410-216
410-216
    DIGILENT(迪芝伦)
    BOARD CHIPKIT BASIC I/O SHIELD
410-216 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com chipKIT™ Basic I/O Shield™ Reference Manual Revised August 27, 2013 This manual applies to the chipKIT Basic I/O Shield rev. C Overview The chipKIT Basic I/O Shield is an input/output expansion shield designed for use with chipKIT microcontroller boards such as the Uno32™, uC32™, and the Max32™. These boards are based on the popular Arduino® IDE opensource hardware prototyping platform. The Basic I/O Shield provides a range of input/output devices for both beginners and advanced users. It provides simple digital input devices such as switches and buttons, and digital output devices such as discrete LEDs and 2 2 high-current open FET drivers. It also provides more advanced devices such as an I C EEPROM, an I C temperature sensor, an organic LED graphic display, and a potentiometer for use as an analog input device. The Basic I/O Shield has the same form factor as the Uno32 board, but is also useable with the Max32 board. Features include: • • • • • • • • • A 128x32 pixel OLED graphic display. 2 An I C temperature sensor. 2 A 256Kbit I C EEPROM. 2 An I C daisy chain connector. Four push buttons. Four slide switches. Eight discrete LEDs. Four open-drain FET drivers. An analog potentiometer. The chipKIT Basic I/O Shield. DOC#: 502-216 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 13 chipKIT™ Basic I/O Shield™ Reference Manual 1 Hardware Overview The Basic I/O Shield has the following hardware features: 1. Pushbuttons Four pushbuttons provide discrete momentary-contact digital inputs. These can be accessed using the digitalRead function. 2. Slide Switches Four slide switches provide discrete digital inputs. These can be accessed using the digitalRead function. 3. J2: Shield Power Connector This connector receives power from the chipKIT microcontroller board. 4. J3: Analog Signal Connector Pin 1 (analog signal A0) is connected to a potentiometer. Pins 5 and 6 (labeled A4 and A5) provide 2 2 2 access to the I C signals SDA and SCL for the I C bus. The I C bus is used to access the temperature 2 sensor and the EEPROM and for the I C daisy chain connector. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 13 chipKIT™ Basic I/O Shield™ Reference Manual Note: On the Uno32 and uC32 boards, you need to set jumpers JP6 & JP7 to the correct position to 2 access the I C signals on that board. On the Max32 board, you need to use jumper wires to bring the 2 2 I C signals onto the board, because the connector that provides the I C bus on the Max32 board doesn’t contact the Basic I/O Shield. 5. Discrete LEDs The eight LEDs provide discrete digital outputs. These can be accessed individually using the digitalWrite function. The LEDs are connected to the low eight bits of microcontroller PORTE and all eight can be written at the same time by writing to PORTE. 6. IC2: Temperature Sensor 2 This is a Microchip TCN75A digital temperature sensor. It is accessed via the I C bus. 7. 2 JP2 & JP3: I C Pull-up Resistor Enable Jumpers 2 2 These jumpers are used to enable or disable the I C pull-up resistors on the I C bus. Installing the shorting blocks enables the resistors. Removing the shorting blocks disables the resistors. 8. 2 J11: I C Daisy Chain Connector 2 This is a 2x4 pin header connector that provides access to the I C signals SDA and SCL as well as 2 power from the 3.3V power bus and ground. The connector can be used to extend the I C bus to 2 2 another board and to power an external I C device. Digilent has cables and a selection of I C peripheral modules that can be connected to this shield. 9. Potentiometer This is a 10K-ohm potentiometer connected across VCC3V3 and ground. It provides an analog input voltage to analog input A0. 10. J1 & J2: Digital Signal Connectors These connectors bring digital signals from the chipKIT microcontroller board to the Basic I/O shield. 11. Organic LED Graphic Display This is a 128x32 pixel monochrome OLED graphic display panel is accessed using the SPI interface. 12. J9 & J10: Digital I/O Signal Connectors These are screw terminal connectors that provide access to digital I/O signals 3, 5, 6, and 9. These are four of the PWM signals from the chipKIT microcontroller board. 13. J6: Open Drain FET Power Connector This provides access to the power connections for the open drain FETs. 14. J7 & J8: Open Drain FET Output These provide access to the outputs of the open drain FETs. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 13 chipKIT™ Basic I/O Shield™ Reference Manual 2 Hardware Description The following is a description of the Basic I/O Shield and how to use it. See Appendix A for pin definitions and Appendix B for sample code to use the OLED graphic display. 2.1 OLED Graphic Display The Basic I/O Shield provides a 128x32 pixel organic LED (OLED) graphic display panel, the WiseChip/Univision UG23832HSWEG04. The UG2832 uses the Soloman Systech SSD1306 display controller. Note: The UG2832 has a power on/power off sequence that should be followed. Failure to follow the power on/power off sequence can shorten the life of the display. The Basic I/O provides two FETs for software control of the two power supplies for the display. The VDD_EN control is used to toggle the power to the logic of the display. The VBAT_EN control is used to toggle power to the OLED display itself. These two pins have pull-up resistors to turn off their respective power supplies when not being driven. The pin is made an output and driven low to turn on the power supply. Power on sequence: 1. 2. 3. 4. 5. 6. 7. Apply power to VDD. Send Display Off command. Initialize display to desired operating mode. Clear screen. Apply power to VBAT. Delay 100ms. Send Display On command. Power off sequence: 1. 2. 3. 4. Send Display Off command. Power off VBAT. Delay 100ms. Power off VDD. The display has a D/C pin (display or command select) that is used to determine whether bytes sent to the display are interpreted as commands or as display data. The D/C pin is set high for display buffer access and low for command access. The RES pin is used to reset the SG1306 display controller. The RES pin is driven low for reset and driven high for normal operation. The low-going reset pulse must be a minimum of 3us (microseconds) for the display controller to reset correctly. The UG2832 is a serial device that is accessed using SPI. It is however, a write-only device. It is not possible to read back either the display buffer contents or any kind of status from the panel. The maximum SPI clock frequency supported by the UG2832 is 10MHz. Due to pin limitations between the Basic I/O Shield and the Uno32 board, the select pin (SS) is wired low on the Basic I/O Shield and the display is always enabled to receive data over the SPI interface. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 4 of 13 chipKIT™ Basic I/O Shield™ Reference Manual Digilent has a set of libraries for using the Basic I/O Shield with the chipKIT MPIDE. The OLED library can be used as-is or as a starting point for a more sophisticated graphics library. It is contained in document # DSD-0000311 (chipKIT IOShield Library.zip) which can be downloaded from the Basic I/O Shield product page at www.digilentinc.com. The OLED library is IOShieldOled. Appendix B provides sample driver code for initializing the display and writing to it. 2.2 Discrete Digital I/O Devices The Basic I/O Shield provides various discrete digital I/O devices. These can be accessed using the digitalRead and digitalWrite functions. The pinMode function is used to set the pin to input or output. When the buttons and switches on the Basic I/O Shield are not being used, the pins are available on the passthrough shield connectors for use by other shields in the stack. The pins used by the LEDs are also available, however the presence of the LEDs on the lines will load them down, possibly causing some devices to not work. It is safe to use any of these pins as either inputs or outputs. Pushbuttons: There are four pushbuttons labeled BTN1 (pin 4), BTN2 (pin 34), BTN3 (pin 36), and BTN4 (pin 37). The digitalRead function will return low if the button is not pressed and high when the button is pressed. Slide Switches: There are four slide switches labeled SW1 (pin 2), SW2 (pin 7), SW3 (pin 8) and SW4 (pin 35). The digitalRead function will return low when the switch is down (toward the pushbuttons) and high when the switch is up (toward the OLED display). LEDs: There are eight LEDs labeled LD1 –LD8 that are accessed through digital pins 33 – 26. An LED is illuminated when the corresponding pin is set to high using the digitalWrite function and off when set to low. The LEDs are attached to the low eight bits of PORTE, with LD1 connected to PORTE bit 0, and LD8 connected to PORTE bit 7. An 8-bit value written to PORTE (or LATE) will display the corresponding binary value on the LEDs. 2.3 Open Drain FET Outputs The Basic I/O Shield has four open-drain FET outputs. These are low-side N-channel devices and can be used to provide a digital switch closure to ground. These can be used to switch external loads such as relay coils, solenoids, stepper motors, and so on. An FET is used to switch an external load, such as a relay coil, on and off. The load is wired between the positive side of an external power supply and the output of the FET. When the FET is switched on, current flows from the external power supply through the load and the FET to ground. FETs are often used to switch highly inductive loads, such as relay coils, solenoids, and motors. When the current through an inductive load is switched off, a voltage spike will occur that can damage the FET. The Basic I/O Shield has clamp diodes (also called snubber or flyback diodes) to clamp the voltage spike and feed the current back to the external supply. The NTHD4508N FETs are rated for a maximum VDS (voltage from drain to source) of 20V. They are rated for a maximum continuous current of 3.0A at 25ºC and 2.2A at 85ºC. For detailed specifications, see the data sheet available at www.onsemi.com. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 5 of 13 chipKIT™ Basic I/O Shield™ Reference Manual The FETs are labeled Q1A (pin 9), Q1B (pin 6), Q2A (pin 5), and Q2B (pin 3). These four pins are also four of the pulse width modulation (PWM) outputs supported by the chipKIT boards. The FETs can be switched using PWM via the analogWrite function. An FET is switched on by driving its gate high. When the FET is on, it provides a low impedance path to ground (similar to a closed switch to ground). When the FET is switched off by driving its gate low, it becomes a high impedance path to ground (similar to an open switch to ground). Pull-down resistors are connected to the gate of each FET to ensure that it is off unless being actively driven high by the microcontroller on the chipKIT board. The FET outputs are accessed via screw terminal connectors J7 and J8 on the left side of the shield. The digital signals used to switch the FETs on and off are also available on screw terminal connectors J9 and J10 at the left side of the upper edge of the shield. Screw terminal connector J6 is used to make the power and ground connections back to the external power supply. The negative (-) pin of J6 connects the external supply ground with the Basic I/O Shield ground, and the positive (+) terminal connects the Basic I/O Shield to the external supply voltage. The unloaded 2-pin header JP1 can be used to connect the shield’s VCC5V0 power supply bus to the external power supply bus so that the shield’s 5V supply can be used instead of an external supply. In this case, J6 is used to connect the shield’s supply to the external loads. If this is done, the total current consumed by all external loads must not exceed 2A or the current rating of the shield’s power supply (whichever is less). 2.4 I2C Bus 2 2 The I C bus from the chipKIT microcontroller board is brought onto the Basic I/O Shield. There are two I C devices 2 2 on the board and a connector for taking the I C bus off the shield to connect to additional external I C devices. 2 2 I C Connector: Connector J11 can be used to extend the I C bus off of the shield to connect to additional external 2 2 I C devices. J11 is a standard 2x4 pin header connector with 0.100” spaced pins. It provides access to the I C 2 signals, SCL and SDA, plus VCC3V3 and ground. The VCC3V3 can be used to power external I C devices. 2 The I C bus uses open collector drivers to allow multiple devices to drive the bus signals. This means that pull-up resistors must be provided to supply the logic high state for the signals. The Basic I/O Shield provides 2.2K-ohm pull-up resistors. Generally, only one set of pull-up resistors is used on the bus. Jumpers JP2 and JP3 can be used to disable the on-board pull-up resistors if a different value is needed or some other device on the bus is providing the pull-ups. The on-board pull-up resistors are enabled by install shorting blocks on JP2 and JP3. Removing the shorting blocks disables the pull-up resistors. 2 Digilent has several small I/O peripheral modules (Pmods) that can be connected using the I C connector. These include a 3-axis accelerometer, a 4-channel 12-bit A/D converter, a serial character LCD panel, a 3-axis gyroscope, a real-time clock/calendar, and an I/O expander. 2 EEPROM: A 256Kbit (32Kbyte), I C EEPROM is provided using a Microchip 24LC256. This EEPROM, IC1, is located on the bottom left of the shield, just below the chipKIT logo. 2 The 7-bit I C device address for the EEPROM is ‘1010000’. Digilent has a library for using the EEPROM. It is contained in document # DSD-0000311 (chipKIT IOShield Library.zip) which can be downloaded from the Basic I/O Shield product page at www.digilentinc.com. The EEPROM library is IOShieldEEPROM. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 6 of 13 chipKIT™ Basic I/O Shield™ Reference Manual For details on the 24LC256, see the data sheet at www.microchip.com. Temperature Sensor: A digital temperature sensor is provided using a Microchip TCN75A 2-Wire Serial 2 Temperature Sensor. The temperature sensor, IC2, is an I C device, and is located in the lower right corner of the shield. The TCN75A is rated for an accuracy of +/-1ºC and has selectable resolution from 0.5ºC down to 0.0625ºC. The 7bit device address is ‘1001000’. Digilent has a library for using the temperature sensor. It is contained in document # DSD-0000311 (chipKIT IOShield Library.zip) which can be downloaded from the Basic I/O Shield product page at www.digilentinc.com. The temperature sensor library is IOShieldTemp. The TCN75A provides an alert output that can be programmed for various functions. This output can be accessed using JP4, which is adjacent to IC2. For complete technical documentation on the TCN75A, see the data sheet available at www.microchip.com. 2.5 Potentiometer A potentiometer (pot) is provided on the shield for use as an analog signal source or analog control input. The pot is a 10K-ohm trimmer pot connected between the VCC3V3 supply and ground. The wiper of the pot is connected to analog input A0. The pot is read using the analogRead function. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 7 of 13 chipKIT™ Basic I/O Shield™ Reference Manual Appendix A: chipKIT Basic I/O Shield Pinout Table Uno32 Pin # Max32 Pin # 10 Function Description Notes 10 RES OLED reset JP4 on Uno32 39 83 DC OLED data/command select 13 13 SCLK OLED serial clock 11 11 SDIN OLED serial data in 40 84 VBAT_EN OLED VBAT enable 38 82 VDD_EN OLED VDD enable 33 77 LD1 User LED 32 76 LD2 User LED 31 75 LD3 User LED 30 74 LD4 User LED 29 73 LD5 User LED 28 72 LD6 User LED 27 71 LD7 User LED 26 70 LD8 User LED 4 4 BTN1 Pushbutton 34 78 BTN2 Pushbutton 36 80 BTN3 Pushbutton 37 81 BTN4 Pushbutton 2 2 SW1 Slide switch 7 7 SW2 Slide switch 8 8 SW3 Slide switch 35 79 SW4 Slide switch 3 3 OC1 Open drain/PWM output 5 5 OC2 Open drain/PWM output 6 6 OC3 Open drain/PWM output 9 9 OC4 Open drain/PWM output 19 59 SCL I2C clock 18 58 SDA I2C data 14 54 A0 Potentiometer Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. JP7 on Uno32/JP4 on Max32 JP8 on Uno32/jumper wire on Max32 JP6 on Uno32/jumper wire on Max32 Page 8 of 13 chipKIT™ Basic I/O Shield™ Reference Manual Appendix B: Example Driver Code The following gives an example of code that initializes the display controller and writes the contents of a memory buffer into the display. This example is written for the chipKIT Uno32 board. Symbol and Variable Declarations /* ------------------------------------------------------------ */ /* Pin definitions for access to OLED control signals on chipKIT Uno32 */ #define #define #define #define #define #define #define #define prtVddCtrl prtVbatCtrl prtDataCmd prtReset bitVddCtrl bitVbatCtrl bitDataCmd bitReset IOPORT_F IOPORT_F IOPORT_F IOPORT_G BIT_6 BIT_5 BIT_4 BIT_9 /* ------------------------------------------------------------ */ /* Symbols describing the geometry of the display. #define cbOledDispMax #define #define #define ccolOledMax crowOledMax cpagOledMax 512 //max number of bytes in display buffer 128 32 4 //number of display columns //number of display rows //number of display memory pages /* ------------------------------------------------------------ */ /* This array is the off-screen frame buffer used for rendering. ** It isn't possible to read back from the OLED display device, ** so display data is rendered into this off-screen buffer and then ** copied to the display. */ BYTE rgbOledBmp[cbOledDispMax]; PIC32 Hardware Initialization The following function initializes the PIC32 hardware for talking to the display. It initializes the SPI controller and sets the control pins to be outputs. /* ------------------------------------------------------------ */ /*** OledHostInit ** ** Parameters: ** none ** ** Return Value: ** none ** ** Errors: ** none ** ** Description: ** Perform PIC32 device initialization to prepare for use ** of the OLED display. ** This example is hard coded for the chipKIT Uno32 and ** SPI2. */ Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 9 of 13 chipKIT™ Basic I/O Shield™ Reference Manual void OledHostInit() { unsigned int tcfg; /* Initialize SPI port 2. */ SPI2CON = 0; SPI2BRG = 15; SPI2STATbits.SPIROV = 0; SPI2CONbits.CKP = 1; SPI2CONbits.MSTEN = 1; SPI2CONbits.ON = 1; //8Mhz, with 80Mhz PB clock /* Make pins RF4, RF5, and RF6 be outputs. */ PORTSetBits(IOPORT_F, bitVddCtrl|bitVbatCtrl|bitDataCmd); PORTSetPinsDigitalOut(prtDataCmd, bitDataCmd); //Data/Command# select PORTSetPinsDigitalOut(prtVddCtrl, bitVddCtrl); //VDD power control (1=off) PORTSetPinsDigitalOut(prtVbatCtrl, bitVbatCtrl); //VBAT power control (1=off) /* Make the RG9 pin be an output. On the Basic I/O Shield, this pin ** is tied to reset. */ PORTSetBits(prtReset, bitReset); PORTSetPinsDigitalOut(prtReset, bitReset); } Display Controller Initialization The following function performs initialization of the display controller on the display panel. This performs the power up sequence on the display and initializes it for a non-interleaved display buffer with the origin in the upper left corner. /* ------------------------------------------------------------ */ /*** OledDspInit ** ** Parameters: ** none ** ** Return Value: ** none ** ** Errors: ** none ** ** Description: ** Initialize the OLED display controller and turn the display on. */ void OledDspInit() { /* We're going to be sending commands, so clear the Data/Cmd bit */ PORTClearBits(prtDataCmd, bitDataCmd); /* Start by turning VDD on and wait a while for the power to come up. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 10 of 13 chipKIT™ Basic I/O Shield™ Reference Manual */ PORTClearBits(prtVddCtrl, bitVddCtrl); DelayMs(1); /* Display off command */ Spi2PutByte(0xAE); /* Bring Reset low and then high */ PORTClearBits(prtReset, bitReset); DelayMs(1); PORTSetBits(prtReset, bitReset); /* Send the Set Charge Pump and Set Pre-Charge Period commands */ Spi2PutByte(0x8D); Spi2PutByte(0x14); Spi2PutByte(0xD9); Spi2PutByte(0xF1); /* Turn on VCC and wait 100ms */ PORTClearBits(prtVbatCtrl, bitVbatCtrl); DelayMs(100); /* Send the commands to invert the display. This puts the display origin ** in the upper left corner. */ Spi2PutByte(0xA1); //remap columns Spi2PutByte(0xC8); //remap the rows /* Send the commands to select sequential COM configuration. This makes the ** display memory non-interleaved. */ Spi2PutByte(0xDA); //set COM configuration command Spi2PutByte(0x20); //sequential COM, left/right remap enabled /* Send Display On command */ Spi2PutByte(0xAF); } Display Memory Update This function copies the contents of a 512-byte buffer from PIC32 memory to the display. The display memory is organized as four pages of 128 bytes each. Each memory page corresponds to an 8-pixel-high stripe across the display. Each byte in the memory page corresponds to an 8-pixel-high column on the display. The least significant bit in a display byte is the top most pixel, and the most significant bit the bottom most pixel. The first byte in the page corresponds to the left most pixels on the display and the last byte the right most pixels. This function assumes that the display buffer to be copied is the global variable rgbOledBmp /* ------------------------------------------------------------ */ /*** OledUpdate ** ** Parameters: ** none ** ** Return Value: Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 11 of 13 chipKIT™ Basic I/O Shield™ Reference Manual ** ** ** ** ** ** ** */ none Errors: none Description: Update the OLED display with the contents of the memory buffer void OledUpdate() { int int BYTE * ipag; icol; pb; pb = rgbOledBmp; for (ipag = 0; ipag < cpagOledMax; ipag++) { PORTClearBits(prtDataCmd, bitDataCmd); /* Set the page address */ Spi2PutByte(0x22); Spi2PutByte(ipag); //Set page command //page number /* Start at the left column */ Spi2PutByte(0x00); //set low nybble of column Spi2PutByte(0x10); //set high nybble of column PORTSetBits(prtDataCmd, bitDataCmd); /* Copy this memory page of display data. */ OledPutBuffer(ccolOledMax, pb); pb += ccolOledMax; } } Low-Level SPI Functions The following functions are used to write data to the display panel using the SPI controller. /* ------------------------------------------------------------ */ /*** OledPutBuffer ** ** Parameters: ** cb - number of bytes to send/receive ** rgbTx - pointer to the buffer to send ** ** Return Value: ** none ** ** Errors: ** none ** ** Description: ** Send the bytes specified in rgbTx to the slave. */ Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 12 of 13 chipKIT™ Basic I/O Shield™ Reference Manual void OledPutBuffer(int cb, BYTE * rgbTx) { int ib; BYTE bTmp; /* Write/Read the data */ for (ib = 0; ib < cb; ib++) { /* Wait for transmitter to be ready */ while (SPI2STATbits.SPITBE == 0); /* Write the next transmit byte. */ SPI2BUF = *rgbTx++; /* Wait for receive byte. */ while (SPI2STATbits.SPIRBF == 0); bTmp = SPI2BUF; } } /* ------------------------------------------------------------ */ /*** Spi2PutByte ** ** Parameters: ** bVal - byte value to write ** ** Return Value: ** Returns byte read ** ** Errors: ** none ** ** Description: ** Write/Read a byte on SPI port 2 */ BYTE Spi2PutByte(BYTE bVal) { BYTE bRx; /* Wait for transmitter to be ready */ while (SPI2STATbits.SPITBE == 0); /* Write the next transmit byte. */ SPI2BUF = bVal; /* Wait for receive byte. */ while (SPI2STATbits.SPIRBF == 0); /* Put the received byte in the buffer. */ bRx = SPI2BUF; return bRx; } Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 13 of 13
410-216 价格&库存
很抱歉,暂时无法提供与“410-216”相匹配的价格&库存,您可以联系我们找货
