PRT-10401
PRT-10401
    SPARKFUNELECTRONICS
    MCP73831 - Power Management, Battery Charger Evaluation Board
PRT-10401 数据手册
 SparkFun LiPo Charger Basic - Mini-USB PRT-10 401 ROH S        2  images are CC BY-NC-SA 3.0 3D Download: Sketchup, STL, Blender Description: If you need to charge LiPo batteries, this simple charger will do just that. It is designed to charge single-cell Li-Ion or Li-Polymer batteries. Check the datasheet below to see if it will work with your battery. The board incorporates a charging circuit, status LED, connector for your battery (JST-type used in the batteries we carry), and a mini-USB connector. Note: This version uses a mini-USB cable. We also have this charger with a microUSB connection as well. Dimensions: 29.4x10.8mm https://www.sparkfun.com/products/10401 10/9/2015
PRT-10401 价格&库存
很抱歉,暂时无法提供与“PRT-10401”相匹配的价格&库存,您可以联系我们找货
