FS-931
FS-931
    DIGIINTERNATIONAL
    JTAG-BOOSTER FOR ELANSC520 3.3V
FS-931 数据手册
JTAG-Booster for AMD ÉlanSC520 P.O. Box 1103 Kueferstrasse 8 (+49 (7667) 908-0 sales@fsforth.de l l l l D-79200 Breisach, Germany D-79206 Breisach, Germany Fax +49 (7667) 908-200 http://www.fsforth.de JTAG-Booster for AMD ÉlanSC520 Copyright  1995..2002: FS FORTH-SYSTEME GmbH Postfach 1103, D-79200 Breisach, Germany Release of Document: Author: Filename: Program Version: March 12, 2002 Dieter Fögele JTAGEL5d.doc 3.xx All rights reserved. No part of this document may be copied or reproduced in any form or by any means without the prior written consent of FS FORTH-SYSTEME GmbH. 2 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 Table of Contents 1. General ...............................................................................................................4 1.1. System Requirements .............................................................................4 1.2. Connecting your PC to the target system................................................5 1.3. First Example ...........................................................................................7 1.4. Trouble Shooting ......................................................................................9 1.5. Error Messages......................................................................................10 1.6. Initialization file JTAGEL5.INI ..................................................................14 1.7. Supported flash devices.........................................................................22 2. JTAGEL5 Parameter Description.....................................................................27 2.1. Programming a Flash Device................................................................30 2.2. Read a Flash Device to file ....................................................................34 2.3. Verify a Flash Device with file ................................................................36 2.4. Dump target memory.............................................................................38 2.5. Program an I²C-Device..........................................................................39 2.6. Read an I²C-Device to file ......................................................................41 2.7. Verify an I²C-Device with file ..................................................................43 2.8. Dump an I²C-Device ..............................................................................45 2.9. Toggle CPU pins ....................................................................................46 2.10. Polling CPU pins ....................................................................................47 2.11. Polling CPU pins while the CPU is running ...........................................48 2.12. List of supported Flash Devices ............................................................49 3. Implementation Information ..............................................................................50 JTAGEL5d.doc 3 JTAG-Booster for AMD ÉlanSC520 1. General The program JTAGEL5 uses the JTAG port of the AMD ÉlanSC520 embedded microprocessor in conjunction with the small JTAG-BOOSTER: • • • • • to program data into flash memory to verify and read the contents of a flash memory to make a memory dump to access a I2C Device to test CPU signals All functions are done without any piece of software running in the target. No firmware or BIOS must be written. Bootstrap software may be downloaded to initially unprogrammed memories. For latest documentation please refer to the file README.TXT on the distribution disk. 1.1.System Requirements To successfully run this tool the following requirements must be met: • MSDOS, WIN3.x, WIN9x or WinNT (WinNT is supported with an additional support-kit) • Intel 80386 or higher • 205 kByte of free DOS memory • no extended memory • Parallel Port 4 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 1.2.Connecting your PC to the target system The JTAG-Booster can be plugged into standard parallel ports (LPT1-3) with a DB25-Connector. 1 LPT1-3 1 Élan SC400 Module Élan486 The target end of the cable has the following reference: 1 TCK 2* GND 3 TMS 4 TRST# 5 NC 6 TDI 7 TDO 8 +3.3V *PIN 2 can be detected by the white thick cable. To connect your design to the JTAG-BOOSTER you need a single row berg connector with a spacing of 2.54mm on your PCB. The names refer to the target: Pin 7 is the target’s TDO pin and is connected to the JTAG-Booster’s TDI pin. A 3.3V version of the JTAG-Booster is delivered for the AMD ElanSC520. Do not connect the 3.3V JTAG-Booster to a 5V power supply. The JTAGBooster may be damaged. Before you start the program, the JTAG-BOOSTER must be plugged to a parallel interface of your PC and to the 8 pin JTAG connector on the target. JTAGEL5d.doc 5 JTAG-Booster for AMD ÉlanSC520 The utility is started with the general command line format: JTAGEL5 /function [filename] [/option_1] ... [/option_n]. Note that the function must be the first argument followed (if needed) by the filename. If you want to cancel execution of JTAGEL5, press CTRL-Break-Key. On any error the program aborts with an MSDOS error level of one. 6 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 1.3.First Example In the following simple example it is assumed that the JTAG-Booster is connected to LPT1 of your PC and target power is on. Typing JTAGEL5 /P MYAPP.BIN /VERIFY at the DOS prompt results in the following output: JTAGEL5 --- JTAG utility for AMD ÉlanSC520 Copyright  FS FORTH-SYSTEME GmbH, Breisach Version 3.0 of mm/dd/yyyy (1) (2) (3) (4) Configuration loaded from file JTAGEL5.INI Target: FS FORTH-SYSTEME, EVA520 Using LPT at I/O-address 0378h JTAG Adapter detected (5) More than 9 devices detected in JTAG chain or TDI pin stuck at low level Device 0: IDCODE=10EFF003 AMD ÉlanSC520, Revision 1 Device 1: IDCODE=10EFF003 AMD ÉlanSC520, Revision 1 Device 2: IDCODE=10EFF003 AMD ÉlanSC520, Revision 1 Device 3: IDCODE=10EFF003 AMD ÉlanSC520, Revision 1 Device 4: IDCODE=10EFF003 AMD ÉlanSC520, Revision 1 Device 5: IDCODE=10EFF003 AMD ÉlanSC520, Revision 1 Device 6: IDCODE=10EFF003 AMD ÉlanSC520, Revision 1 Device 7: IDCODE=10EFF003 AMD ÉlanSC520, Revision 1 Device 8: IDCODE=10EFF003 AMD ÉlanSC520, Revision 1 Sum of instruction register bits : 4 CPU position :0 Instruction register offset :0 (6) (7) (8) (9) (10) AMD 29F040 detected Erasing Flash-EPROM Block #:6 7 Programming File MYAPP.BIN 131072 Bytes programmed Programming ok JTAGEL5d.doc 7 JTAG-Booster for AMD ÉlanSC520 Erase Time Programming Time : : 1.1 sec 121.2 sec (1) The initialization file JTAGEL5.INI was found in the current directory. (2) The target identification line of the initialization file is printed here. (3) The resulting I/O-address of the parallel port is printed here. (4) A JTAG-Booster is found on the parallel port (5) The JTAG chain is analyzed. There may be several parts in the JTAG chain. The chain is analyzed and all parts except the AMD ÉlanSC520 are switched to bypass mode. Please note: The current revision of the AMD ÉlanSC520 has a silicon bug with the JTAG identification register. As a result of that bug, the contents of the identification register is shifted out infinitely. If there are other devices in the JTAG chain, the AMD ÉlanSC520 must be the first part in the chain (nearest to TDI). Otherwise the JTAG-Booster does not work. (6) The length of all instruction registers in the JTAG chain are added. (7) The position of the AMD ÉlanSC520 in the JTAG chain is checked. (8) The position of the JTAG instruction register of the AMD ÉlanSC520 is checked (9) One Flash-EPROM AMD 29F040 selected with chip select BOOTCS# is found. (10) In this example two blocks must be erased. 8 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 1.4.Trouble Shooting Avoid long distances between your Host-PC and the target. If you are using standard parallel extension cable, the JTAG-BOOSTER may not work. Don't use Dongles between the parallel port and the JTAG-BOOSTER. Switch off all special modes of your printer port (EPP, ECP, ...) in the BIOS setup. Only standard parallel port (SPP) mode is allowed. On very fast PCs there could be verify errors. To avoid this, watch for the ´IO recovery time´-switch in the BIOS Setup which must be turned on. Otherwise try to slow down your PC by setting the turbo switch off. When using older flash devices (nearly maximum erase cycles reached), we propose to use the /VERIFY option. This is also true for the relatively slow 3 Volt only flash devices. Some newer fast flash devices need a setup time between address/data and the write strobe signal. If programming of this devices fails, try with the option /WRSETUP again. If there are problems with autodetection of the flash devices use the /DEVICE= option. To speed up autodetection specify the option /16BIT or /8BIT. Don't use hardware protected flash memories. The used chip selects must be defined as output and inactive in the initialization file (see chapter 1.6 “Initialization file JTAGEL5.INI”). Also the address bits must be defined as output. JTAGEL5d.doc 9 JTAG-Booster for AMD ÉlanSC520 1.5.Error Messages • 80386 or greater required The JTAG-BOOSTER does not work on a 8088/8086 or a 80286 platform. • Adapter not connected or target power fail The JTAG-Booster wasn't found. Please check connection to parallel port and connection to target. Check target power. Check your BIOS-Setup. • Can't open x:\yyy\zzz\JTAGEL5.OVL The overlay file JTAGEL5.OVL must be in the same directory as JTAGEL5.EXE. • Configuration file XYZ not found. The file specified with the option /INI= wasn't found. • Device offset out of range The value specified with the option /OFFSET= is greater than the size of the detected flash device. • Disk full Writing a output file was aborted as a result of missing disk space. • Error creating file: The output file could not be opened. Please check free disk space or write protection. • Error: Pin-Name is an output only pin The specified pin cannot be sampled. Check the command line. Check the initialization file. • Error: Pin-Name is an input only pin The specified pin cannot be activated. Check the command line. Check the initialization file. • Error: Pin-Name may not be read back The specified pin can be switched to tristate, but cannot be read back. Check the command line. 10 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 • illegal function: The first parameter of the command line must be a valid function. See chapter 2 “JTAGEL5 Parameter Description” for a list of supported functions. • illegal number: The specified number couldn’t be interpret as a valid number. Check the relevant number base. • illegal option: See chapter 2 “JTAGEL5 Parameter Description” for a list of supported options. • illegal Pin Type: The name specified with the option /PIN= must be one of the list of chapter 1.6 ”Initialization file JTAGEL5.INI” • illegal Flash Type: The name specified with the option /DEVICE= must be one of the list of chapter 1.7 ”Supported flash devices”. • Input file not found: The specified file cannot be found • Input file is empty: Files with zero length are not accepted • " " is undefined Please check the syntax in your configuration file. (See chapter 1.6 “Initialization file JTAGEL5.INI”). • LPTx not installed The LPT port specified with /LPTx cannot be found. Please check the LPT port or specify a installed LPT port. Check your BIOS setup. • missing filename Most functions need a filename as second parameter. JTAGEL5d.doc 11 JTAG-Booster for AMD ÉlanSC520 • missing option /I2CCLK= Some functions need the option /I2CCLK= to be defined. • missing option /I2CDAT= Some functions need the option /I2CDAT= or the options /I2CDATO= and /I2CDATI= to be defined. • missing option /LENGTH= Some functions need the option /LENGTH= to be defined. • missing option /PIN= Some functions need the option /PIN= to be defined. • More than 9 devices in the JTAG chain or TDI pin stuck at low level The JTAG chain is limited to 9 parts. Check target power. Check the target’s TDO pin. • No devices found in JTAG chain or TDI pin stuck at high level A stream of 32 high bits was detected on the pin TDI. TDI may stuck at high level. Check the connection to your target. Check the target power. Check the target’s TDO pin. • Option /CPUPOS= out of range The number specified with the option /CPUPOS= must be less or equal to the number of parts minus 1. • Option /IROFFS= out of range Please specify a smaller value • Part at specified position is not a AMD ÉlanSC520 The option /CPUPOS= points to a part not a AMD ÉlanSC520 • Pins specified with /I2CCLK= and /I2CDAT= must have different control cells The pin specified with the option /I2CDAT= must be able to be switched to high impedance while the pin specified with option /I2CCLK= is an active output. See chapter 1.6 “Initialization file JTAGEL5.INI”. 12 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 • Pins specified with /I2CCLK= and /I2CDATI= must have different control cells The pin specified with the option /I2CDATI= must be able to be switched to high impedance while the pin specified with option /I2CCLK= is an active output. See chapter 1.6 “Initialization file JTAGEL5.INI”. • Pins specified with /I2CDATO= and /I2CDATI= must have different control cells The pin specified with the option /I2CDATI= must be able to be switched to high impedance while the pin specified with option /I2CDATO= is an active output. See chapter 1.6 “Initialization file JTAGEL5.INI”. • Specify only one of that options: Some options are exclusive (i.e. /8BIT and /16BIT). Don't mix them. • There are unknown parts in the JTAG chain. Please use the option /IROFFS= to specify the instr. reg. offset of the CPU. If there are unknown parts in the JTAG chain, the program isn’t able to determine the logical position of the CPU’s instruction register. • There is no AMD ÉlanSC520 in the JTAG chain No AMD ÉlanSC520 was found in the JTAG chain. Check the target power. Try with option /DRIVER=4 again. • Value of option /FILE-OFFSET out of range The value of the option /FILE-OFFSET= points behind end of file. • wrong driver # The value specified with the option /DRIVER= is out of range. • wrong Identifier (xxxx) No valid identifier found. Check the specified chip select signal and the bus width. Try with the option /DEVICE= . JTAGEL5d.doc 13 JTAG-Booster for AMD ÉlanSC520 1.6.Initialization file JTAGEL5.INI This file is used to set the CPU signals for input/output. In case of output signal an additional parameter is used to set the default level to high or low. This file can be used to adapt your own AMD ÉlanSC520 design to the JTAG-BOOSTER. The Target-Entry is used to identify your design which is displayed with most commands. When the JTAGEL5 software is started it scans the current directory for an existing initialization file named JTAGEL5.INI. If no entry is found the default values are used. You may also specify the initialization file with the option /INI= . If the specified file isn't found, the program aborts with an error message. The CPU pins can also be used with the functions /BLINK (chapter 2.9), /PIN? (chapter 2.10) and /SAMPLE (chapter 2.11) to test the signals on your design. Example of JTAGEL5.INI: // Description file for AMD ÉlanSC520 Target: FS FORTH-SYSTEME, EVA520 // All chip select signals are set to output and inactive. // All signals should be defined. Undefined signals are set to their defaults. // Pin names are defined in upper case. // Low active signals are signed with a trailing #. // Group A: All pins in this group must be set to the same direction // This pins are tristateable outputs and may not be read back BA1 Out,Lo // SDRAM, bank address BA0 Out,Lo // SDRAM, kank address MA12 Out,Lo // SDRAM, address MA11 Out,Lo // MA10 Out,Lo // MA9 Out,Lo // MA8 Out,Lo // MA7 Out,Lo // MA6 Out,Lo // MA5 Out,Lo // MA4 Out,Lo // MA3 Out,Lo // MA2 Out,Lo // 14 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 MA1 MA0 Out,Lo Out,Lo // // // Group B: All pins in this group must be set to the same direction // This pins are bidirectional MD31 Inp // SDRAM data bus MD30 Inp // MD29 Inp // MD28 Inp // MD27 Inp // MD26 Inp // MD25 Inp // MD24 Inp // MD23 Inp // MD22 Inp // MD21 Inp // MD20 Inp // MD19 Inp // MD18 Inp // MD17 Inp // MD16 Inp // MD15 Inp // MD14 Inp // MD13 Inp // MD12 Inp // MD11 Inp // MD10 Inp // MD9 Inp // MD8 Inp // MD7 Inp // MD6 Inp // MD5 Inp // MD4 Inp // MD3 Inp // MD2 Inp // MD1 Inp // MD0 Inp // MECC6 Inp // SDRAM, memory error correction code MECC5 Inp // MECC4 Inp // MECC3 Inp // JTAGEL5d.doc 15 JTAG-Booster for AMD ÉlanSC520 MECC2 MECC1 MECC0 Inp Inp Inp // // // // Group C: All pins in this group must be set to the same direction // This pins are tristateable outputs but may not be read back SCS3# Out,Hi // SDRAM, chip select SCS2# Out,Hi // SCS1# Out,Hi // SCS0# Out,Hi // // Group D: All pins in this group must be set to the same direction // This pins are tristateable outputs but may not be read back SRASB# Out,Hi // SDRAM, row address strobe SRASA# Out,Hi // // Group E: All pins in this group must be set to the same direction // This pins are tristateable outputs but may not be read back SCASB# Out,Hi // SDRAM, column address strobe SCASA# Out,Hi // // Group F: All pins in this group must be set to the same direction // This pins are tristateable outputs but may not be read back SWEB# Out,Hi // SDRAM, memory write enables SWEA# Out,Hi // // Group G: All pins in this group must be set to the same direction // This pins are tristateable outputs but may not be read back SDQM3 Out,Lo // SDRAM, data ubput/output mask SDQM2 Out,Lo // SDQM1 Out,Lo // SDQM0 Out,Lo // // Group H: All pins in this group must be set to the same direction // This pins are bidirectional AD31 Inp // PCI, address/data bus AD30 Inp // AD29 Inp // AD28 Inp // AD27 Inp // AD26 Inp // 16 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 AD25 AD24 AD23 AD22 AD21 AD20 AD19 AD18 AD17 AD16 AD15 AD14 AD13 AD12 AD11 AD10 AD9 AD8 AD7 AD6 AD5 AD4 AD3 AD2 AD1 AD0 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp // // // // // // // // // // // // // // // // // // // // // // // // // // // Group I: All pins in this group must be set to the same direction // This pins are bidirectional CBE3# Out,Hi // PCI, command or byte enable CBE2# Out,Hi // CBE1# Out,Hi // CBE0# Out,Hi // // Group J: All pins in this group must be set to the same direction // Pins GPA14..0 are tristateable outputs but may not be read back // Pins GPA25..15 are bidirectional // For Flash programming this pins must be set to output GPA25 Out,Lo // = DEBUG_ENTER config switch GPA24 Out,Lo // = INST_TRCE config switch GPA23 Out,Lo // = AMDEBUG_DIS config switch JTAGEL5d.doc 17 JTAG-Booster for AMD ÉlanSC520 GPA22 GPA21 GPA20 GPA19 GPA18 GPA17 GPA16 GPA15 GPA14 GPA13 GPA12 GPA11 GPA10 GPA9 GPA8 GPA7 GPA6 GPA5 GPA4 GPA3 GPA2 GPA1 GPA0 Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo Out,Lo // = RSTLD7 config switch // = RSTLD6 config switch // = RSTLD5 config switch // = RSTLD4 config switch // = RSTLD3 config switch // = RSTLD2 config switch // = RSTLD1 config switch // = RSTLD0 config switch // // // // // // // // // // // // // // // // Group K: All pins in this group must be set to the same direction // This pins are bidirectional GPD15 Inp // GPD14 Inp // GPD13 Inp // GPD12 Inp // GPD11 Inp // GPD10 Inp // GPD9 Inp // GPD8 Inp // // Group L: All pins in this group must be set to the same direction // This pins are bidirectional GPD7 Inp // GPD6 Inp // GPD5 Inp // GPD4 Inp // 18 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 GPD3 GPD2 GPD1 GPD0 Inp Inp Inp Inp // // // // // The direction of each following pin can be set independent of the others, // but this pins can not be read back. CLKMEMOUT Out,Lo// SDRAM, clock output BOOTCS# Out,Hi// ROMRD# Out,Hi// FLASHWR# Out,Hi// ROMBUFOE# Out,Hi// ROMCS1# Out,Hi// ROMCS2# Out,Hi // CLKPCIOUT Out,Lo // PCI, clock input RST# Out,Hi // PCI, reset GNT4# Out,Hi // GNT3# Out,Hi // GNT2# Out,H i// GNT1# Out,Hi // GNT0# Out,Hi // GPRESET Out,Lo // some people connect GPRESET to the Boot-Flash!! GPIORD# Out,Hi // GPIOWR# Out,Hi // GPMEMRD# Out,Hi // GPMEMWR# Out,Hi // SOUT1 Out,Lo // RTS1# Out,Lo // DTR1# Out,Lo // SOUT2 Out,Lo // RTS2# Out,Lo // DTR2# Out,Lo // SSI_CLK Out,Hi // SSI_DO Out,Hi // CMDACK Out,Lo // STOP/TX Out,Lo // TRIG/TRACE Out,Lo // // The following pins are complete bidirectional pins. // The direction of each pin can be set independent of the other pins. // Each pin can be used as input. JTAGEL5d.doc 19 JTAG-Booster for AMD ÉlanSC520 PAR PERR# FRAME# TRDY# IRDY# STOP# DEVSEL# PIO27 PIO26 PIO25 PIO24 PIO23 PIO22 PIO21 PIO20 PIO19 PIO18 PIO17 PIO16 PIO15 PIO14 PIO13 PIO12 PIO11 PIO10 PIO9 PIO8 PIO7 PIO6 PIO5 PIO4 PIO3 PIO2 PIO1 PIO0 PIO28 PIO29 PIO30 PIO31 CLKTIMER DC 20 Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Out,Hi Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Inp Out,Hi Out,Hi Out,Hi Out,Hi Inp Inp Inp Inp Out,Lo Out,Lo Inp Out,Hi Out,Lo Inp Inp Inp Inp Inp Out,Lo // // // // // // // // = GPCS0# // = PMEMCS16# // = GPIOCS16# // = GPDBUFOE# // = GPIRQ0 // = GPIRQ1 // = GPIRQ2 // = GPIRQ3 // = GPIRQ4 // = GPIRQ5 // = GPIRQ6 // = GPIRQ7 // = GPIRQ8 // = GPIRQ9 // = GPIRQ10 // = GPDACK0# // = GPDACK1# // = GPDACK2# // = GPDACK3# // = GPDRQ0 // = GPDRQ1 // = GPDRQ2 // = GPDRQ3 // = GPTC // = GPAEN // = GPRDY // = GPBHE# // = CPALE // = CTS2# // = DSR2# // = DCD2 // = RIN2# // // JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 DATASTRB CPUACT PITOUT2 PITGATE2 TMRIN1 TMRIN0 TMROUT1 TMROUT0 Out,Lo Out,Lo Out,Lo Inp Inp Inp Out,Lo Out,Lo // // // // // // // // // The following pins are input only. // Setting to output of one of these pins results in an error. // Declaration of the direction of these pins is optional. CLKMEMIN Inp // SERR# Inp // CLKPCIIN Inp // INTD# Inp // INTC# Inp // INTB# Inp // INTA# Inp // REQ4# Inp // REQ3# Inp // REQ2# Inp // REQ1# Inp // REQ0# Inp // SIN1 Inp // CTS1# Inp // DSR1# Inp // DCD1# Inp // RIN1# Inp // SIN2 Inp // SSI_DI Inp // PWRGOOD Inp // PRGRESET Inp // BR/TC Inp // This example is equal to the default initialization which is used when no initialization file could be found in the current directory and no initialization file is specified with the option /INI=. Changes to the structure of the file could result in errors. Remarks can be added by using //. JTAGEL5d.doc 21 JTAG-Booster for AMD ÉlanSC520 1.7.Supported flash devices The following types could be used with the /DEVICE= option: * * * * * * * * * * * * * * * * * * * * * * * * * * * * * AM29F010 AM29F010*2 AM29LV010 AM29LV010*2 AM29F100BW AM29F100BB AM29F100TW AM29F100TB AM29F200BW AM29F200BB AM29F200TW AM29F200TB AM29LV200BW AM29LV200BB AM29LV200TW AM29LV200TB AM29F040 AM29F040*2 AM29F400BW AM29F400BB AM29F400TW AM29F400TB AM29LV400BW AM29LV400BB AM29LV400TW AM29LV400TB AM29LV004B AM29LV004T AM29F080 AM29F080*2 AM29LV081 AM29LV081*2 AM29F800BW AM29F800BB AM29F800TW AM29F800TB AM29LV800BW 22 : AMD 29F010 : Dual AMD 29F010 : AMD 29LV010 : Dual AMD 29LV010 : AMD 29F100B : AMD 29F100B : AMD 29F100T : AMD 29F100T : AMD 29F200B : AMD 29F200B : AMD 29F200T : AMD 29F200T : AMD 29F200B : AMD 29F200B : AMD 29F200T : AMD 29F200T : AMD 29F040 : Dual AMD 29F040 : AMD 29F400B : AMD 29F400B : AMD 29F400T : AMD 29F400T : AMD 29LV400B : AMD 29LV400B : AMD 29LV400T : AMD 29LV400T : AMD 29LV004B : AMD 29LV004T : AMD 29F080 : Dual AMD 29F080 : AMD 29LV081 : Dual 29LV081 : AMD 29F800B : AMD 29F800B : AMD 29F800T : AMD 29F800T : AMD 29LV800B (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) (word mode) (byte mode) (word mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (word mode) (byte mode) (word mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V) (3.3V) (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) (3.3V, word mode) JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 * AM29LV800BB AM29LV800TW * AM29LV800TB * AM29LV008T * AM29LV008B AM29F016 AM29F016*2 * AM29F017 AM29F017*2 AM29LV017*2 * AM29F160BW * AM29F160BB * AM29F160TW * AM29F160TB * AM29F160BB*2 * AM29F160TB*2 AM29LV160BW * AM29LV160BB * AM29LV160TW * AM29LV160TB AM29LV160BB*2 * AM29LV160TB*2 AM29F032 AM29F032*2 * AM29LV033 * AM29LV033*2 * AM29LV640 : AMD 29LV800B : AMD 29LV800T : AMD 29LV800T : AMD 29LV008T : AMD 29LV008B : AMD 29F016 : Dual AMD 29F016 : AMD 29F017 : Dual AMD 29F017 : Dual AMD 29LV017 : AMD 29F160B : AMD 29F160B : AMD 29F160T : AMD 29F160T : Dual AMD 29F160B : Dual AMD 29F160T : AMD 29LV160B : AMD 29LV160B : AMD 29LV160T : AMD 29LV160T : Dual AMD 29LV160B : Dual AMD 29LV160T : AMD 29F032 : Dual AMD 29F032 : AMD 29LV033 : Dual AMD 29F033 : AMD 29LV160 * * * * * * * * * * * : Intel 28F001T : Dual Intel 28F001T : Intel 28F001B : Intel 28F200B : Intel 28F200B : Intel 28F200T : Intel 28F200T : Intel 28F002B : Intel 28F002T : Intel 28F400B : Intel 28F400B : Intel 28F400T : Intel 28F400T I28F001T I28F001T*2 I28F001B I28F200BW I28F200BB I28F200TW I28F200TB I28F002B I28F002T I28F400BW I28F400BB I28F400TW I28F400TB JTAGEL5d.doc (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V) (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) (byte mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, byte mode) (3.3V, byte mode) (3.3V) (3.3V) (3.3V, word mode) (word mode) (byte mode) (word mode) (byte mode) (word mode) (byte mode) (word mode) (byte mode) 23 JTAG-Booster for AMD ÉlanSC520 * * * * * * * * * * * * * * * * * * I28F004B I28F004T I28F400B3B I28F400B3T I28F004S5 I28F800BW I28F800BB I28F800TW I28F800TB I28F800B3B I28F800B3T I28F008B I28F008T I28F008SA I28F008SA*2 I28F008S5 I28F008S5*2 I28F016W I28F016B I28F016S5 I28F160B3B I28F160B3T I28F160S5W I28F160S5B I28F320S5W I28F320S5B I28F320J5W I28F320J5B I28F320J3W I28F320J3B I28F640J5W I28F640J5B I28F640J3W I28F640J3B I28F128J3W I28F128J3B : Intel 28F004B : Intel 28F004T : Intel 28F400B3B : Intel 28F400B3T : Intel 28F004 : Intel 28F800B : Intel 28F800B : Intel 28F800T : Intel 28F800T : Intel 28F800B3B : Intel 28F800B3T : Intel 28F008B : Intel 28F008T : Intel 28F008 : Dual Intel 28F008 : Intel 28F008 : Dual Intel 28F008 : Intel 28F016 : Intel 28F016 : Intel 28F016 : Intel 28F160 : Intel 28F160 : Intel 28F160 : Intel 28F160 : Intel 28F320 : Intel 28F320 : Intel 28F320 : Intel 28F320 : Intel 28F320 : Intel 28F320 : Intel 28F640 : Intel 28F640 : Intel 28F640 : Intel 28F640 : Intel 28F128 : Intel 28F128 * * * * MBM29F200BW MBM29F200BB MBM29F200TW MBM29F200TB : : : : * * * * * * * * * * * 24 Fujitsu 29F200B Fujitsu 29F200B Fujitsu 29F200T Fujitsu 29F200T Boot Block Smart3 Bottom Boot Block Smart3 Top FlashFile Smart3/5 (word mode) (byte mode) (word mode) (byte mode) Boot Block Smart3 Bottom Boot Block Smart3 Top FlashFile 12V FlashFile 12V FlashFile Smart3/5 FlashFile Smart3/5 FlashFile (word mode) FlashFile (byte mode) FlashFile Smart3/5 Boot Block Smart3 Bottom Boot Block Smart3 Top FlashFile Smart5 (word mode) FlashFile Smart5 (byte mode) FlashFile Smart3/5 (word mode) FlashFile Smart3/5 (byte mode) StrataFlash (word mode) StrataFlash (byte mode) StrataFlash (3.3V, word mode) StrataFlash (3.3V, byte mode) StrataFlash (word mode) StrataFlash (byte mode) StrataFlash (3.3V, word mode) StrataFlash (3.3V, byte mode) StrataFlash (3.3V, word mode) StrataFlash (3.3V, byte mode) (word mode) (byte mode) (word mode) (byte mode) JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * MBM29LV200BW MBM29LV200BB MBM29LV200TW MBM29LV200TB MBM29F002B MBM29F002SB MBM29LV002B MBM29F002T MBM29F002ST MBM29LV002T MBM29F040 MBM29F400BW MBM29F400BB MBM29F400TW MBM29F400TB MBM29LV400BW MBM29LV400BB MBM29LV400TW MBM29LV400TB MBM29LV004B MBM29LV004T MBM29F080 MBM29LV080 MBM29F800BW MBM29F800BB MBM29F800TW MBM29F800TB MBM29LV800BW MBM29LV800BB MBM29LV800TW MBM29LV800TB MBM29LV008B MBM29LV008T MBM29F016 MBM29F016*2 MBM29F017 MBM29F017*2 MBM29F160BW MBM29F160BB MBM29F160TW MBM29F160TB JTAGEL5d.doc : Fujitsu 29LV200B : Fujitsu 29LV200B : Fujitsu 29LV200T : Fujitsu 29LV200T : Fujitsu 29F002B : Fujitsu 29F002SB : Fujitsu 29LV002B : Fujitsu 29F002T : Fujitsu 29F002ST : Fujitsu 29LV002T : Fujitsu 29F040 : Fujitsu 29F400B : Fujitsu 29F400B : Fujitsu 29F400T : Fujitsu 29F400T : Fujitsu 29LV400B : Fujitsu 29LV400B : Fujitsu 29LV400T : Fujitsu 29LV400T : Fujitsu 29LV004B : Fujitsu 29LV004T : Fujitsu 29F080 : Fujitsu 29LV080 : Fujitsu 29F800B : Fujitsu 29F800B : Fujitsu 29F800T : Fujitsu 29F800T : Fujitsu 29LV800B : Fujitsu 29LV800B : Fujitsu 29LV800T : Fujitsu 29LV800T : Fujitsu 29LV008B : Fujitsu 29LV008T : Fujitsu 29F016 : Dual Fujitsu 29F016 : Fujitsu 29F017 : Dual Fujitsu 29F017 : Fujitsu 29LV160B : Fujitsu 29LV160B : Fujitsu 29LV160T : Fujitsu 29LV160T (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (TSOP40) (3.3V) (TSOP40) (3.3V) (word mode) (byte mode) (word mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V) (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) 25 JTAG-Booster for AMD ÉlanSC520 * * * * * * MBM29F160BB*2 MBM29F160TB*2 MBM29LV160BW MBM29LV160BB MBM29LV160TW MBM29LV160TB MBM29LV160BB*2 * MBM29LV160TB*2 MBM29F032 MBM29F032*2 : : : : : : : : : : * * * * : ST 29F100B : ST 29F100B : ST 29F100T : ST 29F100T : ST 29F200B : ST 29F200B : ST 29F200T : ST 29F200T : ST 29F040 : Dual ST 29F040 : ST 29W040 : Dual ST 29W040 : ST 29F400B : ST 29F400B : ST 29F400T : ST 29F400T : ST 29W400B : ST 29W400B : ST 29W400T : ST 29W400T : ST 29W004B : ST 29W004T : ST 29F800B : ST 29F800B : ST 29F800T : ST 29F800T * * * * * * * * * * * * * * * * * * * * * M29F100BW M29F100BB M29F100TW M29F100TB M29F200BW M29F200BB M29F200TW M29F200TB M29F040 M29F040*2 M29W040 M29W040*2 M29F400BW M29F400BB M29F400TW M29F400TB M29W400BW M29W400BB M29W400TW M29W400TB M29W004B M29W004T M29F800BW M29F800BB M29F800TW M29F800TB Dual Fujitsu 29LV160B Dual Fujitsu 29LV160T Fujitsu 29LV160B Fujitsu 29LV160B Fujitsu 29LV160T Fujitsu 29LV160T Dual Fujitsu 29LV160B Dual Fujitsu 29LV160T Fujitsu 29F032 Dual Fujitsu 29F032*2 (byte mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, byte mode) (3.3V, byte mode) (word mode) (byte mode) (word mode) (byte mode) (word mode) (byte mode) (word mode) (byte mode) (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V, word mode) (3.3V, byte mode) (3.3V) (3.3V) (word mode) (byte mode) (word mode) (byte mode) The flash devices signed with ´*´ are not yet tested. 26 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 2. JTAGEL5 Parameter Description When you start JTAGEL5.EXE without any parameters the following help screen with all possible functions and options is displayed: JTAGEL5 --- JTAG utility for the AMD ÉlanSC520 Copyright © FS FORTH-SYSTEME GmbH, Breisach Version 3.0 of mm/dd/yyyy Programming of Flash-EPROMs and Debugging on targets with the AMD ÉlanSC520. The JTAG-Booster is needed to connect the parallel port of the PC to the JTAG port of the AMD ÉlanSC520. Usage: JTAGEL5 /function [filename] [/option_1] ... [/option_n] Supported functions: /P : Programming a Flash Device /R : Read a Flash Device to file /V : Verify a Flash Device with file /DUMP : Make a target dump /PI2C : Program an I2C Device with file /RI2C : Read an I2C Device to file /VI2C : Verify an I2C Device with file /DUMPI2C : Make a dump of an I2C Device /BLINK : Toggle a CPU pin /PIN? : Test a CPU pin /SAMPLE : Test a CPU pin while CPU is running /LIST : Print a list of supported Flash devices Supported Options: /BOOTCS /ROMCS1 /ROMCS2 /VERIFY /TOP /PAUSE /NOERASE /LATTICE /ERASEALL /LPT3 /LPT-BASE= /16BIT /32H /32L /MBUS /FILE-OFFSET= /FO= /DELAY= /DEVICE-BASE= /DATA-MASK= /DM= /IROFFS= /PIN= /I2CCLK= /I2CDAT= /WATCH= /OUT= /INI= JTAGEL5d.doc /NOCS /P /LPT1 /8BIT /LENGTH= /OFFSET= /DB= /CPUPOS= /I2CDATI= /WRSETUP /NODUMP /LPT2 /NOMAN /L= /O= /DRIVER= /DEVICE= /I2CDATO= 27 JTAG-Booster for AMD ÉlanSC520 The following options are valid for most functions: /DRIVER=x with x = 1,2,3,4 A driver for the interface to the JTAG-BOOSTER on the parallel port may be specified. /DRIVER=1 selects the fastest available driver, /DRIVER=4 selects the slowest one. Use a slower driver if there are problems with JTAG-BOOSTER. Default: /DRIVER=3 /INI=file An initialization file may be specified. By default the current directory is searched for the file JTAGEL5.INI. If this file is not found and no initialization file is specified in the command line, default initialization values are used (see also chapter 1.6 “Initialization file JTAGEL5.INI”). Default: /INI=JTAGEL5.INI /LATTICE For demonstration purposes this software works with the Lattice ispLSI-Adapter, too. With the option /LATTICE you can simulate the speed achievable with the simple ispLSI-Adapter. /LPT1 /LPT2 /LPT3 A printer port may be specified where the JTAG-Booster resides. Default: /LPT1 /LPT-BASE The physical I/O-Address of printer port may be specified instead of the logical printer name. /OUT=file_or_device All screen outputs are redirected to the specified file or device. Note that you can't redirect to the same parallel port where the JTAG-Booster resides. Default: /OUT=CON /PAUSE With the option /PAUSE you can force the program to stop after each screen. Please do not use this option if you redirect the output to a file. Abbreviation: /P 28 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 /WATCH= With the option /WATCH= a pin can be specified, which is toggled twice per second, while the program is active. This pin may be the trigger of a watchdog. This pin must be specified as output in the initialization file. JTAGEL5d.doc 29 JTAG-Booster for AMD ÉlanSC520 2.1.Programming a Flash Device Usage: JTAGEL5 /P filename [optionlist] The specified file is programmed into the flash memory. Finally a complete verify is done, if the option /VERIFY is omitted. If the verify fails, the contents of the flash memory is written to a file with the extension DMP. The type of the flash device is normally detected by the software. When autodetect fails you should use the /DEVICE= option to set the right flash device. The known devices are shown in chapter 1.7 “Supported flash devices”. Options: /DEVICE=devicename The device is detected automatically by switching to autoselect mode. In case of trouble you should select the device by using this parameter to avoid autodetection. /NOMAN If you use a flash device which is identical to one of the supported parts, but is from a different manufacturer, with this option you can suppress the comparison of the manufacturer identification code. We recommend to use this option together with the /DEVICE= option to avoid failures in autodetection. /DEVICE-BASE=hhhhhh1 By default a device start address of 3000000h (=48MByte) is used for accesses to the flash device. Default: /DEVICE-BASE=3000000 Abbreviation: /DB= /OFFSET=hhhhhh The programming starts at an offset of hhhhhh relative to the start address of the flash device. If the offset is negative, the offset specifies an address relative to the end of the flash device. See also option /TOP Default: /OFFSET=0 Abbreviation: /O= 1 hhhhhh=number base is hex 30 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 /TOP If the option /TOP is used the option /OFFSET= specifies the address where the programming ends (plus one) instead of the starting address. This option is very important for Intel CPU architectures, because target execution always starts at the top of the address space. /FILE-OFFSET=hhhhhh If FILE-OFFSET is specified, the first hhhhhh bytes of the file are skipped and not programmed to target. Default: /FILE-OFFSET=0 Abbreviation: /FO= /LENGTH=hhhhhh The number of programmed bytes may be limited to LENGTH. If no LENGTH is specified the whole file is programmed. Default: /LENGTH=4000000 (64 MByte) Abbreviation: /L= /VERIFY If this option is specified, the result is verified on a cell by cell (cell=8bit or 16bit) basis instead of a complete verify after programming. If you want both a cell by cell verify and a complete verify after programming, please use a additional command line with the verify function. See chapter 2.3 “Verify a Flash Device with file”. /NODUMP In case of a verify error the contents of the flash memory is written to a file with the extension .DMP. With /NODUMP you can suppress this feature. /ERASEALL Erase the whole flash device. If this option isn't set, only those blocks are erased where new data should be written to. /NOERASE This option prevents the flash device from being erased. JTAGEL5d.doc 31 JTAG-Booster for AMD ÉlanSC520 /BOOTCS /ROMCS1 /ROMCS2 This options may be used to specify one or more chip select signals to the flash memory. The used chip selects must be defined as output and inactive in the initialization file. (See chapter 1.6 “Initialization file JTAGEL5.INI”.) Default: /BOOTCS /NOCS Use this option to switch off all chip select signals. This may be necessary if the device's chip select is generated via a normal decoder instead of using the AMD ÉlanSC520 chip select unit. /8BIT /16BIT Specifies the bus interface to the target device. You can speed up autodetection, if you specify the correct bus interface width. /32L /32H The JTAG-Booster is not able to handle the interface to a dual 16bit ROM (32bitROM). With this two options you can select one 16 bit half of a 32bit-ROM. The option /32L selects the low word and /32H selects the high word. 32 bit flash eproms are always connected to the SDRAM data bus. It is not necessary to specify the option /MBUS if the option /32L or /32H is used. Do not specify the option /8BIT together with /32L or /32H. /MBUS With this option the SDRAM data bus (MDx bus) is used instead of the general purpose data bus (GPDx bus) for accesses to flash eproms. /WRSETUP By default write cycles to the Flash EPROM start with address, data and write strobe set at the same time. With the option /WRSETUP you can force the program to generate a setup time for address and data with respect to the write strobe. 32 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 Examples: JTAGEL5 /P ROMDOS.ROM /VERIFY /L=20000 /TOP This example programs up to 128 Kbytes of the file ROMDOS.ROM (with i.e. 512 Kbytes) to the top of the flash memory. JTAGEL5 /P CE.EVN /VERIFY /32L /ROMCS1 This example programs the file CE.EVN to the lower word of a 32bit-ROM connected to ROMCS1#. JTAGEL5d.doc 33 JTAG-Booster for AMD ÉlanSC520 2.2.Read a Flash Device to file Usage: JTAGEL5 /R filename [optionlist] The contents of a flash device is read and written to a file. The type of flash device is normally detected by the software. When autodetect fails you should use the /DEVICE= option to set the right flash device. The known devices are shown in chapter 1.7 “Supported flash devices”. Options: /DEVICE=devicename See function /P (Chapter 2.1) /NOMAN See function /P (Chapter 2.1) /DEVICE-BASE=hhhhhh2 See function /P (Chapter 2.1) /OFFSET=hhhhhh Reading of the flash memory starts at an offset of hhhhhh relative to the start address of the flash device. If the offset is negative, the offset specifies a address relative to the end of the flash device. See also option /TOP. Default: /OFFSET=0 Abbreviation: /O= /TOP If the option /TOP is used the option /OFFSET= specifies the address where reading ends (plus one) instead of the starting address. /LENGTH=hhhhhh The number of read bytes may be limited to LENGTH. If no LENGTH is specified the whole flash device is read (if no offset is specified). 2 hhhhhh=number base is hex 34 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 /BOOTCS /ROMCS1 /ROMCS2 /NOCS See function /P (Chapter 2.1) /8BIT /16BIT See function /P (Chapter 2.1) /32L /32H See function /P (Chapter 2.1) /MBUS See function /P (Chapter 2.1) /WRSETUP See function /P (Chapter 2.1) Please note: In the function /R write cycles are needed to detect the type of the flash memory. Example: JTAGEL5 /R BIOS.ABS /L=10000 /TOP This example may be used to read the upper most 64 Kbyte of the flash memory to the file BIOS.ABS. JTAGEL5d.doc 35 JTAG-Booster for AMD ÉlanSC520 2.3.Verify a Flash Device with file Usage: JTAGEL5 /V filename [optionlist] The contents of a flash device is compared with the specified file. If there are differences the memory is dumped to a file with the extension DMP. The type of flash device is normally detected by the software. When autodetect fails you should use the /DEVICE= option to set the right flash device. The known devices are shown in chapter 1.7 “Supported flash devices”. Options: /DEVICE=devicename See function /P (Chapter 2.1) /NOMAN See function /P (Chapter 2.1) /DEVICE-BASE=hhhhhh See function /P (Chapter 2.1) /OFFSET=hhhhhh See function /P (Chapter 2.1) /TOP See function /P (Chapter 2.1) /FILE-OFFSET=hhhhhh See function /P (Chapter 2.1) /LENGTH=hhhhhh See function /P (Chapter 2.1) /NODUMP See function /P (Chapter 2.1) /BOOTCS /ROMCS1 /ROMCS2 /NOCS See function /P (Chapter 2.1) 36 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 /8BIT /16BIT See function /P (Chapter 2.1) /32L /32H See function /P (Chapter 2.1) /MBUS See function /P (Chapter 2.1) /WRSETUP See function /P (Chapter 2.1) Please note: In the function /V write cycles are needed to detect the type of the flash memory. Example: JTAGEL5 /V ROMDOS.ROM /L=20000 /TOP This example may be used to verify the upper most 128 Kbytes of the flash memory with the file ROMDOS.ROM (with i.e. 512 Kbytes). JTAGEL5d.doc 37 JTAG-Booster for AMD ÉlanSC520 2.4.Dump target memory Usage: JTAGEL5 /DUMP [optionlist] A Hex-Dump of the target memory is printed on the screen, if not redirected to file or device. Options: /OFFSET=hhhhhh The memory dump starts at an offset of hhhhhh. Default: /OFFSET=0 Abbreviation: /O= /TOP If the option /TOP is used the option /OFFSET= specifies the address where the dump ends (plus one) instead of the starting address /LENGTH=hhhhhh Default: /LENGTH=100 Abbreviation: /L= /BOOTCS /ROMCS1 /ROMCS2 /NOCS See function /P (Chapter 2.1) Default: /BOOTCS /8BIT /16BIT Default: /16BIT /32L /32H See function /P (Chapter 2.1) /MBUS See function /P (Chapter 2.1) Example: JTAGEL5 /DUMP /BOOTCS This example makes a memory dump of the first 256 bytes of the Boot-EPROM. 38 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 2.5.Program an I²C-Device Usage: JTAGEL5 /PI2C filename [optionlist] The specified file is programmed to a I²C-Device (i.e. a serial EEPROM) connected to pins of the CPU. Finally a complete verify is done. If the verify fails, the contents of the I²C-Device is written to a file with the extension DMP. Two methods to connect the I²C-Device to the CPU are supported. The first method is to use two CPU pins, one pin for clock output (I2CCLK) and one pin for serial data input and output (I2CDAT). The second method is to use one pin for clock output (I2CCLK), one for serial data input (I2CDATI) and one for serial data output (I2CDATO). Options: /DEVICE-BASE=hhhhhh3 By default a device start address of 3000000h (=48MByte) is used for accesses to the flash device. Default: /DEVICE-BASE=3000000 Abbreviation: /DB= /OFFSET=hhhhhh The programming starts at an offset of hhhhhh relative to the start address of the I²C-Device. Default: /OFFSET=0 Abbreviation: /O= /FILE-OFFSET=hhhhhh If FILE-OFFSET is specified, the first hhhhhh bytes of the file are skipped and not programmed to target. Default: /FILE-OFFSET=0 Abbreviation: /FO= 3 hhhhhh=number base is hex JTAGEL5d.doc 39 JTAG-Booster for AMD ÉlanSC520 /LENGTH=hhhhhh The number of programmed bytes may be limited to LENGTH. If no LENGTH is specified the whole file is programmed. Abbreviation: /L= /NODUMP In case of a verify error the contents of the I²C-Device is written to a file with the extension .DMP. With option /NODUMP you can suppress this feature. /I2CCLK=pin_name Specifies the CPU pin used for serial clock output. /I2CDAT=pin_name Specifies the CPU pin used for serial data input and output. Pin_name must specify a bidirectional pin otherwise an error message occurs. Instead of one bidirectional pin one pin for serial data input and one for serial data output may be used. See option /I2CDATO= and /I2CDATI= . /I2CDATO=pin_name Specifies the CPU pin used for serial data output. Pin_name must specify a output pin otherwise an error message occurs. /I2CDATI=pin_name Specifies the CPU pin used for serial data input. Pin_name must specify a input pin otherwise an error message occurs. Example: JTAGEL5 /PI2C EEPROM.CFG /I2CCLK=PIO31 /I2CDAT=PIO30 This example loads the file EEPROM.CFG to a serial EEPROM connected to the pins PIO31 and PIO30 of the AMD ÉlanSC520 40 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 2.6.Read an I²C-Device to file Usage: JTAGEL5 /RI2C filename /L=hhhhhh [optionlist] The contents of a I²C-Device (i.e. a serial EEPROM) is read and written to a file. The option /LENGTH= must be specified. Options: /DEVICE-BASE=hhhhhh4 See function /PI2C (Chapter 2.5) /OFFSET=hhhhhh Reading of the I²C-Device starts at an offset of hhhhhh relative to the start address of the I²C-Device. Default: /OFFSET=0 Abbreviation: /O= /LENGTH=hhhhhh The number of read bytes must be specified otherwise an error message occurs. Abbreviation: /L= /I2CCLK=pin_name See function /PI2C (Chapter 2.5) /I2CDAT=pin_name See function /PI2C (Chapter 2.5) /I2CDATO=pin_name See function /PI2C (Chapter 2.5) /I2CDATI=pin_name See function /PI2C (Chapter 2.5) 4 hhhhhh=number base is hex JTAGEL5d.doc 41 JTAG-Booster for AMD ÉlanSC520 Example: JTAGEL5 /RI2C EEPROM.CFG /I2CCLK=PIO31 /I2CDAT=PIO30 /L=100 This example reads 256 bytes from a serial EEPROM to the file EEPROM.CFG. The serial EEPROM is connected to the pins PIO31 and PIO30 of the AMD ÉlanSC520. 42 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 2.7.Verify an I²C-Device with file Usage: JTAGEL5 /VI2C filename [optionlist] The contents of a I²C-Device (i.e. a serial EEPROM) is compared with the specified file. If there are differences the contents of the I2C-Device is written to a file with the extension DMP. Options: /DEVICE-BASE= hhhhhh5 See function /PI2C (Chapter 2.5) /OFFSET=hhhhhh See function /PI2C (Chapter 2.5) /FILE-OFFSET=hhhhhh See function /PI2C (Chapter 2.5) /LENGTH=hhhhhh See function /PI2C (Chapter 2.5) /NODUMP See function /PI2C (Chapter 2.5) /I2CCLK=pin_name See function /PI2C (Chapter 2.5) /I2CDAT=pin_name See function /PI2C (Chapter 2.5) /I2CDATO=pin_name See function /PI2C (Chapter 2.5) /I2CDATI=pin_name See function /PI2C (Chapter 2.5) 5 hhhhhh=number base is hex JTAGEL5d.doc 43 JTAG-Booster for AMD ÉlanSC520 Example: JTAGEL5 /VI2C EEPROM.CFG /I2CCLK=PIO31 /I2CDAT=PIO30 This example verifies 256 bytes from a serial EEPROM with the file EEPROM.CFG. The serial EEPROM is connected to the pins PIO31 and PIO30 of the AMD ÉlanSC520. 44 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 2.8.Dump an I²C-Device Usage: JTAGEL5 /DUMPI2C [optionlist] A Hex-Dump of a I²C-Device is printed on the screen, if not redirected to file or device. Options: /OFFSET=hhhhhh6 The memory dump starts at an offset of hhhhhh. Default: /OFFSET=0 Abbreviation: /O= /LENGTH=hhhhhh Default: /LENGTH=100 Abbreviation: /L= /I2CCLK=pin_name See function /PI2C (Chapter 2.5) /I2CDAT=pin_name See function /PI2C (Chapter 2.5) /I2CDATO=pin_name See function /PI2C (Chapter 2.5) /I2CDATI=pin_name See function /PI2C (Chapter 2.5) Example: JTAGEL5 /DUMPI2C /I2CCLK=PIO31 /I2CDAT=PIO30 This example makes a memory dump of the first 100h bytes of a serial EEPROM connected to the CPU. 6 hhhhhh=number base is hex JTAGEL5d.doc 45 JTAG-Booster for AMD ÉlanSC520 2.9.Toggle CPU pins Usage: JTAGEL5 /BLINK /PIN=pinname [optionlist] This command allows to test the hardware by blinking with LEDs or toggling CPU signals. Faster signals can be generated by setting the delay option to zero. This can be a very helpful feature to watch signals on an oscilloscope. Please Note: Not every pin of the AMD ÉlanSC520 may be specified as an output pin. Options: /PIN=pin_name CPU pin to toggle. If the option /PIN= is not specified an error message occurs. Most pins of the list in chapter 1.6 “Initialization file JTAGEL5.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. /DELAY=dddddd7 Time to wait to next change of signal. This option can be adjusted to get optimum signals for measures with the oscilloscope. Default: /DELAY=10000 Example: JTAGEL5 /BLINK /PIN=CS0# /DELAY=0 This example toggles the CS0# pin very fast which can be followed by the use of an oscilloscope. 7 dddddd=number base is decimal 46 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 2.10. Polling CPU pins Usage: JTAGEL5 /PIN? /PIN=pinname [optionlist] This command allows to test the hardware by polling CPU signals. Please Note: Not every pin of the AMD ÉlanSC520 may be specified as an input pin. Options: /PIN=pin_name CPU pin to poll. If the option /PIN= is not specified an error message occurs. Most pins of the list in chapter 1.6 “Initialization file JTAGEL5.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. Example: JTAGEL5 /PIN? /PIN=PWRGOOD This example samples the reset pin of the AMD ÉlanSC520. JTAGEL5d.doc 47 JTAG-Booster for AMD ÉlanSC520 2.11. Polling CPU pins while the CPU is running Usage: JTAGEL5 /SAMPLE /PIN=pinname [optionlist] This command is similar to the function /PIN?. But with this function any pin can be observed, independent of the pin direction. Furthermore the CPU remains in normal operation. Options: /PIN=pin_name CPU pin to poll. If the option /PIN= is not specified an error message occurs. All pins of the list in chapter 1.6 “Initialization file JTAGEL5.INI” can be used. If you type /PIN= without any pin declaration a list of the CPU pins is displayed. Example: JTAGEL5 /SAMPLE /PIN=PITOUT2 This example samples the state of the port pin PITOUT2 (=signal for the speaker) while the AMD ÉlanSC520 is running. 48 JTAGEL5d.doc JTAG-Booster for AMD ÉlanSC520 2.12. List of supported Flash Devices Usage: JTAGEL5 /LIST [optionlist] This command lists all supported flash devices to screen if not redirected to file or device. Flash devices signed with ´*´ are not yet tested. JTAGEL5d.doc 49 JTAG-Booster for AMD ÉlanSC520 3. Implementation Information This chapter summarizes some information about the implementation of the JTAG-Booster and describes some restrictions. • The JTAG-Booster currently uses the EXTEST function of the JTAG-Interface to perform Flash programming. The new debug interface of the AMD ÉlanSC520 is not used. • The revision A0 and A1 of the AMD ÉlanSC520 have a silicon bug with the JTAG identification register. As a result of that bug, the contents of the identification register is shifted out infinitely. If there are other devices in the JTAG chain, the AMD ÉlanSC520 must be the first part in the chain (nearest to targets TDI). Otherwise the JTAG-Booster does not work. 50 JTAGEL5d.doc
FS-931 价格&库存
很抱歉,暂时无法提供与“FS-931”相匹配的价格&库存,您可以联系我们找货
