ELM 4-055
ELM 4-055
    BIVAR
ELM 4-055 数据手册
REV. E F DESCRIPTION DATE Engineering Update w/o Changes Material Update. APPROVED 02/26/04 11/10/05 M. C. M. C. L Ø.145 [Ø3.7mm] 0.032±0.005 TYP. Ø.100 [Ø2.5mm] REF. C/L 3. TOLERANCE "L" DIMENSION: 0.030 - 0.500 (1.0 - 12.7mm)±0.005(0.1mm) 0.505 - 0.750 (12.8 - 19.1mm)±0.008(0.2mm) 0.755 - 1.250 (19.2 - 31.8mm)±0.015(0.4mm) 2. MATERIAL: PVC ALLOY, 94V-0, BLACK. BIVAR MATERIAL CODE 58-BK. CYBERTECH CYBERSHIELD PVC ALLOY, CS1534WX-BLK02N BLACK. STANDARD TOLERANCE DECIMALS .X ± .1 .XX ± .01 .XXX ± .005 DESIGNED: Shane Irving 1. GENERAL SPECIFICATIONS: BIVAR EXTRUDED PRODUCT SPECIFICATION BV00-E105.  ( UNLESS OTHERWISE SPECIFIED ) CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED, SELF-RETAINING LED MOUNT DATE: 02/03/98 DATE: 12/17/02 PART NO: REVISION: ELM 4 F CAGE CODE : 32559 SHEET # 1 OF CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. 1
ELM 4-055 价格&库存
很抱歉,暂时无法提供与“ELM 4-055”相匹配的价格&库存,您可以联系我们找货
