A2F500-DEV-KIT-2
A2F500-DEV-KIT-2
    OTHER
A2F500-DEV-KIT-2 数据手册
SmartFusion Development Kit QSG0204 Quickstart Guide Kit Contents – A2F500-DEV-KIT-2 (RoHS-compliant) Quantity Description 1 SmartFusion® Development board with A2F500M3G-FGG484ES 1 Low-cost programming stick (LCPS) 2 USB 2.0 A to mini-B Cable 1 5 V power supply with international adapters Overview The SmartFusion Development Kit offers a full-featured development board for SmartFusion customizable system-on-chip (cSoC) devices. These are the only devices that integrate an FPGA, ARM® Cortex™-M3 microcontroller, and programmable analog, offering full customization, IP protection, and ease-of-use. The device contains on-chip flash and SRAM memory, as well as additional off-chip memory on the board. The board also contains LEDs, switches, and various features for extensive analog experimentation, including voltage rail monitoring, current POT, temperature diodes, and voltage sweeping using active bipolar prescalers (ABPS). Networking interfaces include Ethernet PHY, EtherCAT, CAN, UART, and RS485. Jumpers and Switch Settings Jumpers and switches are set during the manufacturing and test of the development board. To confirm settings, review the “Running the Manufacturing Test”. Any jumper connectors not noted are open. © 2015 Microsemi Corporation. All rights reserved. SmartFusion Development Kit Quickstart Card SW9 must be off (JTAGSEL = H) in order to program the SmartFusion device. SW9 remains in the off position for Libero® software and SoftConsole programming. Factory Default Factory Default Factory Default JP1: 1–2 JP12: 1–2 JP21: 1–2 JP2: 1–2 JP13: 1–2 JP22: 2–3 JP4: 1–3; 7–9 JP14: 1–2 JP23: 1–2 JP5: 1–2; 3–4 JP15: 1–2 JP24: 1–2 JP6: 2–3 JP16: 2–3 JP27: 1–2 J7: 2–3; 6–7; 10–11; 14–15 JP17: 2–3 JP28: 1-2 JP7: 1–2 JP18: 1–2 J32: 1–2; 3–4; 5–6 JP8: 3-4; 7-8; 11-12; 15-16 JP19: 2–3 – JP11: 1-2 JP20: 1–2 – For a full description and location of all jumpers, refer to the SmartFusion Development Kit User’s Guide. Running the Manufacturing Test You can run the manufacturing test to verify the device and board connections. The manufacturing test files are available from the SmartFusion Development Kit page. Instructions on how to run the test are available in the SmartFusion Development Kit User’s Guide. Connecting the Board Follow the steps below to connect the board: 1. Connect one of the USB cables from the PC to the USB connector on the board. 2. Connect the LCPS to the PC via a USB cable. 3. Connect the LCPS to the programming header on the board. 4. Connect the 5 V power supply to the board. 2 SmartFusion Development Kit Quickstart Card SmartFusion Device JP16 JP24 DB9 Connector DB9 Connector JTAG Chain A2F500 for CAN1 Connector Configuration Header for CAN0 (JP5) DIP Switch AGLP DIP Switch RealView® Header JP28 IGLOO PLUS Header Memory Device Configuration Headers (JP17, JP19) Power Switch JTAG_SEL Switch JP11, JP12 LCPS Connector Power Jack JP7 PUB Switch 1.5 V Header (JP6) JP1, JP2 JP20 JP31 Board Reset Switch DB9 Connector for RS485 (UART1) RJ45 Connectors for 10/100 Ethernet I2C Headers (J7) 10/100 Ethernet PHY USB Connector for UART0 RJ45 Connectors for EthernetCAT Ports JP22, JP23 JP18 JP30 Push-button Switches DirectC Header (J13) POT for DACOUT/ADC Mixed Signal Current Monitor Headers (JP4) Header JP13 SPI Headers DAC0 and DAC1 J32 (JP8) Callibration POTS for ± 15 V Bipolar Outputs 3 JP14, JP15, JP21,JP27 SmartFusion Development Kit Quickstart Card Software and Licensing The SmartFusion Development Kit is supported by Libero® System-on-Chip (SoC) v10.0 or later, which includes a web install option. SoftConsole Software IDE and FlashPro are enabled by default in the web install; these software tools can be used for software design and debug. SmartFusion is also supported by Keil and IAR Systems, which can be installed separately. Refer to the SmartFusion Development Kit User’s Guide for more information. Software releases: www.microsemi.com/products/fpga-soc/design-resources/design-software/ libero-soc Keil and IAR information: www.microsemi.com/soc/products/smartfusion/ecosystem.aspx Libero SoC v10.0 requires a valid Gold, Platinum, or Standalone Libero license. If you need a new license, select FREE Libero SoC Gold license and request a new one from your Microsemi Customer Portal account. This license supports all tools for designing with the SmartFusion family and associated development kits. License updates:www.microsemi.com/products/fpga-soc/design-resources/licensing Documentation Resources For further kit information, including user's guide, tutorial, and full design examples, refer to the SmartFusion Evaluation Kit page: www.microsemi.com/products/fpga-soc/design-resources/dev-kits/smartfusion/smartfusiondevelopment-kit Technical Support and Contacts Technical support is available online at www.microsemi.com/soc/support and by email at soc_tech@microsemi.com. Microsemi SoC Sales offices, including Representatives and Distributors, are located worldwide. To find your local representative visit www.microsemi.com/soc/company/contact. 50200204-4/04.15
A2F500-DEV-KIT-2 价格&库存
很抱歉,暂时无法提供与“A2F500-DEV-KIT-2”相匹配的价格&库存,您可以联系我们找货
