DA7218-EVAL
DA7218-EVAL
    DIALOGSEMICONDUCTOR(戴乐格)
    EVALUATIONBOARDFORDA7218
DA7218-EVAL 数据手册
User Guide DA7218 EVB User Guide – Rev1.1 DA7218 Ultra Low Power Codec Introduction The DA7218 Evaluation Board (233-02) has been designed to allow measurement and evaluation of the DA7218 device. It connects to the Digital IO Board for USB control and for digital audio input/output via the digital audio interface. All analogue audio codec functionalities are contained within the DA7218 Evaluation Board (EVB). The Digital IO Board user guide accompanies this document. The EVB is supplied with a USB memory stick containing various documents and a GUI to allow the user to control the DA7218. The GUI is called SmartCanvas™. It uses a simple graphical interface, allowing the DA7218 to be controlled via a USB port of a PC. The SmartCanvas user guide accompanies this document. The EVB has a number of jumper links to enable the user to change the system configuration and to allow them to make appropriate measurements, although, in reality, few jumper links are required to be altered for standard operations of the device. VDD_MIC DIGITAL ENGINE Sidetone Filter @ SR2 DA7218 MICBIAS1 Biquad Filter @ SR2 Output Filters @ SR2 (High-Pass, 5-Band EQ, 5× Biquad) MICBIAS2 MIC2_N DMIC2IN Tone Generator @ SR2 1 4 2 DACR VDDDIG HPLDET CHARGE PUMP LDO VDD_IO DATIN DATOUT BCLK HPR HEADPHONE DETECT DIGITAL AUDIO INTERFACE WCLK SCL SDA CONTROL INTERFACE AD VREF VMID DACREF VDD VOLTAGE REFS GND GND_SENSE 2 PLL nIRQ MCLK HPL HPCFP ADC2 DACL HPCFN Input Selection MIC2_P DMIC2CLK Dynamic Range Extension HPCSN ADC1 MIC1_N DMIC1IN HPCSP Input Filters @ SR1 (High-Pass, ALC, Level Detect) System Controller GND_CP MIC1_P DMIC1CLK Figure :1 DA7218 Block Diagram DA7218 EVB User Guide_Rev1v1 Page 1 of 9 User Guide DA7218 EVB User Guide – Rev1.1 Table of Contents SUMMARY 3 HARDWARE 4 Power Supplies Audio Connections Jumpers Link Positions 5 6 7 REVISION HISTORY DA7218 EVB User Guide_Rev1v1 9 Page 2 of 9 User Guide DA7218 EVB User Guide – Rev1.1 Summary This document provides useful information to the user about the EVB to allow testing and evaluation of the DA7218 Ultra Low Power Codec. The hardware solution is based upon two PCBs: - “Digital I/O Board” - “DA7218 Performance Board 233-02-C” The user guide for the Digital I/O board accompanies this document. DA7218 EVB User Guide_Rev1v1 Page 3 of 9 User Guide DA7218 EVB User Guide – Rev1.1 Hardware The DA7218 Evaluation Board consists of the DA7218 device, the essential external components and analogue interconnects. This board could also be used in standalone or as a module for a customer development platform. Figure 2: DA7218 – Default Jumper positions shown in Red (power) and Blue (signal) Note: The EVB has been configured by default to work from the digital I/O board’s on-board regulators. DA7218 EVB User Guide_Rev1v1 Page 4 of 9 User Guide DA7218 EVB User Guide – Rev1.1 Power Supplies The DA7218 EVB can be powered from the Digital I/O Board or externally via the provided connectors (J2, J3, J4, J5 and J6). Figure 3 DA7218 EVB Power Connectors An external current monitor can be placed across each of the supplies by removing the appropriate jumper on J12, J13 and J14 and removing resistors R18, R19 and R20 from the underside of the board. Figure 4 External current monitor connection points DA7218 EVB User Guide_Rev1v1 Page 5 of 9 User Guide DA7218 EVB User Guide – Rev1.1 Audio Connections Connector J8 Name Headset Connector J7 HPL, GND, HPR Function Tip: Headphone Left Ring: Headphone Right Ring2: GND Sleeve: Microphone Headphone outputs. J16 LINE MIC2 P/N MIC2 Input (set by J28 and J29) J18 LINE MIC1 P/N MIC1 Input (set by J30 and J31) J22 DIFF MIC2 MIC2 Input (set by J28 and J29) J27 DIFF MIC1 MIC1 Input (set by J30 and J31) MK1 Low Power Mic J31 MIC 1 N SEL J30 MIC 1 P SEL J29 MIC 2 N SEL J28 MIC 2 P SEL J26 MICBIAS1 & 2 Invensense low power MEMS microphone. Maximum supply = 1.3V Selects which input is used for MIC 1 N 1-2: Low Power Mic N 2-3: DMIC1 Data 2-A: LINE MIC1 N 2-B: DIFF MIC1 N Selects which input is used for MIC 1 P 1-2: Low Power Mic P 2-3: DMIC1 Clock 2-A: LINE MIC1 P 2-B: DIFF MIC1 P Selects which input is used for MIC 2 N 1-2: Low Power Mic N 2-3: DMIC2 Data 2-A: LINE MIC2 N 2-B: DIFF MIC2 N Selects which input is used for MIC 1 P 1-2: Low Power Mic P 2-3: DMIC2 Clock 2-A: LINE MIC2 P 2-B: DIFF MIC2 P Access to MICBIAS output J25 DMIC1 Interface DMIC1 input pins J24 DMIC2 Interface DMIC2 input pins DA7218 EVB User Guide_Rev1v1 Page 6 of 9 User Guide DA7218 EVB User Guide – Rev1.1 J19 J23 Digital Audio Interface Control Interface J17 HPLDET Access to DAI pins Access to the control interface pins (I2C, IRQ). Test point for HPLDET circuitry. Table 1 233-02-C Connectors Jumpers Link Positions Jumper number J2 – J6 Position J9 1-2 (default) 2-3 J10 1-2 (default) 2-3 J11 1-2 (default) 2-3 J1 Unpop (default) 1-2 J12 1-2 (default) 3 J13 1-2 (default) 3 J14 1-2 (default) 3 DA7218 EVB User Guide_Rev1v1 Function External supply and GND connections VDD_IO from the Digital I/O board VDD_IO from J3 VDD from the Digital I/O board VDD from J5 VDD_MIC from the Digital I/O board VDD_MIC from J6 Digital I/O board IO supply from Digital I/O board Digital I/O board IO supply from J3 VDD_IO supply. Replace jumper with ammeter for current measurement. VDD_IO voltage monitoring pin VDD supply. Replace jumper with ammeter for current measurement. VDD voltage monitoring pin VDD_MIC supply. Replace jumper with ammeter for current measurement. VDD_MIC voltage monitoring pin Page 7 of 9 User Guide DA7218 EVB User Guide – Rev1.1 J21 Connection to Digital I/O Board Table 2: 233-02-C Jumpers Link Positions and Button Settings DA7218 EVB User Guide_Rev1v1 Page 8 of 9 User Guide DA7218 EVB User Guide – Rev1.1 REVISION HISTORY REVISION DATE ORIGINATOR CHANGE 1.0 19/05/2015 CM Initial Release 1.1 02/03/2016 CM Updated for DIO2 Dialog Semiconductor Worldwide Germany (Headquarter) Tel: (+49) 7021 805-0 Fax (+49) 7021 805-100 USA Tel: (+1) 949 623 8686 Fax: (+1) 949 623 8305 United Kingdom Tel: (+44) 1793 757700 Fax: (+44) 1793 757800 China Tel: (+852) 2607 4271 Fax: (+852) 2607 4169 Japan Tel: +81-3-3215-5123 Fax +81-3-3125-5124 Taiwan Tel: +886 22 67 57 876 Fax +886 22 67 54 098 This publication is issued to provide outline information only, which (unless agreed by Dialog Semiconductor in writing) may not be used, applied or reproduced for any purpose or form part of any order or contract or be regarded as a representation relating to products or services concerned. Dialog Semiconductor reserves the right to alter without notice the specification, design, price or conditions of supply of the product. Customer takes note that Dialog Semiconductor’s products are not designed for use in devices or systems intended for supporting or monitoring life nor for surgical implants into the body. Customer shall notify the company of any such intended use so that Dialog Semiconductor may determine suitability. Customer agrees to indemnify Dialog Semiconductor for all damages that may be incurred due to use without the company’s prior written permission of products in such applications. Email: enquiry@diasemi.com DA7218 EVB User Guide_Rev1v1 www.dialog-semiconductor.com Page 9 of 9
DA7218-EVAL 价格&库存
很抱歉,暂时无法提供与“DA7218-EVAL”相匹配的价格&库存,您可以联系我们找货
