out,Hi // L_DD1, LCD data pin 1 // L_DD2, LCD data pin 2 // L_DD3, LCD data pin 3 // L_DD4, LCD data pin 4 // L_DD5, LCD data pin 5 // L_DD6, LCD data pin 6 // L_DD7, LCD data pin 7 // L_DD8, LCD data pin 8 // MBREQ, memory controller alternate bus master request // L_DD9, LCD data pin 9 // MMCCS0, MMC chip select 0 // L_DD10, LCD data pin 10 // MMCCS1, MMC chip select 1 // L_DD11, LCD data pin 11 // MMCCLK, MMC clock output // L_DD12, LCD data pin 12 // RTCCLK, RTC 1Hz output // L_DD13, LCD data pin 13 // 3.6MHZ, 3.6MHz clock output // L_DD14, LCD data pin 14 // 32KHZ, 32kHz clock output // L_DD15, LCD data pin 15 // MBGNT, memory controller grant // L_FCLK, LCD frame clock // L_LCLK, LCD line clock // L_PCLK, LCD pixel clock // L_BIAS, LCD AC bias drive // CS2#, chip select 2 // CS3#, chip select 3 // CS4#, chip select 4 // MMC data pin // MMC command pin // Boot Chip Select // Group 85: All pins in this group must be set to the same direction // These pins are bidirectional MD0 Inp // Memory Data Bus MD1 Inp // Memory Data Bus MD2 Inp // Memory Data Bus MD3 Inp // Memory Data Bus MD4 Inp // Memory Data Bus MD5 Inp // Memory Data Bus MD6 Inp // Memory Data Bus 28 JTAG_XScaleb.doc JTAG-Booster for Intel XScale MD7 MD8 MD9 MD10 MD11 MD12 MD13 MD14 MD15 Inp Inp Inp Inp Inp Inp Inp Inp Inp // Memory Data Bus // Memory Data Bus // Memory Data Bus // Memory Data Bus // Memory Data Bus // Memory Data Bus // Memory Data Bus // Memory Data Bus // Memory Data Bus // Group 84: All pins in this group must be set to the same direction // These pins are bidirectional MD16 Inp // Memory Data Bus MD17 Inp // Memory Data Bus MD18 Inp // Memory Data Bus MD19 Inp // Memory Data Bus MD20 Inp // Memory Data Bus MD21 Inp // Memory Data Bus MD22 Inp // Memory Data Bus MD23 Inp // Memory Data Bus MD24 Inp // Memory Data Bus MD25 Inp // Memory Data Bus MD26 Inp // Memory Data Bus MD27 Inp // Memory Data Bus MD28 Inp // Memory Data Bus MD29 Inp // Memory Data Bus MD30 Inp // Memory Data Bus MD31 Inp // Memory Data Bus // Group 205: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back RD/WR# Out,Hi // Read/Write# DQM2 Out,Lo // DQM3 Out,Lo // // Group 207: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back WE# Out,Hi // OE# Out,Hi // JTAG_XScaleb.doc 29 JTAG-Booster for Intel XScale // Group 208: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back SDCLK1 Out,Lo // SDCS0# Out,Hi // DQM0 Out,Lo // SDRAM DQM0 DQM1 Out,Lo // SDRAM DQM1 SDCAS# Out,Hi // SDRAM CAS# SDRAS# Out,Hi // SDRAM RAS# MA0 Out,Lo // MA1 Out,Lo // MA2 Out,Lo // MA3 Out,Lo // MA4 Out,Lo // MA5 Out,Lo // MA6 Out,Lo // MA7 Out,Lo // MA8 Out,Lo // MA9 Out,Lo // MA10 Out,Lo // MA11 Out,Lo // MA12 Out,Lo // MA13 Out,Lo // MA14 Out,Lo // MA15 Out,Lo // MA16 Out,Lo // MA17 Out,Lo // MA18 Out,Lo // MA19 Out,Lo // MA20 Out,Lo // MA21 Out,Lo // MA22 Out,Lo // MA23 Out,Lo // MA24 Out,Lo // MA25 Out,Lo // // Group 81: All pins in this group must be set to the same direction // These pins are bidirectional USB_N Inp // USB_P Inp // 30 JTAG_XScaleb.doc JTAG-Booster for Intel XScale // The following pins are output only pins. // Setting to input (tristate) one of these pins results in an error. PWR_EN Out,Hi // Enable ext. power supply RESET_OUT# Out,Lo // Reset ouput ACRESET# Out,Lo // AC97 audio port reset output SDCLK0 Out,Lo // SDRAM clock output 0 SDCLK2 Out,Lo // SDRAM clock output 2 SDCKE0 Out,Lo // SDRAM clock enable 0 SDCKE1 Out,Lo // SDRAM clock enable 1 SDCS1# Out,Hi // SDRAM chip select 1 SDCS2# Out,Hi // SDRAM chip select 2 SDCS3# Out,Hi // SDRAM chip select 3 // The following pins are input only. // Setting to output of one of these pins results in an error. // Declaration of the direction of these pins is optional. TEST Inp // Test Mode input, must be grounded TESTCLK Inp // Test clock input, should be grounded VDD_FAULT# Inp // VDD fault BATT_FAULT# Inp // Battery fault BOOT_SEL0 Inp // boot programming select pin BOOT_SEL1 Inp // boot programming select pin BOOT_SEL2 Inp // boot programming select pin RESET# Inp // hard reset input JTAG_XScaleb.doc 31 JTAG-Booster for Intel XScale Sample File JTAG255.INI: // Description file for Intel PXA255/26x Target: Generic Target // Adapt this file carefully to your design!! // All chip select signals are set to output and inactive. // The chip selects for the external PC-Card are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults. // Pin names are defined in upper case. // Low active signal are signed with a trailing #. // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. GPIO0 Inp // GPIO1 Inp // GP_RST#, GPreset input GPIO2 Inp // GPIO3 Inp // GPIO4 Inp // GPIO5 Inp // GPIO6 Inp // MMCCLK, MMC clock output GPIO7 Inp // 48MHZ, 48MHz clock output GPIO8 Inp // MMCCS0, MMC chip select 0 GPIO9 Inp // MMCCS1, MMC chip select 1 // USB_RCV, USB client single-ended interface RCV GPIO10 Inp // RTCCLK, RTC 1Hz output GPIO11 Inp // 3.6MHZ, 3.6MHz clock output GPIO12 Inp // 32KHZ, 32kHz clock output GPIO13 Inp // MBGNT, memory controller grant GPIO14 Inp // MBREQ, memory controller alternate bus master request GPIO15 Out,Hi // CS1#, chip select 1 GPIO16 Inp // PWM0, PMW0 output GPIO17 Inp // PWM1, PWM1 output GPIO18 Inp // RDY, ext. bus ready input GPIO19 Inp // DREQ1, ext. DMA request 1 GPIO20 Inp // DREQ0, ext. DMA request 0 GPIO21 Inp // GPIO22 Inp // GPIO23 Inp // SSPSCLK, SSP clock output GPIO24 Inp // SSPSFRM, SSP frame GPIO25 Inp // SSPTXD, SSP transmit data GPIO26 Inp // SSPRXD, SSP receive data GPIO27 Inp // SSPEXTCLK, SSP ext. clock input 32 JTAG_XScaleb.doc JTAG-Booster for Intel XScale GPIO28 GPIO29 GPIO30 GPIO31 GPIO32 GPIO33 GPIO34 GPIO35 GPIO36 GPIO37 GPIO38 GPIO39 GPIO40 GPIO41 GPIO42 GPIO43 GPIO44 GPIO45 GPIO46 GPIO47 GPIO48 GPIO49 GPIO50 Inp // BITCLK, AC97 bit clock input // BITCLK, AC97 bit clock output // BITCLK, I2S bit clock input // BITCLK, I2S bit clock output Inp // SDATA_IN0, AC97 sdata input 0 // SDATA_IN, I2S sdata input Inp // SDATA_OUT, AC97 sdata output // SDATA_OUT, I2S sdata output Inp // SYNC, AC97 sync output // SYNC, I2S sync output Inp // SDATA_IN1, AC97 sdata input 1 // SYSCLK, I2S system clock output // USB_VP, USB client single-ended interface VP Out,Hi // CS5#, chip select 5 Inp // FFRXD, Full Function UART receive data // MMCCS0, MMC chip select 0 // USB_VM, USB client single-ended interface VM Inp // FFCTS#, Full Function UART clear to send Inp // FFDCD#, Full Function UART data carrier detect Inp // FFDSR#, Full Function UART data terminal ready Inp // FFRI#, Full Function UART ring indicator Inp // FFTXD, Full Function UART transmit data // MMCCS1, MMC chip select 1 // USB_VPO, USB client single-ended interface VPO Inp // FFDTR#, Full Function UART data terminal ready Inp // FFRTS#, Full Function UART request to send Inp // BTRXD, Bluetooth UART receive data // HWRXD, Hardware UART receive data Inp // BTTXD, Bluetooth UART transmit data // HWTXD, Hardware UART transmit data Inp // BTCTS#, Bluetooth UART clear to send // HWCTS#, Hardware UART clear to send Inp // BTRTS#, Bluetooth UART request to send // HWRTS#, Hardware UART request to send Inp // RXD, STD_UART receive data // IRRXD, IrDA receive data Inp // TXD, STD_UART transmit data // IRTXD, IrDA transmit data Inp // POE#, Card Space output enable // HWTXD, Hardware UART transmit data Inp // PWE#, Card Space write enable // HWRXD, Hardware UART receive data Inp // PIOR#, Card Space I/O read JTAG_XScaleb.doc 33 JTAG-Booster for Intel XScale GPIO51 Inp GPIO52 GPIO53 Out,Hi Out,Hi GPIO54 Inp GPIO55 GPIO56 Inp Inp GPIO57 Inp GPIO58 GPIO59 GPIO60 GPIO61 GPIO62 GPIO63 GPIO64 GPIO65 GPIO66 Inp Inp Inp Inp Inp Inp Inp Inp Inp GPIO67 Inp GPIO68 Inp GPIO69 Inp GPIO70 Inp GPIO71 Inp GPIO72 Inp GPIO73 Inp GPIO74 GPIO75 GPIO76 GPIO77 GPIO78 GPIO79 Inp Inp Inp Inp Out,Hi Out,Hi 34 // HWCTS#, Hardware UART clear to send // PIOW#, Card Space I/O write // HWRTS#, Hardware UART request to send // PCE1#. Card Space card enable 1, !!! // PCE2#, Card Space card enable 2, !!! // MMCCLK, MMC clock output // PSKTSEL#, Card Space socket select // MMCCLK, MMC clock output // PREG#, Card Space register select // PWAIT#, Card Space wait input // USB_VMO, USB client single-ended interface VMO // IOIS16#, Card Space I/O bus width select // USB_OE#, USB client single-ended interface OE# // L_DD0, LCD data pin 0 // L_DD1, LCD data pin 1 // L_DD2, LCD data pin 2 // L_DD3, LCD data pin 3 // L_DD4, LCD data pin 4 // L_DD5, LCD data pin 5 // L_DD6, LCD data pin 6 // L_DD7, LCD data pin 7 // L_DD8, LCD data pin 8 // MBREQ, memory controller alternate bus master request // L_DD9, LCD data pin 9 // MMCCS0, MMC chip select 0 // L_DD10, LCD data pin 10 // MMCCS1, MMC chip select 1 // L_DD11, LCD data pin 11 // MMCCLK, MMC clock output // L_DD12, LCD data pin 12 // RTCCLK, RTC 1Hz output // L_DD13, LCD data pin 13 // 3.6MHZ, 3.6MHz clock output // L_DD14, LCD data pin 14 // 32KHZ, 32kHz clock output // L_DD15, LCD data pin 15 // MBGNT, memory controller grant // L_FCLK, LCD frame clock // L_LCLK, LCD line clock // L_PCLK, LCD pixel clock // L_BIAS, LCD AC bias drive // CS2#, chip select 2 // CS3#, chip select 3 JTAG_XScaleb.doc JTAG-Booster for Intel XScale GPIO80 GPIO81 GPIO82 GPIO83 GPIO84 GPIO85 GPIO86 GPIO87 GPIO88 GPIO89 MMDAT MMCMD CS0# Out,Hi Inp Inp Inp Inp Inp Out,Hi Out,Hi Out,Hi Out,Lo Inp Inp Out,Hi // CS4#, chip select 4 // NSSPSCLK, Network synchronous serial port (output) // NSSPSFRM, Network synchronous serial frame signal (output) // NSSPTXD, Network synchronous serial port transmit (output) // NSSPRXD, Network synchronous serial port receive (input) // // SDCS2#, SDRAM chip select 2 // SDCS3#, SDRAM chip select 3 // RD/WR#, Read/Write# // ACRESET#, AC97 audio port reset output // MMC data pin // MMC command pin // Boot Chip Select // Group 85: All pins in this group must be set to the same direction // These pins are bidirectional MD0 Inp // Memory Data Bus MD1 Inp // Memory Data Bus MD2 Inp // Memory Data Bus MD3 Inp // Memory Data Bus MD4 Inp // Memory Data Bus MD5 Inp // Memory Data Bus MD6 Inp // Memory Data Bus MD7 Inp // Memory Data Bus MD8 Inp // Memory Data Bus MD9 Inp // Memory Data Bus MD10 Inp // Memory Data Bus MD11 Inp // Memory Data Bus MD12 Inp // Memory Data Bus MD13 Inp // Memory Data Bus MD14 Inp // Memory Data Bus MD15 Inp // Memory Data Bus // Group 84: All pins in this group must be set to the same direction // These pins are bidirectional MD16 Inp // Memory Data Bus MD17 Inp // Memory Data Bus MD18 Inp // Memory Data Bus MD19 Inp // Memory Data Bus MD20 Inp // Memory Data Bus MD21 Inp // Memory Data Bus MD22 Inp // Memory Data Bus MD23 Inp // Memory Data Bus JTAG_XScaleb.doc 35 JTAG-Booster for Intel XScale MD24 MD25 MD26 MD27 MD28 MD29 MD30 MD31 Inp Inp Inp Inp Inp Inp Inp Inp // Memory Data Bus // Memory Data Bus // Memory Data Bus // Memory Data Bus // Memory Data Bus // Memory Data Bus // Memory Data Bus // Memory Data Bus // Group 205: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back DQM2 Out,Lo // DQM3 Out,Lo // // Group 207: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back WE# Out,Hi // OE# Out,Hi // // Group 208: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back SDCLK1 Out,Lo // SDCS0# Out,Hi // DQM0 Out,Lo // SDRAM DQM0 DQM1 Out,Lo // SDRAM DQM1 SDCAS# Out,Hi // SDRAM CAS# SDRAS# Out,Hi // SDRAM RAS# MA0 Out,Lo // MA1 Out,Lo // MA2 Out,Lo // MA3 Out,Lo // MA4 Out,Lo // MA5 Out,Lo // MA6 Out,Lo // MA7 Out,Lo // MA8 Out,Lo // MA9 Out,Lo // MA10 Out,Lo // MA11 Out,Lo // MA12 Out,Lo // MA13 Out,Lo // MA14 Out,Lo // MA15 Out,Lo // 36 JTAG_XScaleb.doc JTAG-Booster for Intel XScale MA16 MA17 MA18 MA19 MA20 MA21 MA22 MA23 MA24 MA25 Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo // // // // // // // // // // // Group 81: All pins in this group must be set to the same direction // These pins are bidirectional USB_N Inp // USB_P Inp // // The following pins are output only pins. // Setting to input (tristate) one of these pins results in an error. PWR_EN Out,Hi // Enable ext. power supply RESET_OUT# Out,Lo // Reset ouput SDCLK0 Out,Lo // SDRAM clock output 0 SDCLK2 Out,Lo // SDRAM clock output 2 SDCKE0 Out,Lo // SDRAM clock enable 0 SDCKE1 Out,Lo // SDRAM clock enable 1 SDCS1# Out,Hi // SDRAM chip select 1 // The following pins are input only. // Setting to output of one of these pins results in an error. // Declaration of the direction of these pins is optional. TEST Inp // Test Mode input, must be grounded TESTCLK Inp // Test clock input, should be grounded VDD_FAULT# Inp // VDD fault BATT_FAULT# Inp // Battery fault BOOT_SEL0 Inp // boot programming select pin BOOT_SEL1 Inp // boot programming select pin BOOT_SEL2 Inp // boot programming select pin RESET# Inp // hard reset input JTAG_XScaleb.doc 37 JTAG-Booster for Intel XScale Sample File JTAG321.INI: // Description file for Intel IOP321 Target: Generic Target // Adapt this file carefully to your design!! // All chip select signals are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults. // Pin names are defined in upper case. // Low active signal are signed with a trailing #. // Group 39: All pins in this group must be set to the same direction // These pins are bidirectional PCE0# Out,Hi // PBI Peripheral Chip Enable 0 // RST_MODE# configuration pin latch at pos. edge of P_RST# PCE1# Out,Hi // PBI Peripheral Chip Enable 1 // RETRY configuration pin latch at pos. edge of P_RST# PCE2# Out,Hi // PBI Peripheral Chip Enable 2 // 32BITPCI# configuration pin latch at pos. edge of P_RST# PCE3# Out,Hi // PBI Peripheral Chip Enable 3 // P_BOOT16# configuration pin latch at pos. edge of P_RST# PCE4# Out,Hi // PBI Peripheral Chip Enable 4 // PBI66MHZ# configuration pin latch at pos. edge of P_RST# PCE5# Out,Hi // PBI Peripheral Chip Enable 5 // PBI100MHZ# configuration pin latch at pos. edge of P_RST# // Group 40: All pins in this group must be set to the same direction // These pins are bidirectional AD24 Inp // PBI Address/Data Bus AD25 Inp // PBI Address/Data Bus AD26 Inp // PBI Address/Data Bus AD27 Inp // PBI Address/Data Bus AD28 Inp // PBI Address/Data Bus AD29 Inp // PBI Address/Data Bus AD30 Inp // PBI Address/Data Bus AD31 Inp // PBI Address/Data Bus // Group 41: All pins in this group must be set to the same direction // These pins are bidirectional AD16 Inp // PBI Address/Data Bus AD17 Inp // PBI Address/Data Bus AD18 Inp // PBI Address/Data Bus AD19 Inp // PBI Address/Data Bus AD20 Inp // PBI Address/Data Bus 38 JTAG_XScaleb.doc JTAG-Booster for Intel XScale AD21 AD22 AD23 Inp Inp Inp // PBI Address/Data Bus // PBI Address/Data Bus // PBI Address/Data Bus // Group 42: All pins in this group must be set to the same direction // These pins are bidirectional AD8 Inp // PBI Address/Data Bus AD9 Inp // PBI Address/Data Bus AD10 Inp // PBI Address/Data Bus AD11 Inp // PBI Address/Data Bus AD12 Inp // PBI Address/Data Bus AD13 Inp // PBI Address/Data Bus AD14 Inp // PBI Address/Data Bus AD15 Inp // PBI Address/Data Bus // Group 43: All pins in this group must be set to the same direction // These pins are bidirectional AD0 Inp // PBI Address/Data Bus AD1 Inp // PBI Address/Data Bus AD2 Inp // PBI Address/Data Bus AD3 Inp // PBI Address/Data Bus AD4 Inp // PBI Address/Data Bus AD5 Inp // PBI Address/Data Bus AD6 Inp // PBI Address/Data Bus AD7 Inp // PBI Address/Data Bus // Group 51: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back A2 Out,Lo // PBI Demultiplexed Address A3 Out,Lo // PBI Demultiplexed Address // Group 52: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back WIDTH0 Out,Lo // PBI WIDTH1 Out,Lo // PBI JTAG_XScaleb.doc 39 JTAG-Booster for Intel XScale // Group 53: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back BE0# Out,Lo // PBI Byte Enable for AD0..7 for 32/16Bit // PBI Address Bit A0 for 8Bit BE1# Out,Lo // PBI Byte Enable for AD8..15 for 32Bit // PBI Address Bit A1 for 16/8Bit BE2# Out,Lo // PBI Byte Enable for AD16..23 for 32Bit BE3# Out,Lo // PBI Byte Enable for AD24..31 for 32Bit // PBI Byte Enable for AD8..15 for 16Bit // Group 111: All pins in this group must be set to the same direction // These pins are bidirectional P_AD32 Inp // PCI Data upper bits P_AD33 Inp // P_AD34 Inp // P_AD35 Inp // P_AD36 Inp // P_AD37 Inp // P_AD38 Inp // P_AD39 Inp // P_AD40 Inp // P_AD41 Inp // P_AD42 Inp // P_AD43 Inp // P_AD44 Inp // P_AD45 Inp // P_AD46 Inp // P_AD47 Inp // P_AD48 Inp // P_AD49 Inp // P_AD50 Inp // P_AD51 Inp // P_AD52 Inp // P_AD53 Inp // P_AD54 Inp // P_AD55 Inp // P_AD56 Inp // P_AD57 Inp // P_AD58 Inp // P_AD59 Inp // P_AD60 Inp // P_AD61 Inp // P_AD62 Inp // 40 JTAG_XScaleb.doc JTAG-Booster for Intel XScale P_AD63 Inp // // Group 112: All pins in this group must be set to the same direction // These pins are bidirectional P_AD0 Inp // PCI Address/Data P_AD1 Inp // P_AD2 Inp // P_AD3 Inp // P_AD4 Inp // P_AD5 Inp // P_AD6 Inp // P_AD7 Inp // P_AD8 Inp // P_AD9 Inp // P_AD10 Inp // P_AD11 Inp // P_AD12 Inp // P_AD13 Inp // P_AD14 Inp // P_AD15 Inp // P_AD16 Inp // P_AD17 Inp // P_AD18 Inp // P_AD19 Inp // P_AD20 Inp // P_AD21 Inp // P_AD22 Inp // P_AD23 Inp // P_AD24 Inp // P_AD25 Inp // P_AD26 Inp // P_AD27 Inp // P_AD28 Inp // P_AD29 Inp // P_AD30 Inp // P_AD31 Inp // // Group 113: All pins in this group must be set to the same direction // These pins are bidirectional P_CBE0# Inp // PCI Command and Byte Enable P_CBE1# Inp // PCI Command and Byte Enable P_CBE2# Inp // PCI Command and Byte Enable P_CBE3# Inp // PCI Command and Byte Enable JTAG_XScaleb.doc 41 JTAG-Booster for Intel XScale // Group 114: All pins in this group must be set to the same direction // These pins are bidirectional P_CBE4# Inp // PCI Byte Enable P_CBE5# Inp // PCI Byte Enable P_CBE6# Inp // PCI Byte Enable P_CBE7# Inp // PCI Byte Enable // Group 224: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back M_CK0 Out,Lo // DDR Memory Clock M_CK0# Out,Hi // DDR Memory Clock // Group 225: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back M_CK1 Out,Lo // SDRAM Memory Clock M_CK1# Out,Hi // SDRAM Memory Clock // Group 226: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back M_CK2 Out,Lo // SDRAM Memory Clock M_CK2# Out,Hi // SDRAM Memory Clock // Group 227: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back SCS0# Out,Hi // SDRAM Chip Select SCS1# Out,Hi // SDRAM Chip Select SRAS# Out,Hi // SDRAM Row Address Strobe SCAS# Out,Hi // SDRAM Column Address Strobe SWE# Out,Hi // SDRAM Write Enable M_RST# Out,Lo // SDRAM Reset Output RCVENO# Out,Hi // SDRAM Receive Enable Out SCKE0 Out,Lo // SDRAM Clock Enable Output SCKE1 Out,Lo // SDRAM Clock Enable Output // Group 228: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back SBA0 Out,Lo // SDRAM Bank Address SBA1 Out,Lo // SDRAM Bank Address SA0 Out,Lo // SDRAM Memory Address SA1 Out,Lo // SDRAM Memory Address SA2 Out,Lo // SDRAM Memory Address SA3 Out,Lo // SDRAM Memory Address 42 JTAG_XScaleb.doc JTAG-Booster for Intel XScale SA4 SA5 SA6 SA7 SA8 SA9 SA10 SA11 SA12 Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo // SDRAM Memory Address // SDRAM Memory Address // SDRAM Memory Address // SDRAM Memory Address // SDRAM Memory Address // SDRAM Memory Address // SDRAM Memory Address // SDRAM Memory Address // SDRAM Memory Address // Group 229: All pins in this group must be set to the same direction // SDQM0..3 are tristateable, but can not be read back // DQ0..31 are bidirectional SDQM0 Inp // SDRAM Data Mask SDQM1 Inp // SDRAM Data Mask SDQM2 Inp // SDRAM Data Mask SDQM3 Inp // SDRAM Data Mask DQ0 Inp // SDRAM Data DQ1 Inp // SDRAM Data DQ2 Inp // SDRAM Data DQ3 Inp // SDRAM Data DQ4 Inp // SDRAM Data DQ5 Inp // SDRAM Data DQ6 Inp // SDRAM Data DQ7 Inp // SDRAM Data DQ8 Inp // SDRAM Data DQ9 Inp // SDRAM Data DQ10 Inp // SDRAM Data DQ11 Inp // SDRAM Data DQ12 Inp // SDRAM Data DQ13 Inp // SDRAM Data DQ14 Inp // SDRAM Data DQ15 Inp // SDRAM Data DQ16 Inp // SDRAM Data DQ17 Inp // SDRAM Data DQ18 Inp // SDRAM Data DQ19 Inp // SDRAM Data DQ20 Inp // SDRAM Data DQ21 Inp // SDRAM Data DQ22 Inp // SDRAM Data DQ23 Inp // SDRAM Data DQ24 Inp // SDRAM Data DQ25 Inp // SDRAM Data JTAG_XScaleb.doc 43 JTAG-Booster for Intel XScale DQ26 DQ27 DQ28 DQ29 DQ30 DQ31 Inp Inp Inp Inp Inp Inp // SDRAM Data // SDRAM Data // SDRAM Data // SDRAM Data // SDRAM Data // SDRAM Data // Group 232: All pins in this group must be set to the same direction // SDQM4..7 are tristateable, but can not be read back // DQ32..63 are bidirectional SDQM4 Out,Lo // SDRAM Data Mask SDQM5 Out,Lo // SDRAM Data Mask SDQM6 Out,Lo // SDRAM Data Mask SDQM7 Out,Lo // SDRAM Data Mask DQ32 Inp // SDRAM Data DQ33 Inp // SDRAM Data DQ34 Inp // SDRAM Data DQ35 Inp // SDRAM Data DQ36 Inp // SDRAM Data DQ37 Inp // SDRAM Data DQ38 Inp // SDRAM Data DQ39 Inp // SDRAM Data DQ40 Inp // SDRAM Data DQ41 Inp // SDRAM Data DQ42 Inp // SDRAM Data DQ43 Inp // SDRAM Data DQ44 Inp // SDRAM Data DQ45 Inp // SDRAM Data DQ46 Inp // SDRAM Data DQ47 Inp // SDRAM Data DQ48 Inp // SDRAM Data DQ49 Inp // SDRAM Data DQ50 Inp // SDRAM Data DQ51 Inp // SDRAM Data DQ52 Inp // SDRAM Data DQ53 Inp // SDRAM Data DQ54 Inp // SDRAM Data DQ55 Inp // SDRAM Data DQ56 Inp // SDRAM Data DQ57 Inp // SDRAM Data DQ58 Inp // SDRAM Data DQ59 Inp // SDRAM Data DQ60 Inp // SDRAM Data 44 JTAG_XScaleb.doc JTAG-Booster for Intel XScale DQ61 DQ63 Inp Inp // SDRAM Data // SDRAM Data // Group 233: All pins in this group must be set to the same direction // SCB0..7 are bidirectional // SDQM8 is tristateable, but can not be read back SCB0 Inp // SDRAM ECC Check SCB1 Inp // SDRAM ECC Check SCB2 Inp // SDRAM ECC Check SCB3 Inp // SDRAM ECC Check SCB4 Inp // SDRAM ECC Check SCB5 Inp // SDRAM ECC Check SCB6 Inp // SDRAM ECC Check SCB7 Inp // SDRAM ECC Check SDQM8 Inp // SDRAM Data Mask // Group 230: All pins in this group must be set to the same direction // These pins are bidirectional DQS0 Inp // SDRAM Data Strobe DQS1 Inp // SDRAM Data Strobe DQS2 Inp // SDRAM Data Strobe DQS3 Inp // SDRAM Data Strobe // Group 231: All pins in this group must be set to the same direction // These pins are bidirectional DQS4 Inp // SDRAM Data Strobe DQS5 Inp // SDRAM Data Strobe DQS6 Inp // SDRAM Data Strobe DQS7 Inp // SDRAM Data Strobe // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. NC0 Inp // not connected NC1 Inp // not connected NC2 Inp // not connected GPIO0 Inp // General Purpose Input/Output GPIO1 Inp // General Purpose Input/Output GPIO2 Inp // General Purpose Input/Output GPIO3 Inp // General Purpose Input/Output GPIO4 Inp // = SDA1 GPIO5 Inp // = SCL1 GPIO6 Inp // = SDA0 JTAG_XScaleb.doc 45 JTAG-Booster for Intel XScale GPIO7 RDYRCV# P_ACK64# P_REQ64# P_PAR64 P_SERR# P_PERR# P_PAR P_STOP# P_DEVSEL# P_TRDY# P_FRAME# DQS8 Inp Out,Hi Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // = SCL0 // PBI Read/Recover // PCI Bus Acknowledge 64 bit Transfer // PCI Bus Request 64 bit // PCI Bus Upper DWORD Parity // PCI Bus System Error // PCI Parity Error // PCI Bus Parity // PCI Bus Stop // PCI Bus Device Select // PCI Bus Target Ready // PCI Bus Initiator Ready // SDRAM Data Strobe // The following pins are tristateable, but can not be read back TXD Inp // Serial Transmit Data SFRM Inp // Serial Frame SSCKO Inp // Serial Port Clock Out ALE Out,Lo // PBI Address Latch Enable ADS# Out,Hi // PBI Address Strobe W/R# Out,Hi // PBI Write/Read FWE# Out,Hi // PBI Flash Write Enable DEN# Out,Hi // PBI Data Enable BLAST# Out,Hi // PBI Burst Last PB_RST# Out,Hi // PBI Peripheral Bus Reset HOLDA Out,Lo // PBI Hold Acknowledge PB_CLK Out,Lo // PBI Peripheral Bus Clock P_REQ# Inp // PCI Bus Request P_INTA# Out,Hi // PCI Interrupt Output P_INTB# Out,Hi // PCI Interrupt Output P_INTC# Out,Hi // PCI Interrupt Output P_INTD# Out,Hi // PCI Interrupt Output // The following pins are input only. // Setting to output of one of these pins results in an error. // Declaration of the direction of these pins is optional. HPI# Inp // High Priority Interrupt PWRDELAY Inp // Power Fail Delay RXD Inp // Serial Receive Data SSCKI Inp // Serial Port Clock In XINT0# Inp // External Interrupt Request XINT1# Inp // External Interrupt Request XINT2# Inp // External Interrupt Request 46 JTAG_XScaleb.doc JTAG-Booster for Intel XScale XINT3# HOLD P_M66EN P_GNT# P_RST# P_IDSEL P_CLK RCVENI# Inp Inp Inp Inp Inp Inp Inp Inp JTAG_XScaleb.doc // External Interrupt Request // PBI HOLD // PCI 66MHz enable // PCI Bus Grant input // PCI Reset Input // PCI Initialization Device Select // PCI Clock Input // SDRAM Receive Enable Input 47 JTAG-Booster for Intel XScale Sample File JTAG425.INI: // Description file for Intel IXP425 Target: Generic Target // Adapt this file carefully to your design!! // All chip select signals are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults. // Pin names are defined in upper case. // Low active signal are signed with a trailing #. // The following pins are complete bidirectional pins // The direction of each pin can be set independent of the other pins // For Flash Programming these pins must be set to output EX_ADDR23 Out,Lo // Expansion Bus Address EX_ADDR22 Out,Lo // EX_ADDR21 Out,Lo // EX_ADDR20 Out,Lo // EX_ADDR19 Out,Lo // EX_ADDR18 Out,Lo // EX_ADDR17 Out,Lo // EX_ADDR16 Out,Lo // EX_ADDR15 Out,Lo // EX_ADDR14 Out,Lo // EX_ADDR13 Out,Lo // EX_ADDR12 Out,Lo // EX_ADDR11 Out,Lo // EX_ADDR10 Out,Lo // EX_ADDR9 Out,Lo // EX_ADDR8 Out,Lo // EX_ADDR7 Out,Lo // EX_ADDR6 Out,Lo // EX_ADDR5 Out,Lo // EX_ADDR4 Out,Lo // EX_ADDR3 Out,Lo // EX_ADDR2 Out,Lo // EX_ADDR1 Out,Lo // EX_ADDR0 Out,Lo // 48 JTAG_XScaleb.doc JTAG-Booster for Intel XScale // The following pins are complete bidirectional pins // These pins are switched between output/active and input/tristate during // programming of Flash-EPROMs EX_DATA15 Inp // Expansion Bus Data EX_DATA14 Inp // EX_DATA13 Inp // EX_DATA12 Inp // EX_DATA11 Inp // EX_DATA10 Inp // EX_DATA9 Inp // EX_DATA8 Inp // EX_DATA7 Inp // EX_DATA6 Inp // EX_DATA5 Inp // EX_DATA4 Inp // EX_DATA3 Inp // EX_DATA2 Inp // EX_DATA1 Inp // EX_DATA0 Inp // // The following pins are tristateable, but can not be read back // These pins are modified during flash programming EX_CS7# Out,Hi // Expansion Bus Chip Select EX_CS6# Out,Hi // EX_CS5# Out,Hi // EX_CS4# Out,Hi // EX_CS3# Out,Hi // EX_CS2# Out,Hi // EX_CS1# Out,Hi // EX_CS0# Out,Hi // EX_RD# Out,Hi // Expansion Bus Read Strobe EX_WR# Out,Hi // Expansion Bus Write Strobe // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. HSS_TXFRAME1 Inp // High Speed Serial Transmit Frame 1 HSS_TXCLK1 Inp // High Speed Serial Transmit Clock 1 HSS_RXFRAME1 Inp // High Speed Serial Receive Frame 1 HSS_RXCLK1 Inp // High Speed Serial Receive Clock 1 HSS_TXFRAME0 Inp // High Speed Serial Transmit Frame 0 HSS_TXCLK0 Inp // High Speed Serial Transmit Clock 0 HSS_RXFRAME0 Inp // High Speed Serial Receive Frame 0 JTAG_XScaleb.doc 49 JTAG-Booster for Intel XScale HSS_RXCLK0 PCI_GNT0# PCI_REQ0# PCI_SERR# PCI_PERR# PCI_DEVSEL# PCI_STOP# PCI_TRDY# PCI_IRDY# PCI_FRAME# PCI_PAR PCI_CBE3# PCI_CBE2# PCI_CBE1# PCI_CBE0# PCI_AD31 PCI_AD30 PCI_AD29 PCI_AD28 PCI_AD27 PCI_AD26 PCI_AD25 PCI_AD24 PCI_AD23 PCI_AD22 PCI_AD21 PCI_AD20 PCI_AD19 PCI_AD18 PCI_AD17 PCI_AD16 PCI_AD15 PCI_AD14 PCI_AD13 PCI_AD12 PCI_AD11 PCI_AD10 PCI_AD9 PCI_AD8 PCI_AD7 PCI_AD6 PCI_AD5 PCI_AD4 50 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // High Speed Serial Receive Clock 0 // PCI Arbitration Grant // PCI Arbitration Request // PCI System Error // PCI Parity Error // PCI Device Select // PCI Stop // PCI Target Ready // PCI Initiator Ready // PCI Cycle Frame // PCI Parity // PCI Command/Byte Enable // // // // PCI ADdress/Data // // // // // // // // // // // // // // // // // // // // // // // // // // // JTAG_XScaleb.doc JTAG-Booster for Intel XScale PCI_AD3 PCI_AD2 PCI_AD1 PCI_AD0 SDM_DATA31 SDM_DATA30 SDM_DATA29 SDM_DATA28 SDM_DATA27 SDM_DATA26 SDM_DATA25 SDM_DATA24 SDM_DATA23 SDM_DATA22 SDM_DATA21 SDM_DATA20 SDM_DATA19 SDM_DATA18 SDM_DATA17 SDM_DATA16 SDM_DATA15 SDM_DATA14 SDM_DATA13 SDM_DATA12 SDM_DATA11 SDM_DATA10 SDM_DATA9 SDM_DATA8 SDM_DATA7 SDM_DATA6 SDM_DATA5 SDM_DATA4 SDM_DATA3 SDM_DATA2 SDM_DATA1 SDM_DATA0 USB_DUSB_D+ GPIO15 GPIO14 GPIO13 GPIO12 GPIO11 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp JTAG_XScaleb.doc // // // // // SDRAM Data // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // CLKOUT // // // // 51 JTAG-Booster for Intel XScale GPIO10 GPIO9 GPIO8 GPIO7 GPIO6 GPIO5 GPIO4 GPIO3 GPIO2 GPIO1 UTP_IP_ADDR4 UTP_IP_ADDR3 UTP_IP_ADDR2 UTP_IP_ADDR1 UTP_IP_ADDR0 UTP_OP_ADDR4 UTP_OP_ADDR3 UTP_OP_ADDR2 UTP_OP_ADDR1 UTP_OP_ADDR0 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // // // // // // // // // // // Utopia Receive PHY Address // // // // // Utopia Transmit PHY Address // // // // // The following pins are tristateable, but can not be read back HSS_TXDATA1 Inp // High Speed Serial Transmit Data HSS_TXDATA0 Inp // PCI_INTA# Inp // PCI Interrupt PCI_GNT3# Inp // PCI Arbitration Grant PCI_GNT2# Inp // PCI_GNT1# Inp // SDM_CLKOUT Out,Lo // SDRAM Clock SDM_CKE Out,Lo // SDRAM Clock Enable SDM_WE# Out,Hi // SDRAM Write Enable SDM_RAS# Out,Hi // SDRAM Row Address Strobe SDM_CAS# Out,Hi // SDRAM Column Address Strobe SDM_BA1 Out,Lo // SDRAM BAnk Address SDM_BA0 Out,Lo // SDM_DQM3 Inp // SDRAM Data Bus Mask SDM_DQM2 Inp // SDM_DQM1 Inp // SDM_DQM0 Inp // SDM_CS1# Out,Hi // SDRAM Chip Select SDM_CS0# Out,Hi // SDM_ADDR12 Out,Lo // SDRAM Address SDM_ADDR11 Out,Lo // 52 JTAG_XScaleb.doc JTAG-Booster for Intel XScale SDM_ADDR10 SDM_ADDR9 SDM_ADDR8 SDM_ADDR7 SDM_ADDR6 SDM_ADDR5 SDM_ADDR4 SDM_ADDR3 SDM_ADDR2 SDM_ADDR1 SDM_ADDR0 EX_ALE RTS1# TXDATA1 RTS0# TXDATA0 UTP_IP_FCO UTP_OP_SOC UTP_OP_DATA7 UTP_OP_DATA6 UTP_OP_DATA5 UTP_OP_DATA4 UTP_OP_DATA3 UTP_OP_DATA2 UTP_OP_DATA1 UTP_OP_DATA0 UTP_OP_FCO ETH_TXDATA1_3 ETH_TXDATA1_2 ETH_TXDATA1_1 ETH_TXDATA1_0 ETH_TXEN1 ETH_TXDATA0_3 ETH_TXDATA0_2 ETH_TXDATA0_1 ETH_TXDATA0_0 ETH_TXEN0 Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // // // // // // // // // // // // Expansion Bus Address Latch Enable // // // // // Utopia Receive Data Flow Control Output // Utopia Transmit Start of Cell // Utopia Transmit Data // // // // // // // // Utopia Transmit Data Flow Control Output // // // // // // // // // // // The following pins are input only. // Setting to output of one of these pins results in an error. // Declaration of the direction of these pins is optional. HSS_RXDATA1 Inp // HSS_RXDATA0 Inp // JTAG_XScaleb.doc 53 JTAG-Booster for Intel XScale PCI_CLKIN PCI_REQ3# PCI_REQ2# PCI_REQ1# PCI_IDSEL EX_RDY3# EX_RDY2# EX_RDY1# EX_RDY0# EX_CLK EX_IOWAIT# CTS1# RXDATA1 CTS0# RXDATA0 UTP_IP_DATA7 UTP_IP_DATA6 UTP_IP_DATA5 UTP_IP_DATA4 UTP_IP_DATA3 UTP_IP_DATA2 UTP_IP_DATA1 UTP_IP_DATA0 UTP_IP_SOC UTP_IP_FCI UTP_IP_CLK UTP_OP_FCI UTP_OP_CLK RESET_IN# BYPASS_CLK ETH_COL1 ETH_CRS1 ETH_RXCLK1 ETH_RXDATA1_3 ETH_RXDATA1_2 ETH_RXDATA1_1 ETH_RXDATA1_0 ETH_RXDV1 ETH_TXCLK1 ETH_COL0 ETH_CRS0 ETH_RXCLK0 ETH_RXDATA0_3 54 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // // // // // // // // // // // // // // // // Utopia Receive Data // // // // // // // // Utopia Receive Start of Cell // Utopia Receive Data Flow Control Input // Utopia Receive Data Clock Input // Utopia Transmit Data Flow Control Input // Utopia Transmit Data Clock Input // // // // // // // // // // // // // // // JTAG_XScaleb.doc JTAG-Booster for Intel XScale ETH_RXDATA0_2 ETH_RXDATA0_1 ETH_RXDATA0_0 ETH_RXDV0 ETH_TXCLK0 Inp Inp Inp Inp Inp JTAG_XScaleb.doc // // // // // 55 JTAG-Booster for Intel XScale 1.12. Supported flash devices Type JTAGxxx /LIST [optionlist] to get a online list of all flash types which could be used with the /DEVICE= option. See separate file JTAG_V4xx_FLASHES.pdf to get a complete list of supported flash types. 56 JTAG_XScaleb.doc JTAG-Booster for Intel XScale 2. JTAGxxx Parameter Description When you start JTAGxxx.EXE without any parameters the following help screen with all possible functions and options is displayed: JTAGxxx --- JTAG utility for Intel XScale Copyright © FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy Programming of Flash-EPROMs and hardware tests on targets with the Intel XScale. The JTAG-Booster is needed to connect the parallel port of the PC to the JTAG port of the Intel XScale. Usage: JTAGxxx /function [filename] [/option_1] ... [/option_n] Supported functions: /P : Program a Flash Device /R : Read a Flash Device to file /V : Verify a Flash Device with file /DUMP : Make a target dump /PI2C : Program an I2C Device with file /RI2C : Read an I2C Device to file /VI2C : Verify an I2C Device with file /DUMPI2C : Make a dump of an I2C Device /BLINK : Toggle a CPU pin /PIN? : Test a CPU pin /SAMPLE : Test a CPU pin while the CPU is running /SNAP : Test all CPU pins while CPU is running /LIST : Print a list of supported Flash devices JTAG_XScaleb.doc 57 JTAG-Booster for Intel XScale Supported Options: /CS0 /CS1 /CS5 /NOCS /BM /PAUSE /LATTICE /ERASEALL /LPT-BASE= /32BIT /LENGTH= L= /O= /DELAY= /DATA-MASK= /DM= /PIN= /I2CCLK= I2CBIG /WATCH= /CS2 /CS3 /NOWRSETUP /TOP /P /NODUMP /LPT1 /LPT2 /16BIT /8BIT /FILE-OFFSET= /FO= /DEVICE-BASE= /DB= /IROFFS= /CPUPOS= /I2CDAT= /I2CDATI= /OUT= /INI= /CS4 /BYTE-MODE /NOERASE /LPT3 /NOMAN /OFFSET= /DRIVER= /DEVICE= /I2CDATO= /REP The following options are valid for most functions: /DRIVER=x with x = 1,2,3,4 A driver for the interface to the JTAG-BOOSTER on the parallel port may be specified. /DRIVER=1 selects the fastest available driver, /DRIVER=4 selects the slowest one. Use a slower driver if there are problems with JTAGBOOSTER. Default: /DRIVER=3 /INI=file An initialization file may be specified. By default the current directory is searched for the file JTAGxxx.INI. If this file is not found and no initialization file is specified in the command line, default initialization values are used (see also chapter 1.11 “Initialization file JTAGxxx.INI”). Note: The initialization file is not loaded for the functions /SAMPLE (chapter 2.11) and /SNAP (chapter 2.12). Default: /INI=JTAGxxx.INI /LATTICE /WIGGLER /PLS /TRITON Besides the standard JTAG-Booster interface there are several simple "ParallelPort-JTAG" interfaces supported. With this interfaces the programming performance, of course, is reduced. 58 JTAG_XScaleb.doc JTAG-Booster for Intel XScale /LPT1 /LPT2 /LPT3 A printer port may be specified where the JTAG-Booster resides. If you are using this program with WinNT, Win2000 or WinXP you must specify /LPT2 or /LPT-BASE=378 to get access to the standard printer port. Default: /LPT1 /LPT-BASE The physical I/O-Address of printer port may be specified instead of the logical printer name. Useful option, if you work with WinNT, Win2000 or WindowsXP, because the standard printer port is mapped as LPT2 here. Use the option /LPT-BASE=378 to get a command line which works independent of the operation system. /OUT=file_or_device All screen outputs are redirected to the specified file or device. Note that you can't redirect to the same parallel port where the JTAG-Booster resides. Default: /OUT=CON /PAUSE With the option /PAUSE you can force the program to stop after each screen. Please do not use this option if you redirect the output to a file. Abbreviation: /P /WATCH= With the option /WATCH= a pin can be specified, which is toggled twice per second, while the program is active. This pin may be the trigger of a watchdog. This pin must be specified as output in the initialization file. /IROFFS= Specifies the position of the Intel XScale instruction register within the JTAG chain. In most cases this option is not needed. Default: /IROFFS=0 /CPUPOS= Specifies the position of the Intel XScale within the JTAG chain. Default: /CPUPOS=0 JTAG_XScaleb.doc 59 JTAG-Booster for Intel XScale 2.1. Program a Flash Device Usage: JTAGxxx /P filename [optionlist] The specified file is programmed into the flash memory. The flash status is polled after programming of each cell (cell=8, 16 or 32 bit, depending on current data bus width). In case of a programming error, the contents of the flash memory is written to a file with the extension DMP. If you want a complete verify after programming, please use an additional command line with the verify function. See chapter 2.3 “Verify a Flash Device with file”. In most cases this additional verify step is not needed. The type of the flash device is normally detected by the software. When autodetection fails you should use the /DEVICE= option together with /8BIT or /16BIT or /32BIT to set the right flash device and configuration. The known flash devices are shown in chapter 1.12 “Supported flash devices”. Options: /DEVICE=devicename The flash device is detected automatically by switching to autoselect mode. In case of trouble you should select the flash device by using this parameter to avoid autodetection. Combine this option with one of the following options which specify the data bus width and the option /BYTE-MODE if applicable. /8BIT /16BIT /32BIT Specifies the data bus width to the target flash device. You can speed up autodetection, if you specify the correct data bus size. You need this option together with the option /DEVICE= to explicit specify a specific flash configuration. /BYTE-MODE If there is a flash device connected to the CPU which does have a byte mode pin (8 bit and 16/32 bit bus mode), you can force it to be used as 8 bit mode with the option /BYTE-MODE. In most cases this option will not be needed. 60 JTAG_XScaleb.doc JTAG-Booster for Intel XScale /NOMAN If you use a flash device which is identical to one of the supported parts, but is from a different manufacturer, with this option you can suppress the comparison of the manufacturer identification code. We recommend to use this option together with the /DEVICE= option to avoid failures in autodetection. /DEVICE-BASE=hhhhhh1 Here you can specify a flash device starting address. In most cases, where the flash device is selected with one of the CPUs chip select pins, this parameter is not needed. But if there is any decoding logic in your hardware, this option will be needed. Especially, if there are several flash banks connected to one chip select and a sub decoding logic generates chip selects for these flash banks, this option can be used to select a specific flash bank. Default: /DEVICE-BASE=0 Abbreviation: /DB= /OFFSET=hhhhhh The programming starts at an offset of hhhhhh relative to the start address of the flash device. If the offset is negative, the offset specifies an address relative to the end of the flash device. See also option /TOP Default: /OFFSET=0 Abbreviation: /O= /TOP If the option /TOP is used the option /OFFSET= specifies the address where the programming ends (plus one) instead of the starting address. This option is very important for Intel CPU architectures, because target execution always starts at the top of the address space. /FILE-OFFSET=hhhhhh If FILE-OFFSET is specified, the first hhhhhh bytes of the file are skipped and not programmed to target. Default: /FILE-OFFSET=0 Abbreviation: /FO= 1 hhhhhh=number base is hex JTAG_XScaleb.doc 61 JTAG-Booster for Intel XScale /LENGTH=hhhhhh The number of programmed bytes may be limited to LENGTH. If no LENGTH is specified the whole file is programmed. Default: /LENGTH=4000000 (64 MByte) Abbreviation: /L= /NODUMP In case of a verify error the contents of the flash memory is written to a file with the extension .DMP. With /NODUMP you can suppress this feature. /ERASEALL Erase the whole flash device. If this option isn't set, only those blocks are erased where new data should be written to. /NOERASE This option prevents the flash device from being erased. /CS0 /CS1 /CS2 /CS3 /CS4 /CS5 This options may be used to specify one or more chip select signals to the flash memory. The used chip selects must be defined as output and inactive in the initialization file. (See chapter 1.11 “Initialization file JTAGxxx.INI”.) Default: /CS0 /NOCS Use this option to switch off all chip select signals. This may be necessary if the device's chip select is generated via a normal decoder instead of using the Intel XScale chip select unit. /NOWRSETUP By default write cycles to the Flash EPROM are realized with three steps: 1. set address/data 2. write strobe active 3. write strobe inactive. In most cases it is possible to set the write strobe coincident with setting of address and data by specifying the option /NOWRSETUP. This increases the programming speed by 50%. 62 JTAG_XScaleb.doc JTAG-Booster for Intel XScale Examples: JTAGxxx /P ROMDOS.ROM /L=20000 /TOP This example programs up to 128 Kbytes of the file ROMDOS.ROM (with i.e. 512 Kbytes) to the top of the boot flash memory. JTAGxxx /P CE.ROM /32BIT /CS1 This example programs the file CE.ROM to the 32 Bit Flash-EPROM connected to CS1#. JTAG_XScaleb.doc 63 JTAG-Booster for Intel XScale 2.2. Read a Flash Device to file Usage: JTAGxxx /R filename [optionlist] The contents of a flash device is read and written to a file. The type of the flash device is normally detected by the software. When autodetection fails you should use the /DEVICE= option together with /8BIT or /16BIT or /32BIT to set the right flash device and configuration. The known devices are shown in chapter 1.12 “Supported flash devices”. Options: /DEVICE=devicename See function /P (Chapter 2.1) /8BIT /16BIT /32BIT See function /P (Chapter 2.1) /BYTE-MODE See function /P (Chapter 2.1) /NOMAN See function /P (Chapter 2.1) /DEVICE-BASE=hhhhhh2 See function /P (Chapter 2.1) /OFFSET=hhhhhh Reading of the flash memory starts at an offset of hhhhhh relative to the start address of the flash device. If the offset is negative, the offset specifies a address relative to the end of the flash device. See also option /TOP. Default: /OFFSET=0 Abbreviation: /O= 2 hhhhhh=number base is hex 64 JTAG_XScaleb.doc JTAG-Booster for Intel XScale /TOP If the option /TOP is used the option /OFFSET= specifies the address where reading ends (plus one) instead of the starting address. /LENGTH=hhhhhh The number of read bytes may be limited to LENGTH. If no LENGTH is specified the whole flash device is read (if no offset is specified). /CS0 /CS1 /CS2 /CS3 /CS4 /CS5 See function /P (Chapter 2.1) /NOWRSETUP See function /P (Chapter 2.1) Please note: In the function /R write cycles are needed to detect the type of the flash memory. Example: JTAGxxx /R BIOS.ABS /L=10000 /TOP This example may be used to read the upper most 64 Kbyte of the flash memory to the file BIOS.ABS. JTAG_XScaleb.doc 65 JTAG-Booster for Intel XScale 2.3. Verify a Flash Device with file Usage: JTAGxxx /V filename [optionlist] The contents of a flash device is compared with the specified file. If there are differences the memory is dumped to a file with the extension DMP. The type of flash device is normally detected by the software. When autodetect fails you should use the /DEVICE= option together with /8BIT or /16BIT or /32BIT to set the right flash device and configuration. The known devices are shown in chapter 1.12 “Supported flash devices”. Options: /DEVICE=devicename See function /P (Chapter 2.1) /8BIT /16BIT /32BIT See function /P (Chapter 2.1) /BYTE-MODE See function /P (Chapter 2.1) /NOMAN See function /P (Chapter 2.1) /DEVICE-BASE=hhhhhh See function /P (Chapter 2.1) /OFFSET=hhhhhh See function /P (Chapter 2.1) /TOP See function /P (Chapter 2.1) /FILE-OFFSET=hhhhhh See function /P (Chapter 2.1) 66 JTAG_XScaleb.doc JTAG-Booster for Intel XScale /LENGTH=hhhhhh See function /P (Chapter 2.1) /NODUMP See function /P (Chapter 2.1) /CS0 /CS1 /CS2 /CS3 /CS4 /CS5 See function /P (Chapter 2.1) /NOWRSETUP See function /P (Chapter 2.1) Please note: In the function /V write cycles are needed to detect the type of the flash memory. Example: JTAGxxx /V ROMDOS.ROM /L=20000 /TOP This example may be used to verify the upper most 128 Kbytes of the flash memory with the file ROMDOS.ROM (with i.e. 512 Kbytes). JTAG_XScaleb.doc 67 JTAG-Booster for Intel XScale 2.4. Dump target memory Usage: JTAGxxx /DUMP [optionlist] A Hex-Dump of the target memory is printed on the screen, if not redirected to file or device. Options: /8BIT /16BIT /32BIT Default: /32BIT /OFFSET=hhhhhh The memory dump starts at an offset of hhhhhh plus the device start address (see option /DEVICE-BASE=). Default: /OFFSET=0 Abbreviation: /O= /DEVICE-BASE=hhhhhh3 The device start address is used as an additional offset. This gives the function /DUMP the same behavior as function /P /V and /R. Default: /DEVICE-BASE=0 Abbreviation: /DB= /TOP If the option /TOP is used the option /OFFSET= specifies the address where the dump ends (plus one) instead of the starting address /LENGTH=hhhhhh Default: /LENGTH=100 Abbreviation: /L= /CS0 /CS1 /CS2 /CS3 /CS4 /CS5 See function /P (Chapter 2.1) Default: /CS0 3 hhhhhh=number base is hex 68 JTAG_XScaleb.doc JTAG-Booster for Intel XScale Example: JTAGxxx /DUMP This example makes a memory dump of the first 256 bytes of the Boot-EPROM. JTAG_XScaleb.doc 69 JTAG-Booster for Intel XScale 2.5. Program an I²C-Device Usage: JTAGxxx /PI2C filename [/I2CBIG] [optionlist] The specified file is programmed to an I²C-Device (i.e. a serial EEPROM) connected to pins of the CPU. Finally a complete verify is done. If the verify fails, the contents of the I²C-Device is written to a file with the extension DMP. Two methods to connect the I²C-Device to the CPU are supported. The first method is to use two CPU pins, one pin for clock output (I2CCLK) and one pin for serial data input and output (I2CDAT). The second method is to use one pin for clock output (I2CCLK), one for serial data input (I2CDATI) and one for serial data output (I2CDATO). Options: /I2CBIG Specify this option if there is a device which needs a three byte address instead of a two byte address. This option must be the first option after the filename. /DEVICE-BASE=hhhhhh This option specifies an I²C device starting address. The default values are chosen to access an serial EEPROM. Default: /DEVICE-BASE=5000 (if option /I2CBIG omitted) Default: /DEVICE-BASE=500000 (if option /I2CBIG specified) /OFFSET=hhhhhh The programming starts at an offset of hhhhhh relative to the start address of the I²C-Device. Default: /OFFSET=0 Abbreviation: /O= /FILE-OFFSET=hhhhhh If FILE-OFFSET is specified, the first hhhhhh bytes of the file are skipped and not programmed to target. Default: /FILE-OFFSET=0 Abbreviation: /FO= 70 JTAG_XScaleb.doc JTAG-Booster for Intel XScale /LENGTH=hhhhhh The number of programmed bytes may be limited to LENGTH. If no LENGTH is specified the whole file is programmed. Abbreviation: /L= /NODUMP In case of a verify error the contents of the I²C-Device is written to a file with the extension .DMP. With option /NODUMP you can suppress this feature. /I2CCLK=pin_name Specifies the CPU pin used for serial clock output. /I2CDAT=pin_name Specifies the CPU pin used for serial data input and output. Pin_name must specify a bidirectional pin otherwise an error message occurs. Instead of one bidirectional pin one pin for serial data input and one for serial data output may be used. See option /I2CDATO= and /I2CDATI= . /I2CDATO=pin_name Specifies the CPU pin used for serial data output. Pin_name must specify a output pin otherwise an error message occurs. /I2CDATI=pin_name Specifies the CPU pin used for serial data input. Pin_name must specify a input pin otherwise an error message occurs. Example: JTAGxxx /PI2C EEPROM.CFG /I2CCLK=FLAG0 /I2CDAT=FLAG1 This example loads the file EEPROM.CFG to a serial EEPROM connected to the pins FLAG0 and FLAG1 of the Intel XScale JTAG_XScaleb.doc 71 JTAG-Booster for Intel XScale 2.6. Read an I²C-Device to file Usage: JTAGxxx /RI2C filename [/I2CBIG] /L=hhhhhh [optionlist] The contents of an I²C-Device (i.e. a serial EEPROM) is read and written to a file. The option /LENGTH= must be specified. Options: /I2CBIG This option must be the first option after the filename. See function /PI2C (Chapter 2.5) /DEVICE-BASE=hhhhhh See function /PI2C (Chapter 2.5) /OFFSET=hhhhhh Reading of the I²C-Device starts at an offset of hhhhhh relative to the start address of the I²C-Device. Default: /OFFSET=0 Abbreviation: /O= /LENGTH=hhhhhh The number of read bytes must be specified otherwise an error message occurs. Abbreviation: /L= /I2CCLK=pin_name See function /PI2C (Chapter 2.5) /I2CDAT=pin_name See function /PI2C (Chapter 2.5) /I2CDATO=pin_name See function /PI2C (Chapter 2.5) /I2CDATI=pin_name See function /PI2C (Chapter 2.5) 72 JTAG_XScaleb.doc JTAG-Booster for Intel XScale Example: JTAGxxx /RI2C EEPROM.CFG /I2CCLK=GP26 /I2CDAT=GP27 /L=100 This example reads 256 bytes from a serial EEPROM to the file EEPROM.CFG. The serial EEPROM is connected to the pins CP26 and GP27 of the Intel XScale. JTAG_XScaleb.doc 73 JTAG-Booster for Intel XScale 2.7. Verify an I²C-Device with file Usage: JTAGxxx /VI2C filename [/I2CBIG] [optionlist] The contents of an I²C-Device (i.e. a serial EEPROM) is compared with the specified file. If there are differences the contents of the I²C -Device is written to a file with the extension DMP. Options: /I2CBIG This option must be the first option after the filename. See function /PI2C (Chapter 2.5) /DEVICE-BASE=hhhhhh See function /PI2C (Chapter 2.5) /OFFSET=hhhhhh See function /PI2C (Chapter 2.5) /FILE-OFFSET=hhhhhh See function /PI2C (Chapter 2.5) /LENGTH=hhhhhh See function /PI2C (Chapter 2.5) /NODUMP See function /PI2C (Chapter 2.5) /I2CCLK=pin_name See function /PI2C (Chapter 2.5) /I2CDAT=pin_name See function /PI2C (Chapter 2.5) /I2CDATO=pin_name See function /PI2C (Chapter 2.5) 74 JTAG_XScaleb.doc JTAG-Booster for Intel XScale /I2CDATI=pin_name See function /PI2C (Chapter 2.5) Example: JTAGxxx /VI2C EEPROM.CFG /I2CCLK=GP26 /I2CDAT=GP27 This example verifies 256 bytes from a serial EEPROM with the file EEPROM.CFG. The serial EEPROM is connected to the pins CP26 and GP27 of the Intel XScale. JTAG_XScaleb.doc 75 JTAG-Booster for Intel XScale 2.8. Dump an I²C-Device Usage: JTAGxxx /DUMPI2C [/I2CBIG] [optionlist] A Hex-Dump of an I²C-Device is printed on the screen, if not redirected to file or device. Options: /I2CBIG This option must be the first option. See function /PI2C (Chapter 2.5) /DEVICE-BASE=hhhhhh See function /PI2C (Chapter 2.5) /OFFSET=hhhhhh4 The memory dump starts at an offset of hhhhhh. Default: /OFFSET=0 Abbreviation: /O= /LENGTH=hhhhhh Default: /LENGTH=100 Abbreviation: /L= /I2CCLK=pin_name Specifies the CPU pin used for serial clock output. /I2CDAT=pin_name Specifies the CPU pin used for serial data input and output. Pin_name must specify a bidirectional pin otherwise an error message occurs. Instead of one bidirectional pin one pin for serial data input and one for serial data output may be used. See option /I2CDATO= and /I2CDATI= . /I2CDATO=pin_name Specifies the CPU pin used for serial data output. Pin_name must specify a output pin otherwise an error message occurs. 4 hhhhhh=number base is hex 76 JTAG_XScaleb.doc JTAG-Booster for Intel XScale /I2CDATI=pin_name Specifies the CPU pin used for serial data input. Pin_name must specify a input pin otherwise an error message occurs. Example: JTAGxxx /DUMPI2C /I2CCLK=FLAG0 /I2CDAT=FLAG1 This example makes a memory dump of the first 100h bytes of a serial EEPROM connected to the CPU. JTAG_XScaleb.doc 77 JTAG-Booster for Intel XScale 2.9. Toggle CPU pins Usage: JTAGxxx /BLINK /PIN=pinname [optionlist] This command allows to test the hardware by blinking with LEDs or toggling CPU signals. Faster signals can be generated by setting the delay option to zero. This can be a very helpful feature to watch signals on an oscilloscope. The signal on the defined pin has an duty cycle of 1/2: The level is 67% high and 33% low. Please Note: Not every pin of the Intel XScale may be specified as an output pin. Options: /PIN=pin_name CPU pin to toggle. If the option /PIN= is not specified an error message occurs. Most pins of the list in chapter 1.11 “Initialization file JTAGxxx.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. /DELAY=dddddd5 Time to wait to next change of signal. This option can be adjusted to get optimum signals for measures with the oscilloscope. Default: /DELAY=10000 Example: JTAGxxx /BLINK /PIN=FLAG3 /DELAY=0 This example toggles the FLAG3 pin very fast which can be followed by the use of an oscilloscope. 5 dddddd=number base is decimal 78 JTAG_XScaleb.doc JTAG-Booster for Intel XScale 2.10. Polling CPU pins Usage: JTAGxxx /PIN? /PIN=pinname [optionlist] This command allows to test the hardware by polling CPU signals. Please Note: Not every pin of the Intel XScale may be specified as an input pin. Options: /PIN=pin_name CPU pin to poll. If the option /PIN= is not specified an error message occurs. Most pins of the list in chapter 1.11 “Initialization file JTAGxxx.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. Example: JTAGxxx /PIN? /PIN=RESET# This example samples the reset pin of the Intel XScale. JTAG_XScaleb.doc 79 JTAG-Booster for Intel XScale 2.11. Polling CPU pins while the CPU is running Usage: JTAGxxx /SAMPLE /PIN=pinname [optionlist] This command is similar to the function /PIN?. But with this function any pin can be observed, independent of the pin direction. Furthermore the CPU remains in normal operation. Options: /PIN=pin_name CPU pin to poll. If the option /PIN= is not specified an error message occurs. All pins of the list in chapter 1.11 “Initialization file JTAGxxx.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. Example: JTAGxxx /SAMPLE /PIN=FLAG3 This example samples the state of the port pin FLAG3 while the Intel XScale is running. 80 JTAG_XScaleb.doc JTAG-Booster for Intel XScale 2.12. Show status of all CPU pins while the CPU is running Usage: JTAGxxx /SNAP [optionlist] This function is similar to the function /SAMPLE, but displays the status of all CPU pins on the screen. The CPU remains in normal operation. The behavior of the function /SNAP depends on the option /REP: With this option specified, the JTAG-Booster samples and displays the state of the CPU pins repetitive. Without this option the status of the pins is displayed only once. Options: /PAUSE Use this option to stop the output after each displayed screen. Don't use this option together with the option /REP or if the output is redirected to a file. Abbreviation /P /REP If this option is specified the status of the pins is sampled and displayed repetitive. In case of many signals the display is separated into several screens. Therefor we recommend to use a video mode with 43 or 50 lines. Use the '+' and the '-' key to switch between different screens. Any other key terminates the program. JTAG_XScaleb.doc 81 JTAG-Booster for Intel XScale Sample output: This is a sample output for a Intel PXA210/250 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 0 GPIO0 1 GPIO4 1 GPIO8 1 GPIO12 1 GPIO16 1 GPIO20 0 GPIO24 1 GPIO28 1 GPIO32 1 GPIO36 1 GPIO40 1 GPIO44 1 GPIO48 1 GPIO52 1 GPIO56 1 GPIO60 1 GPIO64 1 GPIO68 1 GPIO72 1 GPIO76 1 GPIO80 0 USB_P 0 MD1 1 MD5 1 MD9 1 MD13 0 MD17 0 MD21 0 MD25 0 MD29 1 RESET_OUT# 1 SDCLK1 1 SDCS0# 0 DQM0 1 SDCAS# 1 CS0# 0 MA3 0 MA7 0 MA11 1 MA15 0 MA19 82 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1 GPIO1 1 GPIO5 1 GPIO9 1 GPIO13 1 GPIO17 1 GPIO21 1 GPIO25 1 GPIO29 1 GPIO33 1 GPIO37 1 GPIO41 1 GPIO45 1 GPIO49 1 GPIO53 0 GPIO57 1 GPIO61 1 GPIO65 1 GPIO69 1 GPIO73 1 GPIO77 1 SCL 1 MMDAT 0 MD2 0 MD6 0 MD10 0 MD14 0 MD18 0 MD22 0 MD26 0 MD30 0 ACRESET# 0 SDCLK2 1 SDCS1# 0 DQM1 1 SDRAS# 0 MA0 0 MA4 0 MA8 0 MA12 0 MA16 1 MA20 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1 GPIO2 1 GPIO6 1 GPIO10 1 GPIO14 1 GPIO18 0 GPIO22 1 GPIO26 1 GPIO30 1 GPIO34 1 GPIO38 1 GPIO42 1 GPIO46 1 GPIO50 0 GPIO54 0 GPIO58 1 GPIO62 1 GPIO66 1 GPIO70 1 GPIO74 1 GPIO78 1 SDA 1 MMCMD 0 MD3 0 MD7 0 MD11 0 MD15 0 MD19 0 MD23 0 MD27 0 MD31 1 RD/WR# 0 SDCKE0 1 SDCS2# 0 DQM2 1 WE# 0 MA1 0 MA5 0 MA9 0 MA13 1 MA17 0 MA21 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1 GPIO3 1 GPIO7 0 GPIO11 1 GPIO15 1 GPIO19 1 GPIO23 1 GPIO27 1 GPIO31 1 GPIO35 1 GPIO39 1 GPIO43 1 GPIO47 1 GPIO51 1 GPIO55 0 GPIO59 1 GPIO63 1 GPIO67 1 GPIO71 1 GPIO75 1 GPIO79 0 USB_N 0 MD0 1 MD4 1 MD8 1 MD12 0 MD16 0 MD20 0 MD24 0 MD28 1 PWR_EN 0 SDCLK0 1 SDCKE1 1 SDCS3# 0 DQM3 1 OE# 0 MA2 0 MA6 0 MA10 1 MA14 1 MA18 0 MA22 JTAG_XScaleb.doc JTAG-Booster for Intel XScale | 0 MA23 | 0 TESTCLK | 0 BOOT_SEL1 | 0 MA24 | 1 VDD_FAULT# | 0 BOOT_SEL2 JTAG_XScaleb.doc | 0 MA25 | 0 TEST | 1 BATT_FAULT# | 0 BOOT_SEL0 | 0 RESET# 83 JTAG-Booster for Intel XScale 3. Implementation Information This chapter summarizes some information about the implementation of the JTAG-Booster and describes some restrictions. • The JTAG-Booster currently uses Boundary Scan to perform Flash programming. The XScale Onchip debugger is not used. • The software assumes the following scheme for connecting the FlashEPROM to the Intel XScale. Please contact us, if you have used a different method. PXA210/250, PXA255/26x signal CS0# GPIO15/CS1# GPIO78/CS2# GPIO79/CS3# GPIO80/CS4# GPIO33/CS5# OE# WE# MA0 MA1 MA2..25 MD0..7 MD0..15 MD0..31 IOP321 signal PCE0# PCE1# PCE2# PCE3# PCE4# PCE5# W/R# FWE# BE0# BE1# A2, A3, AD4..25 AD0..7 AD0..15 AD0..31 84 8 Bit Flash 16 Bit Flash 32 Bit Flash CS# CS# CS# OE# WE# A0 A1 A2..25 D0..7 - OE# WE# A1 A2..25 D0..15 - OE# WE# A2..25 D0..31 8 Bit Flash CS# 16 Bit Flash CS# 32 Bit Flash CS# OE# WE# A0 A1 A2..25 D0..7 - OE# WE# A1 A2..25 D0..15 - OE# WE# A2..25 D0..31 JTAG_XScaleb.doc JTAG-Booster for Intel XScale IXP425 signal EX_CS0#..EX_CS1# EX_CS2#..EX_CS3# EX_CS4#..EX_CS5# EX_CS6#..EX_CS7# EX_RD# EX_WR# EX_ADDR0 EX_ADDR1 EX_ADDR2..23 EX_DATA0..7 EX_DATA0..15 EX_DATA0..31 8 Bit Flash CS# 16 Bit Flash CS# 32 Bit Flash CS# OE# WE# A0 A1 A2..23 D0..7 - OE# WE# A1 A2..23 D0..15 - OE# WE# A2..23 D0..31 1.) All other signals are hold static during flash programming. The state of these signals is defined in the Initialization file. JTAG_XScaleb.doc 85 JTAG-Booster for Intel XScale 4. Converter Program HEX2BIN.EXE Since the JTAG-Booster software is not able to handle Intel-HEX or Motorola SRecord files, an separate converter tool is delivered with this product package. Five types of HEX formats can be converted to BIN file: • I • D : Digital Research • M : MOTOROLA S HEX format (BYTE oriented) • T : TEKTRONICS HEX format (BYTE oriented) • H : Intel HEX-32 : INTEL HEX format (BYTE oriented) th Maximum conversion size is 256 kBytes. A 4 parameter for starting address can be specified to skip out the leading garbage and you will maintain a small size of output binary file. If you start the HEX2BIN without any additional parameter all necessary parameters will be asked for in a prompt mode: HEX2BIN Input HEX file name: MYAPP.H86 Output BIN file name[MYAPP.BIN]: HEX file format ntel /otorola /igital Research /ektronics /[H] Intel HEX-32[I] : H Input CODE segment start address[0000000]: 10000 Input CODE segment end address[FFFFFFF]: Unused bytes will be 00 FF [1] : 2 Instead of using the prompt mode, you can directly specify all necessary parameters in the command line. This is essential for making batch files: HEX2BIN MYAPP.H86 MYAPP.BIN H 0010000 FFFFFFF 2 It is very important to fill unused bytes with 0xFF, because this are simply skipped by the JTAG-Boosters software and so it speeds up the programming performance. 86 JTAG_XScaleb.doc JTAG-Booster for Intel XScale Please Note: "CODE segment start address" is interpreted as a Intel x86 architecture segment address: You have to specify a start address of 10000 to start the conversion at 1 MByte. This converter is a relatively old DOS tool and therefor it has problems with non DOS compliant file and directory names. Avoid names with spaces, limit names to eight characters. Otherwise the converter does not convert the input file, without any error message!! JTAG_XScaleb.doc 87 JTAG-Booster for Intel XScale 5. Support for Windows NT, Windows 2000 and Windows XP A configured run time version of the "Kithara DOS Enabler, Version 6.x" is used to give support for some of our DOS based tools (like the JTAG-Booster) for Windows NT, Windows 2000 and Windows XP. After installation of the "DOS Enabler" the accesses to the LPT ports are allowed for the all programs listed in file Readme_WinNT.txt Note: Accesses to the ports are only allowed for the programs listed in file Readme_WinNT.txt. If you rename one of our tools, the DOS Enabler does not work. Important: You need administrator rights to install or de-install this program. 5.1. Installation on a clean system If you have a clean system without having installed a previous version of the "Kithara Tool Center", this tool is really simple to install. Extract the ZIP file to a new folder and start KSETUP.EXE. Everything is done within a few seconds. No additional input is needed. Now reboot your PC. 5.2. Installation with already installed version 5.x/6.x of Kithara If you have already installed an older WinNT support (Kithara Version 5.x or 6.x), st you have to de-install it 1 as described in chapter 5.4. After rebooting your PC you can install the Kithara 6.x as described above. 5.3. Installation with already installed version 4.x of Kithara Important!! If you have already installed an older WinNT support, you have to deinstall it completely!!! • Start kcenter • Select Register "Einstellungen" (=Settings) and deactivate "VDD benutzen" and "speziellen seriellen Treiber benutzen". • Stop Kernel 88 JTAG_XScaleb.doc JTAG-Booster for Intel XScale • exit the kcenter program • Now you can deinstall the Kithara Package with: Settings - Control Panel. All unused parts must be removed. • Reboot your PC • Now you can install the Kithara 6.x as described above. 5.4. De-Installation version 5.x/6.x: For deinstallation of the runtime version of the "Kithara DOS-Enabler Version 5.x/6.x": • use: Settings - Control-Panel - Add/Remove Programs and remove the “FS FORTH-SYSTEME WinNT Support” and/or “WinNT Support for JTAG-Booster and FLASH166” • Reboot your PC JTAG_XScaleb.doc 89
FS-9003 价格&库存
很抱歉,暂时无法提供与“FS-9003”相匹配的价格&库存,您可以联系我们找货
