DK-M3-LS-1.8-6
DK-M3-LS-1.8-6
    AMSOSRAM(艾迈斯半导体)
    M3-LS - Power Management, Motor Control Evaluation Board
DK-M3-LS-1.8-6 数据手册
SMALL, PRECISE, SMART … IN MOTION M3-LS Linear Smart Stage All-in-one USB micro stage  All-in-one smart module: no separate electronics - Runs directly from USB adapter - USB, I2C or SPI interface  Small size: less than 29 x 20 x 10 mm  High resolution: 0.5 m  Absolute encoding: no homing  Long stroke: 6 mm  Low power use: 3.3 V DC input, < 0.75 W when moving  High repeatability and low runout Unmatched precision, stability and ease of use The M3-LS Linear Smart Stage is a direct-drive, high-precision micro stage built for fast, simple integration into miniature OEM systems. All drive electronics are integrated right into the compact stage housing – no external board needed! The piezo-driven stage has 0.5 m resolution for precise, repeatable positioning of optics, probes, sensors and more. Absolute encoding removes the need to home the stage on power-up, eliminating errors and disruptions in processes and experiments. The unique linear slide has uniform and very low friction, even under high direct loads and side loads. Six ball bearings in a kinematic “v” guide-way eliminate cage creep and friction spike problems common in other micro stages. The M3-LS has high stiffness and lateral stability, no backlash, and less than10 m runout over its full travel range. The M3-LS Linear Smart Stage is an ultra-compact positioning stage with high resolution, low power use and absolute encoding. All electronics are built into the stage for simple system integration. Control the stage using high-level motion commands via USB, I2C or SPI interface. APPLICATIONS  Hand-held and mobile instruments  Battery-powered instruments  Portable medical devices  Miniature microscopes   Spectroscopy Micro assembly  Biomedical probing & sampling  High-resolution tuning systems  Targeting systems  UAV/UGV controls and optics  Miniature camera systems Direct input via USB, I2C or SPI The stage accepts simple high-level motion commands via standard serial interface. Use the USB adapter to power and control multiple stages from a single New Scale Pathway™ software screen. Use the intuitive script generator to easily create command sequences for automated operations. The M3-LS stage can also be driven directly from your system processor via standard I2C or SPI interface. Low power for hand-held systems The M3-LS Linear Smart Stage needs only 3.3 V DC and uses less than 0.75 W typical when moving. It can be powered by USB or standard batteries. The integrated piezo motor holds position without using power. The internal electronics can be switched to sleep mode for extreme low-power applications. New Scale Technologies, Inc. ~ w w w . n e w s c a l e t e c h . c o m ~ Phone (585) 924-4450 New Scale Pathway™ software with easy-to-use graphical interface. Control multiple smart stages from one PC screen, or develop your own code using the intuitive scripting tool. M3-LS Linear Smart Stage Specifications M3-LS Linear Smart Stage specifications MODEL M3-LS-1.8-6 Stroke 6 mm Dimensions 29 x 20 x 9.5 mm Mass of Smart Stage 8.4 grams Moving mass (vertical) (note 1) ≤ 10 grams recommended Moving mass (horizontal) (note 1) ≤ 20 grams (offset < 10 mm) recommended Force (operating) 0.2 N Speed (at operating force) 5 mm/s Closed-loop performance Resolution 0.5 m with absolute encoding Bi-directional repeatability < 5 m Accuracy < 20 m Input Power 3.3 V DC < 0.75 W typical at 5 mm/s, closed-loop (2 W max.) Mechanical stage Static parallelism < 30 m Runout < 10 m Pitch and yaw < 1 mrad Absolute maximum load 10 N Environment Relative humidity < 70% Operating temperature (note 2) -30 °C to +70 °C Storage temperature -40 °C to +80 °C Lifetime (note 3) >10 million random moves while not exceeding 1.2 km total travel. See note 3. Drive electronics Integrated into the smart stage Control interface Via USB adapter from PC or directly to I2C or SPI serial interface Note 1: Higher mass is possible but will affect performance and lifetime. Note 2: Speed and force reduced at lower temperatures within the range. Note 3: Corresponds to 10 million moves with an average random move of 120 µm. Lifetime depends on the application and use case. Please consult the factory to discuss your specific system design. M3 smart module platform The M3-LS Linear Smart Stage is built on New Scale’s M3 micromechatronic “smart module” platform, integrating a patented piezoelectric SQUIGGLE® micro motor, precision mechanical guide system, position sensor, microprocessor, and drive electronics into one tiny package. Eliminating the need for external controllers, M3 smart modules offer the smallest system size and easiest integration into OEM systems. They operate on 3.3 V DC input, accept high-level motion commands, and hold position with power off. 2 | New Scale Technologies, Inc. ~ w w w . n e w s c a l e t e c h . c o m ~ Phone (585) 924-4450 Multi-axis systems: Create miniature X-Y or X-Y-Z smart stages using two or three M3-LS Linear Smart Stages. M3-LS Linear Smart Stage M3-LS-1.8-6 Linear Smart Stage FLEX CABLE OPTIONS STRAIGHT 250.00 RIGHT-ANGLE 250.00 13.50 M3-LS-1.8-6 X-Y configuration M3-LS-1.8-6 X-Y-Z configuration New Scale Technologies, Inc. ~ w w w . n e w s c a l e t e c h . c o m ~ Phone (585) 924-4450 | 3 M3-LS Linear Smart Stage M3-LS for electrophysiology EP-clamp-6.35 With its high resolution, repeatability and lateral stability, the M3-LS makes an ideal backlashfree motorized micro drive for electrode positioning in chronic recording. The EP-clamp6.35 pipette holder clamp facilitates easy removal and replacement of the pipette holder in the recording chamber. Low EMI ensures non-interference with electrode recording. Dimensions in mm Ordering information Developer’s Kits M3-LS developer’s kits provide easy evaluation and prototyping of one-axis M3-LS Linear Smart Stage systems. Developer’s kits are available from New Scale and select reps and distributors. Developer’s Kit Description DK- M3-LS-1.8-6 M3-LS-1.8 Developer’s Kit with 6 mm travel  One M3-LS-1.8-6 Linear Smart Stage  One M3-1.8-USB Adapter  M3-1.8-0-Deg-250 straight flex cable, 250 mm long  M3-1.8-90-Deg-250 angled flex cable, 250 mm long  New Scale Pathway™ Software on separate USB  Mounting hardware kit Contact New Scale regarding additional stages, brackets and flex cables for use with the developer’s kit to create 2-axis and 3-axis systems, or to inquire about volume pricing or customization of M3-LS smart stage systems. Additional Components Description M3-LS-1.8-6 Linear Smart Stage with 6 mm travel Stage, no cables Developer’s Kit DK-M3-LS-1.8-6 M3-1.8-0-Deg-250 Flex cable for M3-LS stage Straight, 250 mm length M3-1.8-90-Deg-250 Flex cable for M3-LS stage Right angle at one end, 250 mm length M3-1.8-Y-Bracket Bracket for Y-axis smart stage Affixes Y-axis smart stage to X-axis smart stage M3-1.8-Z-Bracket Bracket for Z-axis smart stage Affixes Z-axis smart stage to X- or Y-axis smart stage EP-clamp-6.35 Pipette holder clamp Suitable for pipette holders with body dia. 0.25” (6.35mm) e.g. models 67944x from A.M. Systems M3-1.8-USB Adapter M3-1.8-0-Deg-250 Flex Cable M3-LS-1.8-6 Linear Smart Stage Additional information Visit the website to download STEP files, the integration guide and command and control reference guide for M3-LS Linear Smart Stages: http://www.newscaletech.com/downloads/softwarecad-manuals.php (registration required). 4 | New Scale Technologies, Inc. ~ w w w . n e w s c a l e t e c h . c o m ~ Phone (585) 924-4450 M3-LS-datasheet-04-08-2017
DK-M3-LS-1.8-6 价格&库存
很抱歉,暂时无法提供与“DK-M3-LS-1.8-6”相匹配的价格&库存,您可以联系我们找货
