3328
3328
    ADAFRUIT
3328 数据手册
Adafruit MAX31865 RTD PT100 or PT1000 Amplifier Created by lady ada https://learn.adafruit.com/adafruit-max31865-rtd-pt100-amplifier Last updated on 2021-11-15 06:49:40 PM EST ©Adafruit Industries Page 1 of 30 Table of Contents Overview 3 Pinouts 6 • • • • 6 6 7 8 Power Pins: SPI Logic pins: Sensor Terminal Blocks Configuration Jumpers Assembly 9 • Prepare the header strip: • Solder! 9 10 RTD Wiring & Config 13 • • • • • • • 4-Wire RTDs 3-Wire RTDs 2-Wire RTDs How To Wire Up! 4-Wire Sensors 3-Wire Sensors 2 Wire Sensor 13 14 15 16 16 16 17 Arduino Code 17 • • • • • • • • 18 18 19 20 21 21 22 22 SPI Wiring Download Adafruit_MAX31865 library Attach PT100 or PT1000 RTD Load Demo More Accuracy Library Reference Reading Resistance Calculating Temperature Python & CircuitPython • • • • • • CircuitPython Microcontroller Wiring Python Computer Wiring CircuitPython Installation of MAX31865 Library Python Installation of MAX31865 Library CircuitPython & Python Usage Full Example Code 23 24 24 25 25 26 27 Python Docs 28 F.A.Q. 28 Downloads 29 • Files • Schematic & Fabrication Print ©Adafruit Industries 29 30 Page 2 of 30 Overview For precision temperature sensing, nothing beats a Platinum RTD. Resistance temperature detectors (RTDs) are temperature sensors that contain a resistor that changes resistance value as its temperature changes, basically a kind of thermistor. In this sensor, the resistor is actually a small strip of Platinum with a resistance of 100 or 1000 ohms at 0°C, thus the name PT100/PT1000. Compared to most NTC/PTC thermistors, the PT type of RTD is much more stable and precise (but also more expensive) PT's have been used for many years to measure temperature in laboratory and industrial processes, and have developed a reputation for accuracy (better than thermocouples), repeatability, and stability.  ©Adafruit Industries Page 3 of 30 However, to get that precision and accuracy out of your PT100x RTD you must use an amplifier that is designed to read the low resistance. Better yet, have an amplifier that can automatically adjust and compensate for the resistance of the connecting wires. If you're looking for a great RTD sensor, today is your lucky day because we have a lovely Adafruit RTD Sensor Amplifier with the MAX31865 sensor. We've carried various MAXIM thermocouple amplifiers and they're great - but thermocouples don't have the best accuracy or precision, for when the readings must be as good as can be. The MAX31865 handles all of your RTD needs, and can even compensate 3 or 4 wire RTDs for better accuracy. Connect to it with any ©Adafruit Industries Page 4 of 30 microcontroller over SPI and read out the resistance ratio from the internal ADC. We put a 0.1% resistor as a reference resistor on the breakout. We have some example code that will calcuate the temperature based on the resistance for you. • The PT100 version of the breakout uses 430Ω • The PT1000 version uses 4300Ω We even made the breakout 5V compliant, with a 3.3V regulator and level shifting, so you can use it with any Arduino or microcontroller Each order comes with one assembled RTD amplifier breakout board. Also comes with two 2-pin terminal blocks (for connecting to the RTD sensor) and pin header (to plug into any breadboard or perfboard). A required PT100 or PT1000 RTD is not included! (But we stock them in the shop). Some soldering is required to solder the headers and terminal blocks to the breakout, but it's an easy task with soldering tools. ©Adafruit Industries Page 5 of 30 Pinouts The MAX31865 is a tiny surface mount chip, and it needs a lot of other parts to make it work, so we've got it on a nice breakout board for you. You can control the chip and read data from it using the breakouts at the bottom. Let's go thru these! Power Pins: • Vin - this is the power pin. Since the chip uses 3 VDC, we have included a voltage regulator on board that will take 3-5VDC and safely convert it down. To power the board, give it the same power as the logic level of your microcontroller - e.g. for a 5V micro like Arduino, use 5V • 3Vo - this is the 3.3V output from the voltage regulator, you can grab up to 100mA from this if you like • GND - common ground for power and logic SPI Logic pins: All pins going into the breakout have level shifting circuitry to make them 3-5V logic level safe. Use whatever logic level is on Vin! • SCK - This is the SPI Clock pin, its an input to the chip • SDO - this is the Serial Data Out / Microcontroller In Sensor Out pin, for data sent from the MAX31865 to your processor ©Adafruit Industries Page 6 of 30 • SDI - this is the Serial Data In / Microcontroller Out Sensor In pin, for data sent from your processor to the MAX31865 • CS - this is the Chip Select pin, drop it low to start an SPI transaction. Its an input to the chip If you want to connect multiple MAX31865's to one microcontroller, have them share the SDI, SDO and SCK pins. Then assign each one a unique CS pin. • RDY (Ready) - is a data-ready indicator pin,  you can use this pin to speed up your reads if you are writing your own driver. Our Arduino driver doesn't use it to save a pin Sensor Terminal Blocks If you have an RTD sensor, you need to connect it somehow! the terminal block area is where you can clamp down to the sensor wires. There are four contacts, but you can use 2, 3 or 4 wire sensors. You may need to solder or jumper some pads depending on how many wires you want to use. You can also use a 3 or 4 wire sensor as a 3-wire or 2-wire sensor (just don't connect the extra wires). Check the RTD wiring page for details on how to connect the sensor you've got! ©Adafruit Industries Page 7 of 30 Configuration Jumpers By default the sensor is wired up for 4-wire RTD usage but can be set up for 2 or 3 wire very easily. For 4-wire usage, do nothing with the jumpers! For 3-wire usage. Solder closed the jumper labeled 2/3 Wire and cut the wire connecting the left side of the 2-way jumper right above Rref. Then solder closed the right side labeled 3 For 2-wire usage, solder closed the two triangular jumpers below the terminal blocks (or put short wire jumpers between the two terminal blocks on either side (essentially jumpering the two right side terminal holes together, and same for left side) Check the RTD wiring page for details on how to connect the sensor you've got! ©Adafruit Industries Page 8 of 30 Assembly Prepare the header strip:   Cut the strip to length if necessary. It will be easier to solder if you insert it into a breadboard - long pins down   ©Adafruit Industries Page 9 of 30 Solder!   Be sure to solder all pins for reliable electrical contact. (For tips on soldering, be sure to check out our Guide to Excellent Soldering (https://adafru.it/aTk)).   ©Adafruit Industries Page 10 of 30 Next we will solder in the two 3.5mm terminal blocks used to connect power & the motor to the breakout board.    Make sure the open parts of the terminals face outwards so you can easily connect wires   To make it easier to keep these in place, you can use some tape to hold down the two header pieces. Tacky clay also works, whatever you've got handy!   ©Adafruit Industries Page 11 of 30 Solder in both pins of each terminal block. You can remove the tape when done. ©Adafruit Industries Page 12 of 30 OK You're done!  RTD Wiring & Config RTDs are really very simple devices: just a small strip of Platinum that measures 100Ω or 1000Ω exactly at 0°C. Bonded to the PT100/PT1000 are 2, 3 or 4 wires. 4-Wire RTDs We'll explain the 4-wire version since that's the most complex. Normally if you want to measure a resistor you just connect your multimeter to each side of the resistor. The multimeter puts a small current through the resistor and measures the voltage generated across it (remember V = I * R). This works great for just about all resistors. However, for very precise readings of low-resistance resistors, you also have to account for the wires connected! For basic resistors, they are only good to 5% anyways so we don't mind the resistance of the wires. For RTDs, the wires, especially the 1 meter long ones, are 1, 2 maybe even 4Ω of extra resistance! That can add up to half or even a full °C! No good, we want to make sure that resistance is not included in our measurement ©Adafruit Industries Page 13 of 30 Thus, the 4-wire RTD. Each side of the RTD has two wires attached. Each wire is maybe 1Ω of resistance. When connected to the amplifier, the smart amp will measure the voltage across the RTD and also across the wire pairs. For example, here's the approximate resistances of a 4-Wire PT100 RTD at 0°C (for a PT1000, the middle resistance would be (1002Ω rather than 102Ω) (Remember that the middle resistance - 102 or 1002 Ω - will vary with temperature, but the 2Ω wires will not) When the amp measures this sensor, it will measure the resistance between one set of red and blue wires. It will then measure the resistances between the red wires and blue wires. Then divide those resistances by half - since there's two wires and we just want the resistance of one wire. The final result is 102 - 1 - 1 = 100Ω 3-Wire RTDs These are very similar to the 4-wire type but there is only one 'pair' of connected wires. The reasoning for this is that the wires for the RTD are all pretty much the same gauge and length, so rather than having two pairs, the amplifier will just read one pair and use that resistance as the same for both wires. ©Adafruit Industries Page 14 of 30 2-Wire RTDs These are as simple as it gets, only one wire per side. You may need to calibrate the sensor by putting it in an ice bath to get the resistance at 0°C (say 102Ω) and then subtracting 100Ω to figure out the collective resistance of the connection wires! ©Adafruit Industries Page 15 of 30 How To Wire Up! 4-Wire Sensors Connect the four wires to each of the pads. Use a multimeter to determine which wires connect together directly (2 ohms or so between them) and which connect through the RTD. Chances are the wires that connect together are the same color. The two pairs connect so that the ones that are connected together go into the two matching terminal blocks on left or right. It doesn't matter which of the matched pair is on the outside or inside. It doesn't matter which of the match pairs are on the left or right. Do not solder closed any jumpers or cut any jumpers. Use as is! 3-Wire Sensors Connect the three wires to the three right-most contacts. Use a multimeter to determine which wires connect together directly (2 ohms or so between them) and which connect through the RTD. Chances are the wires that connect together are the same color. The two wires that are connected together should go in the right-most blocks (labeled F+ and RTD+). It doesn't matter which of the matched pair is on the outside or inside. The third wire that is on the other side of the RTD connects to the left (marked F- or RTD-). It doesn't matter which slot it's in! ©Adafruit Industries Page 16 of 30 You will have to cut the thin trace in between the 2-way jumper on the right side of the board, and then solder closed the blob on the right side. Then next to the terminal block on the left, solder closed that jumper as well. Alternatively you can put a piece of wire into the terminal blocks to 'short' them 2 Wire Sensor This is the easiest wiring, you can just use either terminal block slot on the sides for each wire. Then either solder closed the jumpers next to the RTD terminal block or put little wires in the right and left terminal blocks to short them together. Arduino Code You can easily wire this breakout to any microcontroller, we'll be using an Arduino. For another kind of microcontroller, as long as you have 4 available pins it is possible to 'bit-bang SPI' or you can use hardware SPI if you like. Just check out the library, then port the code. ©Adafruit Industries Page 17 of 30 SPI Wiring Since this is a SPI-capable sensor, we can use hardware or 'software' SPI. To make wiring identical on all Arduinos, we'll begin with 'software' SPI. The following pins should be used: • Connect Vin to the power supply, 3V or 5V is fine. Use the same voltage that the microcontroller logic is based off of. For most Arduinos, that is 5V • Connect GND to common power/data ground • Connect the CLK pin to Digital #13 but any pin can be used later • Connect the SDO pin to Digital #12 but any pin can be used later • Connect the SDI pin to Digital #11 but any pin can be used later • Connect the CS pin Digital #10 but any pin can be used later Later on, once we get it working, we can adjust the library to use hardware SPI if you desire, or change the pins to other Download Adafruit_MAX31865 library To begin reading sensor data, you will need to the Adafruit MAX31865 library from the Arduino library manager. Open up the Arduino library manager: ©Adafruit Industries Page 18 of 30 Search for the Adafruit MAX31865 library and install it We also have a great tutorial on Arduino library installation at: http://learn.adafruit.com/adafruit-all-about-arduino-libraries-install-use (https:// adafru.it/aYM) Attach PT100 or PT1000 RTD You'll need to attach an RTD, for this demo we'll be using a 3-wire 1 meter long one but you can adjust the demo if you have a 2 or 4 wire. Check the RTD wiring page for the jumpers and wiring requirements! ©Adafruit Industries Page 19 of 30 Load Demo Open up File->Examples->Adafruit_MAX31865->max31865 and upload to your Arduino wired up to the sensor. Adjust the  max.begin(MAX31865_3WIRE) line if necessary. Upload to your Arduino and open up the serial console at 115200 baud to see a print out of the sensors data. The MAX31865 doesn't actually return the resistance it measures. Instead it returns the ratio between the resistance measured and the Rref reference resistor. • For the PT100 version of the breakout, this is a 430 ohm 0.1% resistor (marking is 4300 !!!) • For the PT1000 version of the breakout, this is a 4300 ohm 0.1% resistor (marking is 4301 !!!) You can use that ratio to calculate the resistance and then determine the temperature ©Adafruit Industries Page 20 of 30 More Accuracy Our library is efficient and small and uses an algorithm to calculate temperature. While this works very well, it isn't as accurate as it could be. Check out this ITS-90 conforming library from DrHaney that uses a lookup table for better accuracy! (https:/ /adafru.it/Cbo) Library Reference You can start out by creating a MAX31865 object with either software SPI (where all four pins can be any I/O) using // Use software SPI: CS, DI, DO, CLK Adafruit_MAX31865 max = Adafruit_MAX31865(10, 11, 12, 13); Or you can use hardware SPI. With hardware SPI you must use the hardware SPI pins for your Arduino - and each arduino type has different pins! Check the SPI reference to see what pins to use. (https://adafru.it/d5h) In this case, you can use any CS pin, but the other three pins are fixed // use hardware SPI, just pass in the CS pin Adafruit_MAX31865 max = Adafruit_MAX31865(10); ©Adafruit Industries Page 21 of 30 Once started, you can initialize the sensor with one of the following, depending on what kind of RTD you've got connected! max.begin(MAX31865_2WIRE) max.begin(MAX31865_3WIRE) max.begin(MAX31865_4WIRE) Reading Resistance If you want to know the actual resistance (not temperature) you can do that fairly easily. You can read ratio from the MAX31865 with max.readRTD() This will give you the raw 16-bit unsigned value where 0xFFFF is '1.0 ratio'. Chances are you want to convert it to the resistance. We recommend this code: Serial.print("RTD value: "); Serial.println(rtd); float ratio = rtd; ratio /= 32768; Serial.print("Ratio = "); Serial.println(ratio,8); Serial.print("Resistance = "); Serial.println(RREF*ratio,8); You'll need to define RREF - in this case its 430.0 for PT100 and 4300.0 for PT1000 Calculating Temperature Once you have the resistance you can look up in an RTD table or use a calculation to do a best-fit approximation. We use the example from this app note:  http:// www.analog.com/media/en/technical-documentation/application-notes/AN709_0.pdf ( https://adafru.it/swC) It's fast and seems to work very well! We have a one-stop function that does everything for you, just call: max.temperature(100, RREF) Where the first argument is the resistance of the RTD at 0°C (for PT100 that's 100) and the second argument is the value of the reference resistor. This function returns the tempreature in °C ©Adafruit Industries Page 22 of 30 Faults The MAX31865 has a wide-ranging fault mechanism that can alert you via pin or function when something is amiss. Don't forget to test this functionality before relying on it! You can read faults with max.readFault() Which will return a uint8_t type with bits set for each of 6 different fault types. You can test for each one with this set of code: // Check and print any faults uint8_t fault = max.readFault(); if (fault) { Serial.print("Fault 0x"); Serial.println(fault, HEX); if (fault & MAX31865_FAULT_HIGHTHRESH) { Serial.println("RTD High Threshold"); } if (fault & MAX31865_FAULT_LOWTHRESH) { Serial.println("RTD Low Threshold"); } if (fault & MAX31865_FAULT_REFINLOW) { Serial.println("REFIN- > 0.85 x Bias"); } if (fault & MAX31865_FAULT_REFINHIGH) { Serial.println("REFIN- < 0.85 x Bias - FORCE- open"); } if (fault & MAX31865_FAULT_RTDINLOW) { Serial.println("RTDIN- < 0.85 x Bias - FORCE- open"); } if (fault & MAX31865_FAULT_OVUV) { Serial.println("Under/Over voltage"); } max.clearFault(); } In particular, the last four are ones that indicate a hardware failure. The first two are threshold faults, we don't have code for setting those thresholds at this time. Python & CircuitPython It's easy to use the MAX31865 sensor with Python or CircuitPython, and the Adafruit CircuitPython MAX31865 (https://adafru.it/Cbp) module.  This module allows you to easily write Python code that reads the range from the sensor. ©Adafruit Industries Page 23 of 30 You can use this sensor with any CircuitPython microcontroller board or with a computer that has GPIO and Python thanks to Adafruit_Blinka, our CircuitPython-forPython compatibility library (https://adafru.it/BSN). CircuitPython Microcontroller Wiring First wire up a MAX31865 to your board exactly as shown on the previous pages for Arduino.   Here's an example of wiring a Feather M0 to the sensor with a SPI connection: • Board 3V to sensor VIN • Board GND to sensor GND • Board SCK to sensor CLK • Board MOSI to sensor SDI • Board MISO to sensor SDO • Board D5 to sensor CS (or any other digital I/O pin) Python Computer Wiring Since there's dozens of Linux computers/boards you can use we will show wiring for Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to see whether your platform is supported (https://adafru.it/BSN).  Here's the Raspberry Pi wired with SPI: • Pi 3V3 to sensor VIN • Pi GND to sensor GND • Pi MOSI to sensor SDI • Pi MISO to sensor SDO • Pi SCLK to sensor CLK • Pi GPIO5 to sensor CS (or use any other free GPIO pin) ©Adafruit Industries Page 24 of 30 CircuitPython Installation of MAX31865 Library Next you'll need to install the Adafruit CircuitPython MAX31865 (https://adafru.it/Cbp) l ibrary on your CircuitPython board. First make sure you are running the latest version of Adafruit CircuitPython (https:// adafru.it/tBa) for your board. Next you'll need to install the necessary libraries to use the hardware--carefully follow the steps to find and install these libraries from Adafruit's CircuitPython library bundle  (https://adafru.it/zdx).  For example the Circuit Playground Express guide has a great page on how to install the library bundle (https://adafru.it/Bf2) for both express and non-express boards. Remember for non-express boards like the Trinket M0, Gemma M0, and Feather/ Metro M0 basic you'll need to manually install the necessary libraries from the bundle: • adafruit_max31865.mpy • adafruit_bus_device Before continuing make sure your board's lib folder or root filesystem has the adafrui t_max31865.mpy, and adafruit_bus_device files and folders copied over. Next connect to the board's serial REPL (https://adafru.it/Awz) so you are at the CircuitPython >>> prompt. Python Installation of MAX31865 Library You'll need to install the Adafruit_Blinka library that provides the CircuitPython support in Python. This may also require enabling I2C on your platform and verifying you are running Python 3. Since each platform is a little different, and Linux changes often, please visit the CircuitPython on Linux guide to get your computer ready (https ://adafru.it/BSN)! Once that's done, from your command line run the following command: • sudo pip3 install adafruit-circuitpython-max31865 ©Adafruit Industries Page 25 of 30 If your default Python is version 3 you may need to run 'pip' instead. Just make sure you aren't trying to use CircuitPython on Python 2.x, it isn't supported! CircuitPython & Python Usage To demonstrate the usage of the sensor we'll initialize it and read the range and more from the board's Python REPL. Run the following code to import the necessary modules and initialize the SPI connection with the sensor: import board import digitalio import adafruit_max31865 spi = board.SPI() cs = digitalio.DigitalInOut(board.D5) # Chip select of the MAX31865 board. sensor = adafruit_max31865.MAX31865(spi, cs) Notice you need to explicitly define the chip select digital I/O pin--be sure to use the same pin as your wiring (D5 if following this example exactly). By default the MAX31865 class assumes a 2 wire sensor, however you can change this by setting the wires keyword argument in the initializer.  Set this to the number of wires in your sensor (2, 3, or 4).  For example to create a 3 wire sensor: import board import digitalio import adafruit_max31865 spi = board.SPI() cs = digitalio.DigitalInOut(board.D5) # Chip select of the MAX31865 board. sensor = adafruit_max31865.MAX31865(spi, cs, wires=3) Be sure to set wires to the appropriate value for your sensor! In addition you can specify the nominal resistance and reference resistance of the RTD with these optional keyword arguments of the initializer: • rtd_nominal - This is the resistance value in Ohms of the RTD at a nominal value (typically 0 degrees Celsius).  This defaults to 100 for a PT100 sensor.  For a PT1000 change it to 1000 Ohms. • ref_resistor - The reference resistor value in Ohms.  The default is 430 Ohms which matches the PT100 version of the breakout.  For a PT1000 breakout change this to 4300 Ohms. ©Adafruit Industries Page 26 of 30 For example here's how to create a 2-wire PT1000 sensor instance with 1000 Ohm nominal resistance and 4300 Ohm reference resistance: import board import digitalio import adafruit_max31865 spi = board.SPI() cs = digitalio.DigitalInOut(board.D5) # Chip select of the MAX31865 board. sensor = adafruit_max31865.MAX31865(spi, cs, rtd_nominal=1000.0, ref_resistor=4300.0) Now you're ready to read values from the sensor using any of these properties: • temperature - The temperature measured by the sensor in degrees Celsius. • resistance - The resistance of the RTD in Ohms. print('Temperature: {0:0.3f}C'.format(sensor.temperature)) print('Resistance: {0:0.3f} Ohms'.format(sensor.resistance)) See the simpletest.py example (https://adafru.it/Cbr) for a complete demo of printing the range every second.  Save this as code.py on the board and examine the REPL output to see the temperature printed every second. That's all there is to using the MAX31865 with CircuitPython! Full Example Code # SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries # SPDX-License-Identifier: MIT # Simple demo of the MAX31865 thermocouple amplifier. # Will print the temperature every second. import time import board import digitalio import adafruit_max31865 # Create sensor object, communicating over the board's default SPI bus spi = board.SPI() cs = digitalio.DigitalInOut(board.D5) # Chip select of the MAX31865 board. sensor = adafruit_max31865.MAX31865(spi, cs) # Note you can optionally provide the thermocouple RTD nominal, the reference # resistance, and the number of wires for the sensor (2 the default, 3, or 4) # with keyword args: # sensor = adafruit_max31865.MAX31865(spi, cs, rtd_nominal=100, ref_resistor=430.0, wires=2) ©Adafruit Industries Page 27 of 30 # Main loop to print the temperature every second. while True: # Read temperature. temp = sensor.temperature # Print the value. print("Temperature: {0:0.3f}C".format(temp)) # Delay for a second. time.sleep(1.0) Python Docs Python Docs (https://adafru.it/Cbs) F.A.Q. Do I have a 100ohm or 1kohm RTD breakout? While the MAX31865 can support either 100ohm or 1kohm RTDs, the Adafruit breakout comes in two versions with different reference resistors specific to each type of RTD. • PID 3328 (https://adafru.it/Scm) = 430Ω for use with 100ohm RTDs. • PID 3648 (https://adafru.it/Scn) = 4.3kΩ for use with 1kohm RTDs. If you are unsure which one you have, you can check the value of the reference resistor by reading the label. See below for details. Also, be sure to change the value for RREF in your code to match. If marking is 4300 or 431 its PT100 If marking is 4301 or 432 its PT1000 ©Adafruit Industries Page 28 of 30 Downloads Files • Fritzing object in Adafruit Fritzing library (https://adafru.it/c7M) • EagleCAD PCB files on GitHub (https://adafru.it/swF) • Library on GitHub (https://adafru.it/swA) • MAX31865 Datasheet (https://adafru.it/sxa) • A "lookup table" based library is bigger but more precise since it doesn't do an approximation of the temperature - for advanced users! (https://adafru.it/uBo) ©Adafruit Industries Page 29 of 30 Schematic & Fabrication Print ©Adafruit Industries Page 30 of 30
很抱歉,暂时无法提供与“3328”相匹配的价格&库存,您可以联系我们找货
  • 1+142.969321+18.49527
库存:76
3328
    • 1+278.69400
    • 200+111.20760
