410-239
410-239
    DIGILENT(迪芝伦)
    PMODDPOT DIGITAL POTENTIOMETER
410-239 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com PmodDPOT™ Reference Manual Revised April 8, 2016 This manual applies to the PmodDPOT rev. A Overview The Digilent PmodDPOT is a digital potentiometer allowing users to set a desired resistance anywhere from 60 to a nominal 10 kΩ. Features include:      Digital potentiometer with 8-bit resolution Select desired resistance from 60 Ω to 10 kΩ Small PCB size for flexible designs 0.9“ × 0.8” (2.3 cm × 2.0 cm) 6-pin Pmod port with SPI interface Follows Digilent Interface Specification Type 2 The PmodDPOT. 1 Functional Description The PmodDPOT utilizes Analog Devices AD5160 to digitally set a desired resistance between two terminals. With 256 possible step values, a resistance between 60 Ω and 9961 Ω can be programmed. The wiper terminal has an internal resistance of 60 Ω. 2 Interfacing with the Pmod The PmodDPOT communicates with the host board via the SPI protocol. By bringing the Chip Select (CS) line low, users may then provide 8-bits of data on the falling Serial Clock (SCLK) edge in SPI Mode 0. Once the 8 bits of data have been transferred, the rising edge of the CS line loads the data into the internal register DAC, whereupon the resistance between terminals is set. The PmodDPOT can be utilized in two different styles: a rheostat where users set a desired resistance between one outside terminal and the wiper terminal or in a voltage divider mode where the two outside terminals are powered at set voltages and a ratio of resistance is specified. DOC#: 502-239 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 2 PmodDPOT™ Reference Manual Equations for the programmable resistance values and output voltages are provided from the AD5160 datasheet below: RWB ( D)  D  RAB  RW 256 Here, RAB represents the nominal resistance of 10 kΩ and R W is the wiper terminal resistance of 60 Ω. RWA ( D)  256  D  RAB  RW 256 Here, RAB represents the nominal resistance of 10 kΩ and RW is the wiper terminal resistance of 60 Ω. VW ( D)  RWB ( D) R ( D) VA  WA VB 256 256 Here, RWA and RWB are the resistances calculated in the two above equations and VA and VB are the voltages applied at terminals A and B, respectively. Care must be taken to ensure that current flow between the wiper terminal and either terminal A or B must be limited to a pulsed ±20mA or a continuous 4.7mA so that the power dissipation capabilities of the on-board chip is not exceeded. 2.1 Pinout Description Table Pin 1 2 3 4 5 6 Signal ~CS MOSI (NC) SCLK GND VCC Description Chip Select Master-In-Slave-Out Not Connected Serial Clock Power Supply Ground Power Supply (3.3V/5V) Any external power applied to the PmodDPOT must be within 2.7V and 5.5V; however, it is recommended that Pmod is operated at 3.3V. Users must also ensure that any voltage applied to the outside terminals is between GND and VCC. 3 Physical Dimensions The pins on the pin header are spaced 100 mil apart. The PCB is 0.9 inches long on the sides parallel to the pins on the pin header and 0.8 inches long on the sides perpendicular to the pin header. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 2
410-239 价格&库存
很抱歉,暂时无法提供与“410-239”相匹配的价格&库存,您可以联系我们找货
  • 1+114.633481+14.87734
库存:87
410-239
  • 1+162.064591+21.03303
库存:3
