395
395
    ADAFRUIT
395 数据手册
TXB0108 www.ti.com SCES643B – NOVEMBER 2006 – REVISED FEBRUARY 2010 8-BIT BIDIRECTIONAL VOLTAGE-LEVEL TRANSLATOR WITH AUTO-DIRECTION SENSING AND ±15-kV ESD PROTECTION Check for Samples: TXB0108 FEATURES 1 • 1 20 2 19 3 18 4 17 5 16 6 15 7 14 8 13 9 12 10 11 B1 B2 B3 B4 VCCB GND B5 B6 B7 B8 5 C B A TERMINAL ASSIGNMENTS (20-Ball GXY/ZXY Package) 1 2 3 4 5 D VCCB B2 B4 B6 B8 C B1 B3 B5 B7 GND B A1 A3 A5 A7 OE A VCCA A2 A4 A6 A8 RGY PACKAGE (TOP VIEW) A1 1 20 VCCA 2 19 A2 A3 A4 A5 3 18 4 17 5 16 6 15 A6 A7 7 14 8 13 9 12 10 11 A8 OE 4 D PW PACKAGE (TOP VIEW) DQS PACKAGE (TOP VIEW) A1 A2 A3 A4 VCCA OE A5 A6 A7 A8 3 B1 VCCB B2 B3 B4 B5 B6 B7 B8 GND VCCA A2 A3 A4 A5 A6 A7 A8 B1 • 2 1 20 4 19 VCCB 18 B2 17 B3 5 6 16 B4 15 B5 7 14 B6 13 B7 2 3 8 12 B8 9 10 11 GND • • • 1 A1 • GXY OR ZXY PACKAGE (BOTTOM VIEW) 1.2 V to 3.6 V on A Port and 1.65 to 5.5 V on B Port (VCCA ≤ VCCB) VCC Isolation Feature – If Either VCC Input Is at GND, All Outputs Are in the High-Impedance State OE Input Circuit Referenced to VCCA Low Power Consumption, 4-mA Max ICC Ioff Supports Partial-Power-Down Mode Operation Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II ESD Protection Exceeds JESD 22 – A Port – 2000-V Human-Body Model (A114-B) – 1000-V Charged-Device Model (C101) – B Port – ±15-kV Human-Body Model (A114-B) – 1000-V Charged-Device Model (C101) OE • 1 Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of the Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. Copyright © 2006–2010, Texas Instruments Incorporated TXB0108 SCES643B – NOVEMBER 2006 – REVISED FEBRUARY 2010 www.ti.com DESCRIPTION/ORDERING INFORMATION This 8-bit noninverting translator uses two separate configurable power-supply rails. The A port is designed to track VCCA. VCCA accepts any supply voltage from 1.2 V to 3.6 V. The B port is designed to track VCCB. VCCB accepts any supply voltage from 1.65 V to 5.5 V. This allows for universal low-voltage bidirectional translation between any of the 1.2-V, 1.5-V, 1.8-V, 2.5-V, 3.3-V, and 5-V voltage nodes. VCCA should not exceed VCCB. When the output-enable (OE) input is low, all outputs are placed in the high-impedance state. The TXB0101 is designed so that the OE input circuit is supplied by VCCA. This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down. To ensure the high-impedance state during power up or power down, OE should be tied to GND through a pulldown resistor; the minimum value of the resistor is determined by the current-sourcing capability of the driver. Table 1. ORDERING INFORMATION (1) PACKAGE (2) TA –40°C to 85°C (1) (2) ORDERABLE PART NUMBER TOP-SIDE MARKING QFN – RGY Reel of 1000 TXB0108RGYR YE08 SON – DQS Reel of 2000 TXB0108DQSR 5MR TSSOP – PW Reel of 2000 TXB0108PWR YE08 VFBGA – GXY Reel of 2500 TXB0108GXYR YE08 VFBGA – ZXY (Pb-free) Reel of 2500 TXB0108ZXYR YE08 For the most current package and ordering information, see the Package Option Addendum at the end of this document, or see the TI web site at www.ti.com. Package drawings, thermal data, and symbolization are available at www.ti.com/packaging. PIN DESCRIPTION NO. (DQS, PW, RGY) 2 NAME FUNCTION 1 A1 2 VCCA Input/output 1. Referenced to VCCA. 3 A2 Input/output 2. Referenced to VCCA. 4 A3 Input/output 3. Referenced to VCCA. 5 A4 Input/output 4. Referenced to VCCA. 6 A5 Input/output 5. Referenced to VCCA. 7 A6 Input/output 6. Referenced to VCCA. 8 A7 Input/output 7. Referenced to VCCA. 9 A8 Input/output 8. Referenced to VCCA. 10 OE Output enable. Pull OE low to place all outputs in 3-state mode. Referenced to VCCA. 11 GND 12 B8 Input/output 8. Referenced to VCCB. 13 B7 Input/output 7. Referenced to VCCB. 14 B6 Input/output 6. Referenced to VCCB. 15 B5 Input/output 5. Referenced to VCCB. 16 B4 Input/output 4. Referenced to VCCB. 17 B3 Input/output 3. Referenced to VCCB. 18 B2 Input/output 2. Referenced to VCCB. 19 VCCB 20 B1 A-port supply voltage. 1.1 V ≤ VCCA ≤ 3.6 V, VCCA ≤ VCCB. Ground B-port supply voltage. 1.65 V ≤ VCCB ≤ 5.5 V. Input/output 1. Referenced to VCCB. Submit Documentation Feedback Copyright © 2006–2010, Texas Instruments Incorporated Product Folder Link(s): TXB0108 TXB0108 www.ti.com SCES643B – NOVEMBER 2006 – REVISED FEBRUARY 2010 TYPICAL OPERATING CIRCUIT 1.8 V 3.3 V VCCA VCCB OE TXB0108 1.8 -V System Controller Data A1 A2 B1 B2 A3 A4 A5 A6 A7 A8 B3 B4 B5 B6 B7 B8 3.3-V System Data Absolute Maximum Ratings (1) over operating free-air temperature range (unless otherwise noted) MIN MAX UNIT VCCA Supply voltage range –0.5 4.6 V VCCB Supply voltage range –0.5 6.5 V VI Input voltage range (2) –0.5 6.5 V –0.5 6.5 V VO Voltage range applied to any output in the high-impedance or power-off state (3) (2) A inputs –0.5 VCCA + 0.5 B inputs –0.5 VCCB + 0.5 VO Voltage range applied to any output in the high or low state (2) IIK Input clamp current VI < 0 –50 mA IOK Output clamp current VO < 0 –50 mA IO Continuous output current ±50 mA ±100 mA Continuous current through VCCA, VCCB, or GND DQS package qJA Package thermal impedance TBD GXY/ZXY package (4) 78 PW package (4) 83 RGY package (5) Tstg (1) (2) (3) (4) (5) Storage temperature range V °C/W 37 –65 150 °C Stresses beyond those listed under "absolute maximum ratings" may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under "recommended operating conditions" is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. The input and output negative-voltage ratings may be exceeded if the input and output current ratings are observed. The value of VCCA and VCCB are provided in the recommended operating conditions table. The package thermal impedance is calculated in accordance with JESD 51-7. The package thermal impedance is calculated in accordance with JESD 51-5. Submit Documentation Feedback Copyright © 2006–2010, Texas Instruments Incorporated Product Folder Link(s): TXB0108 3 TXB0108 SCES643B – NOVEMBER 2006 – REVISED FEBRUARY 2010 Recommended Operating Conditions (1) www.ti.com (2) VCCA VCCA VCCB Supply voltage VIH High-level input voltage VIL Low-level input voltage Δt/Δv Input transition rise or fall rate TA Operating free-air temperature (1) (2) (3) 4 VCCB Data inputs OE 1.2 V to 3.6 V Data inputs 1.2 V to 5.5 V OE 1.2 V to 3.6 V A-port inputs 1.2 V to 3.6 V B-port inputs 1.2 V to 3.6 V 1.65 V to 5.5 V 1.65 V to 5.5 V MIN MAX 1.2 3.6 1.65 5.5 VCCI x 0.65 (3) VCCI VCCA x 0.65 5.5 0 VCCI x 0.35 (3) 0 VCCA x 0.35 1.65 V to 5.5 V 40 1.65 V to 3.6 V 40 4.5 V to 5.5 V UNIT V V V ns/V 30 –40 85 °C The A and B sides of an unused data I/O pair must be held in the same state, i.e., both at VCCI or both at GND. VCCA must be less than or equal to VCCB and must not exceed 3.6 V. VCCI is the supply voltage associated with the input port. Submit Documentation Feedback Copyright © 2006–2010, Texas Instruments Incorporated Product Folder Link(s): TXB0108 TXB0108 www.ti.com SCES643B – NOVEMBER 2006 – REVISED FEBRUARY 2010 Electrical Characteristics (1) (2) over recommended operating free-air temperature range (unless otherwise noted) PARAMETER TEST CONDITIONS VOHA IOH = –20 mA VOLA IOL = 20 mA VOHB IOH = –20 mA VOLB II IOZ –40°C to 85°C MAX MIN MAX 1.1 0.9 0.4 1.65 V to 5.5 V VCCB – 0.4 1.65 V to 5.5 V UNIT V VCCA – 0.4 1.2 V V V 0.4 V 1.2 V to 3.6 V 1.65 V to 5.5 V ±1 ±2 mA A port 0V 0 V to 5.5 V ±1 ±2 B port 0 V to 3.6 V 0V ±1 ±2 1.2 V to 3.6 V 1.65 V to 5.5 V ±1 ±2 A or B port OE = GND VI = VCCI or GND, IO = 0 1.4 V to 3.6 V 0V 0V 5.5 V VI = VCCI or GND, IO = 0 ICCB ICCA + ICCB VI = VCCI or GND, IO = 0 ICCZA VI = VCCI or GND, IO = 0, OE = GND ICCZB VI = VCCI or GND, IO = 0, OE = GND OE 1.4 V to 3.6 V 1.65 V to 5.5 V 5 5.5 V 2 3.5 1.65 V to 5.5 V 10 1.2 V 1.4 V to 3.6 V mA mA 0.05 1.65 V to 5.5 V 5 1.2 V 1.4 V to 3.6 V mA –2 0V 1.2 V mA 3.4 –2 1.2 V to 3.6 V B port 2 0V 1.2 V to 3.6 V A port 5 3.6 V 1.4 V to 3.6 V mA 0.06 1.65 V to 5.5 V 3.6 V 1.2 V (1) (2) TYP 1.2 V IOL = 20 mA ICCA Cio MIN 1.4 V to 3.6 V 1.2 V CI TA = 25°C VCCB 1.4 V to 3.6 V OE Ioff VCCA mA 3.3 1.65 V to 5.5 V 5 1.65 V to 5.5 V 1.65 V to 5.5 V 5 5.5 5 6.5 8 10 mA pF pF VCCI is the supply voltage associated with the input port. VCCO is the supply voltage associated with the output port. Timing Requirements TA = 25°C, VCCA = 1.2 V Data rate tw Pulse duration Data inputs VCCB = 1.8 V VCCB = 2.5 V VCCB = 3.3 V VCCB = 5 V TYP TYP TYP TYP 20 20 20 20 Mbps 50 50 50 50 ns UNIT Timing Requirements over recommended operating free-air temperature range, VCCA = 1.5 V ± 0.1 V (unless otherwise noted) VCCB = 1.8 V ± 0.15 V MIN Data rate tw Pulse duration MAX VCCB = 2.5 V ± 0.2 V MIN 50 Data inputs 20 MAX VCCB = 3.3 V ± 0.3 V MIN 50 20 MAX VCCB = 5 V ± 0.5 V MIN 50 20 50 20 Submit Documentation Feedback Copyright © 2006–2010, Texas Instruments Incorporated Product Folder Link(s): TXB0108 UNIT MAX Mbps ns 5 TXB0108 SCES643B – NOVEMBER 2006 – REVISED FEBRUARY 2010 www.ti.com Timing Requirements over recommended operating free-air temperature range, VCCA = 1.8 V ± 0.15 V (unless otherwise noted) VCCB = 1.8 V ± 0.15 V MIN MAX Data rate tw VCCB = 2.5 V ± 0.2 V MIN MAX 52 Pulse duration Data inputs VCCB = 3.3 V ± 0.3 V MIN MAX 60 19 VCCB = 5 V ± 0.5 V MIN 60 17 60 17 UNIT MAX 17 Mbps ns Timing Requirements over recommended operating free-air temperature range, VCCA = 2.5 V ± 0.2 V (unless otherwise noted) VCCB = 2.5 V ± 0.2 V MIN MAX Data rate tw VCCB = 3.3 V ± 0.3 V MIN MAX 70 Pulse duration Data inputs VCCB = 5 V ± 0.5 V MIN 100 14 100 10 UNIT MAX 10 Mbps ns Timing Requirements over recommended operating free-air temperature range, VCCA = 3.3 V ± 0.3 V (unless otherwise noted) VCCB = 3.3 V ± 0.3 V MIN Data rate tw VCCB = 5 V ± 0.5 V MAX MIN 100 Pulse duration Data inputs 10 UNIT MAX 100 10 Mbps ns Switching Characteristics TA = 25°C, VCCA = 1.2 V FROM (INPUT) TO (OUTPUT) VCCB = 1.8 V VCCB = 2.5 V VCCB = 3.3 V VCCB = 5 V TYP TYP TYP TYP A B 9.5 7.9 7.6 8.5 B A 9.2 8.8 8.4 8 A 1 1 1 1 B 1 1 1 1 A 20 17 17 18 B 20 16 15 15 trA, tfA A-port rise and fall times 4.1 4.4 4.1 3.9 ns trB, tfB B-port rise and fall times 5 5 5.1 5.1 ns tSK(O) Channel-to-channel skew 2.4 1.7 1.9 7 ns 20 20 20 20 Mbps PARAMETER tpd ten OE tdis OE Max data rate 6 Submit Documentation Feedback UNIT ns ms ns Copyright © 2006–2010, Texas Instruments Incorporated Product Folder Link(s): TXB0108 TXB0108 www.ti.com SCES643B – NOVEMBER 2006 – REVISED FEBRUARY 2010 Switching Characteristics over recommended operating free-air temperature range, VCCA = 1.5 V ± 0.1 V (unless otherwise noted) PARAMETER tpd FROM (INPUT) TO (OUTPUT) A B ten OE tdis OE VCCB = 1.8 V ± 0.15 V VCCB = 2.5 V ± 0.2 V VCCB = 3.3 V ± 0.3 V VCCB = 5 V ± 0.5 V UNIT MIN MAX MIN MAX MIN MAX MIN MAX B 1.4 12.9 1.2 10.1 1.1 10 0.8 9.9 A 0.9 14.2 0.7 12 0.4 11.7 0.3 13.7 A 1 1 1 1 B 1 1 1 1 ns ms A 6.6 33 6.4 25.3 6.1 23.1 5.9 24.6 B 6.6 35.6 5.8 25.6 5.5 22.1 5.6 20.6 trA, tfA A-port rise and fall times 0.8 6.5 0.8 6.3 0.8 6.3 0.8 6.3 ns trB, tfB B-port rise and fall times 1 7.3 0.7 4.9 0.7 4.6 0.6 4.6 ns tSK(O) Channel-to-channel skew Max data rate 2.6 1.9 50 50 1.6 50 1.3 50 ns ns Mbps Switching Characteristics over recommended operating free-air temperature range, VCCA = 1.8 V ± 0.15 V (unless otherwise noted) PARAMETER tpd FROM (INPUT) TO (OUTPUT) A B ten OE tdis OE VCCB = 1.8 V ± 0.15 V VCCB = 2.5 V ± 0.2 V VCCB = 3.3 V ± 0.3 V VCCB = 5 V ± 0.5 V UNIT MIN MAX MIN MAX MIN MAX MIN MAX B 1.6 11 1.4 7.7 1.3 6.8 1.2 6.5 A 1.5 12 1.2 8.4 0.8 7.6 0.5 7.1 A 1 1 1 1 B 1 1 1 1 ns ms A 5.9 26.7 5.6 21.6 5.4 18.9 4.8 18.7 B 6.1 33.9 5.2 23.7 5 19.9 5 17.6 trA, tfA A-port rise and fall times 0.7 5.1 0.7 5 1 5 0.7 5 ns trB, tfB B-port rise and fall times 1 7.3 0.7 5 0.7 3.9 0.6 3.8 ns tSK(O) Channel-to-channel skew 0.6 ns Max data rate 0.8 52 0.7 60 0.6 60 60 Submit Documentation Feedback Copyright © 2006–2010, Texas Instruments Incorporated Product Folder Link(s): TXB0108 ns Mbps 7 TXB0108 SCES643B – NOVEMBER 2006 – REVISED FEBRUARY 2010 www.ti.com Switching Characteristics over recommended operating free-air temperature range, VCCA = 2.5 V ± 0.2 V (unless otherwise noted) PARAMETER tpd FROM (INPUT) TO (OUTPUT) A B ten OE tdis OE VCCB = 2.5 V ± 0.2 V VCCB = 3.3 V ± 0.3 V VCCB = 5 V ± 0.5 V UNIT MIN MAX MIN MAX MIN MAX B 1.1 6.4 1 5.3 0.9 4.7 A 1 7 0.6 5.6 0.3 4.4 A 1 1 1 B 1 1 1 A 5 16.9 4.9 15 4.5 13.8 B 4.8 21.8 4.5 17.9 4.4 15.2 ns ms ns trA, tfA A-port rise and fall times 0.8 3.6 0.6 3.6 0.5 3.5 ns trB, tfB B-port rise and fall times 0.6 4.9 0.7 3.9 0.6 3.2 ns tSK(O) Channel-to-channel skew 0.4 Max data rate 0.3 70 0.3 100 100 ns Mbps Switching Characteristics over recommended operating free-air temperature range, VCCA = 3.3 V ± 0.3 V (unless otherwise noted) PARAMETER tpd FROM (INPUT) TO (OUTPUT) A B ten OE tdis OE VCCB = 5 V ± 0.5 V UNIT MIN MAX MIN MAX B 0.9 4.9 0.8 4 A 0.5 5.4 0.2 4 A 1 1 B 1 1 A 4.5 13.9 4.1 12.4 B 4.1 17.3 4 14.4 ns ms ns trA, tfA A-port rise and fall times 0.5 3 0.5 3 ns trB, tfB B-port rise and fall times 0.7 3.9 0.6 3.2 ns tSK(O) Channel-to-channel skew 0.3 ns Max data rate 8 VCCB = 3.3 V ± 0.3 V 0.4 100 Submit Documentation Feedback 100 Mbps Copyright © 2006–2010, Texas Instruments Incorporated Product Folder Link(s): TXB0108 TXB0108 www.ti.com SCES643B – NOVEMBER 2006 – REVISED FEBRUARY 2010 Operating Characteristics TA = 25°C VCCA 1.2 V 1.2 V 1.5 V 1.8 V 2.5 V 2.5 V 3.3 V 5V 3.3 V to 5V VCCB PARAMETER TEST CONDITIONS 5V 1.8 V TYP CpdA CpdB CpdA CpdB A-port input, B-port output B-port input, A-port output A-port input, B-port output B-port input, A-port output A-port input, B-port output B-port input, A-port output A-port input, B-port output B-port input, A-port output CL = 0, f = 10 MHz, tr = tf = 1 ns, OE = VCCA (outputs enabled) CL = 0, f = 10 MHz, tr = tf = 1 ns, OE = GND (outputs disabled) 1.8 V TYP 1.8 V TYP 2.5 V TYP TYP TYP UNIT TYP 9 8 7 7 7 7 8 12 11 11 11 11 11 11 35 26 27 27 27 27 28 26 19 18 18 18 20 21 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.01 0.03 0.01 0.01 0.01 0.01 0.01 0.01 0.03 Submit Documentation Feedback Copyright © 2006–2010, Texas Instruments Incorporated Product Folder Link(s): TXB0108 pF pF 9 TXB0108 SCES643B – NOVEMBER 2006 – REVISED FEBRUARY 2010 www.ti.com PRINCIPLES OF OPERATION Applications The TXB0108 can be used in level-translation applications for interfacing devices or systems operating at different interface voltages with one another. Architecture The TXB0108 architecture (see Figure 1) does not require a direction-control signal to control the direction of data flow from A to B or from B to A. In a dc state, the output drivers of the TXB0108 can maintain a high or low, but are designed to be weak, so that they can be overdriven by an external driver when data on the bus starts flowing the opposite direction. The output one shots detect rising or falling edges on the A or B ports. During a rising edge, the one shot turns on the PMOS transistors (T1, T3) for a short duration, which speeds up the low-to-high transition. Similarly, during a falling edge, the one shot turns on the NMOS transistors (T2, T4) for a short duration, which speeds up the high-to-low transition. The typical output impedance during output transition is 70Ω at VCCO = 1.2 V to 1.8 V, 50Ω at VCCO = 1.8 V to 3.3 V and 40Ω at VCCO = 3.3 V to 5 V. VCCA VCCB One Shot T1 4k One Shot T2 A B One Shot T3 4k T4 One Shot Figure 1. Architecture of TXB0108 I/O Cell Input Driver Requirements Typical IIN vs VIN characteristics of the TXB0108 are shown in Figure 2. For proper operation, the device driving the data I/Os of the TXB0108 must have drive strength of at least ±2 mA. 10 Submit Documentation Feedback Copyright © 2006–2010, Texas Instruments Incorporated Product Folder Link(s): TXB0108 TXB0108 www.ti.com SCES643B – NOVEMBER 2006 – REVISED FEBRUARY 2010 IIN VT/4 kW VIN –(VD – VT)/4 kW A. VT is the input threshold voltage of the TXB0108 (typically VCCI/2). B. VD is the supply voltage of the external driver. Figure 2. Typical IIN vs VIN Curve Power Up During operation, ensure that VCCA ≤ VCCB at all times. During power-up sequencing, VCCA ≥ VCCB does not damage the device, so any power supply can be ramped up first. The TXB0108 has circuitry that disables all output ports when either VCC is switched off (VCCA/B = 0 V). Enable and Disable The TXB0108 has an OE input that is used to disable the device by setting OE = low, which places all I/Os in the high-impedance (Hi-Z) state. The disable time (tdis) indicates the delay between when OE goes low and when the outputs actually get disabled (Hi-Z). The enable time (ten) indicates the amount of time the user must allow for the one-shot circuitry to become operational after OE is taken high. Pullup or Pulldown Resistors on I/O Lines The TXB0108 is designed to drive capacitive loads of up to 70 pF. The output drivers of the TXB0108 have low dc drive strength. If pullup or pulldown resistors are connected externally to the data I/Os, their values must be kept higher than 50 kΩ to ensure that they do not contend with the output drivers of the TXB0108. For the same reason, the TXB0108 should not be used in applications such as I2C or 1-Wire where an open-drain driver is connected on the bidirectional data I/O. For these applications, use a device from the TI TXS01xx series of level translators. Submit Documentation Feedback Copyright © 2006–2010, Texas Instruments Incorporated Product Folder Link(s): TXB0108 11 TXB0108 SCES643B – NOVEMBER 2006 – REVISED FEBRUARY 2010 www.ti.com PARAMETER MEASUREMENT INFORMATION 2 × VCCO From Output Under Test 15 pF 15 pF 1 MW Open 50 kW TEST tPZL/tPLZ tPHZ/tPZH LOAD CIRCUIT FOR ENABLE/DISABLE TIME MEASUREMENT LOAD CIRCUIT FOR MAX DATA RATE, PULSE DURATION PROPAGATION DELAY OUTPUT RISE AND FALL TIME MEASUREMENT S1 50 kW From Output Under Test S1 2 × VCCO Open VCCI Input VCCI/2 VCCI/2 0V tPLH tPHL tw Output VCCO/2 0.9 y VCCO 0.1 y VCCO VOH tf tr VCCI VCCO/2 VOL Input VCCI/2 0V VOLTAGE WAVEFORMS PULSE DURATION VOLTAGE WAVEFORMS PROPAGATION DELAY TIMES A. B. C. D. E. F. G. VCCI/2 CL includes probe and jig capacitance. All input pulses are supplied by generators having the following characteristics: PRRv10 MHz, ZO = 50 Ω, dv/dt ≥ 1 V/ns. The outputs are measured one at a time, with one transition per measurement. tPLH and tPHL are the same as tpd. VCCI is the VCC associated with the input port. VCCO is the VCC associated with the output port. All parameters and waveforms are not applicable to all devices. Figure 3. Load Circuits and Voltage Waveforms 12 Submit Documentation Feedback Copyright © 2006–2010, Texas Instruments Incorporated Product Folder Link(s): TXB0108 PACKAGE OPTION ADDENDUM www.ti.com 14-Oct-2010 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Drawing Pins Package Qty Eco Plan (2) TXB0108DQSR ACTIVE USON DQS 20 3000 Green (RoHS & no Sb/Br) TXB0108PWR ACTIVE TSSOP PW 20 2000 TXB0108PWRG4 ACTIVE TSSOP PW 20 TXB0108RGYR ACTIVE VQFN RGY TXB0108RGYRG4 ACTIVE VQFN TXB0108ZXYR ACTIVE BGA MICROSTAR JUNIOR Lead/ Ball Finish Call TI MSL Peak Temp (3) Samples (Requires Login) Level-1-260C-UNLIM Request Free Samples Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM Request Free Samples 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM Request Free Samples 20 3000 Green (RoHS & no Sb/Br) Call TI Level-2-260C-1 YEAR Request Free Samples RGY 20 3000 Green (RoHS & no Sb/Br) Call TI Level-2-260C-1 YEAR Request Free Samples ZXY 20 2500 Green (RoHS & no Sb/Br) SNAGCU Level-1-260C-UNLIM Request Free Samples (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability information and additional product content details. TBD: The Pb-Free/Green conversion plan has not been defined. Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes. Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above. Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) (3) MSL, Peak Temp. -- The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature. Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Addendum-Page 1 PACKAGE OPTION ADDENDUM www.ti.com 14-Oct-2010 In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis. Addendum-Page 2 PACKAGE MATERIALS INFORMATION www.ti.com 30-May-2011 TAPE AND REEL INFORMATION *All dimensions are nominal Device Package Package Pins Type Drawing TXB0108DQSR USON TXB0108PWR TXB0108RGYR TXB0108ZXYR SPQ Reel Reel A0 Diameter Width (mm) (mm) W1 (mm) B0 (mm) K0 (mm) P1 (mm) W Pin1 (mm) Quadrant DQS 20 3000 177.8 12.4 2.21 4.22 0.81 4.0 12.0 Q1 TSSOP PW 20 2000 330.0 16.4 6.95 7.1 1.6 8.0 16.0 Q1 VQFN RGY 20 3000 330.0 12.4 3.8 4.8 1.6 8.0 12.0 Q1 ZXY 20 2500 330.0 12.4 2.8 3.3 1.0 4.0 12.0 Q2 BGA MI CROSTA R JUNI OR Pack Materials-Page 1 PACKAGE MATERIALS INFORMATION www.ti.com 30-May-2011 *All dimensions are nominal Device Package Type Package Drawing Pins SPQ Length (mm) Width (mm) Height (mm) TXB0108DQSR USON DQS 20 3000 202.0 201.0 28.0 TXB0108PWR TSSOP PW 20 2000 346.0 346.0 33.0 TXB0108RGYR VQFN RGY 20 3000 355.0 350.0 50.0 TXB0108ZXYR BGA MICROSTAR JUNIOR ZXY 20 2500 340.5 338.1 20.6 Pack Materials-Page 2 IMPORTANT NOTICE Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, modifications, enhancements, improvements, and other changes to its products and services at any time and to discontinue any product or service without notice. Customers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All products are sold subject to TI’s terms and conditions of sale supplied at the time of order acknowledgment. TI warrants performance of its hardware products to the specifications applicable at the time of sale in accordance with TI’s standard warranty. Testing and other quality control techniques are used to the extent TI deems necessary to support this warranty. Except where mandated by government requirements, testing of all parameters of each product is not necessarily performed. TI assumes no liability for applications assistance or customer product design. Customers are responsible for their products and applications using TI components. To minimize the risks associated with customer products and applications, customers should provide adequate design and operating safeguards. TI does not warrant or represent that any license, either express or implied, is granted under any TI patent right, copyright, mask work right, or other TI intellectual property right relating to any combination, machine, or process in which TI products or services are used. Information published by TI regarding third-party products or services does not constitute a license from TI to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from TI under the patents or other intellectual property of TI. Reproduction of TI information in TI data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. Reproduction of this information with alteration is an unfair and deceptive business practice. TI is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of TI products or services with statements different from or beyond the parameters stated by TI for that product or service voids all express and any implied warranties for the associated TI product or service and is an unfair and deceptive business practice. TI is not responsible or liable for any such statements. TI products are not authorized for use in safety-critical applications (such as life support) where a failure of the TI product would reasonably be expected to cause severe personal injury or death, unless officers of the parties have executed an agreement specifically governing such use. Buyers represent that they have all necessary expertise in the safety and regulatory ramifications of their applications, and acknowledge and agree that they are solely responsible for all legal, regulatory and safety-related requirements concerning their products and any use of TI products in such safety-critical applications, notwithstanding any applications-related information or support that may be provided by TI. Further, Buyers must fully indemnify TI and its representatives against any damages arising out of the use of TI products in such safety-critical applications. TI products are neither designed nor intended for use in military/aerospace applications or environments unless the TI products are specifically designated by TI as military-grade or "enhanced plastic." Only products designated by TI as military-grade meet military specifications. Buyers acknowledge and agree that any such use of TI products which TI has not designated as military-grade is solely at the Buyer's risk, and that they are solely responsible for compliance with all legal and regulatory requirements in connection with such use. TI products are neither designed nor intended for use in automotive applications or environments unless the specific TI products are designated by TI as compliant with ISO/TS 16949 requirements. Buyers acknowledge and agree that, if they use any non-designated products in automotive applications, TI will not be responsible for any failure to meet such requirements. Following are URLs where you can obtain information on other Texas Instruments products and application solutions: Products Applications Audio www.ti.com/audio Communications and Telecom www.ti.com/communications Amplifiers amplifier.ti.com Computers and Peripherals www.ti.com/computers Data Converters dataconverter.ti.com Consumer Electronics www.ti.com/consumer-apps DLP® Products www.dlp.com Energy and Lighting www.ti.com/energy DSP dsp.ti.com Industrial www.ti.com/industrial Clocks and Timers www.ti.com/clocks Medical www.ti.com/medical Interface interface.ti.com Security www.ti.com/security Logic logic.ti.com Space, Avionics and Defense www.ti.com/space-avionics-defense Power Mgmt power.ti.com Transportation and Automotive www.ti.com/automotive Microcontrollers microcontroller.ti.com Video and Imaging www.ti.com/video RFID www.ti-rfid.com Wireless www.ti.com/wireless-apps RF/IF and ZigBee® Solutions www.ti.com/lprf TI E2E Community Home Page e2e.ti.com Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265 Copyright © 2011, Texas Instruments Incorporated
395
物料型号: TXB0108
器件简介: - TXB0108是一个8位非反相转换器,使用两个独立的可配置电源轨。 - A端口设计为跟踪VCCA,接受1.2V至3.6V的任何电源电压。 - B端口设计为跟踪VCCB,接受1.65V至5.5V的任何电源电压。 - 支持在1.2V、1.5V、1.8V、2.5V、3.3V和5V电压节点之间的通用低压双向转换。 - VCCA不应超过VCCB。
引脚分配: - GXY/ZXY封装(底部视图): - VcCB: B端口电源电压 - B2, B4, B6, B8: B端口输入/输出 - B1, B3, B5, B7: B端口输入/输出 - A1, A3, A5, A7: A端口输入/输出 - OE: 输出使能 - VCCA: A端口电源电压 - A2, A4, A6, A8: A端口输入/输出
参数特性: - VCC隔离特性:如果任一VCC输入在GND,所有输出都处于高阻态。 - OE输入电路参考VCCA。 - 低功耗,最大ICC为4mA。 - 支持部分断电模式操作。 - 抗锁定性能超过JESD 78,II类,每JESD 78为100mA。
功能详解: - TXB0108不需要方向控制信号来控制数据流的方向。 - 输出驱动器在直流状态下可以维持高或低电平,但设计为弱驱动,以便在总线上的数据开始反向流动时被外部驱动器覆盖。 - 输出单拍检测A或B端口上的上升或下降沿,以加速输出转换。
应用信息: - TXB0108可用于电平转换应用,用于接口设备或系统在不同接口电压下相互操作。
封装信息: - 提供多种封装选项,如USON、TSSOP、VQFN和BGA MICROSTAR JUNIOR。 - 封装类型包括RGY、PW、DQS和ZXY。 - 封装数量从2000到3000不等。 - 所有封装均符合RoHS标准,部分封装为无铅。
很抱歉,暂时无法提供与“395”相匹配的价格&库存,您可以联系我们找货
  • 1+75.908211+9.82076
库存:77
