FS-9019
FS-9019
    DIGIINTERNATIONAL
    JTAG-BOOSTER FOR ALCHEMY 3.3V
FS-9019 数据手册
JTAG-Booster for AMD Alchemy Solutions Processors P.O: Box 1103 Kueferstrasse 8 Tel. +49 (7667) 908-0 sales@fsforth.de • • • • D-79200 Breisach, Germany D-79206 Breisach, Germany Fax +49 (7667) 908-200 http://www.fsforth.de AMD Alchemy Solutions Processors Copyright  1995..2004: FS FORTH-SYSTEME GmbH Postfach 1103, D-79200 Breisach, Germany Release of Document: Author: Filename: Program Version: November 22, 2004 Dieter Fögele JTAG_alchemyb.doc 4.xx All rights reserved. No part of this document may be copied or reproduced in any form or by any means without the prior written consent of FS FORTH-SYSTEME GmbH. 2 JTAG_alchemyb.doc AMD Alchemy Solutions Processors Table of Contents 1. General ............................................................................................................ 5 1.1. Ordering Information.............................................................................. 7 1.2. System Requirements ........................................................................... 7 1.3. Contents of Distribution Disk ................................................................. 8 1.4. Connecting your PC to the target system .............................................. 9 1.5. First Example with AMD Alchemy Solutions Au1000 Processor ......... 11 1.6. First Example with AMD Alchemy Solutions Au1100 Processor ......... 13 1.7. First Example with AMD Alchemy Solutions Au1500 Processor ......... 15 1.8. First Example with AMD Alchemy Solutions Au1550 Processor ......... 17 1.9. Trouble Shooting ................................................................................. 19 1.10.Error Messages ................................................................................... 20 1.11.Initialization file JTAuxxxx.INI.............................................................. 25 1.12.Supported flash devices ...................................................................... 60 2. JTAuxxxx Parameter Description................................................................... 61 2.1. Program a Flash Device ...................................................................... 64 2.2. Read a Flash Device to file.................................................................. 68 2.3. Verify a Flash Device with file.............................................................. 70 2.4. Dump target memory ........................................................................... 72 2.5. Program a Serial Device (I²C/SPI/MicroWire)...................................... 74 2.6. Read a Serial Device to file (I²C/SPI/MicroWire) ................................. 77 2.7. Verify a Serial Device with file (I²C/SPI/MicroWire) ............................. 79 2.8. Dump a Serial Device (I²C/SPI/MicroWire) .......................................... 81 2.9. Toggle CPU pins.................................................................................. 83 2.10.Polling CPU pins ................................................................................. 84 2.11.Polling CPU pins while the CPU is running ......................................... 85 2.12.Show status of all CPU pins while the CPU is running........................ 86 3. Implementation Information ........................................................................... 89 4. Converter Program HEX2BIN.EXE ................................................................ 90 5. Support for Windows NT, Windows 2000 and Windows XP.......................... 92 5.1. Installation on a clean system.............................................................. 92 5.2. Installation with already installed version 5.x/6.x of Kithara................. 92 5.3. Installation with already installed version 4.x of Kithara ...................... 92 JTAG_alchemyb.doc 3 AMD Alchemy Solutions Processors 5.4. De-Installation version 5.x/6.x: .............................................................93 4 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 1. General The programs JTAu1000.EXE, JTAu1100.EXE, JTAu1500.EXE and JTAu1550.EXE use the IEEE 1149.1 JTAG port of the AMD Alchemy Solutions Processors in conjunction with the small JTAG-Booster: • • • • • to program data into flash memory to verify and read the contents of a flash memory to make a memory dump to access a serial device (I²C/SPI/MicroWire) to test CPU signals All functions are done without any piece of software running in the target. No firmware or BIOS must be written. Bootstrap software may be downloaded to initially unprogrammed memories. As this tool uses boundary scan, it is extremely simple and very powerful. It assists you in bringing-up new hardware. Even if there are essential bugs in the hardware (i.e. RAM not reliable working, soldering problems with the BGA package), in many cases you are able to load small test programs into flash, which helps you to analyze hardware problems. Or if you have a flash memory, which is not connected correctly to the CPU (i.e. CPU's A0 is connected to a 16 bit AMD flash), we can support you with a special adapted version of the JTAGBooster. The JTAG-BOOSTER' s software is highly optimized to the JTAG chain of a specific target CPU. To give support for all processors of the AMD Alchemy Solutions Processors family, there are three different programs on the distribution disk: • JTAu1000.EXE : Tool for AMD Alchemy Solutions Au1000 Processor • JTAu1100.EXE : Tool for AMD Alchemy Solutions Au1100 Processor • JTAu1500.EXE : Tool for AMD Alchemy Solutions Au1500 Processor • JTAu1550.EXE : Tool for AMD Alchemy Solutions Au1550 Processor Please contact us, if you need support for other members of the AMD Alchemy Solutions Processors family. JTAG_alchemyb.doc 5 AMD Alchemy Solutions Processors For latest documentation please refer to the file README.TXT on the distribution disk. 6 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 1.1. Ordering Information The following related products are available • 9019 1.2. JTAG-Booster AMD Alchemy Solutions Processors, 3.3V, AMD Au1000, Au1100, Au1500, Au1550 DOS/Win9x/WinNT/Win2000/WinXP delivered with adapter type 285 and additional cable with single strands TK02206 System Requirements To successfully run this tool the following requirements must be met: • MSDOS, WIN3.x, WIN9x, WinNT, Win2000 or WindowsXP (WinNT/Win2000/WindowsXP is supported with an additional tool, see chapter 5 “Support for Windows NT, Windows 2000 and Windows XP”) • Intel 80386 or higher • 205 kByte of free DOS memory • Parallel Port JTAG_alchemyb.doc 7 AMD Alchemy Solutions Processors 1.3. Contents of Distribution Disk • JTAu1000.EXE JTAu1000.OVL Tool for AMD Alchemy Solutions Au1000 Processor • JTAu1000.INI Template configuration file for AMD Alchemy Solutions Au1000 Processor. See chapter 1.11 "Initialization file JTAuxxxx.INI" • JTAu1100.EXE JTAu1100.OVL Tool for AMD Alchemy Solutions Au1100 Processor • JTAu1100.INI Template configuration file for AMD Alchemy Solutions Au1100 Processor. See chapter 1.11 "Initialization file JTAuxxxx.INI" • JTAu1500.EXE JTAu1500.OVL Tool for AMD Alchemy Solutions Au1500 Processor • JTAu1500.INI Template configuration file for AMD Alchemy Solutions Au1500 Processor. See chapter 1.11 "Initialization file JTAuxxxx.INI" • JTAu1550.EXE JTAu1550.OVL Tool for AMD Alchemy Solutions Au1550 Processor • JTAu1550.INI Template configuration file for AMD Alchemy Solutions Au1550 Processor. See chapter 1.11 "Initialization file JTAuxxxx.INI" • WinNT This subdirectory contains the support for Windows NT, Windows 2000 and Windows XP. See chapter 5 "Support for Windows NT, Windows 2000 and Windows XP" • JTAG_V4xx_FLAS HES.pdf List of all supported Flash devices • README.txt Release notes, new features, known problems 8 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 1.4. Connecting your PC to the target system The JTAG-Booster can be plugged into standard parallel ports (LPT1-3) with a DB25-Connector. 1 LPT1-3 1 Élan SC400 Module Élan486 The target end of the cable has the following reference: 1 TCK 2* GND 3 TMS 4 TRST# 5 NC 6 TDI 7 TDO 8 +3.3V *PIN 2 can be detected by the thick cable. To connect your design to the JTAG-BOOSTER you need a single row berg connector with a spacing of 2.54mm on your PCB. The names refer to the target: Pin 7 is the target’s TDO pin and is connected to the JTAG-Booster’s TDI pin. The 3.3V version of the JTAG-Booster (FS part number 285) is delivered together with this package. Don’t use the 5V version of the JTAG-Booster (FS part number 227) with a 3.3V target. Don’t apply 5V to the 3.3V version of the JTAG-Booster! Your target must be able to power the JTAG-Booster, it draws about 100mA. Before you start the program, the JTAG-BOOSTER must be plugged to a parallel interface of your PC and to the 8 pin JTAG connector on the target. JTAG_alchemyb.doc 9 AMD Alchemy Solutions Processors The utility is started with the general command line format: JTAGxxx JTAuxxxx /function [filename] [/option_1] ... [/option_n]. Note that the function must be the first argument followed (if needed) by the filename. If you want to cancel execution of JTAuxxxx, press CTRL-Break-Key. On any error the program aborts with an MSDOS error level of one. 10 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 1.5. First Example with AMD Alchemy Solutions Au1000 Processor In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JTAu1000 /P MYAPP.BIN at the DOS prompt results in the following output: JTAu1000 --- JTAG utility for AMD Alchemy Solutions Au1000 Processor Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JTAu1000.INI Target: Generic Target Using LPT at I/O-address 0378h JTAG Adapter detected (5) 1 Device detected in JTAG chain Device 0: IDCODE=003E828F AMD Alchemy Au1000, Revision 0 Sum of instruction register bits : 5 CPU position :0 Instruction register offset :0 Length of boundary scan reg : 569 (6) (7) (8) (9) (10) (11) (12) (13) Looking for a known flash device. Please wait.. AMD 29LV160B, 3,3V, Boot Block Bottom detected Bus size is 16 Bit Erasing Flash-EPROM Block #:0 1 2 3 Unlock Bypass used Programming File MYAPP.BIN 65536 Bytes programmed successfully Erase Time Programming Time JTAG_alchemyb.doc : : 0.8 sec xx.1 sec 11 AMD Alchemy Solutions Processors (1) The initialization file JTAu1000.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. With WinNT/Win2000/WinXP you must specify the option /LPT2 to access to the standard address 378h. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the AMD Alchemy Solutions Au1000 Processor are switched to bypass mode. (6) The length of all instruction registers in the JTAG chain are added. (7) The position of the AMD Alchemy Solutions Au1000 Processor in the JTAG chain is assumed to be zero, if not specified in the command line (see option /CPUPOS=). (8) The position of the JTAG instruction register of the AMD Alchemy Solutions Au1000 Processor is assumed to be zero, if not specified in the command line (see option /IROFFS=). (9) The real length of the boundary scan register is displayed here and compared with the boundary scan register length of a AMD Alchemy Solutions Au1000 Processor. (10) A Flash AMD 29LV160B selected with RCS0# was found. (11) The resulting data bus size is printed here. (12) In this example 4 blocks must be erased. (13) If available, the "Unlock Bypass Mode" is activated. In boundary scan mode, this increases the programming performance by 67..75%. 12 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 1.6. First Example with AMD Alchemy Solutions Au1100 Processor In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JTAu1100 /P MYAPP.BIN at the DOS prompt results in the following output: JTAu1100 --- JTAG utility for AMD Alchemy Solutions Au1100 Processor Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JTAu1100.INI Target: Generic Target Using LPT at I/O-address 0378h JTAG Adapter detected (5) 1 Device detected in JTAG chain Device 0: IDCODE=0020228F AMD Alchemy Au1100, Revision 0 Sum of instruction register bits : 5 CPU position :0 Instruction register offset :0 Length of boundary scan reg : 672 (6) (7) (8) (9) (10) (11) (12) (13) Looking for a known flash device. Please wait.. AMD 29LV160B, 3.3V, Boot Block Bottom detected Bus size is 16 Bit Erasing Flash-EPROM Block #:0 1 2 3 Unlock Bypass used Programming File MYAPP.BIN 65536 Bytes programmed successfully Erase Time Programming Time JTAG_alchemyb.doc : : 0.8 sec xx.0 sec 13 AMD Alchemy Solutions Processors (1) The initialization file JTAu1100.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the AMD Alchemy Solutions Au1100 Processor are switched to bypass mode. (6) The length of all instruction registers in the JTAG chain are added. (7) The position of the AMD Alchemy Solutions Au1100 Processor in the JTAG chain is assumed to be zero, if not specified in the command line (see option /CPUPOS=). (8) The position of the JTAG instruction register of the AMD Alchemy Solutions Au1100 Processor is assumed to be zero, if not specified in the command line (see option /IROFFS=). (9) The real length of the boundary scan register is displayed here and compared with the boundary scan register length of a AMD Alchemy Solutions Au1100 Processor. (10) A Flash AMD 29LV160B selected with RCS0# was found. (11) The resulting data bus size is printed here. (12) In this example four block must be erased. (13) If available, the "Unlock Bypass Mode" is activated. In boundary scan mode, this increases the programming performance by 67..75%. 14 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 1.7. First Example with AMD Alchemy Solutions Au1500 Processor In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JTAu1500 /P MYAPP.BIN at the DOS prompt results in the following output: JTAu1500 --- JTAG utility for AMD Alchemy Solutions Au1500 Processor Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JTAu1500.INI Target: Generic Target Using LPT at I/O-address 0378h JTAG Adapter detected (5) 1 Device detected in JTAG chain Device 0: IDCODE=0010228F AMD Alchemy Au1500, Revision 0 Sum of instruction register bits : 5 CPU position :0 Instruction register offset :0 Length of boundary scan reg : 744 (6) (7) (8) (9) (10) (11) (12) (13) Looking for a known flash device. Please wait.. AMD 29LV160B, 3.3V, Boot Block Bottom detected Bus size is 16 Bit Erasing Flash-EPROM Block #:0 1 2 3 Unlock Bypass used Programming File MYAPP.BIN 65536 Bytes programmed successfully Erase Time Programming Time JTAG_alchemyb.doc : : 0.8 sec xx.0 sec 15 AMD Alchemy Solutions Processors (1) The initialization file JTAu1500.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the AMD Alchemy Solutions Au1500 Processor are switched to bypass mode. (6) The length of all instruction registers in the JTAG chain are added. (7) The position of the AMD Alchemy Solutions Au1500 Processor in the JTAG chain is assumed to be zero, if not specified in the command line (see option /CPUPOS=). (8) The position of the JTAG instruction register of the AMD Alchemy Solutions Au1500 Processor is assumed to be zero, if not specified in the command line (see option /IROFFS=). (9) The real length of the boundary scan register is displayed here and compared with the boundary scan register length of a AMD Alchemy Solutions Au1500 Processor. (10) A Flash AMD 29LV160B selected with RCS0# was found. (11) The resulting data bus size is printed here. (12) In this example four block must be erased. (13) If available, the "Unlock Bypass Mode" is activated. In boundary scan mode, this increases the programming performance by 67..75%. 16 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 1.8. First Example with AMD Alchemy Solutions Au1550 Processor In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JTAu1550 /P MYAPP.BIN at the DOS prompt results in the following output: JTAu1550 --- JTAG utility for AMD Alchemy Solutions Au1550 Processor Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JTAu1550.INI Target: Generic Target Using LPT at I/O-address 0378h JTAG Adapter detected (5) 1 Device detected in JTAG chain Device 0: IDCODE=0030228F AMD Alchemy Au1550, Revision 0 Sum of instruction register bits : 5 CPU position :0 Instruction register offset :0 Length of boundary scan reg : 773 (6) (7) (8) (9) (10) (11) (12) (13) Looking for a known flash device. Please wait.. AMD 29LV160B, 3.3V, Boot Block Bottom detected Bus size is 16 Bit Erasing Flash-EPROM Block #:0 1 2 3 Unlock Bypass used Programming File MYAPP.BIN 65536 Bytes programmed successfully Erase Time Programming Time JTAG_alchemyb.doc : : 0.8 sec xx.0 sec 17 AMD Alchemy Solutions Processors (1) The initialization file JTAu1550.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the AMD Alchemy Solutions Au1550 Processor are switched to bypass mode. (6) The length of all instruction registers in the JTAG chain are added. (7) The position of the AMD Alchemy Solutions Au1550 Processor in the JTAG chain is assumed to be zero, if not specified in the command line (see option /CPUPOS=). (8) The position of the JTAG instruction register of the AMD Alchemy Solutions Au1550 Processor is assumed to be zero, if not specified in the command line (see option /IROFFS=). (9) The real length of the boundary scan register is displayed here and compared with the boundary scan register length of a AMD Alchemy Solutions Au1550 Processor. (10) A Flash AMD 29LV160B selected with RCS0# was found. (11) The resulting data bus size is printed here. (12) In this example four block must be erased. (13) If available, the "Unlock Bypass Mode" is activated. In boundary scan mode, this increases the programming performance by 67..75%. 18 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 1.9. Trouble Shooting Avoid long distances between your Host-PC and the target. If you are using standard parallel extension cable, the JTAG-BOOSTER may not work. Don't use Dongles between the parallel port and the JTAG-BOOSTER. Switch off all special modes of your printer port (EPP, ECP, ...) in the BIOS setup. Only standard parallel port (SPP) mode is allowed. If there are problems with autodetection of the flash devices use the /DEVICE= option. To speed up autodetection specify one of the options /8BIT /16BIT or /32BIT. Don't use hardware protected flash memories. The used chip selects must be defined as output and inactive in the initialization file (see chapter 1.11 “Initialization file JTAuxxxx.INI”). Also the address bits must be defined as output. Use the option /NOWRSETUP to speed up flash programming. JTAG_alchemyb.doc 19 AMD Alchemy Solutions Processors 1.10. Error Messages • 80386 or greater required The JTAG-BOOSTER does not work on a 8088/8086 or a 80286 platform. • Cable not connected or target power fail The JTAG-Booster (or one of the simple Parallel Port JTAG adapters selected with the options /LATTICE /WIGGLER /PLS) wasn't found. Please check connection to parallel port and connection to target. Check target power. Check the command line options. Check your BIOS-Setup. If you are using this program with WinNT, Win2000 or WinXP you must specify /LPT2 or /LPT-BASE=378 to get access to the standard printer port. • Can't open x:\yyy\zzz\JTAuxxxx.OVL The overlay file JTAuxxxx.OVL must be in the same directory as JTAuxxxx.EXE. • Configuration file XYZ not found. The file specified with the option /INI= wasn't found. • Device offset out of range The value specified with the option /OFFSET= is greater than the size of the detected flash device. • Disk full Writing a output file was aborted as a result of missing disk space. • Do not specify option /NOCS with any other chip select There is a conflict in the command line. • Do not specify option /BYTE-MODE. Flash device does not have a byte mode pin. The flash device specified with the option /DEVICE= does not support switching between 16 (or 32) bit mode and 8 bit mode. In practice it does not have a pin with the name BYTE# • Error creating file: The output file could not be opened. Please check free disk space or write protection. 20 JTAG_alchemyb.doc AMD Alchemy Solutions Processors • Error: Pin-Name is an output only pin The specified pin cannot be sampled. Check the command line. Check the initialization file. • Error: Pin-Name is an input only pin The specified pin cannot be activated. Check the command line. Check the initialization file. • Error: Pin-Name may not be read back The specified pin can be switched to tristate, but cannot be read back. Check the command line. • illegal function: The first parameter of the command line must be a valid function. See chapter 2 “JTAuxxxx Parameter Description” for a list of supported functions. • illegal number: The specified number couldn’t be interpret as a valid number. Check the relevant number base. • illegal option: See chapter 2 “JTAuxxxx Parameter Description” for a list of supported options. • illegal Pin Type: The name specified with the option /PIN= must be one of the list of chapter 1.11 ”Initialization file JTAuxxxx.INI” • illegal Flash Type: The name specified with the option /DEVICE= must be one of the list of chapter 1.12 “Supported flash devices” • Input file not found: The specified file cannot be found • Input file is empty: Files with zero length are not accepted JTAG_alchemyb.doc 21 AMD Alchemy Solutions Processors • " " is undefined Please check the syntax in your configuration file. (See chapter 1.11 “Initialization file JTAuxxxx.INI”). • LPTx not installed The LPT port specified with /LPTx cannot be found. Please check the LPT port or specify a installed LPT port. Check your BIOS setup. If you are using this program with WinNT, Win2000 or WinXP you 1st must install the WinNT support package as described in chapter 5"Support for Windows NT, Windows 2000 and Windows XP • missing filename Most functions need a filename as second parameter. • missing option /SERCLK= Some functions need the option /SERCLK= to be defined. • missing option /SERDAT= Some functions need the option /SERDAT= or the options /SERDATO= and /SERDATI= to be defined. • missing option /SERCS= Some functions need the option /SERCS= if the option /SPI or the option /MWIRE is specified. • missing option /LENGTH= Some functions need the option /LENGTH= to be defined. • missing option /PIN= Some functions need the option /PIN= to be defined. • More than 9 devices in the JTAG chain or TDO pin stuck at low level The JTAG chain is limited to 9 parts. Check target power. Check the target’s TDO pin. • No devices found in JTAG chain or TDO pin stuck at high level A stream of 32 high bits was detected on the pin TDO. TDO may stuck at high level. Check the connection to your target. Check the target power. Check the target’s TDO pin. 22 JTAG_alchemyb.doc AMD Alchemy Solutions Processors • Option /CPUPOS= out of range The number specified with the option /CPUPOS= must be less or equal to the number of parts minus 1. • Option /IROFFS= out of range Please specify a smaller value • Part at specified position is not a AMD Alchemy Solutions Processors The option /CPUPOS= points to a part not a AMD Alchemy Solutions Processors • Pins specified with /SERCLK= and /SERDAT= must have different control cells The pin specified with the option /SERDAT= must be able to be switched to high impedance while the pin specified with option /SERCLK= is an active output. See chapter 1.11 “Initialization file JTAuxxxx.INI”. • Pins specified with /SERCLK= and /SERDATI= must have different control cells The pin specified with the option /SERDATI= must be able to be switched to high impedance while the pin specified with option /SERCLK= is an active output. See chapter 1.11 “Initialization file JTAuxxxx.INI”. • Pins specified with /SERDATO= and /SERDATI= must have different control cells The pin specified with the option /SERDATI= must be able to be switched to high impedance while the pin specified with option /SERDATO= is an active output. See chapter 1.11 “Initialization file JTAuxxxx.INI”. • Specify only one of these options: Some options are exclusive (i.e. /8BIT and /16BIT). Don't mix them. • Sum of instruction register bits to low. Should be at least 5 bits for a AMD Alchemy Solutions Processors The sum of all instruction register bits in the JTAG chain does not fit to the AMD Alchemy Solutions Processors. Check the target connection. Check the target CPU type. Check the settings for /IROFFS= and /CPUPOS= , if there are several parts in the JTAG chain. JTAG_alchemyb.doc 23 AMD Alchemy Solutions Processors • Target no longer connected There is a cyclic check of the JTAG chain. Check target power. Check target connection. • There are unknown parts in the JTAG chain. Please use the option /IROFFS= to specify the instr. reg. offset of the CPU. If there are unknown parts in the JTAG chain, the program isn’t able to determine the logical position of the CPU’s instruction register. • There is no AMD Alchemy Solutions Processors in the JTAG chain No AMD Alchemy Solutions Processors was found in the JTAG chain. Check the target power. Try with option /DRIVER=4 again. • Value of option /FILE-OFFSET out of range The value of the option /FILE-OFFSET= points behind end of file. • wrong driver # The value specified with the option /DRIVER= is out of range. • Wrong Flash Identifier (xxxx) No valid identifier found. Check the specified chip select signal and the bus width. Try with the option /DEVICE= . Use the option /8BIT or /16BIT or /32BIT to specify the correct data bus size. • Wrong length of boundary scan register. Should be 569 for a AMD Alchemy Solutions Au1000 Processor. (Should be 672 for a AMD Alchemy Solutions Au1100 Processor. Should be 744 for a AMD Alchemy Solutions Au1500 Processor Should be 773 for a AMD Alchemy Solutions Au1550 Processor.) The length of the boundary scan register of the selected part (if there are more than one in the chain) does not fit to the AMD Alchemy Solutions Processors. Check the target connection. Check the target CPU type. Check the settings for /IROFFS= and /CPUPOS= , if there are several parts in the JTAG chain. 24 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 1.11. Initialization file JTAuxxxx.INI This file is used to define the default direction and level of all CPU signals. This file must be carefully adapted to your design with the AMD Alchemy Solutions Processors. The Target-Entry is used to identify your design which is displayed with most commands. When the program JTAuxxxx.EXE is started it scans the current directory for an existing initialization file named JTAuxxxx.INI. If no entry is found the default values are used. You may also specify the initialization file with the option /INI= . If the specified file isn't found, the program aborts with an error message. The CPU pins can also be used with the functions /BLINK (chapter 2.9), /PIN? (chapter 2.10) and /SAMPLE (chapter 2.11) to test the signals on your design. The sample file below represents the values which are used for default initialization when no initialization file could be found in the current directory and no initialization file is specified with the option /INI=. Changes to the structure of the file could result in errors. Remarks can be added by using //. JTAG_alchemyb.doc 25 AMD Alchemy Solutions Processors Sample File JTAu1000.INI: // Description file for AMD Au1000 Target: Generic Target, 2003/10/02 // Adapt this file carefully to your design!! // All chip select signals are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults. // Pin names are defined in upper case. // Low active signals are signed with a trailing #. // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. // During flash programming these pins are switched between // input/inactive and output/active. // For Flash programming and other memory accesses // these pins should be set to Input RD0 Inp // SRAM/IO/PCMCIA/FLASH/ROM/LCD Data Bus RD1 Inp // RD2 Inp // RD3 Inp // RD4 Inp // RD5 Inp // RD6 Inp // RD7 Inp // RD8 Inp // RD9 Inp // RD10 Inp // RD11 Inp // RD12 Inp // RD13 Inp // RD14 Inp // RD15 Inp // RD16 Inp // RD17 Inp // RD18 Inp // RD19 Inp // RD20 Inp // RD21 Inp // 26 JTAG_alchemyb.doc AMD Alchemy Solutions Processors RD22 RD23 RD24 RD25 RD26 RD27 RD28 RD29 RD30 RD31 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // // // // // // // // // // // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. // For Flash Programming these pins must be set to output RAD0 Out,Lo // SRAM/IO/PCMCIA/FLASH/ROM/LCD Address Bus RAD1 Out,Lo // RAD2 Out,Lo // RAD3 Out,Lo // RAD4 Out,Lo // RAD5 Out,Lo // RAD6 Out,Lo // RAD7 Out,Lo // RAD8 Out,Lo // RAD9 Out,Lo // RAD10 Out,Lo // RAD11 Out,Lo // RAD12 Out,Lo // RAD13 Out,Lo // RAD14 Out,Lo // RAD15 Out,Lo // RAD16 Out,Lo // RAD17 Out,Lo // RAD18 Out,Lo // RAD19 Out,Lo // RAD20 Out,Lo // RAD21 Out,Lo // RAD22 Out,Lo // RAD23 Out,Lo // JTAG_alchemyb.doc 27 AMD Alchemy Solutions Processors RAD24 RAD25 RAD26 RAD27 RAD28 RAD29 RAD30 RAD31 Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Hi Out,Lo Out,Hi // // // // // // // // // Group 552: All pins in this group must be set to the same direction // These pins are bidirectional USBH1P Inp // USBH1M Inp // // Group 546: All pins in this group must be set to the same direction // These pins are bidirectional USBDP Inp // USBH0P USBDM Inp // USBH0M // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. GPIO10 Inp // U3DSR# GPIO11 Inp // U3DCD# GPIO12 Inp // U3RI# S0DOUT Inp // GPIO16 S0CLK Inp // GPIO17 S0DEN Inp // GPIO18 IRDATX Inp // GPIO19 I2SDIO Inp // GPIO29 ACRST# Inp // S1DEN ACSYNC Inp // S1DOUT ACDO Inp // S1CLK I2SCLK Inp // GPIO30 I2SWORD Inp // GPIO31 U0TXD Inp // GPIO20 U1TXD Inp // GPIO21 U2TXD Inp // GPIO22 U3TXD Inp // GPIO23 28 JTAG_alchemyb.doc AMD Alchemy Solutions Processors GPIO13 GPIO14 GPIO15 N0TXEN N0TXD0 N0TXD1 N0TXD2 N0TXD3 N0MDC N0MDIO N1TXEN N1TXD0 N1TXD1 N1TXD2 N1TXD3 N1MDC N1MDIO SDD0 SDD1 SDD2 SDD3 SDD4 SDD5 SDD6 SDD7 SDD8 SDD9 SDD10 SDD11 SDD12 SDD13 SDD14 SDD15 SDD16 SDD17 SDD18 SDD19 SDD20 SDD21 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp JTAG_alchemyb.doc // U3RTS# // U3DTR# // IRFIRSEL // // // // // // // // GPIO24 // GPIO25 // GPIO26 // GPIO27 // GPIO28 // // // SDRAM Data Bus // // // // // // // // // // // // // // // // // // // // // 29 AMD Alchemy Solutions Processors SDD22 SDD23 SDD24 SDD25 SDD26 SDD27 SDD28 SDD29 SDD30 SDD31 SDCLK0 SDCLK1 SDCLK2 GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 PIOW# PIOR# POE# PREG# PCE1# PCE2# PWE# LRD0# LRD1# LWR0# LWR1# RBEN0# RBEN1# RBEN2# RBEN3# RWE# 30 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Out,Lo Out,Lo Out,Lo Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Out,Hi Out,Hi Out,Hi Inp Out,Hi Out,Hi Inp Inp Inp Inp Inp Out,Lo Out,Lo Out,Lo Out,Lo Out,Hi // // // // // // // // // // // // // // // // EXTCLK0 // EXTCLK1 // DMA_REQ0 // DMA_REQ1 // SMROMCKE // // I2SDI // U3CTS# // PCMCIA Write Cycle Indication // PCMCIA Read Cycle Indication // PCMCIA Output Enable // PCMCIA register-only access signal // PCMCIA Card Enable // PCMCIA Card Enable // PCMCIA write enable // LCD Controller Chip Interface read indicator // LCD Controller Chip Interface read indicator // LCD Controller Chip Interface write indicator // LCD Controller Chip Interface write indicator // SRAM/IO/PCMCIA/FLASH/ROM/LCD Byte Enable // // // // SRAM/IO/PCMCIA/FLASH/ROM/LCD Write Enable JTAG_alchemyb.doc AMD Alchemy Solutions Processors ROE# RCS0# RCS1# RCS2# RCS3# Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi // SRAM/IO/PCMCIA/FLASH/ROM/LCD Output Enable // SRAM/IO/PCMCIA/FLASH/ROM/LCD Chip Select // // // // The following pins are output only pins. // Setting to input (tristate) one of these pins results in an error. SDCS0# Out,Hi // Programmable Chip Select SDCS1# Out,Hi // SDCS2# Out,Hi // SDWE# Out,Hi // SDRAM command Output SDRAS# Out,Hi // SDRAM command Output SDCAS# Out,Hi // SDRAM command Output SDCKE Out,Lo // SDRAM Clock enable SDQM0# Out,Hi // SDRAM Byte Mask SDQM1# Out,Hi // SDRAM Byte Mask SDQM2# Out,Hi // SDRAM Byte Mask SDQM3# Out,Hi // SDRAM Byte Mask SDBA0 Out,Lo // SDRAM Bak Address SDBA1 Out,Lo // SDRAM Bak Address SDA0 Out,Lo // SDRAM Address Output SDA1 Out,Lo // SDA2 Out,Lo // SDA3 Out,Lo // SDA4 Out,Lo // SDA5 Out,Lo // SDA6 Out,Lo // SDA7 Out,Lo // SDA8 Out,Lo // SDA9 Out,Lo // SDA10 Out,Lo // SDA11 Out,Lo // SDA12 Out,Lo // RESETOUT# Out,Hi // Buffered Output of CPU Reset Input LCLK Out,Lo // LCD Controller Chip Interface Clock JTAG_alchemyb.doc 31 AMD Alchemy Solutions Processors // The following pins are input only. // Setting to output of one of these pins results in an error. // Declaration of the direction of these pins is optional. U0RXD U1RXD U2RXD IRDARX U3RXD ACDI ACBCLK N0CRS N0RXD0 N0RXD1 N0RXD2 N0RXD3 N0RXCLK N0RXDV N0COL N0TXCLK N1CRS N1RXD0 N1RXD1 N1RXD2 N1RXD3 N1RXCLK N1RXDV N1COL N1TXCLK VDDXOK TESTEN ROMSEL ROMSIZE RESETIN# TC0 TC1 TC2 TC3 PIOS16# 32 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // UART0 receive // UART1 receive // UART2 receive // Serial IrDA input // UART3 receive // AC-Link TDM input stream // S1DIN // // // // // // // // // // // // // // // // // // // VDDX stable // Test Enable, should be pulled low // Boot from ROM or SMROM // ROM width 16 or 32 bit // CPU Reset input // Test Clock Input, should be pulled low // Test Clock Input, should be pulled low // Test Clock Input, should be pulled low // Test Clock Input, should be pulled low // PCMCIA I/O is 16 Bit JTAG_alchemyb.doc AMD Alchemy Solutions Processors PWAIT# LWAIT# EWAIT# Inp Inp Inp JTAG_alchemyb.doc // PCMCIA entend Cycle // LCD Controller Chip Interface Extend Cycle // SRAM/IO/PCMCIA/FLASH/ROM Extend Cycle 33 AMD Alchemy Solutions Processors Sample File JTAu1100.INI: // Description file for AMD Au1100 Target: Generic Target, 2003/10/02 // Adapt this file carefully to your design!! // All chip select signals are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults. // Pin names are defined in upper case. // Low active signals are signed with a trailing #. // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. // During flash programming these pins are switched between // input/inactive and output/active. // For Flash programming and other memory accesses // these pins should be set to Input RD0 Inp // SRAM/IO/PCMCIA/FLASH/ROM/LCD Data Bus RD1 Inp // RD2 Inp // RD3 Inp // RD4 Inp // RD5 Inp // RD6 Inp // RD7 Inp // RD8 Inp // RD9 Inp // RD10 Inp // RD11 Inp // RD12 Inp // RD13 Inp // RD14 Inp // RD15 Inp // RD16 Inp // RD17 Inp // RD18 Inp // RD19 Inp // RD20 Inp // RD21 Inp // 34 JTAG_alchemyb.doc AMD Alchemy Solutions Processors RD22 RD23 RD24 RD25 RD26 RD27 RD28 RD29 RD30 RD31 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // // // // // // // // // // // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. // For Flash Programming these pins must be set to output RAD0 Out,Lo // SRAM/IO/PCMCIA/FLASH/ROM/LCD Address Bus RAD1 Out,Lo // RAD2 Out,Lo // RAD3 Out,Lo // RAD4 Out,Lo // RAD5 Out,Lo // RAD6 Out,Lo // RAD7 Out,Lo // RAD8 Out,Lo // RAD9 Out,Lo // RAD10 Out,Lo // RAD11 Out,Lo // RAD12 Out,Lo // RAD13 Out,Lo // RAD14 Out,Lo // RAD15 Out,Lo // RAD16 Out,Lo // RAD17 Out,Lo // RAD18 Out,Lo // RAD19 Out,Lo // RAD20 Out,Lo // RAD21 Out,Lo // RAD22 Out,Lo // RAD23 Out,Lo // JTAG_alchemyb.doc 35 AMD Alchemy Solutions Processors RAD24 RAD25 RAD26 RAD27 RAD28 RAD29 RAD30 RAD31 Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Hi Out,Lo Out,Hi // // // // // // // // // Group 666: All pins in this group must be set to the same direction // These pins are bidirectional USBH1P Inp // USBH1M Inp // // Group 659: All pins in this group must be set to the same direction // These pins are bidirectional USBDP Inp // USBDM Inp // // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. GPIO10 Inp // U3DSR# GPIO11 Inp // U3DCD# GPIO12 Inp // U3RI# S0DOUT Inp // GPIO208 S0CLK Inp // GPIO209 S0DEN Inp // GPIO210 IRDATX Inp // GPIO211 I2SDIO Inp // GPIO29 ACRST# Inp // S1DEN# ACSYNC Inp // S1DOUT ACDO Inp // S1CLK I2SCLK Inp // GPIO30 I2SWORD Inp // GPIO31 U0TXD Inp // GPIO212 U1TXD Inp // GPIO213 U3TXD Inp // GPIO214 GPIO13 Inp // U3RTS# 36 JTAG_alchemyb.doc AMD Alchemy Solutions Processors GPIO14 GPIO15 N0TXEN N0TXD0 N0TXD1 N0TXD2 N0TXD3 N0MDC N0MDIO GPIO16 GPIO17 GPIO18 GPIO19 GPIO20 GPIO21 GPIO22 GPIO23 RESVD_3 LCD_PWM0 LCD_PWM1 SDMS0_CLK SDMS0_CMD SDMS0_DAT0 SDMS0_DAT1 SDMS0_DAT2 SDMS0_DAT3 SDMS1_CLK SDMS1_CMD SDMS1_DAT0 SDMS1_DAT1 SDMS1_DAT2 SDMS1_DAT3 SDD0 SDD1 SDD2 SDD3 SDD4 SDD5 SDD6 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Out,Lo Inp Inp Inp Inp Inp Out,Lo Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp JTAG_alchemyb.doc // U3DTR# // IRFIRSEL // GPIO24 // GPIO25 // GPIO26 // GPIO27 // GPIO28 // GPIO215 // // // // // // // // // // Reserved, should be left open // Pulse Width Modulation Clock 0 // Pulse Width Modulation Clock 1 // SD Card 0 Interface Clock // SD Card 0 Half Duplex Command and Response // SD Card 0 Data Bus // SD Card 0 Data Bus // SD Card 0 Data Bus // SD Card 0 Data Bus // SD Card 1 Interface Clock // SD Card 1 Half Duplex Command and Response // SD Card 1 Data Bus // SD Card 1 Data Bus // SD Card 1 Data Bus // SD Card 1 Data Bus // SDRAM Data Bus // // // // // // 37 AMD Alchemy Solutions Processors SDD7 SDD8 SDD9 SDD10 SDD11 SDD12 SDD13 SDD14 SDD15 SDD16 SDD17 SDD18 SDD19 SDD20 SDD21 SDD22 SDD23 SDD24 SDD25 SDD26 SDD27 SDD28 SDD29 SDD30 SDD31 SDCLK0 SDCLK1 SDCLK2 GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 PIOW# 38 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Out,Lo Out,Lo Out,Lo Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Out,Hi // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // EXTCLK0 // EXTCLK1 // DMA_REQ0 // DMA_REQ1 // SMROMCKE // // I2SDI // U3CTS# // PCMCIA Write Cycle Indication JTAG_alchemyb.doc AMD Alchemy Solutions Processors PIOR# POE# PREG# PCE1# PCE2# PWE# LRD0# LRD1# LWR0# LWR1# RBEN0# RBEN1# RBEN2# RBEN3# RWE# ROE# RCS0# RCS1# RCS2# RCS3# LCD_D0 LCD_D1 LCD_D2 LCD_D3 LCD_D4 LCD_D5 LCD_D6 LCD_D7 LCD_D8 LCD_D9 LCD_D10 LCD_D11 LCD_D12 LCD_D13 LCD_D14 LCD_D15 LCD_LCK LCD_FCK LCD_BIAS Out,Hi Out,Hi Inp Out,Hi Out,Hi Inp Inp Inp Inp Inp Out,Lo Out,Lo Out,Lo Out,Lo Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo JTAG_alchemyb.doc // PCMCIA Read Cycle Indication // PCMCIA Output Enable // GPIO204 // GPIO205 // GPIO206 // GPIO207 // GPIO200 // GPIO201 // GPIO202 // GPIO203 // SRAM/IO/PCMCIA/FLASH/ROM/LCD Byte Enable // // // // SRAM/IO/PCMCIA/FLASH/ROM/LCD Write Enable // SRAM/IO/PCMCIA/FLASH/ROM/LCD Output Enable // SRAM/IO/PCMCIA/FLASH/ROM/LCD Chip Select // // // // LCD Data Output // // // // // // // // // // // // // // // // LCD Line Clock // LCD Frame Clock // LCD Bias Clock 39 AMD Alchemy Solutions Processors LCD_LEND Out,Lo // LCD Line End // The following pins are output only pins. // Setting to input (tristate) one of these pins results in an error. SDCS0# Out,Hi // Programmable Chip Select SDCS1# Out,Hi // SDCS2# Out,Hi // SDWE# Out,Hi // SDRAM command Output SDRAS# Out,Hi // SDRAM command Output SDCAS# Out,Hi // SDRAM command Output SDCKE Out,Lo // SDRAM Clock enable SDQM0# Out,Hi // SDRAM Byte Mask SDQM1# Out,Hi // SDRAM Byte Mask SDQM2# Out,Hi // SDRAM Byte Mask SDQM3# Out,Hi // SDRAM Byte Mask SDBA0 Out,Lo // SDRAM Bak Address SDBA1 Out,Lo // SDRAM Bak Address SDA0 Out,Lo // SDRAM Address Output SDA1 Out,Lo // SDA2 Out,Lo // SDA3 Out,Lo // SDA4 Out,Lo // SDA5 Out,Lo // SDA6 Out,Lo // SDA7 Out,Lo // SDA8 Out,Lo // SDA9 Out,Lo // SDA10 Out,Lo // SDA11 Out,Lo // SDA12 Out,Lo // RESETOUT# Out,Hi // Buffered Output of CPU Reset Input LCLK Out,Lo // LCD Controller Chip Interface Clock LCD_PCK Out,Lo // LCD Pixel Clock // The following pins are input only. // Setting to output of one of these pins results in an error. // Declaration of the direction of these pins is optional. U0RXD Inp // UART0 receive U1RXD Inp // UART1 receive 40 JTAG_alchemyb.doc AMD Alchemy Solutions Processors IRDARX U3RXD ACDI ACBCLK N0CRS N0RXD0 N0RXD1 N0RXD2 N0RXD3 N0RXCLK N0RXDV N0COL N0TXCLK RESVD_0 RESVD_1 RESVD_2 RESVD_4 RESVD_5 VSEL TESTEN ROMSEL ROMSIZE RESETIN# TC0 TC1 TC2 TC3 PIOS16# PWAIT# LWAIT# EWAIT# Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp JTAG_alchemyb.doc // Serial IrDA input // UART3 receive // AC-Link TDM input stream // S1DIN // // // // // // // // // // Reserved, should be pulled low // Reserved, should be pulled low // Reserved, should be pulled low // Reserved, should be pulled low // Reserved, should be pulled low // External SDRAM Voltage Type: 0=2.5V, 1=3.3V // Test Enable, should be pulled low // Boot from ROM or SMROM // ROM width 16 or 32 bit // CPU Reset input // Test Clock Input, should be pulled low // Test Clock Input, should be pulled low // Test Clock Input, should be pulled low // Test Clock Input, should be pulled low // PCMCIA I/O is 16 Bit // PCMCIA entend Cycle // LCD Controller Chip Interface Extend Cycle // SRAM/IO/PCMCIA/FLASH/ROM Extend Cycle 41 AMD Alchemy Solutions Processors Sample File JTAu1500.INI: // Description file for AMD Alchemy Solutions Au1500 Processor Target: Generic Target, 2003/10/02 // Adapt this file carefully to your design!! // All chip select signals are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults. // Pin names are defined in upper case. // Low active signals are signed with a trailing #. // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. // During flash programming these pins are switched between // input/inactive and output/active. // For Flash programming and other memory accesses // these pins should be set to Input RD0 Inp // SRAM/IO/PCMCIA/FLASH/ROM/LCD Data Bus RD1 Inp // RD2 Inp // RD3 Inp // RD4 Inp // RD5 Inp // RD6 Inp // RD7 Inp // RD8 Inp // RD9 Inp // RD10 Inp // RD11 Inp // RD12 Inp // RD13 Inp // RD14 Inp // RD15 Inp // RD16 Inp // RD17 Inp // RD18 Inp // RD19 Inp // RD20 Inp // RD21 Inp // 42 JTAG_alchemyb.doc AMD Alchemy Solutions Processors RD22 RD23 RD24 RD25 RD26 RD27 RD28 RD29 RD30 RD31 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // // // // // // // // // // // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. // For Flash Programming these pins must be set to output RAD0 Out,Lo // SRAM/IO/PCMCIA/FLASH/ROM/LCD Address Bus RAD1 Out,Lo // RAD2 Out,Lo // RAD3 Out,Lo // RAD4 Out,Lo // RAD5 Out,Lo // RAD6 Out,Lo // RAD7 Out,Lo // RAD8 Out,Lo // RAD9 Out,Lo // RAD10 Out,Lo // RAD11 Out,Lo // RAD12 Out,Lo // RAD13 Out,Lo // RAD14 Out,Lo // RAD15 Out,Lo // RAD16 Out,Lo // RAD17 Out,Lo // RAD18 Out,Lo // RAD19 Out,Lo // RAD20 Out,Lo // RAD21 Out,Lo // RAD22 Out,Lo // RAD23 Out,Lo // JTAG_alchemyb.doc 43 AMD Alchemy Solutions Processors RAD24 RAD25 RAD26 RAD27 RAD28 RAD29 RAD30 RAD31 Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Hi Out,Lo Out,Hi // // // // // // // // // Group 151: All pins in this group must be set to the same direction // These pins are bidirectional USBH1P Inp // USBH1M Inp // // Group 146: All pins in this group must be set to the same direction // These pins are bidirectional USBDP Inp // USBDM Inp // // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. GPIO10 Inp // U3DSR# GPIO11 Inp // U3DCD# GPIO12 Inp // U3RI# GPIO200 Inp // PCI_RSTO# GPIO201 Inp // GPIO202 Inp // GPIO203 Inp // GPIO204 Inp // GPIO205 Inp // GPIO206 Inp // GPIO207 Inp // GPIO208 Inp // DMA_REQ2 GPIO209 Inp // DMA_REQ3 GPIO210 Inp // GPIO211 Inp // GPIO212 Inp // GPIO213 Inp // 44 JTAG_alchemyb.doc AMD Alchemy Solutions Processors GPIO214 GPIO215 ACRST# ACSYNC ACDO U0TXD U3TXD GPIO13 GPIO14 GPIO15 N0TXEN N0TXD0 N0TXD1 N0TXD2 N0TXD3 N0MDC N0MDIO N1TXEN N1TXD0 N1TXD1 N1TXD2 N1TXD3 N1MDC N1MDIO SDD0 SDD1 SDD2 SDD3 SDD4 SDD5 SDD6 SDD7 SDD8 SDD9 SDD10 SDD11 SDD12 SDD13 SDD14 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp JTAG_alchemyb.doc // // // AC-Link CODEC reset // AC-Link fixed rate sample sync // AC-Link TDM output stream // GPIO20 // GPIO23 // U3RTS# // U3DTR# // // // // // // // // // // // // // // // // SDRAM Data Bus // // // // // // // // // // // // // // 45 AMD Alchemy Solutions Processors SDD15 SDD16 SDD17 SDD18 SDD19 SDD20 SDD21 SDD22 SDD23 SDD24 SDD25 SDD26 SDD27 SDD28 SDD29 SDD30 SDD31 SDCLK0 SDCLK1 SDCLK2 GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 PIOW# PIOR# POE# PREG# PCE1# PCE2# PWE# LRD0# LRD1# 46 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Out,Lo Out,Lo Out,Lo Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi // // // // // // // // // // // // // // // // // // // // // // // EXTCLK0 // EXTCLK1 // DMA_REQ0 // DMA_REQ1 // SMROMCKE // // // U3CTS# // PCMCIA Write Cycle Indication // PCMCIA Read Cycle Indication // PCMCIA Output Enable // PCMCIA register-only access signal // PCMCIA card enable // PCMCIA card enable // PCMCIA write enable // LCD controller chip interface read indicator // LCD controller chip interface read indicator JTAG_alchemyb.doc AMD Alchemy Solutions Processors LWR0# LWR1# RBEN0# RBEN1# RBEN2# RBEN3# RWE# ROE# RCS0# RCS1# RCS2# RCS3# PCI_DEVSEL# PCI_STOP# PCI_FRAME# PCI_IRDY# PCI_TRDY# PCI_PAR PCI_GNT0# PCI_GNT1# PCI_GNT2# PCI_GNT3# PCI_PERR# PCI_SERR# PCI_AD0 PCI_AD1 PCI_AD2 PCI_AD3 PCI_AD4 PCI_AD5 PCI_AD6 PCI_AD7 PCI_AD8 PCI_AD9 PCI_AD10 PCI_AD11 PCI_AD12 PCI_AD13 PCI_AD14 Out,Hi Out,Hi Out,Lo Out,Lo Out,Lo Out,Lo Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp JTAG_alchemyb.doc // LCD controller chip interface write indicator // LCD controller chip interface write indicator // SRAM/IO/PCMCIA/FLASH/ROM/LCD Byte Enable // // // // SRAM/IO/PCMCIA/FLASH/ROM/LCD Write Enable // SRAM/IO/PCMCIA/FLASH/ROM/LCD Output Enable // SRAM/IO/PCMCIA/FLASH/ROM/LCD Chip Select // // // // PCI device select // PCI target stop // PCI frame // PCI initiator ready // PCI target ready // PCI parity // PCI arbiter bus grant output // PCI arbiter bus grant output // PCI arbiter bus grant output // PCI arbiter bus grant output // PCI parity error // PCI system error // PCI address/data // // // // // // // // // // // // // // 47 AMD Alchemy Solutions Processors PCI_AD15 PCI_AD16 PCI_AD17 PCI_AD18 PCI_AD19 PCI_AD20 PCI_AD21 PCI_AD22 PCI_AD23 PCI_AD24 PCI_AD25 PCI_AD26 PCI_AD27 PCI_AD28 PCI_AD29 PCI_AD30 PCI_AD31 PCI_CBE0# PCI_CBE1# PCI_CBE2# PCI_CBE3# Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // // // // // // // // // // // // // // // // // // PCI bus command and byte enable // // // // The following pins are output only pins. // Setting to input (tristate) one of these pins results in an error. SDCS0# Out,Hi // SDRAM Programmable Chip Select SDCS1# Out,Hi // SDCS2# Out,Hi // SDWE# Out,Hi // SDRAM command Output SDRAS# Out,Hi // SDRAM command Output SDCAS# Out,Hi // SDRAM command Output SDCKE Out,Lo // SDRAM Clock enable SDQM0# Out,Hi // SDRAM Byte Mask SDQM1# Out,Hi // SDRAM Byte Mask SDQM2# Out,Hi // SDRAM Byte Mask SDQM3# Out,Hi // SDRAM Byte Mask SDBA0 Out,Lo // SDRAM Bank Address SDBA1 Out,Lo // SDRAM Bank Address SDA0 Out,Lo // SDRAM Address Output SDA1 Out,Lo // 48 JTAG_alchemyb.doc AMD Alchemy Solutions Processors SDA2 SDA3 SDA4 SDA5 SDA6 SDA7 SDA8 SDA9 SDA10 SDA11 SDA12 RESETOUT# LCLK PCI_CLKO Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Hi Out,Lo Out,Lo // // // // // // // // // // // // Buffered Output of CPU Reset Input // LCD Controller Chip Interface Clock // PCI clock output // The following pins are input only. // Setting to output of one of these pins results in an error. // Declaration of the direction of these pins is optional. U0RXD Inp // UART0 receive U3RXD Inp // UART3 receive PCI_LOCK# Inp // PCI lock fopr atomic operations PCI_CLK Inp // PCI input clock PCI_REQ0# Inp // PCI arbiter bus request input PCI_REQ1# Inp // PCI arbiter bus request input PCI_REQ2# Inp // PCI arbiter bus request input PCI_REQ3# Inp // PCI arbiter bus request input PCI_CFG Inp // PCI configuration, 0->sattelite mode, 1->host mode PCI_IDSEL Inp // PCI initialization device select input PCI_INTA# Inp // PCI interrupt input PCI_INTB# Inp // PCI interrupt input PCI_INTC# Inp // PCI interrupt input PCI_INTD# Inp // PCI interrupt input PCI_RST# Inp // PCI reset input ACDI Inp // AC-Link TDM input stream ACBCLK Inp // AC-Link serial data clock N0CRS Inp // N0RXD0 Inp // N0RXD1 Inp // N0RXD2 Inp // JTAG_alchemyb.doc 49 AMD Alchemy Solutions Processors N0RXD3 N0RXCLK N0RXDV N0COL N0TXCLK N1CRS N1RXD0 N1RXD1 N1RXD2 N1RXD3 N1RXCLK N1RXDV N1COL N1TXCLK VDDXOK TESTEN ROMSEL ROMSIZE RESETIN# TC0 TC1 TC2 TC3 PIOS16# PWAIT# LWAIT# EWAIT# 50 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // // // // // // // // // // // // // // // VDDX stable // Test enable, should be pulled low // Boot from ROM or SMROM // ROM width 16 or 32 bit // CPU Reset input // Test Clock Input, should be pulled low // Test Clock Input, should be pulled low // Test Clock Input, should be pulled low // Test Clock Input, should be pulled low // PCMCIA I/O is 16 Bit // PCMCIA entend Cycle // LCD Controller Chip Interface Extend Cycle // SRAM/IO/Flash/ROM Extend Cycle JTAG_alchemyb.doc AMD Alchemy Solutions Processors Sample File JTAu1550.INI: // Description file for AMD Alchemy Solutions Au1550 Processor Target: Generic Target, 2004/11/19 // Adapt this file carefully to your design!! // All chip select signals are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults. // Pin names are defined in upper case. // Low active signals are signed with a trailing #. // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. // During flash programming these pins are switched between // input/inactive and output/active. // For Flash programming and other memory accesses // these pins should be set to Input RD0 Inp // SRAM/IO/PCMCIA/FLASH/ROM/NAND Data Bus RD1 Inp // RD2 Inp // RD3 Inp // RD4 Inp // RD5 Inp // RD6 Inp // RD7 Inp // RD8 Inp // RD9 Inp // RD10 Inp // RD11 Inp // RD12 Inp // RD13 Inp // RD14 Inp // RD15 Inp // RD16 Inp // RD17 Inp // RD18 Inp // RD19 Inp // RD20 Inp // RD21 Inp // RD22 Inp // RD23 Inp // RD24 Inp // RD25 Inp // JTAG_alchemyb.doc 51 AMD Alchemy Solutions Processors RD26 RD27 RD28 RD29 RD30 RD31 Inp Inp Inp Inp Inp Inp // // // // // // // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. // For Flash Programming these pins must be set to output RAD0 Out,Lo // SRAM/IO/PCMCIA/FLASH/ROM/NAND Address Bus RAD1 Out,Lo // RAD2 Out,Lo // RAD3 Out,Lo // RAD4 Out,Lo // RAD5 Out,Lo // RAD6 Out,Lo // RAD7 Out,Lo // RAD8 Out,Lo // RAD9 Out,Lo // RAD10 Out,Lo // RAD11 Out,Lo // RAD12 Out,Lo // RAD13 Out,Lo // RAD14 Out,Lo // RAD15 Out,Lo // RAD16 Out,Lo // RAD17 Out,Lo // RAD18 Out,Lo // RAD19 Out,Lo // RAD20 Out,Lo // RAD21 Out,Lo // RAD22 Out,Lo // RAD23 Out,Lo // RAD24 Out,Lo // RAD25 Out,Lo // RAD26 Out,Lo // RAD27 Out,Lo // RAD28 Out,Lo // // Group 765: All pins in this group must be set to the same direction // These pins are bidirectional 52 JTAG_alchemyb.doc AMD Alchemy Solutions Processors USBH0P USBH0M Inp Inp // // // Group 760: All pins in this group must be set to the same direction // These pins are bidirectional USBH1P Inp // USBH1M Inp // // Group 770: All pins in this group must be set to the same direction // These pins are bidirectional USBDP Inp // USBDM Inp // // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as an input. GPIO200 Inp // PCI_RSTO# GPIO201 Inp // PSC0_EXTCLK GPIO202 Inp // PSC1_EXTCLK GPIO203 Inp // PSC2_EXTCLK GPIO204 Inp // PSC3_EXTCLK GPIO205 Inp // GPIO206 Inp // PSC2_SYNC1 GPIO207 Inp // PSC2_SYNC0 GPIO208 Inp // PSC2_D1/DMA_REQ2 GPIO209 Inp // PSC2_D0/DMA_REQ3 GPIO210 Inp // PSC2_CLK GPIO211 Inp // PSC3_SYNC1 GPIO212 Inp // PSC3_SYNC0 GPIO213 Inp // PSC3_D1 GPIO214 Inp // PSC3_D0 GPIO215 Inp // PSC3_CLK U0TXD Inp // GPIO20 U1TXD Inp // GPIO21 U1RTS# Inp // GPIO22 U3TXD Inp // GPIO23 N0TXEN Inp // N0TXD0 Inp // N0TXD1 Inp // N0TXD2 Inp // N0TXD3 Inp // N0MDC Inp // N0MDIO Inp // JTAG_alchemyb.doc 53 AMD Alchemy Solutions Processors N1TXEN N1TXD0 N1TXD1 N1TXD2 N1TXD3 N1MDC N1MDIO DDQ0 DDQ1 DDQ2 DDQ3 DDQ4 DDQ5 DDQ6 DDQ7 DDQ8 DDQ9 DDQ10 DDQ11 DDQ12 DDQ13 DDQ14 DDQ15 DDQ16 DDQ17 DDQ18 DDQ19 DDQ20 DDQ21 DDQ22 DDQ23 DDQ24 DDQ25 DDQ26 DDQ27 DDQ28 DDQ29 DDQ30 DDQ31 DDQS0 DDQS1 DDQS2 DDQS3 54 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // GPIO24 // GPIO25 // GPIO26 // GPIO27 // GPIO28 // // // SDRAM Data Bus // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // DDR SDRAM Strobe // // // JTAG_alchemyb.doc AMD Alchemy Solutions Processors GPIO0 GPIO1 GPIO2 GPIO3 GPIO4 GPIO5 GPIO6 GPIO7 GPIO8 GPIO9 GPIO10 GPIO11 GPIO12 GPIO13 GPIO14 GPIO15 PIOW# PIOR# POE# PREG# PCE1# PCE2# PWE# RBEN0# RBEN1# RBEN2# RBEN3# RWE# ROE# RCS0# RCS1# RCS2# RCS3# RALE RCLE PCI_DEVSEL# PCI_STOP# PCI_FRAME# PCI_IRDY# PCI_TRDY# PCI_PAR PCI_GNT0# PCI_GNT1# Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Lo Out,Lo Out,Lo Out,Lo Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Hi Out,Lo Out,Lo Inp Inp Inp Inp Inp Inp Inp Inp JTAG_alchemyb.doc // // // EXTCLK0 // EXTCLK1 // DMA_REQ0 // DMA_REQ1 // SMROMCKE // // // U3CTS# // U3DSR# // U3DCD# // U3RI# // U3RTS# // U3DTR# // // PCMCIA Write Cycle Indication // PCMCIA Read Cycle Indication // PCMCIA Output Enable // PCMCIA register-only access signal // PCMCIA card enable // PCMCIA card enable // PCMCIA write enable // SRAM/IO/PCMCIA/FLASH/ROM/NAND Byte Enable // // // // SRAM/IO/PCMCIA/FLASH/ROM/NAND Write Enable // SRAM/IO/PCMCIA/FLASH/ROM/NAND Output Enable // SRAM/IO/PCMCIA/FLASH/ROM/NAND Chip Select // // // // NAND Address Latch Enable // NAND Command Latch Enable // PCI device select // PCI target stop // PCI frame // PCI initiator ready // PCI target ready // PCI parity // PCI arbiter bus grant output // PCI arbiter bus grant output 55 AMD Alchemy Solutions Processors PCI_GNT2# PCI_GNT3# PCI_PERR# PCI_SERR# PCI_AD0 PCI_AD1 PCI_AD2 PCI_AD3 PCI_AD4 PCI_AD5 PCI_AD6 PCI_AD7 PCI_AD8 PCI_AD9 PCI_AD10 PCI_AD11 PCI_AD12 PCI_AD13 PCI_AD14 PCI_AD15 PCI_AD16 PCI_AD17 PCI_AD18 PCI_AD19 PCI_AD20 PCI_AD21 PCI_AD22 PCI_AD23 PCI_AD24 PCI_AD25 PCI_AD26 PCI_AD27 PCI_AD28 PCI_AD29 PCI_AD30 PCI_AD31 PCI_CBE0# PCI_CBE1# PCI_CBE2# PCI_CBE3# PSC0_CLK PSC0_SYNC0 PSC0_SYNC1 56 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // PCI arbiter bus grant output // PCI arbiter bus grant output // PCI parity error // PCI system error // PCI address/data // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // // PCI bus command and byte enable // // // // PSC0 clock // // GPIO16 JTAG_alchemyb.doc AMD Alchemy Solutions Processors PSC0_D0 PSC0_D1 PSC1_CLK PSC1_SYNC0 PSC1_SYNC1 PSC1_D0 PSC1_D1 Inp Inp Inp Inp Inp Inp Inp // // // PSC0 clock // // GPIO17 // // // The following pins are output only pins. // Setting to input (tristate) one of these pins results in an error. RESETOUT# Out,Hi // Buffered Output of CPU Reset Input DA0 Out,Lo // SDRAM Address Output DA1 Out,Lo // DA2 Out,Lo // DA3 Out,Lo // DA4 Out,Lo // DA5 Out,Lo // DA6 Out,Lo // DA7 Out,Lo // DA8 Out,Lo // DA9 Out,Lo // DA10 Out,Lo // DA11 Out,Lo // DA12 Out,Lo // DA13 Out,Lo // DBA0 Out,Lo // SDRAM Bank Address DBA1 Out,Lo // SDRAM Bank Address DCS0# Out,Hi // SDRAM Programmable Chip Select DCS1# Out,Hi // DCS2# Out,Hi // DCK0 Out,Lo // DCK0# Out,Lo // DCK1 Out,Lo // DCK1# Out,Lo // DCKE Out,Lo // SDRAM Clock enable DRAS# Out,Hi // SDRAM command Output DCAS# Out,Hi // SDRAM command Output DWE# Out,Hi // SDRAM command Output DDM0 Out,Hi // SDRAM Byte Mask DDM1 Out,Hi // SDRAM Byte Mask DDM2 Out,Hi // SDRAM Byte Mask DDM3 Out,Hi // SDRAM Byte Mask RCLK Out,Lo // Bus clock output for synchrous mode JTAG_alchemyb.doc 57 AMD Alchemy Solutions Processors PCI_CLKO Out,Lo // PCI clock output // The following pins are input only. // Setting to output of one of these pins results in an error. // Declaration of the direction of these pins is optional. DRVSEL Inp // SDRAM drive strength select U0RXD Inp // UART0 receive U1RXD Inp // UART1 receive U1CTS# Inp // UART1 CTS U3RXD Inp // UART3 receive PCI_LOCK# Inp // PCI lock fopr atomic operations PCI_CLK Inp // PCI input clock PCI_REQ0# Inp // PCI arbiter bus request input PCI_REQ1# Inp // PCI arbiter bus request input PCI_REQ2# Inp // PCI arbiter bus request input PCI_REQ3# Inp // PCI arbiter bus request input PCI_CFG Inp // PCI configuration, 0->sattelite mode, 1->host mode PCI_IDSEL Inp // PCI initialization device select input PCI_INTA# Inp // PCI interrupt input PCI_INTB# Inp // PCI interrupt input PCI_INTC# Inp // PCI interrupt input PCI_INTD# Inp // PCI interrupt input PCI_RST# Inp // PCI reset input N0CRS Inp // N0RXD0 Inp // N0RXD1 Inp // N0RXD2 Inp // N0RXD3 Inp // N0RXCLK Inp // N0RXDV Inp // N0COL Inp // N0TXCLK Inp // N1CRS Inp // N1RXD0 Inp // N1RXD1 Inp // N1RXD2 Inp // N1RXD3 Inp // N1RXCLK Inp // N1RXDV Inp // N1COL Inp // N1TXCLK Inp // VDDXOK Inp // VDDX stable WAKE# Inp // Wake from hibernate request 58 JTAG_alchemyb.doc AMD Alchemy Solutions Processors FWTOY# BOOT0 BOOT1 BOOT2 RESETIN# TESTEN TC0 TC1 TC2 TC3 PIOS16# PWAIT# EWAIT# R/B# Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp JTAG_alchemyb.doc // Firewall the TOY clock signal // Boot Memory Select // // // CPU Reset input // Test enable, should be pulled low // Test Clock Input, should be pulled low // Test Clock Input, should be pulled low // Test Clock Input, should be pulled low // Test Clock Input, should be pulled low // PCMCIA I/O is 16 Bit // PCMCIA extend Cycle // SRAM/IO/Flash/ROM Extend Cycle // NAND Ready/not Busy 59 AMD Alchemy Solutions Processors 1.12. Supported flash devices Type JTAuxxxx /LIST [optionlist] to get a online list of all flash types which could be used with the /DEVICE= option. See separate file JTAG_V4xx_FLASHES.pdf to get a complete list of supported flash types. 60 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 2. JTAuxxxx Parameter Description When you start JTAuxxxx.EXE without any parameters the following help screen with all possible functions and options is displayed: JTAuxxxx --- JTAG utility for AMD Alchemy Solutions Processors Copyright © FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy Programming of Flash-EPROMs and hardware tests on targets with the AMD Alchemy Solutions Processors. The JTAG-Booster is needed to connect the parallel port of the PC to the JTAG port of the AMD Alchemy Solutions Processors. Usage: JTAuxxxx /function [filename] [/option_1] ... [/option_n] Supported functions: /P : Program a Flash Device /R : Read a Flash Device to file /V : Verify a Flash Device with file /DUMP : Make a target dump /PSER : Program a I2C/SPI/MicroWire Device with file /RSER : Read a I2C/SPI/MicroWire Device to file /VSER : Verify a I2C/SPI/MicroWire Device with file /DUMPSER : Make a dump of a I2C/SPI/MicroWire Device /BLINK : Toggle a CPU pin /PIN? : Test a CPU pin /SAMPLE : Test a CPU pin while the CPU is running /SNAP : Test all CPU pins while CPU is running /LIST : Print a list of supported Flash devices JTAG_alchemyb.doc 61 AMD Alchemy Solutions Processors Supported Options: /CS0 /CS1 /CS2 /NOCS /NOWRSETUP /TOP /CFI /CFIDEBUG /PAUSE /NOERASE /ERASEALL /LATTICE /LPT3 /LPT-BASE= /32BIT /NOMAN /LENGTH= /L= /OFFSET= /O= /DELAY= /DRIVER= /IROFFS= /CPUPOS= /SERCS= /SERCLK= /SERDAT= /SERBUFF= /SERBIG /SPI /SPIERA /WATCH= /OUT= /CS3 /BYTE-MODE /P /LPT1 /16BIT /FILE-OFFSET= /DEVICE-BASE= /DEVICE= /SERDATI= /MWIRE /INI= /BIG /BM /NODUMP /LPT2 /8BIT /FO= /DB= /PIN= /SERDATO= /LSB1ST /REP The following options are valid for most functions: /BIG This option switches the byte ordering to big endian mode. This option must fit to the target's endianess Default: Little Endian /DRIVER=x with x = 1,2,3,4 A driver for the interface to the JTAG-BOOSTER on the parallel port may be specified. /DRIVER=1 selects the fastest available driver, /DRIVER=4 selects the slowest one. Use a slower driver if there are problems with JTAG-BOOSTER. Default: /DRIVER=3 /INI=file An initialization file may be specified. By default the current directory is searched for the file JTAuxxxx.INI. If this file is not found and no initialization file is specified in the command line, default initialization values are used (see also chapter 1.11 “Initialization file JTAuxxxx.INI”). Note: The initialization file is not loaded for the functions /SAMPLE (chapter 2.11) and /SNAP (chapter 2.12). Default: /INI=JTAuxxxx.INI /LATTICE For demonstration purposes this software works with the Lattice ispLSI-Adapter, too. With the option /LATTICE you can simulate the speed achievable with the simple ispLSI-Adapter. 62 JTAG_alchemyb.doc AMD Alchemy Solutions Processors /LPT1 /LPT2 /LPT3 A printer port may be specified where the JTAG-Booster resides. If you are using this program with WinNT, Win2000 or WinXP you must specify /LPT2 or /LPTBASE=378 to get access to the standard printer port. Default: /LPT1 /LPT-BASE The physical I/O-Address of printer port may be specified instead of the logical printer name. Useful option, if you work with WinNT, Win2000 or WinXP, because the standard printer port is mapped as LPT2 here. Use the option /LPT-BASE=378 to get a command line which works independent of the operating system. /OUT=file_or_device All screen outputs are redirected to the specified file or device. Note that you can't redirect to the same parallel port where the JTAG-Booster resides. Default: /OUT=CON /PAUSE With the option /PAUSE you can force the program to stop after each screen. Please do not use this option if you redirect the output to a file. Abbreviation: /P /WATCH= With the option /WATCH= a pin can be specified, which is toggled twice per second, while the program is active. This pin may be the trigger of a watchdog. This pin must be specified as output in the initialization file. /IROFFS= Specifies the position of the AMD Alchemy Solutions Processors instruction register within the JTAG chain. In most cases this option is not needed. Default: /IROFFS=0 /CPUPOS= Specifies the position of the AMD Alchemy Solutions Processors within the JTAG chain. Default: /CPUPOS=0 JTAG_alchemyb.doc 63 AMD Alchemy Solutions Processors 2.1. Program a Flash Device Usage: JTAuxxxx /P filename [optionlist] The specified file is programmed into the flash memory. The flash status is polled after programming of each cell (cell=8, 16 or 32 bit, depending on current data bus width). In case of a programming error, the contents of the flash memory is written to a file with the extension DMP. If you want a complete verify after programming, please use an additional command line with the verify function. See chapter 2.3 “Verify a Flash Device with file”. In most cases this additional verify step is not needed. The type of the flash device is normally detected by the software. When autodetection fails you should use the /DEVICE= option together with /8BIT or /16BIT or /32BIT to set the right flash device and configuration. The known flash devices are shown in chapter 1.12 “Supported flash devices”. Use the option /CFI if the flash is not in the list of know devices. Options: /DEVICE=devicename The flash device is detected automatically by switching to autoselect mode. In case of trouble you should select the flash device by using this parameter to avoid autodetection. Combine this option with one of the following options which specify the data bus width and the option /BYTE-MODE if applicable. 64 JTAG_alchemyb.doc AMD Alchemy Solutions Processors /CFI To be prepared for future flash chips, the JTAG-Booster integrates support for flashes which contain the CFI (Common Flash Interface) information structure. The CFI support is activated by simply adding the option /CFI to the command line. The JTAG-Booster then automatically searches in all available bus widths for all possible flash types and configurations instead of searching for the JEDEC identification code. In case of an error add the command line option /CFIDEBUG and redirect the program output into a file. Sending us this file helps in solving problems. /8BIT /16BIT /32BIT Specifies the data bus width to the target flash device. You can speed up autodetection, if you specify the correct data bus size. You need this option together with the option /DEVICE= to explicit specify a specific flash configuration. /BYTE-MODE If there is a flash device connected to the CPU which does have a byte mode pin (8 bit and 16/32 bit bus mode), you can force it to be used as 8 bit mode with the option /BYTE-MODE. In most cases this option will not be needed. Abbreviation: /BM /NOMAN If you use a flash device which is identical to one of the supported parts, but is from a different manufacturer, with this option you can suppress the comparison of the manufacturer identification code. We recommend to use this option together with the /DEVICE= option to avoid failures in autodetection. /DEVICE-BASE=hhhhhh1 Here you can specify a flash device starting address. In most cases, where the flash device is selected with one of the CPUs chip select pins, this parameter is not needed. But if there is any decoding logic in your hardware, this option will be needed. Especially, if there are several flash banks connected to one chip select and a sub decoding logic generates chip selects for these flash banks, this option can be used to select a specific flash bank. Default: /DEVICE-BASE=0 Abbreviation: /DB= 1 hhhhhh=number base is hex JTAG_alchemyb.doc 65 AMD Alchemy Solutions Processors /OFFSET=hhhhhh The programming starts at an offset of hhhhhh relative to the start address of the flash device. If the offset is negative, the offset specifies an address relative to the end of the flash device. See also option /TOP Default: /OFFSET=0 Abbreviation: /O= /TOP If the option /TOP is used the option /OFFSET= specifies the address where the programming ends (plus one) instead of the starting address. This option is very important for Intel CPU architectures, because target execution always starts at the top of the address space. /FILE-OFFSET=hhhhhh If FILE-OFFSET is specified, the first hhhhhh bytes of the file are skipped and not programmed to target. Default: /FILE-OFFSET=0 Abbreviation: /FO= /LENGTH=hhhhhh The number of programmed bytes may be limited to LENGTH. If no LENGTH is specified the whole file is programmed. Default: /LENGTH=4000000 (64 MByte) Abbreviation: /L= /NODUMP In case of a verify error the contents of the flash memory is written to a file with the extension .DMP. With /NODUMP you can suppress this feature. /ERASEALL Erase the whole flash device. If this option isn't set, only those blocks are erased where new data should be written to. /NOERASE This option prevents the flash device from being erased. 66 JTAG_alchemyb.doc AMD Alchemy Solutions Processors /CS0 /CS1 /CS2 /CS3 This options may be used to specify one or more chip select signals to the flash memory. The used chip selects must be defined as output and inactive in the initialization file. (See chapter 1.11 “Initialization file JTAuxxxx.INI”.) Default: /CS0 /NOCS Use this option to switch off all chip select signals. This may be necessary if the device's chip select is generated via a normal decoder instead of using the AMD Alchemy Solutions Processors chip select unit. /NOWRSETUP By default write cycles to the Flash EPROM are realized with three steps: 1. set address/data 2. write strobe active 3. write strobe inactive. In most cases it is possible to set the write strobe coincident with setting of address and data by specifying the option /NOWRSETUP. This increases the programming speed by 50%. Examples: JTAuxxxx /P ROMDOS.ROM /L=20000 /TOP This example programs up to 128 Kbytes of the file ROMDOS.ROM (with i.e. 512 Kbytes) to the top of the boot flash memory. JTAuxxxx /P CE.ROM /32BIT /CS1 This example programs the file CE.ROM to the 32 Bit Flash-EPROM connected to RCS1#. JTAG_alchemyb.doc 67 AMD Alchemy Solutions Processors 2.2. Read a Flash Device to file Usage: JTAuxxxx /R filename [optionlist] The contents of a flash device is read and written to a file. The type of the flash device is normally detected by the software. When autodetection fails you should use the /DEVICE= option together with /8BIT or /16BIT or /32BIT to set the right flash device and configuration. The known devices are shown in chapter 1.12 “Supported flash devices”. Use the option /CFI if the flash is not in the list of know devices. Options: /DEVICE=devicename See function /P (Chapter 2.1) /CFI See function /P (Chapter 2.1) /8BIT /16BIT /32BIT See function /P (Chapter 2.1) /BYTE-MODE See function /P (Chapter 2.1) /NOMAN See function /P (Chapter 2.1) /DEVICE-BASE=hhhhhh2 See function /P (Chapter 2.1) 2 hhhhhh=number base is hex 68 JTAG_alchemyb.doc AMD Alchemy Solutions Processors /OFFSET=hhhhhh Reading of the flash memory starts at an offset of hhhhhh relative to the start address of the flash device. If the offset is negative, the offset specifies a address relative to the end of the flash device. See also option /TOP. Default: /OFFSET=0 Abbreviation: /O= /TOP If the option /TOP is used the option /OFFSET= specifies the address where reading ends (plus one) instead of the starting address. /LENGTH=hhhhhh The number of read bytes may be limited to LENGTH. If no LENGTH is specified the whole flash device is read (if no offset is specified). /CS0 /CS1 /CS2 /CS3 See function /P (Chapter 2.1) /NOWRSETUP See function /P (Chapter 2.1) Please note: In the function /R write cycles are needed to detect the type of the flash memory. Example: JTAuxxxx /R BIOS.ABS /L=10000 /TOP This example may be used to read the upper most 64 Kbyte of the flash memory to the file BIOS.ABS. JTAG_alchemyb.doc 69 AMD Alchemy Solutions Processors 2.3. Verify a Flash Device with file Usage: JTAuxxxx /V filename [optionlist] The contents of a flash device is compared with the specified file. If there are differences the memory is dumped to a file with the extension DMP. The type of flash device is normally detected by the software. When autodetect fails you should use the /DEVICE= option together with /8BIT or /16BIT or /32BIT to set the right flash device and configuration. The known devices are shown in chapter 1.12 “Supported flash devices”. Use the option /CFI if the flash is not in the list of know devices. Options: /DEVICE=devicename See function /P (Chapter 2.1) /CFI See function /P (Chapter 2.1) /8BIT /16BIT /32BIT See function /P (Chapter 2.1) /BYTE-MODE See function /P (Chapter 2.1) /NOMAN See function /P (Chapter 2.1) /DEVICE-BASE=hhhhhh See function /P (Chapter 2.1) /OFFSET=hhhhhh See function /P (Chapter 2.1) /TOP See function /P (Chapter 2.1) 70 JTAG_alchemyb.doc AMD Alchemy Solutions Processors /FILE-OFFSET=hhhhhh See function /P (Chapter 2.1) /LENGTH=hhhhhh See function /P (Chapter 2.1) /NODUMP See function /P (Chapter 2.1) /CS0 /CS1 /CS2 /CS3 See function /P (Chapter 2.1) /NOWRSETUP See function /P (Chapter 2.1) Please note: In the function /V write cycles are needed to detect the type of the flash memory. Example: JTAuxxxx /V ROMDOS.ROM /L=20000 /TOP This example may be used to verify the upper most 128 Kbytes of the flash memory with the file ROMDOS.ROM (with i.e. 512 Kbytes). JTAG_alchemyb.doc 71 AMD Alchemy Solutions Processors 2.4. Dump target memory Usage: JTAuxxxx /DUMP [optionlist] A Hex-Dump of the target memory is printed on the screen, if not redirected to file or device. Options: /8BIT /16BIT /32BIT Default: /32BIT /OFFSET=hhhhhh The memory dump starts at an offset of hhhhhh plus the device start address (see option /DEVICE-BASE=). Default: /OFFSET=0 Abbreviation: /O= /DEVICE-BASE=hhhhhh3 The device start address is used as an additional offset. This gives the function /DUMP the same behavior as function /P /V and /R. Default: /DEVICE-BASE=0 Abbreviation: /DB= /TOP If the option /TOP is used the option /OFFSET= specifies the address where the dump ends (plus one) instead of the starting address /LENGTH=hhhhhh Default: /LENGTH=100 Abbreviation: /L= /CS0 /CS1 /CS2 /CS3 See function /P (Chapter 2.1) Default: /CS0 3 hhhhhh=number base is hex 72 JTAG_alchemyb.doc AMD Alchemy Solutions Processors Example: JTAuxxxx /DUMP This example makes a memory dump of the first 256 bytes of the Boot-EPROM. JTAG_alchemyb.doc 73 AMD Alchemy Solutions Processors 2.5. Program a Serial Device (I²C/SPI/MicroWire) Usage: JTAuxxxx /PSER filename [/SERBIG] [optionlist] The specified file is programmed to a serial device (i.e. EEPROM) connected to pins of the CPU. Finally a complete verify is done. If the verify fails, the contents of the serial device is written to a file with the extension DMP. For an I²C device there are two different methods how to connect it to the CPU. The first method uses two CPU pins, one pin for clock output (SERCLK) and one pin for serial data input/output (SERDAT). The second method uses one pin for clock output (SERCLK), one for serial data input (SERDATI) and one for serial data output (SERDATO). Connecting a SPI/MicroWire device needs four different CPU pins: SERCS is the chip select output of the CPU, SERCLK is the clock output of the CPU, SERDATO is the serial data output of the CPU and must be connected to the SI input at the SPI/MicroWire device and SERDATI is the serial data input to the CPU and must be connected to the SO output of the SPI/MicroWire device. Options: /SERBIG Specify this option if there is a device which needs a three byte address instead of a two byte address. For SPI devices this option is normally needed for devices with more than or equal to 64 kBytes. For I²C devices this option is normally needed for devices with more than 2 kByte. This option must be the first option after the filename. /SPI Specify this option, if there is a SPI device connected instead of an I²C device. /MWIRE Specify this option, if there is a MicroWire device connected instead of an I²C device. Please Note: Actually only the M93C06 and the M93C46 and only in 16 Bit mode are supported. 74 JTAG_alchemyb.doc AMD Alchemy Solutions Processors /DEVICE-BASE=hhhhhh This option specifies an I²C device starting address. The default values are chosen to access a serial EEPROM. By changing the device starting address different devices can be selected. As SPI/MicroWire devices are selected by the chip select signal instead of an address, this option does not make sense for SPI/MicroWire devices. Default: /DEVICE-BASE=5000 (if option /SERBIG omitted) Default: /DEVICE-BASE=500000 (if option /SERBIG specified) Default: /DEVICE-BASE=0 (for SPI/MicroWire devices) /OFFSET=hhhhhh The programming starts at an offset of hhhhhh relative to the start address of the serial device. Default: /OFFSET=0 Abbreviation: /O= /FILE-OFFSET=hhhhhh If FILE-OFFSET is specified, the first hhhhhh bytes of the file are skipped and not programmed to target. Default: /FILE-OFFSET=0 Abbreviation: /FO= /LENGTH=hhhhhh The number of programmed bytes may be limited to LENGTH. If no LENGTH is specified the whole file is programmed. Abbreviation: /L= /NODUMP In case of a verify error the contents of the I²C-Device is written to a file with the extension .DMP. With option /NODUMP you can suppress this feature. /SERCS=pin_name (SPI/MicroWire mode only) Specifies the CPU pin used to select the serial device. In SPI mode SERCS is treated as low active. In MicroWire mode SERCS is treated as high active. /SERCLK=pin_name Specifies the CPU pin used for serial clock output. JTAG_alchemyb.doc 75 AMD Alchemy Solutions Processors /SERDAT=pin_name (I²C only) Specifies the CPU pin used for serial data input and output for an I²C device. Pin_name must specify a bidirectional pin otherwise an error message occurs. Instead of one bidirectional pin one pin for serial data input and one for serial data output may be used. See option /SERDATO= and /SERDATI= . /SERDATO=pin_name Specifies the CPU pin used for serial data output. Pin_name must specify a output pin otherwise an error message occurs. This pin must be connected to the serial data input of a SPI/MicroWire device. /SERDATI=pin_name Specifies the CPU pin used for serial data input. Pin_name must specify a input pin otherwise an error message occurs. This pin must be connected to the serial data output of a SPI/MicroWire device. /SERBUFF= hhhhhh For I²C and SPI devices the write page mode can be activated by specifying the option /SERBUFF=. Using this feature increases the programming performance. Please note: Some SPI devices do not support single byte write mode. For these devices the option /SERBUFF= must be specified in the command line. /LSB1ST Some devices need the least significant data bit sent/received first (i.e. Altera ECS1 configuration device for FPGAs). Addresses are still sent/received most significant bit first. This option does not affect the behavior of accessing I²C devices. /SPIERA Some SPI devices need to be erased before programming. Add option /SPIERA to the command line to perform a chip erase procedure before programming. Example: JTAuxxxx /PSER EEPROM.CFG /SERCLK=GPIO0 /SERDAT=GPIO This example loads the file EEPROM.CFG to a I²C EEPROM connected to the pins GPIO0 and GPIO1 of the AMD Alchemy Solutions Processors 76 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 2.6. Read a Serial Device to file (I²C/SPI/MicroWire) Usage: JTAuxxxx /RSER filename [/SERBIG] /L=hhhhhh [optionlist] The contents of a serial device (i.e. EEPROM) is read and written to a file. The option /LENGTH= must be specified. Options: /SERBIG This option must be the first option after the filename. See function /PSER (Chapter 2.5) /SPI Specify this option, if there is a SPI device connected instead of a I²C device. /MWIRE Specify this option, if there is a MicroWire device connected instead of an I²C device. /DEVICE-BASE=hhhhhh See function /PSER (Chapter 2.5) /OFFSET=hhhhhh Reading of the serial device starts at an offset of hhhhhh relative to the start address of the serial device. Default: /OFFSET=0 Abbreviation: /O= /LENGTH=hhhhhh The number of read bytes must be specified otherwise an error message occurs. Abbreviation: /L= /SERCS=pin_name See function /PSER (Chapter 2.5) /SERCLK=pin_name See function /PSER (Chapter 2.5) JTAG_alchemyb.doc 77 AMD Alchemy Solutions Processors /SERDAT=pin_name See function /PSER (Chapter 2.5) /SERDATO=pin_name See function /PSER (Chapter 2.5) /SERDATI=pin_name See function /PSER (Chapter 2.5) /LSB1ST See function /PSER (Chapter 2.5) Example: JTAuxxxx /RSER EEPROM.CFG /SERCLK=GPIO0 /SERDAT=GPIO1 /L=100 This example reads 256 bytes from a I²C EEPROM to the file EEPROM.CFG. The serial EEPROM is connected to the pins CPIO0 and GPIO1 of the AMD Alchemy Solutions Processors. 78 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 2.7. Verify a Serial Device with file (I²C/SPI/MicroWire) Usage: JTAuxxxx /VSER filename [/SERBIG] [optionlist] The contents of a serial device (i.e. EEPROM) is compared with the specified file. If there are differences the contents of the I²C -Device is written to a file with the extension DMP. Options: /SERBIG This option must be the first option after the filename. See function /PSER (Chapter 2.5) /SPI Specify this option, if there is a SPI device connected instead of a I²C device. /MWIRE Specify this option, if there is a MicroWire device connected instead of an I²C device. /DEVICE-BASE=hhhhhh See function /PSER (Chapter 2.5) /OFFSET=hhhhhh See function /PSER (Chapter 2.5) /FILE-OFFSET=hhhhhh See function /PSER (Chapter 2.5) /LENGTH=hhhhhh See function /PSER (Chapter 2.5) /NODUMP See function /PSER (Chapter 2.5) /SERCS=pin_name See function /PSER (Chapter 2.5) JTAG_alchemyb.doc 79 AMD Alchemy Solutions Processors /SERCLK=pin_name See function /PSER (Chapter 2.5) /SERDAT=pin_name See function /PSER (Chapter 2.5) /SERDATO=pin_name See function /PSER (Chapter 2.5) /SERDATI=pin_name See function /PSER (Chapter 2.5) /LSB1ST See function /PSER (Chapter 2.5) Example: JTAuxxxx /VSER EEPROM.CFG /SERCLK=GPIO0 /SERDAT=GPIO1 This example verifies 256 bytes from a serial EEPROM with the file EEPROM.CFG. The serial EEPROM is connected to the pins GPIO0 and GPIO1 of the AMD Alchemy Solutions Processors. 80 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 2.8. Dump a Serial Device (I²C/SPI/MicroWire) Usage: JTAuxxxx /DUMPSER [/SERBIG] [optionlist] A Hex-Dump of serial device (i.e. EEPROM) is printed on the screen, if not redirected to file or device. Options: /SERBIG This option must be the first option. See function /PSER (Chapter 2.5) /SPI Specify this option, if there is a SPI device connected instead of a I²C device. /MWIRE Specify this option, if there is a MicroWire device connected instead of an I²C device. /DEVICE-BASE=hhhhhh See function /PSER (Chapter 2.5) /OFFSET=hhhhhh4 The memory dump starts at an offset of hhhhhh. Default: /OFFSET=0 Abbreviation: /O= /LENGTH=hhhhhh Default: /LENGTH=100 Abbreviation: /L= /SERCS=pin_name See function /PSER (Chapter 2.5) /SERCLK=pin_name See function /PSER (Chapter 2.5) 4 hhhhhh=number base is hex JTAG_alchemyb.doc 81 AMD Alchemy Solutions Processors /SERDAT=pin_name See function /PSER (Chapter 2.5) /SERDATO=pin_name See function /PSER (Chapter 2.5) /SERDATI=pin_name See function /PSER (Chapter 2.5) /LSB1ST See function /PSER (Chapter 2.5) Example: JTAuxxxx /DUMPSER /SERCLK=GPIO0 /SERDAT=GPIO1 This example makes a memory dump of the first 100h bytes of a I²C EEPROM connected to the CPU. 82 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 2.9. Toggle CPU pins Usage: JTAuxxxx /BLINK /PIN=pinname [optionlist] This command allows to test the hardware by blinking with LEDs or toggling CPU signals. Faster signals can be generated by setting the delay option to zero. This can be a very helpful feature to watch signals on an oscilloscope. The signal on the defined pin has an duty cycle of 1/2: The level is 67% high and 33% low. Please Note: Not every pin of the AMD Alchemy Solutions Processors may be specified as an output pin. Options: /PIN=pin_name CPU pin to toggle. If the option /PIN= is not specified an error message occurs. Most pins of the list in chapter 1.11 “Initialization file JTAuxxxx.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. /DELAY=dddddd5 Time to wait to next change of signal. This option can be adjusted to get optimum signals for measures with the oscilloscope. Default: /DELAY=10000 Example: JTAuxxxx /BLINK /PIN=FLAG3 /DELAY=0 This example toggles the FLAG3 pin very fast which can be followed by the use of an oscilloscope. 5 dddddd=number base is decimal JTAG_alchemyb.doc 83 AMD Alchemy Solutions Processors 2.10. Polling CPU pins Usage: JTAuxxxx /PIN? /PIN=pinname [optionlist] This command allows to test the hardware by polling CPU signals. Please Note: Not every pin of the AMD Alchemy Solutions Processors may be specified as an input pin. Options: /PIN=pin_name CPU pin to poll. If the option /PIN= is not specified an error message occurs. Most pins of the list in chapter 1.11 “Initialization file JTAuxxxx.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. Example: JTAuxxxx /PIN? /PIN=RESET# This example samples the reset pin of the AMD Alchemy Solutions Processors. 84 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 2.11. Polling CPU pins while the CPU is running Usage: JTAuxxxx /SAMPLE /PIN=pinname [optionlist] This command is similar to the function /PIN?. But with this function any pin can be observed, independent of the pin direction. Furthermore the CPU remains in normal operation. Options: /PIN=pin_name CPU pin to poll. If the option /PIN= is not specified an error message occurs. All pins of the list in chapter 1.11 “Initialization file JTAuxxxx.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. Example: JTAuxxxx /SAMPLE /PIN=FLAG3 This example samples the state of the port pin FLAG3 while the AMD Alchemy Solutions Processors is running. JTAG_alchemyb.doc 85 AMD Alchemy Solutions Processors 2.12. Show status of all CPU pins while the CPU is running Usage: JTAuxxxx /SNAP [optionlist] This function is similar to the function /SAMPLE, but displays the status of all CPU pins on the screen. The CPU remains in normal operation. The behavior of the function /SNAP depends on the option /REP: With this option specified, the JTAG-Booster samples and displays the state of the CPU pins repetitive. Without this option the status of the pins is displayed only once. Options: /PAUSE Use this option to stop the output after each displayed screen. Don't use this option together with the option /REP or if the output is redirected to a file. Abbreviation /P /REP If this option is specified the status of the pins is sampled and displayed repetitive. In case of many signals the display is separated into several screens. Therefor we recommend to use a video mode with 43 or 50 lines. Use the '+' and the '-' key to switch between different screens. Any other key terminates the program. 86 JTAG_alchemyb.doc AMD Alchemy Solutions Processors Sample output: This is a sample output for a AMD Alchemy Solutions Au1100 Processor | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 0 GPIO10 | 0 S0DIN | 0 GPIO12 | 0 U1RXD | 0 U3RXD | 0 ACBCLK | 0 N0CRS | 0 U3TXD | 0 GPIO14 | 0 N0TXEN | 0 N0TXD1 | 0 N0MDIO | 0 GPIO16 | 0 RESVD_2 | 0 GPIO23 | 0 RESVD_5 | 0 SDMS0_CMD | 0 SDMS0_DAT3 | 0 SDMS1_DAT1 | 0 SDD1 | 1 SDD5 | 0 SDD9 | 0 SDD13 | 0 SDD17 | 1 SDD21 | 1 SDD25 | 1 SDD29 | 1 SDCLK1 | 1 SDWE# | 1 SDCAS# | 1 SDQM3# | 1 SDA1 | 1 SDA5 | 1 SDA9 | 1 RESETOUT# | 1 ROMSIZE | 0 GPIO1 | 0 GPIO3 | 0 TC3 | 0 USBH1P | 0 USBDP | 0 S0DOUT | 0 IRDARX | 0 ACDI | 0 ACDO | 0 N0RXD0 | 0 GPIO13 | 0 GPIO15 | 0 N0TXD0 | 0 N0TXD2 | 0 N0TXCLK | 0 GPIO17 | 0 GPIO20 | 0 RESVD_3 | 0 LCD_PWM1 | 0 SDMS0_DAT0 | 0 SDMS1_CMD | 0 SDMS1_DAT2 | 0 SDD2 | 1 SDD6 | 1 SDD10 | 1 SDD14 | 1 SDD18 | 1 SDD22 | 1 SDD26 | 1 SDCLK0 | 1 SDCS0# | 1 SDCLK2 | 1 SDQM0# | 1 SDBA0 | 1 SDA2 | 1 SDA6 | 1 SDA10 | 1 VSEL | 0 RESETIN# | 0 TC0 | 0 GPIO4 | 0 PIOW# | JTAG_alchemyb.doc 0 USBH1M 0 USBDM 0 S0CLK 0 IRDATX 0 ACRST# 0 I2SCLK 0 U0TXD 0 N0RXD1 0 N0RXD3 0 N0RXDV 0 N0TXD3 0 RESVD_0 0 GPIO18 0 GPIO21 0 LCD_PWM0 0 SDMS_MS_EN 0 SDMS0_DAT1 0 SDMS1_CLK 0 SDMS1_DAT3 1 SDD3 1 SDD7 0 SDD11 0 SDD15 1 SDD19 1 SDD23 1 SDD27 1 SDD30 1 SDCS1# 1 SDRAS# 1 SDQM1# 1 SDBA1 1 SDA3 1 SDA7 1 SDA11 1 TESTEN 0 VDDXOK 0 TC1 0 GPIO5 0 GPIO6 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 0 U0RXD 0 GPIO11 0 S0DEN 0 I2SDIO 0 ACSYNC 0 I2SWORD 0 U1TXD 0 N0RXD2 0 N0RXCLK 0 N0COL 0 N0MDC 0 RESVD_1 0 GPIO19 0 GPIO22 0 RESVD_4 0 SDMS0_CLK 0 SDMS0_DAT2 0 SDMS1_DAT0 0 SDD0 1 SDD4 1 SDD8 1 SDD12 1 SDD16 1 SDD20 1 SDD24 1 SDD28 1 SDD31 1 SDCS2# 1 SDCKE 1 SDQM2# 1 SDA0 1 SDA4 1 SDA8 1 SDA12 1 ROMSEL 0 GPIO0 0 GPIO2 0 TC2 0 GPIO7 87 AMD Alchemy Solutions Processors | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1 PIOR# 0 PREG# 0 LRD0# 0 EWAIT# 1 RD1 1 RD5 1 RD9 1 RD13 1 RD17 0 RD21 0 RD25 0 RD29 1 RAD1 1 RAD5 1 RAD9 1 RAD13 1 RAD17 1 RAD21 1 RAD25 1 RAD29 0 RBEN1# 1 ROE# 1 RCS3# 1 LCD_D2 1 LCD_D5 0 LCD_D8 0 LCD_D12 1 LCD_BIAS 88 | | | | | | | | | | | | | | | | | | | | | | | | | | | | 0 PIOS16# 0 PWAIT# 0 LRD1# 1 LCLK 0 RD2 1 RD6 1 RD10 1 RD14 0 RD18 0 RD22 0 RD26 1 RD30 1 RAD2 1 RAD6 1 RAD10 1 RAD14 1 RAD18 1 RAD22 1 RAD26 1 RAD30 0 RBEN2# 1 RCS0# 1 LCD_PCK 1 LCD_LCK 1 LCD_D6 1 LCD_D9 0 LCD_D13 1 LCD_LEND | | | | | | | | | | | | | | | | | | | | | | | | | | | | 0 PWE# 0 PCE1# 1 LWR0# 0 LWR1# 1 RD3 1 RD7 1 RD11 1 RD15 0 RD19 0 RD23 0 RD27 1 RD31 1 RAD3 1 RAD7 1 RAD11 1 RAD15 1 RAD19 1 RAD23 1 RAD27 1 RAD31 0 RBEN3# 1 RCS1# 1 LCD_D0 1 LCD_D3 1 LCD_FCK 0 LCD_D10 1 LCD_D14 1 GPIO8 | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1 POE# 0 PCE2# 0 LWAIT# 1 RD0 1 RD4 1 RD8 1 RD12 1 RD16 0 RD20 1 RD24 0 RD28 1 RAD0 1 RAD4 1 RAD8 1 RAD12 1 RAD16 1 RAD20 1 RAD24 1 RAD28 0 RBEN0# 1 RWE# 1 RCS2# 1 LCD_D1 1 LCD_D4 1 LCD_D7 1 LCD_D11 0 LCD_D15 1 GPIO9 JTAG_alchemyb.doc AMD Alchemy Solutions Processors 3. Implementation Information This chapter summarizes some information about the implementation of the JTAG-Booster and describes some restrictions. • The JTAG-Booster currently uses Boundary Scan to perform Flash programming. EJTAG is not used. • The software assumes the following scheme for connecting the FlashEPROM to the AMD Alchemy Solutions Processors. Please contact us, if you need support for a different method. AMD Au1x00 signal RCS0# RCS1# RCS2# RCS3# ROE# RWE# RAD0 RAD1 RAD2..28 RD0..7 RD0..15 RD0..31 8 Bit Flash CS# 16 Bit Flash CS# 32 Bit Flash CS# OE# WE# A0 A1 A2..28 D0..7 - OE# WE# A1 A2..28 D0..15 - OE# WE# A2..28 D0..31 1.) All other signals are hold static during flash programming. The state of these signals is defined in the Initialization file. • Default endianess is "Little Endian". Use the option /BIG for big endian support. • Physical address range for static memory and peripherals is limited to 512MByte (MIPS32 specific). For memory accesses with boundary scan, the address lines RAD29, RAD30 and RAD31 are not modified. • Support for NAND flashes is not included as standard functionality, but can be provided on customers request (AMD Alchemy Solutions Au1550 Processor only). JTAG_alchemyb.doc 89 AMD Alchemy Solutions Processors 4. Converter Program HEX2BIN.EXE Since the JTAG-Booster software is not able to handle Intel-HEX or Motorola SRecord files, an separate converter tool is delivered with this product package. Five types of HEX formats can be converted to BIN file: • I • D : Digital Research • M : MOTOROLA S HEX format (BYTE oriented) • T : TEKTRONICS HEX format (BYTE oriented) • H : Intel HEX-32 : INTEL HEX format (BYTE oriented) Maximum conversion size is 256 kBytes. A 4th parameter for starting address can be specified to skip out the leading garbage and you will maintain a small size of output binary file. If you start the HEX2BIN without any additional parameter all necessary parameters will be asked for in a prompt mode: HEX2BIN Input HEX file name: MYAPP.H86 Output BIN file name[MYAPP.BIN]: HEX file format ntel /otorola /igital Research /ektronics /[H] Intel HEX-32[I] : H Input CODE segment start address[0000000]: 10000 Input CODE segment end address[FFFFFFF]: Unused bytes will be 00 FF [1] : 2 Instead of using the prompt mode, you can directly specify all necessary parameters in the command line. This is essential for making batch files: HEX2BIN MYAPP.H86 MYAPP.BIN H 0010000 FFFFFFF 2 It is very important to fill unused bytes with 0xFF, because this are simply skipped by the JTAG-Boosters software and so it speeds up the programming performance. 90 JTAG_alchemyb.doc AMD Alchemy Solutions Processors Please Note: "CODE segment start address" is interpreted as a Intel x86 architecture segment address: You have to specify a start address of 10000 to start the conversion at 1 MByte. This converter is a relatively old DOS tool and therefor it has problems with non DOS compliant file and directory names. Avoid names with spaces, limit names to eight characters. Otherwise the converter does not convert the input file, without any error message!! JTAG_alchemyb.doc 91 AMD Alchemy Solutions Processors 5. Support for Windows NT, Windows 2000 and Windows XP A configured run time version of the "Kithara DOS Enabler, Version 6.x" is used to give support for some of our DOS based tools (like the JTAG-Booster) for Windows NT, Windows 2000 and Windows XP. After installation of the "DOS Enabler" the accesses to the LPT ports are allowed for the all programs listed in file Readme_WinNT.txt Note: Accesses to the ports are only allowed for the programs listed in file Readme_WinNT.txt. If you rename one of our tools, the DOS Enabler does not work. Important: You need administrator rights to install or de-install this program. 5.1. Installation on a clean system If you have a clean system without having installed a previous version of the "Kithara Tool Center", this tool is really simple to install. Extract the ZIP file to a new folder and start KSETUP.EXE. Everything is done within a few seconds. No additional input is needed. Now reboot your PC. 5.2. Installation with already installed version 5.x/6.x of Kithara If you have already installed an older WinNT support (Kithara Version 5.x or 6.x), you have to de-install it 1st as described in chapter 5.4. After rebooting your PC you can install the Kithara 6.x as described above. 5.3. Installation with already installed version 4.x of Kithara Important!! If you have already installed an older WinNT support, you have to deinstall it completely!!! • Start kcenter • Select Register "Einstellungen" (=Settings) and deactivate "VDD benutzen" and "speziellen seriellen Treiber benutzen". • Stop Kernel 92 JTAG_alchemyb.doc AMD Alchemy Solutions Processors • exit the kcenter program • Now you can deinstall the Kithara Package with: Settings - Control Panel. All unused parts must be removed. • Reboot your PC • Now you can install the Kithara 6.x as described above. 5.4. De-Installation version 5.x/6.x: For deinstallation of the runtime version of the "Kithara DOS-Enabler Version 5.x/6.x": • use: Settings - Control-Panel - Add/Remove Programs and remove the “FS FORTH-SYSTEME WinNT Support” and/or “WinNT Support for JTAG-Booster and FLASH166” • Reboot your PC JTAG_alchemyb.doc 93
FS-9019 价格&库存
很抱歉,暂时无法提供与“FS-9019”相匹配的价格&库存,您可以联系我们找货
