ENC28J60-H
ENC28J60-H
    OLIMEX
ENC28J60-H 数据手册
ENC28J60 ENC28J60 Silicon Errata and Data Sheet Clarification The ENC28J60 devices that you have received conform functionally to the current Device Data Sheet (DS39662C), except for the anomalies described in this document. The silicon issues discussed in the following pages are for silicon listed in Table 1. The silicon issues are summarized in Table 2. Issues specific to technical conformance with IEEE Std. 802.3 are listed in Table 3. Data Sheet clarifications and corrections start on page 9, following the discussion of silicon issues. TABLE 1: Note: This document summarizes all silicon errata issues from all revisions of silicon, previous as well as current. Only the issues indicated in the last column of Table 2 and Table 3 apply to the current silicon revision (B7). The silicon revision level can be retrieved by querying the read-only EREVID register, located at address 12h in Bank 3 of the device’s Control register space. Please refer to the Device Data Sheet for detailed information on accessing this register. The values for the various ENC28J60 silicon revisions are shown in Table 1. SILICON EREVID VALUES Part Number B1 B4 B5 B7 ENC28J60 0000 0010 0000 0100 0000 0101 0000 0110  2010 Microchip Technology Inc. DS80349C-page 1 ENC28J60 TABLE 2: SILICON ISSUE SUMMARY Module Feature Issue Affected Revisions Issue Summary B1 B4 B5 B7 MAC Interface — 1. MAC registers unreliable with slow asynchronous SPI clock X X Reset — 2. CLKRDY set early X X Core Operating Specifications 3. Industrial (-40C to +85C) temperature range unsupported X X Oscillator CLKOUT pin 4. CLKOUT unavailable in Power Save mode X Memory Ethernet Buffer 5. Receive buffer must start at 0000h X Interrupts — 6. Receive Packet Pending Interrupt Flag (PKTIF) unreliable X X X X PHY — 7. TPIN+/- automatic polarity detection and correction unreliable X X X X PHY — 8. RBIAS resistor value differs between silicon revisions X X PHY — 9. Internal loopback in half-duplex unreliable X X X X PHY — 10. Internal loopback in full-duplex unreliable X X X X X X X X X X X X PHY LEDs — 11. Combined Collision and Duplex Status mode unavailable X X X X Transmit Logic — 12. Transmit abort may stall transmit logic X X X X PHY — 13. Received link pulses potentially cause collisions X X Memory Ethernet Buffer 14. Even values in ERXRDPT may corrupt receive buffer X X X X Transmit Logic — 15. LATECOL Status bit unreliable X X X X PHY LEDs — 16. LED auto-polarity detection unreliable X X X X DMA — 17. DMA checksum calculations will abort receive packets X X X X Receive Filter — 18. Pattern match filter allows reception of extra packets X X X X SPI Interface — 19. Reset command unavailable in Power Save mode X X X X TABLE 3: ETHERNET CONFORMANCE ISSUES Issue Affected Revisions Issue Summary B1 B4 1. TP_IDL transmit waveform violates IEEE STD 802.3™ template X X 2. PHY accepts receive packet in Link Test Fail state X X 3. Collision enforcement is delayed X X DS80349C-page 2 B5 B7  2010 Microchip Technology Inc. ENC28J60 Silicon Errata Issues Note: This document summarizes all silicon errata issues from all revisions of silicon, previous as well as current. Only the issues indicated by the shaded column in the following tables apply to the current silicon revision (B7). 1. Module: MAC Interface When the SPI clock from the host microcontroller is run at frequencies of less than 8 MHz, reading or writing to the MAC registers may be unreliable. 3. Module: Core (Operating Specifications) The device data sheet specifies that industrial operating temperature range (-40C to +85C) is supported. However, silicon revisions B1 and B4 only support the commercial temperature range (0C to +70C). Work around Use silicon revision B5 or later. Affected Silicon Revisions B1 B4 X X B5 B7 Work around Two work arounds are presented; others may be available. 1. Run the SPI at frequencies of at least 8 MHz. 2. Generate an SPI clock of 25/2 (12.5 MHz), 25/3 (8.333 MHz), 25/4 (6.25 MHz), 25/5 (5 MHz), etc., and synchronize with the 25 MHz clock entering OSC1 on the ENC28J60. This could potentially be accomplished by feeding the same 25 MHz clock into the ENC28J60 and host controller. Alternatively, the host controller could potentially be clocked off of the CLKOUT output of the ENC28J60. Affected Silicon Revisions B1 B4 X X B5 4. Module: Oscillator (CLKOUT Pin) No output is available on CLKOUT while operating in Power Save mode (ECON2.PWRSV = 0). Work around If the host controller uses the CLKOUT signal as the system clock, do not enable Power Save mode. Affected Silicon Revisions B1 B4 B5 B7 X X X X B7 5. Module: Memory (Ethernet Buffer) 2. Module: Reset After sending an SPI Reset command, the PHY clock is stopped but the ESTAT.CLKRDY bit is not cleared. Therefore, polling the CLKRDY bit will not work to detect if the PHY is ready. Additionally, the hardware start-up time of 300 s may expire before the device is ready to operate. Work around After issuing the Reset command, wait at least 1 ms in firmware for the device to be ready. Affected Silicon Revisions B1 B4 B5 B7 X X X X  2010 Microchip Technology Inc. The receive hardware maintains an internal Write Pointer which defines the area in the receive buffer where bytes arriving over the Ethernet are written. This internal Write Pointer should be updated with the value stored in ERXST whenever the Receive Buffer Start Pointer, ERXST, or the Receive Buffer End Pointer, ERXND, is written to by the host microcontroller. Sometimes, when ERXST or ERXND is written to, the exact value, 0000h, is stored in the internal receive Write Pointer instead of the ERXST address. Work around Use the lower segment of the buffer memory for the receive buffer, starting at address 0000h. For example, use the range (0000h to n) for the receive buffer and ((n + 1) to 8191) for the transmit buffer. Affected Silicon Revisions B1 B4 B5 B7 X X X X DS80349C-page 3 ENC28J60 6. Module: Interrupts The Receive Packet Pending Interrupt Flag (EIR.PKTIF) does not reliably/accurately report the status of pending packets. Work around In the Interrupt Service Routine (ISR), if it is unknown if a packet is pending and the source of the interrupt, switch to Bank 1 and check the value in EPKTCNT. If polling to see if a packet is pending, check the value in EPKTCNT. Note: This errata applies only to the interrupt flag. If the receive packet pending interrupt is enabled, the INT pin will continue to reliably become asserted when a packet arrives. The receive packet pending interrupt is cleared in the same manner described in the data sheet. Affected Silicon Revisions B1 B4 B5 B7 X X X X 8. Module: PHY The external resistor value recommended for RBIAS in the current revision of the data sheet does not apply to certain revisions of silicon. Using an incorrect resistor value will cause the Ethernet transmit waveform to violate IEEE 802.3 specification requirements. Work around For silicon revisions, B1 and B4, use a 2.7 k, 1% external resistor between the RBIAS pin and ground. The value shown in the data sheet (2.32 k,) is correct for revisions B5 and B7. Affected Silicon Revisions B1 B4 X X B5 B7 9. Module: PHY The PHY Half-Duplex Loopback mode, enabled when PHCON1.PDPXMD = 0, PHCON2.HDLDIS = 0 and PHCON2.FRCLNK = 1, or a link partner is connected, does not loop packets back to itself reliably. Work around 7. Module: PHY The automatic RX polarity detection and correction features of the PHY layer do not work as described. When incorrect RX polarity is present, poor receive network performance, or no receive activity with some link partners, may occur. Work around When designing the application, always verify that the TPIN+ and TPIN- pins are connected correctly. Perform loopback diagnostics in full duplex using an external loopback connector/cable. To avoid looping occasional packets back to one self, PHCON2.HDLDIS should be set by the host controller. PHCON2.HDLDIS is clear by default. Affected Silicon Revisions B1 B4 B5 B7 X X X X Affected Silicon Revisions B1 B4 B5 B7 X X X X 10. Module: PHY The PHY Full-Duplex Loopback mode, enabled when PHCON1.PDPXMD = 1 and PHCON1.PLOOPBK = 1, does not loop packets back to itself reliably. Work around Perform loopback diagnostics in full duplex using an external loopback connector/cable. Affected Silicon Revisions DS80349C-page 4 B1 B4 B5 B7 X X X X  2010 Microchip Technology Inc. ENC28J60 11. Module: PHY LEDs When the PHLCON register is programmed to output the duplex status and collision activity on the same LED (‘1110’), only the duplex status will be displayed (i.e., the LED will be illuminated when in Full-Duplex mode and extinguished when in Half-Duplex mode, regardless of collision activity). Work around When Half-Duplex mode is being used, program the PHLCON register’s LxCFG bits with ‘0011’ to display the collision status. When Full-Duplex mode is being used, program the PHLCON register’s LxCFG bits with ‘0101’ to display the duplex status. Affected Silicon Revisions B1 B4 B5 B7 X X X X 12. Module: Transmit Logic In Half-Duplex mode, a hardware transmission abort caused by excessive collisions, a late collision or excessive deferrals, may stall the internal transmit logic. The next packet transmit initiated by the host controller may never succeed (ECON1.TXRTS will remain set indefinitely). Work around Before attempting to transmit a packet (setting ECON1.TXRTS), reset the internal transmit logic by setting ECON1.TXRST and then clearing ECON1.TXRST. The host controller may wish to issue this Reset before any packet is transmitted (for simplicity), or it may wish to conditionally reset the internal transmit logic based on the Transmit Error Interrupt Flag (EIR.TXERIF), which will become set whenever a transmit abort occurs. Clearing ECON1.TXRST may cause a new transmit error interrupt event (EIR.TXERIF will become set). Therefore, the interrupt flag should be cleared after the Reset is completed. Affected Silicon Revisions B1 B4 B5 B7 X X X X  2010 Microchip Technology Inc. 13. Module: PHY When transmitting in Half-Duplex mode with some link partners, the PHY will sometimes incorrectly interpret a received link pulse as a collision event. If less than, or equal to, MACLCON2 bytes have been transmitted when the false collision occurs, the MAC will abort the current transmission, wait a random back-off delay and then automatically attempt to retransmit the packet from the beginning – as it would for a genuine collision. If greater than MACLCON2 bytes have been transmitted when the false collision occurs, the event will be considered a late collision by the MAC and the packet will be aborted without retrying. This causes the packet to not be delivered to the remote node. In some cases, the abort will fail to reset the transmit state machine. Work around Implement a software retransmit mechanism whenever a late collision occurs. When a late collision occurs, the associated bit in the transmit status vector will be set. Also, the EIR.TXERIF bit will become set, and if enabled, the transmit error interrupt will occur. If the transmit state machine does not get reset, the ECON1.TXRTS bit will remain set and no transmit interrupt will occur (the EIR.TXIF bit will remain clear). As a result, software should detect the completion of a transmit attempt by checking both TXIF and TXERIF. If the Transmit Interrupt (TXIF) did not occur, software must clear the ECON1.TXRTS bit to force the transmit state machine into the correct state. The logic in Example 1 (following page) will accomplish a transmission and any necessary retransmissions with a maximum retry abort. Affected Silicon Revisions B1 B4 B5 B7 X X DS80349C-page 5 ENC28J60 EXAMPLE 1: ECON1.TXRST = 1 ECON1.TXRST = 0 EIR.TXERIF = 0 EIR.TXIF = 0 ECON1.TXRTS = 1 while(EIR.TXIF = 0 and EIR.TXERIF = 0) NOP ECON1.TXRTS = 0 read tsv for retrycount = 0 to 15 if (EIR.TXERIF and tsv) then ECON1.TXRST = 1 ECON1.TXRST = 0 EIR.TXERIF = 0 EIR.TXIF = 0 ECON1.TXRTS = 1 while(EIR.TXIF = 0 and EIR.TXERIF = 0) NOP ECON1.TXRTS = 0 read tsv else exit for end if next retrycount 14. Module: Memory (Ethernet Buffer) The receive hardware may corrupt the circular receive buffer (including the Next Packet Pointer and receive status vector fields) when an even value is programmed into the ERXRDPTH:ERXRDPTL registers. Work around Ensure that only odd addresses are written to the ERXRDPT registers. Assuming that ERXND contains an odd value, many applications can derive a suitable value to write to ERXRDPT by subtracting one from the Next Packet Pointer (a value always ensured to be even because of hardware padding) and then compensating for a potential ERXST to ERXND wrap-around. Assuming that the receive buffer area does not span the 1FFFh to 0000h memory boundary, the logic in Example 2 will ensure that ERXRDPT is programmed with an odd value: 15. Module: Transmit Logic If a collision occurs after 64 bytes have been transmitted, the transmit logic may not set the Late Collision Error status bit (ESTAT.LATECOL). Work around Whenever a late collision has potentially occurred (both EIR.TXERIF and ESTAT.TXABRT bits will be set), read the transmit status vector and check the transmit late collision bit (bit 29). Affected Silicon Revisions B1 B4 B5 B7 X X X X EXAMPLE 2: if (Next Packet Pointer = ERXST) then: ERXRDPT = ERXND else: ERXRDPT = Next Packet Pointer – 1 Affected Silicon Revisions B1 B4 B5 B7 X X X X DS80349C-page 6  2010 Microchip Technology Inc. ENC28J60 16. Module: PHY LEDs With some LEDs, the LED auto-polarity detection circuit misdetects the connected polarity of the LED upon Reset. As a result, the LED output pin will sink current when it should be sourcing current and vice versa. The LED will visually appear inverted. For example, an LED configured to display the link status will be illuminated when no link is present and extinguished when a link has been established. The likelihood of a misdetection will vary over temperature. If LEDB is misdetected, the PHCON1.PDPXMD bit will also reset to the incorrect state. Work around Place a resistor in parallel with the LED. The resistor value needed is not critical. Resistors between 1 k and 100 k are recommended. Affected Silicon Revisions B1 B4 B5 B7 X X X X the enabled filter criteria. This will occur if the receive packet is less than or equal to 64+EPMO bytes long. For typical applications using the Pattern Match and Unicast receive filters simultaneously with a zero Pattern Match offset, this will result in the reception of unwanted 64-byte Address Resolution Protocol (ARP) broadcast frames, among possible others. Work around When using the pattern match receive filter, discard any unwanted packets in software. Affected Silicon Revisions B1 B4 B5 B7 X X X X 19. Module: SPI Interface When operating in Power Save mode (ECON2.PWRSV = 1), issuing the SPI System Reset command will have no effect. Work around 17. Module: DMA If the DMA module is operated in Checksum mode (ECON1.CSUMEN, DMAST = 1) at any time while a packet is currently being received from the Ethernet (ESTAT.RXBUSY = 1), the packet being received will be aborted. The packet abort will cause the Receive Error Interrupt Flag (EIR.RXERIF) to be set, the interrupt will occur, if enabled, and the Buffer Error status bit (ESTAT.BUFER) will also become set. The packet will be permanently lost. Work around Do not use the DMA module to perform checksum calculations; perform checksums in software. This problem does not affect the DMA copy operation (ECON1.CSUMEN = 0). Affected Silicon Revisions B1 B4 B5 B7 X X X X Clear the PWRSV bit and wait for the device’s power regulator to stabilize before issuing an SPI System Reset command. For a device in an unknown state, the recommended Reset sequence is: 1. Use the Bit Field Clear command and clear ECON2.PWRSV (ECON2). 2. Wait at least 300 µs for power to be restored. 3. Issue the System Reset command. 4. Wait 1 ms for the Reset to complete and to ensure that all modules are ready to be used. 5. Confirm that the Reset has taken place. This can be accomplished by reading a register and checking for an expected Reset value. For example, read ESTAT and confirm that the CLKRDY bit (bit 0) is set and the unimplemented bit (bit 3) is clear. If one or both of these conditions are not met, this may indicate that the ENC28J60 is not ready yet (e.g., the microcontroller has exited POR while ENC28J60 is still powering up). In this case, repeat the procedure from Step 1. Affected Silicon Revisions 18. Module: Receive Filter If using the Pattern Match receive filter, some packets may be accepted that should be rejected. Specifically, if ERXFCON.ANDOR = 0, ERXFCON.PMEN = 1 and at least one of the Hash Table, Magic PacketTM, Broadcast, Multicast or Unicast receive filters are enabled, then packets can be accepted that do not meet any of  2010 Microchip Technology Inc. B1 B4 B5 B7 X X X X DS80349C-page 7 ENC28J60 Ethernet Conformance Issues The following conformance issues were noted in testing the B1 and B4 silicon revisions for compliance with IEEE Standard 802.3. These issues are not present after Revision B4 and are included for informational purposes. In the unlikely event that this situation does occur, higher layer protocols would protect the system from accepting unwanted data. It is unlikely that this failure will have significant impact on a networked application. No failures have been observed due to this issue. 1. Issue: Work around TP_IDL Pattern The observed TP_IDL pattern transmitted by ENC28J60 was observed to not stay within the standard defined template when using the TPM (Twisted Pair Model) and TP Test Load 2. Reference: IEEE Std Figures 14-10 and 14-11 802.3, §14.3.1.2.1, Use silicon revision B5 or later. Affected Silicon Revisions B1 B4 X X B5 B7 Potential Application Impact The TP_IDL test requires a total of six separate subtests, using three different test loads with and without TPM. The fact that the device consistently passed five of the six sub tests, while narrowly missing the sixth, leads to the conclusion that this is a minor issue. No failures have been observed due to this issue. Use silicon revision B5 or later. Affected Silicon Revisions B4 X X 2. Issue: Collision Handling The delay from the collision event to collision enforcement with the jam pattern is approximately 50 BT (Bit Times), which is greater than the specified limit of 36 BT. Reference: IEEE Std 802.3, Annex B, § B.1.2 Potential Application Impact Work around B1 3. Issue: B5 B7 Exiting Link Test Fail State The ENC28J60 was observed to improperly accept a frame with no preceding LTPs (Link Test Pulse). When a device is in the Link Test Fail state, it should exit this state when a valid packet is received, however, the first packet should not be accepted. The second and subsequent packets should be accepted while the device is in the Link Test Pass state. Reference: IEEE Std 802.3, Figure 14-6 A collision in a half-duplex 10Base-T is not an unexpected event. It exists as a normal part of the network operation. The purpose of the jam pattern is to ensure that the duration of the collision is sufficient to be noticed by the other transmitting station(s) involved in the collision. A longer delay between the collision event and the start of jam pattern would cause the duration of the collision to be longer. After each collision, both transmitting stations would back off and wait a random amount of time before attempting to transmit again. The minimum Idle time between each Ethernet frame is 9.6 s. The longer collision duration of 14 BT, or 1.4 s, can be considered as a small fraction of time wasted for each collision. It is unlikely that this issue will have significant impact on networked applications. No failures have been observed due to this issue. Potential Application Impact Work around Link Test Pulse is an integral part of every 10Base-T system. It is used to notify a link partner of the presence of a 10Base-T device. An absence of LTPs signifies that the Ethernet cable is not connected or a link partner is missing. Even when a cable is not connected, a 10Base-T device would continuously send out LTPs. This fact makes it unlikely that there will ever be a situation in which a device would be receiving valid Ethernet frames without already being in the Link Test Pass state. Use silicon revision B5 or later. DS80349C-page 8 Affected Silicon Revisions B1 B4 X X B5 B7  2010 Microchip Technology Inc. ENC28J60 Data Sheet Clarifications The following typographic corrections and clarifications are to be noted for the latest version of the device data sheet (DS39662C): Note: Corrections are shown in bold. Where possible, the original bold text formatting has been removed for clarity. 1. Module: Receive Filter In Section 8.2 “Pattern Match Filter”, it is stated that the pattern match offset programmed into the EPMOH:EPMOL registers should be loaded with the offset from the beginning of the destination address field. This implies that any value can be used. In fact, for correct operation, it is required that the EPMOH:EPMOL registers be programmed with an even value only (i.e., EPMOL must always be ‘0’).  2010 Microchip Technology Inc. DS80349C-page 9 ENC28J60 APPENDIX A: DOCUMENT REVISION HISTORY Rev A Document (10/2007) Original revision. Silicon errata issues 1 (Reset), 2 (Oscillator – CLKOUT Pin), 3 (Memory – Ethernet Buffer), 4 (Interrupts), 5-8 (PHY), 9 (PHY LEDs), 10 (Transmit Logic), 11 (Memory – Ethernet Buffer), 12 (Transmit Logic), 13-14 (PHY) and 15 (DMA). Rev B Document (07/2008) Updated the revision of the referenced data sheet. Changed the revision identifier for this device as the previous version contained an error. Rev C Document (07/2010) Revises the document to include all released silicon revisions of the device, starting with revision B1, and removes “silicon revision B7” from the title. Order of issues has been re-aligned to better reflect sequential issue history: • • • • • • • • • • • • • • 1 (MAC Interface) 2 (Reset) 3 (Core) 4 (Oscillator) 5 (Memory) 6 (Interrupts) 7-10 (PHY) 11 (PHY LEDs) 12 (Transmit Logic) 13 (PHY) 14 (Memory – Ethernet Buffer) 15 (Transmit Logic) 16 (PHY) 17 (DMA) Adds new silicon issues 18 (Receive Filter) and 19 (SPI Interface) to all silicon revisions. Makes minor clarifying changes and typographic corrections to issues 2, 3, 4, 5, 7, 13 and 14. Revises issue 8 (PHY) to reflect that the current revision of the data sheet correctly describes the current silicon revision. Adds Ethernet Conformance Issues 1 (TP_IDL Pattern), 2 (Exiting Link Test Fail State) and 3 (Collision Handling) from previous revisions B1 and B4. Adds Data Sheet Clarification 1 (Receive Filters). This document replaces these errata documents: • DS80254, “ENC28J60 Revision B1 Silicon Errata” • DS80257, “ENC28J60 Revision B4 Silicon Errata” • DS80264, “ENC28J60 Revision B5 Silicon Errata” DS80349C-page 10  2010 Microchip Technology Inc. Note the following details of the code protection feature on Microchip devices: • Microchip products meet the specification contained in their particular Microchip Data Sheet. • Microchip believes that its family of products is one of the most secure families of its kind on the market today, when used in the intended manner and under normal conditions. • There are dishonest and possibly illegal methods used to breach the code protection feature. All of these methods, to our knowledge, require using the Microchip products in a manner outside the operating specifications contained in Microchip’s Data Sheets. Most likely, the person doing so is engaged in theft of intellectual property. • Microchip is willing to work with the customer who is concerned about the integrity of their code. • Neither Microchip nor any other semiconductor manufacturer can guarantee the security of their code. Code protection does not mean that we are guaranteeing the product as “unbreakable.” Code protection is constantly evolving. We at Microchip are committed to continuously improving the code protection features of our products. Attempts to break Microchip’s code protection feature may be a violation of the Digital Millennium Copyright Act. If such acts allow unauthorized access to your software or other copyrighted work, you may have a right to sue for relief under that Act. Information contained in this publication regarding device applications and the like is provided only for your convenience and may be superseded by updates. It is your responsibility to ensure that your application meets with your specifications. MICROCHIP MAKES NO REPRESENTATIONS OR WARRANTIES OF ANY KIND WHETHER EXPRESS OR IMPLIED, WRITTEN OR ORAL, STATUTORY OR OTHERWISE, RELATED TO THE INFORMATION, INCLUDING BUT NOT LIMITED TO ITS CONDITION, QUALITY, PERFORMANCE, MERCHANTABILITY OR FITNESS FOR PURPOSE. Microchip disclaims all liability arising from this information and its use. Use of Microchip devices in life support and/or safety applications is entirely at the buyer’s risk, and the buyer agrees to defend, indemnify and hold harmless Microchip from any and all damages, claims, suits, or expenses resulting from such use. No licenses are conveyed, implicitly or otherwise, under any Microchip intellectual property rights. Trademarks The Microchip name and logo, the Microchip logo, dsPIC, KEELOQ, KEELOQ logo, MPLAB, PIC, PICmicro, PICSTART, PIC32 logo, rfPIC and UNI/O are registered trademarks of Microchip Technology Incorporated in the U.S.A. and other countries. FilterLab, Hampshire, HI-TECH C, Linear Active Thermistor, MXDEV, MXLAB, SEEVAL and The Embedded Control Solutions Company are registered trademarks of Microchip Technology Incorporated in the U.S.A. Analog-for-the-Digital Age, Application Maestro, CodeGuard, dsPICDEM, dsPICDEM.net, dsPICworks, dsSPEAK, ECAN, ECONOMONITOR, FanSense, HI-TIDE, In-Circuit Serial Programming, ICSP, Mindi, MiWi, MPASM, MPLAB Certified logo, MPLIB, MPLINK, mTouch, Octopus, Omniscient Code Generation, PICC, PICC-18, PICDEM, PICDEM.net, PICkit, PICtail, REAL ICE, rfLAB, Select Mode, Total Endurance, TSHARC, UniWinDriver, WiperLock and ZENA are trademarks of Microchip Technology Incorporated in the U.S.A. and other countries. SQTP is a service mark of Microchip Technology Incorporated in the U.S.A. All other trademarks mentioned herein are property of their respective companies. © 2010, Microchip Technology Incorporated, Printed in the U.S.A., All Rights Reserved. Printed on recycled paper. ISBN: 978-1-60932-370-7 Microchip received ISO/TS-16949:2002 certification for its worldwide headquarters, design and wafer fabrication facilities in Chandler and Tempe, Arizona; Gresham, Oregon and design centers in California and India. The Company’s quality system processes and procedures are for its PIC® MCUs and dsPIC® DSCs, KEELOQ® code hopping devices, Serial EEPROMs, microperipherals, nonvolatile memory and analog products. In addition, Microchip’s quality system for the design and manufacture of development systems is ISO 9001:2000 certified.  2010 Microchip Technology Inc. DS80349C-page 11 WORLDWIDE SALES AND SERVICE AMERICAS ASIA/PACIFIC ASIA/PACIFIC EUROPE Corporate Office 2355 West Chandler Blvd. Chandler, AZ 85224-6199 Tel: 480-792-7200 Fax: 480-792-7277 Technical Support: http://support.microchip.com Web Address: www.microchip.com Asia Pacific Office Suites 3707-14, 37th Floor Tower 6, The Gateway Harbour City, Kowloon Hong Kong Tel: 852-2401-1200 Fax: 852-2401-3431 India - Bangalore Tel: 91-80-3090-4444 Fax: 91-80-3090-4123 India - New Delhi Tel: 91-11-4160-8631 Fax: 91-11-4160-8632 Austria - Wels Tel: 43-7242-2244-39 Fax: 43-7242-2244-393 Denmark - Copenhagen Tel: 45-4450-2828 Fax: 45-4485-2829 India - Pune Tel: 91-20-2566-1512 Fax: 91-20-2566-1513 France - Paris Tel: 33-1-69-53-63-20 Fax: 33-1-69-30-90-79 Japan - Yokohama Tel: 81-45-471- 6166 Fax: 81-45-471-6122 Germany - Munich Tel: 49-89-627-144-0 Fax: 49-89-627-144-44 Atlanta Duluth, GA Tel: 678-957-9614 Fax: 678-957-1455 Boston Westborough, MA Tel: 774-760-0087 Fax: 774-760-0088 Chicago Itasca, IL Tel: 630-285-0071 Fax: 630-285-0075 Cleveland Independence, OH Tel: 216-447-0464 Fax: 216-447-0643 Dallas Addison, TX Tel: 972-818-7423 Fax: 972-818-2924 Detroit Farmington Hills, MI Tel: 248-538-2250 Fax: 248-538-2260 Kokomo Kokomo, IN Tel: 765-864-8360 Fax: 765-864-8387 Los Angeles Mission Viejo, CA Tel: 949-462-9523 Fax: 949-462-9608 Santa Clara Santa Clara, CA Tel: 408-961-6444 Fax: 408-961-6445 Toronto Mississauga, Ontario, Canada Tel: 905-673-0699 Fax: 905-673-6509 Australia - Sydney Tel: 61-2-9868-6733 Fax: 61-2-9868-6755 China - Beijing Tel: 86-10-8528-2100 Fax: 86-10-8528-2104 China - Chengdu Tel: 86-28-8665-5511 Fax: 86-28-8665-7889 Korea - Daegu Tel: 82-53-744-4301 Fax: 82-53-744-4302 China - Chongqing Tel: 86-23-8980-9588 Fax: 86-23-8980-9500 Korea - Seoul Tel: 82-2-554-7200 Fax: 82-2-558-5932 or 82-2-558-5934 China - Hong Kong SAR Tel: 852-2401-1200 Fax: 852-2401-3431 Malaysia - Kuala Lumpur Tel: 60-3-6201-9857 Fax: 60-3-6201-9859 China - Nanjing Tel: 86-25-8473-2460 Fax: 86-25-8473-2470 Malaysia - Penang Tel: 60-4-227-8870 Fax: 60-4-227-4068 China - Qingdao Tel: 86-532-8502-7355 Fax: 86-532-8502-7205 Philippines - Manila Tel: 63-2-634-9065 Fax: 63-2-634-9069 China - Shanghai Tel: 86-21-5407-5533 Fax: 86-21-5407-5066 Singapore Tel: 65-6334-8870 Fax: 65-6334-8850 China - Shenyang Tel: 86-24-2334-2829 Fax: 86-24-2334-2393 Taiwan - Hsin Chu Tel: 886-3-6578-300 Fax: 886-3-6578-370 China - Shenzhen Tel: 86-755-8203-2660 Fax: 86-755-8203-1760 Taiwan - Kaohsiung Tel: 886-7-536-4818 Fax: 886-7-536-4803 China - Wuhan Tel: 86-27-5980-5300 Fax: 86-27-5980-5118 Taiwan - Taipei Tel: 886-2-2500-6610 Fax: 886-2-2508-0102 China - Xian Tel: 86-29-8833-7252 Fax: 86-29-8833-7256 Thailand - Bangkok Tel: 66-2-694-1351 Fax: 66-2-694-1350 Italy - Milan Tel: 39-0331-742611 Fax: 39-0331-466781 Netherlands - Drunen Tel: 31-416-690399 Fax: 31-416-690340 Spain - Madrid Tel: 34-91-708-08-90 Fax: 34-91-708-08-91 UK - Wokingham Tel: 44-118-921-5869 Fax: 44-118-921-5820 China - Xiamen Tel: 86-592-2388138 Fax: 86-592-2388130 China - Zhuhai Tel: 86-756-3210040 Fax: 86-756-3210049 01/05/10 DS80349C-page 12  2010 Microchip Technology Inc.
ENC28J60-H 价格&库存
很抱歉,暂时无法提供与“ENC28J60-H”相匹配的价格&库存,您可以联系我们找货
