DFR0233
DFR0233
    DFROBOT
DFR0233 数据手册
    RS485 Sensor Node V1.0 (SKU:DFR0233)   Contents        1 Introduction 2 Application 3 Specification 4 Pin Out 4.1 More details 5 Product Directive 6 Connecting Diagram 7 Sample Code Introduction This RS-485 Sensor Node module can be used in various applications such as intelligent agriculture, environment monitoring,home automation...etc. It is a Internet of things device. This RS-485 Sensor node provides 6 channel analog input and 1 SHT1x Humidity & Temperature digital input. The RS485 protocol supports up to 254 nodes at 1200m distance between each node. This allows a wide range cover for monitoring the environment. A screw free design allows easy connection of cables without scarfice reliable & stable. RS-485 standard is used effectively over long distances and in electrically noisy environments. Multiple receivers may be connected to such a network in a linear, multi-drop configuration. These characteristics make such networks useful in industrial environments and similar applications.RS485 enables the configuration of inexpensive local networks and multidrop communications links. It offers data transmission speeds of 35 Mbit/s up to 10 m and 100 kbit/s at 1200 m. RS-485 bus is the most popular communication method in industry. Compared with RS-232 bus, it is able to transfer information in further distance with lower cost. Establishing an “Internet of Things” by integrating RS-485 with Ethernet, which is the widely available in the world, in the hope that this method will coordinate all devices with low cost and high efficiency. Application      Intelligent agriculture Public safety Environment monitoring Individual health Home automation Specification              MCU:Atmega8 Input Voltage:12V Baud rate:9600 Slave address: 0x01 - 0x7F RS-485 long distance,reliable & stable conmunication Multiple connection(up to 127 modules) Press to connect cables, quick and easy 1 SHT1x Humidity and Temperature Sensor interface 6 channel analog sensor interface 8 small switches for setting slave address directly Humidity:0-100%RH(±4.5%RH) Temperature:-40-128.8 (±0.5 ) Size:82x50mm Pin Out More details Details for slave address setting Auto or manual operation:This bit is for setting the addresses of slave devices by software or hardware.   A: set slave address via software, when it is at the A side, the Bits for setting slave address will be invalid. M: set slave address via hardware, when it is at the M side means you can set the slave address via the 7 small switches.Success to set after 30 seconds. Bits for setting address of slave:0x01~0x7F,just be effective to M side Product Directive  Check all the current real-time data directive--0x21 Command: Word Head Device Address Frame Length Command Word Checksum 0x55 0xAA 0x11 0x00 0x21 SUM This command will check all data of current device.There are 10 register data totally.A register data is 16 digit,consisting of 8 high digit and 8 low digit. Return the following: Content Order 1 Register Illustration Register Data Register Range manually/automatically set address status 0x00 0x01 1 for automatic; 0 for manual 2 Humidity Measurement 0x00 0x02 0.0 to 100.0%(RH) 3 Temperature Measurement 0x00 0x03 -40.0 to 128.0( ) 4 SHT1X error status 0x00 0x04 1 for error; 0 for normal 5 Analog Measurement 1 0x00 0x05 0 to 1023 6 Analog Measurement 2 0x00 0x06 0 to 1023 7 Analog Measurement 3 0x00 0x07 0 to 1023 8 Analog Measurement 4 0x00 0x08 0 to 1023 9 Analog Measurement 5 0x00 0x09 0 to 1023 10 Analog Measurement 6 0x00 0x10 0 to 1023 Instruction Description: content value consists of 2 byte; 0.0 to 100.0 degree stand for 0 to 1000; -40.0 to 128.0 degree stand for -400 to 1280 Return Value: Word Head Device Address Frame Length Command Word 0x55 0xAA 0x11 0x14 0x21 Content H T Checksum SUM Sample: Send instruction: Word Head Device Address Frame Length Command Word Checksum 0x55 0xAA 0x11 0x00 0x21 0x55 Return instruction: Word Head Device Address Frame Length Command Word Content1 Content2 Content3 0x55 0xAA 0x11 0x14 0x21 0x00 0x00 0x00 0x00 0x00 0x00 Content4 Content5 Content6 Content7 Content8 Content9 Content10 Checksum 0x00 0x01 0x00 0x66 0x00 0x99 0x00 0x66 0x00 0x99 0x00 0x66 0x00 0x99  0x46 Set address for the model --0x55 Command: Word Head Device Address Frame Length Command Word Content Checksum 0x55 0xAA 0xAB 0x01 0x55 0x22 SUM Word Head Device Address Frame Length Command Word Content Checksum 0x55 0xAA 0xAB 0x01 0x55 0x22 SUM Return Value: Instruction Description: 0xAB is broadcast address,that is, it is shared address of all models. Send 0x55 to address 0xAB in order to set model address in the uncertain model status According to new device address,model will return 0x55 after address set successfully; In manual status,sending 0x55 can't set current device address,if the product can set device address manually and automatically.Then, the return value is 0xFE that illustrates product in manual setting address status. Return Value: Word Head Device Address Frame Length Command Word Content Checksum 0x55 0xAA 0xAB 0x01 0x55 0xFF SUM Word Head Device Address Frame Length Command Word Content Checksum 0x55 0xAA 0xAB 0x01 0x55 0x11 0x11 Sample: Send instruction: this sample is used for setting device address as 0x11. In the status of setting address manually Send instruction: Word Head Device Address Frame Length Command Word Content Checksum 0x55 0xAA 0xAB 0x01 0x55 0x11 0x11 Word Head Device Address Frame Length Command Word Content Checksum 0x55 0xAA 0xAB 0x01 0x55 0xFF 0xFF Return instruction: Connecting Diagram RS485 Sensor Node V1.0 connecting diagram Sample Code /* # The Sample code for test the data of Analogue_Test and SHT1X Module # Editor : Lisper # Date : 2013.12.9 # Ver : 1.3 # Product: Analogue_Test and SHT1X Module # SKU : DFR0233 # Description: # Read the Analog value and the data of humidity & temperature # Hardwares: 1. Arduino UNO 2. IO Expansion Shield V5 3. Analogue_Test and SHT1X Module # Interface: RS485 # Note: Connect the Analogue_Test and SHT1X Module with IO Expansion Shield V5 through RS485 Set the address of the module in manual,range from 0x02 to 0x7F,take effect after 30 seconds */ #define uint unsigned int #define uchar unsigned char #define ulong unsigned long #define addr 0x02 //set address of the device for 0x02 uchar cmd[50]; uchar receive_ACK[100]; int EN = 2; #if defined(ARDUINO) && ARDUINO >= 100 #include "Arduino.h" #define printByte(args) Serial.write(args) #define printlnByte(args) Serial.write(args),Serial.println() #else #include "WProgram.h" #define printByte(args) Serial.print(args,BYTE) #define printlnByte(args) #endif void setup() { Serial.println(args,BYTE) Serial.begin(9600); pinMode(2, OUTPUT); // TTL -> RS485 chip driver pin } void loop() { static ulong timepoint = 0; if (millis() - timepoint > 1000) { read_command(); timepoint = millis(); } if (Serial.available() > 0) data_return(); // delay(1000); } /************************Send command to Analogue_Test and SHT1X Module****** *******************/ void read_command() { int i; char sum_cmd = 0; digitalWrite(EN, HIGH); // Turn the drvier pin to HIGH -> Turn on code tran smitting mode for the RS485 interface // Turn the driver pin to LOW ace delay(10); cmd[0] = 0x55; cmd[1] = 0xaa; cmd[2] = addr; cmd[3] = 0x00; cmd[4] = 0x21; for (i = 0; i < 5; i++) { sum_cmd += cmd[i]; } -> Turn on reading mode for the RS485 interf cmd[5] = sum_cmd; for (i = 0; i < 6; i++) { printByte(cmd[i]);// command send to device #if defined(ARDUINO) && ARDUINO >= 100 Serial.flush();// complete the transmission of outgoing serial data #endif delay(10); } digitalWrite(EN, LOW); } /************Feedback data of the Analog value and humidity & temperature *** *********/\ void data_return() { digitalWrite(EN, LOW); // Turn the driver pin to LOW de for the RS485 interface delay(10); int i = 0; unsigned long timer = millis(); while (true) { if (Serial.available()) { receive_ACK[i] = Serial.read(); i++; } if (millis() - timer > 100) { break; Serial.println("Finish reading!"); -> Turn on reading mo } } print_data () ; /*************************************************************************/ // Display the original data // for(int j = 0; j < 26; j++){ // Serial.print(receive_ACK[j],HEX); // return command // Serial.print(" "); // } // Serial.println(" "); } void show_0x21_command(void) { sht1x_data(); Analog_test_data(); } /************Deal with datas from Sht1x humidity & temperature sensor******** ****/ void sht1x_data() { uint humidity; uint temperature; humidity = receive_ACK[7] * 256 + receive_ACK[8]; temperature = receive_ACK[9] * 256 + receive_ACK[10]; Serial.print("H:"); Serial.print(humidity / 10, DEC); Serial.print(" "); Serial.print("T:"); Serial.println(temperature / 10, DEC); } /********************Deal with datas from 6 Analog Sensors****************/ void Analog_test_data() { char register_addr; uint Analog_data; register_addr = 13; Serial.print("Analog Value:"); for (int n = 1; n < 7; n++) { Analog_data = receive_ACK[register_addr] * 256 + receive_ACK[register_add r + 1]; register_addr = register_addr + 2; Serial.print(Analog_data, DEC); Serial.print(" "); } Serial.println(" "); delay(1000); } /*************************** by lisper *********************************/ //print humidity and temperature void print_data () { if (checksum ()) { // if check sum is right Serial.println (); float humidity = read_uint8_t (receive_ACK, 7) / 10.0; Serial.print ("humidity="); Serial.println (humidity, 2); float temperature = (read_uint8_t (receive_ACK, 9) / 10.0); Serial.print ("temperature="); Serial.println (temperature, 2); } else { Serial.print ("\ncheck sum error! sum="); Serial.println (getsum_add (receive_ACK, 25), HEX); } } //if check sum is ok boolean checksum () { uint8_t checksum = getsum_add (receive_ACK, 25); if (checksum == receive_ACK[25]) return true; else return false; } //read 2 byte to uint16_t uint16_t read_uint8_t (uint8_t *buffer, uint8_t sub) { first byte is high byte // Big-Endian, return ((uint16_t)(buffer[sub])
DFR0233 价格&库存
很抱歉,暂时无法提供与“DFR0233”相匹配的价格&库存,您可以联系我们找货
