IL41050-01
IL41050-01
    NVECORP
    ISOLATED CAN EVAL BOARD
IL41050-01 数据手册
® IsoLoop Isolated CAN Evaluation Board Board No.: IL41050-01 NVE Corporation (952) 829-9217 iso-apps@nve.com www.IsoLoop.com www.nve.com About This Evaluation Board This Evaluation Board provides a complete isolated CAN node using the revolutionary IL41050TA-3E isolated transceiver. The IL41050TA is a galvanically isolated, CAN (Controller Area Network) transceiver, designed as the interface between the CAN protocol controller and the physical bus. Advanced features facilitate reliable bus operation. Unpowered nodes do not disturb the bus, and a unique non-volatile programmable power-up feature prevents unstable nodes. The devices also have a hardware-selectable silent mode that disables the transmitter. Designed for harsh CAN and DeviceNet environments, IL41050TA transceivers have transmit data dominant time-out, bus pin transient protection, a rugged Charged Device Model ESD rating, thermal shutdown protection, and short-circuit protection. Unique edge-triggered inputs improve noise performance. Unlike optocouplers or other isolation technologies, IsoLoop isolators have virtually indefinite barrier life. The Isolation Advantage Battery fire caused by over or under charging of individual lithium ion cells is a major concern in multi-cell high voltage electric and hybrid vehicle batteries. To combat this, each cell is monitored for current flow, cell voltage, and in some advanced batteries, magnetic susceptibility. The IL41050 allows seamless connection of the monitoring electronics of every cell to a common CAN bus by electrically isolating inputs from outputs, effectively isolating each cell from all other cells. Cell status is then monitored via the CAN controller in the Battery Management System (BMS). Another major advantage of isolation is the tremendous increase in noise immunity it affords the CAN node, even if the power source is a battery. Inductive drives and inverters can produce large transients. Traditional, non-isolated CAN nodes provide some protection due to differential signaling and symmetrical driver/receiver pairs, but the IL41050 typically provides several times more transient immunity than traditional CAN nodes. NVE Corporation (952) 829-9217 iso-apps@nve.com www.IsoLoop.com www.nve.com Circuit Diagram VDD2 VDD1 C DD1 100nF 1 R TXD Isolation Boundary C DD2 100nF 11 16 14 13 12 16K TxD RxD 3 10 9 IL41050 TA-3E pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Symbol VDD1 GND1 TxD RxD NC NC NC NC IsoRxD CANL VDD2 CANH S IsoTxD GND2 VDD2 S RL 120R 4 GND1 IsoTxD 2 15 IL41050TA-3E CANH CANL IsoRxD GND2 Description VDD1 power supply VDD1 power supply ground return Transmit Data input Receive Data output No internal connection No internal connection No internal connection No internal connection Isolated RxD output (for test purposes only) Low level CANbus line VDD2 CAN I/O bus circuitry power supply input* High level CANbus line Mode select input (open or low for normal operation; high for silent mode) Isolated TxD output (for test purposes only) VDD2 power supply ground return VDD2 isolation power supply input* *Pin 11 is not internally connected to pin 16; both are connected to VDD2 in the PCA. NVE Corporation (952) 829-9217 iso-apps@nve.com www.IsoLoop.com www.nve.com Application Information Bus-Side Power Supply Pins Both VDD2 power supply inputs (pins 11 and 16) must be connected to the bus-side power supply. Pin 11 powers the bus side of the CAN I/O circuitry, while pin 16 powers the bus-side isolation circuitry. For testing purposes, they are not internally connected, but the part will not operate without both pins powered, and operation without both pins powered can cause damage. Power Supply Decoupling Both VDD1 and VDD2 must be bypassed with 100 nF ceramic capacitors. These supply the dynamic current required for the isolator switching and should be placed as close as possible to VDD and their respective ground return pins. Input Configurations The TxD input should not be left open as the state will be indeterminate. If connected to an open-drain or open collector output, a pull-up resistor (typically 16 kΩ) should be connected from the input to VDD1. This kit has a 16 kΩ pull-up resistor. The Mode Select (“S”) input has a 150 kΩ nominal internal pull-down resistor. It can be left open or set low for normal operation. Bus Termination Because of their relatively low speed, CAN networks can sometimes be unterminated, but reflections are minimized by terminating both ends of the bus (but not every node). Two 120 Ω termination resistors are generally used to match a 60 Ω cable impedance. This kit comes with a 120 Ω termination resistor. The resistor can be removed for multi-node configurations. Level Shifting As shown in the figure at right, the IL41050 can provide isolation and level shifting between a 5 volt CAN bus and a 3 volt microcontroller such as an SJA1000 MCU. VDD2 = 5V VDD1 = 3.3V C DD1 C DD2 100 nF 100 nF ADR 0...7, CS XTAL1 SJA1000 Tx0 TxD CANH Rx0 RxD CANL IsoRxD / IsoTxD Outputs The IsoRxD and IsoTxD outputs are isolated versions of the RxD and TxD signals. These outputs are provided on the IL41050 narrow-body version for troubleshooting, and are brought to test points in this kit. Normally no connections are made to the pins. Dominant Mode Time-out and Failsafe Receiver Functions CAN bus latch up is prevented by an integrated Dominant mode timeout function. If the TxD pin is forced permanently low by hardware or software application failure, the time-out returns the RxD output to the high state no more than 765 μs after TxD is asserted dominant. The timer is triggered by a negative edge on TxD. If the duration of the low is longer than the internal timer value, the transmitter is disabled, driving the bus to the recessive state. The timer is reset by a positive edge on pin TxD. If VDD2 power is lost, the IL41050 asserts the RxD output high when the supply voltage falls below 3.8 V. RxD will return to normal operation when VDD2 rises above approximately 4.2 V. Programmable Power-Up A unique non-volatile programmable power-up feature prevents unstable nodes. A state that needs to be present at node power up can be programmed at the last power down. For example if a CAN node is required to “pulse” dominant at power up, TxD can be sent low by the controller immediately prior to power down. When power is resumed, the node will immediately go dominant allowing self-check code in the microcontroller to verify node operation. If desired, the node can also power up silently by presetting the TxD line high at power down. At the next power on, the IL41050 will remain silent, awaiting a dominant state from the bus. The microcontroller can check that the CAN node powered down correctly before applying power at the next “power on” request. If the node powered down as intended, RxD will be set high and stored in the IL41050’s non-volatile memory. The level stored in the RxD bit can be read before isolated node power is enabled, avoiding possible CAN bus disruption due to an unstable node. XTAL2 IL41050 GND1 NVE Corporation (952) 829-9217 iso-apps@nve.com www.IsoLoop.com GND2 www.nve.com NVE Corporation (952) 829-9217 iso-apps@nve.com www.IsoLoop.com www.nve.com Specification Highlights and Quickstart IL41050TA Specification Highlights: • Fully compliant with the ISO 11898 CAN standard • 3.0 V to 5.5 V input power supplies • 12 mA maximum quiescent recessive supply current • 70 mA maximum bus-side dynamic supply current • 1200 VRMS 1 minute isolation (QSOP); 2500 VRMS for narrow and wide SOIC versions • ±500 V CDM ESD • 1 Mbps • 50 kV/μs transient immunity • Silent mode to disable transmitter • Unpowered nodes do not disturb the bus • Edge triggered, non-volatile input improves noise performance • Thermal shutdown protection • Short-circuit protection for ground and bus power • −55°C to +125°C operating temperature • QSOP, 0.15" SOIC, or 0.3" True 8™ mm 16-pin packages • UL 1577 recognized; IEC 60747-5-5 (VDE 0884) certified Quick Start: • Connect VDD1 to a 3.3 V power supply and VDD2 to 5 V. • Connect a 500 kHz signal generator to the “TxD” input. • Verify the “RxD” and CAN outputs on an oscilloscope: TxD RxD CANH CANL Visit www.IsoLoop.com for datasheets. NVE Corporation (952) 829-9217 iso-apps@nve.com www.IsoLoop.com www.nve.com Evaluation Board Layout 100 nF decoupling capacitors close to VDD1 and VDD2 pins Power supply connections ISO 11898 compliant 3V - 5.5V supply 12mA max Iq Narrow-body package 16kΩ TxD pull-up resistor CANbus connections Input connections IL41050-06 IL41050TA-3E narrow-body isolated CAN transceiver NVE Corporation (952) 829-9217 120Ω bus termination resistor iso-apps@nve.com www.IsoLoop.com www.nve.com Limited Warranty and Liability Information in this document is believed to be accurate and reliable. However, NVE does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including, without limitation, lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Right to Make Changes NVE reserves the right to make changes to information published in this document including, without limitation, specifications and product descriptions at any time and without notice. Use in Life-Critical or Safety-Critical Applications Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical devices or equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and such inclusion or use is at the customer’s own risk. Should the customer use NVE products for such application whether authorized by NVE or not, the customer shall indemnify and hold NVE harmless against all claims and damages. Applications Applications described in this document are illustrative only. NVE makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NVE products, and NVE accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customers. Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NVE does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customers. The customer is responsible for all necessary testing for the customer’s applications and products using NVE products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customers. NVE accepts no liability in this respect. An ISO 9001 Certified Company NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 ©NVE Corporation All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. Manual No.: ISB-CB-007 June 2014 NVE Corporation (952) 829-9217 iso-apps@nve.com www.IsoLoop.com www.nve.com
IL41050-01 价格&库存
很抱歉,暂时无法提供与“IL41050-01”相匹配的价格&库存,您可以联系我们找货
