ROB-09107
ROB-09107
    SPARKFUNELECTRONICS
    IRF7862 Power Management, Motor Control Evaluation Board
ROB-09107 数据手册
Page 1 of 2   Motor Driver 15A IRF7862PBF ROB - 09107  images are CC BY-NC-SA 3.0 Description: The Pololu 15 Amp high-power motor driver is a discrete MOSFET H-bridge designed to drive one DC brushed motor. The H-bridge is made up of one N-channel MOSFET per leg, and most of the board’s performance is determined by these MOSFETs (the rest of the board contains the circuitry to take user inputs and control the MOSFETs). The board supports a wide 5.5 to 24 V voltage range and is efficient enough to deliver a continuous 15 A without a heat sink, or 21 A with a heat sink. With the PWM pin held low, both motor outputs will be held low (a brake operation). With PWM high, the motor outputs will be driven according to the DIR input. This allows two modes of operation: sign-magnitude, in which the PWM duty cycle controls the speed of the motor and DIR controls the direction, and locked-antiphase, in which a pulse-width-modulated signal is applied to the DIR pin with PWM held high. The included axial capacitor should be mounted to the + and - holes in the middle of the PCB. Make sure the cap is connected with the correct orientation. Note: Batteries that are nominally 24 V can be much higher than that when fully charged; this product is therefore not recommended for use with 24 V batteries unless appropriate measures are taken to limit the peak voltage. Features: • • • • • IRF7862PBF MOSFETs Motor Driver 1 Motor Channel Operating Voltage: 5.5 - 24V Continuous output current: 15 Amps Peak output current: 170 Amps Page 2 of 2 • Max PWM frequency: 40kHz • MOSFET on-resistance: 3.7mOhm Dimensions: 1.3" x 0.8" https://www.sparkfun.com/products/9107 11/11/2015
ROB-09107
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出等。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
ROB-09107 价格&库存
很抱歉,暂时无法提供与“ROB-09107”相匹配的价格&库存,您可以联系我们找货
