Page 1 of 2
SparkFun Opto-isolator Breakout
B OB-09 118 ROH S
3
images are CC BY-NC-SA 3.0
3D Download: STL, Blender
Description: This is a board designed for opto-isolation. This board is helpful for
connecting digital systems (like a 5V microcontroller) to a high-voltage or noisy
system. This board electrically isolates a controller from the high-power system by
use of an opto-isolator IC. This IC has two LEDs and two photodiodes built-in. This
allows the low-voltage side to control a high voltage side.
We often use this board to allow a microcontroller control servos or other motors that
use a higher voltage than the TTL logic on the (3.3V or 5V) micro, and may cause
electromagnetic interferance with our system as the motors turn on and off. This
board will isolate the systems, creating a type of electrical noise barrier between
devices.
This breakout board uses the ILD213T optoisolator and discrete transistors to correct
the logic. Comes with two channels. Great for use in noisy circuits where signal lines
require electrical isolation.
Page 2 of 2
A normal LED opto-isolator will invert the logic of a signal. We threw some transistors
on this compact board to correct the inversion. What you put into the IN pins, will be
replicated on the the OUT pins, but at the higher voltage (HV).
https://www.sparkfun.com/products/9118
11/16/2015
很抱歉,暂时无法提供与“BOB-09118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+103.79880
- 200+41.41800
