ISD-DMK_9160
ISD-DMK_9160
    NUVOTON(新唐)
    KIT DEV/DEMO ISD9160 DEMO9160
ISD-DMK_9160 数据手册
ISD9160 Demo Board User’s Manual ISD9160 Demo Board Rev B User’s Manual -1- Publication Release Date: Aug. 16, 2013 Revision V0.3 ISD9160 Demo Board User’s Manual The information described in this document is the exclusive intellectual property of Nuvoton Technology Corporation and shall not be reproduced without permission from Nuvoton. Nuvoton is providing this document only for reference purposes of ISD ChipCorder microcontroller based system design. Nuvoton assumes no responsibility for errors or omissions. All data and specifications are subject to change without notice. For additional information or questions, please contact: Nuvoton Technology Corporation. -2- Release Date: Aug. 16, 2013 Revision V0.3 ISD9160 Demo Board User’s Manual Table of Contents 1 2 3 INTRODUCTION ......................................................................................................................... 4 JUMPER AND BUTTONS........................................................................................................... 5 DEMO CODE .............................................................................................................................. 6 3.1 Operation ........................................................................................................................ 6 4 5 BOARD SCHEMATIC ................................................................................................................. 7 REVISION HISTORY .................................................................................................................. 8 Table of Figures Figure 1: Demo board and ISD-9160_Touch ................................................................................... 4 -3- Release Date: Aug. 16, 2013 Revision V0.3 ISD9160 Demo Board User’s Manual 1 Introduction The ISD9160 demo board is a small board, its dimension is around 35mm by 50mm. All function pins are layout to the connectors for easy expansion. It is convenient for demo use, and also could be used for development with ISD-Nu-Link-dongle. This document only describes demo code, demo board hardware, jumper function and schematic. User can refer to the “Introduction to ISD9160 Development Environment” for the project development & tools function to get the overall development concept. Below is the picture of ISD9160 Demo Board and Touch Board, all components are on the top side except the SPI-flash related which are on the back. Figure 1: Demo board and ISD-9160_Touch -4- Release Date: Aug. 16, 2013 Revision V0.3 ISD9160 Demo Board User’s Manual 2 Jumper and buttons Component Name Description Default J1 SW_RES button selection for RESETN or GPA6 Pin 1, 2 & 3 short for GPA6 scanning. No reset key. J2 Option for D2 LED driving by GPA12 Short for LED driving by GPA12 J12 Power input J13 Speaker signal output. J14 GPIOA port connector J15 GPIOB port connector. Also can connect with ISD-9160_Touch for touch sensing function. J19 ISD dongle interface for programming or debugging J21 Option for MIC+ signal input, from microphone or speaker Signal input from microphone (MK+1) J22 Option for MIC- signal input, from microphone or speaker Signal input from microphone (MK-1) WAKEUP (PB1) Wakeup key for wakeup from deep power down Open and pull-high SW_RES Reset key or GPA6 key, based on J1 setting GPA6 key -5- Release Date: Aug. 16, 2013 Revision V0.3 ISD9160 Demo Board User’s Manual 3 Demo code Normally a VR light control demo code was programmed before shipping. User can try the demo code function with default jumper setting. 3.1  Operation Capacitive Touch Button Sensing with Audio Feedback Touch CS0, CS2, CS4 of Touch Board will play Do, Re, Mi and turn led D2 on/off.  Play preprogrammed sound (Siren7, 16Kbps, 16K sampling rate) There are two pre-programmed sounds in ISD9160 flash and one sound in SPI-flash. CS3 is Play/Stop key. Touch CS3 will cyclically play these sounds. Pressing CS3 can stop playing if sound is being played.  SPI-flash Record/Play (Siren7, 16Kbps, 16K sampling rate) SW_RES button is default set to GPA6 connection (no reset function). This key supports multi functions Record/Play/Stop. Pressing this button can play the recorded sound or stop the playing/recording. Pressing over 2 second will have a prompt sound, and will start recording sound into SPI-flash once button released. Only one recorded sound is allowed in this code, record again will overwrite the previous recorded sound.  Voice Recognition: VR function is always on except Record or Play function is processing. The below table is the command and description. Environment: Office environment, no loud background sound. (The speaking should be 20dB louder than environment sound.) Best Distance: within 30 cm (from MIC). Note: Need to adjust the program and trade off the distance under noisy environment. Voice Command Description Cinderella An ID command to enable the following four action commands, a prompt sound will be played once ID command recognized. User can speak the action command within 2 seconds after the prompt sound. Lights Off The D2 LED will be off Turn Lights On The D2 LED will be on with full brightness. Dimmer Decrease the brightness with prompt sound, 3 stages including full brightness. Only works when lights on Brighter Increase the brightness with prompt sound, 3 stages including full brightness. Only works when lights on. -6- Release Date: Aug. 16, 2013 Revision V0.3 ISD9160 Demo Board User’s Manual 4 Board Schematic -7- Release Date: Aug. 16, 2013 Revision V0.3 ISD9160 Demo Board User’s Manual 5 Revision History VERSION DATE PAGE/ CHAP. V0.0 Nov. 28, 2011 - First Release. V0.1 Mar. 08,2012 - Add operation environment and distance for VR demo V0.2 May 30, 2013 - Removed “Preliminary” V0.3 Aug 16, 2013 - Removed jumper setting and added Cap Sensor Audio Feedback DESCRIPTION -8- Release Date: Aug. 16, 2013 Revision V0.3 ISD9160 Demo Board User’s Manual Important Notice Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Furthermore, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation where personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. Please note that all data and specifications are subject to change without notice. All the trademarks of products and companies mentioned in this datasheet belong to their respective owners. -9- Release Date: Aug. 16, 2013 Revision V0.3
ISD-DMK_9160
- 物料型号:文档中提到的物料型号是ISD9160。 - 器件简介:ISD9160 Demo Board是一个小型开发板,尺寸约为35mm x 50mm,所有功能引脚都布局到连接器上,便于扩展使用,也适用于与ISD-Nu-Link-dongle一起开发。 - 引脚分配:文档中提到了多个跳线和按钮,例如J1用于选择RESETN或GPA6,J2用于选择D2 LED的驱动方式,J12是电源输入,J13是扬声器信号输出,J14和J15是GPIOA和GPIOB端口连接器。 - 参数特性:文档中没有提供详细的参数特性,但提到了ISD9160芯片具有电容触摸按钮感应和音频反馈功能,以及预编程声音播放和SPI-flash录音/播放功能。 - 功能详解:文档详细介绍了电容触摸按钮感应、预编程声音播放、SPI-flash录音/播放以及语音识别功能。 - 应用信息:文档中提到了ISD9160 Demo Board的一些应用示例,如触摸控制LED灯的开关和亮度调节,以及通过语音命令控制LED灯。 - 封装信息:文档中提到了ISD9160芯片的封装类型为LQFP48。
ISD-DMK_9160 价格&库存
很抱歉,暂时无法提供与“ISD-DMK_9160”相匹配的价格&库存,您可以联系我们找货
