FS-9017
FS-9017
    DIGIINTERNATIONAL
    JTAG-BOOSTER FOR PPC405XXX 3.3V
FS-9017 数据手册
JTAG-Booster for IBM PPC405xxx P.O: Box 1103 Kueferstrasse 8 Tel. +49 (7667) 908-0 sales@fsforth.de • • • • D-79200 Breisach, Germany D-79206 Breisach, Germany Fax +49 (7667) 908-200 http://www.fsforth.de JTAG-Booster for IBM PPC405 Copyright  1995..2003: FS FORTH-SYSTEME GmbH Postfach 1103, D-79200 Breisach, Germany Release of Document: Author: Filename: Program Version: September 10, 2003 Dieter Fögele JTAG_PPC405a.doc 4.xx All rights reserved. No part of this document may be copied or reproduced in any form or by any means without the prior written consent of FS FORTH-SYSTEME GmbH. 2 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 Table of Contents 1. General ..........................................................................................................4 1.1. Ordering Information ............................................................................5 1.2. System Requirements ..........................................................................5 1.3. Contents of Distribution Disk ................................................................6 1.4. Connecting your PC to the target system .............................................7 1.5. First Example with IBM PPC405EP ......................................................9 1.6. First Example with IBM PPC405GPr................................................... 11 1.7. Trouble Shooting ................................................................................ 13 1.8. Error Messages .................................................................................. 14 1.9. Initialization file JT405xxx.INI.............................................................. 19 1.10.Supported flash devices..................................................................... 29 2. JT405xxx Parameter Description.................................................................. 30 2.1. Program a Flash Device ..................................................................... 34 2.2. Read a Flash Device to file................................................................. 38 2.3. Verify a Flash Device with file ............................................................. 40 2.4. Dump target memory.......................................................................... 42 2.5. Program an I²C-Device....................................................................... 44 2.6. Read an I²C-Device to file................................................................... 46 2.7. Verify an I²C-Device with file............................................................... 48 2.8. Dump an I²C-Device ........................................................................... 50 2.9. Toggle CPU pins ................................................................................ 52 2.10.Polling CPU pins ................................................................................ 53 2.11.Polling CPU pins while the CPU is running ........................................ 54 2.12.Show status of all CPU pins while the CPU is running ....................... 55 3. Implementation Information .......................................................................... 58 4. Converter Program HEX2BIN.EXE............................................................... 59 5. Support for Windows NT, Windows 2000 and Windows XP ......................... 61 5.1. Installation on a clean system............................................................. 61 5.2. Installation with already installed version 5.x/6.x of Kithara................. 61 5.3. Installation with already installed version 4.x of Kithara ...................... 61 5.4. De-Installation version 5.x/6.x:............................................................ 62 JTAG_PPC405a.doc 3 JTAG-Booster for IBM PPC405 1. General The programs JT405EP.EXE and JT405GPr.EXE use the JTAG port of the IBM PPC405xxx mircocontrollers in conjunction with the small JTAG-Booster: • • • • • to program data into flash memory to verify and read the contents of a flash memory to make a memory dump to access an I²C Device to test CPU signals All functions are done without any piece of software running in the target. No firmware or BIOS must be written. Bootstrap software may be downloaded to initially unprogrammed memories. The JTAG-BOOSTER' s software is highly optimized to the JTAG chain of a specific target CPU. To give support for all processors of the IBM PPC405xxx family, there are two different programs on the distribution disk: • JT405EP.EXE : Tool for IBM PPC405EP • JT405GPr.EXE : Tool for IBM PPC405GPr Please contact us, if you need support for other members of the IBM PPC405xxx family. For latest documentation please refer to the file README.TXT on the distribution disk. 4 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 1.1. Ordering Information The following related products are available • 9017 JTAG-Booster IBM PPC405xxx, 3.3V, PPC405EP and PPC405GPr DOS/Win9x/WinNT/Win2000/WinXP, delivered with adapter type 285 1.2. System Requirements To successfully run this tool the following requirements must be met: • MSDOS, WIN3.x, WIN9x, WinNT, Win2000 or WindowsXP (WinNT/Win2000/WindowsXP is supported with an additional tool, see chapter 5 “Support for Windows NT, Windows 2000 and Windows XP”) • Intel 80386 or higher • 205 kByte of free DOS memory • Parallel Port JTAG_PPC405a.doc 5 JTAG-Booster for IBM PPC405 1.3. Contents of Distribution Disk • JT405EP.EXE JT405EP.OVL Tool for IBM PPC405EP • JT405EP.INI Template configuration file for IBM PPC405EP. See chapter 1.9 "Initialization file JT405xxx.INI" • JT405GPr.EXE JT405GPr.OVL Tool for IBM PPC405GPr • JT405GPr.INI Template configuration file for IBM PPC405GPr. See chapter 1.9 "Initialization file JT405xxx.INI" • WinNT.zip Support for Windows NT, Windows 2000 and Windows XP. See chapter 5 "Support for Windows NT, Windows 2000 and Windows XP" • JTAG_V4xx_FLAS HES.pdf List of all supported Flash devices • README.txt Release notes, new features, known problems 6 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 1.4. Connecting your PC to the target system The JTAG-Booster can be plugged into standard parallel ports (LPT1-3) with a DB25-Connector. 1 LPT1-3 1 Élan SC400 Module Élan486 The target end of the cable has the following reference: 1 TCK 2* GND 3 TMS 4 TRST# 5 NC 6 TDI 7 TDO 8 +3.3V *PIN 2 can be detected by the thick cable. To connect your design to the JTAG-BOOSTER you need a single row berg connector with a spacing of 2.54mm on your PCB. The names refer to the target: Pin 7 is the target’s TDO pin and is connected to the JTAG-Booster’s TDI pin. The 3.3V version of the JTAG-Booster (FS part number 285) is delivered together with this package. Don’t use the 5V version of the JTAG-Booster (FS part number 227) with a 3.3V target. Don’t apply 5V to the 3.3V version of the JTAG-Booster! Your target must be able to power the JTAG-Booster, it draws about 100mA. Before you start the program, the JTAG-BOOSTER must be plugged to a parallel interface of your PC and to the 8 pin JTAG connector on the target. JTAG_PPC405a.doc 7 JTAG-Booster for IBM PPC405 The utility is started with the general command line format: JTAGxxx JT405xxx /function [filename] [/option_1] ... [/option_n]. Note that the function must be the first argument followed (if needed) by the filename. If you want to cancel execution of JT405xxx, press CTRL-Break-Key. On any error the program aborts with an MSDOS error level of one. 8 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 1.5. First Example with IBM PPC405EP In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JT405EP /P MYAPP.BIN at the DOS prompt results in the following output: JT405EP --- JTAG utility for IBM PPC405EP Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JT405EP.INI Target: Generic Target Using LPT at I/O-address 0378h JTAG Adapter detected (5) 1 Device detected in JTAG chain Device 0: IDCODE=00267049 IBM PPC405EP, Revision 0 Sum of instruction register bits : 7 CPU position :0 Instruction register offset :0 Length of boundary scan reg : 300 (6) (7) (8) (9) (10) (11) (12) Looking for a known flash device. Please wait.. STM 29W320B, 3,3V, Boot Block Bottom detected Bus size is 16 Bit Erasing Flash-EPROM Block #:0 1 2 3 Programming File MYAPP.BIN 65536 Bytes programmed successfully Erase Time Programming Time JTAG_PPC405a.doc : : 0.8 sec 33.8 sec 9 JTAG-Booster for IBM PPC405 (1) The initialization file JT405EP.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. With WinNT/Win2000/WinXP you must specify the option /LPT2 to access to the standard address 378h. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the IBM PPC405EP are switched to bypass mode. (6) The length of all instruction registers in the JTAG chain are added. (7) The position of the IBM PPC405EP in the JTAG chain is assumed to be zero, if not specified in the command line (see option /CPUPOS=). (8) The position of the JTAG instruction register of the IBM PPC405EP is assumed to be zero, if not specified in the command line (see option /IROFFS=). (9) The real length of the boundary scan register is displayed here and compared with the boundary scan register length of a IBM PPC405EP. (10) A Flash STM 29W320B selected with PER_CS0# was found. (11) The resulting data bus size is printed here. (12) In this example 4 blocks must be erased. 10 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 1.6. First Example with IBM PPC405GPr In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JT405GPr /P MYAPP.BIN at the DOS prompt results in the following output: JT405GPr --- JTAG utility for IBM PPC405GPr Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JT405GPr.INI Target: Generic Target Using LPT at I/O-address 0378h JTAG Adapter detected (5) 1 Device detected in JTAG chain Device 0: IDCODE=04088049 IBM PPC405GPr, Revision 0 Sum of instruction register bits : 7 CPU position :0 Instruction register offset :0 Length of boundary scan reg : 360 (6) (7) (8) (9) (10) (11) (12) Looking for a known flash device. Please wait.. STM 29W320B, 3.3V, Boot Block Bottom detected Bus size is 16 Bit Erasing Flash-EPROM Block #:0 1 2 3 Programming File MYAPP.BIN 65536 Bytes programmed successfully Erase Time Programming Time JTAG_PPC405a.doc : : 0.8 sec xx.0 sec 11 JTAG-Booster for IBM PPC405 (1) The initialization file JT405GPr.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the IBM PPC405GPr are switched to bypass mode. (6) The length of all instruction registers in the JTAG chain are added. (7) The position of the IBM PPC405GPrin the JTAG chain is assumed to be zero, if not specified in the command line (see option /CPUPOS=). (8) The position of the JTAG instruction register of the IBM PPC405GPris assumed to be zero, if not specified in the command line (see option /IROFFS=). (9) The real length of the boundary scan register is displayed here and compared with the boundary scan register length of a IBM PPC405GPr. (10) A Flash STM 29W320B selected with EX_CS0# was found. (11) The resulting data bus size is printed here. (12) In this example four blocks must be erased. 12 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 1.7. Trouble Shooting Avoid long distances between your Host-PC and the target. If you are using standard parallel extension cable, the JTAG-BOOSTER may not work. Don't use Dongles between the parallel port and the JTAG-BOOSTER. Switch off all special modes of your printer port (EPP, ECP, ...) in the BIOS setup. Only standard parallel port (SPP) mode is allowed. If there are problems with autodetection of the flash devices use the /DEVICE= option. To speed up autodetection specify one of the options /8BIT /16BIT or /32BIT. Don't use hardware protected flash memories. The used chip selects must be defined as output and inactive in the initialization file (see chapter 1.9 “Initialization file JT405xxx.INI”). Also the address bits must be defined as output. Use the option /NOWRSETUP to speed up flash programming. JTAG_PPC405a.doc 13 JTAG-Booster for IBM PPC405 1.8. Error Messages • 80386 or greater required The JTAG-BOOSTER does not work on a 8088/8086 or a 80286 platform. • Cable not connected or target power fail The JTAG-Booster (or one of the simple Parallel Port JTAG adapters selected with the options /LATTICE /WIGGLER /PLS) wasn't found. Please check connection to parallel port and connection to target. Check target power. Check the command line options. Check your BIOS-Setup. If you are using this program with WinNT, Win2000 or WinXP you must specify /LPT2 or /LPT-BASE=378 to get access to the standard printer port. • Can't open x:\yyy\zzz\JT405xxx.OVL The overlay file JT405xxx.OVL must be in the same directory as JT405xxx.EXE. • Configuration file XYZ not found. The file specified with the option /INI= wasn't found. • Device offset out of range The value specified with the option /OFFSET= is greater than the size of the detected flash device. • Disk full Writing a output file was aborted as a result of missing disk space. • Do not specify option /NOCS with any other chip select There is a conflict in the command line. • Do not specify option /BYTE-MODE. Flash device does not have a byte mode pin. The flash device specified with the option /DEVICE= does not support switching between 16 (or 32) bit mode and 8 bit mode. In practice it does not have a pin with the name BYTE# • Error creating file: The output file could not be opened. Please check free disk space or write protection. 14 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 • Error: Pin-Name is an output only pin The specified pin cannot be sampled. Check the command line. Check the initialization file. • Error: Pin-Name is an input only pin The specified pin cannot be activated. Check the command line. Check the initialization file. • Error: Pin-Name may not be read back The specified pin can be switched to tristate, but cannot be read back. Check the command line. • illegal function: The first parameter of the command line must be a valid function. See chapter 2 “JT405xxx Parameter Description” for a list of supported functions. • illegal number: The specified number couldn’t be interpret as a valid number. Check the relevant number base. • illegal option: See chapter 2 “JT405xxx Parameter Description” for a list of supported options. • illegal Pin Type: The name specified with the option /PIN= must be one of the list of chapter 1.9 ”Initialization file JT405xxx.INI” • illegal Flash Type: The name specified with the option /DEVICE= must be one of the list of chapter 1.10 ”Supported flash devices”. • Input file not found: The specified file cannot be found • Input file is empty: Files with zero length are not accepted JTAG_PPC405a.doc 15 JTAG-Booster for IBM PPC405 • " " is undefined Please check the syntax in your configuration file. (See chapter 1.9 “Initialization file JT405xxx.INI”). • LPTx not installed The LPT port specified with /LPTx cannot be found. Please check the LPT port or specify a installed LPT port. Check your BIOS setup. If you are using this program with WinNT, Win2000 or WinXP you 1st must install the WinNT support package as described in chapter 5 "Support for Windows NT, Windows 2000 and Windows XP" • missing filename Most functions need a filename as second parameter. • missing option /I2CCLK= Some functions need the option /I2CCLK= to be defined. • missing option /I2CDAT= Some functions need the option /I2CDAT= or the options /I2CDATO= and /I2CDATI= to be defined. • missing option /LENGTH= Some functions need the option /LENGTH= to be defined. • missing option /PIN= Some functions need the option /PIN= to be defined. • More than 9 devices in the JTAG chain or TDO pin stuck at low level The JTAG chain is limited to 9 parts. Check target power. Check the target’s TDO pin. • No devices found in JTAG chain or TDO pin stuck at high level A stream of 32 high bits was detected on the pin TDO. TDO may stuck at high level. Check the connection to your target. Check the target power. Check the target’s TDO pin. • Option /CPUPOS= out of range The number specified with the option /CPUPOS= must be less or equal to the number of parts minus 1. 16 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 • Option /IROFFS= out of range Please specify a smaller value • Part at specified position is not a IBM PPC405xxx The option /CPUPOS= points to a part not a IBM PPC405xxx • Pins specified with /I2CCLK= and /I2CDAT= must have different control cells The pin specified with the option /I2CDAT= must be able to be switched to high impedance while the pin specified with option /I2CCLK= is an active output. See chapter 1.9 “Initialization file JT405xxx.INI”. • Pins specified with /I2CCLK= and /I2CDATI= must have different control cells The pin specified with the option /I2CDATI= must be able to be switched to high impedance while the pin specified with option /I2CCLK= is an active output. See chapter 1.9 “Initialization file JT405xxx.INI”. • Pins specified with /I2CDATO= and /I2CDATI= must have different control cells The pin specified with the option /I2CDATI= must be able to be switched to high impedance while the pin specified with option /I2CDATO= is an active output. See chapter 1.9 “Initialization file JT405xxx.INI”. • Specify only one of these options: Some options are exclusive (i.e. /8BIT and /16BIT). Don't mix them. • Sum of instruction register bits to low. Should be at least 7 bits for a IBM PPC405xxx The sum of all instruction register bits in the JTAG chain does not fit to the IBM PPC405xxx. Check the target connection. Check the target CPU type. Check the settings for /IROFFS= and /CPUPOS= , if there are several parts in the JTAG chain. • Target no longer connected There is a cyclic check of the JTAG chain. Check target power. Check target connection. JTAG_PPC405a.doc 17 JTAG-Booster for IBM PPC405 • There are unknown parts in the JTAG chain. Please use the option /IROFFS= to specify the instr. reg. offset of the CPU. If there are unknown parts in the JTAG chain, the program isn’t able to determine the logical position of the CPU’s instruction register. • There is no IBM PPC405xxx in the JTAG chain No IBM PPC405xxx was found in the JTAG chain. Check the target power. Try with option /DRIVER=4 again. • Value of option /FILE-OFFSET out of range The value of the option /FILE-OFFSET= points behind end of file. • wrong driver # The value specified with the option /DRIVER= is out of range. • Wrong Flash Identifier (xxxx) No valid identifier found. Check the specified chip select signal and the bus width. Try with the option /DEVICE= . Use the option /8BIT or /16BIT or /32BIT to specify the correct data bus size. • Wrong length of boundary scan register. Should be 300 for a IBM PPC405EP. (Should be 360 for a IBM PPC405GPr.) The length of the boundary scan register of the selected part (if there are more than one in the chain) does not fit to the IBM PPC405xxx. Check the target connection. Check the target CPU type. Check the settings for /IROFFS= and /CPUPOS= , if there are several parts in the JTAG chain. 18 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 1.9. Initialization file JT405xxx.INI This file is used to define the default direction and level of all CPU signals. This file must be carefully adapted to your design with the IBM PPC405xxx. The Target-Entry is used to identify your design which is displayed with most commands. When the program JT405xxx.EXE is started it scans the current directory for an existing initialization file named JT405xxx.INI. If no entry is found the default values are used. You may also specify the initialization file with the option /INI= . If the specified file isn't found, the program aborts with an error message. The CPU pins can also be used with the functions /BLINK (chapter 2.9), /PIN? (chapter 2.10) and /SAMPLE (chapter 2.11) to test the signals on your design. The sample file below represents the values which are used for default initialization when no initialization file could be found in the current directory and no initialization file is specified with the option /INI=. Changes to the structure of the file could result in errors. Remarks can be added by using //. JTAG_PPC405a.doc 19 JTAG-Booster for IBM PPC405 Sample File JT405EP.INI: // Description file for IBM PPC405EP Target: Generic Target, 2003/08/26 // Adapt this file carefully to your design!! // All chip select signals are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults. // Pin names are defined in upper case. // Low active signals are signed with a trailing #. // Group 25: // // // // // PER_DATA0 PER_DATA1 PER_DATA2 PER_DATA3 PER_DATA4 PER_DATA5 PER_DATA6 PER_DATA7 All pins in this group must be set to the same direction These pins are bidirectional During flash programming these pins are switched between input/inactive and output/active. For Flash programming and other memory accesses these pins should be set to Input Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // // Group 43: All pins in this group must be set to the same direction // These pins are bidirectional // During flash programming these pins are switched between // input/inactive and output/active. // For Flash programming and other memory accesses // these pins should be set to Input PER_DATA8 Inp // PER_DATA9 Inp // PER_DATA10 Inp // PER_DATA11 Inp // PER_DATA12 Inp // PER_DATA13 Inp // PER_DATA14 Inp // PER_DATA15 Inp // 20 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 // The following pins are output only pins. // Setting to input (tristate) one of these pins results in an error. // These are used for Flash programming PER_ADDR6 Out,Lo // PER_ADDR7 Out,Lo // PER_ADDR8 Out,Lo // PER_ADDR9 Out,Lo // PER_ADDR10 Out,Lo // PER_ADDR11 Out,Lo // PER_ADDR12 Out,Lo // PER_ADDR13 Out,Lo // PER_ADDR14 Out,Lo // PER_ADDR15 Out,Lo // PER_ADDR16 Out,Lo // PER_ADDR17 Out,Lo // PER_ADDR18 Out,Lo // PER_ADDR19 Out,Lo // PER_ADDR20 Out,Lo // PER_ADDR21 Out,Lo // PER_ADDR22 Out,Lo // PER_ADDR23 Out,Lo // PER_ADDR24 Out,Lo // PER_ADDR25 Out,Lo // PER_ADDR26 Out,Lo // PER_ADDR27 Out,Lo // PER_ADDR28 Out,Lo // PER_ADDR29 Out,Lo // PER_ADDR30 Out,Lo // PER_ADDR31 Out,Lo // // Group 264: All pins in this group must be set to the same direction // These pins are bidirectional MEM_DATA0 Inp // MEM_DATA1 Inp // MEM_DATA2 Inp // MEM_DATA3 Inp // MEM_DATA4 Inp // MEM_DATA5 Inp // MEM_DATA6 Inp // MEM_DATA7 Inp // JTAG_PPC405a.doc 21 JTAG-Booster for IBM PPC405 // Group 278: All pins in this group must be set to the same direction // These pins are bidirectional MEM_DATA8 Inp // MEM_DATA9 Inp // MEM_DATA10 Inp // MEM_DATA11 Inp // MEM_DATA12 Inp // MEM_DATA12 Inp // MEM_DATA14 Inp // MEM_DATA15 Inp // // Group 290: All pins in this group must be set to the same direction // These pins are bidirectional MEM_DATA16 Inp // MEM_DATA17 Inp // MEM_DATA18 Inp // MEM_DATA19 Inp // MEM_DATA20 Inp // MEM_DATA21 Inp // MEM_DATA22 Inp // MEM_DATA23 Inp // // Group 7: All pins in this group must be set to the same direction // These pins are bidirectional MEM_DATA24 Inp // MEM_DATA25 Inp // MEM_DATA26 Inp // MEM_DATA27 Inp // MEM_DATA28 Inp // MEM_DATA29 Inp // MEM_DATA30 Inp // MEM_DATA31 Inp // // Group 229: All pins in this group must be set to the same direction // These pins are bidirectional UART0_TX Inp // UART0_RTS# Inp // SYS_ERR Inp // 22 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 // Group 125: All pins in this group must be set to the same direction // These pins are bidirectional PCI_AD0 Inp // PCI_AD1 Inp // PCI_AD2 Inp // PCI_AD3 Inp // // Group 132: All pins in this group must be set to the same direction // These pins are bidirectional PCI_AD4 Inp // PCI_AD5 Inp // PCI_AD6 Inp // PCI_AD7 Inp // // Group 137: All pins in this group must be set to the same direction // These pins are bidirectional PCI_AD8 Inp // PCI_AD9 Inp // PCI_AD10 Inp // PCI_AD11 Inp // // Group 142: All pins in this group must be set to the same direction // These pins are bidirectional PCI_AD12 Inp // PCI_AD13 Inp // PCI_AD14 Inp // PCI_AD15 Inp // // Group 173: All pins in this group must be set to the same direction // These pins are bidirectional PCI_AD16 Inp // PCI_AD17 Inp // PCI_AD18 Inp // PCI_AD19 Inp // // Group 179: All pins in this group must be set to the same direction // These pins are bidirectional PCI_AD20 Inp // PCI_AD21 Inp // PCI_AD22 Inp // PCI_AD23 Inp // JTAG_PPC405a.doc 23 JTAG-Booster for IBM PPC405 // Group 184: All pins in this group must be set to the same direction // These pins are bidirectional PCI_AD24 Inp // PCI_AD25 Inp // PCI_AD26 Inp // PCI_AD27 Inp // // Group 190: All pins in this group must be set to the same direction // These pins are bidirectional PCI_AD28 Inp // PCI_AD29 Inp // PCI_AD30 Inp // PCI_AD31 Inp // // Group 130: All pins in this group must be set to the same direction // These pins are bidirectional PCI_C/BE0# Inp // PCI_C/BE1# Inp // PCI_C/BE2# Inp // PCI_C/BE3# Inp // // Group 163: All pins in this group must be set to the same direction // These pins are bidirectional PCI_TRDY# Inp // PCI_STOP# Inp // PCI_DEVSEL# Inp // // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. // For Flash programming PER_ADDR3 Out,Lo // GPIO14 PER_ADDR4 Out,Lo // GPIO15 PER_ADDR5 Out,Lo // GPIO16 // Group 152: All pins in this group must be set to the same direction // These pins are tristateable, but can not be read back PCI_GNT0# Out,Lo // REQ# PCI_GNT1# Out,Lo // PCI_GNT2# Out,Lo // 24 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. IIC_SDA Inp // IIC_SCL Inp // UART0_DCD# Inp // GPIO24 UART0_DSR# Inp // GPIO25 UART0_RI# Inp // GPIO26 UART0_DTR# Inp // GPIO27 UART1_RX Inp // GPIO28 UART1_TX Inp // GPIO29 PER_CS1# Out,Lo // GPIO10 PER_CS2# Out,Lo // GPIO11 PER_CS3# Out,Lo // GPIO12 PER_CS4# Out,Lo // GPIO13 PER_BLAST# Inp // GPIO0 PCI_INT# Inp // PER_WE# PCI_FRAME# Inp // PCI_IRDY# Inp // PCI_TRDY# Inp // PCI_SERR# Inp // PCI_PERR# Inp // PCI_PARITY Inp // IRQ6 Inp // GPIO23 IRQ5 Inp // GPIO22 IRQ4 Inp // GPIO21 IRQ3 Inp // GPIO20 IRQ2 Inp // GPIO19 IRQ1 Inp // GPIO18 IRQ0 Inp // GPIO17 GPIO9 Inp // TRC_CLK GPIO8 Inp // TS6 GPIO7 Inp // TS5 GPIO6 Inp // TS4 GPIO5 Inp // TS3 GPIO4 Inp // TS2O GPIO3 Inp // TS1O GPIO2 Inp // TS2E GPIO1 Inp // TS1E REJECT_PKT1 Inp // GPIO31 REJECT_PKT0 Inp // GPIO30 SYS_RESET# Inp // EMC0_MDIO Inp // JTAG_PPC405a.doc 25 JTAG-Booster for IBM PPC405 // The following pins are output only pins. // Setting to input (tristate) one of these pins results in an error. DQM0 Out,Lo // DQM1 Out,Lo // DQM2 Out,Lo // DQM3 Out,Lo // EMC0_TX0EN Out,Lo // EMC0_TX0ERR Out,Lo // EMC0_TX0D0 Out,Lo // EMC0_TX0D1 Out,Lo // EMC0_TX0D2 Out,Lo // EMC0_TX0D3 Out,Lo // EMC0_TX1EN Out,Lo // EMC0_TX1ERR Out,Lo // EMC0_TX1D0 Out,Lo // EMC0_TX1D1 Out,Lo // EMC0_TX1D2 Out,Lo // EMC0_TX1D3 Out,Lo // EMC0_MDCLK Out,Lo // PER_WBE0# Out,Lo // PER_WBE1# Out,Lo // PER_OE# Out,Lo // PER_R/W# Out,Lo // PER_CS0# Out,Lo // PER_CLK Out,Lo // EXT_RESET# Out,Lo // PCI_RESET# Out,Lo // MEM_ADDR12 Out,Lo // MEM_ADDR11 Out,Lo // MEM_ADDR10 Out,Lo // MEM_ADDR9 Out,Lo // MEM_ADDR8 Out,Lo // MEM_ADDR7 Out,Lo // MEM_ADDR6 Out,Lo // MEM_ADDR5 Out,Lo // MEM_ADDR4 Out,Lo // MEM_ADDR3 Out,Lo // MEM_ADDR2 Out,Lo // MEM_ADDR1 Out,Lo // MEM_ADDR0 Out,Lo // MEM_BA0 Out,Lo // MEM_BA1 Out,Lo // 26 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 MEM_RAS# MEM_CAS# MEM_WE# MEM_CLKOUT0 MEM_CLKOUT1 MEM_CLKEN0 MEM_CLKEN1 BANKSEL0# BANKSEL1# Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo // // // // // // // // // // The following pins are input only. // Setting to output of one of these pins results in an error. // Declaration of the direction of these pins is optional. UART0_CTS# Inp // UART0_RX Inp // PHY0_RX1D0 Inp // PHY0_RX1D1 Inp // PHY0_RX1D2 Inp // PHY0_RX1D3 Inp // PHY0_RX1CLK Inp // PHY0_RX1ERR Inp // PHY0_RX1DV Inp // PHY0_TX1CLK Inp // PHY0_COL1 Inp // PHY0_CRS1 Inp // PHY0_RX0D0 Inp // PHY0_RX0D1 Inp // PHY0_RX0D2 Inp // PHY0_RX0D3 Inp // PHY0_RX0CLK Inp // PHY0_RX0ERR Inp // PHY0_RX0DV Inp // PHY0_TX0CLK Inp // PHY0_COL0 Inp // PHY0_CRS0 Inp // PER_READY Inp // PCI_CLK Inp // PCI_IDSEL Inp // HALT# Inp // PCI_REQ0# Inp // GNT# PCI_REQ1# Inp // PCI_REQ2# Inp // SYS_CLK Inp // JTAG_PPC405a.doc 27 JTAG-Booster for IBM PPC405 Sample File JT405GPr.INI: In preparation 28 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 1.10. Supported flash devices Type JT405xxx /LIST [optionlist] to get a online list of all flash types which could be used with the /DEVICE= option. See separate file JTAG_V4xx_FLASHES.pdf to get a complete list of supported flash types. JTAG_PPC405a.doc 29 JTAG-Booster for IBM PPC405 2. JT405xxx Parameter Description When you start JT405xxx.EXE without any parameters the following help screen with all possible functions and options is displayed: JT405xxx --- JTAG utility for IBM PPC405xxx Copyright © FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy Programming of Flash-EPROMs and hardware tests on targets with the IBM PPC405xxx. The JTAG-Booster is needed to connect the parallel port of the PC to the JTAG port of the IBM PPC405xxx. Usage: JT405xxx /function [filename] [/option_1] ... [/option_n] Supported functions: /P : Program a Flash Device /R : Read a Flash Device to file /V : Verify a Flash Device with file /DUMP : Make a target dump /PI2C : Program an I2C Device with file /RI2C : Read an I2C Device to file /VI2C : Verify an I2C Device with file /DUMPI2C : Make a dump of an I2C Device /BLINK : Toggle a CPU pin /PIN? : Test a CPU pin /SAMPLE : Test a CPU pin while the CPU is running /SNAP : Test all CPU pins while CPU is running /LIST : Print a list of supported Flash devices 30 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 Supported Options: /CS0 /CS1 /BIG /NOCS /BM /PAUSE /ERASEALL /LATTICE /LPT-BASE= /16BIT L= /FILE-OFFSET= /DELAY= /DEVICE-BASE= /CPUPOS= /DEVICE= /I2CDATI= /I2CDATO= /INI= /REP /CS2 /NOWRSETUP /P /LPT1 /8BIT /FO= /DB= /PIN= I2CBIG /CS3 /TOP /NODUMP /LPT2 /NOMAN /OFFSET= /DRIVER= /I2CCLK= /WATCH= /CS4 /BYTE-MODE /NOERASE /LPT3 /LENGTH= /O= /IROFFS= /I2CDAT= /OUT= The following options are valid for most functions: /BIG This option switches the byte ordering to big endian mode. This option must fit to the target's endianess. Normally the target is configured to the right endianess after reset. In some cases, the endianess can be changed within the configuration file. Default: Little Endian /DRIVER=x with x = 1,2,3,4 A driver for the interface to the JTAG-BOOSTER on the parallel port may be specified. /DRIVER=1 selects the fastest available driver, /DRIVER=4 selects the slowest one. Use a slower driver if there are problems with JTAGBOOSTER. Default: /DRIVER=3 /INI=file An initialization file may be specified. By default the current directory is searched for the file JT405xxx.INI. If this file is not found and no initialization file is specified in the command line, default initialization values are used (see also chapter 1.9 “Initialization file JT405xxx.INI”). Note: The initialization file is not loaded for the functions /SAMPLE (chapter 2.11) and /SNAP (chapter 2.12). Default: /INI=JT405xxx.INI JTAG_PPC405a.doc 31 JTAG-Booster for IBM PPC405 /LATTICE Besides the standard JTAG-Booster interface there may be several simple "Parallel-Port-JTAG" interfaces supported. With this interfaces the programming performance, of course, is reduced. /LPT1 /LPT2 /LPT3 A printer port may be specified where the JTAG-Booster resides. If you are using this program with WinNT, Win2000 or WinXP you must specify /LPT2 or /LPT-BASE=378 to get access to the standard printer port. Default: /LPT1 /LPT-BASE The physical I/O-Address of printer port may be specified instead of the logical printer name. Useful option, if you work with WinNT or Win2000, because the standard printer port is mapped as LPT2 here. Use the option /LPT-BASE=378 to get a command line which works independent of the operation system. /OUT=file_or_device All screen outputs are redirected to the specified file or device. Note that you can't redirect to the same parallel port where the JTAG-Booster resides. Default: /OUT=CON /PAUSE With the option /PAUSE you can force the program to stop after each screen. Please do not use this option if you redirect the output to a file. Abbreviation: /P /WATCH= With the option /WATCH= a pin can be specified, which is toggled twice per second, while the program is active. This pin may be the trigger of a watchdog. This pin must be specified as output in the initialization file. /IROFFS= Specifies the position of the IBM PPC405xxx instruction register within the JTAG chain. In most cases this option is not needed. Default: /IROFFS=0 32 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 /CPUPOS= Specifies the position of the IBM PPC405xxx within the JTAG chain. Default: /CPUPOS=0 JTAG_PPC405a.doc 33 JTAG-Booster for IBM PPC405 2.1. Program a Flash Device Usage: JT405xxx /P filename [optionlist] The specified file is programmed into the flash memory. The flash status is polled after programming of each cell (cell=8, 16 or 32 bit, depending on current data bus width). In case of a programming error, the contents of the flash memory is written to a file with the extension DMP. If you want a complete verify after programming, please use an additional command line with the verify function. See chapter 2.3 “Verify a Flash Device with file”. In most cases this additional verify step is not needed. The type of the flash device is normally detected by the software. When autodetection fails you should use the /DEVICE= option together with /8BIT or /16BIT or /32BIT to set the right flash device and configuration. The known flash devices are shown in chapter 1.10 “Supported flash devices”. Options: /DEVICE=devicename The flash device is detected automatically by switching to autoselect mode. In case of trouble you should select the flash device by using this parameter to avoid autodetection. Combine this option with one of the following options which specify the data bus width and the option /BYTE-MODE if applicable. /8BIT /16BIT /32BIT Specifies the data bus width to the target flash device. You can speed up autodetection, if you specify the correct data bus size. You need this option together with the option /DEVICE= to explicit specify a specific flash configuration. /BYTE-MODE If there is a flash device connected to the CPU which does have a byte mode pin (8 bit and 16/32 bit bus mode), you can force it to be used as 8 bit mode with the option /BYTE-MODE. In most cases this option will not be needed. 34 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 /NOMAN If you use a flash device which is identical to one of the supported parts, but is from a different manufacturer, with this option you can suppress the comparison of the manufacturer identification code. We recommend to use this option together with the /DEVICE= option to avoid failures in autodetection. /DEVICE-BASE=hhhhhh1 Here you can specify a flash device starting address. In most cases, where the flash device is selected with one of the CPUs chip select pins, this parameter is not needed. But if there is any decoding logic in your hardware, this option will be needed. Especially, if there are several flash banks connected to one chip select and a sub decoding logic generates chip selects for these flash banks, this option can be used to select a specific flash bank. Default: /DEVICE-BASE=0 Abbreviation: /DB= /OFFSET=hhhhhh The programming starts at an offset of hhhhhh relative to the start address of the flash device. If the offset is negative, the offset specifies an address relative to the end of the flash device. See also option /TOP Default: /OFFSET=0 Abbreviation: /O= /TOP If the option /TOP is used the option /OFFSET= specifies the address where the programming ends (plus one) instead of the starting address. This option is very important for Intel CPU architectures, because target execution always starts at the top of the address space. /FILE-OFFSET=hhhhhh If FILE-OFFSET is specified, the first hhhhhh bytes of the file are skipped and not programmed to target. Default: /FILE-OFFSET=0 Abbreviation: /FO= 1 hhhhhh=number base is hex JTAG_PPC405a.doc 35 JTAG-Booster for IBM PPC405 /LENGTH=hhhhhh The number of programmed bytes may be limited to LENGTH. If no LENGTH is specified the whole file is programmed. Default: /LENGTH=4000000 (64 MByte) Abbreviation: /L= /NODUMP In case of a verify error the contents of the flash memory is written to a file with the extension .DMP. With /NODUMP you can suppress this feature. /ERASEALL Erase the whole flash device. If this option isn't set, only those blocks are erased where new data should be written to. /NOERASE This option prevents the flash device from being erased. /CS0 /CS1 /CS2 /CS3 /CS4 This options may be used to specify one or more chip select signals to the flash memory. The used chip selects must be defined as output and inactive in the initialization file. (See chapter 1.9 “Initialization file JT405xxx.INI”.) Default: /CS0 /NOCS Use this option to switch off all chip select signals. This may be necessary if the device's chip select is generated via a normal decoder instead of using the IBM PPC405xxx chip select unit. /NOWRSETUP By default write cycles to the Flash EPROM are realized with three steps: 1. set address/data 2. write strobe active 3. write strobe inactive. In most cases it is possible to set the write strobe coincident with setting of address and data by specifying the option /NOWRSETUP. This increases the programming speed by 50%. 36 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 Examples: JT405xxx /P ROMDOS.ROM /L=20000 /TOP This example programs up to 128 Kbytes of the file ROMDOS.ROM (with i.e. 512 Kbytes) to the top of the boot flash memory. JT405xxx /P CE.ROM /32BIT /CS1 This example programs the file CE.ROM to the 32 Bit Flash-EPROM connected to CS1#. JTAG_PPC405a.doc 37 JTAG-Booster for IBM PPC405 2.2. Read a Flash Device to file Usage: JT405xxx /R filename [optionlist] The contents of a flash device is read and written to a file. The type of the flash device is normally detected by the software. When autodetection fails you should use the /DEVICE= option together with /8BIT or /16BIT or /32BIT to set the right flash device and configuration. The known devices are shown in chapter 1.10 “Supported flash devices”. Options: /DEVICE=devicename See function /P (Chapter 2.1) /8BIT /16BIT /32BIT See function /P (Chapter 2.1) /BYTE-MODE See function /P (Chapter 2.1) /NOMAN See function /P (Chapter 2.1) /DEVICE-BASE=hhhhhh2 See function /P (Chapter 2.1) /OFFSET=hhhhhh Reading of the flash memory starts at an offset of hhhhhh relative to the start address of the flash device. If the offset is negative, the offset specifies a address relative to the end of the flash device. See also option /TOP. Default: /OFFSET=0 Abbreviation: /O= 2 hhhhhh=number base is hex 38 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 /TOP If the option /TOP is used the option /OFFSET= specifies the address where reading ends (plus one) instead of the starting address. /LENGTH=hhhhhh The number of read bytes may be limited to LENGTH. If no LENGTH is specified the whole flash device is read (if no offset is specified). /CS0 /CS1 /CS2 /CS3 /CS4 See function /P (Chapter 2.1) /NOWRSETUP See function /P (Chapter 2.1) Please note: In the function /R write cycles are needed to detect the type of the flash memory. Example: JT405xxx /R BIOS.ABS /L=10000 /TOP This example may be used to read the upper most 64 Kbyte of the flash memory to the file BIOS.ABS. JTAG_PPC405a.doc 39 JTAG-Booster for IBM PPC405 2.3. Verify a Flash Device with file Usage: JT405xxx /V filename [optionlist] The contents of a flash device is compared with the specified file. If there are differences the memory is dumped to a file with the extension DMP. The type of flash device is normally detected by the software. When autodetect fails you should use the /DEVICE= option together with /8BIT or /16BIT or /32BIT to set the right flash device and configuration. The known devices are shown in chapter 1.10 “Supported flash devices”. Options: /DEVICE=devicename See function /P (Chapter 2.1) /8BIT /16BIT /32BIT See function /P (Chapter 2.1) /BYTE-MODE See function /P (Chapter 2.1) /NOMAN See function /P (Chapter 2.1) /DEVICE-BASE=hhhhhh See function /P (Chapter 2.1) /OFFSET=hhhhhh See function /P (Chapter 2.1) /TOP See function /P (Chapter 2.1) /FILE-OFFSET=hhhhhh See function /P (Chapter 2.1) 40 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 /LENGTH=hhhhhh See function /P (Chapter 2.1) /NODUMP See function /P (Chapter 2.1) /CS0 /CS1 /CS2 /CS3 /CS4 See function /P (Chapter 2.1) /NOWRSETUP See function /P (Chapter 2.1) Please note: In the function /V write cycles are needed to detect the type of the flash memory. Example: JT405xxx /V ROMDOS.ROM /L=20000 /TOP This example may be used to verify the upper most 128 Kbytes of the flash memory with the file ROMDOS.ROM (with i.e. 512 Kbytes). JTAG_PPC405a.doc 41 JTAG-Booster for IBM PPC405 2.4. Dump target memory Usage: JT405xxx /DUMP [optionlist] A Hex-Dump of the target memory is printed on the screen, if not redirected to file or device. Options: /8BIT /16BIT /32BIT Default: /32BIT /OFFSET=hhhhhh The memory dump starts at an offset of hhhhhh plus the device start address (see option /DEVICE-BASE=). Default: /OFFSET=0 Abbreviation: /O= /DEVICE-BASE=hhhhhh3 The device start address is used as an additional offset. This gives the function /DUMP the same behavior as function /P /V and /R. Default: /DEVICE-BASE=0 Abbreviation: /DB= /TOP If the option /TOP is used the option /OFFSET= specifies the address where the dump ends (plus one) instead of the starting address /LENGTH=hhhhhh Default: /LENGTH=100 Abbreviation: /L= /CS0 /CS1 /CS2 /CS3 /CS4 See function /P (Chapter 2.1) Default: /CS0 3 hhhhhh=number base is hex 42 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 Example: JT405xxx /DUMP This example makes a memory dump of the first 256 bytes of the Boot-EPROM. JTAG_PPC405a.doc 43 JTAG-Booster for IBM PPC405 2.5. Program an I²C-Device Usage: JT405xxx /PI2C filename [/I2CBIG] [optionlist] The specified file is programmed to an I²C-Device (i.e. a serial EEPROM) connected to pins of the CPU. Finally a complete verify is done. If the verify fails, the contents of the I²C-Device is written to a file with the extension DMP. Two methods to connect the I²C-Device to the CPU are supported. The first method is to use two CPU pins, one pin for clock output (I2CCLK) and one pin for serial data input and output (I2CDAT). The second method is to use one pin for clock output (I2CCLK), one for serial data input (I2CDATI) and one for serial data output (I2CDATO). Options: /I2CBIG Specify this option if there is a device which needs a three byte address instead of a two byte address. This option must be the first option after the filename. /DEVICE-BASE=hhhhhh This option specifies an I²C device starting address. The default values are chosen to access an serial EEPROM. Default: /DEVICE-BASE=5000 (if option /I2CBIG omitted) Default: /DEVICE-BASE=500000 (if option /I2CBIG specified) /OFFSET=hhhhhh The programming starts at an offset of hhhhhh relative to the start address of the I²C-Device. Default: /OFFSET=0 Abbreviation: /O= /FILE-OFFSET=hhhhhh If FILE-OFFSET is specified, the first hhhhhh bytes of the file are skipped and not programmed to target. Default: /FILE-OFFSET=0 Abbreviation: /FO= 44 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 /LENGTH=hhhhhh The number of programmed bytes may be limited to LENGTH. If no LENGTH is specified the whole file is programmed. Abbreviation: /L= /NODUMP In case of a verify error the contents of the I²C-Device is written to a file with the extension .DMP. With option /NODUMP you can suppress this feature. /I2CCLK=pin_name Specifies the CPU pin used for serial clock output. /I2CDAT=pin_name Specifies the CPU pin used for serial data input and output. Pin_name must specify a bidirectional pin otherwise an error message occurs. Instead of one bidirectional pin one pin for serial data input and one for serial data output may be used. See option /I2CDATO= and /I2CDATI= . /I2CDATO=pin_name Specifies the CPU pin used for serial data output. Pin_name must specify a output pin otherwise an error message occurs. /I2CDATI=pin_name Specifies the CPU pin used for serial data input. Pin_name must specify a input pin otherwise an error message occurs. Example: JT405xxx /PI2C EEPROM.CFG /I2CCLK=FLAG0 /I2CDAT=FLAG1 This example loads the file EEPROM.CFG to a serial EEPROM connected to the pins FLAG0 and FLAG1 of the IBM PPC405xxx JTAG_PPC405a.doc 45 JTAG-Booster for IBM PPC405 2.6. Read an I²C-Device to file Usage: JT405xxx /RI2C filename [/I2CBIG] /L=hhhhhh [optionlist] The contents of an I²C-Device (i.e. a serial EEPROM) is read and written to a file. The option /LENGTH= must be specified. Options: /I2CBIG This option must be the first option after the filename. See function /PI2C (Chapter 2.5) /DEVICE-BASE=hhhhhh See function /PI2C (Chapter 2.5) /OFFSET=hhhhhh Reading of the I²C-Device starts at an offset of hhhhhh relative to the start address of the I²C-Device. Default: /OFFSET=0 Abbreviation: /O= /LENGTH=hhhhhh The number of read bytes must be specified otherwise an error message occurs. Abbreviation: /L= /I2CCLK=pin_name See function /PI2C (Chapter 2.5) /I2CDAT=pin_name See function /PI2C (Chapter 2.5) /I2CDATO=pin_name See function /PI2C (Chapter 2.5) /I2CDATI=pin_name See function /PI2C (Chapter 2.5) 46 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 Example: JT405xxx /RI2C EEPROM.CFG /I2CCLK=GP26 /I2CDAT=GP27 /L=100 This example reads 256 bytes from a serial EEPROM to the file EEPROM.CFG. The serial EEPROM is connected to the pins CP26 and GP27 of the IBM PPC405xxx. JTAG_PPC405a.doc 47 JTAG-Booster for IBM PPC405 2.7. Verify an I²C-Device with file Usage: JT405xxx /VI2C filename [/I2CBIG] [optionlist] The contents of an I²C-Device (i.e. a serial EEPROM) is compared with the specified file. If there are differences the contents of the I²C -Device is written to a file with the extension DMP. Options: /I2CBIG This option must be the first option after the filename. See function /PI2C (Chapter 2.5) /DEVICE-BASE=hhhhhh See function /PI2C (Chapter 2.5) /OFFSET=hhhhhh See function /PI2C (Chapter 2.5) /FILE-OFFSET=hhhhhh See function /PI2C (Chapter 2.5) /LENGTH=hhhhhh See function /PI2C (Chapter 2.5) /NODUMP See function /PI2C (Chapter 2.5) /I2CCLK=pin_name See function /PI2C (Chapter 2.5) /I2CDAT=pin_name See function /PI2C (Chapter 2.5) /I2CDATO=pin_name See function /PI2C (Chapter 2.5) 48 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 /I2CDATI=pin_name See function /PI2C (Chapter 2.5) Example: JT405xxx /VI2C EEPROM.CFG /I2CCLK=GP26 /I2CDAT=GP27 This example verifies 256 bytes from a serial EEPROM with the file EEPROM.CFG. The serial EEPROM is connected to the pins CP26 and GP27 of the IBM PPC405xxx. JTAG_PPC405a.doc 49 JTAG-Booster for IBM PPC405 2.8. Dump an I²C-Device Usage: JT405xxx /DUMPI2C [/I2CBIG] [optionlist] A Hex-Dump of an I²C-Device is printed on the screen, if not redirected to file or device. Options: /I2CBIG This option must be the first option. See function /PI2C (Chapter 2.5) /DEVICE-BASE=hhhhhh See function /PI2C (Chapter 2.5) /OFFSET=hhhhhh4 The memory dump starts at an offset of hhhhhh. Default: /OFFSET=0 Abbreviation: /O= /LENGTH=hhhhhh Default: /LENGTH=100 Abbreviation: /L= /I2CCLK=pin_name Specifies the CPU pin used for serial clock output. /I2CDAT=pin_name Specifies the CPU pin used for serial data input and output. Pin_name must specify a bidirectional pin otherwise an error message occurs. Instead of one bidirectional pin one pin for serial data input and one for serial data output may be used. See option /I2CDATO= and /I2CDATI= . /I2CDATO=pin_name Specifies the CPU pin used for serial data output. Pin_name must specify a output pin otherwise an error message occurs. 4 hhhhhh=number base is hex 50 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 /I2CDATI=pin_name Specifies the CPU pin used for serial data input. Pin_name must specify a input pin otherwise an error message occurs. Example: JT405xxx /DUMPI2C /I2CCLK=FLAG0 /I2CDAT=FLAG1 This example makes a memory dump of the first 100h bytes of a serial EEPROM connected to the CPU. JTAG_PPC405a.doc 51 JTAG-Booster for IBM PPC405 2.9. Toggle CPU pins Usage: JT405xxx /BLINK /PIN=pinname [optionlist] This command allows to test the hardware by blinking with LEDs or toggling CPU signals. Faster signals can be generated by setting the delay option to zero. This can be a very helpful feature to watch signals on an oscilloscope. The signal on the defined pin has an duty cycle of 1/2: The level is 67% high and 33% low. Please Note: Not every pin of the IBM PPC405xxx may be specified as an output pin. Options: /PIN=pin_name CPU pin to toggle. If the option /PIN= is not specified an error message occurs. Most pins of the list in chapter 1.9 “Initialization file JT405xxx.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. /DELAY=dddddd5 Time to wait to next change of signal. This option can be adjusted to get optimum signals for measures with the oscilloscope. Default: /DELAY=10000 Example: JT405xxx /BLINK /PIN=FLAG3 /DELAY=0 This example toggles the FLAG3 pin very fast which can be followed by the use of an oscilloscope. 5 dddddd=number base is decimal 52 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 2.10. Polling CPU pins Usage: JT405xxx /PIN? /PIN=pinname [optionlist] This command allows to test the hardware by polling CPU signals. Please Note: Not every pin of the IBM PPC405xxx may be specified as an input pin. Options: /PIN=pin_name CPU pin to poll. If the option /PIN= is not specified an error message occurs. Most pins of the list in chapter 1.9 “Initialization file JT405xxx.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. Example: JT405xxx /PIN? /PIN=RESET# This example samples the reset pin of the IBM PPC405xxx. JTAG_PPC405a.doc 53 JTAG-Booster for IBM PPC405 2.11. Polling CPU pins while the CPU is running Usage: JT405xxx /SAMPLE /PIN=pinname [optionlist] This command is similar to the function /PIN?. But with this function any pin can be observed, independent of the pin direction. Furthermore the CPU remains in normal operation. Options: /PIN=pin_name CPU pin to poll. If the option /PIN= is not specified an error message occurs. All pins of the list in chapter 1.9 “Initialization file JT405xxx.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. Example: JT405xxx /SAMPLE /PIN=FLAG3 This example samples the state of the port pin FLAG3 while the IBM PPC405xxx is running. 54 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 2.12. Show status of all CPU pins while the CPU is running Usage: JT405xxx /SNAP [optionlist] This function is similar to the function /SAMPLE, but displays the status of all CPU pins on the screen. The CPU remains in normal operation. The behavior of the function /SNAP depends on the option /REP: With this option specified, the JTAG-Booster samples and displays the state of the CPU pins repetitive. Without this option the status of the pins is displayed only once. Options: /PAUSE Use this option to stop the output after each displayed screen. Don't use this option together with the option /REP or if the output is redirected to a file. Abbreviation /P /REP If this option is specified the status of the pins is sampled and displayed repetitive. In case of many signals the display is separated into several screens. Therefor we recommend to use a video mode with 43 or 50 lines. Use the '+' and the '-' key to switch between different screens. Any other key terminates the program. JTAG_PPC405a.doc 55 JTAG-Booster for IBM PPC405 Sample output: This is a sample output for a IBM PPC405EP | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 0 DQM2 1 MEM_DATA23 1 MEM_DATA25 1 DQM3 0 UART0_RX 1 PHY0_RX1D0 1 PER_DATA2 1 PER_DATA3 1 PER_DATA6 1 PER_DATA8 0 PER_DATA9 0 PHY0_RX1D2 0 PER_DATA12 0 PER_OE# 0 PER_CS3# 0 EXT_RESET# 0 PER_ADDR3 0 PHY0_CRS1 1 PER_ADDR7 1 PER_ADDR11 1 PER_ADDR15 0 PER_ADDR18 0 PER_ADDR22 0 PER_ADDR26 0 PER_ADDR30 0 EMC0_TX1D3 0 PCI_INT# 0 PCI_AD3 1 PCI_AD6 0 PCI_AD10 1 PCI_CLK 1 PCI_REQ0# 0 PCI_REQ1# 0 PCI_RESET# 1 PCI_STOP# 1 PCI_PARITY 1 PCI_AD19 0 PCI_AD22 1 PCI_AD26 1 PCI_AD29 56 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1 MEM_DATA21 0 MEM_DATA24 1 MEM_DATA26 1 UART0_CTS# 1 MEM_DATA30 1 EMC0_TX0D3 1 EMC0_TX0D1 0 PER_DATA4 0 UART0_DSR# 1 UART0_DTR# 1 PER_DATA10 1 PER_DATA13 0 PER_WBE0# 0 PER_CS2# 0 PER_CS0# 1 PER_READY 1 PER_ADDR4 1 PER_ADDR5 0 PER_ADDR8 0 PER_ADDR12 0 PER_ADDR16 0 PER_ADDR19 0 PER_ADDR23 0 PER_ADDR27 0 PER_ADDR31 0 EMC0_TX1D0 0 PCI_AD0 1 PCI_C/BE0# 0 PCI_AD7 0 PCI_AD11 1 PCI_IDSEL 0 PCI_AD14 1 PCI_REQ2# 1 PCI_FRAME# 1 PCI_DEVSEL# 1 PCI_AD16 1 PCI_C/BE2# 1 PCI_AD23 0 PCI_C/BE3# 1 PCI_AD30 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1 IIC_SDA 1 EMC0_TX0EN 1 MEM_DATA27 1 MEM_DATA28 1 MEM_DATA31 1 PER_DATA0 1 UART0_RTS# 1 EMC0_TX0D2 0 UART0_RI# 1 UART1_RX 0 PHY0_RX1D1 0 PER_DATA14 0 PER_WBE1# 0 PER_DATA15 0 PER_CS1# 0 PER_CS4# 1 PHY0_COL1 1 PHY0_TX1CLK 1 PER_ADDR9 1 PER_ADDR13 1 PER_ADDR17 0 PER_ADDR20 0 PER_ADDR24 0 PER_ADDR28 0 EMC0_TX1D1 0 EMC0_TX1ERR 0 PCI_AD1 0 PCI_AD4 0 PCI_AD8 1 PCI_AD12 1 PCI_AD13 0 PCI_AD15 0 PCI_GNT1# 1 PCI_IRDY# 0 PCI_SERR# 1 PCI_AD17 0 PCI_AD20 1 PCI_AD24 1 PCI_AD27 0 PCI_AD31 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1 MEM_DATA22 1 EMC0_TX0ERR 1 EMC0_TX0D0 0 MEM_DATA29 1 UART0_TX 1 PER_DATA1 1 UART0_DCD# 0 PER_DATA5 0 PER_DATA7 1 UART1_TX 1 PER_DATA11 0 PHY0_RX1D3 0 PHY0_RX1CLK 0 PER_R/W# 0 PHY0_RX1ERR 0 PER_CLK 0 PHY0_RX1DV 0 PER_ADDR6 0 PER_ADDR10 0 PER_ADDR14 1 PER_BLAST# 0 PER_ADDR21 0 PER_ADDR25 0 PER_ADDR29 0 EMC0_TX1D2 0 EMC0_TX1EN 0 PCI_AD2 1 PCI_AD5 0 PCI_AD9 1 PCI_C/BE1# 0 HALT# 1 PCI_GNT0# 1 PCI_GNT2# 1 PCI_TRDY# 0 PCI_PERR# 1 PCI_AD18 1 PCI_AD21 1 PCI_AD25 1 PCI_AD28 1 IRQ6 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 | | | | | | | | | | | | | | | | | | | | 0 IRQ5 1 GPIO7 1 IRQ2 0 GPIO3 1 PHY0_RX0D1 0 MEM_ADDR11 1 MEM_ADDR7 1 SYS_CLK 1 MEM_ADDR2 1 MEM_BA1 0 MEM_WE# 1 MEM_CLKEN1 1 MEM_DATA0 1 MEM_DATA3 1 MEM_DATA5 0 PHY0_CRS0 1 MEM_DATA10 1 MEM_DATA12 0 MEM_DATA16 0 IIC_SCL | | | | | | | | | | | | | | | | | | | | JTAG_PPC405a.doc 1 IRQ4 1 GPIO6 0 IRQ1 1 GPIO2 1 GPIO1 1 SYS_RESET# 0 MEM_ADDR6 1 MEM_ADDR4 1 PHY0_RX0D2 0 MEM_RAS# 1 MEM_CLKOUT0 1 PHY0_RX0D3 1 MEM_DATA1 1 DQM0 0 MEM_DATA6 1 MEM_DATA8 0 MEM_DATA11 1 MEM_DATA13 1 EMC0_MDCLK 1 MEM_DATA19 | | | | | | | | | | | | | | | | | | | | 1 GPIO9 0 IRQ3 1 IRQ0 1 REJECT_PKT1 1 MEM_ADDR12 1 MEM_ADDR9 1 MEM_ADDR5 1 PHY0_RX0D0 0 MEM_ADDR1 1 MEM_ADDR0 1 MEM_CLKEN0 0 BANKSEL0# 1 MEM_DATA2 0 MEM_DATA4 1 PHY0_RX0DV 0 MEM_DATA9 1 DQM1 1 MEM_DATA14 0 EMC0_MDIO 0 MEM_DATA18 | | | | | | | | | | | | | | | | | | | | 0 GPIO8 1 GPIO5 1 GPIO4 0 REJECT_PKT0 1 MEM_ADDR10 1 MEM_ADDR8 1 SYS_ERR 0 MEM_ADDR3 1 MEM_BA0 1 MEM_CAS# 0 MEM_CLKOUT1 0 BANKSEL1# 1 PHY0_RX0ERR 1 PHY0_RX0CLK 1 MEM_DATA7 1 PHY0_COL0 1 PHY0_TX0CLK 1 MEM_DATA15 1 MEM_DATA17 1 MEM_DATA20 57 JTAG-Booster for IBM PPC405 3. Implementation Information This chapter summarizes some information about the implementation of the JTAG-Booster and describes some restrictions. • The JTAG-Booster currently uses Boundary Scan to perform Flash programming. The Debug Interface of the PPC405 is not used. • The software assumes the following scheme for connecting the FlashEPROM to the IBM PPC405xxx. Please contact us, if you have used a different method. PPC405EP signal PER_CS0# PER_CS1# PER_CS2# PER_CS3# PER_CS4# PER_OE# PER_WBE1# PER_ADDR0 PER_ADDR1 PER_ADDR2..26 PER_DATA0..7 PER_DATA0..15 PER_DATA0..31 8 Bit Flash CS# 16 Bit Flash CS# 32 Bit Flash CS# OE# WE# A0 A1 A2..26 D0..7 - OE# WE# A1 A2..26 D0..15 - OE# WE# A2..26 D0..31 1.) PER_R/W# is set to output with high level during read cycles and is set to output with low level during write cycles. 2.) Only PER_WBE1# is switched as write strobe. 3.) All other signals are hold static during flash programming. The state of these signals is defined in the Initialization file. 58 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 4. Converter Program HEX2BIN.EXE Since the JTAG-Booster software is not able to handle Intel-HEX or Motorola SRecord files, an separate converter tool is delivered with this product package. Five types of HEX formats can be converted to BIN file: • I • D : Digital Research • M : MOTOROLA S HEX format (BYTE oriented) • T : TEKTRONICS HEX format (BYTE oriented) • H : Intel HEX-32 : INTEL HEX format (BYTE oriented) th Maximum conversion size is 256 kBytes. A 4 parameter for starting address can be specified to skip out the leading garbage and you will maintain a small size of output binary file. If you start the HEX2BIN without any additional parameter all necessary parameters will be asked for in a prompt mode: HEX2BIN Input HEX file name: MYAPP.H86 Output BIN file name[MYAPP.BIN]: HEX file format ntel /otorola /igital Research /ektronics /[H] Intel HEX-32[I] : H Input CODE segment start address[0000000]: 10000 Input CODE segment end address[FFFFFFF]: Unused bytes will be 00 FF [1] : 2 Instead of using the prompt mode, you can directly specify all necessary parameters in the command line. This is essential for making batch files: HEX2BIN MYAPP.H86 MYAPP.BIN H 0010000 FFFFFFF 2 It is very important to fill unused bytes with 0xFF, because this are simply skipped by the JTAG-Boosters software and so it speeds up the programming performance. JTAG_PPC405a.doc 59 JTAG-Booster for IBM PPC405 Please Note: "CODE segment start address" is interpreted as a Intel x86 architecture segment address: You have to specify a start address of 10000 to start the conversion at 1 MByte. This converter is a relatively old DOS tool and therefor it has problems with non DOS compliant file and directory names. Avoid names with spaces, limit names to eight characters. Otherwise the converter does not convert the input file, without any error message!! 60 JTAG_PPC405a.doc JTAG-Booster for IBM PPC405 5. Support for Windows NT, Windows 2000 and Windows XP A configured run time version of the "Kithara DOS Enabler, Version 6.x" is used to give support for some of our DOS based tools (like the JTAG-Booster) for Windows NT, Windows 2000 and Windows XP. After installation of the "DOS Enabler" the accesses to the LPT ports are allowed for the all programs listed in file Readme_WinNT.txt Note: Accesses to the ports are only allowed for the programs listed in file Readme_WinNT.txt. If you rename one of our tools, the DOS Enabler does not work. Important: You need administrator rights to install or de-install this program. 5.1. Installation on a clean system If you have a clean system without having installed a previous version of the "Kithara Tool Center", this tool is really simple to install. Extract the ZIP file to a new folder and start KSETUP.EXE. Everything is done within a few seconds. No additional input is needed. Now reboot your PC. 5.2. Installation with already installed version 5.x/6.x of Kithara If you have already installed an older WinNT support (Kithara Version 5.x or 6.x), st you have to de-install it 1 as described in chapter 5.4. After rebooting your PC you can install the Kithara 6.x as described above. 5.3. Installation with already installed version 4.x of Kithara Important!! If you have already installed an older WinNT support, you have to deinstall it completely!!! • Start kcenter • Select Register "Einstellungen" (=Settings) and deactivate "VDD benutzen" and "speziellen seriellen Treiber benutzen". • Stop Kernel JTAG_PPC405a.doc 61 JTAG-Booster for IBM PPC405 • exit the kcenter program • Now you can deinstall the Kithara Package with: Settings - Control Panel. All unused parts must be removed. • Reboot your PC • Now you can install the Kithara 6.x as described above. 5.4. De-Installation version 5.x/6.x: For deinstallation of the runtime version of the "Kithara DOS-Enabler Version 5.x/6.x": • use: Settings - Control-Panel - Add/Remove Programs and remove the “FS FORTH-SYSTEME WinNT Support” and/or “WinNT Support for JTAG-Booster and FLASH166” • Reboot your PC 62 JTAG_PPC405a.doc
FS-9017 价格&库存
很抱歉,暂时无法提供与“FS-9017”相匹配的价格&库存,您可以联系我们找货
