FS-940
FS-940
    DIGIINTERNATIONAL
    JTAG-BOOSTER FOR ADSP-21XXX 5V
FS-940 数据手册
JTAG-Booster for Analog Devices ADSP-21xxx P.O: Box 1103 Kueferstrasse 8 Tel. +49 (7667) 908-0 sales@fsforth.de • • • • D-79200 Breisach, Germany D-79206 Breisach, Germany Fax +49 (7667) 908-200 http://www.fsforth.de JTAG-Booster for Analog Devices ADSP-21xxx Copyright  1995..2002: FS FORTH-SYSTEME GmbH Postfach 1103, D-79200 Breisach, Germany Release of Document: Author: Filename: Program Version: April 19, 2002 Dieter Fögele JTAG_ADSP-21xxxa.doc 4.xx All rights reserved. No part of this document may be copied or reproduced in any form or by any means without the prior written consent of FS FORTH-SYSTEME GmbH. 2 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx Table of Contents 1. General ..........................................................................................................4 1.1. Ordering Information ............................................................................5 1.2. System Requirements ..........................................................................5 1.3. Contents of Distribution Disk ................................................................6 1.4. Connecting your PC to the target system .............................................7 1.5. First Example with Analog Devices ADSP-21060/21061/21062............9 1.6. First Example with Analog Devices ADSP-21065 ............................... 11 1.7. First Example with Analog Devices ADSP-21161 ............................... 13 1.8. Trouble Shooting ................................................................................ 15 1.9. Error Messages .................................................................................. 16 1.10.Initialization file JTAGxxx.INI.............................................................. 21 1.11.Supported flash devices..................................................................... 37 2. JTAGxxx Parameter Description................................................................... 38 2.1. Program a Flash Device ..................................................................... 41 2.2. Read a Flash Device to file................................................................. 45 2.3. Verify a Flash Device with file ............................................................. 47 2.4. Dump target memory.......................................................................... 49 2.5. Program an I²C-Device....................................................................... 51 2.6. Read an I²C-Device to file................................................................... 53 2.7. Verify an I²C-Device with file............................................................... 55 2.8. Dump an I²C-Device ........................................................................... 57 2.9. Toggle CPU pins ................................................................................ 59 2.10.Polling CPU pins ................................................................................ 60 2.11.Polling CPU pins while the CPU is running ........................................ 61 2.12.Show status of all CPU pins while the CPU is running ....................... 62 3. Implementation Information .......................................................................... 64 4. Converter Program HEX2BIN.EXE............................................................... 66 5. Support for Windows NT and Windows 2000 ............................................... 68 5.1. Installation on a clean system............................................................. 68 5.2. Installation with already installed a previous version of Kithara........... 68 5.3. De-Installation version 5.xx:................................................................ 69 JTAG_ADSP-21xxxa.doc 3 JTAG-Booster for Analog Devices ADSP-21xxx 1. General The programs JTAG060.EXE, JTAG065.EXE and JTAG161.EXE use the JTAG port of the Analog Devices ADSP-21xxx DSP Microcomputer in conjunction with the small JTAG-Booster: • • • • • to program data into flash memory to verify and read the contents of a flash memory to make a memory dump to access an I²C Device to test CPU signals All functions are done without any piece of software running in the target. No firmware or BIOS must be written. Bootstrap software may be downloaded to initially unprogrammed memories. The JTAG-BOOSTER' s software is highly optimized to the JTAG chain of a specific target CPU. To give support for all DSPs of the Analog Devices ADSP21xxx family, there are three different programs on the distribution disk: • JTAG060.EXE : Tool for Analog Devices ADSP-21060/21061/21062 • JTAG065.EXE : Tool for Analog Devices ADSP-21065 • JTAG161.EXE : Tool for Analog Devices ADSP-21161 Please contact us, if you need support for other members of the Analog Devices ADSP-21xxx family. For latest documentation please refer to the file README.TXT on the distribution disk. 4 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 1.1. Ordering Information The following related products are available • 940 JTAG-Booster Analog Devices ADSP-21xxx, 5V, DOS/Win9x/WinNT, delivered with adapter type 227 • 953 JTAG-Booster Analog Devices ADSP-21xxx, 3.3V, DOS/Win9x/WinNT, delivered with adapter type 285 1.2. System Requirements To successfully run this tool the following requirements must be met: • MSDOS, WIN3.x, WIN9x, WinME, WinNT or Win2000 (WinNT/Win2000 is supported with an additional tool, see chapter 5) • Intel 80386 or higher • 205 kByte of free DOS memory • Parallel Port JTAG_ADSP-21xxxa.doc 5 JTAG-Booster for Analog Devices ADSP-21xxx 1.3. Contents of Distribution Disk • JTAG060.EXE JTAG060.OVL Tool for Analog Devices ADSP-21060/21061/21062 • JTAG060.INI Template configuration file for Analog Devices ADSP21060/21061/21062. See chapter 1.10 "Initialization file JTAGxxx.INI" • JTAG065.EXE JTAG065.OVL Tool for Analog Devices ADSP-21065 • JTAG065.INI Template configuration file for Analog Devices ADSP21065. See chapter 1.10 "Initialization file JTAGxxx.INI" • JTAG161.EXE JTAG161.OVL Tool for Analog Devices ADSP-21060/21061/21062 • JTAG161.INI Template configuration file for Analog Devices ADSP21161. See chapter 1.10 "Initialization file JTAGxxx.INI" • HEX2BIN.EXE Converter program to convert Intel HEX and Motorola S-Record files to binary. See chapter 4 "Converter Program HEX2BIN.EXE" • WinNT.zip Support for Windows NT and Windows 2000. See chapter 5 "Support for Windows NT and Windows 2000" • JTAG_V4xx_FLAS HES.pdf List of all supported Flash devices • README.txt Release notes, new features, known problems 6 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 1.4. Connecting your PC to the target system The JTAG-Booster can be plugged into standard parallel ports (LPT1-3) with a DB25-Connector. 1 LPT1-3 1 Élan SC400 Module Élan486 The target end of the cable has the following reference: 1 TCK 2* GND 3 TMS 4 TRST# 5 NC 6 TDI 7 TDO 8 +3.3V / +5V *PIN 2 can be detected by the white thick cable. To connect your design to the JTAG-BOOSTER you need a single row berg connector with a spacing of 2.54mm on your PCB. The names refer to the target: Pin 7 is the target’s TDO pin and is connected to the JTAG-Booster’s TDI pin. There are two versions of the JTAG-Booster available: A 5V version (FS part number 227) and a 3.3V version (FS part number 285). Don’t apply 5V to the 3.3V version of the JTAG-Booster! Your target must be able to power the JTAG-Booster, it draws about 100mA. Before you start the program, the JTAG-BOOSTER must be plugged to a parallel interface of your PC and to the 8 pin JTAG connector on the target. JTAG_ADSP-21xxxa.doc 7 JTAG-Booster for Analog Devices ADSP-21xxx The utility is started with the general command line format: JTAGxxx /function [filename] [/option_1] ... [/option_n]. Note that the function must be the first argument followed (if needed) by the filename. If you want to cancel execution of JTAGxxx, press CTRL-Break-Key. On any error the program aborts with an MSDOS error level of one. 8 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 1.5. First Example with Analog Devices ADSP-21060/21061/21062 In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JTAG060 /P MYAPP.BIN at the DOS prompt results in the following output: JTAG060 --- JTAG utility for Analog Devices ADSP-21060/21061/21062 Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JTAGxxx.INI Target: Analog Devices SHARC EZ-KIT Using LPT at I/O-address 0378h JTAG Adapter detected (5) 1 Device detected in JTAG chain Device 0: Part without an ICODE register (1st Bit is 0) Analog Devices ADSP-21060/21061/21062 is selected Sum of instruction register bits : 5 CPU position :0 Instruction register offset :0 Length of boundary scan reg : 363 (6) (7) (8) (9) (10) (11) (12) (13) Looking for a known flash device. Please wait.. AMD 29F010 detected Bus size is 8 Bit Erasing Flash-EPROM Block #:0 Programming File MYAPP.BIN 65536 Bytes programmed Programming ok Erase Time Programming Time JTAG_ADSP-21xxxa.doc : : 1.3 sec 201.6 sec 9 JTAG-Booster for Analog Devices ADSP-21xxx (1) The initialization file JTAG060.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the Analog Devices ADSP-21060/21061/21062 are switched to bypass mode. (6) The Analog Devices ADSP-21xxx does not have an ICODE register. (7) The length of all instruction registers in the JTAG chain are added. (8) The position of the Analog Devices ADSP-21xxx in the JTAG chain is assumed to be zero, if not specified in the command line (see option /CPUPOS=). (9) The position of the JTAG instruction register of the Analog Devices ADSP21xxx is assumed to be zero, if not specified in the command line (see option /IROFFS=). (10) The real length of the boundary scan register is displayed here and compared with the boundary scan register length of a Analog Devices ADSP-21060/21061/21062. This is very important, because the Analog Devices ADSP-21060/21061/21062 does not have an IDCODE register. (11) One Flash-EPROM AMD 29F010 selected with BMS# was found. (12) The resulting data bus size is printed here. (13) In this example one block must be erased. 10 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 1.6. First Example with Analog Devices ADSP-21065 In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JTAG065 /P MYAPP.BIN at the DOS prompt results in the following output: JTAG065 --- JTAG utility for Analog Devices ADSP-21065 Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JTAG065.INI Target: Generic Target with ADSP-21065 Using LPT at I/O-address 0378h JTAG Adapter detected (5) 1 Device detected in JTAG chain Device 0: Part without an ICODE register (1st Bit is 0) Analog Devices ADSP-21065 is selected Sum of instruction register bits : 5 CPU position :0 Instruction register offset :0 Length of boundary scan reg : 285 (6) (7) (8) (9) (10) (11) (12) (13) (14) Looking for a known flash device. Please wait.. AMD 29LV160B, 3.3V, Boot Block Bottom, byte mode detected Bus size is 8 Bit Erasing Flash-EPROM Block #:0 1 2 3 Unlock Bypass used Programming File MYAPP.BIN 65536 Bytes programmed Programming ok Erase Time Programming Time JTAG_ADSP-21xxxa.doc : : 0.9 sec 81.5 sec 11 JTAG-Booster for Analog Devices ADSP-21xxx (1) The initialization file JTAG065.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the Analog Devices ADSP-21065 are switched to bypass mode. (6) The Analog Devices ADSP-21xxx does not have an ICODE register. (7) The length of all instruction registers in the JTAG chain are added. (8) The position of the Analog Devices ADSP-21xxx in the JTAG chain is assumed to be zero, if not specified in the command line (see option /CPUPOS=). (9) The position of the JTAG instruction register of the Analog Devices ADSP21xxx is assumed to be zero, if not specified in the command line (see option /IROFFS=). (10) The real length of the boundary scan register is displayed here and compared with the boundary scan register length of a Analog Devices ADSP-21060/21061/21062. This is very important, because the Analog Devices ADSP-21060/21061/21062 does not have an IDCODE register. (11) One Flash-EPROM AMD 29LV160B selected with BMS# was found. (12) The resulting data bus size is printed here. (13) In this example four blocks must be erased. (14) If the used Flash-EPROM supports the unlock bypass feature, it is used to speed up programming performance. 12 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 1.7. First Example with Analog Devices ADSP-21161 In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JTAG161 /P MYAPP.BIN at the DOS prompt results in the following output: JTAG161--- JTAG utility for Analog Devices ADSP-21161 Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JTAG161.INI Target: Generic Target with Analog Devices ADSP-21161 Using LPT at I/O-address 0378h JTAG Adapter detected (5) 1 Device detected in JTAG chain Device 0: Part without an ICODE register (1st Bit is 0) Analog Devices ADSP-21161 is selected Sum of instruction register bits : 5 CPU position :0 Instruction register offset :0 Length of boundary scan reg : 481 (6) (7) (8) (9) (10) (11) (12) (13) (14) Looking for a known flash device. Please wait.. AMD 29LV160B, 3.3V, Boot Block Bottom, byte mode detected Bus size is 8 Bit Erasing Flash-EPROM Block #:0 1 2 3 Unlock Bypass used Programming File MYAPP.BIN 65536 Bytes programmed Programming ok Erase Time Programming Time JTAG_ADSP-21xxxa.doc : : 0.9 sec ??.0 sec 13 JTAG-Booster for Analog Devices ADSP-21xxx (1) The initialization file JTAG161.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the Analog Devices ADSP-21161 are switched to bypass mode. (6) The Analog Devices ADSP-21xxx does not have an ICODE register. (7) The length of all instruction registers in the JTAG chain are added. (8) The position of the Analog Devices ADSP-21xxx in the JTAG chain is assumed to be zero, if not specified in the command line (see option /CPUPOS=). (9) The position of the JTAG instruction register of the Analog Devices ADSP21xxx is assumed to be zero, if not specified in the command line (see option /IROFFS=). (10) The real length of the boundary scan register is displayed here and compared with the boundary scan register length of a Analog Devices ADSP-21060/21061/21062. This is very important, because the Analog Devices ADSP-21060/21061/21062 does not have an IDCODE register. (11) One Flash-EPROM AMD 29LV160B selected with BMS# was found. (12) The resulting data bus size is printed here. (13) In this example four blocks must be erased. (14) If the used Flash-EPROM supports the unlock bypass feature, it is used to speed up programming performance. 14 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 1.8. Trouble Shooting Avoid long distances between your Host-PC and the target. If you are using standard parallel extension cable, the JTAG-BOOSTER may not work. Don't use Dongles between the parallel port and the JTAG-BOOSTER. Switch off all special modes of your printer port (EPP, ECP, ...) in the BIOS setup. Only standard parallel port (SPP) mode is allowed. On very fast PCs there could be verify errors. To avoid this, watch for the ´IO recovery time´-switch in the BIOS Setup which must be turned on. Otherwise try to slow down your PC by setting the turbo switch off. If there are problems with autodetection of the flash devices use the /DEVICE= option. To speed up autodetection specify one of the options /8BIT /16BIT or /32BIT. Don't use hardware protected flash memories. The used chip selects must be defined as output and inactive in the initialization file (see chapter 1.10 “Initialization file JTAGxxx.INI”). Also the address bits must be defined as output. Use the option /NOWRSETUP to speed up flash programming. JTAG_ADSP-21xxxa.doc 15 JTAG-Booster for Analog Devices ADSP-21xxx 1.9. Error Messages • 80386 or greater required The JTAG-BOOSTER does not work on a 8088/8086 or a 80286 platform. • Adapter not connected or target power fail The JTAG-Booster wasn't found. Please check connection to parallel port and connection to target. Check target power. Check your BIOS-Setup. • Can't open x:\yyy\zzz\JTAGxxx.OVL The overlay file JTAGxxx.OVL must be in the same directory as JTAGxxx.EXE. • Configuration file XYZ not found. The file specified with the option /INI= wasn't found. • Device offset out of range The value specified with the option /OFFSET= is greater than the size of the detected flash device. • Disk full Writing a output file was aborted as a result of missing disk space. • Do not specify option /NOCS with any other chip select There is a conflict in the command line. • Do not specify option /BYTE-MODE. Flash device does not have a byte mode pin. The flash device specified with the option /DEVICE= does not support switching between 16 (or 32) bit mode and 8 bit mode. In practice it does not have a pin with the name BYTE# • Error creating file: The output file could not be opened. Please check free disk space or write protection. • Error: Pin-Name is an output only pin The specified pin cannot be sampled. Check the command line. Check the initialization file. 16 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx • Error: Pin-Name is an input only pin The specified pin cannot be activated. Check the command line. Check the initialization file. • Error: Pin-Name may not be read back The specified pin can be switched to tristate, but cannot be read back. Check the command line. • illegal function: The first parameter of the command line must be a valid function. See chapter 2 “JTAGxxx Parameter Description” for a list of supported functions. • illegal number: The specified number couldn’t be interpret as a valid number. Check the relevant number base. • illegal option: See chapter 2 “JTAGxxx Parameter Description” for a list of supported options. • illegal Pin Type: The name specified with the option /PIN= must be one of the list of chapter 1.10 ”Initialization file JTAGxxx.INI” • illegal Flash Type: The name specified with the option /DEVICE= must be one of the list of chapter 1.11 ”Supported flash devices”. • Input file not found: The specified file cannot be found • Input file is empty: Files with zero length are not accepted • " " is undefined Please check the syntax in your configuration file. (See chapter 1.10 “Initialization file JTAGxxx.INI”). JTAG_ADSP-21xxxa.doc 17 JTAG-Booster for Analog Devices ADSP-21xxx • LPTx not installed The LPT port specified with /LPTx cannot be found. Please check the LPT port or specify a installed LPT port. Check your BIOS setup. • missing filename Most functions need a filename as second parameter. • missing option /I2CCLK= Some functions need the option /I2CCLK= to be defined. • missing option /I2CDAT= Some functions need the option /I2CDAT= or the options /I2CDATO= and /I2CDATI= to be defined. • missing option /LENGTH= Some functions need the option /LENGTH= to be defined. • missing option /PIN= Some functions need the option /PIN= to be defined. • More than 9 devices in the JTAG chain or TDI pin stuck at low level The JTAG chain is limited to 9 parts. Check target power. Check the target’s TDO pin. • No devices found in JTAG chain or TDI pin stuck at high level A stream of 32 high bits was detected on the pin TDI. TDI may stuck at high level. Check the connection to your target. Check the target power. Check the target’s TDO pin. • Option /CPUPOS= out of range The number specified with the option /CPUPOS= must be less or equal to the number of parts minus 1. • Option /IROFFS= out of range Please specify a smaller value • Part at specified position is not a Analog Devices ADSP-21xxx The option /CPUPOS= points to a part not a Analog Devices ADSP-21xxx 18 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx • Pins specified with /I2CCLK= and /I2CDAT= must have different control cells The pin specified with the option /I2CDAT= must be able to be switched to high impedance while the pin specified with option /I2CCLK= is an active output. See chapter 1.10 “Initialization file JTAGxxx.INI”. • Pins specified with /I2CCLK= and /I2CDATI= must have different control cells The pin specified with the option /I2CDATI= must be able to be switched to high impedance while the pin specified with option /I2CCLK= is an active output. See chapter 1.10 “Initialization file JTAGxxx.INI”. • Pins specified with /I2CDATO= and /I2CDATI= must have different control cells The pin specified with the option /I2CDATI= must be able to be switched to high impedance while the pin specified with option /I2CDATO= is an active output. See chapter 1.10 “Initialization file JTAGxxx.INI”. • Specify only one of that options: Some options are exclusive (i.e. /8BIT and /16BIT). Don't mix them. • Sum of instruction register bits to low. Should be at least 5 bits for a Analog Devices ADSP-21xxx The sum of all instruction register bits in the JTAG chain does not fit to the Analog Devices ADSP-21xxx. Check the target connection. Check the target CPU type. Check the settings for /IROFFS= and /CPUPOS= , if there are several parts in the JTAG chain. • Target no longer connected There is a cyclic check of the JTAG chain. Check target power. Check target connection. • There are unknown parts in the JTAG chain. Please use the option /IROFFS= to specify the instr. reg. offset of the CPU. If there are unknown parts in the JTAG chain, the program isn’t able to determine the logical position of the CPU’s instruction register. JTAG_ADSP-21xxxa.doc 19 JTAG-Booster for Analog Devices ADSP-21xxx • There is no Analog Devices ADSP-21xxx in the JTAG chain No Analog Devices ADSP-21xxx was found in the JTAG chain. Check the target power. Try with option /DRIVER=4 again. • Value of option /FILE-OFFSET out of range The value of the option /FILE-OFFSET= points behind end of file. • wrong driver # The value specified with the option /DRIVER= is out of range. • wrong Identifier (xxxx) No valid identifier found. Check the specified chip select signal and the bus width. Try with the option /DEVICE= . • Wrong length of boundary scan register. Should be 363 for a Analog Devices ADSP-21060/21061/21062. (Should be 285 for a Analog Devices ADSP-21065/Should be 481 for a Analog Devices ADSP-21161.) The length of the boundary scan register of the selected part (if there are more than one in the chain) does not fit to the Analog Devices ADSP-21xxx. Check the target connection. Check the target CPU type. Check the settings for /IROFFS= and /CPUPOS= , if there are several parts in the JTAG chain. 20 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 1.10. Initialization file JTAGxxx.INI This file is used to define the default direction and level of all CPU signals. This file must be carefully adapted to your design with the Analog Devices ADSP21xxx. The Target-Entry is used to identify your design which is displayed with most commands. When the program JTAGxxx.EXE is started it scans the current directory for an existing initialization file named JTAGxxx.INI. If no entry is found the default values are used. You may also specify the initialization file with the option /INI= . If the specified file isn't found, the program aborts with an error message. The CPU pins can also be used with the functions /BLINK (chapter 2.9), /PIN? (chapter 2.10) and /SAMPLE (chapter 2.11) to test the signals on your design. The sample file below represents the values which are used for default initialization when no initialization file could be found in the current directory and no initialization file is specified with the option /INI=. Changes to the structure of the file could result in errors. Remarks can be added by using //. JTAG_ADSP-21xxxa.doc 21 JTAG-Booster for Analog Devices ADSP-21xxx Sample File JTAG060.INI: // Description file for Analog Devices ADSP-21xxx Target: Analog Devices SHARC EZ-KIT // All chip select signals are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults. // Pin names are defined in upper case. // Low active signals are signed with a trailing #. // Group A: All pins in this group must be set to the same direction // This pins are bidirectional L5CLK Inp // Link Port Clock L5DAT0 Inp // Link Port Data L5DAT1 Inp // L5DAT2 Inp // L5DAT3 Inp // // Group B: All pins in this group must be set to the same direction // This pins are bidirectional L4CLK Inp // Link Port Clock L4DAT0 Inp // Link Port Data L4DAT1 Inp // L4DAT2 Inp // L4DAT3 Inp // // Group C: All pins in this group must be set to the same direction // This pins are bidirectional L3CLK Inp // Link Port Clock L3DAT0 Inp // Link Port Data L3DAT1 Inp // L3DAT2 Inp // L3DAT3 Inp // // Group D: All pins in this group must be set to the same direction // This pins are bidirectional L2CLK Inp // Link Port Clock L2DAT0 Inp // Link Port Data L2DAT1 Inp // L2DAT2 Inp // L2DAT3 Inp // 22 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx // Group E: All pins in this group must be set to the same direction // This pins are bidirectional L1CLK Inp // Link Port Clock L1DAT0 Inp // Link Port Data L1DAT1 Inp // L1DAT2 Inp // L1DAT3 Inp // // Group F: All pins in this group must be set to the same direction // This pins are bidirectional L0CLK Inp // Link Port Clock L0DAT0 Inp // Link Port Data L0DAT1 Inp // L0DAT2 Inp // L0DAT3 Inp // // Group G: // // // DATA0 DATA1 DATA2 DATA3 DATA4 DATA5 DATA6 DATA7 DATA8 DATA9 DATA10 DATA11 DATA12 DATA13 DATA14 DATA15 DATA16 DATA17 DATA18 DATA19 DATA20 DATA21 DATA22 All pins in this group must be set to the same direction This pins are bidirectional This group is switched between output/active and input/tristate during programming of Flash-EPROMs Inp // External Bus Data Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // = Boot-ROM D0 Inp // = Boot-ROM D1 Inp // = Boot-ROM D2 Inp // = Boot-ROM D3 Inp // = Boot-ROM D4 Inp // = Boot-ROM D5 Inp // = Boot-ROM D6 JTAG_ADSP-21xxxa.doc 23 JTAG-Booster for Analog Devices ADSP-21xxx DATA23 DATA24 DATA25 DATA26 DATA27 DATA28 DATA29 DATA30 DATA31 DATA32 DATA33 DATA34 DATA35 DATA36 DATA37 DATA38 DATA39 DATA40 DATA41 DATA42 DATA43 DATA44 DATA45 DATA46 DATA47 // Group H: // // // // // PAGE DMAG1# DMAG2# WR# RD# ADRCLK 24 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // = Boot-ROM D7 // // // // // // // // // // // // // // // // // // // // // // // // All pins in this group must be set to the same direction DMAG1#, DMAG2# and ADRCLK are tristateable outputs but may not be read back. PAGE, RD# and WR# are bidirectional pins. This group is switched to output/active during programming of Flash-EPROMs. Out,Lo // DRAM Page Boundary Out,Hi // DMA Grant 1, DMA Channel 7 Out,Hi // DMA Grant 2, DMA Channel 8 Out,Hi // Memory Write Strobe = WE# of Flash-EPROM Out,Hi // Memory Read Strobe = OE# of Flash-EPROM Out,Lo // Clock Output Reference JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx // Group I: All pins in this group must be set to the same direction // This pins are bidirectional // For Flash programming this pins must be set to output. SW# Out,Hi // Synchronous Write Select MS0# Out,Hi // Memory Select Line MS1# Out,Hi // Memory Select Line MS2# Out,Hi // Memory Select Line MS3# Out,Hi // Memory Select Line ADDR31 Out,Lo // ADDR30 Out,Lo // ADDR29 Out,Lo // ADDR28 Out,Lo // ADDR27 Out,Lo // ADDR26 Out,Lo // ADDR25 Out,Lo // ADDR24 Out,Lo // ADDR23 Out,Lo // ADDR22 Out,Lo // ADDR21 Out,Lo // ADDR20 Out,Lo // ADDR19 Out,Lo // ADDR18 Out,Lo // ADDR17 Out,Lo // ADDR16 Out,Lo // ADDR15 Out,Lo // ADDR14 Out,Lo // ADDR13 Out,Lo // ADDR12 Out,Lo // ADDR11 Out,Lo // ADDR10 Out,Lo // ADDR9 Out,Lo // ADDR8 Out,Lo // ADDR7 Out,Lo // ADDR6 Out,Lo // ADDR5 Out,Lo // ADDR4 Out,Lo // ADDR3 Out,Lo // ADDR2 Out,Lo // ADDR1 Out,Lo // ADDR0 Out,Lo // JTAG_ADSP-21xxxa.doc 25 JTAG-Booster for Analog Devices ADSP-21xxx // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as input. L5ACK Inp // Link Port Acknowledge L4ACK Inp // Link Port Acknowledge L3ACK Inp // Link Port Acknowledge L2ACK Inp // Link Port Acknowledge L1ACK Inp // Link Port Acknowledge L0ACK Inp // Link Port Acknowledge BR1# Inp // Multiprocessing Bus Request BR2# Inp // Multiprocessing Bus Request BR3# Inp // Multiprocessing Bus Request BR4# Inp // Multiprocessing Bus Request BR5# Inp // Multiprocessing Bus Request BR6# Inp // Multiprocessing Bus Request ACK Inp // Memory Acknowledge HBG# Inp // Host Bus Grant RFS0 Inp // Receive Frame Sync RCLK0 Inp // Receive Clock TFS0 Inp // Transmit Frame Sync TCLK0 Inp // Transmit Clock RFS1 Inp // Receive Frame Sync RCLK1 Inp // Receive Clock TFS1 Inp // Transmit Frame Sync TCLK1 Inp // Transmit Clock BMS# Out,Hi // Boot Memory Select = CS# of Flash-EPROM FLAG0 Out,Lo // Flag Pin = LEx FLAG1 Out,Hi // Flag Pin = LEx FLAG2 Out,Lo // Flag Pin = LEx FLAG3 Out,Hi // Flag Pin = LEx // The direction of each following pin can be set independent of the others, // but this pins can not be read back. REDY Inp // Host Bus Acknowledge DT0 Out,Lo // Data Transmit DT1 Out,Lo // Data Transmit EMU# Inp // Emulation Status // The following pin has an open drain output with a weak pull up. // The pin is bidirectional. CPA# Inp // Core Priority Access // The following pins are output only pins. 26 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx // Setting to input (tristate) one of these pins results in an error. ICSA Out,Lo // Reserved Output TIMEXP Out,Lo // Timer Expired // The following pins are input only. // Setting to output of one of these pins results in an error. // Declaration of the direction of these pins is optional. IRQ0# Inp // Interrupt Request IRQ1# Inp // Interrupt Request IRQ2# Inp // Interrupt Request EBOOT Inp // EPROM Boot Select, EBOOT=1 -> Boot from EPROM RESET# Inp // Processor Reset RPBA Inp // Rotating Priority Bus Arbitration Select LBOOT Inp // Link Boot, is Low for EPROM boot ID0 Inp // Multiprocessing ID ID1 Inp // Multiprocessing ID ID2 Inp // Multiprocessing ID CLKIN Inp // Clock In CS# Inp // Chip Select Input DR0 Inp // Data Receive DR1 Inp // Data Receive HBR# Inp // Host Bus Request DMAR1# Inp // DMA Request 1, DMA Channel 7 DMAR2# Inp // DMA Request 2, DMA Channel 8 SBTS# Inp // Suspend Bus Three-State JTAG_ADSP-21xxxa.doc 27 JTAG-Booster for Analog Devices ADSP-21xxx Sample File JTAG065.INI: // Description file for Analog Devices ADSP-21065 Target: Generic Target with ADSP-21065 // All chip select signals are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults. // Pin names are defined in upper case. // Low active signal are signed with a trailing #. // Group A: // // // DATA0 DATA1 DATA2 DATA3 DATA4 DATA5 DATA6 DATA7 DATA8 DATA9 DATA10 DATA11 DATA12 DATA13 DATA14 DATA15 DATA16 DATA17 DATA18 DATA19 DATA20 DATA21 DATA22 DATA23 DATA24 DATA25 DATA26 DATA27 DATA28 DATA29 28 All pins in this group must be set to the same direction This pins are bidirectional This group is switched between output/active and input/tristate during programming of Flash-EPROMs Inp // = Boot-ROM D0 Inp // = Boot-ROM D1 Inp // = Boot-ROM D2 Inp // = Boot-ROM D3 Inp // = Boot-ROM D4 Inp // = Boot-ROM D5 Inp // = Boot-ROM D6 Inp // = Boot-ROM D7 Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // Inp // JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx DATA30 DATA31 Inp Inp // // // Group B: All pins in this group must be set to the same direction // This pins are bidirectional // For Flash programming this pins must be set to output. ADDR23 Out,Lo // ADDR22 Out,Lo // ADDR21 Out,Lo // ADDR20 Out,Lo // ADDR19 Out,Lo // ADDR18 Out,Lo // ADDR17 Out,Lo // ADDR16 Out,Lo // ADDR15 Out,Lo // ADDR14 Out,Lo // ADDR13 Out,Lo // ADDR12 Out,Lo // ADDR11 Out,Lo // ADDR10 Out,Lo // ADDR9 Out,Lo // ADDR8 Out,Lo // ADDR7 Out,Lo // ADDR6 Out,Lo // ADDR5 Out,Lo // ADDR4 Out,Lo // ADDR3 Out,Lo // ADDR2 Out,Lo // ADDR1 Out,Lo // ADDR0 Out,Lo // // Group C: // // // // // DMAG1# DMAG2# WR# RD# MS0# MS1# All pins in this group must be set to the same direction DMAG1# and DMAG2# are tristateable outputs but can't be read back. RD#, WR#, SW# and MSx# are bidirectional pins. This group is switched to output/active during programming of Flash-EPROMs. Out,Hi // DMA Grant 1, DMA Channel 7 Out,Hi // DMA Grant 2, DMA Channel 8 Out,Hi // Memory Write Strobe = WE# of Flash-EPROM Out,Hi // Memory Read Strobe = OE# of Flash-EPROM Out,Hi // Memory Select Line Out,Hi // Memory Select Line JTAG_ADSP-21xxxa.doc 29 JTAG-Booster for Analog Devices ADSP-21xxx MS2# MS3# SW# // Group D: // // // // SDCLK0 RAS# CAS# SDWE# DQM SDCKE SDA10 Out,Hi Out,Hi Out,Hi // Memory Select Line // Memory Select Line // Synchronous Write Select All pins in this group must be set to the same direction DQM and SDA10 are tristateable outputs but can't be read back. All others are bidirectional pins. This group is switched to output/active during programming of Flash-EPROMs. Out,Lo // SDRAM clock output Out,Hi // SDRAM row address strobe Out,Hi // SDRAM column address strobe Out,Hi // SDRAM write enable Out,Lo // SDRAM data mask Out,Hi // SDRAM clock enable Out,Lo // SDRAM A10 pin // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as input. BR1# Inp // Multiprocessing Bus Request BR2# Inp // Multiprocessing Bus Request ACK Inp // Memory Acknowledge HBG# Inp // Host Bus Grant RFS0 Inp // Receive Frame Sync RCLK0 Inp // Receive Clock TFS0 Inp // Transmit Frame Sync TCLK0 Inp // Transmit Clock RFS1 Inp // Receive Frame Sync RCLK1 Inp // Receive Clock TFS1 Inp // Transmit Frame Sync TCLK1 Inp // Transmit Clock BMS# Out,Hi // Boot Memory Select = CS# of Flash-EPROM FLAG0 Inp // Flag Pin FLAG1 Inp // Flag Pin FLAG2 Inp // Flag Pin FLAG3 Inp // Flag Pin FLAG4 Inp // Flag Pin FLAG5 Inp // Flag Pin FLAG6 Inp // Flag Pin FLAG7 Inp // Flag Pin FLAG8 Inp // Flag Pin FLAG9 Inp // Flag Pin 30 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx FLAG10 Inp FLAG11 Inp PWM_EVENT1 Inp PWM_EVENT0 Inp SDCLK1 Out,Lo // Flag Pin // Flag Pin // PWM output/event capture // PWM output/event capture // SDRAM clock output // The direction of each following pin can be set independent of the others, // but this pins can not be read back. REDY Inp // Host Bus Acknowledge DT0_A Out,Lo // Data Transmit DT0_B Out,Lo // Data Transmit DT1_A Out,Lo // Data Transmit DT1_B Out,Lo // Data Transmit EMU# Inp // Emulation Status // The following pin has an open drain output with a weak pull up. // The pin is bidirectional. CPA# Inp // Core Priority Access // The following pins are output only pins. // Setting to input (tristate) one of these pins results in an error. BMSTR Out,Hi // Bus Master Output // The following pins are input only. // Setting to output of one of these pins results in an error. // Declaration of the direction of these pins is optional. IRQ0# Inp // Interrupt Request IRQ1# Inp // Interrupt Request IRQ2# Inp // Interrupt Request BSEL Inp // EPROM Boot Select, BSEL=1 -> Boot from EPROM RESET# Inp // Processor Reset ID0 Inp // Multiprocessing ID ID1 Inp // Multiprocessing ID CLKIN Inp // Clock In CS# Inp // Chip Select Input DR0_A Inp // Data Receive DR0_B Inp // Data Receive DR1_A Inp // Data Receive DR1_B Inp // Data Receive HBR# Inp // Host Bus Request DMAR1# Inp // DMA Request 1, DMA Channel 7 DMAR2# Inp // DMA Request 2, DMA Channel 8 SBTS# Inp // Suspend Bus Three-State JTAG_ADSP-21xxxa.doc 31 JTAG-Booster for Analog Devices ADSP-21xxx Sample File JTAG161.INI: // Description file for Analog Devices ADSP-21161 Target: Generic Target with ADSP-21161 // All chip select signals are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults // Pin Names are defined in upper case // Low Active Signal are signed with a trailing # // The following pins are complete bidirectional pins // The direction of each pin can be set independent of the other pins // Each pin can be used as an input EBOOT Inp // EPROM Boot Select, EBOOT=1 -> Boot from EPROM LBOOT Inp // Link Boot, should be low for EBOOT=1 WR# Out,Hi // Memory Write Strobe = WE# of Flash-EPROM RD# Out,Hi // Memory Read Strobe = OE# of Flash-EPROM BMS# Out,Hi // Boot Memory Select = CS# of Flash-EPROM MS0# Out,Hi // Memory Select Lines MS1# Out,Hi // MS2# Out,Hi // MS3# Out,Hi // BMSTR Out,Hi // Bus Master Output EMU# Inp // Emulation Status Output RESET# Inp // Processor Reset Input FLAG11 FLAG10 FLAG9 FLAG8 FLAG7 FLAG6 FLAG5 FLAG4 FLAG3 FLAG2 FLAG1 FLAG0 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // Flag Pins // // // // // // // // // // // IRQ0# IRQ1# IRQ2# ID0 ID1 Inp Inp Inp Inp Inp // Interrupt Request Lines // // // Multiprocessing ID // 32 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx ID2 TIMEXP SBTS# PA# BR6# BR5# BR4# BR3# BR2# BR1# BRST SDCLK0 SDCLK1 SDA10 SDCKE CLKOUT CAS# RAS# HBR# HBG# REDY ACK CS# CLKDBL DQM SDWE# CLK_CFG1 CLK_CFG0 DMAR2# DMAG2# DMAR1# DMAG1# NC1 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Hi Out,Hi Inp Inp Inp Inp Inp Inp Out,Hi Out,Hi Inp Inp Inp Out,Hi Inp Out,Hi Inp // // Timer Expired // Suspend Bus & Three-State // Priority Access // Multiprocessing Bus Request // // // // // // Sequential Burst Access // SDRAM Clock Output 0 // SDRAM Clock Output 1 // SDRAM A10 Pin // SDRAM Clock Enable // Local Clock Out // SDRAM Column Access Strobe // SDRAM Row Acess Strobe // Host Bus Request // Host Bus Grant // Host Bus Acknowledge // Memory Acknowlwdge // Chip Select ADSP-21161 // Crystal Double Mode Enable // SDRAM Data Mask // SDRAM Write Enable // Core/CLKIN Ratio Control // // DMA Request 2 // DMA Grant 2 // DMA Request 1 // DMA Grant 1 // L0DAT0 L0DAT1 L0DAT2 L0DAT3 L0DAT4 L0DAT5 L0DAT6 L0DAT7 L0ACK Inp Inp Inp Inp Inp Inp Inp Inp Inp // Link Port 0 Data // // // // // // // // Link Port 0 Acknowledge JTAG_ADSP-21xxxa.doc 33 JTAG-Booster for Analog Devices ADSP-21xxx L0CLK Inp // Link Port 0 Clock L1DAT0 L1DAT1 L1DAT2 L1DAT3 L1DAT4 L1DAT5 L1DAT6 L1DAT7 L1CLK L1ACK Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // Link Port 1 Data // // // // // // // // Link Port 1 Acknowledge // Link Port 1 Clock FS0 SCLK0 D0A D0B Inp Inp Inp Inp // Transmit/Receive Frame Sync // Transmit/Receive Serial Clock // Data Transmit/Receive Channel A // Data Transmit/Receive Channel B FS1 SCLK1 D1A D1B Inp Inp Inp Inp // // // // SFS2 SCLK2 D2A D2B Inp Inp Inp Inp // // // // SFS3 SCLK3 D3A D3B Inp Inp Inp Inp // // // // SPIDS# SPICLK MOSI MISO RPBA# Inp Inp Inp Inp Inp // Serial Peripheral Interface Slave Device Select // Serial Peripheral Interface Clock Signal // SPI Master Out Slave // SPI Master In Slave Out // Rotating Priority Bus Arbitration Select 34 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx // The following pins are complete bidirectional pins // The direction of each pin can be set independent of the other pins // For Flash Programming these pins must be set to output ADDR0 Out,Lo // External Bus Address ADDR1 Out,Lo // ADDR2 Out,Lo // ADDR3 Out,Lo // ADDR4 Out,Lo // ADDR5 Out,Lo // ADDR6 Out,Lo // ADDR7 Out,Lo // ADDR8 Out,Lo // ADDR9 Out,Lo // ADDR10 Out,Lo // ADDR11 Out,Lo // ADDR12 Out,Lo // ADDR13 Out,Lo // ADDR14 Out,Lo // ADDR15 Out,Lo // ADDR16 Out,Lo // ADDR17 Out,Lo // ADDR18 Out,Lo // ADDR19 Out,Lo // ADDR20 Out,Lo // ADDR21 Out,Lo // ADDR22 Out,Lo // ADDR23 Out,Lo // // The following pins are complete bidirectional pins // These pins are switched between output/active and input/tristate during // programming of Flash-EPROMs DATA16 Inp // = Boot-ROM D0 DATA17 Inp // = Boot-ROM D1 DATA18 Inp // = Boot-ROM D2 DATA19 Inp // = Boot-ROM D3 DATA20 Inp // = Boot-ROM D4 DATA21 Inp // = Boot-ROM D5 DATA22 Inp // = Boot-ROM D6 DATA23 Inp // = Boot-ROM D7 DATA24 Inp // DATA25 Inp // DATA26 Inp // DATA27 Inp // JTAG_ADSP-21xxxa.doc 35 JTAG-Booster for Analog Devices ADSP-21xxx DATA28 DATA29 DATA30 DATA31 DATA32 DATA33 DATA34 DATA35 DATA36 DATA37 DATA38 DATA39 DATA40 DATA41 DATA42 DATA43 DATA44 DATA45 DATA46 DATA47 36 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // // // // // // // // // // // // // // // // // // // // JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 1.11. Supported flash devices Type JTAGxxx /LIST [optionlist] to get a online list of all flash types which could be used with the /DEVICE= option. See separate file JTAG_V4xx_FLASHES.pdf to get a complete list of supported flash types. JTAG_ADSP-21xxxa.doc 37 JTAG-Booster for Analog Devices ADSP-21xxx 2. JTAGxxx Parameter Description When you start JTAGxxx.EXE without any parameters the following help screen with all possible functions and options is displayed: JTAGxxx --- JTAG utility for Analog Devices ADSP-21xxx Copyright © FS FORTH-SYSTEME GmbH, Breisach Version 4.xx of mm/dd/yyyy Programming of Flash-EPROMs and hardware tests on targets with the Analog Devices ADSP-21xxx. The JTAG-Booster is needed to connect the parallel port of the PC to the JTAG port of the Analog Devices ADSP-21xxx. Usage: JTAGxxx /function [filename] [/option_1] ... [/option_n] Supported functions: /P : Program a Flash Device /R : Read a Flash Device to file /V : Verify a Flash Device with file /DUMP : Make a target dump /PI2C : Program an I2C Device with file /RI2C : Read an I2C Device to file /VI2C : Verify an I2C Device with file /DUMPI2C : Make a dump of an I2C Device /BLINK : Toggle a CPU pin /PIN? : Test a CPU pin /SAMPLE : Test a CPU pin while the CPU is running /SNAP : Test all CPU pins while CPU is running /LIST : Print a list of supported Flash devices 38 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx Supported Options: /BMS /MS0 /NOCS /NOWRSETUP /PAUSE /P /ERASEALL /LPT1 /32BIT /16BIT L= /FILE-OFFSET= /DELAY= /DEVICE-BASE= /DM= /IROFFS= /I2CCLK= /I2CDAT= /WATCH= /OUT= /MS1 /TOP /NODUMP /LPT2 /8BIT /FO= /DB= /CPUPOS= /I2CDATI= /INI= /MS2 /BYTE-MODE /NOERASE /LPT3 /NOMAN /OFFSET= /DRIVER= /DEVICE= /I2CDATO= /REP /MS3 /BM /LATTICE /LPT-BASE= /LENGTH= /O= /DATA-MASK= /PIN= I2CBIG The following options are valid for most functions: /DRIVER=x with x = 1,2,3,4 A driver for the interface to the JTAG-BOOSTER on the parallel port may be specified. /DRIVER=1 selects the fastest available driver, /DRIVER=4 selects the slowest one. Use a slower driver if there are problems with JTAGBOOSTER. Default: /DRIVER=3 /INI=file An initialization file may be specified. By default the current directory is searched for the file JTAGxxx.INI. If this file is not found and no initialization file is specified in the command line, default initialization values are used (see also chapter 1.10 “Initialization file JTAGxxx.INI”). Default: /INI=JTAGxxx.INI /LATTICE For demonstration purposes this software works with the Lattice ispLSI-Adapter, too. With the option /LATTICE you can simulate the speed achievable with the simple ispLSI-Adapter. /LPT1 /LPT2 /LPT3 A printer port may be specified where the JTAG-Booster resides. Default: /LPT1 JTAG_ADSP-21xxxa.doc 39 JTAG-Booster for Analog Devices ADSP-21xxx /LPT-BASE The physical I/O-Address of printer port may be specified instead of the logical printer name. Useful option, if you work with WinNT or Win2000, because the standard printer port is mapped as LPT2 here. Use the option /LPT-BASE=378 to get a command line which works independent of the operation system. /OUT=file_or_device All screen outputs are redirected to the specified file or device. Note that you can't redirect to the same parallel port where the JTAG-Booster resides. Default: /OUT=CON /PAUSE With the option /PAUSE you can force the program to stop after each screen. Please do not use this option if you redirect the output to a file. Abbreviation: /P /WATCH= With the option /WATCH= a pin can be specified, which is toggled twice per second, while the program is active. This pin may be the trigger of a watchdog. This pin must be specified as output in the initialization file. /IROFFS= Specifies the position of the Analog Devices ADSP-21xxx instruction register within the JTAG chain. In most cases this option is not needed. Default: /IROFFS=0 /CPUPOS= Specifies the position of the Analog Devices ADSP-21xxx within the JTAG chain. Default: /CPUPOS=0 40 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 2.1. Program a Flash Device Usage: JTAGxxx /P filename [optionlist] The specified file is programmed into the flash memory. The flash status is polled after programming of each cell (cell=8, 16 or 32 bit, depending on current data bus width). In case of a programming error, the contents of the flash memory is written to a file with the extension DMP. If you want a complete verify after programming, please use an additional command line with the verify function. See chapter 2.3 “Verify a Flash Device with file”. In most cases this additional verify step is not needed. The type of the flash device is normally detected by the software. When autodetection fails you should use the /DEVICE= option together with /8BIT or /16BIT or /32BIT to set the right flash device and configuration. The known flash devices are shown in chapter 1.11 “Supported flash devices”. Options: /DEVICE=devicename The flash device is detected automatically by switching to autoselect mode. In case of trouble you should select the flash device by using this parameter to avoid autodetection. Combine this option with one of the following options which specify the data bus width and the option /BYTE-MODE if applicable. /8BIT /16BIT /32BIT Specifies the data bus width to the target flash device. You can speed up autodetection, if you specify the correct data bus size. You need this option together with the option /DEVICE= to explicit specify a specific flash configuration. /BYTE-MODE If there is a flash device connected to the CPU which does have a byte mode pin (8 bit and 16/32 bit bus mode), you can force it to be used as 8 bit mode with the option /BYTE-MODE. In most cases this option will not be needed. JTAG_ADSP-21xxxa.doc 41 JTAG-Booster for Analog Devices ADSP-21xxx /NOMAN If you use a flash device which is identical to one of the supported parts, but is from a different manufacturer, with this option you can suppress the comparison of the manufacturer identification code. We recommend to use this option together with the /DEVICE= option to avoid failures in autodetection. /DEVICE-BASE=hhhhhh1 Here you can specify a flash device starting address. In most cases, where the flash device is selected with one of the CPUs chip select pins, this parameter is not needed. But if there is any decoding logic in your hardware, this option will be needed. Especially, if there are several flash banks connected to one chip select and a sub decoding logic generates chip selects for these flash banks, this option can be used to select a specific flash bank. Default: /DEVICE-BASE=0 Abbreviation: /DB= /OFFSET=hhhhhh The programming starts at an offset of hhhhhh relative to the start address of the flash device. If the offset is negative, the offset specifies an address relative to the end of the flash device. See also option /TOP Default: /OFFSET=0 Abbreviation: /O= /TOP If the option /TOP is used the option /OFFSET= specifies the address where the programming ends (plus one) instead of the starting address. This option is very important for Intel CPU architectures, because target execution always starts at the top of the address space. /FILE-OFFSET=hhhhhh If FILE-OFFSET is specified, the first hhhhhh bytes of the file are skipped and not programmed to target. Default: /FILE-OFFSET=0 Abbreviation: /FO= 1 hhhhhh=number base is hex 42 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx /LENGTH=hhhhhh The number of programmed bytes may be limited to LENGTH. If no LENGTH is specified the whole file is programmed. Default: /LENGTH=4000000 (64 MByte) Abbreviation: /L= /NODUMP In case of a verify error the contents of the flash memory is written to a file with the extension .DMP. With /NODUMP you can suppress this feature. /ERASEALL Erase the whole flash device. If this option isn't set, only those blocks are erased where new data should be written to. /NOERASE This option prevents the flash device from being erased. /BMS /MS0 /MS1 /MS2 /MS3 This options may be used to specify one or more chip select signals to the flash memory. The used chip selects must be defined as output and inactive in the initialization file. (See chapter 1.10 “Initialization file JTAGxxx.INI”.) Default: /BMS /NOCS Use this option to switch off all chip select signals. This may be necessary if the device's chip select is generated via a normal decoder instead of using the Analog Devices ADSP-21xxx chip select unit. /NOWRSETUP By default write cycles to the Flash EPROM are realized with three steps: 1. set address/data 2. write strobe active 3. write strobe inactive. In most cases it is possible to set the write strobe coincident with setting of address and data by specifying the option /NOWRSETUP. This increases the programming speed by 50%. JTAG_ADSP-21xxxa.doc 43 JTAG-Booster for Analog Devices ADSP-21xxx Examples: JTAGxxx /P ROMDOS.ROM /L=20000 /TOP This example programs up to 128 Kbytes of the file ROMDOS.ROM (with i.e. 512 Kbytes) to the top of the boot flash memory. JTAGxxx /P CE.ROM /32BIT /MS0 This example programs the file CE.ROM to the 32 Bit Flash-EPROM connected to MS0#. 44 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 2.2. Read a Flash Device to file Usage: JTAGxxx /R filename [optionlist] The contents of a flash device is read and written to a file. The type of the flash device is normally detected by the software. When autodetection fails you should use the /DEVICE= option together with /8BIT or /16BIT or /32BIT to set the right flash device and configuration. The known devices are shown in chapter 1.11 “Supported flash devices”. Options: /DEVICE=devicename See function /P (Chapter 2.1) /8BIT /16BIT /32BIT See function /P (Chapter 2.1) /BYTE-MODE See function /P (Chapter 2.1) /NOMAN See function /P (Chapter 2.1) /DEVICE-BASE=hhhhhh2 See function /P (Chapter 2.1) /OFFSET=hhhhhh Reading of the flash memory starts at an offset of hhhhhh relative to the start address of the flash device. If the offset is negative, the offset specifies a address relative to the end of the flash device. See also option /TOP. Default: /OFFSET=0 Abbreviation: /O= 2 hhhhhh=number base is hex JTAG_ADSP-21xxxa.doc 45 JTAG-Booster for Analog Devices ADSP-21xxx /TOP If the option /TOP is used the option /OFFSET= specifies the address where reading ends (plus one) instead of the starting address. /LENGTH=hhhhhh The number of read bytes may be limited to LENGTH. If no LENGTH is specified the whole flash device is read (if no offset is specified). /BMS /MS0 /MS1 /MS2 /MS3 /NOCS See function /P (Chapter 2.1) /NOWRSETUP See function /P (Chapter 2.1) Please note: In the function /R write cycles are needed to detect the type of the flash memory. Example: JTAGxxx /R BIOS.ABS /L=10000 /TOP This example may be used to read the upper most 64 Kbyte of the flash memory to the file BIOS.ABS. 46 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 2.3. Verify a Flash Device with file Usage: JTAGxxx /V filename [optionlist] The contents of a flash device is compared with the specified file. If there are differences the memory is dumped to a file with the extension DMP. The type of flash device is normally detected by the software. When autodetect fails you should use the /DEVICE= option together with /8BIT or /16BIT or /32BIT to set the right flash device and configuration. The known devices are shown in chapter 1.11 “Supported flash devices”. Options: /DEVICE=devicename See function /P (Chapter 2.1) /8BIT /16BIT /32BIT See function /P (Chapter 2.1) /BYTE-MODE See function /P (Chapter 2.1) /NOMAN See function /P (Chapter 2.1) /DEVICE-BASE=hhhhhh See function /P (Chapter 2.1) /OFFSET=hhhhhh See function /P (Chapter 2.1) /TOP See function /P (Chapter 2.1) /FILE-OFFSET=hhhhhh See function /P (Chapter 2.1) JTAG_ADSP-21xxxa.doc 47 JTAG-Booster for Analog Devices ADSP-21xxx /LENGTH=hhhhhh See function /P (Chapter 2.1) /NODUMP See function /P (Chapter 2.1) /BMS /MS0 /MS1 /MS2 /MS3 /NOCS See function /P (Chapter 2.1) /NOWRSETUP See function /P (Chapter 2.1) Please note: In the function /V write cycles are needed to detect the type of the flash memory. Example: JTAGxxx /V ROMDOS.ROM /L=20000 /TOP This example may be used to verify the upper most 128 Kbytes of the flash memory with the file ROMDOS.ROM (with i.e. 512 Kbytes). 48 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 2.4. Dump target memory Usage: JTAGxxx /DUMP [optionlist] A Hex-Dump of the target memory is printed on the screen, if not redirected to file or device. Options: /8BIT /16BIT /32BIT Default: /8BIT /OFFSET=hhhhhh The memory dump starts at an offset of hhhhhh plus the device start address (see option /DEVICE-BASE=). Default: /OFFSET=0 Abbreviation: /O= /DEVICE-BASE=hhhhhh3 The device start address is used as an additional offset. This gives the function /DUMP the same behavior as function /P /V and /R. Default: /DEVICE-BASE=0 Abbreviation: /DB= /TOP If the option /TOP is used the option /OFFSET= specifies the address where the dump ends (plus one) instead of the starting address /LENGTH=hhhhhh Default: /LENGTH=100 Abbreviation: /L= /BMS /MS0 /MS1 /MS2 /MS3 /NOCS See function /P (Chapter 2.1) Default: /BMS 3 hhhhhh=number base is hex JTAG_ADSP-21xxxa.doc 49 JTAG-Booster for Analog Devices ADSP-21xxx Example: JTAGxxx /DUMP /BMS This example makes a memory dump of the first 256 bytes of the Boot-EPROM. 50 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 2.5. Program an I²C-Device Usage: JTAGxxx /PI2C filename [/I2CBIG] [optionlist] The specified file is programmed to an I²C-Device (i.e. a serial EEPROM) connected to pins of the CPU. Finally a complete verify is done. If the verify fails, the contents of the I²C-Device is written to a file with the extension DMP. Two methods to connect the I²C-Device to the CPU are supported. The first method is to use two CPU pins, one pin for clock output (I2CCLK) and one pin for serial data input and output (I2CDAT). The second method is to use one pin for clock output (I2CCLK), one for serial data input (I2CDATI) and one for serial data output (I2CDATO). Options: /I2CBIG Specify this option if there is a device which needs a three byte address instead of a two byte address. This option must be the first option after the filename. /DEVICE-BASE=hhhhhh This option specifies an I²C device starting address. The default values are chosen to access an serial EEPROM. Default: /DEVICE-BASE=5000 (if option /I2CBIG omitted) Default: /DEVICE-BASE=500000 (if option /I2CBIG specified) /OFFSET=hhhhhh The programming starts at an offset of hhhhhh relative to the start address of the I²C-Device. Default: /OFFSET=0 Abbreviation: /O= /FILE-OFFSET=hhhhhh If FILE-OFFSET is specified, the first hhhhhh bytes of the file are skipped and not programmed to target. Default: /FILE-OFFSET=0 Abbreviation: /FO= JTAG_ADSP-21xxxa.doc 51 JTAG-Booster for Analog Devices ADSP-21xxx /LENGTH=hhhhhh The number of programmed bytes may be limited to LENGTH. If no LENGTH is specified the whole file is programmed. Abbreviation: /L= /NODUMP In case of a verify error the contents of the I²C-Device is written to a file with the extension .DMP. With option /NODUMP you can suppress this feature. /I2CCLK=pin_name Specifies the CPU pin used for serial clock output. /I2CDAT=pin_name Specifies the CPU pin used for serial data input and output. Pin_name must specify a bidirectional pin otherwise an error message occurs. Instead of one bidirectional pin one pin for serial data input and one for serial data output may be used. See option /I2CDATO= and /I2CDATI= . /I2CDATO=pin_name Specifies the CPU pin used for serial data output. Pin_name must specify a output pin otherwise an error message occurs. /I2CDATI=pin_name Specifies the CPU pin used for serial data input. Pin_name must specify a input pin otherwise an error message occurs. Example: JTAGxxx /PI2C EEPROM.CFG /I2CCLK=FLAG0 /I2CDAT=FLAG1 This example loads the file EEPROM.CFG to a serial EEPROM connected to the pins FLAG0 and FLAG1 of the Analog Devices ADSP-21xxx 52 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 2.6. Read an I²C-Device to file Usage: JTAGxxx /RI2C filename [/I2CBIG] /L=hhhhhh [optionlist] The contents of an I²C-Device (i.e. a serial EEPROM) is read and written to a file. The option /LENGTH= must be specified. Options: /I2CBIG This option must be the first option after the filename. See function /PI2C (Chapter 2.5) /DEVICE-BASE=hhhhhh See function /PI2C (Chapter 2.5) /OFFSET=hhhhhh Reading of the I²C-Device starts at an offset of hhhhhh relative to the start address of the I²C-Device. Default: /OFFSET=0 Abbreviation: /O= /LENGTH=hhhhhh The number of read bytes must be specified otherwise an error message occurs. Abbreviation: /L= /I2CCLK=pin_name See function /PI2C (Chapter 2.5) /I2CDAT=pin_name See function /PI2C (Chapter 2.5) /I2CDATO=pin_name See function /PI2C (Chapter 2.5) /I2CDATI=pin_name See function /PI2C (Chapter 2.5) JTAG_ADSP-21xxxa.doc 53 JTAG-Booster for Analog Devices ADSP-21xxx Example: JTAGxxx /RI2C EEPROM.CFG /I2CCLK=GP26 /I2CDAT=GP27 /L=100 This example reads 256 bytes from a serial EEPROM to the file EEPROM.CFG. The serial EEPROM is connected to the pins CP26 and GP27 of the Analog Devices ADSP-21xxx. 54 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 2.7. Verify an I²C-Device with file Usage: JTAGxxx /VI2C filename [/I2CBIG] [optionlist] The contents of an I²C-Device (i.e. a serial EEPROM) is compared with the specified file. If there are differences the contents of the I²C -Device is written to a file with the extension DMP. Options: /I2CBIG This option must be the first option after the filename. See function /PI2C (Chapter 2.5) /DEVICE-BASE=hhhhhh See function /PI2C (Chapter 2.5) /OFFSET=hhhhhh See function /PI2C (Chapter 2.5) /FILE-OFFSET=hhhhhh See function /PI2C (Chapter 2.5) /LENGTH=hhhhhh See function /PI2C (Chapter 2.5) /NODUMP See function /PI2C (Chapter 2.5) /I2CCLK=pin_name See function /PI2C (Chapter 2.5) /I2CDAT=pin_name See function /PI2C (Chapter 2.5) /I2CDATO=pin_name See function /PI2C (Chapter 2.5) JTAG_ADSP-21xxxa.doc 55 JTAG-Booster for Analog Devices ADSP-21xxx /I2CDATI=pin_name See function /PI2C (Chapter 2.5) Example: JTAGxxx /VI2C EEPROM.CFG /I2CCLK=GP26 /I2CDAT=GP27 This example verifies 256 bytes from a serial EEPROM with the file EEPROM.CFG. The serial EEPROM is connected to the pins CP26 and GP27 of the Analog Devices ADSP-21xxx. 56 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 2.8. Dump an I²C-Device Usage: JTAGxxx /DUMPI2C [/I2CBIG] [optionlist] A Hex-Dump of an I²C-Device is printed on the screen, if not redirected to file or device. Options: /I2CBIG This option must be the first option. See function /PI2C (Chapter 2.5) /DEVICE-BASE=hhhhhh See function /PI2C (Chapter 2.5) /OFFSET=hhhhhh4 The memory dump starts at an offset of hhhhhh. Default: /OFFSET=0 Abbreviation: /O= /LENGTH=hhhhhh Default: /LENGTH=100 Abbreviation: /L= /I2CCLK=pin_name Specifies the CPU pin used for serial clock output. /I2CDAT=pin_name Specifies the CPU pin used for serial data input and output. Pin_name must specify a bidirectional pin otherwise an error message occurs. Instead of one bidirectional pin one pin for serial data input and one for serial data output may be used. See option /I2CDATO= and /I2CDATI= . /I2CDATO=pin_name Specifies the CPU pin used for serial data output. Pin_name must specify a output pin otherwise an error message occurs. 4 hhhhhh=number base is hex JTAG_ADSP-21xxxa.doc 57 JTAG-Booster for Analog Devices ADSP-21xxx /I2CDATI=pin_name Specifies the CPU pin used for serial data input. Pin_name must specify a input pin otherwise an error message occurs. Example: JTAGxxx /DUMPI2C /I2CCLK=FLAG0 /I2CDAT=FLAG1 This example makes a memory dump of the first 100h bytes of a serial EEPROM connected to the CPU. 58 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 2.9. Toggle CPU pins Usage: JTAGxxx /BLINK /PIN=pinname [optionlist] This command allows to test the hardware by blinking with LEDs or toggling CPU signals. Faster signals can be generated by setting the delay option to zero. This can be a very helpful feature to watch signals on an oscilloscope. The signal on the defined pin has an duty cycle of 1/2: The level is 67% high and 33% low. Please Note: Not every pin of the Analog Devices ADSP-21xxx may be specified as an output pin. Options: /PIN=pin_name CPU pin to toggle. If the option /PIN= is not specified an error message occurs. Most pins of the list in chapter 1.10 “Initialization file JTAGxxx.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. /DELAY=dddddd5 Time to wait to next change of signal. This option can be adjusted to get optimum signals for measures with the oscilloscope. Default: /DELAY=10000 Example: JTAGxxx /BLINK /PIN=FLAG3 /DELAY=0 This example toggles the FLAG3 pin very fast which can be followed by the use of an oscilloscope. 5 dddddd=number base is decimal JTAG_ADSP-21xxxa.doc 59 JTAG-Booster for Analog Devices ADSP-21xxx 2.10. Polling CPU pins Usage: JTAGxxx /PIN? /PIN=pinname [optionlist] This command allows to test the hardware by polling CPU signals. Please Note: Not every pin of the Analog Devices ADSP-21xxx may be specified as an input pin. Options: /PIN=pin_name CPU pin to poll. If the option /PIN= is not specified an error message occurs. Most pins of the list in chapter 1.10 “Initialization file JTAGxxx.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. Example: JTAGxxx /PIN? /PIN=RESET# This example samples the reset pin of the Analog Devices ADSP-21xxx. 60 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 2.11. Polling CPU pins while the CPU is running Usage: JTAGxxx /SAMPLE /PIN=pinname [optionlist] This command is similar to the function /PIN?. But with this function any pin can be observed, independent of the pin direction. Furthermore the CPU remains in normal operation. Options: /PIN=pin_name CPU pin to poll. If the option /PIN= is not specified an error message occurs. All pins of the list in chapter 1.10 “Initialization file JTAGxxx.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. Example: JTAGxxx /SAMPLE /PIN=FLAG3 This example samples the state of the port pin FLAG3 while the Analog Devices ADSP-21xxx is running. JTAG_ADSP-21xxxa.doc 61 JTAG-Booster for Analog Devices ADSP-21xxx 2.12. Show status of all CPU pins while the CPU is running Usage: JTAGxxx /SNAP [optionlist] This function is similar to the function /SAMPLE, but displays the status of all CPU pins on the screen. The CPU remains in normal operation. The behavior of the function /SNAP depends on the option /REP: With this option specified, the JTAG-Booster samples and displays the state of the CPU pins repetitive. Without this option the status of the pins is displayed only once. Options: /PAUSE Use this option to stop the output after each displayed screen. Don't use this option together with the option /REP or if the output is redirected to a file. Abbreviation /P /REP If this option is specified the status of the pins is sampled and displayed repetitive. In case of many signals the display is separated into several screens. Therefor we recommend to use a video mode with 43 or 50 lines. Use the '+' and the '-' key to switch between different screens. Any other key terminates the program. 62 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx Sample output: This is a sample output for a Analog Devices ADSP-21065 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1 BSEL 1 ADDR22 1 ADDR18 1 ADDR14 1 ADDR10 0 ADDR6 1 ADDR2 1 FLAG1 1 IRQ1# 1 DR0_A 0 DT0_A 1 DR1_A 0 DT1_A 1 BR1# 0 SDCLK0 1 RAS# 1 SDCKE 1 HBG# 0 CLKSEL 1 SW# 1 MS1# 1 FLAG10 0 DATA1 1 DATA5 1 DATA9 0 DATA13 0 DATA17 0 DATA21 0 DATA25 0 DATA29 1 FLAG6 0 ID0 0 SPARE3 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1 BMS# 1 ADDR21 1 ADDR17 1 ADDR13 0 ADDR9 1 ADDR5 1 ADDR1 0 FLAG2 1 IRQ2# 1 DR0_B 0 DT0_B 1 DR1_B 0 DT1_B 1 BR2# 1 DMAR1# 1 CAS# 1 SDA10 1 BMSTR 1 WR# 1 CPA# 1 MS2# 1 FLAG9 0 DATA2 0 DATA6 0 DATA10 0 DATA14 0 DATA18 1 DATA22 0 DATA26 0 DATA30 1 FLAG5 0 EMU# 0 SPARE4 JTAG_ADSP-21xxxa.doc | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1 RESET# 1 ADDR20 1 ADDR16 1 ADDR12 1 ADDR8 0 ADDR4 1 ADDR0 0 FLAG3 1 RFS0 1 TFS0 0 RFS1 0 TFS1 0 PWM_EVENT1 0 CLKIN 1 DMAR2# 1 SDWE# 1 DMAG1# 1 CS# 1 RD# 1 ACK 1 MS3# 1 FLAG8 0 DATA3 0 DATA7 0 DATA11 0 DATA15 0 DATA19 0 DATA23 0 DATA27 0 DATA31 1 FLAG4 0 SPARE1 0 SPARE5 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1 ADDR23 1 ADDR19 1 ADDR15 1 ADDR11 1 ADDR7 1 ADDR3 0 FLAG0 1 IRQ0# 1 RCLK0 1 TCLK0 1 RCLK1 1 TCLK1 0 PWM_EVENT0 0 SDCLK1 1 HBR# 1 DQM 1 DMAG2# 1 SBTS# 0 REDY 1 MS0# 0 FLAG11 0 DATA0 0 DATA4 1 DATA8 0 DATA12 0 DATA16 0 DATA20 0 DATA24 0 DATA28 1 FLAG7 0 ID1 0 SPARE2 0 SPARE6 63 JTAG-Booster for Analog Devices ADSP-21xxx 3. Implementation Information This chapter summarizes some information about the implementation of the JTAG-Booster and describes some restrictions. • The JTAG-Booster currently uses the EXTEST function of the JTAGInterface to perform Flash programming. • The JTAG interface of the Analog Devices ADSP-21xxx does not support an ICODE register. Therefor the analysis of the JTAG chain is not really possible. But we try to avoid unpredictable results by comparing the length of the boundary scan chain with the estimated length. • Refer to the following table for connecting Flash-EPROMs to the Analog Devices ADSP-21xxx: ADSP-21060 signal BMS# 1) MS0# or MS1# or MS2# or MS3# RD# WR# DATA16..23 DATA16..31 DATA16..47 ADSP-21065 signal BMS# 1) MS0# or MS1# or MS2# or MS3# RD# WR# DATA0..7 DATA0..15 DATA0..31 64 8 Bit Flash CS# CS# 16 Bit Flash CS# 32 Bit Flash CS# OE# WE# D0..7 - OE# WE# D0..15 - OE# WE# D0..31 8 Bit Flash CS# CS# 16 Bit Flash CS# 32 Bit Flash CS# OE# WE# D0..7 - OE# WE# D0..15 - OE# WE# D0..31 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx ADSP-21161 signal BMS# 1) MS0# or MS1# or MS2# or MS3# RD# WR# DATA16..23 DATA16..31 DATA16..47 1) 8 Bit Flash CS# CS# 16 Bit Flash CS# 32 Bit Flash CS# OE# WE# D0..7 - OE# WE# D0..15 - OE# WE# D0..31 Only a 8 bit Boot-Flash is supported by the Analog Devices ADSP-21xxx JTAG_ADSP-21xxxa.doc 65 JTAG-Booster for Analog Devices ADSP-21xxx 4. Converter Program HEX2BIN.EXE Since the JTAG-Booster software is not able to handle Intel-HEX or Motorola SRecord files, an separate converter tool is delivered with this product package. Five types of HEX formats can be converted to BIN file: • I • D : Digital Research • M : MOTOROLA S HEX format (BYTE oriented) • T : TEKTRONICS HEX format (BYTE oriented) • H : Intel HEX-32 : INTEL HEX format (BYTE oriented) th Maximum conversion size is 256 kBytes. A 4 parameter for starting address can be specified to skip out the leading garbage and you will maintain a small size of output binary file. If you start the HEX2BIN without any additional parameter all necessary parameters will be asked for in a prompt mode: HEX2BIN Input HEX file name: MYAPP.H86 Output BIN file name[MYAPP.BIN]: HEX file format ntel /otorola /igital Research /ektronics /[H] Intel HEX-32[I] : H Input CODE segment start address[0000000]: 10000 Input CODE segment end address[FFFFFFF]: Unused bytes will be 00 FF [1] : 2 Instead of using the prompt mode, you can directly specify all necessary parameters in the command line. This is essential for making batch files: HEX2BIN MYAPP.H86 MYAPP.BIN H 0010000 FFFFFFF 2 It is very important to fill unused bytes with 0xFF, because this are simply skipped by the JTAG-Boosters software and so it speeds up the programming performance. 66 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx Please Note: "CODE segment start address" is interpreted as a Intel x86 architecture segment address: You have to specify a start address of 10000 to start the conversion at 1 MByte. This converter is a relatively old DOS tool and therefor it has problems with non DOS compliant file and directory names. Avoid names with spaces, limit names to eight characters. Otherwise the converter does not convert the input file, without any error message!! JTAG_ADSP-21xxxa.doc 67 JTAG-Booster for Analog Devices ADSP-21xxx 5. Support for Windows NT and Windows 2000 A configured run time version of the "Kithara DOS Enabler, Version 5.1" is used to give support for some of our DOS based tools (like the JTAG-Booster) for Windows NT and Windows 2000. After installation of the "DOS Enabler" the accesses to the LPT or COM ports are allowed for the all programs listed in file Readme_WinNT.txt Note: Accesses to the ports are only allowed for the programs listed in file Readme_WinNT.txt. If you rename one of our tools, the DOS Enabler does not work. 5.1. Installation on a clean system If you have a clean system without having installed a previous version of the "Kithara Tool Center", this tool is really simple to install. Extract the ZIP file to a new folder and start KSETUP.EXE. Everything is done within a few seconds. No additional input is needed. Now reboot your PC. 5.2. Installation with already installed a previous version of Kithara Important!! If you have already installed an older WinNT support, you have to deinstall it completely!!! • Start kcenter • Select Register "Einstellungen" (=Settings) and deactivate "VDD benutzen" and "speziellen seriellen Treiber benutzen". • Stop Kernel • exit the kcenter program • Now you can deinstall the Kithara Package with: Settings - Control Panel. All unused parts must be removed. • Reboot your PC • Now you can install the Kithara 5.xx as described above. 68 JTAG_ADSP-21xxxa.doc JTAG-Booster for Analog Devices ADSP-21xxx 5.3. De-Installation version 5.xx: For deinstallation of the runtime version of the "Kithara DOS-Enabler Version 5.x": • use: Settings - Control-Panel - Add/Remove Programs and remove the "WinNT support for JTAG-Booster and FLASH166" • Reboot your PC JTAG_ADSP-21xxxa.doc 69
FS-940 价格&库存
很抱歉,暂时无法提供与“FS-940”相匹配的价格&库存,您可以联系我们找货
