DK-RV-1.8-33
DK-RV-1.8-33
    AMSOSRAM(艾迈斯半导体)
    SQL-RV-1.8-6-12, MC-3300-RV, NSD-2101 SQUIGGLE® Series Power Management, Motor Control Evaluation Bo...
DK-RV-1.8-33 数据手册
Developer’s Kits for SQUIGGLE® RV Micro Motor, NSD-2101 Driver and NSE-5310 Position Sensor FEATURES    Easy push-button operation demonstrates forward and reverse motion Intuitive PC software facilitates detailed evaluation and system requirements definition Powered by two 3 V batteries SYSTEM COMPONENTS      SQL-RV-1.8-6-12 SQUIGGLE RV motor NSD-2101 motor drive IC NSE-5310 position sensor (closed loop kits only) New Scale Pathway™ Software USB connector cable and user guides Evaluate the world’s smallest linear motor in an integrated motion system This New Scale developer’s kit allows engineers to evaluate a tiny, closed loop motion system reference design with integrated SQUIGGLE RV (reduced voltage) micro motor, NSD-2101 piezo motor driver and NSE-5310 position sensor. The kits demonstrate the performance of these tiny components – the smallest of their kind – in an integrated motion system. Define system specifications for custom development This developer’s kit is designed to help engineers define system specifications for subsequent development of custom micro motion modules with New Scale Technologies. Developer’s kits demonstrate system performance of an integrated SQUIGGLE motor, NSD-2101 driver and NSE-5310 position sensor. Integrated components  SQL-RV-1.8-6-12 SQUIGGLE® RV micro motor. The world’s smallest linear motor at 2.8 x 2.8 x 6 mm features 6 mm travel, 30 gram force stall force and 0.5 µm resolution.  NSD-2101 motor driver. The drive IC generates ultrasonic signals to drive the SQUIGGLE motor and accepts feedback from the position sensor. It is integrated into the MC-3300-RV motor controller, which provides the USB interface to a PC.  NSD-5310 position sensor (closed-loop kits only). Magnetic sensor array with on-chip digital encoding has 0.5 µm resolution with a size as small as 3.9 x 2.5 mm. The kit includes an 11mm magnet.  Mechanical reference design. The SQUIGGLE RV motor (and NSE5310 sensor in closed-loop kits) is integrated into a slide assembly SQUIGGLE RV motor and driver – all kits integrate an SQL-RV-1.8 SQUIGGLE RV motor and NSD-2101 drive ASIC into a mechanical and electrical reference design. demonstrating proper mounting, loading and alignment. Also included is New Scale Pathway™ Software for Windows with USB connector, intuitive user interface and ActiveX command library that enable easy evaluation of the motor and position sensor. You can build custom programs using the intuitive scripting interface, and port the scripts and ActiveX commands to your embedded hardware. www.ams.com NSE-5310 position sensor – closed-loop kits include an NSE-5310 sensor. Evaluate the sensor and/or the performance of a closed-loop SQUIGGLE motor system. Developer’s Kits for SQUIGGLE® RV Reduced Voltage Micro Motor, NSD-2101 and NSE-5310 position sensor Developer’s kit system components SQL-RV-1.8-6 SQUIGGLE RV micro motor Battery compartment (for two AA batteries) USB Interface Forward/Reverse Push Buttons NSD-2101 drive IC MC-3300-RV controller reference design (drives 1 or 2 motors) Slide assembly mechanical reference design Not shown:  New Scale Pathway Software USB  USB connector cable  User guides NSE-5310 position sensor (closed-loop kits only) Ordering information Developer’s kits are available from distributors. Next Step: Custom product development New Scale integrates its motors, drivers, position sensors and micro mechanical assemblies into small, precise and smart motion systems that are tailored to your unique requirements and easily integrated into your next-generation instruments. Use the developer’s kit to get a sense for what we can do with these components and our expertise in micro-mechatronic system design. Then contact New Scale to discuss your motion system needs. New Scale Part Number Description DK-RV-1.8-33 SQUIGGLE RV motor open-loop developer’s kit: New Scale Pathway™ Software is a flexible, sophisticated development tool with easy-to-use graphical user interface and intuitive scripting environment.  one SQL-RV-1.8-6-12 SQUIGGLE RV motor mounted in a reference integration slide assembly  one battery-operated MC-3300-RV motor controller (incorporates the NSD-2101 driver)  USB connector cable  New Scale Pathway™ Software for Windows DK-RV-1.8-TRK-33 SQUIGGLE RV motor closed-loop / NSE-5310 position sensor developer’s kit:  one SQL-RV-1.8-6-12 SQUIGGLE RV motor mounted in reference integration slide assembly  one NSE-5310 position sensor and 11mm magnet  one battery-operated MC-3300-RV motor controller (incorporates the NSD-2101 driver)  USB connector cable  New Scale Pathway™ Software for Windows www.ams.com 12-17-2018
DK-RV-1.8-33 价格&库存
很抱歉,暂时无法提供与“DK-RV-1.8-33”相匹配的价格&库存,您可以联系我们找货
