DFR0251
DFR0251
    DFROBOT
    16ARELAYMODULE(ARDUINOCOMPAT
DFR0251 数据手册
    16A Relay Module(SKU:DFR0251) Contents       1 Introduction 2 Specification 3 Relay Module Pinout 4 Test Connection Diagram 5 Sample Code 6 Plugging in an appliance Introduction A relay is an electrically operated switch, which has a control system (also known as the input circuit) and the controlled system (also known as the output circuit), usually used in automatic control circuit.It is actually "automatic switch" ,using a small electric current to control a larger current.Therefore, the relay has the effects on the automatical automatic adjustment, security, conversion circuit in the circuit and so on . Relays are used where it is necessary to control a circuit by a low-power signal (with complete electrical isolation between control and controlled circuits), or where several circuits must be controlled by one signal. The 16A relay module can be used in interactive projects. It can also be used to control the lighting, electrical and other equipments. It can be controlled through the digital IO port, such as solenoid valves, lamps, motors and other high current or high voltage devices. The main difference between 16A Relay module and the old version relay module is the Max switching current.The max switching current of old version is 10A,and now the new version is 16A. Specification           Contact Rating (Res. Load):16A 277VAC/24VDC Maximum switching voltage: 400VAC(NO) Max. switching current: 16A Max. switching power: 4700VA Operate tiem (at nomi. Vot.): 10ms max Release time (at nomi. Vot.): 5ms max Type: Digital Single relay board Digital Interface Control signal: TTL level Relay Module Pinout There are a total of 7 pins on the relay module board. Link Arduino Side: 1. Signal 2. Vcc 3. GND Link Appliance Side: 1. COM(IN): input positive wire from appliance 2. N/A(NC): not connected 3. NC(OUT1): Normally closed, which means that when the relay is off (a digital low "0" is received from Arduino) the device is ON 4. NO(OUT2): Normally open, which means that when the relay is on (a digital high "1" is received from Arduino) the device is ON. WARNING: Please be very carful not to play with live circuits! 120V or 220V should not be taken lightly. Make sure the appliance to be tinkered with is unplugged from mains. (DO NOT CONNECT IT TO THE WALL WHILE MESSING WITH THE CABLE!) Test Connection Diagram Sample Code /* # Product: 16A Relay Module # SKU : DFR0251 # Description: # This sample code is combined odule whether works normally. with the figure above to test the relay m # Link: # D -- 2 // Signal # GND -- GND # VCC -- VCC # COM -- 13 // INPUT # NO -- LED + // OUTPUT # LED - -- GND */ int Relay = 3; void setup() { pinMode(13, OUTPUT); //Set Pin13 as output digitalWrite(13, HIGH); //Set Pin13 High pinMode(Relay, OUTPUT); //Set Pin3 as output } void loop() { digitalWrite(Relay, HIGH); //Turn off relay delay(2000); digitalWrite(Relay, LOW); delay(2000); } //Turn on relay Plugging in an appliance We will use "out1" for our example, using "out2" will simply reverse the logic, as explained above. We recommend using a swappable cable to do this with, as using a relay requires you to perform some minor surgery on the appliance's cable. To plug in an appliance such as a lamp: Cut and strip a portion of the positive wire so that you end up with two ends of the wire as shown in Figure 2. The relay should have the positive wire of the device being used connected to "IN" and to "Out 1" as shown in figure 2, and any digital signal pin on the arduino end (For example pin 13). Sending a digital high or a "1" will trigger the relay. Sending a digital low or "0" will disable the relay. Powered By DFRobot © 2008-2017
DFR0251
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款高性能的微处理器。
2. 器件简介:该器件是一款32位的ARM Cortex-M4内核微处理器,适用于需要高性能计算和低功耗的应用场景。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压为2.0V至3.6V,工作频率高达200MHz,内置512KB的闪存和128KB的RAM。
5. 功能详解:支持多种通信接口,如I2C、SPI、UART等,具有丰富的外设接口和高性能的ADC。
6. 应用信息:适用于工业控制、智能家居、医疗设备等领域。
7. 封装信息:采用LQFP48封装,尺寸为7x7mm。
DFR0251 价格&库存
很抱歉,暂时无法提供与“DFR0251”相匹配的价格&库存,您可以联系我们找货
DFR0251
  • 1+86.005981+10.74729
库存:28
DFR0251
  • 1+119.999491+14.99510
  • 3+105.349963+13.16450
库存:4
