e t B u r n e r
Networking in 1 Day!
SB72
Development Kit
NNDK-SB72-KIT
Features
• Complete set of development
tools to write applications for
the SB72
• Includes TCP/IP Stack, Web
Server, uC/OS, GNU C/C++,
GDB graphical Debugger,
SB72 board, SB72 Adapter
board, and configuration
utilities
• Create custom web pages
Customize the SB72 to Suit Any Application
The SB72 development kit enables you to quickly and easily create custom
applications. NetBurner has a solid reputation for development platforms to facilitate
rapid product development, and the SB72 is no exception. The SB72 development kit
includes the hardware platform, TCP/IP Stack, uC/OS Real-time operating system,
Web Server, GNU C/C++ compiler and linker, GDB graphical debugger, end-user
device configuration and flash update utilities, and much more.
Compiler & Linker
TCP/IP Stack
Motorola
ColdFire® 5272
Hardware
• Modify existing serial
protocols or create new
protocols
Your
Application
• Use the SB72 as a powerful
single board computing
platform
Ethernet/PPP
Debug
Web Server
• 32-bit Motorola ColdFire
processor with integrated
10/100 Ethernet MAC
Real Time OS
• SB72 contains 8MBytes
SDRAM
Key Benefits
• Required for SB72 QSPI
• Price: $399 USD
• NetBurner hardware and software is fully tested and ready for your application
• No Porting! The integration effort has already been done and all components
work together perfectly.
• You can be up and running immediately
Kit Contents
• SB72 board assembly
• SB72 adapter board assembly to
assist in development. It is not
required to operate the SB72. The
adapter board includes a switching power supply, RS-232 level
shifters and two DB-9 connectors.
• CD-ROM containing source code,
development tools, manuals and
documentation.
• Cross-wired and straight-through
twisted pair network cables
• Serial cable
• 12 VDC power supply (US and
Canada only)
Processor
• 32-bit Motorola ColdFire 5272 with
integrated 10/100 Ethernet MAC
Network Interface
• 10/100BaseT with RJ-45 connector
Network Protocols
• ARP
• BOOTP
• DHCP
• TCP
• UDP
• ICMP
• HTTP
• FTP
• POP3
• IGMP V2
• PPP
• SMTP
• DNS
• SNMP
Network Services
• Email
• Web Server
• Telnet
• Multicast
• Ping
SNMP
SNMP is an optional software
module and includes:
• SNMP V1, MIBII
• MIB Compiler generator
Utilities
• Single build command to compile,
link, process HTML code, network
download to flash, program flash,
and reboot target board in just
seconds.
• Automatic compile and processing
of dynamic HTML and Java
• Network device configuration
• Flash memory updates
uC/OS Real-Time OS
• Preemptive, priority scheduling
• Semaphores
• Mail Boxes
• Message Queues
• FIFO’s
• Timers
• Stack Checking
• Task debugging tools
Web Server
• Supports Dynamic HTML
• Supports Forms, Cookies and
Passwords
• A project directory of HTML
documents, gifs, and JAVA classes is
compressed into a file that is embedded in the run-time application
Email
• Send and receive email through an
Ethernet or PPP connection
Runtime Environment
• Complete I/O system supports TCP,
Telnet, and both Serial ports. I/O
includes read, write, select, fprintf and
fscanf functionality
• User Parameter Flash storage routines
• Applications are stored compressed
in on-board Flash, and decompressed
into RAM at start up. This provides
the same environment for RAM based
debugging and the end application.
Reduces the risk of releasing your
product. It runs like it was built
• Embedded Monitor supports serial
and network code updates
• Programmable default exception
handling
Contact Information
NetBurner, Inc.
5405 Morehouse Drive, Ste 350
San Diego, CA 92121
858.558.0293 phone
858-558-8549 fax
sales@netburner.com
http://www.netburner.com
e t B u r n e r
© 2002 NetBurner, Inc. Specificatons are subject to change without notice. Every effort has been made to ensure all information is correct, but
NetBurner, Inc. is not responsible for inadvertant errors. ColdFire is a trademark of Motorola Corp.
很抱歉,暂时无法提供与“NNDK-SB72-KIT”相匹配的价格&库存,您可以联系我们找货
