OM13336,598
OM13336,598
    NEXPERIA(安世)
    KIT 6 BOARDS DEMO LOGIC
OM13336,598 数据手册
NXP 74LVC169 demo board Demonstrate a binary counter for high-speed counting applications This compact demo board makes it easy to evaluate the 74LVC169, a binary counter with internal look-ahead carry circuitry for cascading in high-speed counting applications. Key features and benefits } 5 V tolerant inputs for interfacing with 5 V logic and use in 3/5 V mixed voltage applications } Wide supply voltage range: 1.2 to 3.6 V } CMOS low power consumption for portable applications } Direct interface with TTL levels } Up/down counting } Two count enable inputs for n-bit cascading } Built-in look-ahead carry capability } Presettable for programmable operation } Multiple extremely small standard and leadless packages } Wide operating temperature range (-40 to +125 °C), suitable for industrial and automotive applications Applications } Portable devices } Industrial } Automotive The 74LVC169 is a synchronous presettable 4-bit binary counter which features an internal look-ahead carry circuitry for cascading in high-speed counting applications. Synchronous operation is provided by having all flip-flops clocked simultaneously so that the outputs (pins Q0 to Q3) change simultaneously with each other when instructed by the count-enable (pins CEP and CET) inputs and internal gating. This mode of operation eliminates the output counting spikes that are normally associated with asynchronous (ripple clock) counters. A buffered clock (pin CP) input triggers the four flipflops on the LOW-to-HIGH transition of the clock. The counter is fully programmable; that is, the outputs may be preset to any number between 0 and its maximum count of 15. Presetting is synchronous with the clock and takes place regardless of the levels of the count enable inputs. A LOW level on the parallel enable (pin PE) input disables the counter and causes the data at the Dn input to be loaded into the counter on the next LOW-to-HIGH transition of the clock. The direction of the counting is controlled by the up/down (pin U/D) input. When pin U/D is HIGH, the counter counts up, when LOW, it counts down. The look-ahead carry circuitry is provided for cascading counters for n-bit synchronous applications without additional gating. Instrumental in accomplishing this function are two count-enable (pins CEP and CET) inputs and a terminal count (pin TC) output. Both count-enable (pins CEP and CET) inputs must be LOW to count. Input pin CET is fed forward to enable the terminal count (pin TC) output. Pin TC thus enabled will produce a LOW-level output pulse with a duration approximately equal to a HIGH level portion of pin Q0 output. The LOW level pin TC pulse is used to enable successive cascaded stages. The main clock, when connected to the CP pin, is divided by 2 and appears at the Q0 output. There is a clock with 1/4 the frequency of the main clock at Q1. Clocks with 1/8 and 1/16 of main frequency are available at Q2 and Q3 output pins respectively. In order to preset the outputs of the counter to a number between 0 and its maximum count, the PE pin can be pulled LOW by using jumper JP1. Data at Dn inputs can now be loaded to the outputs on next LOW-to-HIGH transition of main clock. Also, U/D pin can be pulled HIGH by providing logic high input at pin 1 of P1 connector to count up instead of counting down. Since CET pin is pulled LOW, when counter reaches terminal count (HHHH in count up mode and LLLL in count down mode), TC output, which is normally HIGH, will go LOW. The low level on TC output can be used to enable successive cascaded devices Schematics of 74LVC169 demo board are shown in figure below. A supply voltage of 1.2 to 3.6 V can be used for the board. In this design, the 74LVC169 is used as a clock divider that divides the main clock connected to CP pin by 2, 4, 8 and 16. By default, U/D pin is pulled low and PE pin is pulled HIGH, so counter starts counting down, when clock input edge goes from LOW to HIGH. VCC 2 1 C1 JP1 0.1uF GND P1 IC1 VCC TC Q0 Q1 Q2 Q3 CET PE 4.7k 74LVC169PW GND R2 R7 4.7k R6 4.7k R5 4.7k R4 4.7k R3 4.7k GND P2 1 2 3 4 5 6 7 8 U/D VCC TC CP Q0 D0 Q1 D1 Q2 D2 Q3 D3 CEP CET GND PE CLK D0 D1 D2 D3 CEP R8 4.7k 1 2 3 4 5 6 7 8 R1 GND GND GND Circuit schematic of 74LVC169 demo board NXP SEMICONDU TITLE: 74LVC169 Evaluation Boar Document Number: Test results Figure 1 shows a main clock of 466 kHz in green at CP input and a divided-by-2 clock output of 233 kHz in purple at Q0 pin. By default PE pin is pulled up to VCC and U/D pin is pulled down to GND. Figure 2 shows a main clock of 500 kHz in green at CP input. The Q1 output shows a divided-by-4 clock of approximately 166 kHz in purple. In this case, U/D pin is pulled up so counter starts counting up on rising edge of input clock. Similarly, Figures 3 and 4 show the clock outputs of 71 and 33 kHz, which are approximately 1/8 and 1/16 of main clock respectively. Since U/D is pulled LOW for clock output in these examples, counter is counting down. Figure 1 Figure 2 Figure 3 Figure 4 Packages 74LVC169 is available in 16-pin SO, SSOP, TSSOP and leadless DQFN packages. Package suffix D PW BQ DS SOT109-1 SOT403-1 SOT763-1 SOT338-1 16-pin 16-pin 16-pin 16-pin Width (mm) 6.0 6.4 2.5 7.75 Length (mm) 9.9 5.0 3.5 6.2 Pitch (mm) 1.27 0.65 0.5 0.65 Ordering information Part number Package Temp. range Name Type Marking Material 74LVC169 -40 to 125 °C SO16 Small outline 74LVC169D Plastic 74LVC169DB -40 to 125 °C SSOP16 Shrink small outline LVC169 Plastic 74LVC169PW -40 to 125 °C TSSOP16 Thin shrink small outline LVC169 Plastic 74LVC169BQ -40 to 125 °C DHVQFN16 Dual in-line compatible thermal enhanced very thin quad flat package with no leads LVC169 Plastic www.nxp.com © 2010 NXP B.V. All rights reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. Date of release: March 2010 The information presented in this document does not form part of any quotation or contract, is believed to be accurate and Document order number: 9397 750 16884 reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Printed in the Netherlands Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights.
OM13336,598 价格&库存
很抱歉,暂时无法提供与“OM13336,598”相匹配的价格&库存,您可以联系我们找货
OM13336,598
    • 1+1178.94960
    • 200+470.41560
    • 500+454.69080
    • 1000+446.92560
