PIM191
PIM191
    PIMORONI
    MOTE(HOST)
PIM191 数据手册
    Mote   Complete Kit (Host + 4 Sticks + Cables) PIM192 Host PIM191     Stick PIM190 Mote Module Cables Mote pHAT PIM216   Mote is the most stylish way to light your home (or ship)! Ideal for under-shelf or under-cabinet lighting, or even lighting the way to the emergency exits on your super-yacht (you have one right?) Mote consists of a USB controller, with four channels, that connects via a USB A to micro B cable to your computer, and up to four APA102 RGB LED strips with 16 pixels on each (for a total of 64 pixels per USB controller, although the firmware can theoretically handle 128 pixels per channel). The USB controller can be powered straight from your computer, but we've provided a power boost port to which you can connect a 2+A power supply, to boost the pixel brightness to retinasearing levels. Of course, you can have several USB controllers running on the same computer, so your only real limitation is providing enough power. We've designed Mote to work equally well with whatever flavour of computer you have, be it Linux (inc. Raspberry Pi 3, 2 or B+), Mac, or Windows. If you're looking for a more compact solution, ideal for the Pi Zero, then there's also Mote pHAT that lets you control your Mote sticks directly through your Pi's GPIO. Features         16 pixel APA102 RGB LED strips (18cm long, 4 strips included in Complete Kit)  USB controller with four micro USB channels  Connects to your computer with USB A to micro B cable (included in Complete Kit)  Micro USB power boost port for extra pixel brightness  Custom‐designed cables (4x 1m Mote cables include in Complete Kit)  Ideal for mood lighting, under‐shelf, or cabinet lighting  Compatible with Raspberry Pi 3, 2, B+, A+, Zero, Mac, and Windows  Python library  Software Our Mote Python library has a bunch of examples showing you how to, for instance, display a rainbow animation, or link Mote up with the Cheerlights crowd-sourced light colours API. We've put together a tutorial showing you how to control Mote with your iPhone and Siri voice control, and Richard Ruston (of Raspberry Jam Berlin) has written an Android app for controlling Mote with your Android phone. Check out our getting started guide to get you up to speed with Mote. Notes The distance between the mounting hole centres is 167mm, and we'd recommend a 4g x 1/2" (2.9 x 13mm) round head screw for mounting.        https://shop.pimoroni.com/products/mote 4/17/2017
PIM191 价格&库存
很抱歉,暂时无法提供与“PIM191”相匹配的价格&库存,您可以联系我们找货
