Qualia Bare Driver Board for LP097QX1
Display
PRODUCT ID: 1716
The Qualia Retina driver board is a work of art (it was designed by resident
engineer KTOWN). It's used in the Adafruit Qualia 9.7" DisplayPort Monitor
Kit and we use the really awesome LT3754 as a 12-channel constant current
driver with individual backlight string channel control. This gives the backlight
perfect consistency over any usage or temperature range. A ATtiny85 handles
the backlight dimming and soft on/off, so you can PWM the backlight over a
range to get the look you want.
This driver is available for advanced users only! The Molex connector that is
used to connect to the LG display is insanely delicate and breaks very very very
easily if you are not very careful! If you order this driver board and break the
connector, it may no longer work and we cannot repair it. If you break it you
may have to buy another driver. We do not offer any returns, refunds or
replacements! Do not purchase if you are not comfortable with this risk!
If you'd like a plug-n-play, easy to use kit with the TFT already attached to the
delicate connector, please purchase our Qualia kit!
TECHNICAL DETAILS
Dimensions: 45mm x 85mm / 1.8" x 3.4"
Mounting Holes Distance: 37mm x 77mm / 1.5" x 3"
Weight: 21g
https://www.adafruit.com/product/1716/12‐11‐18
很抱歉,暂时无法提供与“1716”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1508.11200
- 200+601.74360
- 500+581.64480
- 1000+571.70880
