MIKROE-222
MIKROE-222
    MIKRO
    MAX232 - Interface, Transceiver, RS-232 Evaluation Board
MIKROE-222 数据手册
All Mikroelektronika’s development systems feature a large number of peripheral modules expanding microcontroller’s range of application and making the process of program testing easier. In addition to these modules, it is also possible to use numerous additional modules linked to the development system through the I/O port connectors. Some of these additional modules can operate as stand-alone devices without being connected to the microcontroller. Manual Additional Board MAX232 Board ™ MikroElektronika MAX232 Board MAX232 Board A standard serial interface RS232C for a PC uses voltage levels in a range between -12V and +12V. For the serial signal used by this standard, a voltage ranging between -3 and -12V stands for a logic one (1), whereas a voltage in a range between +3V and +12V stands for a logic zero (0). In order to adjust this signal to voltage levels present on the microcontroller pins (TTL standard), it is necessary to use a voltage level converter. The MAX232 board features a built-in circuit MAX232 used to perform necessary adjustment. This circuit is powered with a single 5V voltage. It is used to convert a serial signal from TTL to RS232C standard and vice versa by means of a built-in voltage generator. There are two connectors provided on the MAX232 board. The female connector DB9 enables connection with devices that use RS232 standard (usually a PC), whereas the 6-pin connector enables connection with the microcontroller pins intended for serial communication (USART). Figure 1: MAX232 additional board Figure 2: MAX232 board connected to a development system via proto board The MAX232 additional board can be connected to a microcontroller provided on the development system. In this case, a PROTO board should be used for connection with the development system’s I/O port. If the MAX232 board is connected to some other device, the connection is established via the appropriate 6-pin female connector or a flat cable. The board is connected to a PC via a standard serial cable provided with a pair of male-female connectors DB9. Figure 3: MAX232 board connection schematic MikroElektronika Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: mikroElektronika: MIKROE-222
MIKROE-222 价格&库存
很抱歉,暂时无法提供与“MIKROE-222”相匹配的价格&库存,您可以联系我们找货
MIKROE-222
  • 1+71.13692
  • 5+69.00209
库存:152
MIKROE-222
