BOB-11771
BOB-11771
    SPARKFUNELECTRONICS
BOB-11771 数据手册
TXB0104 SCES650J – APRIL 2006 – REVISED OCTOBER 2020 TXB0104 4-Bit Bidirectional Voltage-Level Translator With Automatic Direction Sensing and ±15-kV ESD Protection 1 Features 3 Description • This TXB0104 4-bit noninverting translator uses two separate configurable power-supply rails. The A port is designed to track VCCA. VCCA accepts any supply voltage from 1.2 V to 3.6 V. The B port is designed to track VCCB. VCCB accepts any supply voltage from 1.65 V to 5.5 V. This allows for universal low-voltage bidirectional translation between any of the 1.2-V, 1.5V, 1.8-V, 2.5-V, 3.3-V, and 5-V voltage nodes. VCCA must not exceed VCCB. • • • • • • 1.2-V to 3.6-V on A port and 1.65-V to 5.5-V on B port (VCCA ≤ VCCB) VCC isolation feature: if either VCC input ss at GND, all outputs are in the high-impedance state Output enable (OE) input circuit referenced to VCCA Low power consumption, 5-μA maximum ICC I OFF supports partial power-down mode operation Latch-up Performance Exceeds 100 mA Per JESD 78, Class II ESD Protection Exceeds JESD 22 – A Port: • 2500-V Human-Body Model (A114-B) • 1500-V Charged-Device Model (C101) – B Port: • ±15-kV Human-Body Model (A114-B) • 1500-V Charged-Device Model (C101) 2 Applications • • • • Headsets Smartphones Tablets Desktop PC When the OE input is low, all outputs are placed in the high-impedance state. To ensure the high-impedance state during power up or power down, OE must be tied to GND through a pulldown resistor The current sourcing capability of the driver determines the minimum value of the resistor. The TXB0104 device is designed so the OE input circuit is supplied by VCCA. This device is fully specified for partial powerdown applications using I OFF. The I OFF circuitry disables the outputs, which prevents damaging current backflow through the device when the device is powered down. Device Information (1)PART NUMBER PACKAGE BODY SIZE (NOM) TXB0104RUT UQFN (12) 2.00 mm × 1.70 mm TXB0104D SOIC (14) 8.65 mm × 3.91 mm TXB0104ZXU/GXU BGA MICROSTAR JUNIOR™ (12) 2.00 mm × 2.50 mm TXB0104PW TSSOP (14) 5.00 mm × 4.40 mm TXB0104RGY VQFN (14) 3.50 mm × 3.50 mm TXB0104YZT DSBGA (12) 1.40 mm × 1.90 mm TXB0104NMN NFBGA (12) 2.00 mm × 2.50 mm (1) For all available packages, see the orderable addendum at the end of the data sheet. VCCA Processor VCCB Peripheral Typical Application Block Diagram for TXB010X An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 Table of Contents 1 Features............................................................................1 2 Applications..................................................................... 1 3 Description.......................................................................1 4 Revision History.............................................................. 2 5 Pin Configuration and Functions...................................3 6 Specifications.................................................................. 5 6.1 Absolute Maximum Ratings........................................ 5 6.2 ESD Ratings............................................................... 5 6.3 Recommended Operating Conditions.........................6 6.4 Thermal Information....................................................6 6.5 Electrical Characteristics.............................................7 6.6 Timing Requirements: VCCA = 1.2 V........................... 8 6.7 Timing Requirements: VCCA = 1.5 V ± 0.1 V............... 8 6.8 Timing Requirements: VCCA = 1.8 V ± 0.15 V............. 8 6.9 Timing Requirements: VCCA = 2.5 V ± 0.2 V............... 8 6.10 Timing Requirements: VCCA = 3.3 V ± 0.3 V............. 8 6.11 Switching Characteristics: VCCA = 1.2 V................... 9 6.12 Switching Characteristics: VCCA = 1.5 V ± 0.1 V.......9 6.13 Switching Characteristics: VCCA = 1.8 V ± 0.15 V...10 6.14 Switching Characteristics: VCCA = 2.5 V ± 0.2 V.....10 6.15 Switching Characteristics: VCCA = 3.3 V ± 0.3 V..... 11 6.16 Operating Characteristics: VCCA = 1.2 V to 1.5 V, VCCB = 1.5 V to 1.8 V.............................................. 12 6.17 Operating Characteristics: VCCA = 1.8 V to 3.3 V, VCCB = 1.8 V to 5 V................................................. 12 6.18 Typical Characteristics............................................ 13 7 Parameter Measurement Information.......................... 14 8 Detailed Description......................................................16 8.1 Overview................................................................... 16 8.2 Functional Block Diagram......................................... 16 8.3 Feature Description...................................................17 8.4 Device Functional Modes..........................................19 9 Application and Implementation.................................. 20 9.1 Application Information............................................. 20 9.2 Typical Application.................................................... 20 10 Power Supply Recommendations..............................22 11 Layout........................................................................... 22 11.1 Layout Guidelines................................................... 22 11.2 Layout Example...................................................... 22 12 Device and Documentation Support..........................23 12.1 Receiving Notification of Documentation Updates..23 12.2 Support Resources................................................. 23 12.3 Trademarks............................................................. 23 12.4 Electrostatic Discharge Caution..............................23 12.5 Glossary..................................................................23 13 Mechanical, Packaging, and Orderable Information.................................................................... 23 4 Revision History NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Changes from Revision I (March 2018) to Revision J (October 2020) Page • Updated the numbering format for tables, figures, and cross-references throughout the document..................1 • Added NMN Package, 12-Pin NFBGA pinout drawing in Pin Configuration and Functions section...................3 Changes from Revision H (January 2018) to Revision I (March 2018) Page • Updated Pin Functions table ..............................................................................................................................3 • Added Pin Assignments table for YZT package ................................................................................................ 3 • Added Pin Assignments table for GXU and ZXU package ................................................................................ 3 • Updated Layout Example ................................................................................................................................ 22 Changes from Revision G (November 2014) to Revision H (January 2018) Page • Added Package, families to Package, pinout drawings in Pin Configuration and Functions section .................3 • Added junction temperature range in Absolute Maximum Ratingstable............................................................. 5 • Changed unit from V to kV in ESD Ratings table............................................................................................... 5 Changes from Revision F (May 2012) to Revision G (November 2014) Page • Added Pin Configuration and Functions section, Handling Rating table, Feature Description section, Device Functional Modes, Application and Implementation section, Power Supply Recommendations section, Layout section, Device and Documentation Support section, and Mechanical, Packaging, and Orderable Information section ............................................................................................................................................................... 1 2 Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 5 Pin Configuration and Functions A B C A 4 4 3 3 2 2 1 1 Figure 5-1. GXU and ZXU Package, 12-Pin BGA Microstar Junior (Top View) B C Figure 5-2. NMN Package, 12-Pin NFBGA (Top View) 3 2 1 D C B A PLACEHOLDER Figure 5-3. YZT Package, 12-Pin DSBGA (Top View) VCCA 1 14 VCCB A1 2 13 B1 A2 3 12 B2 A3 4 11 B3 A4 5 10 B4 NC GND 6 9 7 8 NC OE NC − No internal connection 14 OE VCCB 1 VCCA 13 B1 2 3 4 5 6 1 12 11 VCCB A1 2 10 B1 11 B3 A2 3 9 B2 10 B4 A3 4 8 B3 12 B2 Exposed Center Pad 8 A4 5 6 7 B4 GND 7 OE 9 NC GND A1 A2 A3 A4 NC VCCA Figure 5-4. D or PW Package, 14-Pin SOIC or TSSOP (Top View) Figure 5-6. RUT Package, 12-Pin UQFN (Top View) NC − No internal connection Figure 5-5. RGY Package, 14-Pin VQFN With Exposed Thermal Pad (Top View) Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 3 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 Table 5-1. Pin Functions PIN D, PW RGY RUT GXU, ZXU, NMN YZT A1 2 2 2 A1 A3 I/O Input/output 1. Referenced to VCCA. A2 3 3 3 A2 B3 I/O Input/output 2. Referenced to VCCA. A3 4 4 4 A3 C3 I/O Input/output 3. Referenced to VCCA. A4 5 5 5 A4 D3 I/O Input/output 4. Referenced to VCCA. B1 13 13 10 C1 A1 I/O Input/output 1. Referenced to VCCB. B2 12 12 9 C2 B1 I/O Input/output 2. Referenced to VCCB. NAME I/O DESCRIPTION B3 11 11 8 C3 C1 I/O Input/output 3. Referenced to VCCB. B4 10 10 7 C4 D1 I/O Input/output 4. Referenced to VCCB. GND 7 7 6 B4 D2 — Ground NC 6, 9 6,9 — — — — No connection. Not internally connected. OE 8 8 12 B3 C2 I Tri-state output-mode enable. Pull OE low to place all outputs in tri-state mode. Referenced to VCCA. VCCA 1 1 1 B2 B2 — A-port supply voltage 1.2 V ≤ VCCA ≤ 3.6 V and VCCA ≤ VCCB. VCCB 14 14 11 B1 A2 — B-port supply voltage 1.65 V ≤ VCCB ≤ 5.5 V. Thermal pad — — — — — For the RGY package, the exposed center thermal pad must either be connected to Ground or left electrically open. Table 5-2. Pin Assignments: NMN, GXU and ZXU Package A B C 4 A4 GND B4 3 A3 OE B3 2 A2 VCCA B2 1 A1 VCCB B1 Table 5-3. Pin Assignments: YZT Package 4 3 2 1 D A4 GND B4 C A3 OE B3 B A2 VCCA B2 A A1 VCCB B1 Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 6 Specifications 6.1 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1) MIN MAX Supply voltage, VCCA –0.5 4.6 Supply voltage, VCCB –0.5 6.5 A port –0.5 4.6 B port –0.5 6.5 A port –0.5 4.6 B port -0.5 6.5 A port –0.5 VCCA + 0.5 B port –0.5 VCCB + 0.5 Input voltage, VI Voltage applied to any output in the high-impedance or power-off state, VO Voltage applied to any output in the high or low state, VO (2) UNIT V V V V Input clamp current, IIK VI < 0 –50 mA Output clamp current, IOK VO < 0 –50 mA Continuous output current, IO –50 50 mA Continuous current through VCCA, VCCB, or GND –100 100 mA 150 °C 150 °C Junction temperature range, TJ Storage temperature range, Tstg (1) (2) –65 Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Section 6.3 is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. The value of VCCA and VCCB are provided in the recommended operating conditions table. 6.2 ESD Ratings VALUE JS-001(1) A port ±2.5 Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001(1) B port ±15 JESD22-C101(2) A port ±1.5 Charged-device model (CDM), per JEDEC specification JESD22-C101(2) B port ±1.5 Human-body model (HBM), per ANSI/ESDA/JEDEC V(ESD) (1) (2) Electrostatic discharge Charged-device model (CDM), per JEDEC specification UNIT kV JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 5 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 6.3 Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted)(1) (2) MIN MAX VCCA Supply voltage 1.2 3.6 VCCB Supply voltage 1.65 5.5 VCCI × 0.65(3) VCCI VCCA × 0.65 5.5 Data VCCA = 1.2 V to 5.5 V inputs VCCB = 1.65 V to 5.5 V 0 VCCI × 0.35(3) VCCA = 1.2 V to 3.6 V VCCB = 1.65 V to 5.5 V 0 VCCA × 0.35 0 3.6 0 5.5 VIH High-level input voltage Data VCCA = 1.2 V to 3.6 V inputs VCCB = 1.65 V to 5.5 V OE VIL Low-level input voltage OE Input transition Δt/Δv rise or fall rate TA (1) (2) (3) V V A-port VCCA = 1.2 V to 3.6 V inputs VCCB = 1.65 V to 5.5 V B-port VCCA = 1.2 V to 3.6 V inputs V V VCCA = 1.2 V to 3.6 V VCCB = 1.65 V to 5.5 V V = 1.2 V to 3.6 V A-port CCA Voltage applied to any VCCB = 1.65 V to 5.5 V output in the high-impedance V = 1.2 V to 3.6 V or power-off state B-port CCA VCCB = 1.65 V to 5.5 V VO UNIT 40 VCCB = 1.65 V to 3.6 V 40 VCCB = 4.5 V to 5.5 V 30 Operating free-air temperature –40 ns/V 85 °C The A and B sides of an unused data I/O pair must be held in the same state, that is, both at VCCI or both at GND. VCCA must be less than or equal to VCCB and must not exceed 3.6 V. VCCI is the supply voltage associated with the input port. 6.4 Thermal Information TXB0104 THERMAL METRIC(1) GXU/ZXU PW RGY RUT YZT NMN 14 PINS 12 PINS 14 PINS 14 PINS 12 PINS 12 PINS 12 PINS RθJA Junction-to-ambient thermal resistance 90.7 127.1 121.0 52.8 119.8 89.2 134.3 Rθ Junction-to-case (top) thermal resistance 50.5 92.8 50.0 67.7 42.6 0.9 90.7 RθJB Junction-to-board thermal resistance 45.4 62.2 62.8 28.9 52.5 14.4 88.4 ψJT Junction-to-top characterization parameter 14.7 2.3 6.4 2.6 0.7 3.0 4.3 ψJB Junction-to-board characterization parameter 45.1 62.2 62.2 29.0 52.3 14.4 89.3 Rθ Junction-to-case (bottom) thermal resistance ─ ─ ─ ─ ─ ─ ─ JC(top) JC(bot) (1) 6 D UNIT °C/W For more information about traditional and new thermal metrics, see the IC Package Thermal Metrics application report. Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 6.5 Electrical Characteristics over recommended operating free-air temperature range (unless otherwise noted) PARAMETER(1) (2) TEST CONDITIONS VCCA VCCB IOH = –20 μA VOLA Port A output low voltage IOL = 20 μA VOHB Port B output high voltage IOH = –20 μA 1.65 V to 5.5 V VOLB Port B output low voltage IOL = 20 μA 1.65 V to 5.5 V II Inflection-point OE: current VI = VCCI or GND Ioff Off-state current ICCA ICCB VCCA supply current VCCB supply current MAX MIN MAX 1.4 V to 3.6 V 1.2 V 0.3 1.4 V to 3.6 V 0.4 VCCB – 0.4 0.4 V μA –1 1 –2 2 A port: VI or VO = 0 to 3.6 V 0V 0 V to 5.5 V –1 1 –2 2 B port: VI or VO = 0 to 5.5 V 0 V to 3.6 V 0V –1 1 –2 2 1.2 V to 3.6 V 1.65 V to 5.5 V –1 1 –2 2 1.2 V 1.65 V to 5.5 V 1.4 V to 3.6 V 1.65 V to 5.5 V 5 3.6 V 0V 2 VI = VCCI or GND IO = 0 VI = VCCI or GND IO = 0 ICCZA HighVI = VCCI or GND impedance IO = 0, state, VCCA OE = GND supply current ICCZB HighVI = VCCI or GND impedance IO = 0, state, VCCB OE = GND supply current Ci Input capacitance Cio Input-to-output A port internal B port capacitance OE V V 1.65 V to 5.5 V A or B port: OE = GND UNIT V VCCA – 0.4 1.2 V to 3.6 V ICCA + Combined VI = VCCI or GND ICCB supply current IO = 0 (1) (2) TYP –40°C to 85°C 1.1 Port A output high voltage IOZ MIN 1.2 V VOHA Highimpedancestate output current TA = 25°C μA μA 0.06 0V 5.5 V 1.2 V 1.65 V to 5.5 V 1.4 V to 3.6 V 1.65 V to 5.5 V 5 3.6 V 0V –2 μA –2 3.4 0V 5.5 V 1.2 V 1.65 V to 5.5 V 1.4 V to 3.6 V 1.65 V to 5.5 V 1.2 V 1.65 V to 5.5 V 1.4 V to 3.6 V 1.65 V to 5.5 V 1.2 V 1.65 V to 5.5 V 1.4 V to 3.6 V 1.65 V to 5.5 V 1.2 V to 3.6 V 1.65 V to 5.5 V 3 4 1.2 V to 3.6 V 1.65 V to 5.5 V 5 6 1.2 V to 3.6 V 1.65 V to 5.5 V 11 14 μA 2 3.5 10 μA 0.05 5 μA 3.3 5 μA pF pF VCCI is the supply voltage associated with the input port. VCCO is the supply voltage associated with the output port. Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 7 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 6.6 Timing Requirements: VCCA = 1.2 V TA = 25°C, VCCA = 1.2 V VCCB = 1.8 V MIN TYP Data rate tw Pulse duration Data inputs VCCB = 2.5 V MAX MIN TYP MAX VCCB = 3.3 V MIN VCCB = 5 V TYP MAX MIN TYP MAX UNIT 20 20 20 20 Mbps 50 50 50 50 ns 6.7 Timing Requirements: VCCA = 1.5 V ± 0.1 V over recommended operating free-air temperature range, VCCA = 1.5 V ± 0.1 V (unless otherwise noted) VCCB = 1.8 V ± 0.15 V MIN MAX Data rate tw Pulse duration VCCB = 2.5 V ± 0.2 V MIN MAX 40 Data inputs VCCB = 3.3 V ± 0.3 V MIN 40 25 25 VCCB = 5 V ± 0.5 V MAX MIN 40 40 25 UNIT MAX 25 Mbps ns 6.8 Timing Requirements: VCCA = 1.8 V ± 0.15 V over recommended operating free-air temperature range, VCCA = 1.8 V ± 0.15 V (unless otherwise noted) VCCB = 1.8 V ± 0.15 V MIN MAX Data rate tw Pulse duration VCCB = 2.5 V ± 0.2 V MIN MAX 60 Data inputs VCCB = 3.3 V ± 0.3 V MIN 60 17 VCCB = 5 V ± 0.5 V MAX MIN 60 17 60 17 UNIT MAX 17 Mbps ns 6.9 Timing Requirements: VCCA = 2.5 V ± 0.2 V over recommended operating free-air temperature range, VCCA = 2.5 V ± 0.2 V (unless otherwise noted) VCCB = 2.5 V ± 0.2 V MIN MAX Data rate tw Pulse duration Data inputs VCCB = 3.3 V ± 0.3 V MIN 100 10 MAX VCCB = 5 V ± 0.5 V MIN 100 10 UNIT MAX 100 10 Mbps ns 6.10 Timing Requirements: VCCA = 3.3 V ± 0.3 V over recommended operating free-air temperature range, VCCA = 3.3 V ± 0.3 V (unless otherwise noted) VCCB = 3.3 V ± 0.3 V MIN Data rate tw 8 Pulse duration MAX VCCB = 5 V ± 0.5 V MIN 100 Data inputs 10 Submit Document Feedback 100 10 UNIT MAX Mbps ns Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 6.11 Switching Characteristics: VCCA = 1.2 V TA = 25°C, VCCA = 1.2 V PARAMETER TEST CONDITIONS VCCB = 1.8 V MIN TYP VCCB = 2.5 V MAX MIN TYP VCCB = 3.3 V MAX MIN TYP VCCB = 5 V MAX MIN TYP MAX UNIT A-to-B 6.9 5.7 5.3 5.5 B-to-A 7.4 6.4 6 5.8 OE-to-A 1 1 1 1 OE-to-B 1 1 1 1 OE-to-A 18 15 14 14 OE-to-B 20 17 16 16 Input rise trA, tfA time, input fall time A-port rise and fall times 4.2 4.2 4.2 4.2 ns Input rise trB, tfB time, input fall time B-port rise and fall times 2.1 1.5 1.2 1.1 ns Channel-tochannel skew 0.4 0.5 0.5 1.4 ns tpd Propagation delay time ten Enable time tdis Disable time tSK(O) Skew (time), output Maximum data rate 20 20 20 ns µs ns 20 Mbps 6.12 Switching Characteristics: VCCA = 1.5 V ± 0.1 V over recommended operating free-air temperature range, VCCA = 1.5 V ± 0.1 V (unless otherwise noted) PARAMETER tpd Propagation delay time ten Enable time tdis Disable time TEST CONDITIONS VCCB = 1.8 V ± 0.15 V VCCB = 2.5 V ± 0.2 V VCCB = 3.3 V ± 0.3 V MIN MAX MIN MAX MIN A-to-B 1.4 12.9 1.2 10.1 B-to-A 0.9 14.2 0.7 12 VCCB = 5 V ± 0.5 V UNIT MAX MIN MAX 1.1 10 0.8 9.9 0.4 11.7 0.3 13.7 OE-to-A 1 1 1 1 OE-to-B 1 1 1 1 ns µs OE-to-A 5.9 31 5.7 25.9 5.6 23 5.7 22.4 OE-to-B 5.4 30.3 4.9 22.8 4.8 20 4.9 19.5 Input rise trA, tfA time, input fall time A-port rise and fall times 1.4 5.1 1.4 5.1 1.4 5.1 1.4 5.1 ns Input rise trB, tfB time, input fall time B-port rise and fall times 0.9 4.5 0.6 3.2 0.5 2.8 0.4 2.7 ns 0.5 ns tSK(O) Skew (time), output Maximum data rate Channel-tochannel skew 0.5 40 0.5 40 0.5 40 40 ns Mbps Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 9 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 6.13 Switching Characteristics: VCCA = 1.8 V ± 0.15 V over recommended operating free-air temperature range, VCCA = 1.8 V ± 0.15 V (unless otherwise noted) PARAMETER TEST CONDITIONS tpd Propagation A-to-B delay time B-to-A ten Enable time tdis Disable time VCCB = 1.8 V ± 0.15 V VCCB = 2.5 V ± 0.2 V VCCB = 3.3 V ± 0.3 V VCCB = 5 V ± 0.5 V MIN MAX MIN MAX MIN MAX MIN MAX 1.6 11 1.4 7.7 1.3 6.8 1.2 6.5 1.5 12 1.3 8.4 1 7.6 0.9 7.1 OE-to-A 1 1 1 1 OE-to-B 1 1 1 1 UNIT ns µs OE-to-A 5.9 31 5.1 21.3 5 19.3 5 17.4 OE-to-B 5.4 30.3 4.4 20.8 4.2 17.9 4.3 16.3 Input rise trA, tfA time, input fall time A-port rise and fall times 1 4.2 1.1 4.1 1.1 4.1 1.1 4.1 ns Input rise trB, tfB time, input fall time B-port rise and fall times 0.9 3.8 0.6 3.2 0.5 2.8 0.4 2.7 ns 0.5 ns Skew (time), output tSK(O) Channel-tochannel skew Maximum data rate 0.5 0.5 60 0.5 60 60 60 ns Mbps 6.14 Switching Characteristics: VCCA = 2.5 V ± 0.2 V over recommended operating free-air temperature range, VCCA = 2.5 V ± 0.2 V (unless otherwise noted) PARAMETER TEST CONDITIONS VCCB = 2.5 V ± 0.2 V VCCB = 3.3 V ± 0.3 V VCCB = 5 V ± 0.5 V MIN MAX MIN MAX MIN MAX 1.1 6.3 1 5.2 0.9 4.7 1.2 6.6 1.1 5.1 0.9 4.4 UNIT tpd Propagatio A-to-B n delay B-to-A time ten Enable time OE-to-A 1 1 1 OE-to-B 1 1 1 tdis Disable time OE-to-A 5.1 21.3 4.6 15.2 4.6 13.2 OE-to-B 4.4 20.8 3.8 16 3.9 13.9 trA, tfA Input rise A-port time, input rise and fall time fall times 0.8 3 0.8 3 0.8 3 ns trB, tfB Input rise B-port time, input rise and fall time fall times 0.7 2.6 0.5 2.8 0.4 2.7 ns tSK(O) Skew (time), output 0.5 ns Channel-tochannel skew Maximum data rate 10 0.5 100 0.5 100 Submit Document Feedback 100 ns μs ns Mbps Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 6.15 Switching Characteristics: VCCA = 3.3 V ± 0.3 V over recommended operating free-air temperature range, VCCA = 3.3 V ± 0.3 V (unless otherwise noted) PARAMETER TEST CONDITIONS tpd Propagation A-to-B delay time B-to-A ten Enable time tdis Disable time trA, tfA VCCB = 3.3 V ± 0.3 V VCCB = 5 V ± 0.5 V MIN MAX MIN MAX 0.9 4.7 0.8 4 1 4.9 0.9 3.8 OE-to-A 1 1 OE-to-B 1 1 UNIT ns μs OE-to-A 4.6 15.2 4.3 12.1 OE-to-B 3.8 16 3.4 13.2 Input rise time, input fall time A-port rise and fall times 0.7 2.5 0.7 2.5 ns trB, tfB Input rise time, input fall time B-port rise and fall times 0.5 2.1 0.4 2.7 ns tSK(O) Skew (time), Channel-to-channel output skew 0.5 ns Maximum data rate 0.5 100 100 ns Mbps Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 11 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 6.16 Operating Characteristics: VCCA = 1.2 V to 1.5 V, VCCB = 1.5 V to 1.8 V TA = 25°C PARAMETER CpdA CpdB CpdA CpdB Power dissipation capacitance Power dissipation capacitance Power dissipation capacitance Power dissipation capacitance VCCA = 1.2 V, VCCB =1.5 V TEST CONDITIONS CL = 0 f = 10 MHz tr = tf = 1 ns OE = VCCA (outputs enabled) CL = 0 f = 10 MHz tr = tf = 1 ns OE = GND (outputs disabled) MIN TYP VCCA = 1.2 V, VCCB = 1.8 V MAX MIN TYP VCCA = 1.5 V, VCCB = 1.8 V MAX MIN TYP A-port input, B-port output 7.8 10 9 B-port input, A-port output 12 11 11 A-port input, B-port output 38.1 28 28 B-port input, A-port output 25.4 19 18 A-port input, B-port output 0.01 0.01 0.01 B-port input, A-port output 0.01 0.01 0.01 A-port input, B-port output 0.01 0.01 0.01 B-port input, A-port output 0.01 0.01 0.01 MAX UNIT pF pF 6.17 Operating Characteristics: VCCA = 1.8 V to 3.3 V, VCCB = 1.8 V to 5 V TA = 25°C PARAMETER TEST CONDITIONS VCCA = 1.8 V, VCCB =1.8 V MIN Power CpdA dissipation CL = 0 capacitance f = 10 MHz tr = tf = 1 ns OE = VCCA (outputs Power CpdB dissipation enabled) capacitance Power CpdA dissipation CL = 0 capacitance f = 10 MHz tr = tf = 1 ns OE = GND (outputs Power CpdB dissipation disabled) capacitance 12 TYP MAX VCCA = 2.5 V, VCCB = 2.5 V MIN TYP VCCA = 2.5 V, VCCB = 5 V MAX MIN TYP MAX VCCA = 3.3 V, VCCB = 3.3 V to 5 V MIN TYP A-port input, B-port output 8 8 8 9 B-port input, A-port output 11 11 11 11 A-port input, B-port output 28 29 29 29 B-port input, A-port output 18 19 21 22 A-port input, B-port output 0.01 0.01 0.01 0.01 B-port input, A-port output 0.01 0.01 0.01 0.01 A-port input, B-port output 0.01 0.01 0.01 0.03 B-port input, A-port output 0.01 0.01 0.01 0.04 UNIT MAX pF pF Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 6.18 Typical Characteristics 6 40 25qC (Room Temperature) 85qC 5 A Port I/O Capacitance (pF) OE Pin Input Capacitance (pF) 6 4 3 2 1 0 0 0.5 1 1.5 2 2.5 VCCA (V) 3 3.5 5 4 3 2 40 25qC (Room Temperature) 85qC 1 0 4 0 0.5 1 D001 VCCB= 3.3 V 1.5 2 2.5 VCCA (V) 3 3.5 4 D002 VCCB= 3.3 V Figure 6-1. Input Capacitance for OE Pin (CI) vs Power Supply (VCCA) Figure 6-2. Capacitance for A port I/O Pins (CiO) vs Power Supply (VCCA) B Port I/O Capacitance (pF) 12 10 8 6 4 40 25qC (Room Temperature) 85qC 2 0 0 0.5 1 1.5 2 2.5 3 VCCB (V) 3.5 4 4.5 5 5.5 D003 VCCA= 1.8 V Figure 6-3. Capacitance for B Port I/O Pins (CiO) vs Power Supply (VCCB) Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 13 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 7 Parameter Measurement Information Unless otherwise noted, all input pulses are supplied by generators that have the following characteristics: • PRR 10 MHz • ZO = 50 W • dv/dt ≥ 1 V/ns Note All parameters and waveforms are not applicable to all devices. From Output Under Test 15 pF A. 1M The outputs are measured one at a time, with one transition per measurement. Figure 7-1. Load Circuit For Maximum Data Rate: Pulse Duration, Propagation Delay Output Rise, And Fall Time Measurement 2 x VCCO S1 50 k From Output Under Test 15 pF A. Open 50 k The outputs are measured one at a time, with one transition per measurement. Figure 7-2. Load Circuit For Enable and Disable Time Measurement Table 7-1. Switch Position For Enable and Disable Time Measurement (See Figure 7-2) 14 TEST S1 tPZL, tPLZ 2 × VCCO tPHZ, tPZH Open Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 VCCI Input VCCI / 2 VCCI / 2 0V t PLH Output t PHL VCCO / 2 0.9 VCCO 0.1 VCCO VOH VCCO / 2 VOL tr A. B. C. D. tf VCCI is the VCC associated with the input port. VCCO is theVCC associated with the output port. tPLH and tPHL are the same as tpd. The outputs are measured one at a time, with one transition per measurement. Figure 7-3. Voltage Waveforms Propagation Delay Times tw VCCI Input VCCI / 2 VCCI / 2 0V Figure 7-4. Voltage Waveforms Pulse Duration Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 15 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 8 Detailed Description 8.1 Overview The TXB0104 device is a 4-bit, directionless voltage-level translator specifically designed for translating logic voltage levels. The A port is able to accept I/O voltages ranging from 1.2 V to 3.6 V, while the B port can accept I/O voltages from 1.65 V to 5.5 V. The device is a buffered architecture with edge-rate accelerators (one-shots) to improve the overall data rate. This device can only translate push-pull CMOS logic outputs. If for open-drain signal translation, please refer to TI’s TXS010X products. 8.2 Functional Block Diagram VCCA VCCB OE One Shot B1 A1 4k One Shot 4k 2 channels One Shot B2 B3 A2 A3 4k One Shot 4k One Shot B4 A4 4k One Shot 4k 16 Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 8.3 Feature Description 8.3.1 Architecture The TXB0104 device architecture (see Figure 8-1) does not require a direction-control signal to control the direction of data flow from A to B or from B to A. In a DC state, the output drivers of the device maintain a high or low, but are designed to be weak, so the output drivers can be overdriven by an external driver when data on the bus flows the opposite direction. The output one-shots detect rising or falling edges on the A or B ports. During a rising edge, the one-shot turns on the PMOS transistors (T1, T3) for a short duration, which speeds up the low-to-high transition. Similarly, during a falling edge, the one-shot turns on the NMOS transistors (T2, T4) for a short duration, which speeds up the high-to-low transition. The typical output impedance during output transition is 70 Ω at VCCO = 1.2 V to 1.8 V, 50 Ω at VCCO = 1.8 V to 3.3 V, and 40 Ω at VCCO = 3.3 V to 5 V. VCCA VCCB One Shot T1 4k One Shot T2 A B One Shot T3 4k T4 One Shot Figure 8-1. Architecture of TXB0104 Device I/O Cell Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 17 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 8.3.2 Input Driver Requirements Typical IIN vs VIN characteristics of the device are shown in Figure 8-2. For proper operation, the device driving the data I/Os of the TXB0104 device must have drive strength of at least ±2 mA. IIN VT /4 k VIN ±(VD ± VT)/4 k A. B. VT is the input threshold of the TXB0104 device, (typically VCC / 2). VD is the supply voltage of the external driver. Figure 8-2. Typical IIN vs VIN Curve 8.3.3 Output Load Considerations TI recommends careful PCB layout practices with short PCB trace lengths to avoid excessive capacitive loading and to ensure that proper O.S. triggering takes place. PCB signal trace-lengths must be kept short enough such that the round trip delay of any reflection is less than the one-shot duration. This improves signal integrity by ensuring that any reflection sees a low impedance at the driver. The O.S. circuits have been designed to stay on for approximately 10 ns. The maximum capacitance of the lumped load that can be driven also depends directly on the one-shot duration. With very heavy capacitive loads, the one-shot can time-out before the signal is driven fully to the positive rail. The O.S. duration has been set to best optimize trade-offs between dynamic ICC, load driving capability, and maximum bit-rate considerations. Both PCB trace length and connectors add to the capacitance that the device output sees, so it is recommended that this lumped-load capacitance be considered to avoid O.S. retriggering, bus contention, output signal oscillations, or other adverse system-level affects. 18 Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 8.3.4 Enable and Disable The TXB0104 device has an OE input that is used to disable the device by setting OE = low, which places all I/Os in the high-impedance (Hi-Z) state. The disable time (tdis) indicates the delay between when OE goes low and when the outputs acutally get disabled (Hi-Z). The enable time (ten) indicates the amount of time the user must allow for the one-shot circuitry to become operational after OE is taken high. 8.3.5 Pullup or Pulldown Resistors on I/O Lines The device is designed to drive capacitive loads of up to 70 pF. The output drivers of the TXB0104 device have low dc drive strength. If pullup or pulldown resistors are connected externally to the data I/Os, their values must be kept higher than 50 kΩ to ensure that they do not contend with the output drivers of the TXB0104 device. For the same reason, the TXB0104 device must not be used in applications such as I2C or 1-Wire where an open-drain driver is connected on the bidirectional data I/O. For these applications, use a device from the TI TXS01xx series of level translators. 8.4 Device Functional Modes The device has two functional modes, enabled and disabled. To disable the device, set the OE input to low, which places all I/Os in a high impedance state. Setting the OE input to high will enable the device. Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 19 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 9 Application and Implementation Note Information in the following applications sections is not part of the TI component specification, and TI does not warrant its accuracy or completeness. TI’s customers are responsible for determining suitability of components for their purposes, as well as validating and testing their design implementation to confirm system functionality. 9.1 Application Information The TXB0104 device can be used in level-translation applications for interfacing devices or systems operating at different interface voltages with one another. It can only translate push-pull CMOS logic outputs. If for open-drain signal translation, please refer to TI TXS010X products. Any external pulldown or pullup resistors are recommended larger than 50 kΩ. 9.2 Typical Application 3.3 V 1.8 V 0.1 …F VCCA 0.1 …F VCCB OE 1.8 V System Controller 3.3 V System TXB0104 Data Data GND 9.2.1 Design Requirements For this design example, use the parameters listed in Table 9-1. And make sure the VCCA ≤ VCCB. Table 9-1. Design Parameters DESIGN PARAMETERS 20 EXAMPLE VALUE Input voltage range 1.2 V to 3.6 V Output voltage range 1.65 V to 5.5 V Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 9.2.2 Detailed Design Procedure To begin the design process, determine the following: • Input voltage range - Use the supply voltage of the device that is driving the TXB0104 device to determine the input voltage range. For a valid logic high, the value must exceed the VIH of the input port. For a valid logic low, the value must be less than the VIL of the input port. • Output voltage range - Use the supply voltage of the device that the device is driving to determine the output voltage range. - External pullup or pulldown resistors are not recommended. If mandatory, it is recommended that the value must be larger than 50 kΩ. • An external pulldown or pullup resistor decreases the output VOH and VOL. Use the below equations to draft estimate the VOH and VOL as a result of an external pulldown and pullup resistor. VOH = VCCx × RPD / (RPD + 4.5 kΩ) VOL = VCCx × 4.5 kΩ / (RPU + 4.5 kΩ) Where • VCCx is the output port supply voltage on either VCCA or VCCB • RPD is the value of the external pull down resistor • RPU is the value of the external pull up resistor • 4.5 kΩ is the counting the variation of the serial resistor 4 kΩ in the I/O line. 9.2.3 Application Curves Figure 9-1. Level-Translation of a 2.5-MHz Signal Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 21 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 10 Power Supply Recommendations During operation, ensure that VCCA ≤ VCCB at all times. During power-up sequencing, VCCA ≥ VCCB does not damage the device, so any power supply can be ramped up first. The device has circuitry that disables all output ports when either VCC is switched off (VCCA/B = 0 V). The output-enable (OE) input circuit is designed so that it is supplied by VCCA and when the (OE) input is low, all outputs are placed in the high-impedance state. To ensure the high-impedance state of the outputs during power up or power down, the OE input pin must be tied to GND through a pulldown resistor and must not be enabled until VCCA and VCCB are fully ramped and stable. The minimum value of the pulldown resistor to ground is determined by the current-sourcing capability of the driver. 11 Layout 11.1 Layout Guidelines To ensure reliability of the device, following common printed-circuit board layout guidelines is recommended. • Bypass capacitors must be used on power supplies, and must be placed as close as possible to the VCCA, VCCB pin and GND pin. • Short trace-lengths must be used to avoid excessive loading. • PCB signal trace-lengths must be kept short enough so that the round-trip delay of any reflection is less than the one-shot duration, approximately 10 ns, ensuring that any reflection encounters low impedance at the source driver. 11.2 Layout Example LEGEND Polygonal VIA to Power Plane Copper Pour VIA to GND Plane (Inner Layer) TXB0104PWR Bypass Capacitor To Controller To Controller 0.1 …F 0.1 …F 1 VCCA 2 VCCB 14 A1 B1 13 3 A2 B2 12 4 A3 B3 11 To System To System To System To Controller To Controller Bypass Capacitor 5 A4 B4 10 6 NC NC 9 7 GND OE 8 To System Keep OE low until VCCA and VCCB are powered up 22 Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 12 Device and Documentation Support 12.1 Receiving Notification of Documentation Updates To receive notification of documentation updates, navigate to the device product folder on ti.com. Click on Subscribe to updates to register and receive a weekly digest of any product information that has changed. For change details, review the revision history included in any revised document. 12.2 Support Resources TI E2E™ support forums are an engineer's go-to source for fast, verified answers and design help — straight from the experts. Search existing answers or ask your own question to get the quick design help you need. Linked content is provided "AS IS" by the respective contributors. They do not constitute TI specifications and do not necessarily reflect TI's views; see TI's Terms of Use. 12.3 Trademarks BGA MICROSTAR JUNIOR™ is a trademark of Texas Instruments. TI E2E™ is a trademark of Texas Instruments. All trademarks are the property of their respective owners. 12.4 Electrostatic Discharge Caution This integrated circuit can be damaged by ESD. Texas Instruments recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. 12.5 Glossary TI Glossary This glossary lists and explains terms, acronyms, and definitions. 13 Mechanical, Packaging, and Orderable Information The following pages include mechanical, packaging, and orderable information. This information is the most current data available for the designated devices. This data is subject to change without notice and revision of this document. For browser-based versions of this data sheet, refer to the left-hand navigation. Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 23 TXB0104 www.ti.com SCES650J – APRIL 2006 – REVISED OCTOBER 2020 24 Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: TXB0104 PACKAGE OPTION ADDENDUM www.ti.com 19-Oct-2022 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) Device Marking (3) Samples (4/5) (6) TXB0104D ACTIVE SOIC D 14 50 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 TXB0104 Samples TXB0104DG4 ACTIVE SOIC D 14 50 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 TXB0104 Samples TXB0104DR ACTIVE SOIC D 14 2500 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 TXB0104 Samples TXB0104DRG4 ACTIVE SOIC D 14 2500 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 TXB0104 Samples TXB0104NMNR ACTIVE NFBGA NMN 12 2500 RoHS & Green SNAGCU Level-2-260C-1 YEAR -40 to 85 2AQW Samples TXB0104PWR ACTIVE TSSOP PW 14 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 YE04 Samples TXB0104PWRG4 ACTIVE TSSOP PW 14 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 YE04 Samples TXB0104RGYR ACTIVE VQFN RGY 14 3000 RoHS & Green NIPDAU Level-2-260C-1 YEAR -40 to 85 YE04 Samples TXB0104RGYRG4 ACTIVE VQFN RGY 14 3000 RoHS & Green NIPDAU Level-2-260C-1 YEAR -40 to 85 YE04 Samples TXB0104RUTR ACTIVE UQFN RUT 12 3000 RoHS & Green NIPDAUAG Level-1-260C-UNLIM -40 to 85 (2KR, 2KV) Samples TXB0104YZTR ACTIVE DSBGA YZT 12 3000 RoHS & Green SNAGCU Level-1-260C-UNLIM -40 to 85 2K Samples (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
BOB-11771 价格&库存
很抱歉,暂时无法提供与“BOB-11771”相匹配的价格&库存,您可以联系我们找货
BOB-11771
    • 1+93.42000
    • 200+37.28160
