410-323
410-323
    DIGILENT(迪芝伦)
    - Displays, OLED Display Evaluation Board
410-323 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com PmodOLEDrgb™ Reference Manual Revised April 26, 2016 This manual applies to the PmodOLEDrgb rev. B Overview The Digilent PmodOLEDrgb is an organic RGB LED module with a 96×64 pixel display capable of 16-bit color resolution. Features include:        96×64 pixel RGB OLED screen 0.8“ x 0.5” graphical display 16-bit color resolution Two low-power display shutdown modes Small PCB size for flexible designs (1.4“ x 1.0”) 12-pin Pmod connector with SPI interface Library and example code available in resource center The PmodOLEDrgb. 1 Functional Description The PmodOLEDrgb utilizes a Solomon Systech SSD1331 display controller to receive information from the host board and display the desired information on the OLED screen. 2 Interfacing with the Pmod The PmodOLEDrgb communicates with the host board via the SPI protocol. By driving and keeping the Chip Select (CS) line at a logic level low, users may send both commands and data streams to the display controller based on the state of the Data/Command (D/C) pin. DOC#: 410-323 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 3 PmodOLEDrgb™ Reference Manual As a graphical display interface, users may light up any individual pixel on the OLED, display predefined characters, or even load bitmaps onto the screen. Each pixel can be set to one of the 65,535 colors that are available. The OLED display has a specific power-up and power-down sequence to ensure the longevity of the device. There are two field-effect transistors (FETs) that control the display’s two power supplies. The VCCEN control toggles the positive voltage supply to the screen itself and the PMODEN control toggles the power supply ground to the display. Users may turn off either one of these controls to reduce the power consumption of the PmodOLEDrgb to approximately 200 nA. 2.1 1. 2. 3. 4. 5. 6. 7. 2.2 1. 2. 3. 4. Power-on Sequence Apply power to VCC. Send Display Off command. Initialize display to default settings. Clear screen. Apply power to VCCEN. Delay 100ms. Send Display On command. Power-off Sequence Send Display Off command Power off VCCEN Delay 100ms Power off VCC A pinout table of the PmodOLEDrgb is provided below. Pin Signal Description 1 CS Chip Select 2 MOSI Master-Out-Slave-In 3 NC Not Connected 4 SCK Serial Clock 5 GND Power Supply Ground 6 VCC Power Supply (3.3V) 7 D/C Data/Command Control 8 RES Power Reset 9 VCCEN Vcc Enable 10 PMODEN Vdd Logic Voltage Control 11 GND Power Supply Ground 12 VCC Power Supply (3.3V) Table 1. Header J1 pinout descriptions. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 3 PmodOLEDrgb™ Reference Manual Although users are welcome to create their own interface code for the PmodOLEDrgb if they so desire, preconstructed libraries that provide functions for initializing the display and rendering simple text and graphics onto the screen exist. They are available on the PmodOLEDrgb example code page and can be used as-is or as a starting point for a more sophisticated graphics library. Any external power applied to the PmodOLEDrgb must be within 2.7V and 5V; however, it is recommended that Pmod is operated at 3.3V. 3 Physical Dimensions The pins on the pin header are spaced 100 mil apart. The PCB is 1.4 inches long on the sides parallel to the pins on the pin header and 1 inch long on the sides perpendicular to the pin header. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 3
410-323
物料型号:PmodOLEDrgb
器件简介:PmodOLEDrgb是一个有机RGB LED模块,具有96×64像素的显示屏,能够达到16位颜色分辨率。
引脚分配: - 1. CS:芯片选择 - 2. MOSI:主设备输出从设备输入 - 3. NC:未连接 - 4. SCK:串行时钟 - 5. GND:电源地 - 6. VCC:电源(3.3V) - 7. D/C:数据/命令控制 - 8. RES:电源复位 - 9. VCCEN:Vcc使能 - 10. PMODEN:Vdd逻辑电压控制 - 11. GND:电源地 - 12. VCC:电源(3.3V)
参数特性:包括96×64像素RGB OLED屏幕、0.8" x 0.5"图形显示、16位颜色分辨率、两个低功耗显示关闭模式、小尺寸PCB(1.4" x 1.0")、12针Pmod连接器与SPI接口。
功能详解:PmodOLEDrgb使用Solomon Systech SSD1331显示控制器接收主机板信息,并在OLED屏幕上显示所需信息。用户可以点亮OLED上的任何单个像素,显示预定义字符,甚至将位图加载到屏幕上。每个像素可以设置为65,535种颜色之一。
应用信息:用户可以创建自己的接口代码,或者使用资源中心提供的预构建库,这些库提供了初始化显示和在屏幕上渲染简单文本和图形的函数。
封装信息:引脚排布间隔为100 mil,PCB在与引脚平行的两侧长1.4英寸,在垂直于引脚的两侧长1英寸。
410-323 价格&库存
很抱歉,暂时无法提供与“410-323”相匹配的价格&库存,您可以联系我们找货
