XEB-AW140
XEB-AW140
    DIGIINTERNATIONAL
    HIGH SECURITY CRYPTOGRAPHIC MOD
XEB-AW140 数据手册
XPress™ Crypto Module NIST FIPS 140-2 Certified Cryptographic Module Cryptographic hardware module provides high-level security to products requiring NIST certified FIPS 140-2 encryption. Application Highlight The module supports a Serial Peripheral Interface (SPI) and can be readily embedded in a host microcontroller circuit. A USB control interface allows passwords and encryption keys to be set from a PC, ensuring physical control over access to the configuration. The circuit board is treated with a governmentapproved, tamper-evident coating to protect encryption keys from being compromised. The industrial temperature range (-40° C to +85° C) and small size (30 mm x 50 mm x 15 mm) ensure that the XPress Crypto Module can be placed in a wide variety of applications. The optional development kit allows new users to become familiar with the module and reduces product design time. Encrypted Control Box SPI Interface The XPress Crypto Module allows customers to design and build security products that can be fast-tracked for NIST FIPS 140-2 Level 2 certification. The module carries its own certification and provides data encryption in a secure hardware platform. Unencrypted Overview FIPS 140-2 Encrypted Data Operations Center XPress™ Crypto Modules on FIPS Enabled Devices Features/Benefits • NIST certified FIPS 140-2 Level 2 encryption ensures secure communication • Development kit and pre-certified modules enable fast-track FIPS 140-2 certification • Mini USB Type B port allows easy configuration management with a PC or serial terminal Related Products • AES 128-, 192- or 256-bit encryption up to 5 Mbps for user-specific applications • 2 separately password-protected user modes, Crypto Officer and User, ensure secure day-to-day operation Digi Passport® FIPS XPress™ Ethernet Bridge Support • Tunable for low latency or optimized throughput www.digi.com Specifications XPress™ Crypto Module Features Encryption Throughput 5 Mbps Certifications NIST FIPS 140-2 Level 2, NIST FIPS 197 SPI Data Interface 2 x 5 pin header, 0.1” spacing plus 3 pin support header SPI Clock Speed Maximum 7 MHz; minimum 530 kHz Command Interface API Frames Dimensions (L x W x H) 30 mm x 50 mm x 15 mm (including connectors) Voltage Range 3.1 to 3.6 VDC Power Consumption 45 mA @ 3.3 VDC (150 mW); 5 VDC from USB port of PC Operating Temperature Range -40º C to +85º C Configuration interface Mini USB Socket Type B 91001631 B2/415 You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support Digi International Worldwide HQ 877-912-3444 952-912-3444 www.digi.com Digi International France +33-1-55-61-98-98 www.digi.fr Digi International Japan +81-3-5428-0261 www.digi-intl.co.jp Digi International Singapore +65-6213-5380 Digi International China +86-21-50492199 www.digi.com.cn © 1996-2015 Digi International Inc. All rights reserved. All other trademarks are the property of their respective owners. www.digi.com
XEB-AW140
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:适用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm。
XEB-AW140 价格&库存
很抱歉,暂时无法提供与“XEB-AW140”相匹配的价格&库存,您可以联系我们找货
