PIC-MAXI-WEB
PIC-MAXI-WEB
    OLIMEX
PIC-MAXI-WEB 数据手册
PIC-MAXI-WEB development board Users Manual Rev.B, April 2009 Copyright(c) 2009, OLIMEX Ltd, All rights reserved Page 1 INTRODUCTION: This board allows you to easily develop Ethernet connectivity applications. It has everything you normally would need for such applications: power relays which you can command through web interface, LCD display which will display messages you fill in web forms, analogue inputs for connection to sensors, digital optoisolated inputs, trimmer potentiometer, temperature sensor, Ethernet connector. With this board you can easily automate your home and then control and monitor it from any point in the world via Internet. An extension connector is available so you can connect custom made hardware to the board. The PIC18F97J60 has 128KB Flash program memory and there is external 1Mbit (128KB) flash memory for data storage. The on board DC/DC converter makes this board very tolerant to the external power supply which could be in 9-25V DC or 7-18V AC range. The bridge rectifier on the input allows AC and DC adapters to be used and makes power supply polarity problems go away. BOARD FEATURES: PIC18F97J60 microcontroller with embedded Ethernet MAC and PHY and 128KB Flash programming space 1Mbit on board serial flash for web pages storage ICSP/ICD connector for programming and debugging with PICICD2 and PIC-ICD2-POCKET. Temperature sensor Trimmer potentiometer connected to analogue input Two relays 10A/250VAC Four optoisolated digital inputs Twelve analogue inputs on terminal block Two buttons LCD16x2 with backlight RS232 interface Ethernet interface Complete web server and TCP-IP stack support as per Microchip's open source TCP-IP stack Terminal block for power supply works with 9-25 VDC power supply Extension header to connect to other boards Dimensions 120x108 mm (4.72x4.25") ELECTROSTATIC WARNING: The PIC-MAXI-WEB board is shipped in protective anti-static packaging. The board must not be subject to high electrostatic potentials. General practice for working with static sensitive devices should be applied when working with this board. BOARD USE REQUIREMENTS: Cables: Depends on the used programming/debugging tool. It could be 1.8 meter USB A-B cable to connect PIC-ICD2-POCKET or PIC-ICD2 to USB host on PC or RS232 cable for PIC-ICD2-TINY and PIC-ICD2. You will Page 2 need a serial cable if not for programming, than for configuring the board. You will also need a LAN cable. Hardware: Programmer/Debugger –Olimex programmers are applicable, for example PIC-ICD2, PIC-ICD2-POCKET, PIC-ICD2-TINY or other compatible programming/debugging tool. !!!Warning!!! When you want to program this microcontroller with PICICD2, PIC-ICD2-POCKET or PIC-ICD2-TINY, before connecting the programmer to your target board, you should first connect the programmer to your computer and open MPLAB. There, first from menu Configure – Select Device – choose the microcontroller you are about to program, then from menu Programmer – Select Programmer – choose MPLAB ICD 2, wait while MPLAB is downloading operation system, and after ICD2 is connected – check in menu Programmer – Settings – Power – there is option – Power target circuit from MPLAB ICD 2 – this option should be forbidden, you could not select it. Now it is safe to connect the programmer to your target board. Software: PIC-WEB is tested with MPLAB IDE v.7.62 + MPLAB C18 C compiler. It is possible that the stack might not function properly if used with later versions of MPLAB IDE. You will also need a terminal program configured at 19 200 bps, 8N1 and no flow control. PROCESSOR FEATURES: PIC-MAXI-WEB board use MCU PIC18F97J60 from Microchip with these features: - IEEE 802.3 compatible Ethernet Controller - Integrated MAC and 10Base-T PHY - 8-Kbyte Transmit/Receive Packet Buffer SRAM - Supports One 10Base-T Port - Programmable Automatic Retransmit on Collision - Programmable Padding and CRC Generation - Programmable Automatic Rejection of Erroneous Packets - Activity Outputs for 2 LED Indicators - Buffer: o Configurable transmit/receive buffer size o Hardware-managed circular receive FIFO o Byte-wide random and sequential access o Internal DMA for fast memory copying o Hardware assisted checksum calculation for various protocols - MAC: o Support for Unicast, Multicast and Broadcast packets o Programmable Pattern Match of up to 64 bytes within packet at user-defined offset o Programmable wake-up on multiple packet formats - PHY: Page 3 - - - - o Wave shaping output filter Selectable System Clock derived from Single 25 MHz External Source: o 2.778 to 41.667 MHz Internal 31 kHz Oscillator Secondary Oscillator using Timer1 @ 32 kHz Fail-Safe Clock Monitor: o Allows for safe shutdown if oscillator stops Two-Speed Oscillator Start-up Address Capability of up to 2 Mbytes for External Memory Bus 8-Bit or 16-Bit Interface 2-Bit, 16-Bit and 20-Bit Addressing modes High-Current Sink/Source: 25 mA/25 mA on PORTB and PORTC Five Timer modules (Timer0 to Timer4) Four External Interrupt pins Two Capture/Compare/PWM (CCP) modules Three Enhanced Capture/Compare/PWM (ECCP) modules: o One, two or four PWM outputs o Selectable polarity o Programmable dead time o Auto-shutdown and auto-restart Up to Two Master Synchronous Serial Port (MSSP) modules supporting SPI (all 4 modes) and I2C™ Master and Slave modes Up to Two Enhanced USART modules: o Supports RS-485, RS-232 and LIN 1.2 o Auto-wake-up on Start bit o Auto-Baud Detect (ABD) 10-Bit, Up to 16-Channel Analog-to-Digital Converter module (A/D): o Auto-acquisition capability o Conversion available during Sleep Dual Analog Comparators with Input Multiplexing Parallel Slave Port (PSP) module (100-pin devices only) 5.5V Tolerant Inputs (digital-only pins) Low-Power, High-Speed CMOS Flash Technology: o Self-reprogrammable under software control C compiler Optimized Architecture for Reentrant Code Power Management Features: o Run: CPU on, peripherals on o Idle: CPU off, peripherals on o Sleep: CPU off, peripherals off Priority Levels for Interrupts 8 x 8 Single-Cycle Hardware Multiplier Extended Watchdog Timer (WDT): o Programmable period from 4 ms to 134s Single-Supply 3.3V In-Circuit Serial Programming™ (ICSP™) via Two Pins In-Circuit Debug (ICD) with 3 Breakpoints via Two Pins Operating Voltage Range of 2.35V to 3.6V (3.1V to 3.6V using Ethernet module) On-Chip 2.5V Regulator Page 4 BLOCK DIAGRAM: Page 5 MEMORY MAP: Page 6 Page 7 SCHEMATIC: R11 R16 0.68 R22 0.68 R12 +5V U1 MC34063AP1/ACN_MBR R28 3k/1% C11 1000uF/6.3V/8mm L2 D1 CL150uH/SW68 5 FB U3 MC34063AP1/ACN_MBR C23 R26 3.0k/1% PWR_LED RED 1000uF/6.3V/8mm 470pF 470pF 2 3.3V_E 1 2 1 7 8 VSS SC SE + C47 TC 1N5819 + + 5 FB 3 C24 220u/25V IS DC 6 L3 CL150uH/SW68 4 C46 2 5V_E 1 2 D7 SC SE 1N5819 TC VSS IS DC + 3 C48 220u/25V VCC PWR-2 1 7 8 6 B-DIL3 3.3V 0.68 0.68 VCC G1 4 PWR-1 R27 1k/1% R15 330 R29 1.8k/1% R57 0 3.3V U2 5 6 7 8 69 68 67 57 B2 EXT-26 EXT-25 B1 D_IN3 EXT-24 PGC PGD RB0/INT0/FLT0 RB1/INT1 RB2/INT2 RB3/INT3/ECCP2(1)/P2A(1) RB4/KBI0 RB5/KBI1 RB6/KBI2/PGC RB7/KBI3/PGD C14 33pF 29 3.3V R36 1M Q1 25MHz R44 T PINT PIN+ 73 74 T POUT T POUT + 77 78 R42 2k/1% ENVREG 63 64 C20 33pF RST 3.3V OSC1/CLKI OSC2/CLKO TPOUTTPOUT+ NC RBIAS 13 C39 RE0/AD8/#RD/P2D RE1/AD9/#WR/P2C RE2/AD10/#CS/P2B RE3/AD11/P3C(2) RE4/AD12/P3B(2) RE5/AD13/P1C(2) RE6/AD14/P1B(2) RE7/AD15/ECCP2(1)/P2A(1) TPINTPIN+ 9 80 270/1% RD0/AD0/PSP0 RD1/AD1/PSP1 RD2/AD2/PSP2 RD3/AD3/PSP3 RD4/AD4/PSP4/SDO2 RD5/AD5/PSP5/SDI2/SDA2 RD6/AD6/PSP6/SCK2/SCL2 RD7/AD7/PSP7/#SS2 RF0/AN5 RF1/AN6/C2OUT RF2/AN7/C1OUT RF3/AN8 RF4/AN9 RF5/AN10/CVREF RF6/AN11 RF7/#SS1 #MCLR 16 VDDCORE/VCAP 100nF C40 17 37 59 62 86 100nF C28 C29 C32 C33 C34 100nF 100nF 100nF 100nF 100nF VDD VDD1 VDD2 VDD3 VDD4 15 36 40 60 65 85 VSS VSS1 VSS2 VSS3 VSS4 VSS5 76 75 3.3V C35 C36 100nF 100nF 79 72 C37 VSSTX VSSRX VSSPLL C49 47uF/6.3V KG AY KY T PIN+ 7 6 T PIN8 LEDB R5 49.9/1% R6 49.9/1% R8 #SS2 LAN 1:1 TD+ TCT TDAG KG AY KY RD+ RCT RD- 75 75 GREEN YELLOW 1:1 75 75 1nF/2kV 1 4 5 2 IN1-1 180 2 R37 0 R60 4.7k R30 T3 BC846 LIGHT_LCD 7 8 9 10 11 12 13 14 VO RS R/W E 4 5 6 A DB0 DB1 DB2 DB3 DB4 DB5 DB6 DB7 1.5K R31 10K EXT-16 K _RS R/W E NA NA NA NA NA NA 1 SCK 2 SI 3 CS 4 NA R1 100k #SS1 EXT-10 EXT-9 EXT-8 EXT-7 EXT-6 EXT-5 EXT-4 EXT-3 EXT-1 EXT-2 C41 C42 C43 NA NA NA C44 1 LED2 red LD1 LD0 RED yellow R53 330 R54 330 R55 330 6 IN3-1 D4 1N4148 + C50 AN_TR 10K 10uF/6.3V AIN2 330 BUT1 C1+ C1V- 14 7 13 8 T1OUT T2OUT R1IN R2IN 4 D_IN1 330 3 T1IN T2IN R1OUT R2OUT 1 C16 3 100n 4 C17 5 100n 11 10 T XD 12 9 RXD U4PWR 16 VCC 3.3V C15 100n +5V RAS-05-15 REL1 LED5 green R43 10K D8 1N4148 1 4 2 3 R50 D_IN2 330 R33 OUT 1 OUT1-3 R35 1k R18 Q3 BC817 1k 10K LED4 red R40 OUT1-1 +5V 1 4 2 3 R51 D_IN3 330 OPT4 330 D5 1N4148 R39 RAS-05-15 REL2 LED6 green 10K D6 1N4148 1 4 2 3 R52 330 D_IN4 R41 10K OUT 2 R13 10K B1 330 BUT2 330 C51 C30 C12 10uF/6.3V 100n 100n Q4 BC817 R10 10K PIC-MAXI-WEB R20 10K R14 R2 1k 3.3V R25 R21 B2 RST 330 C31 100n Page 8 RST OUT2-3 R9 1k REL2 H11A817SMD 3.3V OUT1-2 R47 10K H11A817SMD 100nF 3.3V + AIN3 R48 OPT3 330 IN3-2 R23 10K 330 C2 100n V+ 15GND H11A817SMD LED3 red R34 IN4-2 R19 5 C2- C1 TH1 TERMISTOR 6 C2+ 1 2 3 4 5 6 7 8 9 RED OPT2 D3 1N4148 IN4-1 3.3V /WP/ U4 ST3232 2 C18 100n C19 100n RS232 DB9_female NA LD2 OPT1 330 CON62.54-0-D 3.3V VCC /CS/ E R/W RS X5-1 X5-2 X6-1 X6-2 X6-3 2 R32 IN2-1 RST PGD PGC /RESET/ 7 REL1 3.3V 1 2 3 4 5 6 GND EXT-11 49 50 66 61 47 48 58 39 M ISO 8 SO SCK LIGHT _LCD E R/W RS 99 100 1 2 27 26 25 24 MOSI H11A817SMD ICSP 3.3V #SS2 16 AT45DB011 D_IN2 LIGHT _LCD OUT 2 OUT 1 D2 1N4148 IN1-2 3 7 8 6 15 U5 C3 C4 C5 C6 C7 C8 C13 EXT-15 EXT-14 EXT-13 EXT-12 330 IN2-2 3 R59 4.7k DB0 DB1 DB2 DB3 DB4 DB5 DB6 DB7 X1-2 X2-1 X2-2 X3-1 X3-2 X4-1 X4-2 #SS1 71 70 52 51 14 11 10 38 100nF 1 R49 opt DB[0..7],RS,R/W,E,LIGHT _LCD 12 28 23 22 21 20 19 18 LED1 red R17 RJLD-043TC C10 R58 3 10k DB0 DB1 DB2 DB3 DB4 DB5 DB6 DB7 4 3 98 97 96 95 94 93 C25 100nF RJ45 SIDE 3 #SS1/#SS2 EXT-23 EXT-22 EXT-21 EXT-20 EXT-19 EXT-18 EXT-17 R38 opt CONT RAST 3.3V 49.9/1% T POUT + 1 T POUT - 2 LEDA AG R24 10K 92 91 90 89 88 87 84 83 +5V R3 R4 CS 15pF 100nF 49.9/1% 2 15pF Q2 PIC18F97J60 C9 ferrite bead R7 AVSS 100nF C27 32768/6pF C26 D_IN1 SCK MISO 3.3V MOSI T XD RXD GN D 3.3V L1 180 AVDD 31 C38 + 3.3V 3.3V 30 AVDD RJ0/ALE RJ1/#OE RJ2/#WRL RJ3/#WRH RJ4/BA0 RJ5/#CE RJ6/#LB RJ7/#UB VDDPLL 82 100nF R56 270 RH0/A16 RH1/A17 RH2/A18 RH3/A19 RH4/AN12/P3C(2) RH5/AN13/P3B(2) RH6/AN14/P1C(2) RH7/AN15/P1B(2) VDDTX VDDRX 81 3.3V RG0/ECCP3/P3A RG1/TX2/CK2 RG2/RX2/DT2 RG3/CCP4/P3D RG4/CCP5/P1D RG5 RG6 RG7 44 43 53 54 55 56 45 46 3.3V NA RC0/T1OSO/T13CKI RC1/T1OSI/ECCP2(1)/P2A(1) RC2/ECCP1/P1A RC3/SCK1/SCL1 RC4/SDI1/SDA1 RC5/SDO1 RC6/TX1/CK1 RC7/RX1/DT1 VDD R46 100k C45 RA0/LEDA/AN0 RA1/LEDB/AN1 RA2/AN2/VREFRA3/AN3/VREF+ RA4/T0CKI RA5/AN4 1 R45 100k X1-1 35 34 33 32 42 41 LEDA LEDB AIN2 AIN3 D_IN4 AIN4 VSS 3.3V Rev. B COPYRIGHT(C) 2009, Olimex Ltd. http://www.olimex.com/dev OUT2-2 OUT2-1 BOARD LAYOUT: POWER SUPPLY CIRCUIT: PIC-MAXI-WEB can take power only from power connector PWR, where (912) VDC or (6-9) VAC external voltage source has to be applied. The board power consumption is about 200 mA with all peripherals and MCU running at full speed, relays and LEDs on and working Ethernet connection. RESET CIRCUIT: PIC-MAXI-WEB reset circuit is made with RC group R20 – 10k and C31 – 100nF. Serial resistor R21 – 330Ω is used to prevent fast C31 charge and discharge when PIC18F97J60 is being programmed. Manual reset is possible by the RESET button. CLOCK CIRCUIT: Quartz crystal 25MHz is connected to PIC18F97J60 pins OSC1 (CLK1) and OSC2 (CLKO). Internal PLL circuit can multiply this frequency up to 41MHz. 32.768 KHz quartz crystal is connected to PIC18F97J60 pins T1SO and T1OSI for its internal Timer1. Page 9 JUMPER DESCRIPTION: 5V_E enables 5V supply for LCD and relays. Default state closed (shorted). 3.3V_E enables 3.3V supply for PIC18F97J60 and all other devices. Default state closed (shorted). 3.3V is also available to EXT-1, so if you want to connect external backup battery to the PIC18F97J60 this jumper should be opened and the external battery to be connected to EXT-1 pin. #SS1/#SS2 chip select for U5 (AT45DB011) serial flash. Default position is selected to be #SS2 in compatibles with Microchip software but user can change it in its own application. Default state closed (shorted) INPUT/OUTPUT: Two User buttons with names BUT1 and BUT2 – connected to PIC18F97J60 pin 8 RB3/INT3/ECCP2(1)/P2A(1) and pin 6 RB1/INT1; One analog trimmer AN_TR – connected to PIC18F97J60 pin 33 RA2/AN2/VREF-; Thermistor TH1– connected to PIC18F97J60 pin 32 RA2/AN2/VREF+; Three LEDs – LD0 (yellow) – connected to PIC18F97J60 pin 49 RJ0/ALE , LD1 (red) – connected to PIC18F97J60 pin 50 RJ1/#OE, LD2 (red) – connected to PIC18F97J60 pin 66 RJ2/#WRL; Four opto isolated digital inputs IN1-IN4; Four red LEDs – LED1, LED2, LED3, LED4 for every digital input; Two green LEDs – LED5, LED6 – for the relays; Power supply red LED with name PWR_LED – indicates that 3.3V power supply is available Twelve analog inputs X1-X6; LCD Display - SC1602A - 16 characters x 2 lines. Page 10 EXTERNAL CONNECTOR DESCRIPTION: ICSP: Pin # PGD PGC Signal Name 1 RST 2 VCC 3 GND 4 PGD 5 PGC 6 NC I/O Program Data. Serial data for programming. Input Program Clock. Clock used for transferring the serial data (output from ICSP, input for the MCU). RS232: Pin # TXD RXD Signal Name 1 NC 2 TXD 3 RXD 4 NC 5 GND 6 NC 7 NC 8 NC 9 NC OutputTransmit Data. This is the asynchronous serial data output (RS232) for the shift register on the UART controller. Input Receive Data. This is the asynchronous serial data input (RS232) for the shift register on the UART controller. Page 11 X(1÷6)-CONNECTORS Pin # Signal Name 1 AIN4 2 AIN5 3 AIN6 4 AIN7 5 AIN8 6 AIN9 7 AIN10 8 AIN11 9 AIN12 10 AIN13 11 AIN14 12 AIN15 13 GND These are the 12 analog inputs. IN(1÷4)-CONNECTORS Pin # Signal Name 1 IN1+ 2 IN1- 3 IN2+ 4 IN2- 5 IN3+ 6 IN3- 7 IN4+ 8 IN4These are the 4 opto isolated digital inputs. Page 12 EXT: Pin # Signal Name Pin # Signal Name 1 VCC 2 GND 3 RJ7/#UB 4 RJ6/#LB 5 RJ5/#CE 6 RJ4/BA0 7 RJ3/#WRH 8 RJ2/#WRL 9 RJ1/#OE 10 RJ0/ALE 11 RH3/A19 12 PG3/CCP4/P3D 13 RG2/RX2/DT2 14 RG1/TX2/CK2 15 RG0/ECCP3/P3A 16 RF7/#SS1 17 RD6/AD6/PSP6/SCK2/SCL2 18 RD5/AD5/PSP5/SDI2/SDA2 19 RD4/AD4/PSP4/SDO2 20 RD3/AD3/PSP3 21 RD2/AD2/PSP2 22 RS1/AD1/PSP1 23 RD0/AD0/PSP0 24 RB5/KBI1 25 RB0/INT0/FLT0 26 RB2/INT2 Page 13 LAN: Pin # Signal Name Chip Side Pin # Signal Name Chip Side 1 TPOUT+ 5 Not Connected (NC) 2 TPOUT- 6 Not Connected (NC) 3 3.3V 7 TPIN+ 4 Not Connected (NC) 8 TPIN- LED Color Usage Right Yellow Activity Left Green 100MBits/s (Half/Full duplex) RELAYS: Pin # Signal Name 1 Normal Open 2 Common 3 Normal Close Page 14 PWR: Pin # Signal Name 1 AC in 1 2 AC in 2 Page 15 MECHANICAL DIMENSIONS: All measures are in mm. Page 16 AVAILABLE DEMO SOFTWARE: You could find information about PIC-MAXI-WEB board, Microchip TCP/IP stack and how to change and configure the software in Understanding PIC WEB boards on www.olimex.com/dev. Page 17 ORDER CODE: PIC-MAXI-WEB – assembled and tested (no kit, no soldering required) How to order? You can order to us directly or by any of our distributors. Check our web www.olimex.com/dev for more info. All boards produced by Olimex are RoHS compliant Revision history: REV.A - created July 2008 REV B - created April 2009 Page 18 Disclaimer: © 2009 Olimex Ltd. All rights reserved. Olimex®, logo and combinations thereof, are registered trademarks of Olimex Ltd. Other terms and product names may be trademarks of others. The information in this document is provided in connection with Olimex products. No license, express or implied or otherwise, to any intellectual property right is granted by this document or in connection with the sale of Olimex products. Neither the whole nor any part of the information contained in or the product described in this document may be adapted or reproduced in any material from except with the prior written permission of the copyright holder. The product described in this document is subject to continuous development and improvements. All particulars of the product and its use contained in this document are given by OLIMEX in good faith. However all warranties implied or expressed including but not limited to implied warranties of merchantability or fitness for purpose are excluded. This document is intended only to assist the reader in the use of the product. OLIMEX Ltd. shall not be liable for any loss or damage arising from the use of any information in this document or any error or omission in such information or any incorrect use of the product. Page 19
PIC-MAXI-WEB 价格&库存
很抱歉,暂时无法提供与“PIC-MAXI-WEB”相匹配的价格&库存,您可以联系我们找货
