PRT-10217
PRT-10217
    SPARKFUNELECTRONICS
PRT-10217 数据手册
 SparkFun LiPo Charger Basic - Micro-USB PRT-10 217 ROH S        5  images are CC BY-NC-SA 3.0 Description: If you need to charge LiPo batteries, this simple charger will do just that, and do it fast! The SparkFun LiPo Charger Basic is stripped down of all features and just does one thing well - charge 3.7V LiPo cells at a rate of 500mA. It is designed to charge single-cell Li-Ion or Li-Polymer batteries. Check the datasheet below to see if it will work with your battery. The board incorporates a charging circuit, status LED, connector for your battery (JST-type used in the batteries we carry), and a micro-USB connector. A small mounting hole allows this charger to be easily embedded into a project. Note: This version uses a micro-USB cable. We also have this charger with a miniUSB connection as well. Dimensions: 29.4x10.8mm https://www.sparkfun.com/products/10217 10/9/2015
PRT-10217 价格&库存
很抱歉,暂时无法提供与“PRT-10217”相匹配的价格&库存,您可以联系我们找货
