3263
3263
    ADAFRUIT
3263 数据手册
Adafruit MAX31856 Universal Thermocouple Amplifier Created by lady ada https://learn.adafruit.com/adafruit-max31856-thermocouple-amplifier Last updated on 2021-11-15 06:47:36 PM EST ©Adafruit Industries Page 1 of 22 Table of Contents Overview 3 Pinouts 5 • Power Pins: • SPI Logic pins: • Additional Pins 5 6 6 Assembly 7 • Prepare the header strip: • Add the breakout board: • And Solder! 7 7 8 Wiring & Test • • • • • SPI Wiring Download Adafruit_MAX31856 library Attach Thermocouple Load Demo Library Reference 10 11 11 12 13 15 Python & CircuitPython 17 • • • • • • 18 18 19 19 20 20 CircuitPython Microcontroller Wiring Python Computer Wiring CircuitPython Installation of MAX31856 Library Python Installation of MAX31856 Library CircuitPython & Python Usage Full Example Code Python Docs 21 Downloads 21 • Files • Schematic • Fabrication Print 21 21 22 ©Adafruit Industries Page 2 of 22 Overview Thermocouples are very sensitive, requiring a good amplifier with a coldcompensation reference, as well as calculations to handle any non-linearities. For a long time we've suggested our MAX31855K breakout, which works great but is only for K-type thermocouples. Now we're happy to offer a great new thermocouple amplifier/converter that can handle just about any type of thermocouple, and even has the ability to give you notification when the temperature goes out of range, or a fault occurs. Very fancy! This converter communicates over 4-wire SPI and can interface with any K, J, N, R, S, T, E, or B type thermocouple ©Adafruit Industries Page 3 of 22 This breakout does everything for you, and can be easily interfaced with any microcontroller, even one without an analog input. This breakout board has the chip itself, a 3.3V regulator and level shifting circuitry, all assembled and tested. Comes with a 2 pin terminal block (for connecting to the thermocouple) and pin header (to plug into any breadboard or perfboard). We even added inline resistors and a filter capacitor onboard for better stability, as recommended by Maxim. Goes great with our 1m K-type thermocouple (http://adafru.it/270) or any other thermocouple, really! • Works with any K, J, N, R, S, T, E, or B type thermocouple • -210°C to +1800°C output in 0.0078125° resolution - note that many thermocouples have about ±2°C to ±6°C accuracy or worse depending on the temperature and type, so the resolution will be a lot better than the accuracy! • Internal temperature reading • 3.3 to 5v power supply and logic level compliant! • SPI data requires any 4 digital I/O pins. ©Adafruit Industries Page 4 of 22 Pinouts Power Pins: • Vin - this is the power pin. Since the sensor chip uses 3 VDC, we have included a voltage regulator on board that will take 3-5VDC and safely convert it down. To power the board, give it the same power as the logic level of your microcontroller - e.g. for a 5V micro like Arduino, use 5V • 3Vo - this is the 3.3V output from the voltage regulator, you can grab up to 100mA from this if you like ©Adafruit Industries Page 5 of 22 • GND - common ground for power and logic SPI Logic pins: All pins going into the breakout have level shifting circuitry to make them 3-5V logic level safe. Use whatever logic level is on Vin! • SCK - This is the SPI Clock pin, its an input to the chip • SDO - this is the Serial Data Out / Microcontroller In Sensor Out pin, for data sent from the MAX31856 to your processor • SDI - this is the Serial Data In / Microcontroller Out Sensor In pin, for data sent from your processor to the MAX31856 • CS - this is the Chip Select pin, drop it low to start an SPI transaction. Its an input to the chip If you want to connect multiple MAX31856's to one microcontroller, have them share the SDI, SDO and SCK pins. Then assign each one a unique CS pin. Additional Pins There's two more pins that are available for advanced usage • FLT - This is the Fault output. If you use the threshhold-notification capabilities of the MAX31856 you can monitor this pin, when it goes low there's a fault! • DRDY - This pin is used for advanced uses where you tell the sensor to begin a reading and then wait for this pin to go low. We don't use it in our library code because we keep it simple with a delay/wait, but it is available in case you need it! ©Adafruit Industries Page 6 of 22 Assembly Prepare the header strip:   Cut the strip to length if necessary. It will be easier to solder if you insert it into a breadboard - long pins down. Add the breakout board:   Place the breakout board over the pins so that the short pins poke through the breakout pads ©Adafruit Industries Page 7 of 22 And Solder!   Be sure to solder all 5 pins for reliable electrical contact. (For tips on soldering, be sure to check out ourGuide to Excellent Soldering (https://adafru.it/aTk)) Now you can do the terminal block, this is what you'll use to attach the thermocouple since you cannot solder to thermocouples The terminal block goes on the top with the open ends pointing out ©Adafruit Industries Page 8 of 22 Solder the two pads as you did with the plain header. They're quite large and require a lot of solder ©Adafruit Industries Page 9 of 22 Insert the thermocouple wires and tighten down the clamps with a small Phillips or flat screwdriver That's it! you are now ready to wire and test Wiring & Test You can easily wire this breakout to any microcontroller, we'll be using an Arduino. For another kind of microcontroller, as long as you have 4 available pins it is possible to 'bit-bang SPI' or you can use hardware SPI if you like. Just check out the library, then port the code. ©Adafruit Industries Page 10 of 22 Fritzing diagram.fzz https://adafru.it/rAK SPI Wiring Since this is a SPI-capable sensor, we can use hardware or 'software' SPI. To make wiring identical on all Arduinos, we'll begin with 'software' SPI. The following pins should be used: • Connect Vin to the power supply, 3V or 5V is fine. Use the same voltage that the microcontroller logic is based off of. For most Arduinos, that is 5V • Connect GND to common power/data ground • Connect the SCK pin to Digital #13 but any pin can be used later • Connect the SDO pin to Digital #12 but any pin can be used later • Connect the SDI pin to Digital #11 but any pin can be used later • Connect the CS pin Digital #10 but any pin can be used later Later on, once we get it working, we can adjust the library to use hardware SPI if you desire, or change the pins to other Download Adafruit_MAX31856 library To begin reading sensor data, you will need to install Adafruit MAX31856 from the Arduino library manager. ©Adafruit Industries Page 11 of 22 Open up the Arduino library manager: Search for the Adafruit MAX31856 library and install it We also have a great tutorial on Arduino library installation at: http://learn.adafruit.com/adafruit-all-about-arduino-libraries-install-use Attach Thermocouple You'll need to attach a thermocouple, for this demo we'll be using a K-type but you can adjust the demo if you do not have a K-type handy! ©Adafruit Industries Page 12 of 22 Load Demo Open up File->Examples->Adafruit_MAX31856->max31856 and upload to your Arduino wired up to the sensor. Adjust the max.setThermocoupleType(MAX31856_T CTYPE_K) line if necessary. Upload to your Arduino and open up the serial console at 115200 baud to see a print out of the cold junction temperature (temperature of the microcontroller chip) and the thermocouple temperature (temperature detected at the end of the thermocouple probe ©Adafruit Industries Page 13 of 22 You can also see some of the faults that are detectable by say disconnecting one of the pins: ©Adafruit Industries Page 14 of 22 Library Reference You can start out by creating a MAX31856 object with either software SPI (where all four pins can be any I/O) using // Use software SPI: CS, DI, DO, CLK Adafruit_MAX31856 max = Adafruit_MAX31856(10, 11, 12, 13); Or you can use hardware SPI. With hardware SPI you must use the hardware SPI pins for your Arduino - and each arduino type has different pins! Check the SPI reference to see what pins to use. (https://adafru.it/d5h) In this case, you can use any CS pin, but the other three pins are fixed // use hardware SPI, just pass in the CS pin Adafruit_MAX31856 max = Adafruit_MAX31856(10); Once started, you can initialize the sensor with max.begin() You'll also need to set the thermocouple type, remember there's a lot of options! Set the type with: max.setThermocoupleType(MAX31856_TCTYPE_xxx) Your options for the TCTYPE are: • • • • • • • • • • MAX31856_TCTYPE_B MAX31856_TCTYPE_E MAX31856_TCTYPE_J MAX31856_TCTYPE_K MAX31856_TCTYPE_N MAX31856_TCTYPE_R MAX31856_TCTYPE_S MAX31856_TCTYPE_T MAX31856_VMODE_G8 MAX31856_VMODE_G32 The last two are not thermocouple types, they're just 'plain' voltage readings (check the datasheet for more details, we don't use these modes in the library) ©Adafruit Industries Page 15 of 22 If you're ever not sure which mode you're in, query it with max.getThermocoupleType() Once that's set you can read the cold junction temperature, which will return a floating point Celsius reading. This is the temperature detected inside the MAX31856 chip ('ambient' temp) max.readCJTemperature() Or, of course, the temperature at the end/tip of the thermocouple, likewise a floating point # max.readThermocoupleTemperature() Faults The MAX31856 has a wide-ranging fault mechanism that can alert you via pin or function when something is amiss. Don't forget to test this functionality before relying on it! You can read faults with max.readFault() Which will return a uint8_t type with bits set for each of 8 different fault types. You can test for each one with this set of code: uint8_t fault = max.readFault(); if (fault) { if (fault & MAX31856_FAULT_CJRANGE) Fault"); if (fault & MAX31856_FAULT_TCRANGE) Fault"); if (fault & MAX31856_FAULT_CJHIGH) Fault"); if (fault & MAX31856_FAULT_CJLOW) Fault"); if (fault & MAX31856_FAULT_TCHIGH) Fault"); if (fault & MAX31856_FAULT_TCLOW) Fault"); if (fault & MAX31856_FAULT_OVUV) Fault"); if (fault & MAX31856_FAULT_OPEN) Fault"); } ©Adafruit Industries Serial.println("Cold Junction Range Serial.println("Thermocouple Range Serial.println("Cold Junction High Serial.println("Cold Junction Low Serial.println("Thermocouple High Serial.println("Thermocouple Low Serial.println("Over/Under Voltage Serial.println("Thermocouple Open Page 16 of 22 The last two faults are built in. For the low/high threshholds, you can set those with two functions. For the cold junction (chip) temp, use: max.setColdJunctionFaultThreshholds(lowtemp, hightemp) Where lowtemp and hightemp range between -127 and +127 Centigrade (the chip wont function down to -127 but that's the lowest number you can put in. For the thermocouple, use setTempFaultThreshholds(lowtemp, hightemp) Where lowtemp and hightemp are floating point numbers with a range of -4096 to +4096 and a resolution of 0.0625 degrees Centigrade Python & CircuitPython It's easy to use the MAX31856 sensor with Python and CircuitPython, and the Adafruit CircuitPython MAX31856 (https://adafru.it/Gao) module.  This module allows you to easily write Python code that reads the temperature from the thermocouple. You can use this sensor with any CircuitPython microcontroller board or with a computer that has GPIO and Python thanks to Adafruit_Blinka, our CircuitPython-forPython compatibility library (https://adafru.it/BSN). ©Adafruit Industries Page 17 of 22 CircuitPython Microcontroller Wiring First, wire up a MAX31856 to your board exactly as shown on the previous pages for Arduino.  Here's an example of wiring a Feather M0 to the sensor: • Board 3V to sensor VIN • Board GND to sensor GND • Board SCK to sensor SCK • Board MISO to sensor SDO • Board MOSI to sensor SDI • Board D5 to sensor CS (or any other free digital I/O pin) Once wired to the microcontroller, make sure you connect a thermocouple to the terminal on the breakout board. Python Computer Wiring Since there's dozens of Linux computers/boards you can use, this shows wiring for Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to see whether your platform is supported (https://adafru.it/BSN).  Here's the Raspberry Pi wired with SPI: • Pi 3V to sensor VIN • Pi GND to sensor GND • Pi SCK to sensor SCK • Pi MISO to sensor SDO • Pi MOSI to sensor SDI • Pi D5 to sensor CS (or any other free digital I/O pin) Once wired to the Raspberry Pi, make sure you connect a thermocouple to the terminal on the breakout board. ©Adafruit Industries Page 18 of 22 CircuitPython Installation of MAX31856 Library Next, you'll need to install the Adafruit CircuitPython MAX31856 (https://adafru.it/Gao)  library on your CircuitPython board First, make sure you are running the latest version of Adafruit CircuitPython (https:// adafru.it/tBa) for your board. Next you'll need to install the necessary libraries to use the hardware. Carefully follow the steps to find and install these libraries from Adafruit's CircuitPython library bundle  (https://adafru.it/ENC).  For example the Circuit Playground Express guide has a great page on how to install the library bundle (https://adafru.it/Bf2) for both Express and non-Express boards. Remember for non-Express boards like the Trinket M0, Gemma M0, and Feather/ Metro M0 basic you'll need to manually install the necessary libraries from the bundle: • adafruit_max31856.mpy • adafruit_bus_device Before continuing, make sure your board's lib folder has the adafruit_max31856.mpy, and adafruit_bus_device files and folders copied over. Next connect to the board's serial REPL (https://adafru.it/Awz) so you are at the CircuitPython >>> prompt. Python Installation of MAX31856 Library You'll need to install the Adafruit_Blinka library that provides the CircuitPython support in Python. This may also require enabling I2C on your platform and verifying you are running Python 3. Since each platform is a little different, and Linux changes often, please visit the CircuitPython on Linux guide to get your computer ready (https ://adafru.it/BSN)! Once that's done, from your command line run the following command: • sudo pip3 install adafruit-circuitpython-max31856 ©Adafruit Industries Page 19 of 22 If your default Python is version 3 you may need to run 'pip' instead. Just make sure you aren't trying to use CircuitPython on Python 2.x, it isn't supported! CircuitPython & Python Usage To demonstrate the usage of the sensor, initialize it and read the temperature.  Remember to attach a thermocouple to the terminal on the breakout! First initialize the SPI connection and library by running: import board import digitalio import adafruit_max31856 spi = board.SPI() cs = digitalio.DigitalInOut(board.D5) cs.direction = digitalio.Direction.OUTPUT thermocouple = adafruit_max31856.MAX31856(spi,cs) Now you can read the temperature property to retrieve the temperature from the sensor in degrees Celsius: print(thermocouple.temperature) That's all there is to reading temperature with the MAX31856 and CircuitPython code! Full Example Code # SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries # SPDX-License-Identifier: MIT import board import digitalio import adafruit_max31856 # Create sensor object, communicating over the board's default SPI bus spi = board.SPI() # allocate a CS pin and set the direction cs = digitalio.DigitalInOut(board.D5) cs.direction = digitalio.Direction.OUTPUT # create a thermocouple object with the above thermocouple = adafruit_max31856.MAX31856(spi, cs) # print the temperature! print(thermocouple.temperature) ©Adafruit Industries Page 20 of 22 Python Docs Python Docs (https://adafru.it/G7C) Downloads Files • Fritzing object in Adafruit Fritzing library (https://adafru.it/c7M) • EagleCAD PCB files on GitHub (https://adafru.it/rAN) • Library on GitHub (https://adafru.it/rAL) • MAX31856 Datasheet (https://adafru.it/rAO) Schematic ©Adafruit Industries Page 21 of 22 Fabrication Print ©Adafruit Industries Page 22 of 22
很抱歉,暂时无法提供与“3263”相匹配的价格&库存,您可以联系我们找货
    • 1+326.22480
    • 200+130.17240
