ISD-ES1600B-PROG
ISD-ES1600B-PROG
    NUVOTON(新唐)
    ISD1600 Series ChipCorder® Series Audio, Voice Record/Playback Evaluation Board
ISD-ES1600B-PROG 数据手册
Nuvoton ChipCorder® 16xx Family Programmer Demo Board User Guide ISD-ES1600B-Prog Rev 2.0 Instructions www.Nuvoton-usa.com 1 The ISD-ES1600B-Prog board allows the programming of PCM audio files to the Nuvoton I1600B (ISD1600b/12B/16B/20B) ChipCorder® IC controlled through the USB port of a PC. The record and playback functions of the chip may be selected in real time to demonstrate different sampling rates and playback quality of this chip for an end application. The PC connects to the demo board using a standard USB cable. (Not included in the package) Hardware / Software Requirements The ISD-ES1600B-Prog board must be connected to a USB port on a PC running Windows 2000 or higher that supports Microsoft’s .NET framework v1.1 or higher. Software Installation If necessary, install .NET frameworks, which is included on the CD. Insert the CD. The installation should start automatically. If it does not, run setup.msi from the CD. It is recommended to use the default installation options during setup. After the installation is completed, the “ISD-ES1600B-Prog” application program can be started from the Start Menu. The demo board should be connected to the USB port prior to running the application. Hardware Installation The first time the I16xx-Prog board is plugged into the USB port, Windows will begin a search for an appropriate driver for: “ISD-ES1600B-Prog”. Let the wizard search for compatible drivers automatically. If the wizard finds multiple compatible drivers, use “ttsbench.inf” found in the “..\windows\system32\drivers” directory. Jumper Settings J4: Sample rate selector Connect pins 1-2 for 12 kHz Connect pins 3-4 for 8.0 kHz Connect pins 5-6 for 6.4 kHz Connect pins 7-8 for 5.3 kHz Connect pins 9-10 for 4.0 kHz www.Nuvoton-usa.com 2 ChipCorder® ISD-ES1600B-Prog Software Operation Before starting the ISD-ES1600B-Prog software application, make sure that the demo board is plugged into one of the PC’s USB ports and properly installed. Once the software starts, it will attempt to locate the demo board, but if no board is detected, an error message will be displayed. If so, it will be necessary to restart the software. If detection of the board is successful, the main control panel will be displayed. The controls allow selection of the chip device, sample rate, volume decimation, and audio file to be recorded. However, the input audio file must be 8 kHz, 16-bit mono PCM. To program the chip with an audio file, first select an audio file with the “browse” button or scroll through the “wave file” combo box for previously selected files. Recording will begin once the “Record” button is pressed, which will disable the “Record” and “Playback” buttons until the entire audio file is streamed to the board in real time. If the “Record Monitor” checkbox is checked, the audio file will be played through the PC’s speakers while the audio file is being streamed. Volume decimation is also possible by choosing the desired recording level on the volume slider. Note that high decimation levels will decrease audio quality. To decrease volume and maintain quality, create a new PCM audio file at the appropriate volume level. Playback of the ChipCorder® is available via the “Play” button, while the “Stop” button will stop both record and playback operations and set the ChipCorder® back to the idle state. Be aware that the ChipCorder® will only record up to its duration, and if the length of the audio file is greater than the available duration, the extra length at the end of the audio file will be omitted when playback is initiated. www.Nuvoton-usa.com 3 It is also possible to record a particular region within the audio file, by either specifying the beginning and ending time points, or dragging the selection tool on the waveform display graph. ChipCorder® ISD-ES1600B-Prog Board Schematics Note that on the PCB both SOIC and PDIP Socket foot prints are available only the PDIP is populated. In www.Nuvoton-usa.com 4 VCC5 ADD POWER CONNECTOR VCC33 U1 R1 1 6 2 ON/OFF VIN 5 3 GND1 GND2 4 NR VO C2 22UF 1 VCC 2 A0 WP 3 A1 SCL 4 A2 GND SDA .1UF C9 6 4 A B GND GND VCC5 U2 .1UF DUTON SCL SDA 1 6 2 ON/OFF VIN 5 3 GND1 GND2 4 NR VO VCC_DUT_3_3 PQ1R33 24LC64 U4 .1UF 8 7 6 5 C5 C8 5 2 C4 22UF .1UF .1UF C10 .1UF SN65220 J4 VCC_DUT_3_3 DMINUS DPLUS C20 12PF 12PF 1 TP10 .1UF .1UF VCC33 IPAD CY7C6471X_QFN R1 1.5K SCL R2 1.5K SDA CP-3502-ND J1 VCC_DUT_3_3 J2 TP3 TP4 TP5 TP6 TP7 TP8 TP9 35 34 33 32 31 30 29 CON10A C24 3 R19 1 2 3 4 5 6 7 8 RECB PLAYEB PLAYLB VSSD LED REC VCCD PLAYE ROSC PLAYL AUD VSSA AGC MIC+ SP+ MIC- VCCA SP- VSSAD 16 15 14 13 12 11 10 9 RESB TDI TMS TCK 1 2 3 4 5 6 C29 IO 44 /G C K 2 IO 43 /G C K 1 IO 42 IO 41 IO 40 IO 39 IO 38 IO 37 IO 36 /G T S 1 V C C IN T 2 IO 34 /G T S 2 C26 C27 C28 VCC33 C22 C23 .1UF .1UF .1UF .1UF .1UF .1UF U7 100K U8 10K R8 R9 IO33/GSR IO32 IO31 IO30 IO29 IO28 IO27 VCCIO GND TDO IO23 33 32 31 30 29 28 27 26 25 24 23 AOP AOM FSR PCMR BCLK FSR PCMR BCLK DUTEN R16 R17 R18 22 22 22 1 2 3 4 5 6 7 8 9 10 VREF VAG ROAI+ PAI AIPAOAO PAO+ HB VDD VSS FSR FST PCMR PCMT BCLKR BCLKT PUI MCLK W681360 TDO XC9572XL-VQ44 D4 D3 D2 D1 D0 D5 CON6 D7 D6 12 13 14 15 16 17 18 19 20 21 22 TMS TDI TDO TCK IO1/GCK3 IO2 IO3 GND1 IO5 IO6 IO7 IO8 TDI TMS TCK IO 12 IO 13 IO 14 V C C IN T 1 IO 16 GND2 IO 18 IO 19 IO 20 IO 21 IO 22 2 VCC33 J3 VCC33 22 1 2 3 4 5 6 7 8 9 10 11 .1UF .1UF R11 60.4K C25 4.7UF WEB CTL0 CTL1 CTL2 C22 U9 FSR CTL2 CTL1 CTL0 Y2 CMX309FLC4.096MT C21 1UF ISD1620 SOP 44 43 42 41 40 39 38 37 36 35 34 OUT 2 4 6 8 10 1 D3 1N914 1 3 5 7 9 42 41 40 39 38 37 RD Y0 RD Y1 4 VCC EN GND 1 2 2 C19 4.7UF VCC5 .1UF D2 LED 2 3 RESET GND PA7/*FLAGD/SLCS PA6/*PKTEND PA5/FIFOADR1 PA4/FIFOADR0 PA3/*WU2 PA2/*SLOE PA1/INT1 PA0/INT0 VCC CTL2/*FLAGC CTL1/*FLAGB CTL0/*FLAGA C25 D1 LED 16 15 14 13 12 11 10 9 ISD1620 DIP 56 55 54 53 52 51 50 49 48 47 46 45 44 43 RDY0/SLRD RDY1/SLWR AVCC XTALOUT XTALIN AGND AVCC DPLUS DMINUS AGND VCC GND IFCLK/*PE0/T0OUT RES 57 C16 .1UF .1UF C18 SCL SDA VCC P B 0 /F D 0 P B 1 /F D 1 P B 2 /F D 2 P B 3 /F D 3 P B 4 /F D 4 P B 5 /F D 5 P B 6 /F D 6 P B 7 /F D 7 GND VCC GND DPLUS DMINUS C21 C15 .1UF C17 AOM 15 16 17 18 19 20 21 22 23 24 25 26 27 28 24MHZ C14 .1UF R10 100K GND VC C C LK O U T /* P E 1 /T 1O U T GND P D 7 /F D 1 5 P D 6 /F D 1 4 P D 5 /F D 1 3 P D 4 /F D 1 2 P D 3 /F D 1 1 P D 2 /F D 1 0 P D 1/F D 9 P D 0/F D 8 *W A KE U P VC C 1 2 3 4 5 6 7 8 9 10 11 12 13 14 C13 AOP VSSD LED REC VCCD PLAYE ROSC PLAYL AUD VSSA AGC MIC+ SP+ MIC- VCCA SP- VSSAD D0 D1 D2 D3 D4 D5 D6 D7 RDY0 RDY1 .1UF 12KHz DUTON PLAYLB PLAYEB R EC B D UTEN R ESB W EB VCC33 Y1 1 2 3 4 5 6 7 8 RECB PLAYEB PLAYLB R7 1.5K U6 C12 .1UF U5 VCC33 TP1 TP2 C11 R20 1K 1 R5 1K CONUSBB www.Nuvoton-usa.com 5 20 19 18 17 16 15 14 13 12 11 R12 80.6K R13 100K 4KHz 22 22 5 .3 K H z R3 R4 6 .4 K H z 1 2 3 4 5 6 VCC USBDUSBD+ GND SHELL SHELL 8KHz C8 22UF C1 U2 R2 0 C3 PQ1R33 C7 .1UF 0 VCC33 R14 120K R15 160K
ISD-ES1600B-PROG 价格&库存
很抱歉,暂时无法提供与“ISD-ES1600B-PROG”相匹配的价格&库存,您可以联系我们找货
ISD-ES1600B-PROG
    • 1+6012.60840
    • 200+2399.06880
    • 500+2318.90040
    • 1000+2279.29680
