Thermocouple Amplifier MAX31855 breakout
board (MAX6675 upgrade)
PRODUCT ID: 269
9/30/2014
DESCRIPTION
Thermocouples are very sensitive, requiring a good amplifier with a cold-compensation reference. The
MAX31855K does everything for you, and can be easily interfaced with any microcontroller, even one without an
analog input. This breakout board has the chip itself, a 3.3V regulator with 10uF bypass capacitors and level
shifting circuitry, all assembled and tested. Comes with a 2 pin terminal block (for connecting to the
thermocouple) and pin header (to plug into any breadboard or perfboard). Goes great with our 1m K-type
thermocouple (http://www.adafruit.com/products/270).
New! Now uses the MAX31855K instead of the MAX6675, so it can measure a wider temperature measurement
range. Please note! the MAX31855 is not pin compatible or drop-in code compatible with the MAX6675. We do
have an Arduino library for both chips but you'll need to adjust any existing MAX6675 designs for the mew
MAX31855. The MAX6675 has been discontinued by Maxim.
Version 2.0 now includes ferrite beads and filter capacitor onboard for better stability
• Works with any K type thermocouple
• Will not work with any other kind of thermocouple other than K type
• -200°C to +1350°C output in 0.25 degree increments - note that K thermocouples have about ±2°C to ±6°C
accuracy
• Internal temperature reading
• 3.3 to 5v power supply and logic level compliant!
• SPI data output requires any 3 digital I/O pins.
Hey we even have a handy tutorial on thermocouples which includes an Arduino library, wiring diagrams and
example code. How easy is that? (http://learn.adafruit.com/thermocouple/)
http://www.adafruit.com/product/269
9/30/2014
很抱歉,暂时无法提供与“269”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+131.689101+16.39104
