BOB-00765
BOB-00765
    SPARKFUNELECTRONICS
    ENC28J60 Interface, Ethernet Evaluation Board
BOB-00765 数据手册
ENC28J60-H development board User's manual All boards produced by Olimex are ROHS compliant Document revision B, January 2015 Copyright(c) 2015, OLIMEX Ltd, All rights reserved Page 1 INTRODUCTION ENC28J60-H is world’s smallest Ethernet controller development board with it’s size of only 30×24mm. It provides easy connection to any microcontroller with only few ports via SPI which makes it perfect for adding Ethernet connectivity to embedded applications. BOARD FEATURES – ENC28J60 10 Mbit Ethernet controller – on-board RJ45 connector with build in Ethernet transformer and two status LEDs – easy interface to any microcontroller via SPI – compact size in DIL 10 pin format, the distance between pin rows is 0.8” – PCB: FR-4, 1.5 mm (0,062"), soldermask, white silkscreen component print – Dimensions: 30×24 mm (1.18×0.95") ELECTROSTATIC WARNING The ENC28J60-H board is shipped in protective anti-static packaging. The board must not be subject to high electrostatic potentials. General practice for working with static sensitive devices should be applied when working with this board. Ethernet Controller Features ENC28J60-H board use ENC28J60 stand-alone Ethernet controller with these features: – IEEE 802.3. Compatible Ethernet Controller – Fully Compatible with 10/100/1000Base-T Networks – Integrated MAC and 10Base-T PHY – Supports One 10Base-T Port with Automatic Polarity Detection and Correction – Supports Full and Half-Duplex modes – Programmable Automatic Retransmit on Collision – Programmable Padding and CRC Generation – Programmable Automatic Rejection of Erroneous Packets – SPI Interface with Clock Speeds Up to 20 MHz Page 2 BLOCK DIAGRAM Page 3 MEMORY MAP Page 4 18pF C2 +3.3V 18pF 100nF C4 3.3V C1 +3.3V 25MHz Q1 C5 C6 C7 C8 GND_ GND + SCK MOSI MISO WOL INT 10uF C3 2.2k/1% R2 RST CS 10 9 8 7 6 2 21 11 18 14 1 28 20 19 15 25 24 23 22 10 9 R9 10K +3.3V 100nF 100nF 100nF 100nF Page 5 3.3V GND RST CS CLKOUT +3.3V #WOL #INT CLKOUT SCK SI SO TPOUT+ TPOUT- TPIN+ TPIN- LEDA LEDB 5 4 3 WOL INT CLKOUT SCK MOSI MISO TPOUT+ TPOUT- 17 16 8 7 6 TPIN+ TPIN- LEDA LEDB 13 12 27 26 R7 49.9/1% R6 10nF R8 C10 49.9/1% R5 49.9/1% R4 ferrite bead L1 TPIN- TPIN+ LEDB TPOUTLEDA TPOUT+ 49.9/1% R3 http://www.olimex.com/dev COPYRIGHT(C) 2008, OLIMEX Ltd. Rev. B ENC28J60-H 180 ENC28J60 VSS VSSPLL VSSRX VSSTX RBIAS VCAP VDD VDDPLL VDDRX VDDTX VDDOSC OSC2 OSC1 VSSOSC #RESET #CS U1 +3.3V 180 1 2 3 4 5 100k R1 +3.3V 1 3 2 AG KG AY KY 7 6 8 1:1 RJLD-043TC1 TD+ TCT TDAG KG AY KY RD+ RCT RD- LAN 100nF C9 75 1nF/2kV YELLOW 1:1 GREEN 75 75 75 3 7 8 6 1 4 5 2 SCHEMATIC RJ45 SIDE POWER SUPPLY CIRCUIT ENC28J60-H is typically power supplied by EXT pin 10 and pin 9. RESET CIRCUIT ENC28J60-H reset circuit includes EXT connector pin 8, U1 pin 10 and R9 (10k). CLOCK CIRCUIT Quartz crystal 25 MHz is connected to ENC28J60 pin 23 (OSC1) and pin 24 (OSC2). IMPORTANT: If the board has a quartz crystal rotated at 45 degrees relative to the pads provided do not panic. This is normal. We have two types of such crystals – one of them requires 4 pads, the other only 2 pads. That is why we have provided 4 pads to be able to fit both crystals. All boards Olimex manufactures pass automatized optical inspection after assembly and obvious misplacement like this is impossible to occur. A tilted quartz is not a manufacturing error! JUMPER DESCRIPTION There are no configurable jumpers on the board. Page 6 CONNECTOR DESCRIPTIONS LAN Pin # 1 2 3 4 Signal Name Chip Side TX+ TXVDD Not Connected (NC) Pin # 5 6 7 8 LED Color Usage Right Left Green Yellow Link status Activity status Page 7 Signal Name Chip Side Not Connected (NC) VDD RX+ RX- EXT Pin# Signal Name Pin# Signal Name 1 SCK 6 CLKOUT 2 MOSI 7 CS 3 MISO 8 RST 4 WOL 9 GND 5 INT 10 3.3V Page 8 MECHANICAL DIMENSIONS Page 9 AVAILABLE DEMO SOFTWARE Please check the SOFTWARE section of the product page for a number of examples with different boards. The web page for ENC28J60-H is: https://www.olimex.com/Products/Modules/Ethernet/ENC28J60-H/ Page 10 ORDER CODE ENC28J60-H – completely assembled and tested, includes ENC28J60 Ethernet controller How to order? You can purchase directly from our online shop or from any of our distributors. Note that usually it might be faster and cheaper to purchase Olimex products from our distributors. List of confirmed Olimex LTD distributors and resellers: https://www.olimex.com/Distributors Please visit our web site www.olimex.com for more information. REVISION HISTORY: Board revision: Board revision Notable changes B Initial release of the board Manual revision: Document revision Notable changes Modified page A - Initial manual release All B, 23.01.15 - Cleared duplicate information - Added clarification about the rotated quartz crystal - Formatting improvements All Page 11 Disclaimer: © 2015 Olimex Ltd. Olimex®, logo and combinations thereof, are registered trademarks of Olimex Ltd. Other product names may be trademarks of others and the rights belong to their respective owners. The information in this document is provided in connection with Olimex products. No license, express or implied or otherwise, to any intellectual property right is granted by this document or in connection with the sale of Olimex products. The hardware design of ENC28J60-H is considered intellectual property of Olimex. The hardware design files are considered copyright material and would not be distributed. It is possible that the pictures in this manual differ from the latest revision of the board. The product described in this document is subject to continuous development and improvements. All particulars of the product and its use contained in this document are given by OLIMEX in good faith. However all warranties implied or expressed including but not limited to implied warranties of merchantability or fitness for purpose are excluded. This document is intended only to assist the reader in the use of the product. OLIMEX Ltd. shall not be liable for any loss or damage arising from the use of any information in this document or any error or omission in such information or any incorrect use of the product. This evaluation board/kit is intended for use for engineering development, demonstration, or evaluation purposes only and is not considered by OLIMEX to be a finished end-product fit for general consumer use. Persons handling the product must have electronics training and observe good engineering practice standards. As such, the goods being provided are not intended to be complete in terms of required design-, marketing-, and/or manufacturing-related protective considerations, including product safety and environmental measures typically found in end products that incorporate such semiconductor components or circuit boards. Olimex currently deals with a variety of customers for products, and therefore our arrangement with the user is not exclusive. Olimex assumes no liability for applications assistance, customer product design, software performance, or infringement of patents or services described herein. THERE IS NO WARRANTY FOR THE DESIGN MATERIALS AND THE COMPONENTS USED TO CREATE ENC28J60-H. THEY ARE CONSIDERED SUITABLE ONLY FOR ENC28J60-H. Page 12
BOB-00765 价格&库存
很抱歉,暂时无法提供与“BOB-00765”相匹配的价格&库存,您可以联系我们找货
