FIT0261
FIT0261
    DFROBOT
FIT0261 数据手册
  Miga Analog Driver V5 - MOSFET Switch SKU: FIT0261 INTRODUCTION Shape Memory metals that were developed by NASA for the space industry, and have been used for increasing applications down on earth.For example,there have been limited studies on using these materials in robotics. They make it possible to create very light robots. he Miga Analog Driver V5 (MAD-V5) is a MOSFET switch designed to safely power the MigaOne, Dash4, MOBI, NM706Super, and NM70R-6P shape memory alloy actuators across a wide range of speeds or input voltages. The MAD-V5 allows either push-button control, or external GATE or CNTL signals (from 2.5 - 30V) to switch power until the actuator end-of-travel limit is reached. The MAD-V5 then cuts power momentarily, preventing overheating of the shape memory elements. APPLICATIONS  o o o  o o o o  o o o o o Automotive Bi-directional grill louver mechanism Fuel tank door release mechanism Trunk, glove compartment release mechanism Consumer Memory card ejector Electronic latch release Security doors and locks Biometric sensor assist Hobby/Miscellaneous Grasping device Undersea Core Sampling Robot Point Of Use sale items Latch release for ROVs Pneumatic actuator replacement SPECIFICATION          Working voltage: 5~30v Hardware interface: 3p pin header x2 Vin: +5 to 30v GND: Power & Actuator Ground GATE: 3v to 30v PWM, Digital CTRL Vout: MOSFET-switched Vin SW: Actuator End Switch Detection safely power the MigaOne, Dash4, MOBI, NM706-Super, and NM70R-6P shape memory alloy actuators Size:30x10mm (1.18x0.39") Powered By DFRobot © 2008-2017
FIT0261 价格&库存
很抱歉,暂时无法提供与“FIT0261”相匹配的价格&库存,您可以联系我们找货
