410-205P-KIT
410-205P-KIT
    DIGILENT(迪芝伦)
    JTAGHS1 FPGA PROGRAMMING CABLE
410-205P-KIT 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com JTAG-HS1™ Programming Cable for Xilinx® FPGAs Revised January 22, 2015 Overview The joint test action group (JTAG)-HS1 programming cable is a high-speed programming solution for Xilinx fieldprogrammable gate arrays (FPGAs). It is fully compatible will all Xilinx tools, and can be seamlessly driven from iMPACT, Chipscope™, and EDK. The HS1 attaches to target boards using Digilent's 6-pin, 100-mil spaced programming header, or Xilinx's 2x7, 2mm connector (using the included adaptor). The JTAG-HS1 is powered from a PC's USB port, and will be recognized as a Digilent programming cable when connected to a PC, whether or not it is attached to the target board. A separate Vdd pin is provided on the HS1 to supply JTAG signal buffers. The high speed, 24mA, three-state buffers allow target boards to drive the HS1 with signal voltages from 1.8V to 5V, with bus speeds of up to 30MBit/sec. The HS1's Vdd pin must be tied to the same voltage supply that drives the JTAG port on the FPGA (see Fig. 1). Features include:  Small, complete, all-in-one JTAG programming solution for Xilinx FPGAs  Separate Vref drives JTAG/SPI signal voltages; Vref can be any voltage between 1.8V and 5V.  High-Speed USB2 port that can drive JTAG/SPI bus at up to 30Mbit/sec  JTAG/SPI frequency settable by user  Compatible with all Xilinx tools  Uses micro-AB USB2 connector  SPI programming solution (modes 0 and 2 supported)  Fully supported by the Adept SDK, allowing custom JTAG/SPI applications to be created The JTAG-HS1. JTAG signals are held in high-impedance except when actively driven during programming, so the JTAG bus can be shared with other devices. The HS1 uses a standard Type-A to Micro-USB cable (included with the HS1) that attaches to the end of the module opposite the system board connector. The HS1 is small and light, allowing it to be held firmly in place by the system board connector (see Fig. 2). DOC#: 502-205 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 4 JTAG-HS1™ Programming Cable for Xilinx® FPGAs Figure 1. Diagram of signal voltages and connections. Figure 2. Xilinx JTAG headers. Software Support In addition to working seamlessly with all Xilinx tools, the HS1 is supported by Digilent's Adept software and the Adept SDK (the SDK can be freely downloaded from Digilent's website). Adept includes a full-featured programming environment, and a set of public APIs that allow user applications to directly drive the JTAG chain. Using the Adept SDK, custom applications can be created to drive JTAG ports on virtually any device. The HS1 also supports SPI modes 0 and 2. Users may utilize the APIs provided by the SDK to create applications that can drive any SPI device supporting those modes. Please see the Adept SDK reference manual for more information. The HS1 is also supported by Digilent's AVR programmer that can target any AVR device VIO: 5V to 1.8V USB2 Port VDD VIO GND GND TCK SCK TDO MISO TDI MOSI TMS JTAG-HS1 SS SPI Device Figure 3. JTAG-HS1 SPI Device Connections. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 4 JTAG-HS1™ Programming Cable for Xilinx® FPGAs Absolute Maximum Ratings Symbol Parameter Condition Min Max Unit Vdd Operating supply voltage -0.3 4.0 V Vref I/O reference/supply voltage -0.3 6 V VIO Signal Voltage -0.3 6 V IIK,IOK TMS, TCK, TDI, TDO VIO < -0.3V -50 VIO > 6V +20 mA DC Input/Output Diode Current IOUT DC Output Current ±50 mA TSTG Storage Temperature +120 ºC Human Body Model JESD22-A114 2000 V Charge Device Model JESD22-C101 500 V -20 ESD DC Operating Characteristics Symbol Parameter Min Typ Max Unit Vdd Operating supply voltage 2.97 3.3 3.63 Volts Vref I/O reference/supply voltage 1.65 2.5/3.3 5.5 Volts TDO TMS, TCK, TDI Input High Voltage (VIH) 0.75 x Vref 5.5 Volts Input Low Voltage (VIL) 0 0.25 x Vref Volts Output High (VOH) 0.85 x Vdd 0.95 x Vdd Vdd Volts Output Low (VOL) 0 0.05 x Vdd 0.15 x Vdd Volts Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 4 JTAG-HS1™ Programming Cable for Xilinx® FPGAs AC Operating Characteristics HS1 JTAG/SPI signals are driven according to the timing diagram below in Fig. 4. TCK frequencies from 30 MHz to 8 KHz are supported at integer divisions of 30 MHz from 1 to 3750. Common frequencies include 30 MHz, 15 MHz, 10 MHz, and 6 MHz (see Table 1). TCK TCKH TCKL TCK TCD TMS/TDI TSU THD TDO Symbol Parameter Min Max TCK TCK period 33ns 2.185ms TCKH, TCKL TCLK pulse width 20ns 1.1ms TCD TCLK to TMS, TDI 0 15ns TSU TDO Setup time 19ns THD TDO Hold time 0 Figure 4. Timing diagram. Table 1.Common frequencies. Design Notes The HS1 is designed to drive JTAG/SPI signals on target boards that have less than 100ohms of series resistance. Higher resistance may result in degraded operation. Supported Target Devices The JTAG-HS1 is capable of targeting the following Xilinx devices: 1. 2. 3. 4. 5. 6. Ordered List Item Xilinx FPGAs Xilinx Zynq-7000 Xilinx CoolRunner™/CoolRunner-II CPLDs Xilinx Platform Flash ISP configuration PROMs Select third-party SPI PROMs Select third-party BPI PROMs The following devices cannot be targeted by the JTAG-HS1: 1. 2. 3. Ordered List ItemXilinx 9500/9500XL CPLDs Xilinx 1700 and 18V00 ISP configuration PROMs Xilinx FPGA eFUSE programming Remote device configuration is not supported for the JTAG-HS1 when used with Xilinx's iMPACT software. Note: Please see the "Introduction to Indirect Programming – SPI or BPI Flash Memory" help topic in iMPACT for a list of supported FPGA/PROM combinations. Note: Please see the "Configuration Memory Support" section of Xilinx UG908 for a list of the FPGA/PROM combinations that Vivado supports. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 4 of 4
410-205P-KIT 价格&库存
很抱歉,暂时无法提供与“410-205P-KIT”相匹配的价格&库存,您可以联系我们找货
410-205P-KIT
  • 1+870.134781+112.89927
